01-Text | 626.27 KB |
WLAN radio resource measurement commands
wlan band-navigation aging-time
wlan band-navigation balance access-denial
wlan band-navigation balance session
wlan band-navigation rssi-threshold
display wlan ap all radio client-number
display wlan ap all client-number
display wlan client online-duration
reset wlan statistics service-template
snmp-agent trap enable wlan client
snmp-agent trap enable wlan client-audit
wlan client keepalive interval
wlan client reauthentication-period
wlan static-blacklist mac-address
gtk-rekey client-offline enable
snmp-agent trap enable wlan usersec
client-security accounting-delay time
client-security accounting-start trigger
client-security accounting-update trigger
client-security authentication fail-vlan
client-security authentication-mode
client-security authorization-fail offline
client-security ignore-authentication
client-security ignore-authorization
client-security intrusion-protection action
client-security intrusion-protection enable
client-security intrusion-protection timer temporary-block
client-security intrusion-protection timer temporary-service-stop
display wlan client-security block-mac
cloud-management server domain
display cloud-management state
WLAN multicast optimization commands
display wlan ipv6 multicast-optimization entry
display wlan multicast-optimization entry
ipv6 multicast-optimization enable
reset wlan ipv6 multicast-optimization entry
reset wlan ipv6 multicast-optimization entry group
reset wlan multicast-optimization entry
reset wlan multicast-optimization entry group
wlan ipv6 multicast-optimization aging-time
wlan ipv6 multicast-optimization client entry-limit
wlan ipv6 multicast-optimization entry client-limit
wlan ipv6 multicast-optimization global entry-limit
wlan ipv6 multicast-optimization packet-rate-limit
wlan multicast-optimization aging-time
wlan multicast-optimization client entry-limit
wlan multicast-optimization entry client-limit
wlan multicast-optimization global entry-limit
wlan multicast-optimization packet-rate-limit
Radio management commands
WLAN is supported only on the following routers:
· MSR810-W.
· MSR810-W-DB.
· MSR810-W-LM.
· MSR810-W-LM-HK.
· MSR810-W-LM-GL.
The term "AP" in this document refers to MSR routers that support WLAN.
a-mpdu
Use a-mpdu enable to enable the A-MPDU aggregation method.
Use a-mpdu disable to disable the A-MPDU aggregation method.
Use undo a-mpdu to restore the default.
a-mpdu { disable | enable }
undo a-mpdu
The A-MPDU aggregation method is enabled.
Radio interface view
This command is applicable only to 802.11n radios. Changing the radio mode to 802.11a, 802.11b, or 802.11g invalidates the command.
# Disable the A-MPDU aggregation method.
[Sysname] interface wlan-radio 1/0/1
[Sysname-WLAN-Radio1/0/1] type dot11an
[Sysname-WLAN-Radio1/0/1] a-mpdu disable
a-msdu
Use a-msdu enable to enable the A-MSDU aggregation method.
Use a-msdu disable to disable the A-MSDU aggregation method.
Use undo a-msdu to restore the default.
a-msdu { disable | enable }
undo a-msdu
The A-MSDU aggregation method is enabled.
The device can receive but cannot send A-MSDUs.
# Disable the A-MSDU aggregation method.
[Sysname-WLAN-Radio1/0/1] a-msdu disable
ani
Use ani enable to enable Adaptive Noise Immunity (ANI).
Use ani disable to disable ANI.
Use undo ani to restore the default.
ani { disable | enable }
undo ani
ANI is enabled.
ANI enables the device to adjust the anti-noise level based on the environment to reduce interference from the surrounding environment.
[Sysname] interface wlan-radio 1/0/2
[Sysname-WLAN-Radio1/0/2] ani enable
antenna type
Use antenna type to set the antenna type for an AP.
Use undo antenna type to restore the default.
antenna type antenna-type
undo antenna type
The default antenna type for an AP varies by device model.
antenna-type: Specifies an antenna type, a string of 1 to 10 characters.
Perform this task to set the antenna type for an AP. The antenna type setting for an AP must be consistent with the type of the antenna used on the AP.
To ensure that the Effective Isotropic Radiated Power (EIRP) is within the correct range, the antenna gain automatically changes after you set the antenna type.
# Set the antenna type to external.
[Sysname-WLAN-Radio1/0/1] antenna type external
beacon-interval
Use beacon-interval to set the beacon interval.
Use undo beacon-interval to restore the default.
beacon-interval interval
The beacon interval is 100 TUs.
interval: Specifies the beacon interval in the range of 32 to 8191 TUs.
# Set the beacon interval to 1000 TUs.
[Sysname-WLAN-Radio1/0/2] beacon-interval 1000
channel
Use channel to specify a working channel for a radio.
Use undo channel to restore the default.
channel { channel-number | auto }
undo channel
The auto mode is used.
channel-number: Specifies a channel by its number. The value range for this argument varies by country code and radio mode.
auto: Configures the AP to automatically select a channel.
# Specify working channel 6.
[Sysname-WLAN-Radio1/0/2] channel 6
channel band-width
Use channel band-width to set the bandwidth mode.
Use undo channel band-width to restore the default.
channel band-width { 20 | 40 }
The bandwidth mode is 40 MHz for 802.11an radios and 20 MHz for 802.11gn radios.
20: Sets the bandwidth mode to 20 MHz.
40: Sets the bandwidth mode to 40 MHz.
If the bandwidth mode is set to 40 MHz, the radio uses the 40 MHz bandwidth if two adjacent channels that can be bound together exist. If there are no adjacent channels that can be bound together, the radio uses the 20 MHz bandwidth.
This command is applicable only to 802.11n radios. When you change the mode of a radio, the default setting of this command for the new radio mode is restored.
# Set the bandwidth mode to 40 MHz.
[Sysname-WLAN-Radio1/0/1] channel band-width 40
channel
channel-usage measure
Use channel-usage measure to perform on-demand channel usage measurement.
This feature enables the AP to scan supported channels and display the channel usage after measurement. The measurement of each channel takes about one second.
# Perform on-demand channel usage measurement on radio interface 2.
[Sysname] interface WLAN-Radio 1/0/2
[Sysname-WLAN-Radio1/0/2] channel-usage measure
Please wait..............Done.
Channel Usage
1 23%
2 34%
3 26%
4 36%
5 42%
6 39%
7 27%
8 45%
9 29%
10 38%
11 46%
12 30%
13 33%
client dot11b-forbidden
Use client dot11b-forbidden enable to disable access services for 802.11b clients.
Use client dot11b-forbidden disable to enable access services for 802.11b clients.
Use undo client dot11b-forbidden to restore the default.
client dot11b-forbidden { disable | enable }
Access services for 802.11b clients is enabled.
Enabling an 802.11g or 802.11gn radio to reject 802.11b clients reduces the impact of low-speed 802.11b clients and speeds up wireless data transmission.
# Configure WLAN-radio 1/0/2 to reject 802.11b clients.
[Sysname-wlan-radio-1/0/2] client dot11b-forbidden enable
client dot11n-only
Use client dot11n-only enable to enable the client dot11n-only feature.
Use client dot11n-only disable to disable the client dot11n-only feature.
Use undo client dot11n-only to restore the default.
client dot11n-only { disable | enable }
The client dot11n-only feature is disabled.
After you configure this command on a radio, the radio accepts only the 802.11n clients, and all 802.11a/b/g clients that are associated with the radio are logged off.
# Enable the client dot11n-only feature.
[Sysname-WLAN-Radio1/0/1] client dot11n-only enable
client max-count
Use client max-count to set the maximum number of clients that can associate with an AP.
Use undo client max-count to restore the default.
client max-count max-number
No limit is set for the number of clients that can associate with the AP.
max-number: Specifies the maximum number of clients that can associate with the AP, in the range of 1 to 124.
When the maximum number of clients is reached on the AP, the AP stops accepting new clients.
# Set the maximum number of clients that can associate with the AP to 38.
[Sysname-WLAN-Radio1/0/2] client max-count 38
continuous-mode
Use continuous-mode to enable the continuous mode for a radio.
Use undo continuous-mode to restore the default.
continuous-mode { mcs mcs-index | rate rate-value }
The continuous mode is disabled.
mcs mcs-index: Specifies the MCS index in the range of 0 to 76. This option applies only to 802.11n radios.
rate rate-value: Specifies the transmit rate in Mbps. This option applies to 802.11a, 802.11b, and 802.11g radios.
This feature is used for network testing only. Do not use it under any other circumstances.
It enables continuous data packet sending at the specified rate. When the feature is enabled, do not perform any other operations except changing the transmit rate.
# Enable the continuous mode and set the transmit rate to 6 Mbps.
[Sysname-WLAN-Radio1/0/2] continuous-mode rate 6
display wlan ap continuous-mode
custom-antenna gain
Use custom-antenna gain to set the antenna gain.
Use undo custom-antenna gain to restore the default.
custom-antenna gain antenna-gain
The antenna gain is 0 dBi.
antenna-gain: Specifies the antenna gain in the range of 0 to 20 dBi.
This command is applicable only when an AP uses a third-party antenna.
Effective Isotropic Radiated Power (EIRP) is the actual transmit power of an antenna, and it is the sum of the antenna gain and the maximum transmit power of the radio. If the configured antenna gain causes the EIRP to exceed the threshold, the antenna gain configuration fails.
Make sure the antenna gain setting is the same as the gain of the antenna used on the AP.
Changing the radio mode automatically changes the antenna gain.
# Set the antenna gain to 2 dBi.
[Sysname-WLAN-Radio1/0/2] type dot11an
[Sysname-WLAN-Radio1/0/2] custom-antenna gain 2
distance
Use distance to set the maximum transmission distance.
Use undo distance to restore the default.
distance distance
undo distance
The maximum transmission distance is 1 km (0.62 miles).
distance: Specifies the maximum transmission distance in the range of 1 to 40 km (0.62 to 24.86 miles).
# Set the maximum transmission distance to 5 km (3.11 miles).
[Sysname-WLAN-Radio1/0/2] type dot11g
[Sysname-WLAN-Radio1/0/2] distance 5
dot11g protection
Use dot11g protection enable to enable 802.11g protection.
Use dot11g protection disable to disable 802.11g protection.
Use undo dot11g protection to restore the default.
dot11g protection { disable | enable }
802.11g protection is disabled.
802.11g or 802.11n devices send RTS/CTS or CTS-to-self packets before sending data only when 802.11b signals are detected on the channel.
802.11g protection automatically takes effect when 802.11b clients associate with an 802.11g or 802.11n (2.4 GHz) AP.
This command is applicable only to 802.11g and 802.11n (2.4 GHz) radios. If you change the mode of a radio to a mode other than 802.11g or 802.11n (2.4 GHz), 802.11g protection configuration is removed.
# Enable 802.11g protection.
[Sysname-WLAN-Radio1/0/2] dot11g protection enable
protection-mode
dot11n mandatory maximum-mcs
Use dot11n mandatory maximum-mcs to set the maximum mandatory MCS index.
Use undo dot11n mandatory maximum-mcs to restore the default.
dot11n mandatory maximum-mcs index
No maximum mandatory MCS index is set.
index: Specifies the maximum mandatory MCS index in the range of 0 to 76.
CAUTION: Modifying the maximum mandatory MCS of a radio will log off all associated clients of the radio that do not support the modified MCS. |
Before configuring the dot11n multicast-mcs command, you must set the maximum mandatory MCS index.
# Set the maximum mandatory MCS index to 14.
[Sysname-WLAN-Radio1/0/1] dot11n mandatory maximum-mcs 14
Use dot11n multicast-mcs to set the multicast MCS index.
Use undo dot11n multicast-mcs to restore the default.
dot11n multicast-mcs index
No multicast MCS index is set.
index: Specifies the multicast MCS index in the range of 0 to 76.
The multicast MCS index takes effect only when the radio associates only with 802.11n clients.
If non-802.11n clients exist, the AP and clients use the 802.11a/b/g multicast rate to multicast packets.
The multicast MCS index maps to a rate in 20 MHz bandwidth mode regardless of whether the bandwidth mode is 20 MHz or 40 MHz.
# Set the multicast MCS index to 14.
[Sysname-WLAN-Radio1/0/1] dot11n mandatory maximum-mcs 15
[Sysname-WLAN-Radio1/0/1] dot11n multicast-mcs 14
dot11n protection
Use dot11n protection enable to enable 802.11n protection.
Use dot11n protection disable to disable 802.11n protection.
Use undo dot11n protection to restore the default.
dot11n protection { disable | enable }
802.11n protection is disabled.
802.11n devices send RTS/CTS or CTS-to-self packets before sending data only when non-802.11n signals are detected on the channel.
802.11n protection automatically takes effect when non-802.11n clients associate with an 802.11n AP.
This command is applicable only to 802.11n radios. If you change the mode of a radio to a mode other than 802.11n, the 802.11n protection configuration is removed.
NOTE: 802.11n devices refer to 802.11n devices. |
# Enable 802.11n protection.
[Sysname-WLAN-Radio1/0/1] dot11n protection enable
protection-mode
dot11n support maximum-mcs
Use dot11n support maximum-mcs to set the maximum supported MCS index.
Use undo dot11n support maximum-mcs to restore the default.
dot11n support maximum-mcs index
The maximum supported MCS index is 76.
index: Specifies the maximum supported MCS index in the range of 0 to 76.
The maximum supported MCS index cannot be smaller than the maximum mandatory MCS index.
# Set the maximum supported MCS index to 14.
[Sysname-WLAN-Radio1/0/1] dot11n support maximum-mcs 14
dtim
Use dtim to set the Delivery Traffic Indication Map (DTIM) interval.
Use undo dtim to restore the default.
dtim counter
undo dtim
The DTIM interval is 1. The AP sends buffered broadcast and multicast frames after every beacon frame.
counter: Specifies the DTIM interval in the range of 1 to 31.
An AP periodically broadcasts a beacon compliant with the DTIM. After the AP broadcasts the beacon, it sends buffered broadcast and multicast frames based on the value of the DTIM interval. For example, if you set the DTIM interval to 5, the AP sends buffered broadcast and multicast frames every five beacon frames.
# Set the DTIM interval to 5.
[Sysname-wlan-radio1/0/1] dtim 5
fragment-threshold
Use fragment-threshold to set the frame fragmentation threshold.
Use undo fragment-threshold to restore the default.
fragment-threshold size
The fragmentation threshold is 2346 bytes.
size: Specifies the fragmentation threshold in the range of 256 to 2346 bytes. The value for this argument must be an even number.
Frames larger than the fragmentation threshold are fragmented before transmission. Frames smaller than the fragmentation threshold are transmitted without fragmentation.
In a WLAN with great interference, decrease the fragmentation threshold and set the MTU (ip mtu command) of packets sent over the radio to be lower than the fragmentation threshold. This improves the network throughput and efficiency.
# Set the fragmentation threshold to 2048 bytes.
[Sysname-wlan-radio1/0/1] fragment-threshold 2048
green-energy-management
Use green-energy-management enable to enable the energy-saving feature.
Use green-energy-management disable to disable the energy-saving feature.
Use undo green-energy-management to restore the default.
green-energy-management { disable | enable }
The energy-saving feature is disabled.
After you enable the energy-saving feature, the multiple-input and multiple-output (MIMO) mode of a radio automatically changes to 1x1 if no clients associate with the radio. This reduces power consumption.
# Enable the energy-saving feature.
[Sysname-WLAN-Radio1/0/1] green-energy-management enable
ldpc
Use ldpc enable to enable LDPC.
Use ldpc disable to disable LDPC.
Use undo ldpc to restore the default.
ldpc { disable | enable }
undo ldpc
LDPC is disabled.
The device can receive but cannot send LDPC packets.
# Disable LDPC.
[Sysname-wlan-radio-1/0/1] type dot11an
[Sysname-wlan-radio-1/0/1] ldpc disable
long-retry threshold
Use long-retry threshold to set the maximum number of retransmissions for large frames.
Use undo long-retry threshold to restore the default.
long-retry threshold count
The maximum number of retransmissions is 4 for large frames.
count: Specifies the maximum number of retransmissions for large frames, in the range of 1 to 15.
Perform this task to set the hardware retransmission limit for frames larger than the RTS threshold.
# Set the maximum number of retransmissions to 5 for large frames.
[Sysname-wlan-radio-1/0/1] long-retry threshold 5
protection-threshold
short-retry threshold
max-power
Use max-power to set the maximum transmit power.
Use undo max-power to restore the default.
max-power radio-power
undo max-power
The AP uses the maximum supported transmit power.
radio-power: Specifies the maximum transmit power. The value range for this argument varies by device model.
The transmit power range supported by a radio varies by country code, channel, AP model, radio mode, antenna type, and bandwidth mode. If you change these attributes for a radio after you set the maximum transmit power, the configured maximum transmit power might be out of the supported transmit power range. If this happens, the system automatically adjusts the maximum transmit power to a valid value.
If you enable power lock, the locked power becomes the maximum transmit power.
# Set the maximum transmit power to 15 dBm.
[Sysname-WLAN-Radio1/0/2] max-power 15
preamble
Use preamble to set the preamble type.
Use undo preamble to restore the default.
preamble { long | short }
undo preamble
The short preamble is used.
long: Specifies a long preamble. A long preamble ensures compatibility with all wireless devices that use an earlier standard than 802.11n.
short: Specifies a short preamble. A short preamble can improve network performance.
This command is applicable only to 802.11b, 802.11g, and 802.11gn radios.
A preamble is a set of bits in a packet header to synchronize transmission signals between sender and receiver.
# Set the preamble type to long.
[Sysname-WLAN-Radio1/0/2] preamble long
protection-mode
Use protection-mode to specify a collision avoidance mode.
Use undo protection-mode to restore the default.
protection-mode { cts-to-self | rts-cts }
The CTS-to-self mode is used.
cts-to-self: Specifies the CTS-to-self mode.
rts-cts: Specifies the RTS/CTS mode.
You can specify either of the following collision avoidance modes for an AP:
· RTS/CTS—An AP sends an RTS packet to a client before sending data to the client. After receiving the RTS packet, the client sends a CTS packet to the AP. The AP begins to send data after receiving the CTS packet, and other devices that detect the RTS or CTS packet do not send data within a specific time period.
· CTS-to-self—An AP sends a CTS packet with its own MAC address as the destination MAC address before sending data to a client. After receiving the CTS-to-self packet, the AP begins to send data, and other devices that detect the CTS-to-self packet do not send data within a specific time period.
# Specify the RTS/CTS mode.
[Sysname-WLAN-Radio1/0/2] protection-mode rts-cts
dot11g protection
dot11n protection
Use protection-threshold to set the RTS threshold.
Use undo protection-threshold to restore the default.
protection-threshold size
The RTS threshold is 2346 bytes.
size: Specifies the RTS threshold in the range of 0 to 2346 bytes.
The system performs collision avoidance only for packets larger than the RTS threshold.
# Set the RTS threshold to 2048 bytes.
[Sysname-WLAN-Radio1/0/2] protection-threshold 2048
protection-mode
rate
Use rate to set the transmission rates for a radio.
Use undo rate to restore the default.
rate { multicast { auto | rate-value } | { disabled | mandatory | supported } rate-value }
undo rate
· 802.11a/802.11an:
¡ Prohibited rates—None.
¡ Mandatory rates—6, 12, and 24.
¡ Multicast rate—Selected from the mandatory rates.
¡ Supported rates—9, 18, 36, 48, and 54.
· 802.11b:
¡ Mandatory rates—1 and 2.
¡ Supported rates—5.5 and 11.
· 802.11g/802.11gn:
¡ Mandatory rates—1, 2, 5.5, and 11.
¡ Supported rates—6, 9, 12, 18, 24, 36, 48, and 54.
disabled: Specifies rates that cannot be used by an AP.
mandatory: Specifies rates that the clients must support to associate with an AP.
multicast: Specifies the rate at which an AP multicasts packets. The multicast rate must be selected from the mandatory rates.
supported: Specifies rates that an AP supports. After a client associates with an AP, the client can select a higher or lower rate from the supported rates to communicate with the AP.
auto: Automatically selects a mandatory rate as the multicast rate.
rate-value: Specifies the rate value in Mbps. You can set multiple rates and separate them by spaces. The available values for this argument are as follows:
· 802.11a/802.11an—6, 9, 12, 18, 24, 36, 48, and 54.
· 802.11b—1, 2, 5.5, and 11.
· 802.11g/802.11gn—1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48, and 54.
The mandatory rates and multicast rate cannot be null. When there is only one mandatory rate, you cannot specify the mandatory rate as a supported rate or prohibited rate.
# Set the mandatory rates to 6 Mbps, 12 Mbps, and 24 Mbps.
[Sysname-WLAN-Radio1/0/2] rate mandatory 6 12 24
short-gi
Use short-gi enable to enable short Guard Interval (GI).
Use short-gi disable to disable short GI.
Use undo short-gi to restore the default.
short-gi { disable | enable }
undo short-gi
Short GI is enabled.
# Disable short GI.
[Sysname-WLAN-Radio1/0/1] short-gi disable
Use short-retry threshold to set the maximum number of retransmissions for small frames.
Use undo short-retry threshold to restore the default.
short-retry threshold count
The maximum number of retransmissions is 7 for small frames.
count: Specifies the maximum number of retransmissions for small frames, in the range of 1 to 15.
Perform this task to set the hardware retransmission limit for frames smaller than or equal to the RTS threshold.
# Set the maximum number of retransmissions to 10 for small frames.
[Sysname-WLAN-Radio1/0/1] short-retry threshold 10
stbc
Use stbc enable to enable Space-Time Block Coding (STBC).
Use stbc disable to disable STBC.
Use undo stbc to restore the default.
stbc { disable | enable }
undo stbc
STBC is enabled.
# Enable STBC.
[Sysname-wlan-radio-1/0/1] stbc enable
type
Use type to specify a radio mode.
Use undo type to restore the default.
type { dot11a | dot11an | dot11b | dot11g | dot11gn }
undo type
WLAN-Radio 0/0 operates in dot11an mode and WLAN-Radio 0/1 operates in dot11gn mode.
dot11a: Specifies the 802.11a radio mode.
dot11an: Specifies the 802.11n (5 GHz) radio mode.
dot11b: Specifies the 802.11b radio mode.
dot11g: Specifies the 802.11g radio mode.
dot11gn: Specifies the 802.11n (2.4 GHz) radio mode.
CAUTION: Modifying the mode of an enabled radio logs off all associated clients. |
# Set the radio mode to 802.11n (5 GHz).
· MSR810-W.
· MSR810-W-DB.
· MSR810-W-LM.
· MSR810-W-LM-HK.
display wlan measure-report
Use display wlan measure-report to display measurement reports for clients.
display wlan measure-report interface interface-type interface-number [ client mac-address mac-address ]
interface interface-type interface-number: Specifies a radio interface by its type and number.
client mac-address mac-address: Specifies a client by its MAC address. If you do not specify a client, this command displays measurement reports for all clients.
# Display measurement reports for clients associated with the specified radio interface.
<Sysname> display wlan measure-report interface wlan-radio 0/0
Total number of clients: 1
Client MAC address : 0aef-e760-3587
Link measurement:
Link margin : 2 dBm
RCPI : -85 dBm
RSNI : 53 dBm
Noise histogram:
Antenna ID : 3
ANPI : -56 dBm
IPI0 to IPI10 density : 5 12 16 13 8 5 5 15 17 1 3
Spectrum measurement:
Transmit power : 20 dBm
BSS : Detected
OFDM preamble : Detected
Radar : Detected
Unidentified signal : Undetected
CCA busy fraction : 60
RPI0 to RPI7 density : 3 7 11 19 15 23 15 7
Frame report entry:
BSSID : a072-2351-e253
PHY type : fhss
Average RCPI : -10 dBm
Last RSNI : 2 dBm
Last RCPI : -20 dBm
Frames : 1
Dot11BSSAverageAccessDelay group:
Average access delay : 32 ms
BestEffort average access delay : 1 ms
Background average access delay : 1 ms
Video average access delay : 1 ms
Voice average access delay : 1 ms
Clients : 32
Channel utilization rate : 11
Transmit stream:
Traffic ID : 0
Sent MSDUs : 60
Discarded MSDUs : 5
Failed MSDUs : 3
MSDUs resent multiple times : 3
Lost QoS CF-Polls : 2
Average queue delay : 2 ms
Average transmit delay : 1 ms
Bin0 range : 0 to 10 ms
Bin0 to Bin5 : 5 10 10 5 10 10
Gap between the received RSSI and the lowest available RSSI. |
RCPI |
Received Channel Power Indicator. |
RSNI |
Received Signal to Noise Indicator. |
ANPI |
Average Noise Power Indicator during the measurement. |
IPI0 to IPI10 density |
Percentage of time for different IPI ranges to the total measurement period. IPIn represents an IPI range. The value for n is in the range of 1 to 10: · 0: IPI <= –92 dBm. · 1: –92 dBm < IPI <= –89 dBm. · 2: –89 dBm < IPI <= –86 dBm. · 3: –86 dBm < IPI <= –83 dBm. · 4: –83 dBm < IPI <= –80 dBm. · 5: –80 dBm < IPI <= –75 dBm · 6: –75 dBm < IPI <= –70 dBm. · 7: –70 dBm < IPI <= –65 dBm. · 8: –65 dBm < IPI <= –60 dBm. · 9: –60 dBm < IPI <= –55 dBm. · 10: –55 dBm < IPI. |
Transmit power |
Transmission power of the client. |
BSS |
Whether the client has detected wireless packets from other BSSs. |
OFDM preamble |
Whether the client has detected OFDM preambles. |
Radar |
Whether the client has detected radar signals. |
Unidentified signal |
Whether the client has detected unknown signals. |
CCA busy fraction |
CCA utilization is expressed as a percentage of time that the channel is busy (during the measurement period). |
RPI0 to RPI7 density |
Percentage of time that each RPI was used during the measurement period. RPIn represents a RPI range. The value for n is in the range of 1 to 7: · 0: RPI <= –87 dBm. · 1: –87 dBm < RPI <= –82 dBm. · 2: –82 dBm < RPI <= –77 dBm. · 3: –77 dBm < RPI <= –72 dBm. · 4: –72 dBm < RPI <= –67 dBm. · 5: –67 dBm < RPI <= –62 dBm. · 6: –62 dBm < RPI <= –57 dBm. · 7: –57 dBm < RPI. |
PHY type |
Physical media type: fhss, dsss, irbaseband, ofdm, hrdsss, or erp. |
Frames |
Number of frames from the same MAC address and BSSID during the measurement. |
Bin0 range |
Value range for Bin0. |
Bin0 to Bin5 |
Number of successfully sent MSDUs for each average delay range. Binx represents an average delay range. The value for x is in the range of 0 to 5: · Bin0: Delay< 10 ms. · Bin1: 10 ms <= Delay < 20 ms. · Bin2: 20 ms <= Delay < 40 ms. · Bin3: 40 ms <= Delay < 80 ms. · Bin4: 80 ms <= Delay < 160 ms. · Bin5: 160 ms <= Delay. |
measure
Use measure enable to enable the specified measurement feature or all measurement features.
Use measure disable to disable the specified measurement feature or all measurement features.
Use undo measure to restore the default.
measure { all | link | neighbor | radio | spectrum | tpc } { disable | enable }
undo measure
Measurement is disabled.
all: Specifies all measurement features.
link: Specifies link measurement. Link measurement measures RCPI, RSNI, and link redundancy for the requested link.
neighbor: Specifies neighbor measurement. Neighbor measurement measures the channel and BSSID of neighbor APs.
radio: Specifies radio measurement. Radio measurement measures channel load, noise histogram, beacons, frames, station statistics, locations, and transmit streams.
spectrum: Specifies spectrum measurement, which includes basic measurement, Clear Channel Assessment (CCA) measurement, and Receive Power Indication (RPI) measurement.
tpc: Specifies TPC measurement. TPC measurement measures link redundancy and transmission power for clients.
You must enable radio resource measurement if you enable link, neighbor, or radio measurement.
You must enable spectrum management if you enable spectrum or TPC measurement.
# Enable spectrum measurement.
[Sysname] interface wlan-radio 0/0
[Sysname-WLAN-Radio0/0] measure spectrum enable
measure-duration
measure-interval
resource-measure
spectrum-management
measure-duration
Use measure-duration to set the measurement duration.
Use undo measure-duration to restore the default.
measure-duration time
The measurement duration is 500 TUs.
time: Specifies the measurement duration in the range of 1 to 10000 TUs. One TU is equal to 1024 microseconds.
When measurement is enabled on an AP, the AP adds the measurement duration in the measurement requests sent to clients.
# Set the measurement duration to 512 TUs.
[Sysname-WLAN-Radio0/0] measure-duration 512
measure
measure-interval
measure-interval
Use measure-interval to set the measurement interval for an AP to send measurement requests to clients.
Use undo measure-interval to restore the default.
measure-interval interval
The measurement interval is 30 seconds.
interval: Specifies the measurement interval in the range of 10 to 60 seconds.
# Set the measurement interval to 35 seconds.
[Sysname-WLAN-Radio0/0] measure-interval 35
measure
measure-duration
resource-measure
Use resource-measure enable to enable radio resource measurement.
Use resource-measure disable to disable radio resource measurement.
Use undo resource-measure to restore the default.
resource-measure { disable | enable }
Radio resource measurement is disabled.
When radio measurement is enabled on an AP, the AP sets the Radio Measurement field to 1 in beacons, probe responses, association responses, or reassociation responses. It notifies the clients that they can send measurement requests. These frames also carry measurement capabilities of the AP to inform clients of measurement types that the AP supports.
The AP periodically sends Measurement Pilot frames to help clients fast discover the AP. Measurement Pilot frames are sent more frequently than beacons and carry less information.
# Enable radio resource measurement.
[Sysname-WLAN-Radio0/0] resource-measure enable
rm-capability mode
Use rm-capability mode to set the match mode for client radio resource measurement capabilities.
Use undo rm-capability mode to restore the default.
rm-capability mode { all | none | partial }
The match mode is none for client radio resource measurement capabilities.
all: Specifies the all mode. A client is allowed to associate with an AP only when all its radio resource measurement capabilities match the AP's radio resource measurement capabilities.
none: Specifies the none mode. The AP does not check client radio resource measurement capabilities.
partial: Specifies the partial mode. A client is allowed to associate with an AP as long as one of its radio resource measurement capabilities matches any of the AP's radio resource measurement capabilities.
The configuration takes effect only when radio resource measurement is enabled.
# Set the match mode to partial for client radio resource measurement capabilities.
[Sysname-WLAN-Radio0/0] rm-capability mode partial
resource-measure
Band navigation commands
· MSR810-W.
· MSR810-W-DB.
· MSR810-W-LM.
· 810-W-LM-HK.
· MSR810-W-LM-GL.
Use wlan band-navigation aging-time to set the client information aging time.
Use undo wlan band-navigation aging-time to restore the default.
wlan band-navigation aging-time aging-time
The client information aging time is 180 seconds.
aging-time: Specifies the client information aging time in the range of 10 to 600 seconds.
When an AP receives an association request from a client, the AP records the client's information and starts the client information aging timer. If the AP receives a probe request or association request from the client before the aging timer expires, the AP refreshes the client information and resets the client information aging timer. If the AP does not receive any probe requests or association requests from the client before the aging timer expires, the AP deletes the client's information.
Configure an appropriate client information aging time to ensure both client association and system resource efficiency.
# Set the client information aging time to 50 seconds.
[Sysname] wlan band-navigation aging-time 50
Use wlan band-navigation balance access-denial to set the maximum number of denials for 5 GHz association requests.
Use undo wlan band-navigation balance access-denial to restore the default.
wlan band-navigation balance access-denial access-denial
The maximum number of denials is 1 for 5 GHz association requests.
access-denial: Specifies the maximum number of denials for 5 GHz association requests, in the range of 1 to 10.
If the number of times that a 5 GHz radio rejects a client reaches the specified maximum number, the radio accepts the association request of the client.
# Set the maximum number of denials to 5 for 5 GHz association requests.
[Sysname] wlan band-navigation balance access-denial 5
Use wlan band-navigation balance session to configure load balancing for band navigation.
Use undo wlan band-navigation balance session to restore the default.
wlan band-navigation balance session session [ gap gap ]
Load balancing is disabled for band navigation.
session: Specifies the client number threshold for the 5 GHz radio, in the range of 2 to 40.
gap: Specifies the threshold for the client number gap between the 5 GHz radio and the radio that has the fewest clients. The value range for this argument is 1 to 8 and the default value is 4.
If you enable band navigation but do not enable load balancing, the AC directs dual-band clients to the 5 GHz radio.
The AP rejects the 5 GHz association request of a client when the following conditions are met:
· The number of clients on the 5 GHz radio reaches the specified threshold.
· The client number gap between the 5 GHz radio and the radio that has the fewest clients reaches the specified threshold.
# Enable load balancing for band navigation, and set the client number threshold and session gap threshold to 10 and 5, respectively.
[Sysname] wlan band-navigation balance session 10 gap 5
wlan band-navigation enable
Use wlan band-navigation enable to enable band navigation globally.
Use undo wlan band-navigation enable to restore the default.
Band navigation is disabled globally.
# Enable band navigation globally.
[Sysname] wlan band-navigation enable
band-navigation
quick-association enable
Use wlan band-navigation rssi-threshold to set the received signal strength indicator (RSSI) threshold for band navigation.
Use undo wlan band-navigation rssi-threshold to restore the default.
wlan band-navigation rssi-threshold rssi-threshold
The RSSI threshold for band navigation is 15.
rssi-threshold: Specifies the RSSI threshold for band navigation, in the range of 5 to 100.
A client might be detected by multiple radios. A 5 GHz radio rejects the association request of a client if the client's RSSI is lower than the band navigation RSSI threshold.
# Set the RSSI threshold for band navigation to 40.
[Sysname] wlan band-navigation rssi-threshold 40
WLAN access commands
· MSR810-W.
· MSR810-W-DB.
· MSR810-W-LM.
· MSR810-W-LM-HK.
· MSR810-W-LM-GL.
beacon ssid-hide
Use beacon ssid-hide to disable advertising of the Service Set Identifier (SSID) in beacon frames.
Use undo beacon ssid-hide to restore the default.
beacon ssid-hide
The SSID is advertised in beacon frames.
Service template view
This command disables a radio from carrying SSIDs in the beacon frames and responding to probe requests after the specified service template is bound to the radio.
# Disable advertising the SSID in beacon frames.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] beacon ssid-hide
client max-count
Use client max-count to set the maximum number of associated clients for a service template.
The number of associated clients for a service template is not limited.
max-number: Specifies the maximum number of clients in the range of 1 to 2007.
When this feature is configured, new clients cannot access the WLAN when the maximum number is reached.
# Set the maximum number of associated clients to 38 for service template service1.
[Sysname-wlan-st-service1] client max-count 38
customlog format wlan
Use customlog format wlan to enable the device to generate client logs in the specified format.
Use undo customlog format wlan to restore the default.
customlog format wlan { normal | sangfor }
The device generates client logs only in H3C format.
normal: Specifies normal format.
sangfor: Specifies sangfor format.
By default, the device generates client logs only in H3C format that logs AP name, radio ID, client MAC address, SSID, BSSID, and client online status.
You can configure the device to generate client logs in one of the following formats:
· normal—Logs AP MAC address, AP name, client IP address, client MAC address, SSID, and BSSID.
· sangfor—Logs AP MAC address, client IP address, and client MAC address.
This feature does not affect the generation of client logs in H3C format.
# Enable the device to generate client logs in sangfor format.
[Sysname] customlog format wlan sangfor
description
Use description to configure a description for a service template.
No description is configured for a service template.
text: Specifies a description, a case-sensitive string of 1 to 64 characters.
# Configure a description for service template service1.
[Sysname-wlan-st-service1] description wlanst
Use display wlan ap all radio client-number to display the number of online clients and channel information for each radio.
# Display the number of online clients and channel information for each radio.
<Sysname> display wlan ap all radio client-number
AP name RID Channel Clients
1 1 44 12
1 2 11 4
Use display wlan ap all client-number to display the number of online clients at both the 2.4 GHz and 5 GHz bands.
# Display the number of online clients at both the 2.4 GHz and 5 GHz bands.
<System> display wlan ap all client-number
AP name Clients 2.4GHz 5GHz
ap1 3 2 1
Clients |
Total number of online clients. |
2.4GHz |
Number of online clients at the 2.4 GHz band. |
5GHz |
Number of online clients at the 5 GHz band. |
display wlan blacklist
Use display wlan blacklist to display blacklist entries.
display wlan blacklist { dynamic | static }
dynamic: Specifies the dynamic blacklist.
static: Specifies the static blacklist.
# Display static blacklist entries.
<Sysname> display wlan blacklist static
Total number of clients: 3
MAC addresses:
000e-35b2-000e
0019-5b8e-b709
001c-f0bf-9c92
# Display dynamic blacklist entries.
<Sysname> display wlan blacklist dynamic
MAC address APID Lifetime (s) Duration (hh:mm:ss)
000f-e2cc-0001 1 300 00:02:11
000f-e2cc-0002 2 300 00:01:17
000f-e2cc-0003 3 300 00:02:08
MAC address |
Client MAC address. |
APID |
ID of the AP that detects the rogue client. |
Lifetime (s) |
Lifetime of the entry in seconds. |
Duration (hh:mm:ss) |
Duration for the entry since the entry was added to the dynamic blacklist. |
display wlan bss
Use display wlan bss to display basic service set (BSS) information.
display wlan bss { all | bssid bssid } [ verbose ]
all: Displays all BSSs.
bssid bssid: Specifies a BSS by its ID. The value is a 48-bit hexadecimal number in the format of H-H-H.
verbose: Displays detailed client information. If you do not specify this keyword, the command displays brief client information.
# Display brief information about all BSSs.
<Sysname> display wlan bss all
Total number of BSSs: 4
AP name RID SSID BSSID
ap1 1 SSID1 001c-f08f-f804
ap1 2 SSID1 001c-f08f-f806
# Display detailed information about the BSS with ID 001c-f08f-f804.
<Sysname> display wlan bss bssid 001c-f08f-f804 verbose
AP name : ap1
BSSID : 001c-f08f-f804
Radio ID : 1
Service template name : servcie1
SSID : SSID1
VLAN ID : 1
AKM mode : Not configured
User authentication mode : Bypass
AKM mode |
AKM mode: · 802.1X. · PSK. · Not configured. |
User authentication mode |
User authentication mode: · Bypass—No client authentication. · MAC. · 802.1X. · OUI. |
display wlan client
Use display wlan client to display client information.
display wlan client [ interface wlan-radio interface-number | mac-address mac-address | service-template service-template-name ] [ verbose ]
wlan-radio interface-number: Displays information about clients that are connected to the specified radio interface.
service-template service-template-name: Displays information about clients that are associated with the specified service template. The service template name is a case-insensitive string of 1 to 63 characters.
# Display brief information about all clients.
<Sysname> display wlan client
MAC address Username AP name RID IPv4 address VLAN
000f-e265-6400 N/A ap1 1 1.1.1.1 100
84db-ac14-dd08 N/A ap1 1 5.5.5.3 1
Table 5 Command output
MAC address |
Username |
Client username: · The field displays the client username if the client uses 802.1X or MAC authentication. · The field displays N/A if the client does not use 802.1X or MAC authentication. NOTE: If the client uses portal authentication, this field does not display the portal username of the client. |
AP name |
Name of the AP that the client is associated with. |
RID |
ID of the radio that the client is associated with. |
IPv4 address |
IPv4 address of the client. |
VLAN ID |
ID of the VLAN to which the client belongs. |
# Display detailed information about all clients on the specified member device.
<Sysname> display wlan client distributed-sys slot 1 verbose
MAC address : 000f-e265-6400
IPv4 address : 10.1.1.114
IPv6 address : 2001::1234:5678:0102:0304
Username : N/A
AID : 1
AP ID : 1
AP name : ap1
Radio ID : 1
SSID : office
BSSID : 0026-3e08-1150
VLAN ID : 3
Sleep count : 3
Wireless mode : 802.11ac
Channel bandwidth : 80MHz
SM power save : Enabled
SM power save mode : Dynamic
Short GI for 20MHz : Supported
Short GI for 40MHz : Supported
Short GI for 80MHz : Supported
Short GI for 160/80+80MHz : Not supported
STBC RX capability : Not supported
STBC TX capability : Not supported
LDPC RX capability : Not supported
SU beamformee capability : Not supported
MU beamformee capability : Not supported
Beamformee STS capability : N/A
Block Ack : TID 0 In
Supported VHT-MCS set : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8
NSS2 0, 1, 2, 3, 4, 5, 6, 7, 8
Supported HT MCS set : 0, 1, 2, 3, 4, 5, 6, 7,
8, 9, 10, 11, 12, 13, 14,
15, 16, 17, 18, 19, 20,
21, 22, 23
Supported rates : 6, 9, 12, 18, 24, 36,
48, 54 Mbps
QoS mode : WMM
Listen interval : 10
RSSI : 62
Rx/Tx rate : 130/195 Mpbs
Authentication method : Open system
Security mode : PRE-RSNA
Cipher suite : N/A
Authorization ACL ID : 3001(Not effective)
Authorization user profile : N/A
Roam status : N/A
Key derivation : SHA1
PMF status : Enabled
Forward policy name : Not configured
Online time : 0days 0hours 1minutes 13seconds
FT status : Inactive
Table 6 Command output
MAC address |
IPv4 address |
Client IPv4 address. |
IPv6 address |
Client IPv6 address. |
Username |
AID |
Association ID. |
AP ID |
ID of the AP that the client is associated with. |
AP name |
Radio ID |
SSID |
SSID with which the client is associated. |
VLAN ID |
Sleep count |
Client sleep times. |
Wireless mode |
Wireless mode: · 802.11a. · 802.11b. · 802.11g. · 802.11gn. · 802.11an. · 802.11ac. |
Channel bandwidth |
Channel bandwidth: · 20 MHz. · 40 MHz. · 80 MHz. · 160 MHz. |
SM Power Save |
SM Power Save status: · Enabled—Only one antenna of a client operates in active state, and others operate in sleep state to save power. · Disabled. |
SM power save mode |
Power saving mode: · Dynamic. · Static. |
Short GI for 20MHz |
Whether the client supports short GI when its channel bandwidth is 20 MHz: · Supported. · Not supported. |
Short GI for 40MHz |
Whether the client supports short GI when its channel bandwidth is 40 MHz: · Supported. · Not supported. |
Short GI for 80MHz |
Whether the client supports short GI when its channel bandwidth is 80 MHz: · Supported. · Not supported. |
Short GI for 160/80+80MHz |
Whether the client supports short GI when its channel bandwidth is 160 MHz or 80 + 80 MHz: · Supported. · Not supported. |
STBC Rx Capability |
Client STBC receive capability; · Not Supported. · Supported. |
STBC Tx Capability |
Client STBC transmission capability: · Not Supported. · Supported. |
LDPC Rx capability |
Client LDPC receive capability; · Not Supported. · Supported. |
SU beamformee capability |
Client SU beamformee capability: · Not Supported. · Supported. This field is supported only by 802.11ac radios. |
MU beamformee capability |
Client MU beamformee capability: · Not Supported. · Supported. This field is supported only by 802.11ac radios. |
Beamformee STS capability |
Client beamformee STS capability. This field displays N/A if the feature is not supported. |
Block Ack |
Negotiation result of Block ACK with TID: · TID 0 In—Sends Block ACK for inbound traffic. · TID 0 Out—Sends Block ACK for outbound traffic. · TID 0 Both—Sends Block ACK for both inbound and outbound traffic. · N/A—Does not send Block ACK for both inbound and outbound traffic. |
Supported VHT-MCS set |
VHT-MCS supported by the client. |
Supported HT MCS set |
QoS mode |
QoS mode: · N/A—WMM is not supported. · WMM—WMM is supported. WMM information negotiation is carried out between an AP and a client that both support WMM. |
Listen interval |
Interval at which the client wakes up to listen for beacon frames. It is counted by beacon interval. |
RSSI |
Received signal strength indication. This value indicates the client signal strength detected by the AP. |
Rx/Tx rate |
Sending and receiving rates of data, management, and control frames. |
Authentication method |
Authentication method: · Open system. · Shared key. |
Security mode |
Security mode: · RSN—Beacons and probe responses carry RSN IE. · WPA—Beacons and probe responses carry WPA IE. · PRE-RSNA—Beacons and probe responses do not carry RSN IE or WPA IE. |
AKM mode |
Cipher suite |
Cipher suite: · N/A. · WEP40. · WEP104. · WEP128. · CCMP. · TKIP. |
Authorization ACL ID |
Authorized ACL number: · This field displays the ACL number if the authorized ACL takes effect. · This field displays ACL number(Not effective) if the authorized ACL does not take effect. · This field displays N/A if the authentication server is configured without any authorized ACL. |
Authorization user profile |
Name of the authorized user profile: · This field displays the authorized user profile name if the authorized user profile takes effect. · This field displays authorized user profile name + Not effective if the authorized user profile does not take effect. · This field displays N/A if the authentication server is configured without any authorized user profile. |
Roam status |
Roam status: · Roaming in progress. · Inter-AC slow roaming. · Inter-AC fast roaming. · Intra-AC slow roaming. · Intra-AC fast roaming. · This field displays N/A if the client stays in one BSS after coming online. |
Key derivation |
Key derivation type: · SHA1—Uses the HMAC-SHA1 hash algorithm. · SHA256—Uses the HMAC-SHA256 hash algorithm. · N/A—No key derivation algorithm is involved for the authentication type. |
PMF status |
PMF status: · Enabled—Management frame protection is enabled. · Disabled—Management frame protection is disabled. · N/A—Management frame protection is not involved. |
Forward policy name |
WLAN forwarding policy name: · Not configured. · Policy-name. |
Online time |
Client online duration. |
FT status |
Fast BSS transition (FT): · Active—FT is enabled. · Inactive—FT is disabled. |
display wlan client ipv6
Use display wlan client ipv6 to display information about client IPv6 addresses.
# Display brief status information about the specified client.
<Sysname> display wlan client ipv6
MAC address AP name RID IPv6 address VLAN
84db-ac14-dd08 ap1 1 1::2:0:0:3 300
Table 7 Command output
MAC address |
RID |
Radio ID |
IPv6 address |
Use display wlan client online-duration to display client online duration.
display wlan client online-duration [ verbose ]
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display brief information about client online duration.
<Sysname> display wlan client online-duration
Total number of online clients: 2
MAC address IPv4 address Online duration
a4c1-5b79-fa5b-1d62 192.168.11.123 0days 0hours 2minutes 23seconds
22d3-c5b7-a4b5-96fa 192.168.11.234 0days 0hours 5minutes 34seconds
Table 8 Command output
MAC address |
IPv4 address |
Online duration |
display wlan client status
Use display wlan client status to display client status information.
display wlan client status [ mac-address mac-address ] [ verbose ]
mac-address mac-address: Specifies a client by its MAC address in the format of H-H-H. If you do not specify this option, the command displays status information about all clients.
verbose: Displays detailed client status information. If you do not specify this keyword, the command displays brief client status information.
<Sysname> display wlan client status mac-address 001c-f08f-f804
MAC address Access time RSSI Rx/Tx rate Discard AP name RID
001c-f08f-f804 41ms 0 39/117Mbps 0.00 ap2 2
# Display brief status information about all clients.
000f-e265-6401 10ms 62 130/195Mbps 0.00% ap1 1
Table 9 Command output
MAC address |
Access time |
Time the client took to associate with the WLAN. |
RSSI |
RSSI of the client. |
Rx/Tx rate |
Rates at which the client receives and sends data, management packets, and control packets. |
Discard |
Ratio of packets discarded by the client. |
AP name |
Name of the AP with which the client is associated. |
RID |
ID of the radio with which the client is associated. |
# Display detailed status information about the specified client.
<Sysname> display wlan client status mac-address 001c-f08f-f804 verbose
MAC address : 001c-f08f-f804
AP name : ap2
Radio ID : 2
Access time : 41 ms
RSSI : 0
Rx/Tx rate : 39/117 Mbps
Received:
Retransmitted packets : 84
Retransmitted packet ratio : 64.12%
Sent:
Retransmitted packets : 0
Retransmitted packet ratio : 0.00%
Discarded:
Discarded packets : 0
Discarded packet ratio : 0.00%
Table 10 Command output
MAC address |
AP name |
Radio ID |
Access time |
RSSI |
Rx/Tx rate |
Received |
Received packet statistics: · Retransmitted packets. · Retransmitted packet ratio. |
Sent |
Sent packet statistics: · Retransmitted packets. · Retransmitted packet ratio. |
Discarded |
Discarded packet statistics: · Discarded packets. · Discarded packet ratio. |
display wlan service-template
Use display wlan service-template to display service template information.
display wlan service-template [ service-template-name ] [ verbose ]
service-template-name: Specifies a service template by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command displays information about all service templates.
verbose: Displays detailed service template information.
# Display brief information about all service templates.
[Sysname] display wlan service-template
Total number of service templates: 2
Service template name SSID Status
1 2333 Enabled
2 3222 Enabled
# Display detailed information about all service templates.
<Sysname> display wlan service-template verbose
Service template name : service1
Description : Not configured
SSID : wuxianfuwu
SSID-hide : Disabled
User-isolation : Disabled
Service template status : Disabled
Maximum clients per BSS : 64
Frame format : Dot3
Seamless roam status : Disabled
Seamless roam RSSI threshold : 50
Seamless roam RSSI gap : 20
VLAN ID : 1
AKM mode : PSK
Security IE : RSN
Cipher suite : CCMP
WEP key ID : 1
TKIP countermeasure time : 100 sec
PTK lifetime : 43200 sec
GTK rekey : Enabled
GTK rekey method : Time-based
GTK rekey time : 86400 sec
GTK rekey client-offline : Enabled
Intrusion protection : Disabled
Intrusion protection mode : Temporary-block
Temporary block time : 180 sec
Temporary service stop time : 20 sec
Fail VLAN ID : 1
802.1X handshake : Enabled
802.1X handshake secure : Disabled
802.1X domain : my-domain
MAC-auth domain : Not configured
Max 802.1X users per BSS : 4096
Max MAC-auth users per BSS : 4096
802.1X re-authenticate : Enabled
Authorization fail mode : Online
Accounting fail mode : Online
Authorization : Permitted
PMF status : Optional
Hotspot policy number : Not configured
Forwarding policy status : Disabled
Forwarder : AC
FT status : Enabled
FT method : over-the-air
FT reassociation deadline : 20 sec
QoS trust : Port
QoS priority : 0
Table 11 Command output
SSID |
SSID of the service template. |
SSID-hide |
Whether the SSID is hidden in beacons: · Disabled. · Enabled. |
User-isolation |
Use isolation: · Disabled. · Enabled. |
Service template status |
Service template status: · Disabled. · Enabled. |
Maximum clients per BSS |
Maximum number of clients that the BSS supports. |
Frame format |
Client data frame encapsulation format: · Dot3—802.3 format. · Dot11—802.11 format. |
Seamless roam status |
Seamless roaming status: · Disabled. · Enabled. |
Seamless roam RSSI threshold |
Seamless roaming RSSI threshold. |
Seamless roam RSSI gap |
Seamless roaming RSSI gap. |
VLAN ID |
ID of the VLAN to which clients belong after they come online through the service template. |
AKM mode |
AKM mode: · 802.1X. · PSK. |
Security IE |
Security IE: · RSN. · WPA. |
Cipher suite |
Cipher suite: · WEP40. · WEP104. · WEP128. · TKIP. · CCMP. |
TKIP countermeasure time |
TKIP countermeasure time. The value 0 indicates no countermeasures are taken. |
GTK rekey |
Whether GTK rekey is enabled: · Enabled. · Disabled. |
GTK rekey method |
GTK rekey method: · Time-based. · Packet-based. |
GTK rekey time |
GTK rekey interval. |
GTK rekey packets |
Number of packets that can be transmitted before the GTK is refreshed. |
GTK rekey client-offline |
Whether client-off GTK rekey is enabled: · Enabled. · Disabled. |
Authentication mode: · Bypass—No authentication. · MAC. · MAC-or-802.1X—MAC authentication is performed first. If MAC authentication fails, 802.1X authentication is performed. · 802.1X. · 802.1X-or-MAC—802.1X authentication is performed first. If 802.1X authentication fails, MAC authentication is performed. · OUI-or-802.1X—OUI authentication is performed first. If OUI authentication fails, 802.1X authentication is performed. |
Intrusion protection |
Whether intrusion protection is enabled: · Enabled. · Disabled. |
Intrusion protection mode |
Intrusion protection mode: · Temporary-block—Temporarily adds intruders to the block list. · Service-stop—Stops all services provided by the BSS that receives illegal packets until it resets. · Temporary-service-stop—Temporarily stops the access service provided by the BSS that receives illegal packets. |
Temporary block time |
Temporary block time in seconds. |
Temporary service stop time |
Temporary service stop time in seconds. |
Fail VLAN ID |
ID of the VLAN to which clients are added if they cannot pass the authentication when the authentication server can be reached. This field displays Not configured if the fail VLAN ID is not configured. |
Critical VLAN ID |
ID of the VLAN to which clients are added if they cannot pass the authentication because the authentication server cannot be reached. This field displays Not configured if the critical VLAN ID is not configured. |
802.1X handshake |
Whether 802.1X handshake is enabled: · Enabled. · Disabled. |
802.1X handshake secure |
Whether secure 802.1X handshake is enabled: · Enabled. · Disabled. |
802.1X domain |
802.1X authentication domain. This field displays Not configured if the domain is not configured. |
MAC-auth domain |
MAC authentication domain. This field displays Not configured if the domain is not configured. |
Max 802.1X users per BSS |
Maximum number of supported 802.1X users in a BSS. |
Max MAC-auth users per BSS |
Maximum number of supported users that pass the MAC authentication in a BSS. |
802.1X re-authenticate |
Whether 802.1X reauthentication is enabled: · Enabled. · Disabled. |
Authorization fail mode |
Authorization fail mode: · Offline—Clients are logged off when authorization fails. · Online—Clients are not logged off when authorization fails. |
Accounting fail mode |
Accounting fail mode: · Offline—Clients are logged off when accounting fails. · Online—Clients are not logged off when accounting fails. |
Authorization |
Authorization information: · Permitted—Applies the authorization information issued by the RADIUS server or the local device. · Ignored—Ignores the authorization information issued by the RADIUS server or the local device. |
Key derivation |
Key derivation type: · SHA1—Uses the HMAC-SHA1 hash algorithm. · SHA256—Uses the HMAC-SHA256 hash algorithm. · SHA1-AND-SHA256—Uses the HMAC SHA1 and SHA256 hash algorithm. |
PMF status |
PMF status: · Disabled—Management frame protection is disabled. · Optional—Management frame protection in optional mode is enabled. · Mandatory—Management frame protection in mandatory mode is enabled. |
Forwarding policy status |
WLAN forwarding policy status: · Disabled. · Enabled. |
WLAN forwarding policy name: · Not configured—No WLAN forwarding policy is configured. · policy-name. |
Forwarder |
Client traffic forwarder: · AC—AC in a non-AC hierarchical network and local AC in an AC hierarchical network. · AP. · Central AC. This field is not supported in the current software version. |
FT status |
FT status: · Disabled. · Enabled. This field is not supported in the current software version. |
FT method |
FT method: · over-the-air. · over-the-ds. This field is not supported in the current software version. |
FT reassociation deadline |
FT reassociation timeout timer in seconds. |
QoS trust |
QoS priority trust mode: · Port—Port priority trust mode. · Dot11e—802.11e priority trust mode. |
QoS priority |
Port priority in the range of 0 to 7. |
display wlan statistics
Use display wlan statistics to display client statistics or service template statistics.
display wlan statistics { client [ mac-address mac-address ] | service-template service-template-name [ connect-history ] }
client: Specifies client statistics.
mac-address mac-address: Specifies a client by its MAC address. If you do not specify this option, the command displays statistics for all clients.
service-template service-template-name: Specifies a service template by its name.
# Display statistics for all clients.
<Sysname> display wlan statistics client
MAC address : 0014-6c8a-43ff
AP name : ap1
Radio ID : 1
SSID : office
BSSID : 000f-e2ff-7700
RSSI : 31
Sent frames:
Back ground : 0/0 (frames/bytes)
Best effort : 9/1230 (frames/bytes)
Video : 0/0 (frames/bytes)
Voice : 2/76 (frames/bytes)
Received frames:
Best effort : 18/2437 (frames/bytes)
Voice : 7/468 (frames/bytes)
Discarded frames:
Best effort : 0/0 (frames/bytes)
Voice : 5/389 (frames/bytes)
Table 12 Command output
SSID |
MAC address |
Back ground |
AC-BK queue. |
Best effort |
AC-BE queue. |
Video |
AC-VI queue. |
Voice |
AC-VO queue. |
# Display statistics for service template 1.
<Sysname> display wlan statistics service-template 1
AP name : ap1
Radio ID : 1
Received:
Frame count : 1713
Frame bytes : 487061
Data frame count : 1683
Data frame bytes : 485761
Association request count : 2
Sent:
Frame count : 62113
Frame bytes : 25142076
Data frame count : 55978
Data frame bytes : 22626600
Association response count : 2
# Display the connection history for service template 1.
<Sysname> display wlan statistics service-template 1 connect-history
AP name : ap1
Radio ID : 1
Associations : 132
Association failures : 3
Reassociations : 30
Rejections : 12
Abnormal disassociations : 2
Current associations : 57
AP name : ap1
Radio ID : 2
Associations : 1004
Association failures : 35
Reassociations : 59
Rejections : 4
Abnormal disassociations : 22
Current associations : 300
# Display the connection history for AP ap1.
<Sysname> display wlan statistics ap name ap1 connect-history
AP name : ap1
Associations : 1
Reassociations : 0
Failures : 0
Rejections : 0
Abnormal disassociations : 0
Current associations : 1
display wlan whitelist
Use display wlan whitelist to display whitelist entries.
# Display whitelist entries.
<Sysname> display wlan whitelist
MAC addresses:
000e-35b2-000e
0019-5b8e-b709
001c-f0bf-9c92
Use quick-association to enable quick association.
Use undo quick-association to disable quick association.
undo quick-association enable
Quick association is disabled.
This command disables APs from performing load balancing or band navigation on clients associated with the specified service template.
# Enable quick association for service template service1.
[Sysname-wlan-st-service1]quick-association enable
region-code
Use region-code to specify a region code.
Use undo region-code to restore the default.
region-code code
undo region-code
The region code is CN.
Global configuration view
code: Specifies a region code. For more information about region codes, see Table 13.
Table 13 Region code information
Country |
Code |
Country |
Code |
Andorra |
AD |
Korea, Republic of Korea |
KR |
United Arab Emirates |
AE |
Kenya |
KE |
Albania |
AL |
Kuwait |
KW |
Armenia |
AM |
Kazakhstan |
KZ |
Australia |
AU |
Lebanon |
LB |
Argentina |
AR |
Liechtenstein |
LI |
Australia |
AT |
Sri Lanka |
LK |
Azerbaijan |
AZ |
Lithuania |
LT |
Bosnia and Herzegovina |
BA |
Luxembourg |
LU |
Belgium |
BE |
Latvia |
LV |
Bulgaria |
BG |
Libyan |
LY |
Bahrain |
BH |
Morocco |
MA |
Brunei Darussalam |
BN |
Monaco |
MC |
Bolivia |
BO |
Moldova |
MD |
Brazil |
BR |
Macedonia |
MK |
Bahamas |
BS |
Macau |
MO |
Belarus |
BY |
Martinique |
MQ |
Belize |
BZ |
Malta |
MT |
Canada |
CA |
Mauritius |
MU |
Switzerland |
CH |
Mexico |
MX |
Cote d'ivoire |
CI |
Malay Archipelago |
MY |
Chile |
CL |
Namibia |
NA |
China |
CN |
Nigeria |
NG |
Colombia |
CO |
Nicaragua |
NI |
Costarica |
CR |
Netherlands |
NL |
Serbia |
RS |
Norway |
NO |
Cyprus |
CY |
New Zealand |
NZ |
Czech Republic |
CZ |
Oman |
OM |
Germany |
DE |
Panama |
PA |
Denmark |
DK |
Peru |
PE |
Dominica |
DO |
Poland |
PL |
Algeria |
DZ |
Philippines |
PH |
Ecuador |
EC |
Pakistan |
PK |
Estonia |
EE |
Puerto Rico |
PR |
Egypt |
EG |
Portugal |
PT |
Spain |
ES |
Paraguay |
PY |
Faroe Islands |
FO |
Qatar |
QA |
Finland |
FI |
Romania |
RO |
France |
FR |
Russian Federation |
RU |
Britain |
GB |
Saudi Arabia |
SA |
Georgia |
GE |
Sweden |
SE |
Gibraltar |
GI |
Singapore |
SG |
Greenland |
GL |
Slovenia |
SI |
Guadeloupe |
GP |
Slovak |
SK |
Greece |
GR |
San Marino |
SM |
Guatemala |
GT |
Salvador |
SV |
Guyana |
GY |
Syrian |
SY |
Honduras |
HN |
Thailand |
TH |
Hong Kong |
HK |
Tunisia |
TN |
Croatia |
HR |
Turkey |
TR |
Hungary |
HU |
Trinidad and Tobago |
TT |
Iceland |
IS |
, China |
TW |
India |
IN |
Ukraine |
UA |
Indonesia |
ID |
United States of America |
US |
Ireland |
IE |
Uruguay |
UY |
Israel |
IL |
Uzbekistan |
UZ |
Iraq |
IQ |
The Vatican City State |
VA |
Italy |
IT |
Venezuela |
VE |
Iran |
IR |
Virgin Islands |
VI |
Jamaica |
JM |
Vietnam |
VN |
Jordan |
JO |
Yemen |
YE |
Japan |
JP |
South Africa |
ZA |
Democratic People's Republic of Korea |
KP |
Zimbabwe |
ZW |
A region code determines characteristics such as available frequencies, available channels, and transmit power level. Set a valid region code before configuring an AP.
# Specify US as the global region code.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] region-code US
region-code-lock
region-code-lock
Use region-code-lock enable to lock the region code.
Use region-code-lock disable to unlock the region code.
Use undo region-code-lock to restore the default.
region-code-lock { disable | enable }
The region code is not locked.
A locked region code cannot be changed.
# Lock the global region code.
[Sysname-wlan-global-configuration] region-code-lock enable
region-code
reset wlan client
Use reset wlan client to log off a client or all clients.
reset wlan client { all | mac-address mac-address }
View
all: Specifies all clients.
# Log off all clients.
<Sysname> reset wlan client all
display wlan client
reset wlan dynamic-blacklist
Use reset wlan dynamic-blacklist to remove the specified client or all clients from the dynamic blacklist.
reset wlan dynamic-blacklist [ mac-address mac-address ]
mac-address mac-address: Specifies a client by its MAC address. If you do not specify this option, the command removes all clients from the dynamic blacklist.
# Remove all clients from the dynamic blacklist.
<Sysname> reset wlan dynamic-blacklist
# Remove the specified client from the dynamic blacklist.
<Sysname> reset wlan dynamic-blacklist mac-address b8ca-32a2-df69
reset wlan statistics client
Use reset wlan statistics client to clear client statistics.
reset wlan statistics client { all | mac-address mac-address }
View
# Clear statistics about all clients.
<Sysname> reset wlan statistics client all
reset wlan statistics service-template
Use reset wlan statistics service-template to clear service template statistics.
reset wlan statistics service-template service-template-name
View
# Clear statistics about service template service1.
<Sysname> reset wlan statistics service-template service1
service-template
Use service-template to bind a service template to a radio or a radio interface.
Use undo service-template to unbind a service template from a radio or a radio interface.
undo service-template service-template-name
No service template is bound to a radio interface.
WLAN-Radio interface view
Before you bind a service template to a radio or a radio interface, you must create the service template.
# Bind service template service1 to interface WLAN-Radio 1/0/1.
[Sysname] interface wlan-radio 1/0/1
[Sysname-wlan-radio-1] service-template service1
service-template enable
Use service-template enable to enable a service template.
Use undo service-template enable to disable a service template.
A service template is disabled.
If the number of BSSs on a device exceeds the limit, you cannot enable a new service template.
# Enable service template service1.
[Sysname-wlan-st-service1] service-template enable
snmp-agent trap enable wlan client
Use snmp-agent trap enable wlan client to enable SNMP notification for client access.
Use undo snmp-agent trap enable wlan client to disable SNMP notification for client access.
SNMP notification is disabled for client access.
When this feature is enabled, the device sends a client status change notification to an NMS every time the status of a client changes. For the notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
# Enable SNMP notification for client access.
[Sysname] snmp-agent trap enable wlan client
snmp-agent trap enable wlan client-audit
Use snmp-agent trap enable wlan client-audit to enable SNMP notification for client audit.
Use undo snmp-agent trap enable wlan client-audit to disable SNMP notification for client audit.
SNMP notification is disabled for client audit.
When this feature is enabled, the device sends a client status change notification to an NMS when a client comes online, goes offline, roams to another AP, or obtains an IP address. For the notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
# Enable SNMP notification for client audit.
[Sysname] snmp-agent trap enable wlan client-audit
ssid
Use ssid to set an SSID for a service template.
Use undo ssid to restore the default.
ssid ssid-name
undo ssid
No SSID is configured for a service template.
ssid-name: Specifies an SSID name, a case-sensitive string of 1 to 32 characters.
Disable the service template before you execute this command.
# Set the SSID to lynn for service template service1.
[Sysname-wlan-st-service1] ssid lynn
unknown-client
Use unknown-client to set the way that an AP processes traffic from unknown clients.
Use undo unknown-client to restore the default.
unknown-client { deauthenticate | drop }
undo unknown-client
The AP drops packets from unknown clients and deauthenticates these clients.
deauthenticate: Drops packets from unknown clients and deauthenticates these clients.
drop: Drops packets from unknown clients.
# Configure the AP that uses service template example to drop packets from unknown clients but not deauthenticate these clients.
[Sysname] wlan service-template example
[Sysname -wlan-st-example] unknown-client drop
vlan
Use vlan to assign clients coming online through a service template to the specified VLAN.
Use undo vlan to restore the default.
vlan vlan-id
undo vlan
Clients are assigned to VLAN 1 after coming online through a service template.
vlan-id: Specifies a VLAN by its VLAN ID, in the range of 1 to 4094. If the specified VLAN does not exist, this command creates the VLAN when clients come online.
# Assign clients coming online through service template service1 to VLAN 2.
[Sysname-wlan-st-service1] vlan 2
wlan broadcast-probe reply
Use wlan broadcast-probe reply to enable the AP to respond to broadcast probe requests.
Use undo wlan broadcast-probe reply to disable the AP from responding to broadcast probe requests.
The AP responds to broadcast probe requests.
# Disable the AP from responding to broadcast probe requests.
[Sysname] undo wlan broadcast-probe reply
wlan client idle-timeout
Use wlan client idle-timeout to set the client idle timeout timer.
Use undo wlan client idle-timeout to restore the default.
wlan client idle-timeout timeout
The client idle timeout timer is 3600 seconds.
timeout: Specifies the client idle timeout timer in the range of 60 to 86400 seconds.
If an online client does not send any frames to the associated AP before the client idle timeout timer expires, the AP logs off the client.
# Set the client idle timeout timer to 2000 seconds.
[Sysname] wlan client idle-timeout 2000
wlan client keep-alive
Use wlan client keep-alive enable to enable client keepalive.
Use undo wlan client keep-alive to disable client keepalive.
Client keepalive is disabled.
This feature enables the AP to send keepalive packets to clients at the specified intervals to determine whether the clients are online. If the AP does not receive any replies from a client within three keepalive intervals, it logs off the client.
# Enable client keepalive.
[Sysname] client keep-alive enable
wlan client keep-alive interval
wlan client keepalive interval
Use wlan client keepalive interval to set the client keepalive interval.
Use undo wlan client keepalive interval to disable client keepalive.
wlan client keepalive interval interval
The client keepalive interval is 300 seconds.
interval: Specifies the client keepalive interval in the range of 3 to 1800 seconds.
Enable client keepalive on the AP before you execute this command.
This command enables the AP to send keepalive packets to clients at the client keepalive interval to determine whether the clients are online. If the AP does not receive any replies from a client within three keepalive intervals, it logs off the client.
# Set the client keepalive interval to 1000 seconds.
[Sysname] wlan client keepalive interval 1000
wlan client reauthentication-period
Use wlan client reauthentication-period to set the idle period before client reauthentication.
Use undo wlan client reauthentication-period to restore the default.
wlan client reauthentication-period [ period-value ]
The idle period is not configured.
period-value: Specifies the idle period in the range of 1 to 3600 seconds. By default, the idle period is 10 seconds.
Set the idle period before client reauthentication to reduce reauthentication failures.
When URL redirection is enabled for WLAN MAC authentication clients, an AP logs off a client that has passed MAC authentication. At the next MAC authentication attempt, the client can pass MAC authentication and access the WLAN. With the idle period configured, the AP adds the client to the dynamic blacklist after logging off the client and the client entry ages out after the specified idle period.
# Set the idle period before client reauthentication to 100 seconds.
[Sysname] wlan client reauthentication-period 100
wlan gps-report enable
NOTE: Support for this command depends on the device model. |
Use wlan gps-report enable to enable GPS information reporting.
Use undo wlan gps-report enable to disable GPS information reporting.
GPS information reporting is disabled.
This feature enables the AP to output GPS information every 5 seconds and send the GPS information to the information center. For more information about the destination and output rules in the information center, see Network Management and Monitoring Configuration Guide.
Only APs installed with GPS antennas can obtain GPS information. If you enable this feature on an AP that does not have any GPS antennas, the AP does not output or send GPS information.
# Enable GPS information reporting.
[Sysname] wlan gps-report enable
[Sysname] %Jan 1 12:45:33:697 2014 H3C APMGR/6/APMGR_AP_GPSREPORT: SN=CN51GTG0GK, Lng=117.788887, Lat=30.822136, Velocity=25.445878, Orientation=8.054548, DayTime=2016-03-28 15:32:19, Elevation=156.655897.
Table 14 Command output
SN |
Serial number of the AP. |
Lng |
Longitude rounded to six decimal places. |
Lat |
Latitude rounded to six decimal places. |
Velocity |
Horizontal velocity rounded to six decimal places. |
Orientation |
Orientation rounded to six decimal places. |
DayTime |
Date and time. |
Elevation |
Elevation rounded to six decimal places. |
wlan link-test
Use wlan link-test to test wireless link quality.
wlan link-test mac-address
mac-address: Specifies the client MAC address in the H-H-H format.
Wireless link quality detection enables an AP to test the quality of the link to a wireless client. The AP sends empty data frames to the client at each supported rate. Then it calculates link quality information such as RSSI, packet retransmissions, and RTT based on the responses from the client.
The timeout timer for wireless link quality detection is 10 seconds. If wireless link detection is not completed within the timeout timer, test results cannot be obtained.
# Test the quality of the wireless link to the client with MAC address 60a4-4cda-eff0.
<Sysname> wlan link-test 60a4-4cda-eff0
Testing link to 60a4-4cda-eff0. Press CTRL + C to break.
Link Status
MAC address: 60a4-4cda-eff0
VHT-MCS Rate(Mbps) TxCnt RxCnt RSSI Retries RTT(ms)
NSS = 1
0 32.5 5 5 54 0 0
1 65 5 5 51 0 0
2 97.5 5 5 49 0 0
3 130 5 5 47 0 0
4 195 5 5 45 0 0
5 260 5 5 45 0 0
6 292.5 5 5 44 0 0
7 325 5 5 44 0 0
8 390 5 5 44 0 0
9 433.3 5 5 43 0 0
NSS = 2
0 65 5 5 44 0 0
1 130 5 5 44 0 0
2 195 5 5 44 0 0
3 260 5 5 44 0 0
4 390 5 5 44 0 0
5 520 5 5 44 0 0
6 585 5 5 43 0 0
7 650 5 5 43 0 0
8 780 5 5 43 0 0
9 866.7 5 5 43 0 0
Table 15 Command output
No./MCS/VHT-MCS |
· No.—Rate number for link quality test on 802.11a, 802.11b, or 802.11g clients. · MCS—MCS index for link quality test on 802.11n clients. · VHT-MCS—VHT-MCS index for link quality test on 802.11ac clients. |
Rate(Mbps) |
Rate at which the AP sends wireless link quality detection frames. |
TxCnt |
Number of wireless link quality detection frames sent by the AP. |
RxCnt |
Number of responses received by the AP. |
RSSI |
RSSI of the client detected by the AP. |
Retries |
Number of wireless link quality retransmission frames sent by the AP. |
RTT(ms) |
Round trip time for link quality test frames from the AP to the client. |
NSS |
Number of spatial streams for link quality test on 802.11n or 802.11ac clients. |
Use wlan service-template to create a service template and enter its view, or enter the view of an existing service template.
Use undo wlan service-template to delete a service template.
wlan service-template service-template-name
undo wlan service-template service-template-name
No service template exists.
You cannot delete a service template that has been bound to a radio.
# Create service template service1 and enter its view.
wlan static-blacklist mac-address
Use wlan static-blacklist mac-address to add a client to the static blacklist.
Use undo wlan static-blacklist mac-address to remove a client from the static blacklist.
wlan static-blacklist mac-address mac-address
undo wlan static-blacklist [ mac-address mac-address ]
No clients exist in the static blacklist.
If you add an online client to the static blacklist, the command logs off the client.
You cannot add a client to both the whitelist and the static blacklist.
The undo form of the command removes all clients from the static blacklist if you do not specify the mac-address mac-address option.
# Add MAC address 001c-f0bf-9c92 to the static blacklist.
[Sysname] wlan static-blacklist mac-address 001c-f0bf-9c92
wlan whitelist mac-address
Use wlan whitelist mac-address to add a client to the whitelist.
Use undo wlan whitelist mac-address to remove a client from the whitelist.
wlan whitelist mac-address mac-address
undo wlan whitelist [ mac-address mac-address ]
No clients exist in the whitelist.
When you add the first client to the whitelist, the system asks you whether to disconnect all online clients. Enter Y at the prompt to configure the whitelist.
If you remove an online client from the whitelist, the command logs off the client. If you remove all clients from the whitelist, online clients will not be logged off.
The undo form of the command removes all clients from the whitelist if you do not specify the mac-address mac-address option.
# Add MAC address 001c-f0bf-9c92 to the whitelist.
[Sysname] wlan whitelist mac-address 001c-f0bf-9c92
This command will disconnect all clients. Continue? [Y/N]:
WLAN security commands
WLAN is supported only on the following routers:
· MSR810-W.
· MSR810-W-DB.
· MSR810-W-LM.
· MSR810-W-LM-HK.
· MSR810-W-LM-GL.
The term "AP" in this document refers to MSR routers that support WLAN.
akm mode
Use akm mode to set an authentication and key management (AKM) mode.
Use undo akm mode to restore the default.
akm mode { dot1x | private-psk | psk | anonymous-dot1x }
undo akm mode
No AKM mode is set.
WLAN service template view
dot1x: Specifies 802.1X as the AKM mode.
private-psk: Specifies private PSK as the AKM mode.
psk: Specifies PSK as the AKM mode.
anonymous-dot1x: Specifies WiFi alliance anonymous 802.1X as the AKM mode.
You must set the AKM mode for 802.11i (RSNA) networks.
Each WLAN service template supports only one AKM mode. Set the AKM mode only when the WLAN service template is disabled.
Set the WiFi alliance anonymous 802.1X AKM mode if the OSEN IE is used.
Each of the following AKM modes must be used with a specific authentication mode:
· 802.1X AKM—802.1X authentication mode.
· Private PSK AKM—MAC authentication mode.
· PSK AKM—MAC or bypass authentication mode.
· WiFi alliance anonymous 802.1X AKM—802.1X authentication mode.
For more information about the authentication mode, see "Configuring WLAN user access authentication."
# Set the PSK AKM mode.
[Sysname] wlan service-template security
[Sysname-wlan-st-security] akm mode psk
cipher-suite
security-ie
cipher-suite
Use cipher-suite to specify the cipher suite used for frame encryption.
Use undo cipher-suite to remove the cipher suite configuration.
cipher-suite { ccmp | tkip | wep40 | wep104 | wep128 }
undo cipher-suite { ccmp | tkip | wep40 | wep104 | wep128 }
No cipher suite is specified.
ccmp: Specifies the AES-CCMP cipher suite.
tkip: Specifies the TKIP cipher suite.
wep40: Specifies the WEP40 cipher suite.
wep104: Specifies the WEP104 cipher suite.
wep128: Specifies the WEP128 cipher suite.
You must set the cipher suite for 802.11i networks. Set a cipher suite only when the WLAN service template is disabled.
Set the TKIP or CCMP cipher suite when you configure the RSN IE or WPA IE.
The WEP cipher suite includes three types, WEP40, WEP104, and WEP128. Each WLAN service template supports only one type of WEP cipher suite. After you set a type of WEP cipher suite, you must create and apply a key of the same type.
WEP128 cannot be set if the CCMP or TKIP cipher suite is configured.
# Set the TKIP cipher suite for frame encryption.
[Sysname-wlan-st-security] cipher-suite tkip
security-ie
wep key
wep key-id
gtk-rekey client-offline enable
Use gtk-rekey client-offline enable to enable offline-triggered GTK update.
Use undo gtk-rekey client-offline to restore the default.
undo gtk-rekey client-offline enable
Offline-triggered GTK update is disabled.
Enable offline-triggered GTK update only when GTK update is enabled.
# Enable offline-triggered GTK update.
[Sysname-wlan-st-security] gtk-rekey client-offline enable
gtk-rekey enable
gtk-rekey enable
Use gtk-rekey enable to enable GTK update.
Use undo gtk-rekey enable to disable GTK update.
gtk-rekey enable
# Enable GTK update.
[Sysname-wlan-st-security] gtk-rekey enable
gtk-rekey method
Use gtk-rekey method to set a GTK update method.
Use undo gtk-rekey method to restore the default.
gtk-rekey method { packet-based [ packet ] | time-based [ time ] }
The GTK is updated at an interval of 86400 seconds.
packet-based packet: Specifies the number of packets (including multicasts and broadcasts) that are transmitted before the GTK is updated. The value range for the packet argument is 5000 to 4294967295 and the default is 10000000.
time-based time: Specifies the interval at which the GTK is updated. The value range for the time argument is 180 to 604800 seconds and the default is 86400 seconds.
Set the GTK update method only when GTK update is enabled.
The most recent configuration overwrites the previous one. For example, if you set the packet-based method and then set the time-based method, the time-based method takes effect.
If you set the GTK update method after the service template is enabled, the change takes effect when the following conditions exist:
· If you change the GTK update interval, the new interval takes effect when the old timer times out.
· If you change the packet number threshold, the new threshold takes effect immediately.
· If you change the GTK update method to packet-based, the new method takes effect when the timer is deleted and the packet number threshold is reached.
· If you change the GTK update method to time-based, the configuration takes effect immediately.
# Enable time-based GTK update.
[Sysname-wlan-st-security] gtk-rekey method time-based 3600
# Enable packet-based GTK update.
[Sysname-wlan-st-security] gtk-rekey method packet-based 600000
gtk-rekey enable
key-derivation
Use key-derivation to set the key derivation function (KDF).
Use undo key-derivation to restore the default.
key-derivation { sha1 | sha1-and-sha256 | sha256 }
undo key-derivation
The KDF is the HMAC-SHA1 algorithm.
sha1: Specifies the HMAC-SHA1 algorithm as the KDF.
sha256: Specifies the HMAC-SHA256 algorithm as the KDF.
sha1-and-sha256: Specifies the HMAC-SHA1 algorithm and the HMAC-SHA256 algorithm as the KDFs.
KDFs take effect only for a network that uses the 802.11i mechanism.
The HMAC-SHA256 algorithm is recommended if mandatory management frame protection is enabled.
# Configure the HMAC-SHA256 algorithm as the KDF.
[Sysname] wlan service-template 1
[Sysname-wlan-st-1] key-derivation sha256
akm mode
cipher-suite
security-ie
pmf
Use pmf to enable management frame protection.
Use undo pmf to restore the default.
pmf { mandatory | optional }
undo pmf
mandatory: Specifies the mandatory mode. Only clients that support management frame protection can access the WLAN.
optional: Specifies the optional mode. All clients can access the WLAN.
Management frame protection takes effect only for a network that uses the 802.11i mechanism and is configured with the CCMP cipher suite and RSN security information element.
# Enable management frame protection in optional mode.
[Sysname-wlan-st-1] pmf optional
cipher-suite
security-ie
pmf association-comeback
Use pmf association-comeback to set the association comeback time.
Use undo pmf association-comeback to restore the default.
pmf association-comeback time
The association comeback time is 1 second.
time: Specifies the association comeback time in the range of 1 to 20 seconds.
If an AP rejects the current association or reassociation request from a client, it returns an association/reassociation response that carries the association comeback time. The AP starts to receive the association or reassociation request from the client when the association comeback time times out.
# Set the association comeback time to 2 seconds.
[Sysname-wlan-st-1] pmf association-comeback 2
pmf saquery retrycount
Use pmf saquery retrycount to maximum retransmission attempts for SA query requests.
Use undo pmf saquery retrycount to restore the default.
pmf saquery retrycount count
The maximum retransmission attempt number is 4 for SA query requests.
count: Specifies the maximum retransmission attempts for SA query requests, in the range of 1 to 16.
If an AP does not receive an acknowledgment for the SA query request after retransmission attempts reach the maximum number, the AP determines that the client is offline.
# Set the number of maximum retransmission attempt to 3 for SA query requests.
[Sysname-wlan-st-1] pmf saquery retrycount 3
pmf
pmf saquery retrytimeout
Use pmf saquery retrytimeout to set the interval for sending SA query requests.
Use undo pmf saquery retrytimeout to restore the default.
pmf saquery retrytimeout timeout
The interval for sending SA query requests is 200 milliseconds.
timeout: Specifies the interval for an AP to send SA query requests, in the range of 100 to 500 milliseconds.
# Set the interval for sending SA query requests to 300 milliseconds.
[Sysname-wlan-st-1] pmf saquery retrytimeout 300
pmf
preshared-key
Use preshared-key to set the PSK.
Use undo preshared-key to restore the default.
preshared-key { pass-phrase | raw-key } { cipher | simple } string
undo preshared-key
No PSK is set.
pass-phrase: Sets a PSK, a character string.
raw-key: Sets a PSK, a hexadecimal number.
cipher: Sets a key in encrypted form.
simple: Sets a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies a key string. This argument is case sensitive. Key length varies by key type:
· pass-phrase—Its plaintext form is 8 to 63 characters. Its encrypted form is 8 to 117 characters.
· raw-key—Its plaintext form is 64 hexadecimal digits. Its encrypted form is 8 to 117 characters.
Set the PSK only when the WLAN service template is disabled and the AKM mode is PSK. If you set the PSK when the AKM mode is 802.1X, the WLAN service template can be enabled but the PSK configuration does not take effect.
You can set only one PSK for a WLAN service template.
# Configure simple character string 12345678 as the PSK.
[Sysname-wlan-st-security] preshared-key pass-phrase simple 12345678
akm mode
ptk-lifetime
Use ptk-lifetime to set the PTK lifetime.
Use undo ptk-lifetime to restore the default.
ptk-lifetime time
undo ptk-lifetime
The PTK lifetime is 43200 seconds.
time: Specifies the lifetime of the PSK, in the range of 180 to 604800 seconds.
If you configure the PTK lifetime when the service template is enabled, the configuration takes effect after the old timer times out.
# Set the PTK lifetime to 200 seconds.
[Sysname-wlan-st-security] ptk-lifetime 200
ptk-rekey enable
Use ptk-rekey enable to enable PTK update.
Use undo ptk-rekey enable to disable PTK update.
ptk-rekey enable
PTK update is enabled.
This feature enables the device to update the PTK after the PTK lifetime expires.
# Enable PTK update.
[Sysname-wlan-st-security] ptk-rekey enable
ptk-lifetime
security-ie
Use security-ie to enable the OSEN IE, RSN IE, or WPA IE in beacon and probe responses.
Use undo security-ie to disable the OSEN IE, RSN IE, or WPA IE in beacon and probe responses.
security-ie { osen | rsn | wpa }
undo security-ie { osen | rsn | wpa }
OSEN IE, RSN IE, and WPA IE are disabled.
osen: Enables the OSEN IE in the beacon and probe response frames sent by the AP. The OSEN IE advertises the OSEN capabilities of the AP.
rsn: Enables the RSN IE in the beacon and probe response frames sent by the AP. The RSN IE advertises the RSN capabilities of the AP.
wpa: Enables the WPA IE in the beacon and probe response frames sent by the AP. The WPA IE advertises the WPA capabilities of the AP.
You must set the security IE for 802.11i networks. Set a security IE only when the WLAN service template is disabled and the CCMP or TKIP cipher suite is configured.
You can set both the WPA IE and RSN IE for the same WLAN service template. The WPA IE and RSN IE cannot be used together with the OSEN IE for a WLAN service template.
# Enable the RSN IE in beacon and probe responses.
[Sysname-wlan-st-security] security-ie rsn
akm mode
cipher-suite
snmp-agent trap enable wlan usersec
Use snmp-agent trap enable wlan usersec to enable SNMP notifications for WLAN security.
Use undo snmp-agent trap enable wlan usersec to disable SNMP notifications for WLAN security.
SNMP notifications are disabled for WLAN security.
To report critical WLAN security events to an NMS, enable SNMP notifications for WLAN security. For WLAN security event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Enable SNMP notifications for WLAN security.
[Sysname] snmp-agent trap enable wlan usersec
tkip-cm-time
Use tkip-cm-time to set the TKIP MIC failure hold time.
Use undo tkip-cm-time to restore the default.
tkip-cm-time time
undo tkip-cm-time
The TKIP MIC failure hold time is 0 seconds. The AP does not take any countermeasures.
time: Sets the TKIP MIC failure hold time in the range of 0 to 3600 seconds.
Set the TKIP MIC failure hold time only when the TKIP cipher suite is configured.
If you configure the MIC failure hold time when the service template is enabled, the configuration takes effect after the old timer times out.
If the AP detects two MIC failures within the MIC failure hold time, it disassociates all clients for 60 seconds.
# Set the TKIP MIC failure hold time to 180 seconds.
[Sysname-wlan-st-security] tkip-cm-time 180
cipher-suite
wep key
Use wep key to set a WEP key.
Use undo wep key to delete the configured WEP key.
wep key key-id { wep40 | wep104 | wep128 } { pass-phrase | raw-key } { cipher | simple } string
undo wep key key-id
No WEP key is set.
key-id: Sets the key ID in the range of 1 to 4.
wep40: Sets the WEP40 key.
wep104: Sets the WEP104 key.
wep128: Sets the WEP128 key.
pass-phrase: Sets a WEP key, a character string.
raw-key: Sets a WEP key, a hexadecimal number.
key: Specifies a key string. This argument is case sensitive. The cipher key length is in the range of 37 to 73 characters. The plaintext key length varies by key type:
· wep40 pass-phrase—Its plaintext form is 5 characters.
· wep104 pass-phrase—Its plaintext form is 13 characters.
· wep128 pass-phrase—Its plaintext form is 16 characters.
· wep40 raw-key—Its plaintext form is 10 hexadecimal digits.
· wep104 raw-key—Its plaintext form is 26 hexadecimal digits.
· wep128 raw-key—Its plaintext form is 32 hexadecimal digits.
Set a WEP key only when the WLAN service template is disabled and the cipher suite WEP is configured. You can set a maximum of four WEP keys.
# Configure the cipher suite WEP40 and configure plain text 12345 as WEP key 1.
[Sysname-wlan-st-security] cipher-suite wep40
[Sysname-wlan-st-security] wep key 1 wep40 pass-phrase simple 12345
cipher-suite
wep key-id
wep key-id
Use wep key-id to apply a WEP key.
Use undo wep key-id to restore the default.
wep key-id { 1 | 2 | 3 | 4 }
undo wep key-id
Key 1 is applied.
1: Specifies the WEP key whose ID is 1.
2: Specifies the WEP key whose ID is 2.
3: Specifies the WEP key whose ID is 3.
4: Specifies the WEP key whose ID is 4.
Apply a WEP key only when the WLAN service template is disabled.
In the 802.11i mechanism, key 1 is the negotiated key. To apply a WEP key, specify a WEP key whose ID is not 1.
You can only apply an existing WEP key.
# Configure the cipher suite WEP40, configure plain text 12345 as WEP key 1, and apply WEP key 1.
[Sysname-wlan-st-security] wep key-id 1
wep key
wep mode dynamic
Use the wep mode dynamic command to enable the dynamic WEP mechanism.
Use the undo wep mode dynamic command to disable the dynamic WEP mechanism.
wep mode dynamic
The dynamic WEP mechanism is disabled.
Enable the dynamic WEP mechanism only when the WLAN service template is disabled.
The dynamic WEP mechanism requires 802.1X authentication for user access authentication.
Do not apply WEP key 4 if the dynamic WEP mechanism is enabled.
# Enable the dynamic WEP mechanism.
[Sysname-wlan-st-security] wep mode dynamic
cipher-suite
client-security authentication-mode
wep key
wep key-id
WLAN authentication commands
· MSR810-W.
· MSR810-W-DB.
· MSR810-W-LM.
· MSR810-W-LM-HK.
· MSR810-W-LM-GL.
This chapter describes WLAN-specific authentication commands. For more information about 802.1X and MAC authentication commands, see Security Command Reference.
client url-redirect enable
Use client url-redirect enable to enable URL redirection for WLAN clients.
Use undo client url-redirect enable to disable URL redirection for WLAN clients.
URL redirection is disabled for WLAN clients
Service template view
This command is configurable when the service template is disabled, and it takes effect after the service template is enabled.
This command takes effect only on clients that use RADIUS-based MAC authentication.
A client is allowed to pass RADIUS-based MAC authentication only when its credential information (username and password) and MAC address are recorded on the RADIUS server.
This command facilitates MAC authentication for a client whose credential information and MAC address are not recorded on the RADIUS server. After this command is enabled, the client will perform Web authentication on the Web interface specified by the RADIUS server-assigned redirect URL. After the client passes Web authentication, the RADIUS server records the client's credential information and MAC address. At the same time, the server uses DM requests to log off the client. At the next MAC authentication attempt, the client can pass MAC authentication. For information about DMs, see AAA in Security Configuration Guide.
# Enable URL redirection for WLAN clients on service template service1.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] client url-redirect enable
client-security accounting-delay time
Use client-security accounting-delay time to configure the accounting delay.
Use undo client-security accounting-delay time to restore the default.
client-security accounting-delay time time [ no-ip-logoff ]
The device sends start-accounting requests for a client when the device learns the IP address of the client.
time: Specifies the accounting delay timer that starts after the client passes 802.1X or MAC authentication. The value range for the time argument is 1 to 60 seconds.
no-ip-logoff: Logs off a client if the device fails to obtain the client IP address within the delay timer. If you do not specify this keyword, the device sends start-accounting requests when the delay timer expires.
The device takes a predefined action on a client if it does not learn an IP address of the specified type for the client within the delay time. To specify the type of IP addresses that have the accounting-start qualification, use the client-security accounting-start trigger command. When the IP address type is set to none, the accounting delay feature does not take effect.
As a best practice, consider the time the device takes to obtain an IP address when you set the accounting delay timer. Increase the delay timer in a low-performance network.
If you execute this command on a service template that has been enabled, the command takes effect only on subsequent clients. It does not affect clients that have been online since before this command is executed.
# On service template service1, set the accounting delay timer to 15 seconds. Configure the device to log off a client if it fails to learn the required client IP address within the delay timer.
[Sysname-wlan-st-service1] client-security accounting-delay time 15 no-ip-logoff
Use client-security accounting-start trigger to specify an IP address type to have the accounting-start qualification.
Use undo client-security accounting-start trigger to restore the default.
client-security accounting-start trigger { ipv4 | ipv4-ipv6 | ipv6 | none }
The IP address type is IPv4.
ipv4: Specifies the IPv4 address type.
ipv4-ipv6: Specifies the IPv4 or IPv6 address type.
ipv6: Specifies the IPv6 address type.
none: Configures the device to send start-accounting requests for a client when the client passes authentication.
This command allows the device to send start-accounting requests to the accounting server only for clients that use a specific type of IP addresses. The command takes effect on clients that have passed 802.1X or MAC authentication. For more information about accounting, see AAA in Security Configuration Guide.
To configure an IP address type to have the accounting-start qualification, you must enable learning for IP addresses of that type. For information about wireless client IP address learning, see WLAN IP snooping in WLAN Configuration Guide.
The IP address type setting configured by using this command must meet the protocol requirements of the accounting server.
# On service template service1, allow the device to send start-accounting requests only for clients that use IPv6 addresses.
[Sysname-wlan-st-service1] client-security accounting-start trigger ipv6
client ipv4-snooping arp-learning enable
client ipv4-snooping dhcp-learning enable
client ipv6-snooping dhcpv6-learning enable
client ipv6-snooping nd-learning enable
client ipv6-snooping snmp-nd-report enable
client-security accounting-update trigger
Use client-security accounting-update trigger to specify an IP address type to have the accounting-update qualification.
Use undo client-security accounting-update trigger to restore the default.
client-security accounting-update trigger { ipv4 | ipv4-ipv6 | ipv6 }
The device sends update-accounting requests to the accounting server at the server-assigned or user-defined realtime accounting interval.
ipv4: Specifies the IPv4 address type, which indicates that the device triggers accounting update for a client only when the learned IP address of the client changes to an IPv4 address.
ipv4-ipv6: Specifies the IPv4 or IPv6 address type, which indicates that the device triggers accounting update for a client whenever the learned IP address of the client changes.
ipv6: Specifies the IPv6 address type, which indicates that the device triggers accounting update for a client only when the learned IP address of the client changes to an IPv6 address.
This command takes effect only when the client-security accounting-start trigger command takes effect.
This command is independent of the periodic realtime-accounting feature. For example, if you configure the accounting-update trigger as client IP addresses changing to IPv6 addresses and set the realtime accounting interval to 12 minutes, both settings take effect. For a client that uses the settings, the device sends update-accounting requests every 12 minutes and triggers accounting update whenever the client IP address changes to an IPv6 address.
To set the realtime accounting interval, use the timer realtime-accounting command.
# On service template service1, configure the device to trigger accounting update for a client whenever the client IP address changes to an IPv6 address.
[Sysname-wlan-st-service1] client-security accounting-update trigger ipv6
timer realtime-accounting (Security Command Reference)
client-security authentication fail-vlan
Use client-security authentication fail-vlan to configure an Auth-Fail VLAN for a service template.
Use undo client-security authentication fail-vlan to restore the default.
client-security authentication fail-vlan vlan-id
No Auth-Fail VLAN exists for a service template.
vlan-id: Specifies the ID of the Auth-Fail VLAN, in the range of 1 to 4094. Make sure the VLAN has been created.
The WLAN Auth-Fail VLAN accommodates clients that have failed WLAN authentication because of the failure to comply with the organization security strategy. For example, the VLAN accommodates clients that have entered invalid passwords. The Auth-Fail VLAN does not accommodate WLAN clients that have failed authentication for authentication timeouts or network connection problems.
# Configure VLAN 10 as the Auth-Fail VLAN on service template 1.
[Sysname-wlan-st-1] client-security authentication fail-vlan 10
Use client-security authentication-mode to set the authentication mode for WLAN clients.
Use undo client-security authentication-mode to restore the default.
The WLAN authentication mode is Bypass. The device does not perform authentication for WLAN clients.
dot1x: Performs 802.1X authentication only.
dot1x-then-mac: Performs 802.1X authentication first, and then MAC authentication. If the client passes 802.1X authentication, MAC authentication is not performed.
mac: Performs MAC authentication only.
mac-then-dot1x: Performs MAC authentication first, and then 802.1X authentication. If the client passes MAC authentication, 802.1X authentication is not performed.
oui-then-dot1x: Performs OUI authentication first, and then 802.1X authentication. If the client passes OUI authentication, 802.1X authentication is not performed.
A service template allows access of multiple authenticated clients in any authentication mode. To set the maximum number of 802.1X clients, use the dot1x max-user command. To set the maximum number of MAC authentication clients, use the mac-authentication max-user command.
# Set the authentication mode to mac for WLAN clients on service template service1.
[Sysname-wlan-st-service1] client-security authentication-mode mac
client-security authorization-fail offline
Use client-security authorization-fail offline to enable the authorization-fail-offline feature.
Use undo client-security authorization-fail offline to disable the authorization-fail-offline feature.
The authorization-fail-offline feature is disabled.
The authorization-fail-offline feature logs off WLAN clients that fail ACL or user profile authorization.
A WLAN client fails ACL or user profile authorization in the following situations:
· The device or server fails to authorize the specified ACL or user profile to the client.
· The authorized ACL or user profile does not exist.
If this feature is disabled, the device does not log off WLAN clients that fail ACL or user profile authorization. However, the device outputs logs to report the failure.
# Enable the authorization-fail-offline feature for service template service1.
[Sysname-wlan-st-service1] client-security authorization-fail offline
client-security ignore-authentication
Use client-security ignore-authentication to configure the device to ignore the 802.1X or MAC authentication failures.
Use undo client-security ignore-authentication to restore the default.
The device does not ignore the authentication failures for wireless clients that use 802.1X authentication or RADIUS-based MAC authentication.
This command applies to the following clients:
· Clients that use 802.1X authentication.
This command enables the device to ignore the 802.1X authentication failures and allow clients that have failed 802.1X authentication to come online.
· Clients that use both RADIUS-based MAC authentication and portal authentication.
Typically, a client must pass MAC authentication and portal authentication in turn to access network resources. The client provides username and password each time portal authentication is performed.
This command simplifies the authentication process for a client as follows:
¡ If the RADIUS server already records the client's MAC authentication information, the client passes MAC authentication. The device allows the client to access network resources without performing portal authentication.
¡ If the RADIUS server does not record the client's MAC authentication information, the client fails MAC authentication. The device ignores the MAC authentication failure and performs portal authentication for the client. If the client passes portal authentication, it can access network resources. The MAC address of the portal authenticated client will be recorded as MAC authentication information on the RADIUS server.
For 802.1X clients that use RSN to roam to a new AP, do not use this command.
# Configure the device to ignore 802.1X or MAC authentication failures on service template service1.
[Sysname-wlan-st-service1] client-security ignore-authentication
client-security ignore-authorization
Use client-security ignore-authorization to configure the device to ignore the authorization information received from the authentication server (a RADIUS server or the local device).
Use undo client-security ignore-authorization to restore the default.
The device uses the authorization information from the server.
After a client passes RADIUS or local authentication, the server performs authorization based on the authorization attributes configured for the user account. For example, the server can assign a VLAN. If you do not want the device to use these authorization attributes for clients, configure this command to ignore the authorization information from the server.
# Configure the device to ignore the authorization information from the authentication server for service template service1.
[Sysname-wlan-st-service1] client-security ignore-authorization
client-security intrusion-protection action
Use client-security intrusion-protection action to configure the intrusion protection action that the device takes when intrusion protection detects illegal frames.
Use undo client-security intrusion-protection action to restore the default.
The intrusion protection action is temporary-block.
service-stop: Stops the BSS where an illegal frame is received until the BSS is enabled manually on the radio interface.
temporary-block: Adds the source MAC address of an illegal frame to the blocked MAC address list for a period. To set the period, use the client-security intrusion-protection timer temporary-block command.
temporary-service-stop: Stops the BSS where an illegal frame is received for a period. To set the period, use the client-security intrusion-protection timer temporary-service-stop command.
For this command to take effect, you must also use the client-security intrusion-protection enable command to enable the intrusion protection feature.
# Configure the device to stop the BSS where intrusion protection detects illegal frames for service template service1.
[Sysname-wlan-st-service1] client-security intrusion-protection enable
[Sysname-wlan-st-service1] client-security intrusion-protection action service-stop
Use client-security intrusion-protection enable to enable the intrusion protection feature.
Use undo client-security intrusion-protection enable to disable the intrusion protection feature.
The intrusion protection feature is disabled.
When the device receives an association request from an illegal client, the device takes the predefined protection action on the BSS where the request is received. A client is illegal if its MAC address fails WLAN authentication. To set the protection action, use the client-security intrusion-protection action command.
# Enable the intrusion protection feature for service template service1.
Use client-security intrusion-protection timer temporary-block to set the period during which a MAC address is blocked by intrusion protection.
Use undo client-security intrusion-protection timer temporary-block to restore the default.
client-security intrusion-protection timer temporary-block time
An illegal MAC address is blocked for 180 seconds.
time: Specifies the period during which a MAC address is blocked. The value range is 60 to 300 seconds.
This command takes effect only when the intrusion protection action is temporary-block.
If you change the blocking period after the service template is enabled, the new setting takes effect on the subsequent detected illegal packets.
# Configure service template service1 to block illegal MAC addresses for 120 seconds.
[Sysname-wlan-st-service1] client-security intrusion-protection action temporary-block
[Sysname-wlan-st-service1] client-security intrusion-protection timer temporary-block 120
Use client-security intrusion-protection timer temporary-service-stop to set the BSS silence period for intrusion protection.
Use undo client-security intrusion-protection timer temporary-service-stop to restore the default.
client-security intrusion-protection timer temporary-service-stop time
The BSS silence period for intrusion protection is 20 seconds.
time: Specifies the period during which a BSS is disabled. The value range is 10 to 300 seconds.
This command takes effect only when the intrusion protection action is temporary-service-stop.
If you change the BSS silence period after the service template is enabled, the new setting takes effect on the subsequent detected illegal packets.
# Set the BSS silence period to 30 seconds for intrusion protection on service template service1.
[Sysname-wlan-st-service1] client-security intrusion-protection action temporary-service-stop
[Sysname-wlan-st-service1] client-security intrusion-protection timer temporary-service-stop 30
display wlan client-security block-mac
Use display wlan client-security block-mac to display blocked MAC address information for WLAN clients.
A MAC address that fails authentication is added to the blocked MAC address list when the intrusion protection action is temporary-block.
# Display information about all blocked MAC addresses.
<Sysname> display wlan client-security block-mac
MAC address AP ID RADIO ID BSSID
0002-0002-0002 1 1 00ab-0de1-0001
000d-88f8-0577 1 1 0ef1-0001-02c1
Total entries: 2
Table 16 Command output
MAC address |
Blocked MAC address, in the format of H-H-H. |
AP ID |
AP ID of the blocked MAC address. |
RADIO ID |
Radio ID of the blocked MAC address. |
BSSID |
BSS ID of the blocked MAC address, in the format of H-H-H. |
Total entries |
Number of blocked MAC addresses. |
Related commands:
dot1x domain
Use dot1x domain to specify an authentication domain for 802.1X clients on a service template.
Use undo dot1x domain to restore the default.
No authentication domain is specified for 802.1X clients on a service template.
domain-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters.
802.1X chooses an authentication domain for WLAN clients in the following order:
1. Authentication domain specified on the service template.
2. Domain specified by username.
3. Default authentication domain.
# Specify ISP domain my-domain as the authentication domain for 802.1X clients on service template service1.
[Sysname-wlan-st-service1] dot1x domain my-domain
dot1x eap
Use dot1x eap to specify the EAP mode for 802.1X authentication.
Use undo dot1x eap to restore the default.
dot1x eap { extended | standard }
undo dot1x eap
The EAP mode is standard for 802.1X authentication.
extended: Specifies the extended EAP mode. This mode requires the device to interact with clients according to the provisions and packet format defined by the proprietary EAP protocol.
standard: Specifies the standard EAP mode. This mode requires the device to interact with clients according to the provisions and packet format defined by the standard EAP protocol.
When you configure this command, specify the extended keyword for iNode clients and the standard keyword for other clients.
This command is required only when an IMC server is used as the RADIUS server.
# Set the EAP mode to extended for service template 1.
[Sysname-wlan-st-1] dot1x eap extended
dot1x handshake enable
Use dot1x handshake enable to enable the 802.1X online user handshake feature.
Use undo dot1x handshake enable to disable the 802.1X online user handshake feature.
The 802.1X online user handshake feature is disabled.
The online user handshake feature checks the connection status of online 802.1X clients by periodically sending handshake messages to the clients. The device sets a client to the offline state if it does not receive responses from the client after making the maximum handshake attempts within the handshake timer. To set the handshake timer, use the dot1x timer handshake-period command. To set the maximum handshake attempts, use the dot1x retry command.
# Enable the online user handshake feature for 802.1X clients on service template service1.
[Sysname-wlan-st-service1] dot1x handshake enable
dot1x handshake secure enable
dot1x retry (Security Command Reference)
dot1x timer handshake-period (Security Command Reference)
Use dot1x handshake secure enable to enable the 802.1X online user handshake security feature.
Use undo dot1x handshake secure enable to disable the 802.1X online user handshake security feature.
The 802.1X online user handshake security feature is disabled.
For the 802.1X online user handshake security feature to take effect, you must enable the 802.1X online user handshake feature.
The online user handshake security feature protects only authenticated online 802.1X clients.
# Enable the 802.1X online user handshake security feature on service template service1.
[Sysname-wlan-st-service1] dot1x handshake secure enable
dot1x max-user
Use dot1x max-user to set the maximum number of concurrent 802.1X clients on a service template.
Use undo dot1x max-user to restore the default.
A maximum of 4096 concurrent 802.1X clients are allowed on a service template.
count: Specifies the maximum number of concurrent 802.1X clients. The value range is 1 to 4096.
When the maximum number is reached, the service template denies subsequent 802.1X clients.
# Set the maximum number of concurrent 802.1X clients to 32 on service template service1.
[Sysname-wlan-st-service1] dot1x max-user 500
dot1x re-authenticate enable
Use dot1x re-authenticate enable to enable the 802.1X periodic online user reauthentication feature.
Use undo dot1x re-authenticate enable to disable the 802.1X periodic online user reauthentication feature.
The 802.1X periodic online user reauthentication feature is disabled.
Periodic reauthentication enables the device to periodically authenticate online 802.1X clients on a service template. This feature checks the connection status of online clients and updates the authorization attributes assigned by the server, such as the ACL, VLAN, and user profile.
You can use the dot1x timer reauth-period command to configure the interval for reauthentication.
The server-assigned session timeout timer (Session-Timeout attribute) and termination action (Termination-Action attribute) can affect the periodic online user reauthentication feature. To display the server-assigned Session-Timeout and Termination-Action attributes, use the display dot1x connection command (see Security Command Reference).
· If the termination action is Default (logoff), periodic online user reauthentication on the template takes effect only when the periodic reauthentication timer is shorter than the session timeout timer.
· If the termination action is Radius-request, the periodic online user reauthentication configuration on the template does not take effect. The device reauthenticates the online 802.1X clients after the session timeout timer expires.
# Enable the 802.1X periodic online user reauthentication feature on service template service1.
[Sysname-wlan-st-service1] dot1x re-authenticate enable
dot1x timer (Security Command Reference)
mac-authentication domain
Use mac-authentication domain to specify an authentication domain for MAC authentication clients on a service template.
Use undo mac-authentication domain to restore the default.
No authentication domain is specified for MAC authentication clients on a service template.
MAC authentication chooses an authentication domain for WLAN clients in the following order:
2. Global authentication domain specified in system view.
# Specify ISP domain my-domain as the authentication domain for MAC authentication clients on service template service1.
[Sysname-wlan-st-service1] mac-authentication domain my-domain
Use mac-authentication max-user to set the maximum number of concurrent MAC authentication clients on a service template.
Use undo mac-authentication max-user to restore the default.
mac-authentication max-user count
A maximum of 4096 concurrent MAC authentication clients are allowed on a service template.
count: Specifies the maximum number of concurrent MAC authentication clients. The value range for this argument is 1 to 4096.
When the maximum number is reached, the service template denies subsequent MAC authentication clients.
# Configure service template service1 to support a maximum of 32 concurrent MAC authentication clients.
[Sysname-wlan-st-service1] mac-authentication max-user 32
WLAN QoS commands
· MSR810-W.
· MSR810-W-DB.
· MSR810-W-LM.
· MSR810-W-LM-HK.
· MSR810-W-LM-GL.
cac policy
Use cac policy to configure a Connect Admission Control (CAC) policy.
Use undo cac policy to restore the default.
cac policy { channelutilization [ channelutilization-value ] | client [ client-number ] }
undo cac policy
The client-based admission policy is used, and the maximum number of admitted clients is 20.
channelutilization: Specifies the channel usage-based admission policy.
channelutilization-value: Specifies the maximum channel usage in percentage, in the range of 0 to 100. The maximum channel usage refers to the medium time of the accepted AC-VO and AC-VI traffic to the valid time within a certain time. The valid time refers to the time available for transmitting and receiving data. By default, the maximum channel usage is 65%.
client: Specifies the client-based admission policy.
client-number: Specifies the maximum number of clients allowed to be connected, in the range of 0 to 124. A client is counted as one client if it is using both the AC-VO and AC-VI queues.
The CAC policy takes effect only on the AC-VO and the AC-VI queues.
# Configure the channel usage-based admission policy for CAC, and set the maximum channel usage to 70%.
[Sysname] interface wlan-radio 0/1
[Sysname-WLAN-Radio0/1] cac policy channelutilization 70
display wlan wmm
Use display wlan wmm to display WMM statistics.
radio: Displays WMM statistics for radios. If you use this keyword without the interface wlan-radio interface-number option, this command displays WMM statistics for all radios.
mac-address mac-address: Specifies a client by its MAC address in the H-H-H format.
interface wlan-radio interface-number: Specifies a radio interface by its number.
# Display WMM statistics for all radios.
<Sysname> display wlan wmm radio
Radio : 1
Client EDCA updates : 0
QoS mode : WMM
WMM status : Enabled
Radio max AIFSN : 15 Radio max ECWmin : 10
Radio max TXOPLimit : 32767 Radio max ECWmax : 10
CAC information
Clients accepted : 0
Voice : 0
Video : 0
Total request medium time(µs) : 0
Voice(µs) : 0
Video(µs) : 0
Calls rejected due to insufficient resources : 0
Calls rejected due to invalid parameters : 0
Calls rejected due to invalid medium time : 0
Calls rejected due to invalid delay bound : 0
Radio : 2
QoS mode : WMM
WMM status: Disabled
CAC information
Client accepted : 0
Voice : 0
Video : 0
Voice(µs) : 0
Video(µs) : 0
Table 17 Command output
Times that client EDCA parameters have been updated. |
WMM. If this field displays N/A, the QoS mode is not available. |
· Enabled. · Disabled. |
Maximum AIFSN that the radio supports. |
Maximum ECWmin that the radio supports. |
Radio max TXOPLimit |
Maximum TXOPLimit that the radio supports. |
Maximum ECWmax that the radio supports. |
Total request medium time for AC-VO and AC-VI queues, in microseconds. |
# Display WMM statistics for all clients.
<Sysname> display wlan wmm client
MAC address : 000f-e23c-0001 SSID : service
QoS mode : WMM
APSD information :
Max SP length : 7
L: Legacy T: Trigger D: Delivery
AC AC-BK AC-BE AC-VI AC-VO
Assoc State T|D L T|D T|D
Statistics information :
Uplink packets : 0 Downlink packets : 0
Uplink bytes : 0 Downlink bytes : 0
Downgrade packets : 0 Discarded packets : 0
Downgrade bytes : 0 Discarded bytes : 0
TS information:
AC : AC-VO User priority : 7
TID : 1 Direction : Bidirectional
PSB : 0 Surplus bandwidth allowance : 1.0000
Medium time (µs) : 39 MSDU size (bytes) : 1500
Mean data rate (Kbps) : 10.000 Minimum PHY rate (Mbps) : 11.000
TS creation time : 0h:0m:5s
TS updating time : 0h:0m:5s
Uplink TS packets : 0 Downlink TS packets : 0
Uplink TS bytes : 0 Downlink TS bytes : 0
Table 18 Command output
QoS mode |
· WMM. · -NA-. |
Maximum service period (SP) length. |
· AC-VO. · AC-VI. · AC-BE. · AC-BK. |
Assoc state |
APSD attribute for an AC queue: · T—The AC queue is trigger-enabled. · D—The AC queue is delivery-enabled. · T | D—The AC queue is both trigger-enabled and delivery-enabled. · L—The AC queue is of legacy attributes. |
User priority for packets from wired networks. |
Traffic identifier, in the range of 0 to 15. |
Traffic direction: · Uplink. · Downlink. · Bidirectional. |
PSB |
Power save behavior: · 1—U-APSD power saving mode. · 0—Traditional power saving mode. |
Surplus bandwidth allowance |
Surplus bandwidth allowance in percentage. |
Permitted medium time in microseconds. |
MSDU size |
Average MSDU size in bytes. |
Average data transmission rate in Kbps. |
Minimum physical transmission rate in Mbps. |
edca client (ac-be and ac-bk)
Use edca client to set EDCA parameters of AC-BE or AC-BK queues for clients.
Use undo edca client to restore the default.
edca client { ac-be | ac-bk } { aifsn aifsn-value | ecw ecwmin ecwmin-value ecwmax ecwmax-value | txoplimit txoplimit-value } *
undo edca client { ac-be | ac-bk }
The default EDCA parameter values of AC-BE or AC-BK queues for clients are shown in Table 19.
Table 19 Default EDCA parameter values of AC-BE or AC-BK queues for clients
AC |
AIFSN |
ECWmin |
ECWmax |
TXOP Limit |
AC-BK |
7 |
4 |
10 |
0 |
AC-BE |
3 |
4 |
10 |
0 |
Radio interface view
ac-be: Specifies the AC-BE (best-effort traffic) queue.
ac-bk: Specifies the AC-BK (background traffic) queue.
aifsn aifsn-value: Specifies the arbitration inter-frame spacing number (AIFSN), in the range of 1 to 15.
ecwmin ecwmin-value: Specifies the exponent form of CWmin (ECWmin), in the range of 0 to 15.
ecwmax ecwmax-value: Specifies the exponent form of CWmax (ECWmax), in the range of 0 to 15. The value of ECWmax cannot be smaller than the value of ECWmin.
txoplimit txoplimit-value: Specifies the transmission opportunity limit (TXOP Limit) value, in the range of 0 to 65535 (in units of 32 microseconds). If the value is 0, a client can send only one packet each time it holds the channel.
As a best practice, set the TXOP Limit value to 0 for both the AC-BE and AC-BK queues if all the clients are 802.11b clients.
As a best practice, use the default TXOPLimit values for both the AC-BK and AC-BE queues if both 802.11b and 802.11g clients exist in the WLAN.
# Set the AIFSN to 5 for the AC-BE queue.
[Sysname-WLAN-Radio0/1] edca client ac-be aifsn 5
edca client (ac-vi and ac-vo)
Use edca client to set EDCA parameters of AC-VI or AC-VO queues for clients.
edca client { ac-vi | ac-vo } { aifsn aifsn-value | cac { disable | enable } | ecw ecwmin ecwmin-value ecwmax ecwmax-value | txoplimit txoplimit-value } *
undo edca client { ac-vi | ac-vo }
The default EDCA parameter values of AC-VI or AC-VO queues for clients are shown in Table 20.
Table 20 Default EDCA parameter values of AC-VI or AC-VO queues for clients
AC |
AIFSN |
ECWmin |
ECWmax |
TXOP Limit |
AC-VI |
2 |
3 |
4 |
94 |
AC-VO |
2 |
2 |
3 |
47 |
ac-vi: Specifies the AC-VI (video traffic) queue.
ac-vo: Specifies the AC-VO (voice traffic) queue.
cac: Specifies CAC. The AC-VO and AC-VI queues support CAC. CAC is disabled by default.
disable: Disables CAC.
enable: Enables CAC.
As a best practice, set the TXOPLimit value to 188 and 102 for the AC-VI and AC-VO queues, respectively when all the clients are 802.11b clients.
As a best practice, use the default TXOPLimit values for both the AC-VI and AC-VO queues if both 802.11b and 802.11g clients exist in the WLAN.
# Set the AIFSN to 3 for the AC-VO queue.
[Sysname-WLAN-Radio0/1] edca client ac-vo aifsn 3
edca radio
Use edca radio to set EDCA parameters.
Use undo edca radio to restore the default.
edca radio { ac-be | ac-bk | ac-vi | ac-vo } { ack-policy { noack | normalack } | aifsn aifsn-value | ecw ecwmin ecwmin-value ecwmax ecwmax-value | noack | txoplimit txoplimit-value } *
undo edca radio { ac-be | ac-bk | ac-vi | ac-vo }
The default EDCA parameter values are shown in Table 21.
Table 21 Default EDCA parameter values
AC |
AIFSN |
ECWmin |
ECWmax |
TXOP Limit |
AC-BK |
7 |
4 |
10 |
0 |
AC-BE |
3 |
4 |
6 |
0 |
AC-VI |
1 |
3 |
4 |
94 |
AC-VO |
1 |
2 |
3 |
47 |
ack-policy: Specifies the ACK policy for the AC queue.
noack: Specifies the No ACK policy.
normalack: Specifies the Normal ACK policy (the default).
ecwmin ecwmin-value: Specifies the exponent form of CWmin (ECWmin). The value range for the ecwmin-value argument is 0 to 10.
ecwmax ecwmax-value: Specifies the exponent form of CWmax (ECWmax). The value range for the ecwmax-value argument is 0 to 10. The value of ECWmax cannot be smaller than the value of ECWmin.
txoplimit txoplimit-value: Specifies the transmission opportunity limit (TXOP Limit) value in units of 32 microseconds. The value range for the txoplimit-value argument is 0 to 32767. If the value is 0, a client can send only one packet each time it holds the channel.
As a best practice, set TXOP Limit values for AC-BK, AC-BE, AC-VI, and AC-VO queues to 0, 0, 188, and 102, respectively for 802.11b radios.
# Set the AIFSN of the AC-VO queue to 2 in radio view of radio 2.
[Sysname-WLAN-Radio0/1] edca radio ac-vo aifsn 2
qos priority
Use qos priority to set the port priority.
Use undo qos priority to restore the default.
The port priority is 0.
priority-value: Specifies the port priority in the range of 0 to 7. A larger value represents a higher priority.
When the port trust mode is enabled, the AP assigns the port priority to all packets for the service template.
This command does not take effect when the packet trust mode is enabled.
# Set the port priority to 2 for service template 1.
[Sysname-wlan-st-1] qos priority 2
qos trust
Use qos trust to configure the trusted packet priority type.
Use undo qos trust to restore the default.
The port priority is trusted.
dot11e: Uses the 802.1e priority carried in packets for priority mapping.
dscp: Uses the DSCP priority carried in packets for priority mapping.
This feature takes effect only on uplink packets.
# Configure service template 1 to use the 802.1e priority carried in packets for priority mapping.
[Sysname-wlan-st-1] qos trust dot11e
reset wlan wmm
Use reset wlan wmm to clear WMM statistics.
reset wlan wmm { client [ interface wlan-radio interface-number | mac-address mac-address ] | radio [ interface wlan-radio interface-number ] }
client: Clears WMM statistics for clients. If you use this keyword without the interface wlan-radio interface-number or mac-address mac-address option, this command clears WMM statistics for all clients.
radio: Clears WMM statistics for radios. If you use this keyword without the interface wlan-radio interface-number option, this command clears WMM statistics for all radios.
# Clear WMM statistics for all radios.
<Sysname> reset wlan wmm radio
svp map-ac
Use svp map-ac to map SVP packets to the specified AC queue.
Use svp map-ac disable to disable SVP mapping.
Use undo svp map-ac to restore the default.
svp map-ac { ac-vi | ac-vo }
svp map-ac disable
undo svp map-ac
SVP mapping is disabled.
SVP mapping takes effect only on non-WMM clients.
# Map SVP packets to the AC-VO queue.
[Sysname-WLAN-Radio0/1] svp map-ac ac-vo
wmm
Use wmm enable to enable WMM.
Use wmm disable to disable WMM.
Use undo wmm to restore the default.
wmm { disable | enable }
undo wmm
WMM is enabled.
All 802.11n clients must support WLAN QoS. For 802.11n clients to communicate with the associated AP, enable WMM when the radio operates in 802.11an or 802.11gn mode.
[Sysname-WLAN-Radio0/1] wmm disable
Cloud connection commands
· MSR810-W.
· MSR810-W-DB.
· MSR810-W-LM.
· MSR810-W-LM-HK.
· MSR810-W-LM-GL.
cloud-management keepalive
Use cloud-management keepalive to set the keepalive interval for the local device to send keepalive packets to the H3C Oasis server.
Use undo cloud-management keepalive to restore the default.
cloud-management keepalive interval
The keepalive interval is 180 seconds.
interval: Specifies the keepalive interval in the range of 10 to 600 seconds.
If the device does not receive a response from the H3C Oasis server within three keepalive intervals, the device sends a registration request to re-establish the cloud connection.
# Set the keepalive interval to 360 seconds.
[Sysname] cloud-management keepalive 360
cloud-management server domain
Use cloud-management server domain to configure the domain name of the H3C Oasis server.
Use undo cloud-management server domain to restore the default.
cloud-management server domain domain-name
The domain name of the H3C Oasis server is not configured.
domain-name: Specifies the domain name of the H3C Oasis server, a case-sensitive string of 1 to 253 characters.
Before you configure the domain name of the H3C Oasis server, make sure a DNS server is configured to translate the domain name.
If you execute the command multiple times, the most recent configuration takes effect.
# Configure the domain name of the H3C Oasis server as lvzhouv3.h3c.com.
[Sysname] cloud-management server domain lvzhouv3.h3c.com
cloud-management ping
Use cloud-management ping to set the interval at which the local device sends ping packets to the H3C Oasis server.
Use undo cloud-management ping to restore the default.
cloud-management ping interval
The local device sends ping packets to the H3C Oasis server at intervals of 60 seconds.
interval: Specifies the interval at which the local device sends ping packets to the H3C Oasis server, in the range of 10 to 600 seconds.
After the connection to the H3C Oasis server is established, the local device sends ping packets to the server periodically to prevent NAT entry aging. Reduce the interval value if the network condition is poor or the NAT entry aging time is short.
The H3C Oasis server does not respond to ping packets.
# Configure the local device to send ping packets to the H3C Oasis server at intervals of 120 seconds.
[Sysname] cloud-management ping 120
display cloud-management state
Use display cloud-management state to display cloud connection state information.
# Display cloud connection state information.
<Sysname> display cloud-management state
Cloud connection state : Established
Device state : Request_success
Cloud server address : 10.1.1.1
Cloud server domain name : lvzhouv3.h3c.com
Local port : 443
Connected at : Wed Jan 27 14:18:40 2016
Duration : 00d 00h 02m 01s
Process state : DNS not parsed
Failure reason : DNS parse failed
Table 22 Command output
Cloud connection state |
Cloud connection state: Unconnected, Request, and Established. |
Device state |
Local device state: · Idle—In idle state. · Connecting—Connecting to the H3C Oasis server. · Request_CAS_url—Sent a central authentication service (CAS) URL request. · Request_CAS_url_success—Requesting CAS URL succeeded. · Request_CAS_TGT—Sent a ticket granting ticket (TGT) request. · Request_CAS_TGT_success—Requesting TGT succeeded. · Request_CAS_ST—Sent a service ticket (ST) request. · Request_CAS_ST_success—Requesting ST succeeded. · Request_cloud_auth—Sent an authentication request. · Request_cloud_auth_success—Authentication succeeded. · Register—Sent a registration request. · Register_success—Registration succeeded. · Request—Sent a handshake request. · Request_success—Handshake succeeded. |
Cloud server address |
IP address of the H3C Oasis server. |
Cloud server domain name |
Domain name of the H3C Oasis server. |
Local port |
TCP port number used to establish cloud connections. |
Connected at |
Time when the cloud connection was established. |
Duration |
Duration since the establishment of the cloud connection. |
Process state |
Cloud connection processing state: · DNS not parsed. · DNS parsed. · Message not sent. · Message sent. · Message not received. · Message received. |
Failure reason |
Cloud connection failure reason: · DNS parse failed. · Socket connection failed. · SSL creation failed. · Sending CAS url request failed. · Sending CAS TGT failed. · Sending CAS ST failed. · Sending cloud auth failed. · Sending register failed. · Processing CAS url response failed. · Processing CAS TGT response failed. · Processing CAS ST response failed. · Processing cloud auth response failed. · Processing register response failed. · Sending handshake request failed. · Processing handshake failed. · Sending websocket request failed. · Processing websocket packet failed. |
WLAN multicast optimization commands
· MSR810-W.
· MSR810-W-DB.
· MSR810-W-LM.
· MSR810-W-LM-HK.
· MSR810-W-LM-GL.
display wlan ipv6 multicast-optimization entry
Use display wlan ipv6 multicast-optimization entry to display IPv6 multicast optimization entry information.
display wlan ipv6 multicast-optimization entry [ client mac-address [ group group-ip [ source source-ip ] ] ]
client mac-address: Specifies a client by its MAC address. If you do not specify this option, the command displays information about all IPv6 multicast optimization entries.
group group-ip: Specifies a multicast group by its IP address. If you do not specify this option, the command displays information about all IPv6 multicast optimization entries for the specified client.
source source-ip: Specifies a multicast source by its IP address. If you do not specify this option, the command displays information about all IPv6 multicast optimization entries for the specified multicast group to which the specified client belongs.
# Display information about all IPv6 multicast optimization entries.
<Sysname> display wlan ipv6 multicast-optimization entry
Total 2 clients reported
Client: 0000-0000-0001
Reported from AP 1 on radio 1
Total number of groups: 1
Group: FF25::1
Version: MLDv2
Mode: Include
Duration: 00h 02m 03s
Sources: 3
Source: 1::1
Source: 1::2
Duration: 00h 02m 15s
Source: 1::3
Duration: 00h 02m 45s
Client: 0000-0000-0002
Group: FF25::2
Version: MLDv2
Mode: Include
Duration: 00h 01m 09s
Sources: 3
Source: 1::1
Duration: 00h 01m 11s
Source: 1::2
Source: 1::3
Duration: 00h 01m 45s
Table 23 Command output
Total 2 clients reported |
Number of clients in the multicast optimization entry table. |
Client |
MAC address of the client. |
Group |
Multicast group address. |
Version |
Version of the multicast group: · MLDv1. · MLDv2. |
Mode |
WLAN multicast optimization mode of the multicast group: · Include—Multicast packets destined to the multicast group are converted to unicast packets if the multicast source address exists in the source address list obtained from MLDv2 reports. · Exclude—Multicast packets destined to the multicast group are not converted to unicast packets if the multicast source address does not exist in the source address list obtained from MLDv2 reports. This field always displays Exclude for MLDv1 multicast groups. |
Duration |
Lifetime of the multicast optimization entry for the multicast group or multicast source. |
Source |
Multicast source address. |
display wlan multicast-optimization entry
Use display wlan multicast-optimization entry to display IPv4 multicast optimization entry information.
display wlan multicast-optimization entry [ client mac-address [ group group-ip [ source source-ip ] ] ]
client mac-address: Specifies a client by its MAC address. If you do not specify this option, the command displays information about all IPv4 multicast optimization entries.
group group-ip: Specifies a multicast group by its IP address. If you do not specify this option, the command displays information about all IPv4 multicast optimization entries for the specified client.
source source-ip: Specifies a multicast source by its IP address. If you do not specify this option, the command displays information about all IPv4 multicast optimization entries for the specified multicast group to which the specified client belongs.
# Display information about all IPv4 multicast optimization entries.
<Sysname> display wlan multicast-optimization entry
Group: 226.0.0.1
Version: IGMPv3
Mode: Include
Duration: 00h 03m 03s
Sources: 3
Source: 27.0.0.1
Duration: 00h 03m 32s
Source: 27.0.0.2
Duration: 00h 03m 15s
Source: 27.0.0.3
Total number of groups: 2
Group: 226.0.0.1
Version: IGMPv3
Mode: Include
Sources: 3
Source: 27.0.0.1
Duration: 00h 02m 32s
Source: 27.0.0.2
Source: 27.0.0.3
Duration: 00h 02m 23s
Group: 226.0.0.2
Version: IGMPv3
Mode: Include
Sources: 2
Source: 27.0.0.1
Duration: 00h 01m 12s
Source: 27.0.0.2
Table 24 Command output
Client |
Group |
Version |
Version of the multicast group: · IGMPv1v2—IGMPv1 or IGMPv2. · IGMPv3. |
Mode |
WLAN multicast optimization mode of the multicast group: · Include—Multicast packets destined to the multicast group are converted to unicast packets if the multicast source address exists in the source address list obtained from IGMPv2 reports. · Exclude—Multicast packets destined to the multicast group are not converted to unicast packets if the multicast source address does not exist in the source address list obtained from IGMPv2 reports. This field always displays Exclude for IGMPv1 multicast groups. |
Duration |
Source |
ipv6 multicast-optimization enable
Use ipv6 multicast-optimization enable to enable IPv6 WLAN multicast optimization.
Use undo ipv6 multicast-optimization enable to disable IPv6 WLAN multicast optimization.
IPv6 WLAN multicast optimization is disabled.
# Enable IPv6 WLAN multicast optimization for service template 1.
[Sysname-wlan-st-1] ipv6 multicast-optimization enable
Use multicast-optimization enable to enable IPv4 WLAN multicast optimization.
Use undo multicast-optimization enable to disable IPv4 WLAN multicast optimization.
IPv4 WLAN multicast optimization is disabled.
# Enable IPv4 WLAN multicast optimization for service template 1.
[Sysname-wlan-st-1] multicast-optimization enable
reset wlan ipv6 multicast-optimization entry
Use reset wlan ipv6 multicast-optimization entry to clear IPv6 multicast optimization entries.
reset wlan ipv6 multicast-optimization entry { all | client mac-address [ group group-ip [ source source-ip ] ] }
all: Specifies all IPv6 multicast optimization entries.
group group-ip: Specifies a multicast group by its IP address. If you do not specify this option, the command clears all IPv6 multicast optimization entries for the specified client.
source source-ip: Specifies a multicast source by its IP address. If you do not specify this option, the command clears all IPv6 multicast optimization entries for the specified multicast group to which the specified client belongs.
# Clear all IPv6 multicast optimization entries for the client with MAC address 1011-2222-3334.
<Sysname> reset wlan ipv6 multicast-optimization entry client 1011-2222-3334
reset wlan ipv6 multicast-optimization entry group
Use reset wlan ipv6 multicast-optimization entry group to clear IPv6 multicast optimization entries for the specified multicast group.
reset wlan ipv6 multicast-optimization entry group group-ip [ source source-ip ]
source source-ip: Specifies a multicast source by its IP address. If you do not specify this option, the command clears all IPv6 multicast optimization entries for the specified multicast group.
# Clear IPv6 multicast optimization entries for the multicast group with IPv6 address FF28::1.
<Sysname> reset wlan ipv6 multicast-optimization entry group FF28::1
reset wlan multicast-optimization entry
Use reset wlan multicast-optimization entry to clear IPv4 multicast optimization entries.
reset wlan multicast-optimization entry { all | client mac-address [ group group-ip [ source source-ip ] ] }
all: Specifies all IPv4 multicast optimization entries.
group group-ip: Specifies a multicast group by its IP address. If you do not specify this option, the command clears all IPv4 multicast optimization entries for the specified client.
source source-ip: Specifies a multicast source by its IP address. If you do not specify this option, the command clears all IPv4 multicast optimization entries for the specified multicast group to which the specified client belongs.
# Clear all IPv4 multicast optimization entries for the client with MAC address 1011-2222-3334.
<Sysname> reset wlan multicast-optimization entry client 1011-2222-3334
reset wlan multicast-optimization entry group
Use reset wlan multicast-optimization entry group to clear IPv4 multicast optimization entries for the specified multicast group.
reset wlan multicast-optimization entry group group-ip [ source source-ip ]
group-ip: Specifies a multicast group by its address.
source source-ip: Specifies a multicast source by its IP address. If you do not specify this option, the command clears all IPv4 multicast optimization entries for the specified multicast group.
# Clear IPv4 multicast optimization entries for the multicast group with address 235.1.1.1.
<Sysname> reset wlan multicast-optimization entry group 235.1.1.1
wlan ipv6 multicast-optimization aging-time
Use wlan ipv6 multicast-optimization aging-time to set the aging time for IPv6 multicast optimization entries.
Use undo wlan ipv6 multicast-optimization aging-time to restore the default.
wlan ipv6 multicast-optimization aging-time aging-value
The aging time is 260 seconds for IPv6 multicast optimization entries.
aging-value: Specifies the aging time for IPv6 multicast optimization entries, in the range of 60 to 3600 seconds.
# Set the aging time to 600 seconds for IPv6 multicast optimization entries.
[Sysname] wlan ipv6 multicast-optimization aging-time 600
wlan ipv6 multicast-optimization client entry-limit
Use wlan ipv6 multicast-optimization client entry-limit to set the limit for IPv6 multicast optimization entries per client.
Use undo wlan ipv6 multicast-optimization client entry-limit to restore the default.
wlan ipv6 multicast-optimization client entry-limit [ limit-value ]
No limit is set for IPv6 multicast optimization entries per client.
limit-value: Specifies the limit for IPv6 multicast optimization entries per client, in the range of 8 to 1024. The default value is 256.
Configure this command to limit the number of multicast optimization entries that an AP maintains for each client to prevent a client from occupying excessive system resources.
# Set the limit to 64 for IPv6 multicast optimization entries per client.
[Sysname] wlan ipv6 multicast-optimization client entry-limit 64
wlan ipv6 multicast-optimization entry client-limit
Use wlan ipv6 multicast-optimization entry client-limit to configure an IPv6 multicast optimization policy.
Use undo wlan ipv6 multicast-optimization entry client-limit to restore the default.
wlan ipv6 multicast-optimization entry client-limit [ limit-value ] [ drop | multicast | unicast ]
No IPv6 multicast optimization policies exist and an AP performs WLAN multicast optimization for all clients.
limit-value: Specifies the threshold for the number of clients that WLAN multicast optimization supports, in the range of 1 to 256. The default value is 8.
drop: Configures an AP to drop a multicast packet when the number of clients to receive the packet exceeds the threshold.
multicast: Configures an AP to forward a multicast packet to all clients when the number of clients to receive the packet exceeds the threshold.
unicast: Configures an AP to process a multicast packet as follows when the number of clients to receive the packet exceeds the threshold:
· Convert the multicast packet to unicast packets.
· Send the unicast packets to only n (n equal to the specified threshold) clients that are randomly selected.
Use this command to configure the maximum number of clients that WLAN multicast optimization supports and define the action an AP takes when the limit is reached.
If you do not specify an action, an AP performs unicast forwarding.
# Set the threshold for the number of clients that WLAN multicast optimization supports to 32, and specify the unicast forwarding mode.
[Sysname] wlan ipv6 multicast-optimization entry client-limit 32 unicast
wlan ipv6 multicast-optimization global entry-limit
Use wlan ipv6 multicast-optimization global entry-limit to set the limit for IPv6 multicast optimization entries.
Use undo wlan ipv6 multicast-optimization global entry-limit to restore the default.
wlan ipv6 multicast-optimization global entry-limit [ limit-value ]
No limit is set for IPv6 multicast optimization entries.
limit-value: Specifies the limit for IPv6 multicast optimization entries, in the range of 8 to 8192. The default value is 1024.
When the number of multicast optimization entries reaches the limit, the AP stops creating new entries until the number falls below the limit. This action saves system resources.
# Set the limit for IPv6 multicast optimization entries to 512.
[Sysname] wlan ipv6 multicast-optimization global entry-limit 512
wlan ipv6 multicast-optimization packet-rate-limit
Use wlan ipv6 multicast-optimization packet-rate-limit to set the maximum number of MLD packets that can be received from clients within the specified period.
Use undo wlan ipv6 multicast-optimization packet-rate-limit to restore the default.
wlan ipv6 multicast-optimization packet-rate-limit [ interval interval-value | threshold threshold-value ] *
No limit is set for the number of MLD packets that can be received from clients.
interval interval-value: Specifies the interval for calculating the incoming MLD packet rate. The value range is 60 to 3600 seconds. The default setting is 60 seconds.
threshold threshold-value: Specifies the threshold on the number of incoming MLD packets over the specified interval. The value range is 1 to 100000. The default threshold is 100.
If the number of MLD packets received from clients reaches the threshold within the specified interval, the AP stops receiving MLD packets from clients until the next period.
# Configure an AP to receive a maximum of 240 MLD packets every 120 seconds.
[Sysname] wlan ipv6 multicast-optimization packet-rate-limit interval 120 threshold 240
wlan multicast-optimization aging-time
Use wlan multicast-optimization aging-time to set the aging time for IPv4 multicast optimization entries.
Use undo wlan multicast-optimization aging-time to restore the default.
wlan multicast-optimization aging-time aging-value
The aging time is 260 seconds for IPv4 multicast optimization entries.
aging-value: Specifies the aging time for IPv4 multicast optimization entries, in the range of 60 to 3600 seconds.
# Set the aging time to 600 seconds for IPv4 multicast optimization entries.
[Sysname] wlan multicast-optimization aging-time 600
wlan multicast-optimization client entry-limit
Use wlan multicast-optimization client entry-limit to set the limit for IPv4 multicast optimization entries per client.
Use undo wlan multicast-optimization client entry-limit to restore the default.
wlan multicast-optimization client entry-limit [ limit-value ]
No limit is set for IPv4 multicast optimization entries per client.
limit-value: Specifies the limit for IPv4 multicast optimization entries per client, in the range of 8 to 1024. The default value is 256.
# Set the limit to 64 for IPv4 multicast optimization entries per client.
[Sysname] wlan multicast-optimization client entry-limit 64
wlan multicast-optimization entry client-limit
Use wlan multicast-optimization entry client-limit to configure an IPv4 multicast optimization policy.
Use undo wlan multicast-optimization entry client-limit to restore the default.
wlan multicast-optimization entry client-limit [ limit-value ] [ drop | multicast | unicast ]
No IPv4 multicast optimization policies exist and an AP performs WLAN multicast optimization for all clients.
Use this command to configure the maximum number of clients that WLAN multicast optimization supports and define the action an AP takes when the limit is reached. If you do not specify an action, the AP performs unicast forwarding.
[Sysname] wlan multicast-optimization entry client-limit 32 unicast
wlan multicast-optimization global entry-limit
Use wlan multicast-optimization global entry-limit to set the limit for IPv4 multicast optimization entries.
Use undo wlan multicast-optimization global entry-limit to restore the default.
wlan multicast-optimization global entry-limit [ limit-value ]
No limit is set for IPv4 multicast optimization entries.
limit-value: Specifies the limit for IPv4 multicast optimization entries, in the range of 8 to 8192. The default value is 1024.
# Set the limit for IPv4 multicast optimization entries to 512.
[Sysname] wlan multicast-optimization global entry-limit 512
wlan multicast-optimization packet-rate-limit
Use wlan multicast-optimization packet-rate-limit to set the maximum number of IGMP packets that can be received from clients within the specified period.
Use undo wlan multicast-optimization packet-rate-limit to restore the default.
wlan multicast-optimization packet-rate-limit [ interval interval-value | threshold threshold-value ] *
No limit is set for the number of IGMP packets that can be received from clients within the specified period.
interval interval-value: Specifies the interval for calculating the incoming IGMP packet rate. The value range is 60 to 3600 seconds. The default setting is 60 seconds.
threshold threshold-value: Specifies the threshold on the number of incoming IGMP packets over the specified interval. The value range is 1 to 100000. The default threshold is 100.
If the number of IGMP packets received from clients reaches the threshold within the specified interval, the AP stops receiving IGMP packets from clients until the next period.
# Configure an AP to receive a maximum of 240 IGMP packets from clients every 120 seconds.
[Sysname] wlan multicast-optimization packet-rate-limit interval 120 threshold 240
akm mode,73
a-mpdu,1
a-msdu,1
ani,2
antenna type,3
beacon ssid-hide,35
beacon-interval,3
cac policy,106
channel,4
channel band-width,4
channel-usage measure,5
cipher-suite,74
client dot11b-forbidden,6
client dot11n-only,6
client max-count,35
client max-count,7
client url-redirect enable,88
client-security accounting-delay time,89
client-security accounting-start trigger,89
client-security accounting-update trigger,91
client-security authentication fail-vlan,92
client-security authentication-mode,92
client-security authorization-fail offline,93
client-security ignore-authentication,94
client-security ignore-authorization,95
client-security intrusion-protection action,95
client-security intrusion-protection enable,96
client-security intrusion-protection timer temporary-block,97
client-security intrusion-protection timer temporary-service-stop,98
cloud-management keepalive,116
cloud-management ping,117
cloud-management server domain,116
continuous-mode,7
custom-antenna gain,8
customlog format wlan,36
description,37
display cloud-management state,118
display wlan ap all client-number,38
display wlan ap all radio client-number,37
display wlan blacklist,38
display wlan bss,39
display wlan client,40
display wlan client ipv6,45
display wlan client online-duration,46
display wlan client status,47
display wlan client-security block-mac,99
display wlan ipv6 multicast-optimization entry,120
display wlan measure-report,24
display wlan multicast-optimization entry,121
display wlan service-template,48
display wlan statistics,53
display wlan whitelist,55
display wlan wmm,107
distance,9
dot11g protection,9
dot11n mandatory maximum-mcs,10
dot11n multicast-mcs,11
dot11n protection,12
dot11n support maximum-mcs,12
dot1x domain,99
dot1x eap,100
dot1x handshake enable,101
dot1x handshake secure enable,102
dot1x max-user,102
dot1x re-authenticate enable,103
dtim,13
edca client (ac-be and ac-bk),109
edca client (ac-vi and ac-vo),110
edca radio,111
fragment-threshold,14
green-energy-management,14
gtk-rekey client-offline enable,75
gtk-rekey enable,75
gtk-rekey method,76
ipv6 multicast-optimization enable,123
key-derivation,77
ldpc,15
long-retry threshold,16
mac-authentication domain,104
mac-authentication max-user,105
max-power,16
measure,27
measure-duration,28
measure-interval,28
multicast-optimization enable,124
pmf,77
pmf association-comeback,78
pmf saquery retrycount,79
pmf saquery retrytimeout,79
preamble,17
preshared-key,80
protection-mode,18
protection-threshold,18
ptk-lifetime,81
ptk-rekey enable,81
qos priority,112
qos trust,113
quick-association enable,56
rate,19
region-code,56
region-code-lock,59
reset wlan client,59
reset wlan dynamic-blacklist,60
reset wlan ipv6 multicast-optimization entry,124
reset wlan ipv6 multicast-optimization entry group,125
reset wlan multicast-optimization entry,125
reset wlan multicast-optimization entry group,126
reset wlan statistics client,60
reset wlan statistics service-template,61
reset wlan wmm,114
resource-measure,29
rm-capability mode,30
security-ie,82
service-template,61
service-template enable,62
short-gi,20
short-retry threshold,21
snmp-agent trap enable wlan client,62
snmp-agent trap enable wlan client-audit,63
snmp-agent trap enable wlan usersec,83
ssid,63
stbc,21
svp map-ac,114
tkip-cm-time,83
type,22
unknown-client,64
vlan,64
wep key,84
wep key-id,85
wep mode dynamic,86
wlan band-navigation aging-time,31
wlan band-navigation balance access-denial,31
wlan band-navigation balance session,32
wlan band-navigation enable,33
wlan band-navigation rssi-threshold,33
wlan broadcast-probe reply,65
wlan client idle-timeout,65
wlan client keep-alive,66
wlan client keepalive interval,67
wlan client reauthentication-period,67
wlan gps-report enable,68
wlan ipv6 multicast-optimization aging-time,126
wlan ipv6 multicast-optimization client entry-limit,127
wlan ipv6 multicast-optimization entry client-limit,127
wlan ipv6 multicast-optimization global entry-limit,128
wlan ipv6 multicast-optimization packet-rate-limit,129
wlan link-test,69
wlan multicast-optimization aging-time,129
wlan multicast-optimization client entry-limit,130
wlan multicast-optimization entry client-limit,131
wlan multicast-optimization global entry-limit,131
wlan multicast-optimization packet-rate-limit,132
wlan service-template,70
wlan static-blacklist mac-address,71
wlan whitelist mac-address,72
wmm,115
