- 08-Layer 3—IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-IS-IS commands
- 06-EIGRP commands
- 07-BGP commands
- 08-Policy-based routing commands
- 09-IPv6 static routing commands
- 10-RIPng commands
- 11-OSPFv3 commands
- 12-IPv6 policy-based routing commands
- 13-Routing policy commands
- 14-MTR commands
06-EIGRP commands | 159.31 KB |
EIGRP commands
The following compatibility matrixes show the support of hardware platforms for EIGRP:
Hardware |
EIGRP compatibility |
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK |
Yes |
MSR810-LMS, MSR810-LUS |
No |
MSR810-LMS-EA, MSR810-LME |
Yes |
MSR2600-6-X1, MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
Yes |
No |
Yes |
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD |
Yes |
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC |
Yes |
Yes |
MSR3610-G, MSR3620-G |
No |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet, MSR2600-10-X1-WiNet |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR2630-XS |
Yes |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR2630-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
address-family ipv4
Use address-family ipv4 to create the EIGRP IPv4 address family and enter its view, or enter the view of the existing address family.
Use undo address-family ipv4 to remove the EIGRP IPv4 address family and all its configurations.
address-family ipv4
No EIGRP IPv4 address family exists.
EIGRP view
# Create the EIGRP IPv4 address family and enter its view
[Sysname] eigrp 1
[Sysname-eigrp-1] address-family ipv4
[Sysname-eigrp-1-ipv4]
default-metric
Use default-metric to set the metrics for redistributed routes.
Use undo default-metric to restore the default.
default-metric min-bandwidth total-delay reliability load mtu
undo default-metric
The minimum bandwidth is 10000 Kbps, the total delay is 100 microseconds, the minimum reliability value is 255, the maximum load is 1, and the minimum MTU is 1500 bytes.
EIGRP IPv4 address family view
min-bandwidth: Specifies the minimum bandwidth in the range of 1 to 4294967295 Kbps.
total-delay: Specifies the total delay in the range of 1 to 16777215 in 10 microseconds.
reliability: Specifies the minimum reliability value in the range of 1 to 255. A greater value means higher reliability. 1 means completely unreliable. 255 means completely reliable.
load: Specifies the maximum load in the range of 1 to 255. A smaller value means an idler link.
mtu: Specifies the minimum MTU in the range of 1 to 65535 bytes.
EIGRP calculates the composite metric for a route by using the configured metrics and the weights assigned to them. For information about how to calculate the composite route metric, see the metric weights command.
If you do not set the metrics in the import-route command, EIGRP uses the settings in the default-metric command for composite metric calculation.
# For EIGRP process 1, set the bandwidth, delay, reliability, load, and MTU metric values for redistributed routes to 111, 2220, 33, 44, and 555, respectively.
[Sysname] eigrp 1
[Sysname-eigrp-1-ipv4] default-metric 111 222 33 44 555
import-route
metric weights
discard-route
Use discard-route to configure discard route preferences.
Use undo discard-route to restore the default.
discard-route { external external-preference | internal internal-preference } *
undo discard-route
The preference is 5 for discard routes generated from automatic summarization for both internal and external routes.
external external-preference: Specifies the preference for discard routes generated from automatic summarization for external routes, in the range of 1 to 255.
internal internal-preference: Specifies the preference for discard routes generated from automatic summarization for internal routes, in the range of 1 to 255.
# Configure the preference as 100 and 200 for discard routes generated from automatic summarization for external routes and internal routes, respectively.
[Sysname] eigrp 1
[Sysname-eigrp-1-ipv4] discard-route external 100 internal 200
summary automatic
display eigrp
Use display eigrp to display EIGRP configuration information.
display eigrp [ eigrp-as ]
eigrp-as: Specifies an EIGRP process by its AS number in the range of 1 to 65535. If you do not specify this argument, the command displays configuration information for all EIGRP processes.
# Display configuration information for all EIGRP processes.
<Sysname> display eigrp
EIGRP protocol information for AS 1
Router ID: 192.168.10.1
Metric weights: K1 1, K2 0, K3 1, K4 0, K5 0
Active timer: 3 min
GR hold time: 240 sec
Preferences: internal 90, external 170
DSCP value: 48
Default metric:
Minimum bandwidth: 0 kbps
Total delay: 0 microseconds
Reliability: 0
Load : 0
Minimum MTU: 0
Max ECMP paths: 16
Active timer |
Convergence wait timer in seconds. |
GR hold time |
Aging timer for routes on a GR helper, in seconds. |
Preferences |
Internal and external EIGRP route preferences. |
Default metric |
Metrics for redistributed routes. |
Minimum bandwidth |
Minimum bandwidth in Kbps. |
Total delay |
Total delay in microseconds. |
Reliability |
Minimum reliability value. |
Load |
Maximum load value. |
Minimum MTU |
Minimum MTU in bytes. |
Max ECMP paths |
Maximum number of ECMP routes supported. |
display eigrp interface
Use display eigrp interface to display EIGRP interface information.
display eigrp [ eigrp-as ] interface [ interface-type interface-number ] [ verbose ]
eigrp-as: Specifies an EIGRP process by its AS number in the range of 1 to 65535. If you do not specify this argument, the command displays interface information for all EIGRP processes.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this argument, the command displays information for all interfaces.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display brief information for GigabitEthernet 1/0/1 in all EIGRP processes.
<Sysname> display eigrp interface gigabitethernet 1/0/1
Interface State Hello-interval Hold-time Split-horizon
GE1/0/1 Down 20 80 Enabled
Interface name. |
State |
Interface state: Up or Down. |
Hello-interval |
Hello interval in seconds. |
Hold-time |
Hold time in seconds. |
Split-horizon |
Split horizon status: Enabled or Disabled. |
# Display detailed information for GigabitEthernet 1/0/1 in all EIGRP processes.
<Sysname> display eigrp interface gigabitethernet 1/0/1 verbose
EIGRP interface for AS 1
Interface: 192.168.2.2 (GE1/0/1)
State: Down
Hello-interval: 5 sec
Hold-time: 15 sec
Split-horizon: Disabled
Multicasts: 0
Metric:
Bandwidth: 10000000 kbps
Delay: 50000 microseconds
Reliability: 255
Load: 255
MTU: 1500
IP address and name for the interface. |
State |
Hello-interval |
Hold-time |
Split-horizon |
Multicasts |
Number of EIGRP multicast packets to be sent. |
Metric |
EIGRP interface metrics. |
display eigrp peer
Use display eigrp peer to display EIGRP neighbor information.
display eigrp [ eigrp-as ] peer [ interface interface-type interface-number ] [ neighbor-ip ] [ verbose ]
eigrp-as: Specifies an EIGRP process by its AS number in the range of 1 to 65535. If you do not specify this argument, the command displays neighbor information for all EIGRP processes.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays neighbor information for all interfaces.
neighbor-ip: Specifies an EIGRP neighbor by its IP address. If you do not specify this argument, the command displays information about all neighbors for the specified or all EIGRP processes.
# Display brief EIGRP neighbor information.
<Sysname> display eigrp peer
Brief EIGRP neighbor Information for AS 1
Address State Hold time Interface
Address |
IP address of the neighbor. |
State |
Neighbor state: · Down—The neighbor relationship is in initial state. · Pending—The three-way handshake is not complete. · Up—The neighbor relationship is established. |
Hold time |
Interface that is connected to the neighbor. |
# Display detailed EIGRP neighbor information.
<Sysname> display eigrp peer verbose
Neighbor address : 1.2.3.5
State : Up Interface : GE1/0/1
Hold time : 12s Version : 0.1/2.0
Seq Num : 2 Prefixes : 1
Unicasts: 0 Retries : 0
Uptime : 00:04:41
Table 5 Command output
Neighbor Address |
State |
Hold time |
Version |
EIGRP software version number/EIGRP TLV version number of the neighbor. |
Seq Num |
Sequence number of packets received from the neighbor. |
Prefixes |
Number of prefixes advertised by the neighbor. |
Unicasts |
Number of EIGRP unicast packets to be sent to the neighbor. |
Retries |
Number of packet retransmissions. |
Uptime |
Amount of time that the neighbor is in Up state. |
display eigrp peer statistics
Use display eigrp peer statistics to display EIGRP neighbor statistics.
display eigrp [ eigrp-as ] peer statistics [ interface interface-type interface-number ]
eigrp-as: Specifies an EIGRP process by its AS number in the range of 1 to 65535. If you do not specify this argument, the command displays neighbor statistics for all EIGRP processes.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays neighbor statistics for all interfaces.
# Display EIGRP neighbor statistics.
<Sysname> display eigrp 1 peer statistics
EIGRP As 1 with Router ID 5.5.5.5
Neighbor Statistics
Interface Down Pending Up Total
GE1/0/1 0 0 1 1
Total 0 0 1 1
Table 6 Command output
Interface name |
Down |
Number of neighbors in Down state. |
Pending |
Number of neighbors in Pending state. |
Up |
Number of neighbors in Up state. |
Total |
Total number of neighbors in all states. |
display eigrp
display eigrp statistics
Use display eigrp statistics to display EIGRP statistics.
display eigrp [ eigrp-as ] statistics [ error ]
eigrp-as: Specifies an EIGRP process by its AS number in the range of 1 to 65535. If you do not specify this argument, the command displays statistics for all EIGRP processes.
error: Displays error statistics. If you do not specify this keyword, the command displays EIGRP process statistics.
# Display all types of EIGRP statistics.
<Sysname> display eigrp statistics
EIGRP statistics for AS 1
Packet type Sent Received
HELLO 2142 1809
UPDATE 12 9
QUERY 0 0
REPLY 0 0
HELLO(ACK) 7 5
SIA-QUERY 0 0
SIA-REPLY 0 0
Route type Added Deleted
Internal 1 2
External 0 0
Table 7 Command output
Packet type |
Packet type: · HELLO · UPDATE · QUERY · REPLY · HELLO(ACK) · SIA-QUERY · SIA-REPLY |
Sent |
Number of packets sent. |
Received |
Number of packets received. |
Route type |
Route type: Internal or External. |
Added |
Number or routes added to RIB. |
Deleted |
Number or routes deleted from RIB. |
# Display EIGRP error statistics.
<Sysname> display eigrp statistics error
EIGRP error statistics for AS 1
Packet dest errors : 0
Bad version : 0
Bad PktType : 0
Bad checksum : 0
Mismatched K value : 0
Table 8 Command output
Packet dest errors |
Number of packets with wrong destinations. |
Bad version |
Number of packets with wrong version numbers. |
Bad PktType |
Number of packets with packet types. |
Bad checksum |
Number of packets with checksum errors. |
Mismatched K value |
Number of packets with mismatched K values. |
display eigrp peer
display eigrp topology
Use display eigrp topology to display EIGRP topology table information.
display eigrp [ eigrp-as ] topology [ ip-address { mask-length | mask } ] [ all-links | verbose ]
display eigrp [ eigrp-as ] topology statistics
eigrp-as: Specifies an EIGRP process by its AS number in the range of 1 to 65535. If you do not specify this argument, the command displays topology table information for all EIGRP processes.
ip-address { mask-length | mask }: Specifies a route. The ip-address argument specifies the destination network. The mask-length argument specifies the mask length in the range of 0 to 32. The mask argument specifies the subnet mask in dotted decimal notation. If you do not specify a route, the command displays information about all routes.
all-links: Displays information about all paths, including feasible and unfeasible paths. If you do not specify this keyword, the command displays optimal path information.
statistics: Displays statistics for the EIGRP topology table.
If you do not specify the all-links, verbose, or statistics keyword, the command displays topology table information for the specified or all EIGRP processes.
# Display brief EIGRP topology table information.
<Sysname> display eigrp topology
EIGRP topology for AS 1 with Router ID 10.0.0.1
Destination FD State Successor Out interface
10.0.0.0/8 409600 Passive 1.1.1.2 GE1/0/1
20.0.0.0/8 409600 Passive Direct GE1/0/2
Table 9 Command output
Destination |
Destination network address. |
FD |
Feasible distance, that is, the lowest metric to the destination network. |
State |
Route state: Passive or Active. |
Successor |
Successor for the route: · IP address of the successor. · Direct—The route is a direct route. · Imported—The route is a redistributed route. · Summary—The route is a summary route. |
Out interface |
Output interface for the route. |
# Display detailed EIGRP topology table information.
<Sysname> display eigrp topology verbose
Destination : 10.0.0.0/8 FD : 409600 State : Passive
Successor : 8.8.8.5
Type : Internal
Out interface : GE1/0/2
Originating router : 10.0.1.2
Nib ID : 0x0
CD/RD : 409600/128256
Metric :
Minimum bandwidth : 10000 kbps
Total delay : 6000 microseconds
Reliability : 255/255
Load : 1/255
Minimum MTU : 1500
Hop count : 1
Destination : 10.0.0.0/8 FD : 409600 State : Active
Active time : 00:02:41
Query origin : 0
Successor : 8.8.8.5
Type : External
Nib ID : 0x0
Metric :
Load : 1/255
Minimum MTU : 1500
Hop count : 1
External data :
AS number : 2
External protocol : OSPF
External metric : 11
Admin tag : -
Waiting peers reply:
10.0.1.2 on GigabitEthernet1/0/3
10.0.1.3 on GigabitEthernet1/0/3
10.0.1.4 on GigabitEthernet1/0/4
10.0.1.5 on GigabitEthernet1/0/4
Table 10 Command output
Destination |
Destination network. |
FD |
State |
Active time |
Amount of time that the route is in Active state. |
Query origin |
Query origin flag, indicating the sub state for the Active state. · 0—Active 0 state. · 1—Active 1 state. · 2—Active 2 state. · 3—Active 3 state. |
Successor |
Type |
Out interface |
Originating router |
Router ID for the originating router. |
Nib ID |
Next hop ID assigned by route management. |
CD/RD |
Computed Distance/Reported Distance. Computed Distance (CD) is the total metric along the path through the neighbor to the destination network. Reported Distance (RD) is the metric to the destination network advertised by the neighbor. |
Metric |
Metric advertised by the neighbor. |
Minimum bandwidth |
Total delay |
Reliability |
Load |
Minimum MTU |
Hop count |
Number of hops to the destination network. |
External data |
Data contained in the external route. |
AS number |
Process ID for the external routing protocol. |
External protocol |
External routing protocol. |
External metric |
Metric for the external routing protocol. |
Admin tag |
Tag for the external route. |
Waiting peers reply |
EIGRP neighbors from whom the local router is waiting for a reply, and the output interfaces corresponding to the neighbors. |
# Display information about all paths in the EIGRP topology table.
<Sysname> display eigrp topology all-links
Flags: S - Successor F - Feasible successor
Link information:
Flag Peer Out interface Type CD RD
S 1.1.1.2 GE1/0/1 Internal 409600 128256
F 2.1.1.2 GE1/0/2 Internal 576000 213400
3.1.1.2 GE1/0/3 External 631000 510200
Table 11 Command output
Destination |
FD |
State |
Link information |
Information about the paths related to the route. |
Flag |
Path flag: · S—Successor. The neighbor that provides the path is a successor. · F—Feasible successor. The neighbor that provides the path is a feasible successor. |
Peer |
Out interface |
Type |
CD |
Total metric along the path through the neighbor to the destination network. |
RD |
The metric to the destination network advertised by the neighbor. |
# Display statistics for the EIGRP topology table.
<Sysname> display eigrp topology statistics
EIGRP topology statistics for AS 65535 with Router ID 2.1.1.1
Destinations:
Active : 0
Passive : 256
Total : 256
Routes:
Learnt : 7
Direct : 7
Imported : 247
Summary : 0
Total : 261
Table 12 Command output
Destinations |
Prefix statistics. |
Active |
Number of prefixes in Active state. |
Passive |
Number of prefixes in Passive state. |
Total |
Total number of prefixes. |
Routes |
Route statistics. |
Learnt |
Number of routes learned from neighbors. |
Direct |
Number of direct routes. |
Imported |
Number of redistributed routes. |
Summary |
Number of summary routes. |
Total |
Total number of routes. |
dscp
Use dscp to set the DSCP value for EIGRP packets.
Use undo dscp to restore the default.
dscp dscp-value
undo dscp
The DSCP value for EIGRP packets is 48.
dscp-value: Specifies a DSCP value in the range of 0 to 63.
# Set the DSCP value to 63 for packets of EIGRP process 1 in EIGRP IPv4 address family view.
[Sysname] eigrp 1
[Sysname-eigrp-1-ipv4] dscp 63
eigrp
Use eigrp to create an EIGRP process and enter EIGRP view.
Use undo eigrp to delete an EIGRP process.
eigrp [ eigrp-as ] [ vpn-instance vpn-instance-name ]
undo eigrp eigrp-as
No EIGRP process is created.
eigrp-as: Specifies an AS number (process ID) for the EIGRP process, in the range of 1 to 65535. The default value is 1.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the EIGRP process runs on the public network.
# Create EIGRP process 1 and enter EIGRP view.
[Sysname] eigrp 1
[Sysname-eigrp-1]
eigrp metric
Use eigrp metric to configure metrics for an interface.
Use undo eigrp metric to restore the default.
eigrp eigrp-as metric { bandwidth bandwidth | delay delay | load load | reliability reliability } *
undo eigrp eigrp-as metric
No metric is configured for an interface.
Interface view
bandwidth: Specifies the bandwidth in the range of 1 to 4294967295 Kbps. The default value is the actual bandwidth of the interface.
delay: Specifies the delay in the range of 1 to 16777215 in 10 microseconds. The default value for this argument varies by device model.
load: Specifies the load in the range of 1 to 255. The default value is 255. A smaller value means an idler link.
reliability: Specifies the reliability value in the range of 1 to 255. The default value is 1. A smaller value means lower link reliability.
# On GigabitEthernet 1/0/1, configure the bandwidth, delay, load, and reliability values for EIGRP process 1 as 60, 100, 1, and 255, respectively.
[Sysname-GigabitEthernet1/0/1] eigrp 1 metric bandwidth 60 delay 10 load 1 reliability 255
metric weights
eigrp split-horizon
Use eigrp split-horizon to enable split horizon.
Use undo eigrp split-horizon to disable split horizon.
eigrp eigrp-as split-horizon
undo eigrp eigrp-as split-horizon
Split horizon is enabled.
Interface view
The split horizon feature prevents routing loops. As a best practice, do not disable split horizon unless it is necessary.
On Non-Broadcast Multi-Access (NBMA) networks, such as Frame Relay and X.25 where multiple virtual circuits are configured on the primary and secondary interfaces, disable split horizon to ensure correct route advertisement.
# Enable split horizon for EIGRP process 1 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] eigrp 1 split-horizon
eigrp timer hello
Use eigrp timer hello to set the hello timer for an interface.
Use undo eigrp timer hello to restore the default.
eigrp eigrp-as timer hello seconds
undo eigrp eigrp-as timer hello
The hello timer is 60 seconds for NBMA networks and 5 seconds for other networks.
Interface view
seconds: Specifies the hello timer in the range of 1 to 65535 seconds.
A smaller hello timer means a faster speed for detecting topology changes, which consumes more system resources. Set an appropriate hello timer based on your network condition.
As a best practice, set the hold timer to be at least three times the hello timer.
# Set the hello timer to 20 seconds for EIGRP process 1 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] eigrp 1 timer hello 20
eigrp timer hold
eigrp timer hold
Use eigrp timer hold to set the hold timer for an interface.
Use undo eigrp to restore the default.
eigrp eigrp-as timer hold seconds
undo eigrp eigrp-as timer hold
The hold timer is three times the hello timer.
Interface view
seconds: Specifies the hold timer in the range of 1 to 65535 seconds.
The router advertises the hold timer to the neighbor. If the neighbor receives no Hello packets from the local router within the hold time, it determines that the local router is invalid.
# Set the hold timer to 60 seconds for EIGRP process 1 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] eigrp 1 timer hold 60
eigrp timer hello
import-route
Use import-route to enable an EIGRP process to redistribute routes from other EIGRP processes or other routing protocols.
Use undo import-route to remove the configuration.
import-route bgp [ as-number ] [ allow-ibgp | metric min-bandwidth total-delay reliability load mtu | route-policy route-policy-name ] *
import-route { direct | static } [ metric min-bandwidth total-delay reliability load mtu | route-policy route-policy-name ] *
import-route eigrp [ eigrp-as | all-as ] [ allow-direct | metric min-bandwidth total-delay reliability load mtu | route-policy route-policy-name ] *
import-route { isis | ospf | rip } [ process-id | all-processes] [ allow-direct | metric min-bandwidth total-delay reliability load mtu | route-policy route-policy-name ] *
undo import-route { bgp | direct | eigrp [ eigrp-as | all-as ] | { isis | ospf | rip } [ process-id | all-processes ] | static }
Route redistribution is disabled.
bgp: Redistributes BGP routes.
direct: Redistributes direct routes.
static: Redistributes static routes.
eigrp: Redistributes EIGRP routes.
isis: Redistributes IS-IS routes.
rip: Redistributes RIP routes.
ospf: Redistributes OSPF routes.
as-number: Redistributes routes in an AS specified by its number in the range of 1 to 4294967295. If you do not specify this argument, the command redistributes all IPv4 EBGP routes. As a best practice, specify an AS number to prevent the system from redistributing excessive IPv4 EBGP routes.
eigrp-as: Specifies an EIGRP process by its AS number in the range of 1 to 65535. The default value is 1.
all-as: Specifies all EIGRP processes.
process-id: Specifies a process by its ID for IS-IS, OSPF, or RIP, in the range of 1 to 65535. The default value is 1.
all-processes: Redistributes routes from all the processes of IS-IS, OSPF, or RIP.
allow-ibgp: Redistributes IBGP routes.
allow-direct: Redistributes the networks of the local interfaces enabled with the EIGRP process. If you do not specify this keyword, the networks of the local interfaces are not redistributed.
metric: Configures metrics for redistributed routes.
mtu: Specifies the minimum MTU in the range of 1 to 1500 bytes.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
The import-route bgp command redistributes only EBGP routes. Because the import-route bgp allow-ibgp command redistributes both EBGP and IBGP routes and might cause routing loops, use it with caution.
Only active routes can be redistributed. To view route state information, use the display ip routing-table protocol command.
The undo import-route { isis | ospf | rip } all-processes command removes only the configuration made by the import-route { isis | ospf | rip } all-processes command. It does not remove the configuration made by the import-route { isis | ospf | rip } process-id command.
The undo import-route eigrp all-as command removes only the configuration made by the import-route eigrp all-as command. It does not remove the configuration made by the import-route eigrp eigrp-as command.
You can set the metric values used for composite route metric calculation in the import-route command. If you do not set the metric values, the settings in the default-metric command apply.
# Enable EIGRP process 100 to redistribute routes from OSPF process 10, and configure metrics for the redistributed routes.
[Sysname] eigrp 100
[Sysname-eigrp-100] address-family ipv4
[Sysname-eigrp-100-ipv4] import-route ospf 10 metric 100000 10 255 10 1500
default-metric
eigrp metric
maximum load-balancing
Use maximum load-balancing to set the maximum number of EIGRP ECMP routes.
Use undo maximum load-balancing to restore the default.
maximum load-balancing number
The maximum number of EIGRP ECMP routes equals the maximum number of ECMP routes supported by the system.
number: Specifies the maximum number of EIGRP ECMP routes. The value range for this argument is 1 to 32. Load sharing is not performed when the number is set to 1.
The value range for the number argument depends on the max-ecmp-num command. If you set the maximum number of ECMP routes to m by using the max-ecmp-num command and reboot the device, the number argument in the maximum load-balancing command is in the range of 1 to m.
# Set the maximum number of ECMP routes to 6 for EIGRP process 1.
[Sysname] eigrp 1
[Sysname-eigrp-1-ipv4] maximum load-balancing 6
max-ecmp-num
metric weights
Use metric weights to configure metric weights.
Use undo metric weights to restore the default.
metric weights K1 K2 K3 K4 K5
undo metric weights
The weights for metrics K1 through K5 are 1, 0, 1, 0, and 0, respectively.
K1: Specifies the weight for K1, in the range of 0 to 255.
K2: Specifies the weight for K2, in the range of 0 to 255.
K3: Specifies the weight for K3, in the range of 1 to 255.
K4: Specifies the weight for K4, in the range of 0 to 255.
K5: Specifies the weight for K5, in the range of 0 to 255.
EIGRP calculates the composite route metric based on the following metrics:
· Bandwidth—Minimum interface bandwidth on the path from the local router to the destination network.
· Delay—Sum of all interface delays on the path from the local router to the destination network.
· Reliability—Minimum interface reliability value on the path from the local router to the destination network.
· Load—Maximum interface load value on the path from the local router to the destination network.
· MTU—Minimum interface MTU on the path from the local router to the destination network.
EIGRP assigns each metric a weight for calculating the composite route metric. The calculation formula uses coefficients (K values) that correspond to the metrics as follows:
· K1—Bandwidth.
· K2—Load.
· K3—Delay.
· K4—Reliability.
· K5—MTU.
EIGRP calculates the composite route metric as follows:
· If K5 is equal to 0, the following formula applies:
Metric 1 = 256 × [K1 × Bandwidth + (K2 × Bandwidth) / (256 - Load) + K3 × Delay]
· If K5 is not equal to 0, Metric 1 is multiplied by another coefficient as follows:
Metric 2 = Metric 1 × [K5 / (Reliability + K4)]
In the formula: Bandwidth = 10000000 / Minimum interface bandwidth on the path.
# For EIGRP process 1, configure the weights for metrics K1 through K5 as 11, 22, 33, 44, and 55, respectively.
[Sysname] eigrp 1
[Sysname-eigrp-1-ipv4] metric weights 11 22 33 44 55
network
Use network to enable EIGRP on a network.
Use undo network to disable EIGRP on a network
undo network network-address [ wildcard-mask ]
EIGRP is disabled on a network.
network-address: Specifies a network by its IP address. You can specify the IP addresses of networks where the local interfaces reside.
wildcard-mask: Specifies the wildcard mask of the IP address. For example, the wildcard mask of mask 255.0.0.0 is 0.255.255.255. If you do not specify this argument, the natural mask applies.
This command allows you to enable EIGRP for a network. After that, only the interface attached to the network runs EIGRP.
# Enable EIGRP process 1 for the network 129.100.0.0.
[Sysname] eigrp 1
[Sysname-eigrp-1-ipv4] network 129.100.0.0
preference
Use preference to configure EIGRP route preferences.
Use undo preference to restore the default.
preference internal-preference external-preference
undo preference
The internal route preference is 90, and the external route preference is 170.
internal-preference: Specifies the internal route preference in the range of 1 to 255. The smaller the value, the higher the preference.
external-preference: Specifies the external route preference in the range of 1 to 255. The smaller the value, the higher the preference.
Routing protocols each have a default preference. If they find multiple routes destined for the same network, the route found by the routing protocol with the highest preference is selected as the optimal route.
This command allows you to configure the preference for internal routes learned from the same EIGRP process, and for external routes learned from other EIGRP processes or routing protocols.
# Configure the internal route preference and external route preference for EIGRP process 1 as 100 and 190, respectively.
[Sysname] eigrp 1
[Sysname-eigrp-1-ipv4] preference 100 190
reset eigrp peer
Use reset eigrp peer to clear EIGRP neighbor information.
reset eigrp [ eigrp-as ] peer [ interface interface-type interface-number | ip-address ] *
eigrp-as: Specifies an EIGRP process by its AS number in the range of 1 to 65535. If you do not specify this argument, the command clears neighbor information for all EIGRP processes.
ip-address: Specifies a neighbor by its IP address in dotted decimal notation.
If you do not specify the interface-type interface-number or ip-address argument, the command clears information about all neighbors for the specified or all EIGRP processes.
# Clear information about the neighbor with IP address 192.168.10.1 for EIGRP process 100.
<Sysname> reset eigrp 100 peer 192.168.10.1
reset eigrp process
Use reset eigrp process to restart the EIGRP IPv4 address family.
reset eigrp [ eigrp-as ] process address-family ipv4
eigrp-as: Specifies an EIGRP process by its AS number in the range of 1 to 65535. If you do not specify this argument, the command restarts the IPv4 address family for all EIGRP processes.
address-family ipv4: Specifies the IPv4 unicast address family.
This command clears information for the IPv4 address family of the specified EIGRP process, including neighbor information and routing information. Executing the command will terminate and then reestablish the neighbor relationship.
# Restart the IPv4 address family for EIGRP process 100.
<Sysname> reset eigrp 100 process address-family ipv4
reset eigrp statistics
Use reset eigrp statistics to clear EIGRP statistics.
reset eigrp [ eigrp-as ] statistics
eigrp-as: Specifies an EIGRP process by its AS number in the range of 1 to 65535. If you do not specify this argument, the command clears statistics for all EIGRP processes.
# Clear statistics for EIGRP process 100.
<Sysname> reset eigrp 100 statistics
router-id
Use router-id to configure the router ID for an EIGRP process.
Use undo router-id to restore the default.
router-id router-id
undo router-id
No router ID is configured for an EIGRP process. The global router ID is used.
router-id: Specifies the router ID in IPv4 address format. The router ID cannot be 0.0.0.0 or 255.255.255.255.
CAUTION: Changing the router ID for an EIGRP process will reset the neighbor relationship. |
EIGRP uses a router ID to uniquely identify an advertising router in an autonomous system. If a router receives a route containing the router ID of the local router, it discards the route.
As a best practice, to enhance network availability, specify the IP address of a loopback interface as the router ID.
# Configure the router ID for EIGRP process 1 as 10.1.1.3.
[Sysname] eigrp 1
[Sysname-eigrp-ipv4] router-id 10.1.1.3
summary automatic
Use summary automatic to enable automatic route summarization.
Use undo summary automatic to disable automatic route summarization.
summary automatic
Automatic route summarization is disabled.
This command summarizes contiguous networks into a single network with natural mask and advertises the network to neighbors. Route summarization reduces the number of exchanged routes and the routing table size, and improves network scalability and router performance.
To advertise the specific routes that have been summarized, use the undo summary automatic command.
# Enable automatic route summarization for the IPv4 address family of EIGRP process 1.
[Sysname] eigrp 1
[Sysname-eigrp-1-ipv4] summary automatic
timers active-time
Use timers active-time to set the convergence wait timer.
Use undo timers active-time to restore the default.
timers active-time { time-limit | disable }
The convergence wait timer is 3 minutes.
time-limit: Specifies the convergence wait timer in the range of 1 to 65535 minutes.
disable: Sets no time limit for route convergence.
If a route in the topology table enters the Active state and fails to be converged within the convergence wait time, it gets stuck in the active (SIA) state. The router no longer waits for replies from neighbors, and terminates the relationship with the neighbors that have not responded.
The disable keyword means setting no time limit for route convergence. Typically, as a best practice, do not specify this keyword.
# Set the convergence wait timer to 10 minutes for EIGRP process 1 in EIGRP IPv4 address family view.
[Sysname] eigrp 1
[Sysname-eigrp-1-ipv4] timers active-time 10
timers graceful-restart purge-time
Use timers graceful-restart purge-time to set the aging timer for routes on the GR helper.
Use undo timers graceful-restart purge-time to restore the default.
timers graceful-restart purge-time seconds
The aging timer is 240 seconds for routes on a GR helper.
seconds: Specifies the aging timer in the range of 20 to 300 seconds.
# Set the aging timer to 100 seconds for routes on the GR helper in EIGRP process 1.
[Sysname] eigrp 1
[Sysname-eigrp-1-ipv4] timers graceful-restart purge-time 100
