02-Virtual Technologies Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR Router Series Comware 7 Command References-R0615-6W20302-Virtual Technologies Command Reference
Table of Contents
Related Documents
01-Text
01-Text 178.87 KB
IRF commands
The following matrix shows the feature and hardware compatibility:
Hardware
IRF compatibility
MSR810/810-W/810-W-DB/810-LM/810-W-LM/810-10-PoE/810-LM-HK/810-W-LM-HK/810-LMS/810-LUS
No
MSR2600-6-X1/2600-10-X1
No
MSR 2630
Yes
MSR3600-28/3600-51
Yes
MSR3600-28-SI/3600-51-SI
No
MSR3610-X1/3610-X1-DP/3610-X1-DC/3610-X1-DP-DC
Yes
MSR 3610/3620/3620-DP/3640/3660
Yes
MSR5620/5660/5680
Yes
Hardware
IRF compatibility
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
Commands and descriptions for centralized devices apply to the following routers:
·     MSR 2630.
·     MSR3600-28/3600-51.
·     MSR3610-X1/3610-X1-DP/3610-X1-DC/3610-X1-DP-DC.
·     MSR 3610/3620/3620-DP/3640/3660.
Commands and descriptions for distributed devices apply to the following routers:
·     MSR5620.
·     MSR 5660.
·     MSR 5680.
chassis convert mode irf
Use chassis convert mode irf to enable IRF mode.
Use undo chassis convert mode to restore the default.
The device operates in standalone mode.
To set up an IRF fabric, place all member devices in IRF mode after you configure member IDs, priorities, and IRF port settings for the member devices. In standalone mode, a device cannot form an IRF fabric with other devices.
IRF generates packets on a device in IRF mode even if the device does not form an IRF fabric with any other devices. To conserve system resources, set a device to standalone mode after removing it from an IRF fabric.
# (Centralized devices in standalone mode.) Enable IRF mode.
[Sysname] chassis convert mode irf
The device will switch to IRF mode and reboot. You are recommended to save the current running configuration and specify the configuration file for the next startup. Continue? [Y/N]:y
Do you want to convert the content of the next startup configuration file flash:/startup.cfg to make it available in IRF mode? [Y/N]:y
Now rebooting, please wait...
Saving the converted configuration file to the main board succeeded.
# (Centralized devices in IRF mode.) Restore standalone mode.
[Sysname] undo chassis convert mode
The device will switch to stand-alone mode and reboot. You are recommended to save the current running configuration and specify the configuration file for the next startup. Continue? [Y/N]:y
Do you want to convert the content of the next startup configuration file flash:/startup.cfg to make it available in stand-alone mode? [Y/N]:y
# (Distributed devices in standalone mode.) Enable IRF mode.
Do you want to convert the content of the next startup configuration file cfa0:/startup.cfg to make it available in IRF mode? [Y/N]:y
Slot 1:
 Saving the converted configuration file succeeded.
# (Distributed devices in IRF mode.) Restore standalone mode.
Do you want to convert the content of the next startup configuration file cfa0:/startup.cfg to make it available in stand-alone mode? [Y/N]:y
Chassis 2 Slot 1:
display irf
Use display irf to display IRF fabric information, including the member ID, role, priority, bridge MAC address, and description of each IRF member.
display irf
# (Centralized devices.) Display IRF fabric information.
<Sysname> display irf
MemberID   Role     Priority    CPU-Mac           Description
   1       Loading  1           00e0-fcbe-3102    F1Num001
 *+2       Master   1           00e0-fcb1-ade2    F1Num002
 The Bridge MAC of the IRF is: 00e0-fc00-1000
 Auto upgrade                   : yes
 Mac persistent                 : always
 Domain ID                      : 30
 Auto merge                     : yes
MemberID
IRF member ID:
·     ID of the master is prefixed with an asterisk (*) sign.
·     ID of the device where you are logged in is prefixed with a plus (+) sign.
Role
Role of the member device in the IRF fabric:
·     Standby—Subordinate device.
·     Master—Master device.
·     Loading—The device is loading software images.
Priority
IRF member priority.
CPU-MAC
MAC address of the CPU in the device.
Description you have configured for the member device.
·     If no description is configured, this field displays a dashed line (-----).
·     If the description exceeds the maximum number of characters that can be displayed, an ellipsis (…) is displayed in place of the exceeding text. To display the complete description, use the display current-configuration command.
Bridge MAC address of the IRF fabric.
Auto upgrade
Status of the software auto-update feature:
·     yes—Enabled. The master propagates its software images automatically to the device you are adding to the IRF fabric.
·     no—Disabled. You must manually make sure the joining device uses the same software images as the master. If the software images are different, the new device cannot join the IRF fabric.
MAC persistent
IRF bridge MAC persistence setting:
·     6 min—Bridge MAC address of the IRF fabric remains unchanged for 6 minutes after the address owner leaves.
·     always—Bridge MAC address of the IRF fabric does not change after the address owner leaves.
·     no—Bridge MAC address of the current master replaces the original bridge MAC address as soon as the owner of the original address leaves.
Domain ID
Domain ID of the IRF fabric. The domain ID you assign to an IRF fabric must uniquely identify the fabric in a multi-IRF fabric network.
Auto merge
Status of the IRF auto-merge feature:
·     yes—Enabled.
·     no—Disabled.
# (Distributed devices.) Display IRF fabric information.
MemberID  Slot  Role   Priority  CPU-Mac         Description
 *+1      0     Master 1         0210-fc03-0007  -----
 The Bridge MAC of the IRF is: 3ce5-a6b8-3800
 Auto upgrade                : yes
 Domain ID                   : 0
 Auto merge                  : no
MemberID
IRF member ID:
Slot
MPU slot number.
Role
Role of the MPU in the IRF fabric:
·     Standby—Standby MPU for the global active MPU.
·     Master—Global active MPU.
·     Loading—Standby MPU for the global active MPU. The standby MPU is loading software images.
Priority
CPU-MAC
MAC address of the CPU on the MPU.
Description you have configured for the member device:
Auto upgrade
·     yes—Enabled. The global active MPU automatically pushes its software images to the MPUs you are adding to the IRF fabric.
·     no—Disabled. You must manually make sure the joining MPUs use the same software images as the global active MPU. If the software images are different, the joining MPUs cannot be added to the IRF fabric.
MAC persistent
Auto merge
Status of the auto-merge feature:
·     yes—Enabled.
·     no—Disabled.
display irf configuration
display irf topology
Use display irf configuration to display basic IRF settings, including each member's current member ID, new member ID, and physical interfaces bound to the IRF ports. The new member IDs take effect at reboot.
# (Centralized devices in standalone mode.) Display the basic IRF settings of the device.
<Sysname> display irf configuration
 MemberID Priority IRF-Port1                   IRF-Port2
 1        1        disable                     disable
# (Centralized devices in IRF mode.) Display basic IRF settings for all members.
 MemberID NewID    IRF-Port1                     IRF-Port2
 1        1        GigabitEthernet1/0/1          disable
 2        2        disable                       GigabitEthernet2/0/1
# (Distributed devices in standalone mode.) Display the basic IRF settings of the device.
 1        1        disable                     disable
# (Distributed devices in IRF mode.) Display basic IRF settings for all members.
  1        1      GigabitEthernet1/2/0/1        disable
                  GigabitEthernet1/2/0/2
  2        2      disable                       GigabitEthernet2/2/0/1
                                                GigabitEthernet2/2/0/2
MemberID
Current member ID of the device.
Priority
Member priority.
This field is available when the device is operating in standalone mode.
NewID
Member ID assigned to the device. This member ID takes effect at reboot.
This field is available when the device is operating in IRF mode.
IRF-Port1
Physical interfaces bound to IRF-port 1.
This field displays disable if no physical interfaces are bound to the IRF port.
IRF-Port2
Physical interfaces bound to IRF-port 2.
display irf
display irf link
Use display irf link to display IRF link information, including IRF ports, IRF physical interfaces, and IRF link status.
display irf link
# (Centralized devices.) Display IRF link information.
<Sysname> display irf link
Member 1
 IRF Port    Interface                           Status
 1           disable                             --
 2           GigabitEthernet1/0/1                UP
             GigabitEthernet1/0/2                ADM
Member 2
 1           GigabitEthernet2/0/1                UP
             GigabitEthernet2/0/2                DOWN
 2           disable                             --
# (Distributed devices.) Display IRF link information.
Member 1
 1           disable                         --
 2           GigabitEthernet1/2/0/1          UP
Member 2
 1           GigabitEthernet2/2/0/1          UP
 2           disable                         --
Member ID
IRF member ID.
IRF Port
IRF port number:
·     1—IRF-port 1.
·     2—IRF-port 2.
Physical interfaces bound to the IRF port. This field displays disable if no physical interfaces have been bound to the IRF port.
Status
Link state of the IRF physical interface:
·     UP—The link is up.
·     DOWN—The link is down.
·     ADM—The interface has been manually shut down by using the shutdown command.
·     ABSENT—Interface module or expansion interface card that hosts the interface is not present.
Use display irf topology to display IRF fabric topology information, including the member IDs, IRF port state, adjacencies of IRF ports, and CPU MAC address of the master.
# Display the IRF fabric topology.
<Sysname> display irf topology
                           Topology Info
               IRF-Port1                  IRF-Port2
 MemberID   Link        neighbor      Link        neighbor     Belong To
 2          DIS        ---            UP          1            000f-cbb8-1a82
 1          UP          2             DIS         ---          000f-cbb8-1a82
Table 5 Command output
IRF-Port1
Information about IRF-port 1, including its link state and neighbor.
IRF-Port2
Information about IRF-port 2, including its link state and neighbor.
MemberID
IRF member ID.
Link
Link state of the IRF port:
·     UP—The IRF link is up.
·     DOWN—The IRF link is down because the port does not have a reachable physical link or has not been activated by the irf-port-configuration active command.
·     DIS—No physical interfaces have been bound to the IRF port.
·     TIMEOUT—IRF hello interval has timed out.
neighbor
IRF member ID of the device connected to the IRF port.
This field displays three hyphens (---) if no device is connected to the port.
Belong To
IRF fabric that has the device, represented by the CPU MAC address of the master in the IRF fabric.
display irf
display mad
Use display mad to display MAD status and settings.
display mad [ verbose ]
verbose: Displays detailed MAD information. If you do not specify this keyword, the command only displays whether a MAD mechanism is enabled or disabled.
# Display detailed MAD information.
<Sysname> display mad verbose
Multi-active recovery state: No
Excluded ports(user-configured):
  GigabitEthernet1/2/0/3
Excluded ports(system-configured):
  GigabitEthernet1/2/0/4
  GigabitEthernet1/2/0/5
MAD ARP disabled.
MAD ND disabled.
MAD LACP enabled interface: Route-Aggregation1
  MAD status                 : Normal
  Member ID       Port                             MAD status
  1               GigabitEthernet1/2/0/1           Normal
  2               GigabitEthernet2/2/0/1           Normal
MAD BFD enabled interface: Route-Aggregation2
  MAD status                 : Normal
  Member ID   MAD IP address       Neighbor    MAD status
  1           192.168.1.1/24       2           Normal
  2           192.168.1.2/24       1           Normal
Table 6 Command output
Whether the IRF fabric is in Recovery state:
·     Yes—The IRF fabric is in Recovery state. When MAD detects that an IRF fabric has split into multiple IRF fabrics, it allows one fabric to forward traffic. All the other IRF fabrics are set to the Recovery state. In Recovery state, MAD shuts down all network ports in the fabric except for the IRF physical interfaces and ports configured to not shut down.
·     No—The IRF fabric is not in Recovery state. It is active and can forward traffic.
Ports manually configured to not shut down when the IRF fabric transits to the Recovery state.
Ports set to not shut down by default when the IRF fabric transits to the Recovery state. These ports are not user configurable.
MAD ARP disabled.
ARP MAD is not supported in the current software version.
MAD ND disabled.
ND MAD is not supported in the current software version.
Interface on which LACP MAD is enabled. This field is displayed for each interface enabled with LACP MAD.
MAD status
LACP MAD operating status:
·     Normal—LACP MAD is operating correctly.
·     Faulty—LACP MAD is not operating correctly. Verify the following items:
¡     Verify that the ports on LACP MAD links are up.
¡     Verify that the intermediate device supports extended LACPDUs.
¡     Verify that all member devices have member ports used for LACP MAD.
Member ID
Port
MAD status
LACP MAD details:
·     Member ID—IRF member ID of a device.
·     Port—Member ports of the aggregate interface used for LACP MAD.
·     MAD status—LACP MAD operating state on a member port. Options include Normal and Faulty.
Layer 3 interface on which BFD MAD is enabled.
MAD status
BFD MAD operating status:
·     Normal—BFD MAD is operating correctly.
·     Faulty—BFD MAD is not operating correctly. Check the BFD MAD link connectivity.
Member ID
MAD IP address
Neighbor
MAD status
BFD MAD details:
·     Member ID—IRF member ID of the local device.
·     MAD IP address—MAD IP address of a member device.
·     Neighbor—IRF member ID of the neighboring member device.
·     MAD status—BFD MAD link state. Options include Normal and Faulty.
easy-irf
Use easy-irf to bulk-configure basic IRF settings for an IRF member device in IRF mode.
easy-irf [ member member-id [ renumber new-member-id ] domain domain-id [ priority priority ] [ irf-port1 interface-list1 ] [ irf-port2 interface-list2 ] ]
member member-id: Specifies the member ID of a member device. The member ID must be 1 or 2.
renumber new-member-id: Specifies a new member ID for the device. The member ID must be 1 or 2. The member device automatically reboots for the new member ID to take effect. If you do not specify this option, the command does not change the member ID.
domain domain-id: Specifies an IRF domain ID in the range of 0 to 4294967295. Assign the same domain ID to all devices you are adding to the same IRF fabric.
priority priority: Specifies an IRF priority in the range of 1 to 32. The greater the priority value, the higher the priority. A member with higher priority is more likely to be the master.
irf-port1 interface-list1: Specifies a space-separated list of up to two interface items. Each interface item specifies one interface in the interface-type interface-number form. The interfaces are bound to IRF-port 1.
irf-port2 interface-list2: Specifies a space-separated list of up to two interface items. Each interface item specifies one interface in the interface-type interface-number form. The interfaces are bound to IRF-port 2.
This command bulk-configures basic IRF settings for a device in IRF mode, including the member ID, domain ID, priority, and IRF port bindings.
The easy IRF feature provides the following configuration methods:
·     Interactive method—Enter the easy-irf command without parameters. The system will guide you to set the parameters step by step.
·     Non-interactive method—Enter the easy-irf command with parameters.
As a best practice, use the interactive method if you are new to IRF.
If you execute this command multiple times, the following settings take effect:
·     The most recent settings for the member ID, domain ID, and priority.
·     IRF port bindings added through executions of the command. You can bind a maximum of two physical interfaces to an IRF port.
When you specify physical interfaces for an IRF port, you must follow the IRF port binding requirements in Virtual Technologies Configuration Guide.
If you specify physical interfaces by using the interactive method, you must also follow these restrictions and guidelines:
·     Do not enter spaces between the interface type and interface number.
·     Use a comma (,) to separate two physical interfaces. No spaces are allowed between interfaces.
To remove an IRF physical interface from an IRF port, you must use the undo port group interface command in IRF port view.
# (Centralized devices in IRF mode.) Bulk-configure basic IRF settings by using the non-interactive method.
[Sysname] easy-irf member 2 renumber 1 domain 10 priority 10 irf-port1 gigabitethernet 2/0/0 gigabitethernet 2/0/1
                  Configuration summary for member 2
IRF new member ID: 1
IRF domain ID    : 10
IRF priority     : 10
IRF-port 1       : GigabitEthernet2/0/0, GigabitEthernet2/0/1
IRF-port 2       : Disabled
Are you sure to use these settings to set up IRF? [Y/N] y
Starting to configure IRF...
Configuration succeeded.
The device will reboot for the new member ID to take effect. Continue? [Y/N] y
# (Centralized devices in IRF mode.) Bulk-configure basic IRF settings by using the interactive method.
[Sysname] easy-irf
Welcome to use easy IRF.
To skip the current step, enter a dot sign (.).
To return to the previous step, enter a minus sign (-).
To use the default value (enclosed in []) for each parameter, press Enter without
entering a value.
To quit the setup procedure, press CTRL+C.
Select a member by its ID <1> [1]: 1
Specify a new member ID <1~2> [1]: 2
Specify a domain ID <0~4294967295> [0]: 10
Specify a priority <1~32> [1]: 10
Specify IRF-port 1 bindings (a physical interface or a comma-separated physical
interface list)[Disabled]: gigabitethernet1/0/0,gigabitethernet1/0/1
Specify IRF-port 2 bindings (a physical interface or a comma-separated physical
                  Configuration summary for member 1
IRF new member ID: 2
IRF domain ID    : 10
IRF priority     : 10
IRF-port 1       : GigabitEthernet1/0/0, GigabitEthernet1/0/1
# (Distributed devices in IRF mode.) Bulk-configure basic IRF settings by using the non-interactive method.
[Sysname] easy-irf member 2 renumber 1 domain 10 priority 10 irf-port1 gigabitethernet 2/2/0/0 gigabitethernet 2/2/0/1
IRF domain ID    : 10
IRF priority     : 10
IRF-port 1       : GigabitEthernet2/2/0/0, GigabitEthernet2/2/0/1
# (Distributed devices in IRF mode.) Bulk-configure basic IRF settings by using the interactive method.
[Sysname] easy-irf
entering a value.
Select a member by its ID <1> [1]:2
Specify a new member ID <1~2> [2]: 1
interface list)[Disabled]: gigabitethernet2/2/0/0,gigabitethernet2/2/0/1
IRF domain ID    : 10
IRF priority     : 10
IRF-port 1       : GigabitEthernet2/2/0/0,GigabitEthernet2/2/0/1
irf auto-merge enable
Use irf auto-merge enable to enable IRF auto-merge. This command enables an IRF fabric to automatically reboot its member devices if it fails in the master election during an IRF fabric merge.
Use undo irf auto-merge enable to disable IRF auto-merge.
IRF auto-merge is enabled. The IRF fabric that has failed in the master election reboots automatically to complete the IRF fabric merge.
For a successful merge, make sure IRF auto-merge is enabled on both IRF fabrics that are merging.
This command is supported only in IRF mode. When you change the operating mode from IRF to standalone, the setting for this command is lost, regardless of whether you have saved the configuration. To disable IRF auto-merge after you change the operating mode from standalone to IRF, use the undo form of this command.
IRF auto-merge takes effect on merges caused by any of the following events:
·     The IRF link recovers from a link failure.
·     The IRF physical interfaces of the member devices are connected after the interfaces are bound to IRF ports.
The feature does not take effect on a merge that occurs in the following conditions:
·     You bind a physical interface to an IRF port.
·     The interface has been connected to the peer IRF physical interface before the binding operation.
If the IRF auto-merge feature does not take effect, you must save the running configuration, and then follow the system instructions to manually reboot one or multiple member devices.
# Enable IRF auto-merge.
[Sysname] irf auto-merge enable
irf auto-update enable
Use irf auto-update enable to enable the software auto-update feature.
Use undo irf auto-update enable to disable the software auto-update feature.
Software auto-update is enabled.
This command is supported only in IRF mode. When you change the operating mode from IRF to standalone, the setting for this command is lost, regardless of whether you have saved the configuration. To disable software auto-update after you change the operating mode from standalone to IRF, use the undo form of this command.
Centralized devices in IRF mode:
This command automatically propagates the current software images of the master device in the IRF fabric to any devices you are adding to the IRF fabric.
To ensure a successful software update, verify that the new device you are adding to the IRF fabric has sufficient storage space for the new software images. If sufficient storage space is not available, the device automatically deletes the current software images. If the reclaimed space is still insufficient, the device cannot complete the auto-update. You must reboot the device, and then access the Boot ROM menu to delete files.
You must manually update the new device with the software images running on the IRF fabric when software auto-update is disabled.
Distributed devices in IRF mode:
This command automatically propagates the current software images of the master MPU in the IRF fabric to any MPUs you are adding to the IRF fabric.
To ensure a successful software update, verify that the new MPU you are adding to the IRF fabric has sufficient storage space for the new software images. If sufficient storage space is not available, the MPU automatically deletes the current software images. If the reclaimed space is still insufficient, the MPU cannot complete the auto-update. You must reboot the device that holds the MPU, and then access the Boot ROM menu to delete files.
You must manually update the new MPU with the software images running on the IRF fabric when software auto-update is disabled.
# Enable the software auto-update feature.
[Sysname] irf auto-update enable
irf domain
Use irf domain to assign a domain ID to the IRF fabric.
Use undo irf domain to restore the default IRF domain setting.
irf domain domain-id
undo irf domain
The IRF domain ID is 0.
domain-id: Specifies a domain ID for the IRF fabric. The value range is 0 to 4294967295.
This command is supported only in IRF mode. When you change the operating mode from IRF to standalone, the IRF domain setting is lost, regardless of whether you have saved the configuration.
One IRF fabric forms one IRF domain. IRF uses IRF domain IDs to uniquely identify IRF fabrics and prevent IRF fabrics from interfering with one another.
If one IRF fabric uses another IRF fabric as the intermediate device for LACP MAD, you must assign the two IRF fabrics different domain IDs for correct split detection. False detection causes IRF split.
An IRF fabric has only one IRF domain ID. You can change the IRF domain ID by using the irf domain or mad enable, command. The IRF domain IDs configured by using the commands overwrite each other.
# Set the IRF domain ID to 10.
[Sysname] irf domain 10
irf link-delay
Use irf link-delay to set a delay for the IRF ports to report a link down event.
Use undo irf link-delay to restore the default.
irf link-delay interval
undo irf link-delay
A link down event is not delayed to report.
interval: Sets the IRF link down report delay in the range of 0 to 10000 milliseconds. If the interval is set to 0, link down events are reported without any delay.
This command is supported only in IRF mode. When you change the operating mode from IRF to standalone, the command configuration is lost, regardless of whether you have saved the configuration.
If the BFD feature is used on the IRF fabric, make sure the delay interval is shorter than the maximum BFD session lifetime. For more information about BFD, see High Availability Configuration Guide.
# Set the IRF link down report delay to 300 milliseconds.
[Sysname] irf link-delay 300
irf mac-address persistent
Use irf mac-address persistent to configure IRF bridge MAC persistence.
Use undo irf mac-address persistent to enable the IRF fabric to change its bridge MAC address as soon as the address owner leaves.
irf mac-address persistent { always | timer }
IRF bridge MAC address remains unchanged for 6 minutes after the address owner leaves.
always: Enables the IRF bridge MAC address to be permanent. The IRF bridge MAC address does not change after the address owner leaves the fabric.
timer: Enables the IRF bridge MAC address to remain unchanged for 6 minutes after the address owner leaves. If the owner rejoins the IRF fabric with the time limit, the IRF bridge MAC address does not change. If the owner does not rejoin the IRF fabric within the time limit, the IRF fabric uses the bridge MAC address of the current master as the bridge MAC address.
IRF bridge MAC persistence specifies the amount of time an IRF fabric can continue to use a bridge MAC address as its bridge MAC address after the address owner leaves.
Bridge MAC persistence is supported only in IRF mode. When you change the operating mode from IRF to standalone, the bridge MAC persistence setting is lost, regardless of whether you have saved the configuration.
If the IRF fabric has multichassis aggregate links, do not use the undo irf mac-address persistent command. Use of this command might cause traffic disruption.
By default, an IRF fabric uses the bridge MAC address of the master device as its bridge MAC address. Layer 2 protocols, such as LACP, use this bridge MAC address to identify the IRF fabric. On a switched LAN, the bridge MAC address must be unique.
When IRF fabrics merge, IRF ignores the IRF bridge MAC address and checks the bridge MAC address of each member device in the IRF fabrics. IRF merge fails if any two member devices have the same bridge MAC address.
# Enable the IRF bridge MAC address to persist forever.
[Sysname] irf mac-address persistent always
irf member
Use irf member to assign a member ID to the device in standalone mode.
Use undo irf member to restore the default.
irf member member-id
undo irf member
The member ID is 1.
member-id: Assigns an IRF member ID to the device. The member ID must be 1 or 2.
Assign an IRF member ID to a device before enabling IRF mode. The member ID takes effect after IRF mode is enabled. This member ID must be unique among all IRF member devices.
To change the member ID of a device in IRF mode, use the irf member renumber command. The new member ID takes effect at reboot.
# (In standalone mode.) Assign member ID 2 to the device.
[Sysname] irf member 2
irf member renumber
irf member description
Use irf member description to configure a description for an IRF member.
Use undo irf member description to restore the default.
irf member member-id description text
undo irf member member-id description
No description is configured for any IRF member.
member-id: Specifies the ID of an IRF member.
text: Configures the IRF member description, a string of 1 to 127 characters.
Configure a description to describe the location or purpose of a member device.
This command is supported only in IRF mode. When you change the operating mode from IRF to standalone, the IRF member description is lost, regardless of whether you have saved the configuration.
# Configure a description for IRF member 1.
[Sysname] irf member 1 description F1Num001
irf member priority
Use irf member priority to change the priority of an IRF member device in IRF mode.
Use undo irf member priority to restore the default.
irf member member-id priority priority
undo irf member member-id priority
The IRF member priority is 1.
member-id: Specifies an IRF member ID. The IRF member ID must be 1 or 2.
priority: Sets priority in the range of 1 to 32. The greater the priority value, the higher the priority. A member with higher priority is more likely to be the master.
This command is supported only in IRF mode. The new priority setting takes effect at the next master election, but it does not trigger a master election.
To assign an IRF priority to a device in standalone mode, use the irf priority command.
To display the ID and priority settings of IRF members, use the display irf command.
# (In IRF mode.) Set the priority of IRF member 2 to 32.
[Sysname] irf member 2 priority 32
irf priority
irf member renumber
Use irf member renumber to change the IRF member ID of a device in IRF mode.
Use undo irf member renumber to restore the previous IRF member ID of the device.
irf member member-id renumber new-member-id
undo irf member member-id renumber
The device uses the member ID that is set in standalone mode.
member-id: Specifies the ID of an IRF member. The IRF member ID must be 1 or 2.
new-member-id: Assigns a new ID to the IRF member. The IRF member ID must be 1 or 2.
CAUTION
CAUTION:
IRF member ID change can cause losses of member ID-related configurations at reboot, including settings on IRF physical interfaces.
To have the new ID take effect, you must reboot the IRF member. To cancel the member ID change before you reboot the member device, use the undo irf member renumber command. In the command, set the new member ID to be the same as the old member ID.
When adding a device into an IRF fabric, you must assign a unique IRF member ID to the device. If its IRF member ID has been used in the IRF fabric, the device cannot join the IRF fabric.
Plan IRF member ID assignment before setting up an IRF fabric, and change member IDs before configuring any other features.
Interchanging member IDs between IRF member devices might cause undesirable configuration changes and data loss. For example, the IRF member IDs of Device A and Device B are 2 and 3, respectively. After you interchange their member IDs, their port settings also interchange.
After an IRF fabric is formed, make sure you understand the impact of the member ID change on your network.
To set the member ID of a device in standalone mode, use the irf member command.
# (In IRF mode.) Change the ID of an IRF member from 2 to 1.
[Sysname] irf member 2 renumber 1
Renumbering the member ID may result in configuration change or loss. Continue?[Y/N]Y
# (In IRF mode.) Before rebooting the device, cancel the change in the preceding example.
[Sysname] undo irf member 2 renumber
Renumbering the member ID may result in configuration change or loss. Continue?[Y/N]y
If you reboot the device after executing the irf member 2 renumber 1 command, the device member ID changes to 1 at system reboot. Using undo irf member 2 renumber cannot restore the member ID to 2. You must use the irf member 1 renumber 2 command to reconfigure the member ID.
irf member
irf priority
Use irf priority to assign an IRF member priority to a device in standalone mode.
Use undo irf priority to restore the default.
irf priority priority
undo irf priority
priority: Specifies an IRF member priority value in the range of 1 to 32. The greater the priority value, the higher the priority. A member with higher priority is more likely to be the master.
The member priority configured in standalone mode takes effect after you enable IRF mode.
To change the member priority of a device in IRF mode, use the irf member priority command. The new priority setting takes effect at the next master election, but it does not trigger a master election.
# (In standalone mode.) Assign IRF member priority 32 to the device.
[Sysname] system-view
[Sysname] irf priority 32
irf member priority
irf-port
Use irf-port to enter IRF port view.
Use undo irf-port to remove all port bindings on an IRF port.
In standalone mode:
irf-port irf-port-number
undo irf-port irf-port-number
In IRF mode:
irf-port member-id/irf-port-number
undo irf-port member-id/irf-port-number
member-id: Specifies an IRF member device by its member ID.
irf-port-number: Specifies an IRF port on the member device. The irf-port-number argument represents the IRF port index and must be 1 or 2.
To bind physical interfaces to an IRF port, you must enter IRF port view.
Before you remove all port bindings on an IRF port, shut down all its physical interfaces.
# (In standalone mode.) Enter IRF-port 1 view.
[Sysname] irf-port 1
[Sysname-irf-port1]
# (In IRF mode.) Enter IRF-port 2/1 view.
[Sysname] irf-port 2/1
[Sysname-irf-port2/1]
Use irf-port-configuration active to activate IRF ports.
After connecting the physical interfaces between two devices and binding them to the correct IRF ports, you must use this command to activate the settings on the IRF ports. This command merges the two devices into one IRF fabric.
The system activates the IRF port settings automatically in the following situations:
·     The configuration file that the device starts with contains IRF port bindings.
·     You are binding physical interfaces to an IRF port after an IRF fabric is formed.
(Centralized devices.) To configure and activate IRF-port 1/2 when the port is in DIS state:
# Bind GigabitEthernet 2/0/1 to IRF-port 1/2.
[Sysname-GigabitEthernet2/0/1] shutdown
[Sysname-GigabitEthernet2/0/1] quit
[Sysname] irf-port 1/2
[Sysname-irf-port1/2] port group interface GigabitEthernet 2/0/1
 Info : You are recommended to save the configuration now; otherwise, it will be lost after system reboot.
[Sysname-irf-port1/2] quit
[Sysname-GigabitEthernet2/0/1] undo shutdown
# Save the configuration so the IRF port settings can take effect after the device reboots.
[Sysname] save
Please input the file name(*.cfg)[cfa0:/startup.cfg]
cfa0:/startup.cfg exists, overwrite? [Y/N]:y
 Validating file. Please wait............................
Slot 1:
 Save next configuration file successfully.
 Configuration is saved to device successfully.
# Activate the IRF port.
[Sysname] irf-port-configuration active
(Distributed devices.) To configure and activate IRF-port 1/2 when the port is in DIS state:
# Bind GigabitEthernet 1/2/0/0 to IRF-port 1/2.
[Sysname] interface gigabitethernet 1/2/0/0
[Sysname-GigabitEthernet1/2/0/0] shutdown
[Sysname-GigabitEthernet1/2/0/0] quit
[Sysname-irf-port1/2] port group interface gigabitethernet 1/2/0/0
[Sysname-GigabitEthernet1/2/0/0] undo shutdown
[Sysname] save
Chassis 1 Slot 1:
# Activate the IRF port settings.
mad bfd enable
Use mad bfd enable to enable BFD MAD.
Use undo mad bfd enable to disable BFD MAD.
mad bfd enable
undo mad bfd enable
BFD MAD is disabled.
Layer 3 interface view
BFD MAD uses the BFD protocol to detect multi-active collisions. This MAD mechanism can work with or without intermediate devices.
When you configure BFD MAD on a Layer 3 aggregate interface, follow these restrictions and guidelines:
Category
BFD MAD-enabled Layer 3 aggregate interface
The aggregate interface must operate in static aggregation mode.
BFD MAD VLAN
·     On the intermediate device (if any), assign the ports on the BFD MAD links to the same VLAN. Do not assign the ports to an aggregate interface. If these ports are hybrid ports, make sure these ports are untagged members of their PVIDs.
·     If the intermediate device acts as a BFD MAD intermediate device for multiple IRF fabrics, assign different BFD MAD VLANs to the IRF fabrics.
·     Do not use the BFD MAD VLAN on the intermediate device for any purposes other than BFD MAD.
·     Make sure the BFD MAD VLAN on the intermediate device contains only ports on the BFD MAD links. Exclude a port from the BFD MAD VLAN if that port is not on a BFD MAD link. If you have assigned that port to all VLANs by using the port trunk permit vlan all command, use the undo port trunk permit command to exclude that port from the BFD MAD VLAN.
BFD MAD-enabled Layer 3 aggregate interface and feature compatibility
Do not use the BFD MAD-enabled interface and its member ports for any purposes other than configuring BFD MAD. Configure only the mad bfd enable and mad ip address commands on the BFD MAD-enabled interface. If you configure other features, both BFD MAD and other features on the interface might run incorrectly.
MAD IP address
·     To avoid network issues, only use the mad ip address command to configure IP addresses on the BFD MAD-enabled interface. Do not configure an IP address by using the ip address command or configure a VRRP virtual address on the BFD MAD-enabled interface.
·     Make sure all the MAD IP addresses are on the same subnet.
# Enable BFD MAD on Route-Aggregation 3.
[Sysname] interface route-aggregation 3
[Sysname-Route-Aggregation3] mad bfd enable
mad enable
Use mad enable to enable LACP MAD.
Use undo mad enable to disable LACP MAD.
mad enable
undo mad enable
LACP MAD is disabled.
Aggregate interface view
LACP MAD uses extended LACP packets to detect multi-active collisions. This MAD mechanism requires an intermediate device that supports extended LACPDUs.
You must set up a dynamic link aggregation group that spans all IRF member devices between the IRF fabric and the intermediate device. To enable dynamic link aggregation, configure the link-aggregation mode dynamic command on the aggregate interface.
When you use the mad enable command, the system prompts you to enter a domain ID. If you do not want to change the current domain ID, press enter at the prompt.
An IRF fabric has only one IRF domain ID. You can change the IRF domain ID by using the irf domain or mad enable command. The IRF domain IDs configured by using the commands overwrite each other.
# Enable LACP MAD on Bridge-Aggregation 1, a Layer 2 dynamic aggregate interface.
[Sysname-Bridge-Aggregation1] mad enable
 [Current domain is: 0]: 1
 The assigned  domain ID is: 1
 MAD LACP only enable on dynamic aggregation interface.
# Enable LACP MAD on Route-Aggregation 1, a Layer 3 dynamic aggregate interface.
[Sysname-Route-Aggregation1] link-aggregation mode dynamic
[Sysname-Route-Aggregation1] mad enable
irf domain
mad exclude interface
Use mad exclude interface to exclude a network port from being shut down when the IRF fabric transits to the Recovery state upon detection of a multi-active collision.
Use undo mad exclude interface to configure the IRF fabric to shut down a network port when it transits to the Recovery state upon detection of a multi-active collision.
mad exclude interface interface-type interface-number
undo mad exclude interface interface-type interface-number
All ports except the IRF physical interfaces and console ports shut down when the IRF fabric transits to the Recovery state.
interface-type interface-number: Specifies a port by its type and number.
If a port must be kept in up state for special purposes such as Telnet connection, exclude the port from the shutdown action. As a best practice to avoid incorrect traffic forwarding, do not exclude any ports except for the ports used for Telnet.
Do not exclude the MAD-enabled aggregate interfaces and their member ports from the shutdown action.
The ports that have been shut down by MAD come up when the member devices reboot to join the recovered IRF fabric. If auto recovery fails because the current master fails or any other exception occurs, use the mad restore command to manually recover the member devices and bring up the ports.
# (Centralized devices.) Exclude GigabitEthernet 1/0/1 from being shut down when the MAD status transits to Recovery.
[Sysname] mad exclude interface gigabitethernet1/0/1
# (Distributed devices.) Exclude GigabitEthernet 1/2/0/1 from being shut down when the MAD status transits to Recovery.
[Sysname] mad exclude interface gigabitethernet 1/2/0/1
mad restore
mad ip address
Use mad ip address to assign a MAD IP address to an IRF member device for BFD MAD.
Use undo mad ip address to delete the MAD IP address for an IRF member device.
mad ip address ip-address { mask | mask-length } member member-id
undo mad ip address ip-address { mask | mask-length } member member-id
No MAD IP address is configured for an IRF member device.
ip-address: Specifies an IP address in dotted decimal notation. This IP address is bound to an IRF member for BFD detection and is called a MAD IP address.
mask: Specifies a subnet mask in decimal dotted notation.
mask-length: Specifies a subnet mask in length, in the range of 0 to 32.
member member-id: Specifies the ID of an IRF member.
To use BFD MAD, configure a MAD IP address for each IRF member. Make sure all the MAD IP addresses are on the same subnet.
Do not configure a MAD IP address by using the ip address command or configure a VRRP virtual address on the BFD MAD-enabled interface.
The master attempts to establish BFD sessions with other member devices by using its MAD IP address as the source IP address.
·     If the IRF fabric is integrated, only the MAD IP address of the master takes effect. The master cannot establish a BFD session with any other member. If you execute the display bfd session command, the state of the BFD sessions is Down.
·     When the IRF fabric splits, the IP addresses of the masters in the partitioned IRF fabrics take effect. The masters can establish a BFD session. If you execute the display bfd session command, the state of the BFD session between the two devices is Up.
# Assign a MAD IP address to IRF member 1 on Route-Aggregation 3.
[Sysname-Route-Aggregation3] mad ip address 192.168.0.1 255.255.255.0 member 1
# Assign a MAD IP address to IRF member 2 on Route-Aggregation 3.
[Sysname-Route-Aggregation 3] mad ip address 192.168.0.2 255.255.255.0 member 2
mad bfd enable
mad restore
Use mad restore to restore the normal MAD state of the IRF fabric in Recovery state.
mad restore
If the active IRF fabric has failed to work before the IRF split problem is fixed, use this command to restore an IRF fabric in Recovery state. The recovered IRF fabric will take over the active IRF fabric role.
# Restore the normal MAD state of the IRF fabric in Recovery state.
[Sysname] mad restore
   This command will restore the device from multi-active conflict state. Continue? [Y/N]:Y
Restoring from multi-active conflict state, please wait...
Use port group interface to bind a physical interface to an IRF port.
Use undo port group interface to remove the binding of a physical interface to an IRF port.
port group interface interface-type interface-number
undo port group interface interface-name
No physical interfaces are bound to an IRF port.
IRF port view
interface-type interface-number: Specifies a physical interface by its type and number.
interface-name: Specifies a physical interface in the interface-typeinterface-number format. No space is allowed between the interface-type and interface-number arguments.
Bind a minimum of one physical interface to an IRF port for setting up an IRF connection. You can bind a maximum of two physical interfaces to an IRF port.
In IRF mode, use the shutdown command to shut down a physical interface before you bind it to or remove it from an IRF port. To bring up the physical interface after a binding or binding removal operation, use the undo shutdown command.
In standalone mode, the shutdown and undo shutdown operations are not required.
The system does not dynamically remove IRF port bindings when IRF links are lost, for example, because an interface card is removed. To remove IRF port bindings, you must use the undo port group interface command.
For more information about IRF port binding requirements, see Virtual Technologies Configuration Guide.
# (Centralized devices in IRF mode.) Bind GigabitEthernet 2/0/1 to IRF-port 2/1 on IRF member 2.
[Sysname-irf-port2/1] port group interface gigabitethernet 2/0/1
[Sysname-irf-port2/1] quit
# (Distributed devices in standalone mode.) Bind GigabitEthernet 2/0/1 to IRF-port 1.
[Sysname-irf-port1] port group interface gigabitethernet 2/0/1
# (Distributed devices in IRF mode.) Bind GigabitEthernet 1/2/0/1 to IRF-port 1/1 on IRF member 1.
[Sysname] interface gigabitethernet 1/2/0/1
[Sysname-GigabitEthernet1/2/0/1] shutdown
[Sysname-GigabitEthernet1/2/0/1] quit
[Sysname] irf-port 1/1
[Sysname-irf-port 1/1] port group interface gigabitethernet 1/2/0/1
[Sysname-irf-port 1/1] quit
[Sysname-GigabitEthernet1/2/0/1] undo shutdown
irf-port
Index
C D E I M P
C
chassis convert mode irf,1
D
display irf,3
display irf configuration,5
display irf link,6
display irf topology,8
display mad,8
E
easy-irf,10
I
irf auto-merge enable,13
irf auto-update enable,14
irf domain,15
irf link-delay,16
irf mac-address persistent,16
irf member,17
irf member description,18
irf member priority,19
irf member renumber,19
irf priority,20
irf-port,21
irf-port-configuration active,22
M
mad bfd enable,23
mad enable,24
mad exclude interface,26
mad ip address,26
mad restore,27
P
port group interface,28
