- 07-Layer 3 - IP Services
- 01-HH3C-ARP-RATELIMIT-MIB
- 02-HH3C-ARP-SUPPRESSION-MIB
- 03-HH3C-ARP-TRAP-MIB
- 04-HH3C-DHCP4-MIB
- 05-HH3C-DHCP-SNOOP2-MIB
- 06-HH3C-DNS-MIB
- 07-HH3C-FIB-MIB
- 08-HH3C-IP-ADDRESS-MIB
- 09-HH3C-IPV6-ADDRESS-MIB
- 10-HH3C-ND-TRAP-MIB
- 11-HH3C-TCP-MIB
- 12-HH3C-TUNNEL-TRAP-MIB
- 13-IP-FORWARD-MIB
- 14-IP-MIB
- 15-IPV6-ICMP-MIB
- 16-IPV6-MIB
- 17-IPV6-TCP-MIB
- 18-IPV6-UDP-MIB
- 19-TCP-MIB
- 20-UDP-MIB
12-HH3C-TUNNEL-TRAP-MIB | 47.30 KB |
About this MIB
Use this MIB to output notifications for the tunnel module.
MIB file name
hh3c-tunnel-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cTunnelTrap(226)
Notifications
hh3cTunnelTrapVxlanStatusUp
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.226.1.1.0.1 |
A VXLAN tunnel came up. |
Error |
Warning |
N/A |
OFF |
This notification is generated when a VXLAN tunnel comes up at the link layer.
Status control
ON
CLI: Use the snmp-agent trap enable tunnel vxlan-tunnel-status command.
OFF
CLI: Use the undo snmp-agent trap enable tunnel vxlan-tunnel-status command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.226.1.1.1.1 (hh3cTunnelTrapVxlanStatusSType) |
Tunnel source address type. |
No |
INTEGER |
unknown(0), ipv4(1), ipv6(2) |
1.3.6.1.4.1.25506.2.226.1.1.1.2 (hh3cTunnelTrapVxlanStatusSrcIP) |
Tunnel source address. |
No |
InetAddress |
OCTET STRING (0..255) |
1.3.6.1.4.1.25506.2.226.1.1.1.3 (hh3cTunnelTrapVxlanStatusDType) |
Tunnel destination address type. |
No |
INTEGER |
1.3.6.1.4.1.25506.2.226.1.1.1.4 (hh3cTunnelTrapVxlanStatusDstIP) |
Tunnel destination address. |
No |
InetAddress |
Recommended action
No action is required.
hh3cTunnelTrapVxlanStatusDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.226.1.1.0.2 |
A VXLAN tunnel went down. |
Error |
Warning |
N/A |
OFF |
This notification is generated when a VXLAN tunnel goes down at the link layer.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
No |
INTEGER |
No |
InetAddress |
No |
INTEGER |
No |
InetAddress |
Recommended action
