01-HH3C-SPB-MIB | 74.74 KB |
HH3C-SPB-MIB
About this MIB
Use this MIB to management the global SPBM status, interface-specific SPBM status, and B-VLAN and SPBM multicast replication mode of a VSI.
MIB file name
hh3c-spb.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSpb(128)
Scalar objects
hh3cSpbSysStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSpbSysStatus (1.3.6.1.4.1.25506.2.128.1.1.1) |
read-write |
INTEGER |
enabled(1) disabled(2) |
Global SPBM status. |
As per the MIB. |
hh3cSpbMulticastBVlanStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSpbMulticastBVlanStatus (1.3.6.1.4.1.25506.2.128.1.1.2) |
read-write |
INTEGER |
Global multicast B-VLAN status. |
As per the MIB. |
Tabular objects
hh3cSpbIfTable
About this table
Use this table to obtain the status of SPBM on an interface.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSpbIfStatus (1.3.6.1.4.1.25506.2.128.1.2.1.1.1) |
read-write |
INTEGER |
SPBM status. |
As per the MIB. |
hh3cSpbSrvTable
About this table
Use this table to manage B-VLAN and SPBM multicast replication mode settings of a VSI.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are h3cSpbSrvTableEntryTopIx and h3cSpbSrvTableEntryIsid.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSpbSrvTableEntryTopIx (1.3.6.1.4.1.25506.2.128.1.2.2.1.1) |
not-accessible |
Unsigned32 |
Standard MIB values. |
Topology ID. |
As per the MIB. |
hh3cSpbSrvTableEntryIsid(1.3.6.1.4.1.25506.2.128.1.2.2.1.2) |
not-accessible |
Unsigned32 |
Unsigned32(255..16777215) |
I-SID. |
As per the MIB. |
hh3cSpbSrvTableEntryBaseVid(1.3.6.1.4.1.25506.2.128.1.2.2.1.3) |
read-write |
VlanIdOrNone |
Integer32 (0 | 1..4094) |
B-VLAN. |
As per the MIB. |
hh3cSpbSrvTableEntryMode(1.3.6.1.4.1.25506.2.128.1.2.2.1.4) |
read-write |
INTEGER |
headEnd(1) tandem(2) |
SPBM multicast replication mode. |
As per the MIB. |
Notifications
hh3cSpbSPSourceConflictTrap
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.128.1.3.0.1 |
SPSource ID conflict. |
Fault alarm |
Notification |
ON |
This notification is generated if a remote SPSource ID and the local SPSource ID are identical.
Status control
ON
CLI: Use the snmp-agent trap enable spbm spsource-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable spbm spsource-conflict command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.128.1.3.1.1 (hh3cSpbConflictSysID) |
Remote SPSource ID. |
No |
MacAddress |
OCTET STRING (6) |
1.3.6.1.4.1.25506.2.128.1.3.1.2 (hh3cSpbConflictSPSourceID) |
Conflicted SPSource ID. |
No |
IEEE8021SpbmSPsourceId |
OCTET STRING (3) |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
Modify the local or remote SPSource ID.
If you cannot resolve the issue, contact H3C Support.
hh3cSpbBMacConflictTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.128.1.3.0.2 |
B-MAC conflict. |
Fault alarm |
Notification |
ON |
This notification is generated if a remote B-MAC and the local B-MAC are identical.
Status control
ON
CLI: Use the snmp-agent trap enable spbm b-mac-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable spbm b-mac-conflict command.
Objects
OID (object name) |
Index |
Type |
Value range |
No |
MacAddress |
OCTET STRING (6) |
1.3.6.1.4.1.25506.2.128.1.3.1.3 (hh3cSpbConflictBMac) |
Conflicted B-MAC. |
No |
MacAddress |
OCTET STRING (6) |
Recommended action
Modify the local or remote B-MAC.
