04-Bandwidth management commands | 255.39 KB |
bandwidth { per-ip | per-user }
per-ip total traffic-quota per-ip monthly
display traffic-policy statistics bandwidth
display traffic-policy statistics connection-limit
display traffic-policy statistics rule-hit
per-ip bandwidth-threshold max-value
per-ip bandwidth-threshold min-value
per-ip bandwidth-threshold-detect enable
per-ip bandwidth-threshold-learn duration
per-ip bandwidth-threshold-learn enable
per-ip bandwidth-threshold-learn tolerance max-value
per-ip bandwidth-threshold-learn tolerance min-value
reset traffic-policy statistics bandwidth
reset traffic-policy statistics connection-limit
reset traffic-policy statistics rule-hit
The following compatibility matrixes show the support of hardware platforms for bandwidth management:
Hardware |
Bandwidth management compatibility |
MSR610 |
Yes |
Yes |
MSR810-LMS, MSR810-LUS |
No |
MSR810-SI, MSR810-LM-SI |
No |
MSR810-LMS-EA, MSR810-LME |
Yes |
MSR1004S-5G |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3610-G, MSR3620-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
MSR2600-10-X1-WiNet |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
action
Use action to specify an action for a traffic rule.
Use undo action to restore the default.
action { deny | none | qos profile profile-name }
undo action
The action for a traffic rule is none.
Traffic rule view
deny: Drops matching packets.
none: Allows matching packets to pass through without bandwidth management.
qos profile profile-name: Specifies a traffic profile by its name to limit the rate of matching packets. The profile name is a case-insensitive string of 1 to 63 characters.
If a packet matches a traffic rule, the device performs the action specified in the traffic rule on the packet.
# Create a traffic rule named rule1, and apply traffic profile profile1 to the traffic rule.
[Sysname] traffic-policy
[Sysname-traffic-policy] rule name rule1
[Sysname-traffic-policy-rule-rule1] action qos profile profile1
profile name
rule name
all-traffic-control enable
Use all-traffic-control enable to enable bandwidth management for traffic flows of the IP layer and upper layers.
Use undo all-traffic-control enable to restore the default.
Bandwidth management is performed only for traffic flows of Layer 4 and upper layers.
Traffic policy view
Use this command when there is a large number of IP traffic flows in the network.
# Enable bandwidth management for traffic flows of the IP layer and upper layers.
[Sysname-traffic-policy] all-traffic-control enable
application
Use application to configure application or application group as a match criterion.
Use undo application to delete an application or application group match criterion.
application { app application-name | app-group application-group-name }
undo application { app application-name | app-group application-group-name }
No application or application group is used as a match criterion.
Traffic rule view
app application-name: Specifies an application by its name, a case-insensitive string of 1 to 63 characters.
app-group application-group-name: Specifies an application group by its name, a case-insensitive string of 1 to 63 characters.
You can configure multiple applications or application groups for a traffic rule to match packets.
This command enables the device to manage bandwidth by application type, such as email, P2P, IM, and web browsing.
If you specify a user-defined application that uses DCCP, SCTP, or UDP-Lite as the transport layer protocol, the application is not limited by bandwidth management. For information about user-defined applications, see Security Configuration Guide.
# Configure P2P_General_TCP_Communications as a match criterion for traffic rule rule1.
[Sysname-traffic-policy-rule-rule1] application app P2P_General_TCP_Communications
app-group (Security Command Reference)
nbar application (Security Command Reference)
port-mapping (Security Command Reference)
bandwidth
Use bandwidth to set the total guaranteed bandwidth or maximum bandwidth in a traffic profile.
Use undo bandwidth to delete the total guaranteed bandwidth or maximum bandwidth setting of a traffic profile.
bandwidth { downstream | total | upstream } { guaranteed | maximum } bandwidth-value
undo bandwidth { downstream | total | upstream } { guaranteed | maximum }
The total guaranteed bandwidth and maximum bandwidth are not set in a traffic profile.
Traffic profile view
downstream: Specifies downstream traffic (traffic from a server to a client).
total: Specifies both downstream traffic and upstream traffic.
upstream: Specifies upstream traffic (traffic from a client to a server).
guaranteed: Specifies the guaranteed bandwidth.
maximum: Specifies the maximum bandwidth. The maximum bandwidth must be greater than or equal to the guaranteed bandwidth.
bandwidth-value: Specifies the bandwidth value in the range of 8 to 100000000 kbps.
When you specify traffic profiles for parent and child traffic rules, following these restrictions and guidelines:
· The maximum bandwidth for the child traffic rule must be smaller than or equal to that for the parent traffic rule.
· The guaranteed bandwidth for a child traffic rule must be smaller than or equal to that for the parent traffic rule.
· The traffic profiles cannot be the same for the child and parent traffic rules.
An interface with small default expected bandwidth might experience traffic loss if the following conditions exist:
· There is a large amount of traffic on the interface.
· The interface uses the default expected bandwidth.
To avoid traffic loss, implicitly set the expected bandwidth to a large value for such an interface. For example, you can set the expected bandwidth of a tunnel interface to a value greater than 64 kbps (the default) if there is a large amount of traffic on the interface.
# In traffic profile profile1, set both upstream and downstream maximum bandwidth to 10000 kbps, and set both upstream and downstream guaranteed bandwidth to 5000 kbps.
[Sysname-traffic-policy] profile name profile1
[Sysname-traffic-policy-profile-profile1] bandwidth upstream maximum 10000
[Sysname-traffic-policy-profile-profile1] bandwidth downstream maximum 10000
[Sysname-traffic-policy-profile-profile1] bandwidth upstream guaranteed 5000
[Sysname-traffic-policy-profile-profile1] bandwidth downstream guaranteed 5000
bandwidth average enable
Use bandwidth average enable to enable dynamic and even allocation for maximum bandwidth.
Use undo bandwidth average enable to disable dynamic and even allocation for maximum bandwidth.
Dynamic and even allocation for maximum bandwidth is disabled.
This command allows the device to dynamically and evenly allocate the total maximum bandwidth among all online IP addresses.
This command can be enabled only after you set the total maximum bandwidth.
# Enable dynamic and even allocation for maximum bandwidth in traffic profile profile1.
[Sysname-traffic-policy-profile-profile1] bandwidth total maximum 10000
[Sysname-traffic-policy-profile-profile1] bandwidth average enable
bandwidth { downstream | total | upstream } maximum
Use bandwidth { per-ip | per-user } to set the per-IP or per-user maximum or guaranteed bandwidth for a traffic profile.
Use undo bandwidth { per-ip | per-user } to delete the per-IP or per-user maximum or guaranteed bandwidth setting of a traffic profile.
bandwidth { downstream | total | upstream } { guaranteed | maximum } { per-ip | per-user } bandwidth-value
undo bandwidth { downstream | total | upstream } { guaranteed | maximum } { per-ip | per-user }
The per-IP or per-user maximum bandwidth and guaranteed bandwidth are not set in a traffic profile.
guaranteed: Sets the guaranteed bandwidth.
maximum: Sets the maximum bandwidth.
per-ip: Sets the per-IP bandwidth.
per-user: Sets the per-user bandwidth.
This command allows you to manage bandwidth at finer granularity.
The per-IP or per-user maximum bandwidth cannot be greater than the total maximum bandwidth.
The per-IP or per-user guaranteed bandwidth cannot be greater than the total guaranteed bandwidth.
The per-IP or per-user guaranteed bandwidth cannot be greater than the per-IP or per-user maximum bandwidth.
# In traffic profile profile1, set both upstream and downstream per-IP maximum bandwidth to 10000 kbps.
[Sysname-traffic-policy-profile-profile1] bandwidth upstream maximum per-ip 10000
[Sysname-traffic-policy-profile-profile1] bandwidth downstream maximum per-ip 10000
Use per-ip total traffic-quota per-ip monthly to set the per-IP monthly traffic quota.
Use undo total traffic-quota per-ip monthly to restore the default.
bandwidth total traffic-quota per-ip monthly quota-value
undo bandwidth total traffic-quota per-ip monthly
The amount of traffic used by an IP address per month is not limited.
quota-value: Specifies the per-IP monthly traffic quota in the range of 1 to 1000000000 KB.
This command limits the total amount traffic (uplink and downlink) used by an IP address per month. When the traffic used by an IP address reaches the traffic quota, the device drops packets from the IP address.
# In traffic profile prof1, set the per-IP monthly traffic quota to 5000 KB.
[Sysname-traffic-policy] profile name prof1
[Sysname-traffic-policy-profile-prof1] bandwidth total traffic-quota per-ip monthly 5000
connection-limit count
Use connection-limit count to set the connection count limit for a traffic profile.
Use undo connection-limit count to delete the connection count limit setting of a traffic profile.
connection-limit count { per-rule | per-ip | per-user } connection-number
undo connection-limit count { per-rule | per-ip | per-user }
No connection count limit is set for a traffic profile.
per-rule: Specifies the total connection count limit (count limit for the traffic rule associated with the traffic profile).
per-ip: Specifies the per-IP connection count limit.
per-user: Specifies the per-user connection count limit.
connection-number: Specifies the maximum number of connections allowed, in the range of 1 to 12000000.
The per-IP or per-user connection count limit cannot be greater than the total connection count limit.
You cannot set both per-IP and per-user connection count limits for one traffic profile.
# In traffic profile profile1, set the total connection count limit to 1000.
[Sysname-traffic-policy-profile-profile1] connection-limit count per-rule 1000
# In traffic profile profile1, set the per-IP connection count limit to 500.
[Sysname-traffic-policy-profile-profile1] connection-limit count per-ip 500
connection-limit rate
Use connection-limit rate to set the connection rate limit for a traffic profile.
Use undo connection-limit rate to delete the connection rate limit setting of a traffic profile.
connection-limit rate { per-rule | per-ip | per-user } connection-rate
undo connection-limit rate { per-rule | per-ip | per-user }
No connection rate limit is set for a traffic profile.
per-rule: Specifies the total connection rate limit (rate limit for the traffic rule associated with the traffic profile).
per-ip: Specifies the per-IP connection rate limit.
per-user: Specifies the per-user connection rate limit.
connection- rate: Specifies the maximum connection rate in the range of 1 to 12000000 connections per second.
The per-IP or per-user connection rate limit cannot be greater than the total connection rate limit.
You cannot set both per-IP and per-user connection rate limits for one traffic profile.
# In traffic profile profile1, set the total connection rate limit to 1000 connections per second.
[Sysname-traffic-policy-profile-profile1] connection-limit rate per-rule 1000
# In traffic profile profile1, set the per-IP connection rate limit to 500 connections per second.
[Sysname-traffic-policy-profile-profile1] connection-limit rate per-user 500
destination-address
Use destination-address to configure a destination IP address object group as a match criterion.
Use undo destination-address to remove a destination IP address object group as a match criterion.
destination-address address-set object-group-name
undo destination-address address-set object-group-name
No destination IP address object group is used as a match criterion.
Traffic rule view
object-group-name: Specifies an IPv4 or IPv6 address object group by its name, a case-insensitive string of 1 to 63 characters.
This command is used to match the packets with the destination IP addresses in the specified address object group. You can specify multiple address object groups for a traffic rule to match destination IP addresses of packets.
Before rolling back configuration by using the configuration replace file filename command, check the address object group configuration in the traffic rule in the configuration file. The address object group configuration fails to be rolled back if two address object groups have the same name but are of different types (IPv4/IPv6).
# Configure IPv4 address object group obgroup2 for traffic rule rule1 to match destination IPv4 addresses of packets.
[Sysname-traffic-policy-rule-rule1] destination-address address-set obgroup2
object-group (Security Command Reference)
destination-zone
Use destination-zone to configure a destination security zone as a match criterion.
Use undo destination-zone to delete a destination security zone match criterion.
destination-zone destination-zone-name
undo destination-zone destination-zone-name
No destination security zone is used as a match criterion.
Traffic rule view
destination-zone-name: Specifies a destination zone by its name, a case-insensitive string of 1 to 31 characters.
# Configure destination security zone zone2 as a match criterion for traffic rule rule1.
[Sysname-traffic-policy-rule-rule1] destination-zone zone2
security-zone name (Security Command Reference)
disable
Use disable to disable a traffic rule.
Use undo disable to enable a traffic rule.
disable
undo disable
A traffic rule is enabled.
Traffic rule view
If a traffic rule is not used, use this command to disable it. A disabled traffic rule does not participate in traffic matching. You can copy, rename, and move a disabled traffic rule.
# Disable traffic rule rule1.
[Sysname-traffic-policy-rule-rule1] disable
Use display traffic-policy statistics bandwidth to display traffic statistics for traffic rules.
In standalone mode:
display traffic-policy statistics bandwidth { downstream | total | upstream } { per-ip { ipv4 [ ipv4-address ] | ipv6 [ ipv6-address ] } rule rule-name | per-rule [ name rule-name ] | per-user [ user user-name ] rule rule-name }
In IRF mode:
display traffic-policy statistics bandwidth { downstream | total | upstream } { per-ip { ipv4 [ ipv4-address ] | ipv6 [ ipv6-address ] } rule rule-name | per-rule [ name rule-name ] | per-user [ user user-name ] rule rule-name } [ slot slot-number ]
downstream: Displays downstream traffic statistics.
total: Displays the sum of downstream traffic statistics and upstream traffic statistics.
upstream: Displays upstream traffic statistics.
per-ip: Displays per-IP traffic statistics.
ipv4: Displays per-IP traffic statistics for IPv4 addresses.
ipv4-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays per-IP traffic statistics for all IPv4 addresses of the specified traffic rule.
ipv6: Displays per-IP traffic statistics for IPv6 addresses.
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays per-IP traffic statistics for all IPv6 addresses of the specified traffic rule.
rule rule-name: Specifies a traffic rule by its name, a case-insensitive string of 1 to 63 characters.
per-rule: Displays per-rule traffic statistics.
name rule-name: Specifies a traffic rule by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a traffic rule, this command displays per-rule traffic statistics for all traffic rules.
per-user: Displays per-user traffic statistics.
user user-name: Specifies a user by its name, a case-insensitive string of 1 to 55 characters. If you do not specify a user, this command displays per-user traffic statistics for all users of the specified traffic rule.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays traffic statistics for all member devices. (In IRF mode.)
Before displaying traffic statistics, you must execute the statistics bandwidth enable command.
You can identify whether a traffic rule works as configured by displaying the traffic statistics for the traffic rule.
# (In standalone mode.) Display per-rule upstream traffic statistics for traffic rule traffic-rule.
<Sysname> display traffic-policy statistics bandwidth upstream per-rule name traffic-rule
Codes: PP(Passed Packets), PB(Passed Bytes), DP(Dropped Packets), DB(Dropped Bytes), PR(Passed Rate:kbps), DR(Drop Rate:kbps), FPP(Final Passed Packets), FPB(Final Passed Bytes), FPR(Final Passed Rate:kbps)
Rule name State Profile name PP PB DP DB PR DR FPP FPB FPR
traffic-rule Enabled profile1 726 7550 4 2961 703 497 595 6632 664.1
# (In IRF mode.) Display per-rule upstream traffic statistics for traffic rule traffic-rule.
Slot 1:
# (In standalone mode.) Display per-IP upstream traffic statistics for all IPv4 addresses in traffic rule traffic-rule.
<Sysname> display traffic-policy statistics bandwidth upstream per-ip ipv4 rule traffic-rule
Rule name State IP PP PB DP DB PR DR FPP FPB FPR
traffic-rule Enabled 1.1.1.1 726 75502 4 2961 703.3 497 595 6632 664.1
traffic-rule2 Enabled 1.1.1.5 756 74502 4 2901 712 488 595 6632 664.1
traffic-rule3 Enabled 1.1.1.8 756 74502 4 2951 712 488 595 6632 664.1
# (In IRF mode.) Display per-IP upstream traffic statistics for all IPv4 addresses in traffic rule traffic-rule.
Slot 1:
Codes |
Acronyms for fields: · PP(Passed Packets)—Number of packets permitted by the traffic rule. · PB(Passed Bytes)—Number of bytes permitted by the traffic rule. · DP(Dropped Packets)—Number of packets dropped by the traffic rule. · DB(Dropped Bytes)—Number of bytes dropped by the traffic rule. · PR(Passed Rate:kbps)—Rate of packets permitted by the traffic rule, in kbps. · DR(Drop Rate:kbps)—Rate of packets dropped by the traffic rule, in kbps. · FPP(Final Passed Packets)—Number of packets permitted by both the traffic rule and interface bandwidth. · FPB(Final Passed Bytes)—Number of bytes permitted by both the traffic rule and interface bandwidth. · FPR(Final Passed Rate:kbps)—Rate of packets permitted by both the traffic rule and interface bandwidth, in kbps. In the case of rule nesting, the actual values of the FPP, FPB, and FPR fields are displayed only if you specify the lowest-level traffic rule in the display traffic-policy statistics bandwidth command. If you specify a non-lowest-level traffic rule, the value 0 is displayed for these fields. |
Use display traffic-policy statistics connection-limit to display connection limit statistics.
In standalone mode:
display traffic-policy statistics connection-limit { per-ip { ipv4 [ ipv4-address ] | ipv6 [ ipv6-address ] } rule rule-name | per-rule [ name rule-name ] | per-user [ user user-name ] rule rule-name } }
In IRF mode:
display traffic-policy statistics connection-limit { per-ip { ipv4 [ ipv4-address ] | ipv6 [ ipv6-address ] } rule rule-name | per-rule [ name rule-name ] | per-user [ user user-name ] rule rule-name } } [ slot slot-number ]
per-ip: Displays per-IP connection limit statistics.
ipv4: Displays per-IP connection limit statistics for IPv4 addresses.
ipv4-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays connection limit statistics for all IPv4 addresses of the specified traffic rule.
ipv6: Displays per-IP connection limit statistics for IPv6 addresses.
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays connection limit statistics for all IPv6 addresses of the specified traffic rule.
per-rule: Displays per-rule connection limit statistics.
name rule-name: Specifies a traffic rule by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a traffic rule, this command displays per-rule connection limit statistics for all traffic rules.
per-user: Displays per-user connection limit statistics.
user user-name: Specifies a user by its name, a case-insensitive string of 1 to 55 characters. If you do not specify a user, this command displays per-user connection limit statistics for all users of the specified traffic rule.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays connection limit statistics for all member devices. (In IRF mode.)
Before displaying connection limit statistics, you must execute the statistics connection-limit enable command.
You can identify whether a traffic rule works as configured by displaying the connection limit statistics for the traffic rule.
# (In standalone mode.) Display per-IP connection limit statistics for traffic rule traffic-rule.
<Sysname> display traffic-policy statistics connection-limit per-ip ipv4 rule traffic-rule
Codes: CC(Current Connection), RC(Rejective Connection), CL(Current Limit), RRC(Rate Rejective Connection), RR(Rejective Rate), PR(Pass Rate)
Rule name State Profile name IP CC RC CL RRC RR PR
traffic-rule Enabled profile1 1.1.1.1 200 300 200 200 300 200
# (In IRF mode.) Display per-IP connection limit statistics for traffic rule traffic-rule.
Slot 1:
# (In standalone mode.) Display per-rule connection limit statistics for traffic rule traffic-rule.
<Sysname> display traffic-policy statistics connection-limit per-rule name traffic-rule
Rule name State Profile name CC RC CL RRC RR PR
traffic-rule Enabled profile1 200 300 200 200 300 200
# (In IRF mode.) Display per-rule connection limit statistics for traffic rule traffic-rule.
Slot 1:
# (In standalone mode.) Display per-user connection limit statistics for all users of traffic rule traffic-rule.
<Sysname> display traffic-policy statistics connection-limit per-user rule traffic-rule
Rule name State Profile name User ID User name CC RC CL RRC RR PR
traffic-rule Enabled profile1 0x3d user1 200 300 200 200 300 200
# (In IRF mode.) Display per-user connection limit statistics for all users of traffic rule traffic-rule.
Slot 1:
Codes |
Acronyms for fields: · CC (current connections)—Number of current connections. · RC (rejected connections)—Number of connections rejected after the number of current connections reached the limit. · CL (connection limit)—Maximum number of connections allowed. · RRC(Rate Rejective Connection)—Number of connections rejected after the connection establishment rate reached the limit. · RR(Rejective Rate)—Rate of connections rejected, in connections per second. · PR(Pass Rate)—Rate of connections established, in connections per second. |
Use display traffic-policy statistics rule-hit to display rule-hit statistics.
In standalone mode:
display traffic-policy statistics rule-hit [ rule rule-name ]
In IRF mode:
display traffic-policy statistics rule-hit [ rule rule-name ] [ slot slot-number ]
rule rule-name: Specifies a traffic rule by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a traffic rule, this command displays rule-hit statistics for all traffic rules.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays rule-hit statistics for all member devices. (In IRF mode.)
Before displaying rule-hit statistics, you must execute the statistics rule-hit enable command.
# (In standalone mode.) Display rule-hit statistics for all traffic rules.
<Sysname> display traffic-policy statistics rule-hit
Rule ID Rule name State Profile ID Profile name Hit
201 traffic-rule Enabled 21 profile1 11111
202 traffic-rule1 Enabled 22 profile2 11112
203 traffic-rule2 Enabled 23 profile1 11565
# (In IRF mode.) Display rule-hit statistics for all traffic rules.
Slot 1:
Hit |
Number of times that a rule is matched. |
dscp
Use dscp to configure a DSCP priority as a match criterion.
Use undo dscp to remove all DSCP priority match criteria.
dscp dscp-value
undo dscp dscp-value
No DSCP priority is used as a match criterion.
Traffic rule view
dscp-value: Specifies a DSCP priority, which can only be a keyword in Table 4.
Keyword |
DSCP value (binary) |
DSCP value (decimal) |
default |
000000 |
0 |
af11 |
001010 |
10 |
af12 |
001100 |
12 |
af13 |
001110 |
14 |
af21 |
010010 |
18 |
af22 |
010100 |
20 |
af23 |
010110 |
22 |
af31 |
011010 |
26 |
af32 |
011100 |
28 |
af33 |
011110 |
30 |
af41 |
100010 |
34 |
af42 |
100100 |
36 |
af43 |
100110 |
38 |
cs1 |
001000 |
8 |
cs2 |
010000 |
16 |
cs3 |
011000 |
24 |
cs4 |
100000 |
32 |
cs5 |
101000 |
40 |
cs6 |
110000 |
48 |
cs7 |
111000 |
56 |
ef |
101110 |
46 |
# Configure DSCP priority af11 as a match criterion in traffic rule rule1.
[Sysname-traffic-policy-rule-rule1] dscp af11
ipv6 extension-header
Use ipv6 extension-header to configure the IPv6 extension header attribute as a match criterion.
Use undo ipv6 extension-header to delete an extension header match criterion.
ipv6 extension-header { authentication | destination | encapsulating | fragment | hop-by-hop | routing }
The IPv6 extension header attribute is not used as a match criterion.
Traffic rule view
nonzero: Specifies the Authentication header.
destination: Specifies the Destination Options header.
encapsulating: Specifies the Encapsulating Security Payload header.
fragment: Specifies the Fragment header.
hop-by-hop: Specifies the Hop-by-Hop Options header.
routing: Specifies the Routing header.
This command enables the device to perform bandwidth management on the IPv6 packets with the specified extension header. For more information about extension headers, see RFC 2460.
# Configure the Destination Options header as a match criterion in traffic rule rule1.
[Sysname-traffic-policy-rule-rule1] ipv6 extension-header destination
ipv6 flow-label
ipv6 flow-label
Use ipv6 flow-label to configure the IPv6 flow label attribute as a match criterion.
Use undo ipv6 flow-label to delete a flow label match criterion.
ipv6 flow-label { nonzero | zero }
The IPv6 flow label attribute is not used as a match criterion.
Traffic rule view
nonzero: Specifies non-zero IPv6 flow labels.
zero: Specifies the zero IPv6 flow label.
The Flow Label field in IPv6 packet headers is used to identify packets of a flow. This command enables the device to perform bandwidth management on the IPv6 packets with the specified flow label value. For more information about the Flow Label field, see RFC 2460.
# Configure a flow label value of zero as a match criterion in traffic rule rule1.
[Sysname-traffic-policy-rule-rule1] ipv6 flow-label zero
Use per-ip bandwidth-threshold max-value to set the per-IP static maximum bandwidth threshold.
Use undo per-ip bandwidth-threshold max-value to restore the default.
per-ip bandwidth-threshold max-value max-value
The per-IP static maximum bandwidth threshold is not set.
max-value: Specifies the maximum bandwidth threshold in the range of 8 to 1000000000 kbps.
When the device detects that the traffic rate of an IP address exceeds the maximum bandwidth threshold, it sends logs to the log host by using the fast log output feature.
If you configure both the per-IP static maximum bandwidth threshold and the per-IP dynamic threshold learning feature, the following rules apply:
· Before the device learns the average traffic rate, it uses the static maximum bandwidth threshold.
· After the device learns the average traffic rate, it uses the average traffic rate multiplied by the maximum tolerance value as the maximum bandwidth threshold.
# In traffic profile news, set the per-IP static maximum bandwidth threshold to 50000 kbps.
[Sysname-traffic-policy] profile name news
[Sysname-traffic-policy-profile-news] per-ip bandwidth-threshold max-value 50000
Use per-ip bandwidth-threshold min-value to set the per-IP static minimum bandwidth threshold.
Use undo per-ip bandwidth-threshold min-value to restore the default.
per-ip bandwidth-threshold min-value min-value
The per-IP static minimum bandwidth threshold is not set.
min-value: Specifies the minimum bandwidth threshold in the range of 8 to 100000000 kbps.
When the device detects that the traffic rate of an IP address falls below the minimum bandwidth threshold, it sends logs to the log host by using the fast log output feature.
If you configure both the per-IP static minimum bandwidth threshold and the per-IP dynamic threshold learning feature, the following rules apply:
· Before the device learns the average traffic rate, it uses the static minimum bandwidth threshold.
· After the device learns the average traffic rate, it uses the average traffic rate multiplied by the minimum tolerance value as the minimum bandwidth threshold.
# In traffic profile news, set the per-IP static minimum bandwidth threshold to 500 kbps.
[Sysname-traffic-policy-profile-news] per-ip bandwidth-threshold min-value 500
Use per-ip bandwidth-threshold-detect enable to enable per-IP bandwidth threshold detection.
Use undo per-ip bandwidth-threshold-detect enable to disable per-IP bandwidth threshold detection.
Per-IP bandwidth threshold detection is disabled.
This command enables the device to monitor the traffic rates based on source IP addresses in real time to identify the maximum rate and minimum rate of each IP address.
# In traffic profile news, enable per-IP bandwidth threshold detection.
[Sysname-traffic-policy-profile-news] per-ip bandwidth-threshold-detect enable
Use per-ip bandwidth-threshold-learn duration to set the learning duration for per-IP dynamic threshold learning.
Use undo per-ip bandwidth-threshold-learn duration to restore the default.
per-ip bandwidth-threshold-learn duration duration-value
The learning duration is 1440 minutes.
duration-value: Specifies the learning duration in the range of 1 to 10080 minutes.
After per-IP bandwidth threshold detection is enabled, the device measures the traffic rates over a user-configured duration and calculates an average rate. As a best practice, set the learning duration to be longer than 1440 minutes for the device to learn the traffic for no less than a whole day. After a learning duration ends, for the device to learn traffic again, disable and then re-enable dynamic threshold learning. The device will clear the previous learning results and perform a new learning process based on the same duration.
If you modify the duration during the learning process, the device starts a new learning process with the new duration.
# In traffic profile news, set the learning duration for per-IP dynamic threshold learning to 2880 minutes.
[Sysname-traffic-policy-profile-news] per-ip bandwidth-threshold-learn duration 2880
Use per-ip bandwidth-threshold-learn enable to enable per-IP dynamic bandwidth threshold learning.
Use undo per-ip bandwidth-threshold-learn enable to disable per-IP dynamic bandwidth threshold learning.
Per-IP dynamic bandwidth threshold learning is disabled.
Dynamic bandwidth threshold learning is useful if you do not know the traffic patterns in a network and cannot determine appropriate bandwidth thresholds. With this feature enabled, the device measures the traffic rates over a user-configured duration and calculates an average rate. Then, the device obtains the minimum and maximum bandwidth thresholds by using the average rate multiplied by the minimum and maximum tolerance values.
If you configure both static bandwidth thresholds and the dynamic threshold learning feature for a traffic profile, the following rules apply:
· Before the device learns the average traffic rate, it uses the static bandwidth thresholds.
· After the device learns the average traffic rate, it uses the dynamic bandwidth thresholds.
# In traffic profile news, enable per-IP dynamic bandwidth threshold learning.
[Sysname-traffic-policy-profile-news] per-ip bandwidth-threshold-learn enable
Use per-ip bandwidth-threshold-learn tolerance max-value to set the maximum tolerance value for per-IP dynamic bandwidth threshold learning.
Use undo per-ip bandwidth-threshold-learn tolerance max-value to restore the default.
per-ip bandwidth-threshold-learn tolerance max-value max-value
The maximum tolerance value is not set.
max-value: Specifies the maximum tolerance value in the range of 1 to 4000, in percentage.
The per-IP dynamic threshold learning feature uses the learned average traffic rate to multiply the maximum tolerance value to obtain the maximum bandwidth threshold. If you also configure a static maximum bandwidth threshold for the traffic profile, the dynamic maximum bandwidth threshold is used after the average traffic rate is learned.
# In traffic profile news, set the maximum tolerance value for per-IP dynamic bandwidth threshold learning to 200.
[Sysname-traffic-policy-profile-news] per-ip bandwidth-threshold-learn tolerance max-value 200
Use per-ip bandwidth-threshold-learn tolerance min-value to set the minimum tolerance value for per-IP dynamic bandwidth threshold learning.
Use undo per-ip bandwidth-threshold-learn tolerance min-value to restore the default.
per-ip bandwidth-threshold-learn tolerance min-value min-value
The minimum tolerance value is not set.
min-value: Specifies the minimum tolerance value in the range of 1 to 4000, in percentage.
The per-IP dynamic threshold learning feature uses the learned average traffic rate to multiply the minimum tolerance value to obtain the minimum bandwidth threshold. If you also configure a static minimum bandwidth threshold for the traffic profile, the dynamic minimum bandwidth threshold is used after the average traffic rate is learned.
# In traffic profile news, set the minimum tolerance value for per-IP dynamic bandwidth threshold learning to 50.
[Sysname-traffic-policy-profile-news] per-ip bandwidth-threshold-learn tolerance min-value 50
profile name
Use profile name to create a traffic profile and enter its view, or enter the view of an existing traffic profile.
Use undo profile name to delete a traffic profile.
profile name profile-name
undo profile name profile-name
No traffic profile exists.
Traffic policy view
profile-name: Specifies a name for the traffic profile, a case-insensitive string of 1 to 63 characters.
A traffic profile defines the bandwidth resources that can be used and takes effect after it is specified for a traffic rule.
# Create a traffic profile named profile1 and enter traffic profile view.
action
profile reference-mode
Use profile reference-mode to set the reference mode for a traffic profile.
Use undo profile reference-mode to restore the default.
profile reference-mode { per-rule | rule-shared }
The reference mode for a traffic profile is per-rule.
per-rule: Specifies that each traffic rule that uses the traffic profile can reach the bandwidth limits and connection limits specified in the profile.
rule-shared: Specifies that all traffic rules that use the traffic profile share the bandwidth limits and connection limits specified in the profile.
After a traffic profile is specified for a traffic rule, the bandwidth limits and connection limits in the profile take effect. The reference mode for a traffic profile can be per-rule or rule-shared.
# Set the reference mode to rule-shared for traffic profile profile1.
[Sysname-traffic-policy-profile-profile1] profile reference-mode rule-shared
profile rename
Use profile rename to rename a traffic profile.
profile rename old-name new-name
Traffic policy view
old-name: Specifies the old name of the traffic profile, a case-insensitive string of 1 to 63 characters.
new-name: Specifies a new name for the traffic profile, a case-insensitive string of 1 to 63 characters. The new name cannot be an existing traffic profile name.
# Create a traffic profile named profile1, and rename traffic profile profile1 as profile2.
[Sysname-traffic-policy-profile-profile1] quit
[Sysname-traffic-policy] profile rename profile1 profile2
remark dscp
Use remark dscp to mark the DSCP priority for packets of a traffic profile.
Use undo remark dscp to restore the default.
remark dscp dscp-value
undo remark dscp
The DSCP priority for packets of a traffic profile is not marked.
Network devices can classify traffic by using DSCP priorities and provide different treatment for packets with different DSCP priorities.
# Mark DSCP priority af22 for packets of traffic profile profile1.
[Sysname-traffic-policy-profile-profile1] remark dscp af22
profile name
Use reset traffic-policy statistics bandwidth to clear traffic statistics for traffic rules.
In standalone mode:
reset traffic-policy statistics bandwidth { downstream | total | upstream } { per-ip { ipv4 [ ipv4-address ] | ipv6 [ ipv6-address ] } rule rule-name | per-rule [ name rule-name ] | per-user [ user user-name ] rule rule-name }
In IRF mode:
reset traffic-policy statistics bandwidth { downstream | total | upstream } { per-ip { ipv4 [ ipv4-address ] | ipv6 [ ipv6-address ] } rule rule-name | per-rule [ name rule-name ] | per-user [ user user-name ] rule rule-name } [ slot slot-number ]
downstream: Specifies downstream traffic.
upstream: Specifies upstream traffic.
per-ip: Clears per-IP traffic statistics.
ipv4: Clears per-IP traffic statistics for IPv4 addresses.
ipv4-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command clears per-IP traffic statistics for all IPv4 addresses of the specified traffic rule.
ipv6: Clears per-IP traffic statistics for IPv6 addresses.
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command clears per-IP traffic statistics for all IPv6 addresses of the specified traffic rule.
per-rule: Clears per-rule traffic statistics.
name rule-name: Specifies a traffic rule by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a traffic rule, this command clears per-rule traffic statistics for all traffic rules.
per-user: Clears per-user traffic statistics.
user user-name: Specifies a user by its name, a case-insensitive string of 1 to 55 characters. If you do not specify a user, this command clears per-user traffic statistics for all users of the specified traffic rule.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears traffic statistics for all member devices. (In IRF mode.)
# (In standalone mode.) Clear per-rule upstream traffic statistics for traffic rule traffic-rule.
<Sysname> reset traffic-policy statistics bandwidth upstream per-rule name traffic-rule
# (In IRF mode.) Clear per-rule upstream traffic statistics for traffic rule traffic-rule on a slot.
<Sysname> reset traffic-policy statistics bandwidth upstream per-rule name traffic-rule slot 1
Use reset traffic-policy statistics connection-limit to clear connection limit statistics.
In standalone mode:
reset traffic-policy statistics connection-limit { per-ip { ipv4 [ ipv4-address ] | ipv6 [ ipv6-address ] } rule rule-name | per-rule [ name rule-name ] | per-user [ user user-name ] rule rule-name } }
In IRF mode:
reset traffic-policy statistics connection-limit { per-ip { ipv4 [ ipv4-address ] | ipv6 [ ipv6-address ] } rule rule-name | per-rule [ name rule-name ] | per-user [ user user-name ] rule rule-name } } [ slot slot-number ]
per-ip: Clears per-IP connection limit statistics.
ipv4: Clears per-IP connection limit statistics for IPv4 addresses.
ipv4-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command clears connection limit statistics for all IPv4 addresses of the specified traffic rule.
ipv6: Clears per-IP connection limit statistics for IPv6 addresses.
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command clears connection limit statistics for all IPv6 addresses of the specified traffic rule.
per-rule: Clears per-rule connection limit statistics.
name rule-name: Specifies a traffic rule by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a traffic rule, this command clears per-rule connection limit statistics for all traffic rules.
per-user: Clears per-user connection limit statistics.
user user-name: Specifies a user by its name, a case-insensitive string of 1 to 55 characters. If you do not specify a user, this command clears per-user connection limit statistics for all users of the specified traffic rule.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears connection limit statistics for all member devices. (In IRF mode.)
# (In standalone mode.) Clear per-rule connection limit statistics for traffic rule traffic-rule.
<Sysname> reset traffic-policy statistics connection-limit per-rule name traffic-rule
# (In IRF mode.) Clear per-rule connection limit statistics for traffic rule traffic-rule on a slot.
<Sysname> reset traffic-policy statistics connection-limit per-rule name traffic-rule slot 1
Use reset traffic-policy statistics rule-hit to clear rule-hit statistics.
In standalone mode:
reset traffic-policy statistics rule-hit [ rule rule-name ]
In IRF mode:
reset traffic-policy statistics rule-hit [ rule rule-name ] [ slot slot-number ]
rule rule-name: Specifies a traffic rule by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a traffic rule, this command clears rule-hit statistics for all traffic rules.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears rule-hit statistics for all member devices. (In IRF mode.)
# (In standalone mode.) Clear rule-hit statistics for traffic rule traffic-rule.
<Sysname> reset traffic-policy statistics rule-hit rule traffic-rule
# (In IRF mode.) Clear rule-hit statistics for traffic rule traffic-rule on a slot.
<Sysname> reset traffic-policy statistics rule-hit rule traffic-rule slot 1
rule
Use rule to create a traffic rule and enter its view, or enter the view of an existing traffic rule.
Use undo rule to delete a traffic rule.
rule rule-id
rule [ rule-id ] name rule-name [ parent parent-rule-name ]
undo rule { rule-id | name rule-name }
No traffic rule exists.
Traffic policy view
rule-id: Specifies an ID for the traffic rule, in the range of 1 to 65534. If you do not specify a rule ID, the system assigns the unused ID next to the ID used last time. If the rule ID to be assigned is greater than 65534, the system assigns the smallest available rule ID.
rule-name: Specifies a name for the traffic rule, a case-insensitive string of 1 to 63 characters. You must specify a rule name when creating a traffic rule.
parent parent-rule-name: Specifies a parent traffic rule by its name, a case-insensitive string of 1 to 63 characters. To successfully create the traffic rule, make sure the parent traffic rule already exists.
You can configure multiple traffic rules in the traffic policy. For a traffic rule, you can configure match criteria to match packets and specify the traffic profile to apply to matching packets. The device matches traffic rules in their order of appearance on the device. When a traffic rule is matched, the matching process ends and the device applies the traffic profile for the traffic rule to the traffic. If no traffic rule is matched, the device forwards the traffic.
For a new traffic rule to inherit the match criteria of an existing traffic rule, specify the existing traffic rule as the parent of the new traffic rule.
A level-4 rule cannot act as a parent rule
You can specify a parent traffic rule only when creating a traffic rule. You cannot add or modify a parent traffic rule for an existing traffic rule.
# Create a traffic rule with ID 111 and name rule1 and enter traffic rule view.
[Sysname-traffic-policy] rule 111 name rule1
[Sysname-traffic-policy-rule-111-rule1]
rule copy
Use rule copy to copy a traffic rule.
rule copy rule-name new-rule-name
Traffic policy view
rule-name: Specifies a traffic rule to be copied by its name, a case-insensitive string of 1 to 63 characters.
new-rule-name: Specifies a name for the new traffic rule, a case-insensitive string of 1 to 63 characters. The new name cannot be an existing traffic profile name.
If a traffic rule to be created is similar to an existing traffic rule, create the traffic rule by copying the existing traffic rule and then modify it. The new traffic rule is placed next to the copied traffic rule.
If a traffic rule to be copied has child traffic rules, only the parent traffic rule is copied.
# Create a traffic rule named rule2 by copying traffic rule rule1.
[Sysname-traffic-policy] rule copy rule1 rule2
rule move
Use rule move to move a traffic rule to a new position.
rule move rule-name1 { after | before } rule-name2
Traffic policy view
rule-name1: Specifies a traffic rule to be moved by its name, a case-insensitive string of 1 to 63 characters. The traffic rule can be a parent or child traffic rule.
after: Moves the specified traffic rule to the position after a target traffic rule.
before: Moves the specified traffic rule to the position before a target traffic rule.
rule-name2: Specifies the target traffic rule by its name, a case-insensitive string of 1 to 63 characters.
The device matches traffic with traffic rules in their order of appearance on the device. When a traffic rule is matched, the matching process ends and the device applies the traffic profile specified for the traffic rule to the traffic. If no traffic rule is matched, the device forwards the traffic.
To ensure reasonable, precise bandwidth management, configure traffic rules in ascending order of granularity. If the traffic rules are not in ascending order of granularity, you can use the rule move command to change the position of them.
You can move child traffic rules only within their parent traffic rule.
# Create two traffic rules named rule1 and rule2, and move rule1 to the position after rule2.
[Sysname-traffic-policy-rule-rule1] quit
[Sysname-traffic-policy] rule name rule2
[Sysname-traffic-policy-rule-rule2] quit
[Sysname-traffic-policy] rule move rule1 after rule2
rule rename
Use rule rename to rename a traffic rule.
rule rename old-rule-name new-rule-name
Traffic policy view
old-rule-name: Specifies the old name of the traffic rule, a case-insensitive string of 1 to 63 characters.
new-rule-name: Specifies a new name for the traffic rule, a case-insensitive string of 1 to 63 characters. The new name cannot be an existing traffic profile name.
# Create a traffic rule named rule1, and rename traffic rule rule1 as rule2.
[Sysname-traffic-policy] rule rename rule1 rule2
service
Use service to configure a service object group as a match criterion.
Use undo service to delete a service object group match criterion.
service object-group-name
undo service [ object-group-name ]
No service object group is used as a match criterion.
Traffic rule view
object-group-name: Specifies a service object group by its name, a case-insensitive string of 1 to 63 characters.
You can specify multiple service object groups for a traffic rule to match packets.
The undo service command removes all service object groups from match criteria if you do not specify a service object group or specify the system-defined service object group any.
# Specify predefined service object group ftp for traffic rule rule1 to match packets.
[Sysname-traffic-policy-rule-rule1] service ftp
source-address
Use source-address to configure a source IP address object group as a match criterion.
Use undo source-address to delete a source IP address object group as a match criterion.
source-address address-set object-group-name
undo source-address address-set object-group-name
No source IP address object group is used as a match criterion.
Traffic rule view
This command is used to match the packets with the source IP addresses in the specified address object group. You can specify multiple address object groups for a traffic rule to match source IP addresses of packets.
# Specify IPv4 address object group obgroup1 for traffic rule rule1 to match source IPv4 addresses of packets.
[Sysname-traffic-policy-rule-rule1] source-address address-set obgroup1
source-zone
Use source-zone to configure a source security zone as a match criterion.
Use undo source-zone to delete a source security zone match criterion.
source-zone source-zone-name
undo source-zone source-zone-name
No source security zone is used as a match criterion.
Traffic rule view
source-zone-name: Specifies a source zone by its name, a case-insensitive string of 1 to 31 characters.
# Configure source security zone zone1 as a match criterion in traffic rule rule1.
[Sysname-traffic-policy-rule-rule1] source-zone zone1
Use statistics bandwidth enable to enable traffic statistics collection.
Use undo statistics bandwidth enable to disable traffic statistics collection.
Traffic statistics collection is disabled.
Traffic policy view
This command enables the device to collect statistics about matching traffic. To view the statistics, use the display traffic-policy statistics bandwidth command.
This command affects device performance. As a best practice, configure this command only if you need to view statistics.
# Enable traffic statistics collection.
[Sysname-traffic-policy] statistics bandwidth enable
Use statistics connection-limit enable to enable connection limit statistics collection.
Use undo statistics connection-limit enable to disable connection limit statistics collection.
Connection limit statistics collection is disabled.
Traffic policy view
This command enables the device to collect statistics about matching connections. To view the statistics, use the display traffic-policy statistics connection-limit command.
# Enable connection limit statistics collection.
[Sysname-traffic-policy] statistics connection-limit enable
Use statistics rule-hit enable to enable rule-hit statistics collection.
Use undo statistics rule-hit enable to disable rule-hit statistics collection.
Rule-hit statistics collection is disabled.
Traffic policy view
This command enables the device to collect rule-hit statistics. To view the statistics, use the display traffic-policy statistics rule-hit command.
# Enable rule-hit statistics collection.
[Sysname-traffic-policy] statistics rule-hit enable
tcp mss
Use tcp mss to set the TCP maximum segment size (MSS).
Use undo tcp mss to restore the default.
tcp mss mss-value
undo tcp mss
The TCP MSS is not set.
mss-value: Specifies the TCP MSS in the range of 128 to 9158 bytes.
The MSS specifies the maximum size of TCP segments that the peer device can send to the local device. It is negotiated during TCP connection establishment. When establishing a TCP connection, the local device advertises the MSS to the peer device. The peer device does not send TCP packets greater than the MSS. For TCP packets that exceed the MSS, the peer device fragments them before sending them.
This command takes effect only on new TCP connections and does not take effect on existing TCP connections.
This command takes effect only on IP packets. If MPLS is configured, do not set the MSS.
If you configure the MSS in both traffic profile view and interface view, the smaller MSS value takes effect.
# Set the TCP MSS to 128 bytes for traffic profile profile1.
[Sysname-traffic-policy-profile–profile1] tcp mss 128
tcp mss (Layer 3—IP Services Command Reference)
terminal
Use terminal to configure a terminal as a match criterion.
Use undo terminal to delete a terminal match criterion.
terminal terminal-name
undo terminal terminal-name
No terminal is used as a match criterion.
Traffic rule view
Predefined terminal roles
terminal-name: Specifies a terminal by its name, a case-insensitive string of 1 to 63 characters. The names invalid and other are not supported.
You can execute this command multiple times to specify multiple terminals for a traffic rule to match packets.
# Configure terminal terminaltest as a match criterion in traffic rule news.
[Sysname-traffic-policy] rule name news
[Sysname-traffic-policy-rule-news] terminal terminaltest
terminal-group
terminal-group
Use terminal-group to configure a terminal group as a match criterion.
Use undo terminal-group to delete a terminal group match criterion.
terminal-group group-name
undo terminal-group group-name
No terminal group is used as a match criterion.
Traffic rule view
Predefined terminal-group roles
group-name: Specifies a terminal group by its name, a case-insensitive string of 1 to 63 characters. The names invalid and other are not supported.
You can execute this command multiple times to specify multiple terminal groups for a traffic rule to match packets.
# Configure terminal group terminalgrouptest as a match criterion in traffic rule news.
[Sysname-traffic-policy-rule-news] terminal-group terminalgrouptest
terminal
time-range
Use time-range to specify a time range during which a traffic rule is in effect.
Use undo time-range to restore the default.
time-range time-range-name
undo time-range
A traffic rule is in effect at any time.
Traffic rule view
time-range-name: Specifies a time range by its name, a case-insensitive string of 1 to 32 characters.
# Specify time range work-time for traffic rule rule1.
[Sysname-traffic-policy-rule-rule1] time-range work-time
time-range (ACL and QoS Command Reference)
traffic-policy
Use traffic-policy to enter traffic policy view.
Use undo traffic-policy to remove all traffic policy settings.
traffic-policy
undo traffic-policy
In traffic policy view, you can create and manage traffic rules.
# Enter traffic policy view.
traffic-priority
Use traffic-priority to set the traffic priority for a traffic profile.
Use undo traffic-priority to restore the default.
traffic-priority priority-value
The traffic priority is 1 for a traffic profile.
priority-value: Specifies the priority value in the range of 1 to 7. The larger the priority value, the higher the priority.
When an interface is congested with packets of multiple traffic profiles, packets with higher priority are sent first. Packets with the same priority have the same chance of being forwarded.
# Set the traffic priority to 7 for traffic profile profile1.
[Sysname-traffic-policy-profile-profile1] traffic-priority 7
profile name
