- 16-WLAN Command Reference (FAT AP)
- 01-WLAN hardware compatibility (fat APs)
- 02-Radio management commands
- 03-WLAN access commands
- 04-WLAN security commands
- 05-WLAN authentication commands
- 06-WLAN QoS commands
- 07-WLAN load balancing commands
- 08-Band navigation commands
- 09-WLAN multicast optimization commands
07-WLAN load balancing commands | 69.28 KB |
display wlan load-balance group
display wlan load-balance status service-template
snmp-agent trap enable wlan load-balance
wlan load-balance access-denial
For information about MSR routers that can offer WLAN services as fat APs, see "Compatibility of hardware and AP functionality."
description
Use description to set a description for a load balancing group.
No description is set for a load balancing group.
Load balancing group view
text: Specifies a description for a load balancing group, a case-sensitive string of 1 to 64 characters.
# Set the description for load balancing group 10 to marketing.
[Sysname] wlan load-balance group 10
[Sysname-wlan-lb-group10] description marketing
Use display wlan load-balance group to display load balancing group information.
display wlan load-balance group { group-id | all }
group-id: Specifies a load balancing group by its ID. The value range for this argument is 1 to 65535.
all: Specifies all load balancing groups.
# Display information about load balancing group 1.
<Sysname> display wlan load-balance group 1
WLAN load balance group information
Group ID : 1
Description :
Group members : fatap-radio1,
fatap-radio2,
Group members |
List of radios in the load balancing group. |
Use display wlan load-balance status service-template to display load balancing information for radios that are bound to a service template.
display wlan load-balance status service-template template-name { client mac-address | group group-id }
template-name: Specifies a service template by its name, a case-insensitive string of 1 to 63 characters.
client mac-address: Displays information about radios that have detected the specified client. The mac-address argument represents the MAC address of the client and is in H-H-H format.
group group-id: Displays information about radios in a load balancing group. The group-id argument represents the ID of the load balancing group. The value range for this argument is 1 to 65535.
# Display load balancing information for radios that are bound to service template st1 and are in load balancing group 1.
<Sysname> display wlan load-balance status service-template st1 group 1
Current load balancing session threshold/gap: 2/1
Total radios: 2
APID/RID Group ID Session Bandwidth(Mbps) Traffic(%) Balance(Y/N)
1/1 1 2 100 5 Y
1/2 1 10 50 10 N
# Display load balancing information for radios that are bound to service template st1 and that have detected the client with MAC address 702d-2249-33bf.
<Sysname> display wlan load-balance status service-template st1 client 702d-2249-33bf
Load balancing groups exist: Yes
Total radios: 2
RID Group ID Session Balanced(Y/N)
1 1 2 Y
2 1 10 N
Load balancing groups exist |
Whether load balancing groups exist: Yes or No. |
RID |
Radio ID. |
Group ID |
Load balancing group ID. The value of 0 indicates that the radio is not in a load balancing group. |
Session |
Number of clients associated with the radio. |
Balanced(Y/N) |
Load balancing status: · Y—The radio has been load balanced. · N—The radio has not been load balanced. |
radio
Use radio to add a radio to a load balancing group.
Use undo radio to remove a radio from a load balancing group.
radio radio-id
undo radio [ radio-id ]
No radios exist in a load balancing group.
radio-id: Specifies a radio by its ID. The value range for this argument varies by device model.
You can add a radio to only one load balancing group.
If you do not specify a radio in the undo radio command, the command removes all radios from the load balancing group.
# Add radio 2 to load balancing group 1.
[Sysname-wlan-lb-group-1] radio 2
Use snmp-agent trap enable wlan load-balance to enable SNMP notifications for WLAN load balancing.
Use undo snmp-agent trap enable wlan load-balance to disable SNMP notifications for WLAN load balancing.
SNMP notifications for WLAN load balancing are disabled.
To report critical WLAN load balancing events to an NMS, enable SNMP notifications for WLAN load balancing. For WLAN load balancing event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Enable SNMP notifications for WLAN load balancing.
[Sysname] snmp-agent trap enable wlan load-balance
Use wlan load-balance access-denial to set the maximum number of denials for association requests.
Use undo wlan load-balance access-denial to restore the default.
wlan load-balance access-denial access-denial
The maximum number of denials is 10 for association requests.
access-denial: Specifies the maximum number of denials for association requests, in the range of 2 to 10.
If the number of times that an AP rejects a client reaches the maximum number of denials for association requests, the AP accepts the association request from the client.
# Set the maximum number of denials to 4 for association requests.
[Sysname] wlan load-balance access-denial 4
wlan load-balance enable
Use wlan load-balance enable to enable WLAN load balancing.
Use undo wlan load-balance enable to disable WLAN load balancing.
WLAN load balancing is disabled.
# Enable WLAN load balancing.
[Sysname] wlan load-balance enable
Use wlan load-balance group to create a load balancing group and enter its view, or enter the view of an existing load balancing group.
Use undo wlan load-balance group to remove one or all load balancing groups.
wlan load-balance group group-id
undo wlan load-balance group { group-id | all }
No load balancing group exists.
To perform load balancing among specific APs, you can add the radios of these APs to a load balancing group. The device does not perform load balancing on radios that do not belong to the load balancing group.
# Create load balancing group 10 and enter its view.
[Sysname-wlan-lb-group-10]
radio
wlan load-balance mode session
Use wlan load-balance mode session to configure session-mode load balancing.
Use undo wlan load-balance mode to restore the default.
wlan load-balance mode session value [ gap gap-value ]
Session-mode load balancing is used and the session threshold is 20.
value: Specifies the session threshold in the range of 1 to 120.
gap gap-value: Specifies the session gap threshold in the range of 1 to 12. The default session gap threshold is 4.
The AC performs session-mode load balancing when the following conditions are met:
· The number of clients associated with an AP reaches the session threshold.
· The session gap between the AP and the AP that has the fewest clients reaches the session gap threshold.
# Set the load balancing mode to session mode, and set the session threshold and session gap threshold to 7 and 5, respectively.
[Sysname] wlan load-balance mode session 7 gap 5
wlan load-balance rssi-threshold
Use wlan load-balance rssi-threshold to set the received signal strength indicator (RSSI) threshold.
Use undo wlan load-balance rssi-threshold to restore the default.
wlan load-balance rssi-threshold rssi-threshold
The RSSI threshold is 25.
rssi-threshold: Specifies the RSSI threshold in the range of 5 to 100.
An AP determines that a client not detected if the client's RSSI is lower than the load balancing RSSI threshold. If only one AP can detect the client, the AP increases the access probability for the client by decreasing the maximum number of denials to 1 for the client.
# Set the RSSI threshold to 40.
[Sysname] wlan load-balance rssi-threshold 40
