- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-Emergency shell commands
- 09-Automatic configuration commands
- 10-Device management commands
- 11-Tcl commands
- 12-Python commands
- 13-License management commands
- 14-RAID management commands
10-Device management commands | 397.66 KB |
bluetooth disable
Use bluetooth disable to disable Bluetooth.
Use undo bluetooth disable to enable Bluetooth.
bluetooth disable
The following matrixes show the command and hardware compatibility:
Hardware |
Command compatibility |
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK |
Yes |
MSR810-LM-HK, MSR810-W-LM-HK |
No |
MSR810-LMS, MSR810-LUS |
No |
MSR810-LMS-EA, MSR810-LME |
Yes |
MSR2600-6-X1 |
No |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
No |
No |
No |
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD |
Yes |
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC |
Yes |
MSR 3610, MSR 3620, MSR 3640, MSR 3660 |
No |
MSR3620-DP |
Yes |
MSR3610-G, MSR3620-G |
No |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
MSR830-5BEI-WiNet, MSR830-10BEI-WiNet |
Yes |
MSR830-6EI-WiNet |
No |
Yes |
MSR2600-6-WiNet |
No |
MSR2600-10-X1-WiNet |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-WiNet, MSR3660-WiNet |
No |
MSR3620-DP-WiNet |
Yes |
Hardware |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR2600-6-X1-GL |
No |
MSR3600-28-SI-GL |
No |
Bluetooth is enabled.
The MSR Bluetooth module supports serial port transparent transmission. You can use it as a wireless console port. By using an application on your phone to connect to the Bluetooth module on the device, you can implement remote device deployment, configuration, and management. For example, you can deploy a basic configuration on the device before shipping the device to customers so the device can log in to the Oasis platform. Then, you can manage the device through the Oasis platform.
After completing device deployment, you can disable Bluetooth to protect the device against illegal access.
After you disable Bluebooth, you must save the running configuration and reboot the device to make the setting take effect.
# Disable Bluetooth.
[Sysname] bluetooth disable
card-mode
Use card-mode to set the operating mode for an interface module.
In standalone mode:
card-mode slot slot-number mode-name
In IRF mode:
card-mode slot slot-number subslot subslot-number mode-name
The following compatibility matrixes show the support of hardware platforms for this command:
Hardware |
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK |
No |
No |
No |
MSR2600-6-X1, MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
MSR2600-6-WiNet, MSR2600-10-X1-WiNet |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
Yes |
The default varies by interface module model.
slot slot-number: Specifies a subcard by its slot number. (In standalone mode.)
slot slot-number: Specifies an IRF member device by its member ID. (In IRF mode.)
subslot subslot-number: Specifies a subcard by its subslot number.
mode-name: Specifies an operating mode. Available operating modes depend on the interface module type. The following shows all operating mode values:
· atm: Specifies the ATM mode. All interfaces on the interface module act as ATM interfaces.
· auto: Specifies the auto negotiation mode. The interface module operates in ATM or EFM mode, depending on the negotiation result.
· e: Specifies the E mode. All interfaces on the interface module act as CPOS E3-E1 interfaces.
· e1: Specifies the E1 mode. All interfaces on the interface module act as CPOS E1 interfaces.
· e3: Specifies the E3 mode. All interfaces on the interface module act as CPOS E3 interfaces.
· e-cpos: Specifies the E-CPOS mode. All interfaces on the interface module act as 2.5 Gbps CPOS interfaces.
· efm: Specifies the EFM mode. All interfaces on the interface module act as EFM interfaces.
· ipsec: Specifies the IPsec mode.
· oc-12: Specifies the OC-12c/STM-4c mode (622 Mbps). All interfaces on the interface module act as 622 Mbps CPOS interfaces.
· oc-12-atm: Specifies the oc-12-atm mode. All interfaces on the interface module act as ATM OC-12c/STM-4 interfaces and use SONET/SDH for data transmission.
· oc-12-pos: Specifies the oc-12-pos mode. All interfaces on the interface module act as 622 Mbps POS interfaces.
· oc-3: Specifies the OC-3c/STM-1c mode (155 Mbps). All interfaces on the interface module act as 155 Mbps CPOS interfaces.
· oc-3-atm: Specifies the oc-3-atm mode. All interfaces on the interface module act as ATM OC-3c/STM-1 interfaces and use SONET/SDH for data transmission.
· oc-3-pos: Specifies the oc-3-pos mode. All interfaces on the interface module act as 155 Mbps POS interfaces.
· pos: Specifies the POS mode. All interfaces on the interface module act as 2.5 Gbps POS interfaces.
· ssl: Specifies the SSL mode.
· t: Specifies the T mode. All interfaces on the interface module act as CPOS T3-T1 interfaces.
· t1: Specifies the T1 mode. All interfaces on the interface module act as CPOS T1 interfaces.
· t3: Specifies the T3 mode. All interfaces on the interface module act as CPOS T3 interfaces.
For an operating mode change to take effect, you must perform one of the following tasks:
· Restart the device.
· Hot swap the interface module if the interface module supports hot swapping.
For more information about interface types, see Interface Configuration Guide.
# (In standalone mode.) Set the operating mode to E1 for an interface module.
[Sysname] card-mode slot 2 e1
Please reboot or hot-swap the board or card (if supported) to make the configuration take effect.
# (In IRF mode.) Set the operating mode to E1 for a subcard.
[Sysname] card-mode slot 2 subslot 1 e1
clock datetime
Use clock datetime to set the system time.
clock datetime time date
The system time is UTC time 00:00:00 01/01/2011.
time: Specifies a time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
date: Specifies a date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
Correct system time is essential to network management and communication. You must configure the system time correctly before you run the device on the network.
For the device to use the local system time, execute the clock protocol none command and this command in turn. The specified system time takes effect immediately. Then, the device uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
# Set the system time to 08:08:08 01/01/2015.
<Sysname> clock datetime 8:8:8 1/1/2015
# Set the system time to 08:10:00 01/01/2015.
<Sysname> clock datetime 8:10 2015/1/1
clock protocol
clock summer-time
clock timezone
display clock
clock protocol
Use clock protocol to specify the system time source.
Use undo clock protocol to restore the default.
clock protocol { controller cellular cellular-number | none | ntp }
undo clock protocol
The device obtains the UTC time from an NTP time source.
controller cellular cellular-number: Obtains the UTC time through a cellular interface.
none: Uses the system time set by using the clock datetime command.
ntp: Uses NTP to obtain the UTC time. You must configure NTP correctly. For more information about NTP and NTP configuration, see Network Management and Monitoring Configuration Guide.
The device can use the locally set system time, or obtain the UTC time from a time source on the network and calculate the system time.
If you configure the clock protocol none command, the device uses the locally set system time. The device then uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
If you configure the clock protocol ntp command, the device obtains the UTC time through NTP and calculates the system time. The device then periodically synchronizes the UTC time and recalculates the system time.
If you configure the clock protocol controller cellular cellular-number command, the device obtains the UTC time through the specified cellular interface and the connected 3G or 4G modem. If the cellular interface is not in position or not activated, the device uses NTP instead. After the cellular interface operates correctly, the device obtains the UTC time again through the cellular interface.
# Configure the device to use the local UTC time.
[Sysname] clock protocol none
clock summer-time
Use clock summer-time to set the daylight saving time.
Use undo clock summer-time to restore the default.
The daylight saving time is not set.
name: Specifies a name for the daylight saving time schedule, a case-sensitive string of 1 to 32 characters.
start-time: Specifies the start time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
start-date: Specifies the start date in one of the following formats:
· MM/DD. The value range for MM is 1 to 12. The value range for DD varies by month.
· month week day, where:
¡ month—Takes January, February, March, April, May, June, July, August, September, October, November or December.
¡ week—Represents week of the month. It takes first, second, third, fourth, fifth, or last.
¡ day—Takes Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, or Saturday.
end-time: Specifies the end time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
end-date: Specifies the end date in one of the following formats:
add-time: Specifies the time to be added to the standard time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the daylight saving time, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same daylight saving time as the local time.
# Set the system time ahead 1 hour for the period between 06:00:00 on 08/01 and 06:00:00 on 09/01.
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
clock datetime
clock timezone
display clock
clock timezone
Use clock timezone to set the time zone.
Use undo clock timezone to restore the default.
undo clock timezone
The UTC time zone is used.
zone-name: Specifies a time zone by its name, a case-sensitive string of 1 to 32 characters.
add: Adds an offset to the UTC time.
minus: Decreases the UTC time by an offset.
zone-offset: Specifies an offset to the UTC time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the time zone, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same time zone as the local time.
# Set the name of the time zone to Z5, and add 5 hours to the UTC time.
[Sysname] clock timezone Z5 add 5
clock datetime
clock summer-time
display clock
command
Use command to assign a command to a job.
Use undo command to revoke a command.
command id command
undo command id
No command is assigned to a job.
Job view
id: Specifies an ID for the command, in the range of 0 to 4294967295. A command ID uniquely identifies a command in a job. Commands in a job are executed in ascending order of their command IDs.
command: Specifies the command to be assigned to the job.
To assign a command (command A) to a job, you must first assign the job the command or commands for entering the view of command A.
If you specify the ID of an existing command for another command, the existing command is replaced.
Make sure all commands in a schedule are compliant to the command syntax. The system does not examine the syntax when you assign a command to a job.
If a command requires a yes or no answer, the system always assumes that a Y or Yes is entered. If a command requires a character string input, the system assumes that either the default character string (if any) or a null string is entered.
A job cannot contain the telnet, ftp, ssh2, or monitor process command.
# Assign commands to the backupconfig job to back up the startup.cfg file to the TFTP server at 192.168.100.11.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# Assign commands to the shutdownGE job to shut down GigabitEthernet 1/0/1.
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface gigabitethernet 1/0/1
[Sysname-job-shutdownGE] command 3 shutdown
scheduler job
copyright-info enable
Use copyright-info enable to enable copyright statement display.
Use undo copyright-info enable to disable copyright statement display.
Copyright statement display is enabled.
# Enable copyright statement display.
[Sysname] copyright-info enable
The device will display the following statement when a user logs in:
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
display alarm
Use display alarm to display alarm information.
In standalone mode:
display alarm [ slot slot-number ]
In IRF mode:
slot slot-number: Specifies the entire device. The value is fixed at 0. (In standalone mode.)
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays alarm information for all IRF member devices. (In IRF mode.)
# (In standalone mode.) Display alarm information.
<Sysname> display alarm
Slot CPU Level Info
0 0 ERROR faulty
Slot |
The value of this field is fixed at 0. |
Level |
Alarm severity. Possible values include ERROR, WARNING, NOTICE, and INFO, in descending order. |
Info |
Detailed alarm information: · faulty—The card is starting up or faulty. · Fan n is absent—The specified fan is absent. |
# (In IRF mode.) Display alarm information.
Slot CPU Level Info
1 0 ERROR faulty
Slot |
Slot that generated the alarm. If the alarm was generated by the frame, this field displays a hyphen (-). |
Level |
Info |
Detailed alarm information: · faulty—The slot is starting up or faulty. · Fan n is absent—The specified fan is absent. · Power n is absent—The specified power supply is absent. · Power n is faulty—The specified power supply is faulty. · The temperature of sensor n exceeds the lower limit—The temperature of the specified sensor is lower than the low-temperature threshold. · The temperature of sensor n exceeds the upper limit—The temperature of the specified sensor is higher than the high-temperature warning threshold. |
display clock
Use display clock to display the system time, date, time zone, and daylight saving time.
display clock
# Display the system time and date when the time zone is not specified.
<Sysname> display clock
10:09:00.258 UTC Fri 03/16/2015
The time is in the hour:minute:second.milliseconds format.
# Display the system time and date when the time zone Z5 is specified.
15:10:00.152 Z5 Fri 03/16/2015
Time Zone : Z5 add 05:00:00
# Display the system time and date when the time zone Z5 and daylight saving time PDT are specified.
15:11:00.211 Z5 Fri 03/16/2015
clock datetime
clock timezone
clock summer-time
display copyright
Use display copyright to display the copyright statement.
# Display the copyright statement.
display cpu-usage
Use display cpu-usage to display the current CPU usage statistics.
In standalone mode:
display cpu-usage [ summary ] [ cpu cpu-number [ core { core-number | all } ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ]
In IRF mode:
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ] [ slot slot-number [ cpu cpu-number ] ]
control-plane: Displays CPU usage statistics for the control plane. If you do not specify this keyword or the data-plane keyword, the command displays the total CPU usage statistics.
data-plane: Displays CPU usage statistics for the data plane. If you do not specify this keyword or the control-plane keyword, the command displays the total CPU usage statistics.
summary: Displays CPU usage statistics in table form. If you do not specify this keyword, the command displays CPU usage statistics in text form.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays CPU usage statistics for all member devices. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number.
core { core-number | all }: Displays CPU core usage statistics. If you specify a CPU core by its number, this command displays usage statistics for the CPU core. If you specify the all keyword, this command displays average usage statistics for all CPU cores.
# (In standalone mode.) Display the current CPU usage statistics in text form.
<Sysname> display cpu-usage
CPU usage:
1% in last 5 seconds
1% in last 1 minute
1% in last 5 minutes
# (In standalone mode.) Display the current CPU usage statistics in table form.
CPU Last 5 sec Last 1 min Last 5 min
0 2% 2% 10%
# (In IRF mode.) Display the current CPU usage statistics in text form.
Slot 1 CPU 0 CPU usage:
1% in last 1 minute
# (In IRF mode.) Display the current CPU usage statistics in table form.
Slot CPU Last 5 sec Last 1 min Last 5 min
1 0 17% 29% 28%
x% in last 5 seconds Last 5 sec |
Average CPU usage during the most recent 5-second interval. |
y% in last 1 minute Last 1 min |
Average CPU usage during the most recent 1-minute interval. |
z% in last 5 minutes Last 5 min |
Average CPU usage during the most recent 5-minute interval. |
display cpu-usage configuration
Use display cpu-usage configuration to display CPU usage monitoring settings.
In standalone mode:
In IRF mode:
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the CPU usage monitoring settings for the master device. (In IRF mode.)
# Display the CPU usage monitoring settings.
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current monitor threshold is 99%.
Current statistics-interval is 60 seconds for the following cores: 0 to 1.
CPU usage monitor is xxx. |
Whether CPU usage tracking is enabled. |
Current monitor interval is xxx. |
Sampling interval for CPU usage tracking. |
Current monitor threshold is xxx. |
CPU usage threshold. |
Current statistics interval is xxx seconds for the following cores |
CPU core usage statistics interval. |
monitor cpu-usage enable
monitor cpu-usage interval
monitor cpu-usage threshold
display cpu-usage history
Use display cpu-usage history to display the historical CPU usage statistics in a coordinate system.
In standalone mode:
display cpu-usage history [ job job-id ]
In IRF mode:
job job-id: Specifies a process by its ID. The value range for job-id is 1 to 2147483647. If you do not specify a process, this command displays the statistics for the entire system's CPU usage (the total CPU usage of all processes). To view the IDs and names of the running processes, use the display process command. For more information, see Network Management and Monitoring Configuration Guide.
slot slot-number: Specifies an IRF member device by its member ID. If you specify a process but do not specify a member device, this command displays the statistics for the process on the master device. If you do not specify any options, this command displays the statistics for all processes on all member devices. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. If you specify a process but do not specify a CPU, this command displays the statistics for the default CPU. If you do not specify a process or CPU, this command displays the historical statistics for all CPUs.
After CPU usage monitoring is enabled, the system regularly samples CPU usage and saves the samples to the history record buffer. This command displays the most recent 60 samples in a coordinate system as follows:
The vertical axis represents the CPU usage. If a statistic is not a multiple of the usage step, it is rounded up or down to the closest multiple of the usage step. For example, if the CPU usage step is 5%, the statistic 53% is rounded up to 55%, and the statistic 52% is rounded down to 50%.
The horizontal axis represents the time.
Pound signs (#) indicate the CPU usage. The value on the vertical axis for the topmost pound sign at a specific time represents the CPU usage at that time.
# (In standalone mode.) Display the historical CPU usage statistics.
<Sysname> display cpu-usage history
100%|
95%|
90%|
85%|
80%|
75%|
70%|
65%|
60%|
55%|
50%|
45%|
40%|
35%|
30%|
25%|
20%|
15%| #
10%| ### #
5%| ########
10 20 30 40 50 60 (minutes)
cpu-usage last 60 minutes (SYSTEM)
The output shows the following items:
· Process name. The name SYSTEM represents the entire system.
· Historical CPU usage statistics for the entire system during the last 60 minutes.
¡ 12 minutes ago—Approximately 5%.
¡ 13 minutes ago—Approximately 10%.
¡ 14 minutes ago—Approximately 15%.
¡ 15 minutes ago—Approximately 10%.
¡ 16 and 17 minutes ago—Approximately 5%.
¡ 18 minutes ago—Approximately 10%.
¡ 19 minutes ago—Approximately 5%.
¡ Other time—2% or lower.
# (In IRF mode.) Display the historical CPU usage statistics.
100%|
95%|
90%|
85%|
80%|
75%|
70%|
65%|
60%|
55%|
50%|
45%|
40%|
35%|
30%|
25%|
20%|
15%| #
10%| ### #
5%| ########
cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
· CPU that is holding the process: CPU 0 in slot 1.
display device
Use display device to display device information.
In standalone mode:
display device [ cf-card | harddisk | sd-card | usb ] [ verbose ]
In IRF mode:
display device [ cf-card | harddisk | sd-card | usb ] [ slot slot-number | verbose ]
cf-card: Displays CF card information.
The following compatibility matrixes show the support of hardware platforms for this keyword:
Hardware |
Parameter compatibility |
No |
No |
No |
No |
MSR 2630 |
No |
No |
No |
No |
No |
No |
Yes |
No |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
No |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
No |
Yes |
Hardware |
MSR2630-XS |
No |
MSR3600-28-XS |
No |
MSR3610-XS |
No |
MSR3620-XS |
Yes |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR2600-6-X1-GL |
No |
MSR3600-28-SI-GL |
No |
harddisk: Displays hard disk information.
Hardware |
No |
No |
No |
No |
MSR 2630 |
No |
No |
No |
No |
Yes |
Yes |
No |
No |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
No |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
No |
Hardware |
MSR2630-XS |
No |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
No |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR2600-6-X1-GL |
No |
MSR3600-28-SI-GL |
No |
sd-card: Displays SD card information.
Hardware |
Yes |
Yes |
Yes |
No |
MSR 2630 |
No |
No |
No |
No |
Yes |
Yes |
Yes |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
No |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR2630-XS |
No |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR2600-6-X1-GL |
No |
MSR3600-28-SI-GL |
No |
usb: Displays USB interface information.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for all member devices. (In IRF mode.)
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information, and does not display firewall card information.
(In standalone mode.) If you do not specify the cf-card, harddisk, sd-card, or usbkeyword, this command displays information about the device.
(In IRF mode.) If you do not specify the cf-card, harddisk, sd-card, or usb keyword, this command displays information about member devices.
# (In standalone mode.) Display device information.
<Sysname> display device
Slot No. Board Type Status Max Ports
0 RPU Normal 6
Table 5 Command output
Board Type |
Hardware type of the device. |
Status |
Device status: · Illegal—The device is not operating correctly. · Normal—The device is operating correctly. |
Max Ports |
Maximum number of physical ports that the device supports. |
# (In IRF mode.) Display device information.
0 RPU Normal 6
5 HMIM-8GSW Normal 8
10 VPM-256 Normal 1
Table 6 Command output
Board Type |
Hardware type. |
Status |
Status of the device: · Illegal—The device is not operating correctly. · Normal—The device is operating correctly. |
Max Ports |
Number of physical ports on the device. |
display device manuinfo
Use display device manuinfo to display electronic label information for the device.
In standalone mode:
In IRF mode:
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays electronic label information for all member devices. (In IRF mode.)
An electronic label contains the permanent configuration information, including the hardware serial number, manufacturing date, MAC address, and vendor name. The data is written to the storage component during hardware debugging or testing. This command displays only part of the electronic label information.
# (In standalone mode.) Display electronic label information for the device.
<Sysname> display device manuinfo
Slot 0:
DEVICE_NAME : MSR810
DEVICE_SERIAL_NUMBER : 219801A0SAA12C000008
MAC_ADDRESS : 000F-E212-3215
MANUFACTURING_DATE : 2014-12-30
VENDOR_NAME : H3C
PRODUCT ID : RT-MSR810-LM-WiNet
# (In IRF mode.) Display electronic label information for the device.
Slot 0:
DEVICE_NAME : MSR 36-40
DEVICE_SERIAL_NUMBER : 210235A0W8B133000041
MAC_ADDRESS : 0CDA-41B2-1E31
MANUFACTURING_DATE : 2013-03-06
VENDOR_NAME : H3C
Slot 5:
DEVICE_NAME : RT-HMIM-8GSW
DEVICE_SERIAL_NUMBER : 210231A2MP0137000006
MAC_ADDRESS : 000E-FA00-0001
MANUFACTURING_DATE : 2013-07-16
VENDOR_NAME : H3C
PRODUCT ID : RT-HMIM-8GSW
Slot 10:
DEVICE_NAME : RT-VPM2-256
DEVICE_SERIAL_NUMBER : 210231A1V7B12B000013
MAC_ADDRESS : NONE
MANUFACTURING_DATE : 2012-11-21
VENDOR_NAME : H3C
PRODUCT ID : RT-VPM2-256
display diagnostic-information
Use display diagnostic-information to display or save operating information for features and hardware modules.
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ key-info ] [ filename ]
hardware: Specifies hardware-related operating information.
infrastructure: Specifies operating information for the fundamental features.
l2: Specifies operating information for the Layer 2 features.
l3: Specifies operating information for the Layer 3 features.
service: Specifies operating information for Layer 4 and upper-layer features.
key-info: Displays or saves only critical operating information. The device might have a large amount of operating information if an exception occurs or after the device runs for a long period of time. Specifying this keyword reduces the command execution time and helps you focus on critical operating information. If you do not specify this keyword, the command displays or saves both critical and non-critical operating information.
filename: Saves the information to a file. The filename argument must use the .tar.gz extension. If you do not specify this argument, the command prompts you to choose whether to save the information to a file or display the information.
You can use one of the following methods to collect operating statistics for diagnostics and troubleshooting:
· Use separate display commands to collect operating information feature by feature or module by module.
· Use the display diagnostic-information command to collect operating information for multiple or all features and hardware modules.
To save storage space, this command automatically compresses the information before saving the information to a file. To view the file content:
1. Use the tar extract command to extract the file.
2. Use the gunzip command to decompress the extracted file.
3. Use the more command to view the content of the decompressed file.
If you abort the display diagnostic-information command, the gunzip command might not be able to decompress the extracted file. To decompress the extracted file, export the extracted file to a PC that is running Linux, and use the gunzip -c command.
If you do not specify a file name for the command, the system prompts you to choose whether to display or save the information. If you choose to save the information, the system automatically assigns a file name and displays the file name in brackets. For file name uniqueness, the file name includes the device name and the current system time. If the device name contains any of the following special characters, the system uses an underscore (_) to replace each special character: forward slashes (/), backward slashes (\), colons (:), asterisks (*), question marks (?), less than signs (<), greater than signs (>), pipeline signs (|), and quotation marks ("). For example, device name A/B will change to A_B in the file name, as in flash:/diag_A_B_20160101-000438.tar.gz.
If you do not specify any feature parameters, this command displays or saves the operating information for all features and modules.
This command does not support the |, >, and >> options.
While the device is executing this command, do not execute any other commands. Executing other commands might affect the collected operating information.
# Display the operating information for all features and modules.
14:03:55 UTC Thu 01/05/2015
# Save the operating information to the default file.
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20160101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20160101-024601.tar.gz.
Please wait...
Save successfully.
Press Enter when the system prompts you to enter the file name.
# Save the operating information for all features and modules to file test.tar.gz.
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
gunzip
more
tar extract
display environment
Use display environment to display temperature information.
In standalone mode:
display environment
In IRF mode:
Hardware |
No |
No |
No |
Yes |
MSR 2630 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
Yes |
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays temperature information for all member devices. (In IRF mode.)
# (In standalone mode.) Display information about all temperature sensors on the device.
<Sysname> display environment
Slot Subslot Sensor ID Temperature LowerLimit WarningLimit AlarmLimit
0 0 inflow 1 37 -7 53 61
0 0 hotspot 1 41 0 57 65
# (In IRF mode.) Display information about all temperature sensors on the device.
1 0 inflow 1 46 0 58 65
1 0 hotspot 1 52 0 65 75
Table 7 Command output
sensor |
Temperature sensor: · hotspot—Hotspot sensor. · inflow—Air inlet sensor. |
Slot |
Sensor position. |
Temperature |
Current temperature. |
LowerLimit |
Low-temperature threshold. If the device does not support this field, this field displays NA. |
WarningLimit |
High-temperature warning threshold. If the device does not support this field, this field displays NA. |
AlarmLimit |
High-temperature alarming threshold. If the device does not support this field, this field displays NA. |
display fan
Use display fan to display fan tray operating status information.
In standalone mode:
display fan [ fan-id ]
In IRF mode:
display fan [ slot slot-number [ fan-id ] ]
Hardware |
No |
No |
No |
Yes |
MSR 2630 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
Yes |
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays fan tray operating status information for all member devices. (In IRF mode.)
fan-id: Specifies a fan tray by its ID. If you do not specify a fan tray, this command displays operating status information for all fan trays at the specified position.
# Display the operating status of all fan trays.
<Sysname> display fan
Index Status Speedlevel
1 Normal 2
Table 8 Command output
Status |
Fan tray status: · Absent—The slot is not installed with a fan tray. · Fault—The fan tray is faulty. · Normal—The fan tray is operating correctly. · FanDirectionFault—The actual airflow direction is not the preferred direction. |
Speedlevel |
Fan speed level. |
display memory
Use display memory to display memory usage information.
In standalone mode:
display memory [ summary ]
In IRF mode:
summary: Displays brief information about memory usage. If you do not specify this keyword, the command displays detailed information about memory usage.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays memory usage for all member devices. (In IRF mode.)
# (In standalone mode.) Display detailed memory usage information.
<Sysname> display memory
Memory statistics are measured in KB:
Total Used Free Shared Buffers Cached FreeRatio
Mem: 507980 154896 353084 0 488 54488 69.5%
-/+ Buffers/Cache: 99920 408060
Swap: 0 0 0
# (In standalone mode.) Display brief memory usage information.
<Sysname> display memory summary
CPU Total Used Free Buffers Caches FreeRatio
0 1029476 325012 704464 2404 143008 68.4%
# (In IRF mode.) Display detailed memory usage information.
Slot 1:
Mem: 984560 456128 528432 0 4 45616 53.7%
-/+ Buffers/Cache: 410508 574052
Swap: 0 0 0
# (In IRF mode.) Display brief memory usage information.
Slot CPU Total Used Free Buffers Caches FreeRatio
1 0 984560 456128 528432 4 45616 53.7%
Table 9 Command output
Mem |
Memory usage information. |
Total |
Total size of the physical memory space that can be allocated. The memory space is virtually divided into two parts. Part 1 is solely used for functions. Part 2 can be allocated and used for such tasks as running service modules and storing files. The size of part 2 equals the total size minus the size of part 1. |
Used |
Used physical memory. |
Free |
Free physical memory. |
Shared |
Physical memory shared by processes. If this field is not supported, two hyphens (--) are displayed. |
Buffers |
Physical memory used for buffers. If this field is not supported, two hyphens (--) are displayed. |
Cached Caches |
Physical memory used for caches. If this field is not supported, two hyphens (--) are displayed. |
FreeRatio |
Free memory ratio. |
-/+ Buffers/Cache |
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications. -/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications. |
Swap |
Memory space for swapping. |
display memory-threshold
Use display memory-threshold to display memory alarm thresholds and statistics.
In standalone mode:
In IRF mode:
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the memory usage thresholds and statistics for the master device. (In IRF mode.)
For more information about memory usage notifications, see log information containing MEM_EXCEED_THRESHOLD or MEM_BELOW_THRESHOLD.
# Display memory alarm thresholds and statistics.
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory threshold:
Minor: 224M
Severe: 128M
Critical: 96M
Normal: 256M
Current memory state: Normal
Event statistics:
[Back to normal state]
First notification: 0.0
Latest notification: 0.0
Total number of notifications sent: 0
[Enter minor low-memory state]
First notification at: 0.0
Latest notification at: 0.0
[Back to minor low-memory state]
[Enter severe low-memory state]
[Back to severe low-memory state]
[Enter critical low-memory state]
display power
Use display power to display power supply information.
In standalone mode:
display power [ verbose ]
In IRF mode:
display power [ slot slot-number [ verbose ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays power supply information for all member devices. (In IRF mode.)
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information.
# Display brief power supply information.
<Sysname> display power
Index Status
PWR1 normal
PWR2 normal
Table 10 Command output
Index |
Power supply ID. |
Status |
Power supply status: · absent—The slot is not installed with a power supply. · fail—The power supply is faulty. · normal—The power supply is operating correctly. |
# (In standalone mode.) Display detailed power supply information.
<Sysname> display power verbose
Index Status Type Description
PWR1 normal AC PSR300-12A1
PWR2 absent
Table 11 Command output
Index |
Power supply ID. |
Status |
Type |
Type of the power supply: · AC—AC power supply. · DC—DC power supply. |
Description for the power supply. |
display power-supply
Use display power-supply to display power supply management information.
In standalone mode:
display power-supply [ verbose ]
In IRF mode:
display power-supply [ slot slot-number ] [ verbose ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays power supply management information for all member devices. (In IRF mode.)
verbose: Displays detailed power supply management information. If you do not specify this keyword, this command displays the brief information.
# Display power supply information.
<Sysname> display power-supply
Index Status
PWR1 normal
PWR2 normal
display scheduler job
Use display scheduler job to display job configuration information.
job-name: Specifies a job by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a job, this command displays configuration information for all jobs.
# Display configuration information for all jobs.
<Sysname> display scheduler job
Job name: saveconfig
copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
vlan 100
// The output shows that the device has three jobs: the first has one command, the second does not have any commands, and the third has two commands. Jobs are separated by blank lines.
display scheduler logfile
Use display scheduler logfile to display job execution log information.
# Display job execution log information.
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name : shutdown
Schedule name : shutdown
Execution time : Tue Dec 27 10:44:42 2015
Completion time : Tue Dec 27 10:44:47 2015
<Sysname>system-view
[Sysname]interface rang gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[Sysname-if-range]shutdown
Table 12 Command output
Logfile Size |
Size of the log file, in bytes. |
Schedule name |
Schedule to which the job belongs. |
Execution time |
Time when the job was started. |
Completion time |
Time when the job was completed. If the job has never been executed or the job does not have any commands, this field is blank. |
Job output |
Commands in the job and their output. |
reset scheduler logfile
display scheduler reboot
Use display scheduler reboot to display the automatic reboot schedule.
# Display the automatic reboot schedule.
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2015 (in 1 hours and 39 minutes).
scheduler reboot at
scheduler reboot delay
display scheduler schedule
Use display scheduler schedule to display schedule information.
schedule-name: Specifies a schedule by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a schedule, this command displays information about all schedules.
# Display information about all schedules.
<Sysname> display scheduler schedule
Schedule type : Run once after 0 hours 2 minutes
Start time : Tue Dec 27 10:44:42 2015
Last execution time : Tue Dec 27 10:44:42 2015
Last completion time : Tue Dec 27 10:44:47 2015
Execution counts : 1
Job name Last execution status
shutdown Successful
Table 13 Command output
Schedule type |
Execution time setting of the schedule. If no execution time is specified, this field is not displayed. |
Start time |
Time to execute the schedule for the first time. If no execution time is specified, this field is not displayed. |
Last execution time |
Last time when the schedule was executed. If no execution time is specified, this field is not displayed. If the schedule has never been executed, "Yet to be executed" is displayed for this field. |
Last completion time |
Last time when the schedule was completed. If no execution time is specified, this field is not displayed. |
Execution counts |
Number of times the schedule has been executed. If the schedule has never been executed, this field is not displayed. |
Job name |
Name of a job under the schedule. |
Last execution status |
Result of the most recent execution: · Successful. · Failed. · Waiting—The device is executing the schedule and the job is waiting to be executed. · In process—The job is being executed. · -NA-—The execution time has not arrived yet. To view information about whether the commands in the job has been executed and the execution results, execute the display scheduler logfile command. |
display system stable state
Use display system stable state to display system stability and status information.
Before executing an install command or performing a switchover, execute this command multiple times to identify whether the system is operating stably. If the value of the System State field is not Stable, you cannot execute an install command. If the value of the Redundancy Stable field is not Stable, you cannot perform a switchover.
The device startup process takes some time. If the values of the status fields do not change to Stable, execute this command multiple times to identify the members that are not in Stable state. You can also use other commands to identify the faulty components. For example:
· Use the display device command to identify the device operating status.
· Use the display ha service-group command to display the status of HA service groups and identify the groups in batch backup state.
· Use the display system internal process state command in probe view to display service operating status.
# (In standalone mode.) Display system stability and status information.
<Sysname> display system stable state
System state : Stable
Role State
Active Stable
Table 14 Command output
System state |
This field displays Stable if the system is operating stably. |
Role |
Device role. The value of this field is fixed at Active. |
State |
Device status: Stable—The device is operating stably. |
The object is not operating stably. |
# (In IRF mode.) Display system stability and status information.
Redundancy state: No redundance
Slot CPU Role State
1 0 Active Stable
Table 15 Command output
System state |
System status: · Stable—The system is operating stably. · Not ready—The system is not operating stably. You cannot execute an install command when the system is in this state. |
Redundancy state |
System redundancy status: · Stable—Member devices are operating stably. You can perform a switchover. · No redundance—The system has only one member device. You cannot perform a switchover. · Not ready—The system is not operating stably. You cannot perform a switchover. |
Role |
Role of the member device in the system: · Active—The member device is the master. · Standby—The member device is a subordinate member. |
State |
Member device status: · Stable—The member device is operating stably. · Board inserted—The member device has just been installed. · Kernel initiating—Member device kernel is being initialized. · Service starting—Services are starting on the member device. · Service stopping—Services are stopping on the member device. · HA Batch backup—An HA batch backup is going on. · Interface data batch backup—An interface data batch backup is in progress. |
display device
display ha service-group (High Availability Command Reference)
display transceiver alarm
Use display transceiver alarm to display transceiver alarms.
display transceiver alarm { controller [ controller-type controller-number ] | interface [ interface-type interface-number ] }
controller [ controller-type controller-number ]: Specifies a controller by its type and number. If no controller is specified, this command displays the alarms present on all controllers.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the alarms present on every transceiver module.
Table 16 shows the common transceiver alarm components. If no error occurs, "None" is displayed.
Table 16 Common transceiver alarm components
APD |
Avalanche photo diode |
PCS |
Physical coding sublayer |
PHY XS |
PHY extended sublayer |
PMA/PMD |
Physical medium attachment/physical medium dependent |
power |
Optical power |
REFCLK |
Reference clock |
RX |
Receive |
Temp |
Temperature |
TX |
Transmit |
WIS |
WAN interface sublayer |
# Display the alarms present on the transceiver module in interface GigabitEthernet 1/0/1.
<Sysname> display transceiver alarm interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver current alarm information:
RX loss of signal
RX power low
Table 17 Command output
transceiver current alarm information |
Alarms present on the transceiver module. |
RX loss of signal |
Received signals are lost. |
RX power low |
Received power is low. |
display transceiver diagnosis
This command is supported only on H3C transceiver modules.
Use display transceiver diagnosis to display the current values of the digital diagnosis parameters on transceiver modules.
display transceiver diagnosis { controller [ controller-type controller-number ] | interface [ interface-type interface-number ] }
controller [ controller-type controller-number ] : Specifies a controller by its type and number. If no controller is specified, this command displays the current values of the digital diagnosis parameters on all controllers.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the current values of the digital diagnosis parameters on all interfaces.
# Display the current values of the digital diagnosis parameters on the transceiver module in interface GigabitEthernet 1/0/1.
<Sysname> display transceiver diagnosis interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver diagnostic information:
Temp(°C) Voltage(V) Bias(mA) RX power(dBm) TX power(dBm)
36 3.31 6.13 -35.64 -5.19
Alarm thresholds:
Temp(°C) Voltage(V) Bias(mA) RX power(dBM) TX power(dBM)
High 50 3.55 1.44 -10.00 5.00
Low 30 3.01 1.01 -30.00 0.00
Table 18 Command output
transceiver diagnostic information |
Digital diagnosis information for the transceiver module in the interface. |
Temp.(°C) |
Temperature in °C, accurate to 1°C. |
Voltage(V) |
Voltage in V, accurate to 0.01 V. |
Bias(mA) |
Bias current in mA, accurate to 0.01 mA. |
RX power(dBm) |
Receive power in dBm, accurate to 0.01 dBm. |
TX power(dBm) |
Transmit power in dBm, accurate to 0.01 dBm. |
display transceiver interface
Use display transceiver interface to display the key parameters of transceiver modules.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the key parameters of every transceiver module.
# Display the key parameters of the transceiver module in interface GigabitEthernet 1/0/1.
<Sysname> display transceiver interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver information:
Transceiver Type : 1000_BASE_SX_SFP
Connector Type : LC
Wavelength(nm) : 850
Transfer Distance(m) : 550(50um),270(62.5um)
Digital Diagnostic Monitoring : YES
Vendor Name : H3C
Ordering Name : SFP-GE-SX-MM850
Table 19 Command output
Wavelength(nm) |
Central wavelength of the laser in nm. For a fiber transceiver module that supports multiple wavelengths, for example, the 10GBASE-LX4 transceiver module, this field displays all the wavelengths, separating the values by commas (,). For a copper module, this field displays N/A. |
Transfer Distance(m) |
Transmission distance, in km (for single-mode modules) or in m (for other modules). For a module that supports multiple transmission media, this field displays all the transmission distances, separating the values by commas (,). Each transmission distance is followed by the medium name in parentheses. · 9um—9/125um single-mode optical fiber. · 50um—50/125um multi-mode optical fiber. · 62.5um—62.5/125um multi-mode optical fiber. · TP—Twisted pairs. · CX4—CX4 cables. |
Digital Diagnostic Monitoring |
Whether digital diagnosis is supported: · YES—Digital diagnosis is supported. · NO—Digital diagnosis is not supported. |
display transceiver manuinfo
Use display transceiver manuinfo to display electronic label information for transceiver modules.
display transceiver manuinfo { controller [ controller-type controller-number ] | interface [ interface-type interface-number ] }
controller [ controller-type controller-number ] : Specifies a controller by its type and number. If no controller is specified, this command displays the electronic label information for the transceiver modules in all controllers.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays electronic label information for the transceiver modules in all interfaces.
# Display electronic label information for the transceiver module in interface GigabitEthernet 1/0/1.
<Sysname> display transceiver manuinfo interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver manufacture information:
Manu. Serial Number : 213410A0000054000251
Manufacturing Date : 2017-09-01
Vendor Name : H3C
display version
Use display version to display system version information.
display version
# Display system version information.
<Sysname> display version
H3C Comware Software, Version 7.1.064, ESS 0706
Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.
H3C MSR36-40 uptime is 0 weeks, 2 days, 7 hours, 40 minutes
Last reboot reason : Power on
Boot image: cfa0:/msr36-cmw710-boot-e0706.bin
Boot image version: 7.1.064P61, ESS 0706
Compiled Apr 13 2018 16:00:00
System image: cfa0:/msr36-cmw710-system-e0706.bin
System image version: 7.1.064, ESS 0706
Table 20 Command output
Last reboot reason |
Reason for the last reboot: · User reboot—The reboot was manually initiated from a user interface, such as the CLI or SNMP. · Power on—The reboot was caused by a power cycle. · Exception reboot—The reboot was caused by kernel exceptions or dead loops. · Heart-beat timeout—The reboot was caused by a device management handshake failure. · Switch to standby—The reboot was caused by a master/subordinate switchover. · IRF Merge—The reboot was caused by an IRF merge. · Auto reboot after updating—The reboot was caused by a software upgrade. · Out of memory—The reboot was caused by a card-memory-exhausted event. |
display version-update-record
Use display version-update-record to display startup software image upgrade records.
The device records its current startup software version information whenever it starts up, and records all software version update information. Such information can survive reboots.
# Display the startup software image upgrade records.
<Sysname> display version-update-record
Record 1 (updated on Apr 18 2015 at 06:23:54):
*Name : simware-cmw710-boot.bin
Version : 7.1.070 Test 0001
Compile time: Mar 25 2015 15:52:43
*Name : simware-cmw710-system.bin
Record n |
Number of the startup software image upgrade record. Record 1 is the most recent record. |
Name |
Software image file name. |
The software image version changed during the upgrade. |
reset version-update-record
firmware update fota
Use firmware update fota to update the modem firmware through FoTA.
Cellular interface view
CAUTION: Use this command with caution. A modem firmware update through FoTA affects data transmission and consumes SIM card resources. |
This command is supported only on the following devices:
· MSR810-LMS.
· MSR810-LUS.
· Devices that are installed with the SIC-D4G-CNDE or SIC-4G-CNDE card.
# Update the modem firmware through FoTA.
[Sysname] controller cellular 1/0
[Sysname-Controller-Cellular1/0] firmware update fota
Updating firmware for the modem. Continue?[Y/N]:y
Updating the firmware..
Do not turn off power during the updating process! Set modem to Fota Mode.
Updated successfully! The modem is restarting.......................Done.
header
Use header to configure a banner.
Use undo header to delete a banner.
header { legal | login | motd | shell } text
undo header { legal | login | motd | shell }
The device does not have banners.
legal: Configures the banner to be displayed before a user inputs the username and password to access the CLI.
login: Configures the banner to be displayed before password or scheme authentication is performed for a login user.
motd: Configures the greeting banner to be displayed before the legal banner appears.
shell: Configures the banner to be displayed before a user accesses user view.
text: Specifies the banner message. You can enter the banner message on the same line as the keywords or on different lines. For more information, see device management in Fundamentals Configuration Guide.
# Configure the legal banner.
[Sysname] header legal
Welcome to use the legal banner%
job
Use job to assign a job to a schedule.
Use undo job to revoke a job.
job job-name
undo job job-name
No job is assigned to a schedule.
Schedule view
job-name: Specifies the job name, a case-sensitive string of 1 to 47 characters.
You can assign multiple jobs to a schedule. The jobs in a schedule are executed concurrently.
The jobs to be assigned to a schedule must already exist. To create a job, use the scheduler job command.
# Assign job save-job to schedule saveconfig.
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
scheduler job
scheduler schedule
memory-threshold
Use memory-threshold to set free-memory thresholds.
Use undo memory-threshold to restore the defaults.
In standalone mode:
memory-threshold minor minor-value severe severe-value critical critical-value normal normal-value
In IRF mode:
memory-threshold [ slot slot-number [ cpu cpu-number ] ] minor minor-value severe severe-value critical critical-value normal normal-value
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
The default settings vary by device model. To view the default settings, use the undo memory-threshold command to restore the default settings and then execute the display memory-threshold command.
minor minor-value: Specifies the minor alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the minor-value argument. Setting this threshold to 0 disables the minor alarm feature.
severe severe-value: Specifies the severe alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the severe-value argument. Setting this threshold to 0 disables the severe alarm feature.
critical critical-value: Specifies the critical alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the critical-value argument. Setting this threshold to 0 disables the critical alarm feature.
normal normal-value: Specifies the normal state threshold. To view the value range for this threshold, enter a question mark (?) in the place of the normal-value argument.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets free-memory thresholds for the master device. (In IRF mode.)
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. If the amount of free memory space decreases to or below the minor, severe, or critical alarm threshold, the system issues an alarm to affected service modules or processes.
If a memory alarm occurs, delete unused configuration items or disable some features to increase the free memory space. Because the memory space is insufficient, some configuration items might not be able to be deleted.
For more information about the thresholds, see device management in Fundamentals Configuration Guide.
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 64 MB, 48 MB, 32 MB, and 96 MB, respectively.
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
memory-threshold usage
Use memory-threshold usage to set the memory usage threshold.
Use undo memory-threshold usage to restore the default.
In standalone mode:
memory-threshold usage memory-threshold
In IRF mode:
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
The memory usage threshold is 100%.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets the memory usage threshold for the master device. (In IRF mode.)
memory-threshold: Specifies the memory usage threshold in percentage. The value range is 0 to 100.
The device samples memory usage at 1-minute intervals. If the sample is equal to or greater than the memory usage threshold, the device sends a trap.
# Set the memory usage threshold to 80%.
[Sysname] memory-threshold usage 80
Use monitor cpu-usage enable to enable CPU usage monitoring.
Use undo monitor cpu-usage enable to disable CPU usage monitoring.
In standalone mode:
In IRF mode:
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
CPU usage monitoring is enabled.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command enables CPU usage monitoring for the master device. (In IRF mode.)
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the interval specified by the monitor cpu-usage interval command. You can use the display cpu-usage history command to view recent CPU usage.
# Enable CPU usage monitoring.
[Sysname] monitor cpu-usage enable
Use monitor cpu-usage interval to set the sampling interval for CPU usage monitoring.
In standalone mode:
monitor cpu-usage interval interval
In IRF mode:
The system samples CPU usage every 1 minute.
interval: Specifies the sampling interval for CPU usage monitoring. Valid values include 5Sec (5 seconds), 1Min (1 minute), and 5Min (5 minutes), case insensitive.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets the interval for the master device. (In IRF mode.)
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the specified interval. You can use the display cpu-usage history command to view recent CPU usage.
# Set the sampling interval for CPU usage monitoring to 5 seconds.
[Sysname] monitor cpu-usage interval 5Sec
Use monitor cpu-usage threshold to set CPU usage alarm thresholds.
Use undo monitor cpu-usage threshold to restore default settings.
In standalone mode:
monitor cpu-usage threshold severe-threshold
In IRF mode:
monitor cpu-usage threshold severe-threshold [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ slot slot-number [ cpu cpu-number ] ]
The CPU usage alarm threshold is 99%.
severe-threshold: Specifies the severe CPU usage alarm threshold in percentage. The value range for this argument is 2 to 100.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command sets the CPU usage threshold for the master device. (In IRF mode.)
The device samples CPU usage at 1-minute intervals. If the sample is greater than the CPU usage threshold, the device sends a trap.
# Set the CPU usage alarm threshold to 90%.
[Sysname] monitor cpu-usage threshold 90
monitor disk-usage disk
Use monitor disk-usage disk to set disk usage thresholds.
Use undo monitor disk-usage disk to restore the default.
In standalone mode:
monitor disk-usage disk disk-name threshold threshold-value
undo monitor disk-usage disk disk-name threshold
In IRF mode:
monitor disk-usage [ slot slot-number ] disk disk-name threshold threshold-value
undo monitor disk-usage [ slot slot-number ] disk disk-name threshold
The disk usage threshold is 90%.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, the command sets a disk usage threshold for the master device. (In IRF mode.)
disk disk-name: Specifies a storage medium by its name.
threshold threshold-value: Specifies the disk usage threshold in percentage, in the range of 1 to 100.
This device can periodically sample disk usages and compare the usages with the thresholds. If a sample is greater than or equal to the disk usage threshold, the device determines the disk usage is high.
# Set the disk usage threshold to 80% for a storage medium.
[Sysname] disk-threshold disk flash threshold 80
monitor disk-usage interval
Use monitor disk-usage interval to set the disk usage sampling interval.
Use undo monitor disk-usage interval to restore the default.
monitor disk-usage interval interval
The disk usage sampling interval is 300 seconds.
interval interval-time: Specifies the disk usage sampling interval in seconds, a multiple of five in the range of 5 to 1800.
After you set the disk usage sampling interval, the device samples disk usages at the specified intervals.
# Set the disk usage interval to 120 seconds.
[Sysname] monitor disk-usage interval 120
password-recovery enable
Use password-recovery enable to enable password recovery capability.
Use undo password-recovery enable to disable password recovery capability.
Password recovery capability is enabled.
Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure new passwords.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
(In IRF mode.) To access the device configuration without authentication, you must connect to the master device and access the BootWare menu while the master device is starting up.
Availability of BootWare menu options depends on the password recovery capability setting. For more information, see the release notes.
# Disable password recovery capability.
[Sysname] undo password-recovery enable
ptp acceleration enable
Use ptp acceleration enable to enable PTP packet acceleration.
Use undo ptp acceleration enable to disable PTP packet acceleration.
The following compatibility matrixes show the support of hardware platforms for this command:
Hardware |
Command compatibility |
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK |
No |
MSR810-LMS, MSR810-LUS |
No |
MSR810-LMS-EA, MSR810-LME |
No |
MSR2600-6-X1 |
Yes |
MSR2600-10-X1 |
No |
MSR 2630 |
No |
MSR3600-28, MSR3600-51 |
No |
No |
No |
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD |
No |
MSR3610-X1 |
Yes |
MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC |
No |
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3660 |
No |
MSR 3640 |
Yes |
MSR3610-G, MSR3620-G |
No |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
MSR2600-6-WiNet |
Yes |
MSR2600-10-X1-WiNet |
No |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
No |
Hardware |
MSR2630-XS |
Yes |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
No |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
PTP packet acceleration is disabled.
Enabling PTP packet acceleration improves PTP packet forwarding speed and reduces PTP packet transmission delay and jitter.
# Enable PTP packet acceleration.
[Sysname] ptp acceleration enable
reboot
Use reboot to reboot the device.
In standalone mode:
reboot [ force ]
In IRF mode:
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, the command reboots all IRF member devices. (In IRF mode.)
force: Reboots the device immediately without performing software or hard disk check. If this keyword is not specified, the system first identifies whether the reboot might result in data loss or a system failure. For example, the system identifies whether the main system software image file exists and whether a write operation is in progress on a storage medium. If the reboot might cause problems, the system does not reboot the device.
CAUTION: · A reboot might interrupt network services. · Use the force keyword only when the device fails or a reboot command without the force keyword cannot perform a reboot correctly. A reboot command with the force keyword might result in file system corruption because it does not perform data protection. |
If the main startup software images are corrupt or missing, you must re-specify a set of main startup software images before executing the reboot command.
For data security, the device does not reboot if you reboot the device while the device is performing file operations.
In IRF mode:
If the IRF fabric has only one member device, rebooting the member device reboots the entire IRF fabric. If the IRF fabric has a subordinate member and the member is operating correctly, rebooting the master triggers a master/subordinate switchover.
To ensure correct operation of the IRF fabric and member devices, do not trigger a switchover by rebooting the master if no subordinate member devices are in Stable state. To view the status of subordinate member devices, execute the display system stable state command.
# (In standalone mode.) Reboot the device. Save the running configuration at prompt.
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to device successfully.
Now rebooting, please wait...
# (In IRF mode.) Reboot the device. Save the running configuration at prompt.
<Sysname> reboot
Configuration is saved to mainboard device successfully.
# Reboot the device immediately without performing software check.
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
remove
Use remove to unmount an HMIM module.
In standalone mode:
remove subslot subslot-number
In IRF mode:
remove slot slot-number subslot subslot-number
Hardware |
No |
No |
No |
MSR2600-6-X1 |
Yes |
MSR2600-10-X1 |
No |
MSR 2630 |
No |
No |
No |
No |
No |
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC |
Yes |
Yes |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
MSR2600-6-WiNet |
Yes |
No |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR2630-XS |
Yes |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
subslot subslot-number: Specifies an HMIM module by its subslot number. (In standalone mode.)
slot slot-number subslot subslot-number: Specifies an HMIM module. The slot-number argument represents the member ID of the IRF member device. The subslot-number argument represents the subslot number of the HMIM module. (In IRF mode.)
CAUTION: Unmounting an HMIM module stops all services provided by the module. |
Unmount an HMIM module before removing the module from the device. If you remove an HMIM module that is not unmounted, the device might fail or be damaged.
An unmounted HMIM module is not visible or configurable.
# (In standalone mode.) Unmount the HMIM module in subslot 6.
<Sysname> remove subslot 6
You can remove the card now!
# (In IRF mode.) Unmount the HMIM module in subslot 6 of member device 1.
<Sysname> remove slot 1 subslot 6
Use reset scheduler logfile to clear job execution log information.
# Clear job execution log information.
<Sysname> reset scheduler logfile
Use reset version-update-record to clear startup software image upgrade records.
# Clear the startup software image upgrade records.
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
restore factory-default
Use restore factory-default to restore the factory-default configuration for the device.
CAUTION: This command is disruptive. It restores the factory default configuration and forcibly reboots the device. |
Use this command only when you cannot troubleshoot the device by using other methods, or you want to use the device in a different scenario.
# Restore the factory-default configuration for the device.
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data, and forcibly reboot the system. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait....Done.
The system is rebooting...
reboot
scheduler job
Use scheduler job to create a job and enter its view, or enter the view of an existing job.
Use undo scheduler job to delete a job.
scheduler job job-name
undo scheduler job job-name
No job exists.
A job can be referenced by multiple schedules. In job view, you can assign commands to the job.
# Create a job named backupconfig and enter job view.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig]
command
scheduler schedule
scheduler logfile size
Use scheduler logfile size to set the size of the job execution log file.
scheduler logfile size value
The size of the job execution log file is 16 KB.
value: Specifies the size of the job execution log file, in KB. The value range is 16 to 1024.
The job execution log file stores the execution information of jobs. If the file is full, old records are deleted to make room for new records. If the size of the log information to be written to the file is greater than the file size, the excessive information is not written to the file.
# Set the size of the job execution log file to 32 KB.
[Sysname] scheduler logfile size 32
scheduler reboot at
Use scheduler reboot at to specify the reboot date and time.
Use undo scheduler reboot to delete the reboot schedule configuration.
No reboot date or time is specified.
time: Specifies the reboot time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the reboot date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION: Device reboot interrupts network services. |
When the date argument is not specified, the system uses the following rules to determine the reboot time:
· If the reboot time is later than the current time, a reboot occurs at the reboot time of the current day.
· If the reboot time is earlier than the current time, a reboot occurs at the reboot time the next day.
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and scheduler reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
For data security, the system does not reboot at the reboot time if a file operation is being performed.
# Configure the device to reboot at 12:00 p.m. This example assumes that the current time is 11:43 a.m. on June 6, 2015.
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2015 (in 0 hours and 16 minutes). Confirm? [Y/N]:
Use scheduler reboot delay to specify the reboot delay time.
scheduler reboot delay time
No reboot delay time is specified.
time: Specifies the reboot delay time in the hh:mm or mm format. This argument can contain up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and schedule reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
# Configure the device to reboot after 88 minutes. This example assumes that the current time is 11:48 a.m. on June 6, 2015.
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2015(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule
Use scheduler schedule to create a schedule and enter its view, or enter the view of an existing schedule.
Use undo scheduler schedule to delete a schedule.
undo scheduler schedule schedule-name
No schedule exists.
schedule-name: Specifies the schedule name, a case-sensitive string of 1 to 47 characters.
You can configure a schedule to have the device automatically run a command or a set of commands without administrative interference.
To configure a schedule:
1. Use the scheduler job command to create a job and enter job view.
2. Use the command command to assign commands to the job.
3. Use the scheduler schedule command to create a schedule and enter schedule view.
4. Use the job command to assign the job to the schedule. You can assign multiple jobs to a schedule. The jobs must already exist.
5. Use the user-role command to assign user roles to the schedule. You can assign up to 64 user roles to a schedule.
6. Use the time at, time once, or time repeating command to specify an execution time for the schedule. You can specify only one execution time for a schedule.
# Create a schedule named saveconfig.
job
time at
time once
shutdown-interval
Use shutdown-interval to set the port status detection timer.
Use undo shutdown-interval to restore the default.
shutdown-interval interval
The port status detection timer setting is 30 seconds.
interval: Specifies the port status detection timer value in seconds. The value range is 0 to 300. To disable port status detection, set this argument to 0.
The device starts a port status detection timer when a port is shut down by a protocol. Once the timer expires, the device brings up the port so the port status reflects the port's physical status.
If you change the timer setting during port detection, the device compares the new setting (T1) with the time that elapsed since the port was shut down (T).
If T < T1, the port will be brought up after T1 – T seconds.
If T ≥ T1, the port is brought up immediately.
For example, the timer setting is 30 seconds. If you change it to 10 seconds 2 seconds after the port is shut down, the port will come up 8 seconds later. If you change the timer setting to 2 seconds 10 seconds after the port is shut down, the port comes up immediately.
# Set the port status detection timer to 100 seconds.
[Sysname] shutdown-interval 100
sysid
Use sysid to set the system ID.
Use undo sysid to restore the default.
sysid system-id
undo sysid
The device does not have a system ID.
system-id: Specifies the system ID for the device. You can use this argument to indicate the position or functionality of the device or any other information.
# Set the system ID of the device to position-hall.
[Sysname] sysid position-hall
sysname
Use sysname to set the device name.
Use undo sysname to restore the default.
sysname sysname
undo sysname
The device name is H3C.
sysname: Specifies a name for the device, a string of 1 to 64 characters.
A device name identifies a device in a network and is used in CLI view prompts. For example, if the device name is Sysname, the user view prompt is <Sysname>.
# Set the name of the device to R2000.
[Sysname] sysname R2000
time at
Use time at to specify an execution date and time for a non-periodic schedule.
Use undo time to delete the execution date and time configuration for a non-periodic schedule.
time at time date
undo time
No execution time or date is specified for a non-periodic schedule.
Schedule view
time: Specifies the schedule execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the schedule execution date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
The specified time (date plus time) must be later than the current system time.
The time at command, the time once command, and the time repeating command overwrite one another. The most recently configured command takes effect.
# Configure the device to execute schedule saveconfig at 01:01 a.m. on May 11, 2015.
[Sysname-schedule-saveconfig] time at 1:1 2015/05/11
scheduler schedule
time once
Use time once to specify one or more execution days and the execution time for a non-periodic schedule.
Use undo time to delete the execution day and time configuration for a non-periodic schedule.
time once delay time
undo time
No execution time or day is specified for a non-periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
month-date month-day: Specifies a day in the current month, in the range of 1 to 31. If you specify a day that does not exist in the current month, the configuration takes effect on that day in the next month.
week-day week-day&<1-7>: Specifies a space-separated list of up to seven week days for the schedule. Valid week day values include Mon, Tue, Wed, Thu, Fri, Sat, and Sun.
delay time: Specifies the delay time for executing the schedule, in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
If the specified time has already occurred, the schedule will be executed at the specified time the following day.
If the day in the month has already occurred, the schedule will be executed at the specified day in the following month.
If the specified day in a week has already occurred, the schedule will be executed at the specified day in the following week.
# Configure the device to execute schedule saveconfig once at 15:00.
[Sysname-schedule-saveconfig] time once at 15:00
Schedule starts at 15:00 5/11/2011.
# Configure the device to execute schedule saveconfig once at 15:00 on the coming 15th day in a month.
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# Configure the device to execute schedule saveconfig at 12:00 p.m. on the coming Monday and Friday.
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# Configure the device to execute schedule saveconfig after 10 minutes.
[Sysname-schedule-saveconfig] time once delay 10
scheduler schedule
time repeating
Use time repeating to specify an execution time table for a periodic schedule.
Use undo time to delete the execution time table configuration for a periodic schedule.
time repeating [ at time [ date ] ] interval interval
undo time
No execution time table is specified for a periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. If you do not specify this option, the current system time is used as the execution time.
date: Specifies the start date for the periodic schedule, in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month. If you do not specify this argument, the execution start date is the first day when the specified time arrives.
interval interval: Specifies the execution time interval in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59. When in the mm format, this argument must be equal to or greater than 1 minute.
month-date [ month-day | last ]: Specifies a day in a month, in the range 1 to 31. The last keyword indicates the last day of a month. If you specify a day that does not exist in a month, the configuration takes effect on that day in the next month.
The time repeating [ at time [ date ] ] interval interval command configures the device to execute a schedule at intervals from the specified time on.
The time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ] command configures the device to execute a schedule at the specified time on every specified day in a month or week.
The time at command, the time once command, and the time repeating command overwrite one another, whichever is configured most recently takes effect.
# Configure the device to execute schedule saveconfig once an hour from 8:00 a.m. on.
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# Configure the device to execute schedule saveconfig at 12:00 p.m. every day.
[Sysname-schedule-saveconfig] time repeating at 12:00
# Configure the device to execute schedule saveconfig at 8:00 a.m. on the 5th of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# Configure the device to execute schedule saveconfig at 8:00 a.m. on the last day of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# Configure the device to execute schedule saveconfig at 8:00 a.m. every Friday and Saturday.
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
scheduler schedule
usb disable
Use usb disable to disable USB interfaces.
Use undo usb disable to enable USB interfaces.
usb disable
undo usb disable
Hardware |
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK |
Yes |
MSR810-LM-HK, MSR810-W-LM-HK |
No |
No |
Yes |
MSR2600-6-X1 |
No |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
No |
No |
No |
Yes |
Yes |
MSR 3610, MSR 3620, MSR 3640, MSR 3660 |
No |
MSR 3620-DP |
Yes |
No |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
MSR830-5BEI-WiNet, MSR830-10BEI-WiNet |
Yes |
MSR830-6EI-WiNet |
No |
Yes |
MSR2600-6-WiNet |
No |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-WiNet, MSR3660-WiNet |
No |
MSR3620-DP-WiNet |
Yes |
Hardware |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR2600-6-X1-GL |
No |
MSR3600-28-SI-GL |
No |
All USB interfaces are enabled.
You can use USB interfaces to upload or download files or to connect a 3G modem. By default, all USB interfaces are enabled.
Before executing this command, use the umount command to unmount all USB file systems.
# Enable USB interfaces.
[Sysname] undo usb disable
user-role
Use user-role to assign user roles to a schedule.
Use undo user-role to remove user roles from a schedule.
user-role role-name
undo user-role role-name
A schedule has the user roles of the schedule creator.
Schedule view
role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. The user role can be user-defined or predefined. Predefined user roles include network-admin, network-operator, and level-0 to level-15.
A schedule must have one or more user roles. A command in a schedule can be executed if it is permitted by one or more user roles of the schedule. For more information about user roles, see the RBAC configuration in Fundamentals Configuration Guide.
A schedule can have a maximum of 64 user roles. After the limit is reached, you cannot assign additional user roles to the schedule.
# Assign user role rolename to schedule test.
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
command
scheduler schedule
