- 07-Layer 3 - IP Services
- 01-HH3C-ARP-RATELIMIT-MIB
- 02-HH3C-ARP-SUPPRESSION-MIB
- 03-HH3C-ARP-TRAP-MIB
- 04-HH3C-DHCP4-MIB
- 05-HH3C-DHCP-SNOOP2-MIB
- 06-HH3C-DNS-MIB
- 07-HH3C-FIB-MIB
- 08-HH3C-IP-ADDRESS-MIB
- 09-HH3C-IPV6-ADDRESS-MIB
- 10-HH3C-ND-TRAP-MIB
- 11-HH3C-TCP-MIB
- 12-HH3C-TUNNEL-TRAP-MIB
- 13-IP-FORWARD-MIB
- 14-IP-MIB
- 15-IPV6-ICMP-MIB
- 16-IPV6-MIB
- 17-IPV6-TCP-MIB
- 18-IPV6-UDP-MIB
- 19-TCP-MIB
- 20-UDP-MIB
10-HH3C-ND-TRAP-MIB | 121.53 KB |
HH3C-ND-TRAP-MIB
About this MIB
Use this MIB to obtain information about ND entry learning threshold and packet conflict related alarms.
MIB file name
hh3c-nd-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2). hh3cNDTrap(218)
Notifications
This section contains HH3C-ND-TRAP-MIB notifications.
hh3cNDTrapAllThresholdExceed
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.218.1.0.1 |
Number of global ND entries exceeded the alarm threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.218.1.0.2 (hh3cNDTrapThresholdResume) |
OFF |
This notification is generated when the number of ND entries on the device exceeds the alarm threshold.
Status control
ON
CLI: Use the ipv6 nd entry-limit record enable command.
OFF
CLI: Use the undo ipv6 nd entry-limit record enable command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.218.1.1.4 (hh3cNDTrapEntryThreshold) |
Alarm threshold for the number of global ND entries. |
No |
Unsigned32 |
Standard MIB values. |
1.3.6.1.4.1.25506.2.218.1.1.5 (hh3cNDTrapEntryDynamicNum) |
Number of dynamic ND entries. |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.218.1.1.6 |
Number of static ND entries. |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.218.1.1.7 |
Number of other ND entries. |
No |
Unsigned32 |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
Delete the useless dynamic ND entries on the device. If the current alarm threshold value is too small, increase the threshold value as appropriate.
hh3cNDTrapAllThresholdResume
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.218.1.0.6 |
The number of ND entries dropped below the threshold. |
Informational |
N/A |
N/A |
OFF |
This notification is generated when the number of ND entries on the device drops below the alarm threshold.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.218.1.1.4 |
No |
Unsigned32 |
No |
Unsigned32 |
No |
Unsigned32 |
No |
Unsigned32 |
Recommended action
No action is required.
hh3cNDTrapSlotThresholdExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.218.1.0.3 |
The number of ND entries on the current card exceeded the alarm threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.218.1.0.4 (hh3cNDTrapSlotThresholdResumeAlarm) |
OFF |
This notification is generated when the number of the dynamic ND entries on a card reaches or exceeds the alarm threshold.
Status control
ON
OFF
Status control
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.218.1.1.1 (hh3cNDTrapEntryChassis) |
Chassis number. |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.218.1.1.2 (hh3cNDTrapEntrySlot) |
Slot number. |
No |
Unsigned32 |
Alarm threshold for the number of ND entries on the card. |
No |
Unsigned32 |
No |
Unsigned32 |
Recommended action
Delete the useless dynamic ND entries on the card. If the current alarm threshold value is too small, increase the threshold value as appropriate.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.218.1.0.4 |
The number of ND entries on the current card dropped below the alarm threshold. |
Informational |
N/A |
N/A |
ON |
This notification is generated when the number of dynamic ND entries on the card drops below the alarm threshold.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis number. |
No |
Unsigned32 |
Slot number. |
No |
Unsigned32 |
No |
Unsigned32 |
No |
Unsigned32 |
Recommended action
hh3cNDTrapIfThresholdExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.218.1.0.5 |
The number of ND entries on the interface exceeded the alarm threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.218.1.0.6 (hh3cNDTrapIfThresholdResumeAlarm) |
OFF |
This notification is generated when the number of dynamic ND entries on an interface exceeds the alarm threshold.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.218.1.1.3 (hh3cNDTrapEntryIfName) |
Interface name |
No |
DisplayString |
OCTET STRING (1:0..255) |
Alarm threshold for the number of ND entries on the interface. |
No |
Unsigned32 |
No |
Unsigned32 |
Recommended action
Delete the useless dynamic ND entries on the interface. If the current alarm threshold value is too small, increase the threshold value as appropriate.
Basic information
OID |
Event |
Type |
Severity |
Default status |
The number of ND entries on the interface dropped below the alarm threshold. |
Informational |
N/A |
N/A |
ON |
This notification is generated when the number of dynamic ND entries on an interface drops below the alarm threshold.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Interface name |
No |
DisplayString |
No |
Unsigned32 |
No |
Unsigned32 |
Recommended action
hh3cNDTrapSuppThresholdExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.218.1.0.7 |
The number of ND suppression entries on the device exceeded the alarm threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.218.1.0.8 (hh3cNDTrapSuppThresholdResumeAlarm) |
ON |
This notification is generated when the number of ND suppression entries on the device exceeds the alarm threshold.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Alarm threshold for the number of ND suppression entries on the device |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.218.1.1.8 (hh3cNDTrapEntrySuppNum) |
Number of ND suppression entries on the device |
No |
Unsigned32 |
Recommended action
Delete the useless ND suppression entries on the device. If the current alarm threshold value is too small, increase the threshold value as appropriate.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.218.1.0.8 |
The number of ND suppression entries on the device dropped below the alarm threshold. |
Informational |
N/A |
N/A |
ON |
This notification is generated when the number of ND suppression entries on the device drops below the alarm threshold.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
No |
Unsigned32 |
No |
Unsigned32 |
Recommended action
hh3cNDTrapPktSpeedAlarm
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.218.2.0.1 |
The sending rate for ND packets or ND Miss packets exceeded the alarm threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.218.2.0.2 (hh3cNDTrapPktSpeedAlarmResume) |
OFF |
This notification is generated when the ND packets or ND Miss packets sending rate exceeds the alarm threshold.
Status control
ON
CLI: Use the snmp-agent trap enable nd nd-miss command.
OFF
CLI: Use the undo snmp-agent trap enable nd nd-miss command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.218.2.1.1 |
Chassis number |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.218.2.1.2 (hh3cNDTrapPktSpeedSlot) |
Slot number. |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.218.2.1.3 |
Alarm threshold of packet sending rate. |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.218.2.1.4 |
Current packet sending rate. |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.218.2.1.5 |
Packet type: ND, or ND-Miss. |
No |
OCTET STRING |
OCTET STRING (1:1..48) |
Recommended action
Check whether an attack or a loop exists on the network.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.218.2.0.2 |
The sending rate for ND packets or ND Miss packets dropped below the alarm threshold. |
Informational |
N/A |
N/A |
OFF |
This notification is generated when the ND packets or ND Miss packets sending rate on an interface drops below the alarm threshold.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Chassis number |
No |
Unsigned32 |
Slot number. |
No |
Unsigned32 |
No |
Unsigned32 |
No |
Unsigned32 |
No |
OCTET STRING |
Recommended action
hh3cNDTrapHostIPConflict
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.218.2.0.3 |
Local IPv6 address conflicted. |
Error |
Warning |
1.3.6.1.4.1.25506.2.218.2.0.4 (hh3cNDTrapHostIPConflictResume) |
ON |
This notification is generated when an interface receives a packet whose source IPv6 address is the same as the local interface IPv6 address.
Status control
ON
CLI: Use the snmp-agent trap enable nd local-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable nd local-conflict command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.218.2.2.1 (hh3cNDTrapHostIPCftLocalIPv6) |
IPv6 address of the interface. |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.218.2.2.2 (hh3cNDTrapHostIPCftLocalMAC) |
MAC address of the interface. |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.218.2.2.3 (hh3cNDTrapHostIPCftLocalIf) |
Name of the interface. |
No |
DisplayString |
OCTETSTRING (1: 0..255) |
1.3.6.1.4.1.25506.2.218.2.2.4 (hh3cNDTrapHostIPCftLocalPevid) |
Outer VLAN ID of the interface. |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.218.2.2.5 (hh3cNDTrapHostIPCftLocalCevid) |
Inner VLAN ID of the interface. |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.218.2.2.6 (hh3cNDTrapHostIPCftRemoteIPv6) |
Remote IPv6 address. |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.218.2.2.7 (hh3cNDTrapHostIPCftRemoteMAC) |
Remote MAC address. |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.218.2.2.8 (hh3cNDTrapHostIPCftRemotePevid) |
Remote outer VLAN ID. |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.218.2.2.9 (hh3cNDTrapHostIPCftRemoteCevid) |
Remote inner VLAN ID. |
No |
Unsigned32 |
Recommended action
Check whether an ND attack exists on the network.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.218.2.0.4 |
The local IPv6 address conflict was removed. |
Informational |
N/A |
N/A |
OFF |
This notification is generated when the local IPv6 address conflict on an interface is removed. A conflict on an interface is removed if the interface does not receive the same conflict within three minutes.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
No |
OCTET STRING |
No |
OCTET STRING |
No |
DisplayString |
No |
Unsigned32 |
No |
Unsigned32 |
No |
OCTET STRING |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.218.2.2.9 (hh3cNDTrapHostIPCftRemotePevid) |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.218.2.2.10 (hh3cNDTrapHostIPCftRemoteCevid) |
No |
Unsigned32 |
Recommended action
hh3cNDTrapDuplicateIPv6
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.218.2.0.5 |
User IPv6 address conflicted. |
Error |
Warning |
N/A |
OFF |
This notification is generated when a user IPv6 address conflict occurs. A conflict occurs if an incoming NA packet has the same source IPv6 address as an existing ND entry but a different source MAC address.
Status control
ON
CLI: Use the snmp-agent trap enable nd user-ip-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable user-ip-conflict command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.218.2.3.1 (hh3cNDTrapDupIPv6NewMac) |
MAC address of the new user. |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.218.2.3.2 (hh3cNDTrapDupIPv6NewSevid) |
Outer VLAN ID of the new user. |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.218.2.3.3 (hh3cNDTrapDupIPv6NewCevid) |
Inner VLAN ID of the new user. |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.218.2.3.4 (hh3cNDTrapDupIPv6NewIFName) |
Interface name of the new user. |
No |
DisplayString |
1.3.6.1.4.1.25506.2.218.2.3.5 (hh3cNDTrapDupIPv6OldMac) |
MAC address of the old user. |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.218.2.3.6 (hh3cNDTrapDupIPv6OldSevid) |
Outer VLAN ID of the old user. |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.218.2.3.7 (hh3cNDTrapDupIPv6OldCevid) |
Inner VLAN ID of the old user. |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.218.2.3.8 (hh3cNDTrapDupIPv6OldIFName) |
Interface name of the old user. |
No |
DisplayString |
1.3.6.1.4.1.25506.2.218.2.3.9 (hh3cNDTrapDupIPv6DupAddr) |
Conflicted IPv6 address. |
No |
OCTET STRING |
Recommended action
Check whether an ND packet attack or a loop exists on the network.
hh3cNDTrapRatelimitOverspeed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.218.2.0.6 |
The sending rate for ND packets exceeded the rate limit. |
Informational |
N/A |
N/A |
OFF |
This notification is generated when the sending rate for ND packets exceeds the rate limit.
Status control
ON
CLI: Use the snmp-agent trap enable nd rate-limit command.
OFF
CLI: Use the undo snmp-agent trap enable nd rate-limit command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.218.2.4.1 (hh3cNDTrapRatelimitVer) |
Notification version. |
No |
Unsigned32 |
1 |
1.3.6.1.4.1.25506.2.218.2.4.2 (hh3cNDTrapRatelimitCount) |
Rate limit. |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.218.2.4.3 (hh3cNDTrapRatelimitMsg) |
Rate limit message. |
No |
OCTET STRING |
SIZE (1..254) |
Recommended action
