- 07-Layer 3 - IP Services
- 01-HH3C-ARP-RATELIMIT-MIB
- 02-HH3C-ARP-SUPPRESSION-MIB
- 03-HH3C-ARP-TRAP-MIB
- 04-HH3C-DHCP4-MIB
- 05-HH3C-DHCP-SNOOP2-MIB
- 06-HH3C-DNS-MIB
- 07-HH3C-FIB-MIB
- 08-HH3C-IP-ADDRESS-MIB
- 09-HH3C-IPV6-ADDRESS-MIB
- 10-HH3C-ND-TRAP-MIB
- 11-HH3C-TCP-MIB
- 12-HH3C-TUNNEL-TRAP-MIB
- 13-IP-FORWARD-MIB
- 14-IP-MIB
- 15-IPV6-ICMP-MIB
- 16-IPV6-MIB
- 17-IPV6-TCP-MIB
- 18-IPV6-UDP-MIB
- 19-TCP-MIB
- 20-UDP-MIB
07-HH3C-FIB-MIB | 50.21 KB |
HH3C-FIB-MIB
About this MIB
Use this MIB to detect whether the number of FIB entries reaches the threshold and whether the messages to be forwarded on the module are congested.
MIB file name
hh3c-fib.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cFibTrap(216)
Notifications
hh3cFibBoardMsgCongestResume
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.216.1.0.2 |
The module recovered from a message congestion alarm. |
Informational |
Event |
N/A |
On |
This notification is generated when the module recovers from a message congestion alarm.
Status control
ON
CLI: Use the snmp-agent trap enable fib command.
OFF
CLI: Use the undo snmp-agent trap enable fib command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.216.1.1.1 (hh3cFibChassisID) |
Chassis number. |
No |
Unsigned32 |
Standard MIB values. |
1.3.6.1.4.1.25506.2.216.1.1.2 (hh3cFibSlotID) |
Slot number. |
No |
Unsigned32 |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
hh3cFibOverloadForward
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.216.2.0.1 |
The number of FIB entries on the device exceeded the threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.216.2.0.2 (hh3cFibOverloadForwardResume) |
On |
This notification is generated when the number of FIB entries on the device exceeds the threshold.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.216.2.1.1 (hh3cFibOverloadModule) |
Module name (FIB4/FIB6) |
No |
OCTET STRING |
OCTET STRING (0..255) |
Recommended action
Check whether the network is attacked.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.216.2.0.2 |
The device recovered from a FIB entry capacity usage alarm. |
Informational |
Event |
N/A |
On |
This notification is generated when the device recovers from a FIB entry capacity usage alarm.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Module name (FIB4/FIB6). |
No |
OCTET STRING |
Recommended action
