- 07-Layer 3 - IP Services
- 01-HH3C-ARP-RATELIMIT-MIB
- 02-HH3C-ARP-SUPPRESSION-MIB
- 03-HH3C-ARP-TRAP-MIB
- 04-HH3C-DHCP4-MIB
- 05-HH3C-DHCP-SNOOP2-MIB
- 06-HH3C-DNS-MIB
- 07-HH3C-FIB-MIB
- 08-HH3C-IP-ADDRESS-MIB
- 09-HH3C-IPV6-ADDRESS-MIB
- 10-HH3C-ND-TRAP-MIB
- 11-HH3C-TCP-MIB
- 12-HH3C-TUNNEL-TRAP-MIB
- 13-IP-FORWARD-MIB
- 14-IP-MIB
- 15-IPV6-ICMP-MIB
- 16-IPV6-MIB
- 17-IPV6-TCP-MIB
- 18-IPV6-UDP-MIB
- 19-TCP-MIB
- 20-UDP-MIB
02-HH3C-ARP-SUPPRESSION-MIB | 38.21 KB |
About this MIB
Use this MIB to realize the ARP suppression feature.
MIB file name
hh3c-arp-suppression.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cARPSuppression(220)
Tabular objects
hh3cARPSuppressionVsiTable
About this table
This table obtains ARP suppression entries based on VSIs.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cARPSuppressionChassis, hh3cARPSuppressionSlot, hh3cARPSuppressionVsiName, and hh3cARPSuppressionIpAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cARPSuppressionChassis (1.3.6.1.4.1.25506.2.220.1.1.1) |
not-accessible |
Unsigned32 |
Standard MIB values. |
Chassis number. |
As per the MIB. |
hh3cARPSuppressionSlot (1.3.6.1.4.1.25506.2.220.1.1.2) |
not-accessible |
Unsigned32 |
Slot number. |
As per the MIB. |
hh3cARPSuppressionVsiName (1.3.6.1.4.1.25506.2.220.1.1.3) |
not-accessible |
DisplayString |
OCTET STRING(31) |
VSI instance name. |
As per the MIB. |
hh3cARPSuppressionIpAddr (1.3.6.1.4.1.25506.2.220.1.1.4) |
not-accessible |
IpAddress |
IP address. |
As per the MIB. |
hh3cARPSuppressionMacAddr (1.3.6.1.4.1.25506.2.220.1.1.5) |
read-only |
MacAddress |
OCTET STRING (6) |
MAC address. |
As per the MIB. |
hh3cARPSuppressionLinkID (1.3.6.1.4.1.25506.2.220.1.1.6) |
read-only |
Unsigned32 |
Link ID. |
As per the MIB. |
hh3cARPSuppressionAging (1.3.6.1.4.1.25506.2.220.1.1.7) |
read-only |
Unsigned32 |
Aging timer. |
As per the MIB. |
