01-OAP module commands | 37.51 KB |
OAP module commands
The device supports this feature only when it has HMIM-OAP interface modules.
Only MSR 3610, MSR 3620, MSR 3620-DP, MSR 3620-XS, MSR 3640, and MSR 3660 support HMIM-OAP interface modules.
oap connect
Use oap connect to log in to the CLI of an OAP module from the device.
In standalone mode:
oap connect system system-name
In IRF mode:
oap connect slot slot-number [ system system-name ]
slot slot-number: Specifies an IRF member device by its member ID. (In IRF mode.)
system system-name: Specifies an OAP module by its device name (configured by using the sysname command) or by its subslot number. Support for this option depends on the device model.
To return to the CLI of the hosting device from the OAP module, press Ctrl+K.
# (In standalone mode.) Log in to the CLI of the OAP module in the specified subslot.
<Sysname> oap connect system 1
Press CTRL+K to quit.
Connected to OAP.
# (In IRF mode.) Log in to the CLI of the OAP module in a subslot.
<Sysname> oap connect slot 1 system 6
Connected to OAP.
oap reboot
Use oap reboot to reboot an OAP module.
In standalone mode:
oap reboot system system-name
In IRF mode:
oap reboot slot slot-number [ system system-name ]
system system-name: Specifies an OAP module by its system name or subslot number. Support for this option depends on the device model.
# (In standalone mode.) Reboot the OAP module in the specified subslot.
<Sysname> oap reboot system 1
This command might cause data loss on the hard disk if the card is not been shut down.
Continue? [Y/N]:y
Rebooting the OAP card by command…
# (In IRF mode.) Reboot the OAP module in a subslot.
<Sysname> oap reboot slot 1 system 6
Continue? [Y/N]:y
