- 07-Layer 3 - IP Services
- 01-HH3C-ARP-RATELIMIT-MIB
- 02-HH3C-ARP-SUPPRESSION-MIB
- 03-HH3C-ARP-TRAP-MIB
- 04-HH3C-DHCP4-MIB
- 05-HH3C-DHCP-SNOOP2-MIB
- 06-HH3C-DNS-MIB
- 07-HH3C-FIB-MIB
- 08-HH3C-IP-ADDRESS-MIB
- 09-HH3C-IPV6-ADDRESS-MIB
- 10-HH3C-ND-TRAP-MIB
- 11-HH3C-TCP-MIB
- 12-HH3C-TUNNEL-TRAP-MIB
- 13-IP-FORWARD-MIB
- 14-IP-MIB
- 15-IPV6-ICMP-MIB
- 16-IPV6-MIB
- 17-IPV6-TCP-MIB
- 18-IPV6-UDP-MIB
- 19-TCP-MIB
- 20-UDP-MIB
11-HH3C-TCP-MIB | 41.93 KB |
HH3C-TCP-MIB
About this MIB
Use this MIB to test whether the MD5 authentication for the current TCP connection is successful.
MIB file name
hh3c-tcp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cTcp(215)
Notifications
This section contains HH3C-TCP-MIB notifications.
hh3cTcpMD5AuthenFail
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.215.1.0.1 |
TCP connection MD5 authentication failed. |
Error |
Warning |
N/A |
ON |
This notification is generated when MD5 authentication of the current TCP connection fails.
Status control
ON
CLI: Use the snmp-agent trap enable tcp command.
OFF
CLI: Use the undo snmp-agent trap enable tcp command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.215.1.1.1 (hh3cTcpConnLocalAddressTCP) |
Local IP address of the TCP connection |
No |
OCTET STRING |
OCTET STRING (0..255) |
1.3.6.1.4.1.25506.2.215.1.1.2 (hh3cTcpConnLocalPortTCP) |
Local port number of the TCP connection |
No |
Integer32 |
Integer32(0..65535) |
1.3.6.1.4.1.25506.2.215.1.1.3 (hh3cTcpConnRemAddressTCP) |
Remote IP address of the TCP connection |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.215.1.1.4 (hh3cTcpConnRemPortTCP) |
Remote port number of the TCP connection |
No |
Integer32 |
1.3.6.1.4.1.25506.2.215.1.1.5 (hh3cTcpProtocol) |
Name of the upper layer protocol of TCP |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.215.1.1.6 (hh3cTcpVrfNameVRF) |
Name of the VRF of the TCP connection |
No |
OCTET STRING |
Recommended action
Check whether the network is under a packet attack.
