H3C UniServer B16000 Blade Server Chassis User Guide-6W100
HomeSupportServersBlade ServerH3C UniServer B16000Blade Server ChassisInstall & UpgradeInstallation GuidesH3C UniServer B16000 Blade Server Chassis User Guide-6W100
02-Appendix
02-Appendix 108.97 KB
Appendix A  Modules in the chassis
Blade server
Model
Maximum Number
H3C UniServer B5700 G3
16
Half-width full-height blade servers with two processors
H3C UniServer B5800 G3
8
Full-width full-height blade servers with two processors
H3C UniServer B7800 G3
8
Full-width full-height blade servers with four processors
AE module
Model
Maximum Number
H3C Unisever AE100
2
APP engine module
LCD module
Model
Maximum Number
SID-LCD-B
1
LCD display
Management module
Model
Maximum Number
H3C Unisever OM100
2
OM module
ICM module
Model
Maximum Number
H3C UniServer BX720E
6
16*10GE+4*40GE Ethernet switching modules (16*10GB fiber ports+4*40GE fiber ports)
H3C UniServer BX720EF
6
16*10GE+4*40GE converged switching modules (8*FC ports+8*10GE fiber ports+4*40GE fiber ports)
H3C UniServer BX608FE
6
8*16G FC switching modules (8*16G FC ports)
Power supply
Item
Model
PSR3000-12A
3000 W power supply
Range of rated input voltage @ Corresponding output power
·     90–180 V AC, 50 Hz/60 Hz @ 1200 W
·     180–220 V AC, 50 Hz/60 Hz @ 2500 W
·     220–264 V AC, 50 Hz/60 Hz @ 3000 W
·     180–220 V DC @ 2500 W
·     220–320 V DC @ 3000 W
Rated input voltage
16.0A Max
Maximum rated output power
·     3000 W @ 220–264 V AC
·     3000 W @ 220–320 V DC
Efficiency @ 50% load
94%, 80 Plus Platinum level
Redundancy
No redundancy, N+1 redundancy, and N+N redundancy
Cold backup
Yes
Fan module
Model
Maximum Number
FAN-L-B
12
Fan module
Slide rails/cable management bracket
Model
RAIL-12U
12U standard slide rails
CMA-12U
12U cable management bracket
Appendix B  Technical support
If you encounter any complicated problems during daily maintenance or troubleshooting, contact H3C Support.
Collecting server information
Before contacting H3C Support, collect the following server information to facilitate troubleshooting:
·     Log and sensor information of modules in the chassis.
·     Product serial number.
·     Product model and name.
·     Snapshots of error messages and descriptions.
·     Hardware change history of the chassis and modules in the chassis, including installation, replacement, insertion, and removal of hardware.
·     Third-party software installed on modules in the chassis.
·     Operating system type and version of modules in the chassis.
Preparing tools
To facilitate troubleshooting, prepare the following tools as needed:
·     Phillips screwdriver.
·     Cage nut insertion/extraction tool.
·     Diagonal pliers.
·     Multimeter.
·     Interface cable (such as network cable).
·     Access terminal (such as a PC).
·     ESD wrist strap, antistatic gloves, and antistatic clothing.
For more information about these tools, see "Installation tools."
Appendix C  Product recycling
New H3C Technologies Co., Ltd. provides product recycling services for its customers to ensure that hardware at the end of its life is recycled. Vendors with product recycling qualification are contracted to New H3C to process the recycled hardware in an environmentally responsible way.
For product recycling services, contact New H3C at
·     Tel: 400-810-0504
·     Email address: [email protected]
·     Website: http://www.h3c.com
Appendix D  Glossary
Item
B
BIOS
Basic input/output system is non-volatile firmware pre-installed in a ROM chip on a server's management module. The BIOS stores basic input/output, power-on self-test, and auto startup programs to provide the most basic hardware initialization, setup and control functionality.
F
FIST
Fast Intelligent Scalable Toolkit provided by H3C for easy and extensible server management. It can guide users to configure a server quickly with ease and provide an API interface to allow users to develop their own management tools.
H
HDM
Hardware Device Management is the server management control unit with which administrators can configure server settings, view component information, monitor server health status, and remotely manage the server.
K
KVM
KVM is a management method that allows remote users to use their local video display, keyboard, and mouse to monitor and control the server.
R
RAID
Redundant array of independent disks (RAID) is a data storage virtualization technology that combines multiple physical hard drives into a single logical unit to improve storage and security performance.
U
U
Unit of measurement for the height of racks and blade server chassis in the IEC 60297-1 standard. 1 U = 44.45 mm.
Others
Hot swapping
A module that supports hot swapping (a hot-swappable module) can be installed or removed while the server is running without affecting the system operation.
Redundancy
A mechanism that ensures high availability and business continuity by providing backup modules. In redundancy mode, a backup or standby module takes over when the primary module fails.
Appendix E  Acronyms
Acronym
Full name
Chinese Description
A
AE
App Engine
App引擎
AMC
Auxiliary Management Controller
辅助管理控制器
B
BIOS
Basic Input Output System
基本输入输出系统
BMC
Baseboard Management Controller
基板管理控制器
F
FC
Fiber Channel
光纤通道技术
FIST
快速智能可扩展工具集
H
HDM
H3C Device Management
H3C设备管理
I
ICM
Interconnect module
互联模块
K
KVM
Keyboard, Video, and Mouse
键盘、显示器、鼠标
L
LCD
Liquid Crystal Display
液晶显示屏
LDAP
Lightweight Directory Access Protocol
轻量级目录访问协议
LOM
LAN on Motherboard
板载网卡接口
M
Mezz
Mezzanine
中间层连接器,一种接口类型或指代安装在该类型接口上的PCIe
N
NTP
Network Time Protocol
网络时间协议
O
OM
Onboard Management
机箱管理
P
PDU
Power Distribution Unit
电源分配单元
PSU
Power Supply Units
电源装置
R
RAID
Redundant Arrays of Independent Disks
独立磁盘冗余阵列
S
SMTP
Simple Mail Transfer Protocol
简单邮件传输协议
SOL
Serial Over Lan
串口重定向
SSH
Secure Shell
安全Shell
SSL
Secure Sockets Layer
安全套接层
SUV
Serial, USB, and VGA
串口、USB接口、VGA接口
U
UID
Unit Identification
设备标识
UIS
Unified Infrastructure System
统一基础架构系统
UPS
Uninterruptible Power Supply
不间断电源
