08-Customizable IVR commands | 115.02 KB |
The following compatibility matrixes show the support of hardware platforms for customizable IVR:
Hardware |
Customizable IVR compatibility |
MSR610 |
No |
Yes |
MSR810-LMS, MSR810-LUS |
No |
MSR810-SI, MSR810-LM-SI |
No |
MSR810-LMS-EA, MSR810-LME |
No |
MSR1004S-5G |
No |
No |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
Yes |
No |
No |
No |
No |
Yes |
Yes |
MSR3610-G, MSR3620-G |
No |
MSR3640-X1-HI |
Yes |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
MSR2600-6-WiNet |
No |
MSR2600-10-X1-WiNet |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
No |
MSR860-6HI-XS |
No |
MSR2630-XS |
No |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
No |
MSR3600-28-SI-GL |
No |
To support customizable IVR, some device models require the Voice Software License. For more information, see license management in Fundamentals Configuration Guide.
call-normal
Use call-normal to configure the number match mode for normal secondary calls.
Use undo call-normal to restore the default.
call-normal { length number-length | matching | terminator character }
undo call-normal
No number match mode for normal secondary calls exists.
Call node view
length number-length: Specifies the length of called numbers to be matched, in the range of 1 to 31.
matching: Specifies the longest match.
terminator character: Specifies a terminator, a single character that can be a digit 0 through 9, pound sign (#), or asterisk (*).
Do not configure a character included in a called number as a terminator.
# Configure node 1 to match 7-digit called numbers for normal secondary calls.
[Sysname] voice-setup
[Sysname-voice] ivr-system
[Sysname-voice-ivr] node 1 call
[Sysname-voice-ivr-node1] call-normal length 7
description
Use description to configure a description for a node.
No description exists.
Call node view
Jump node view
Service node view
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
# Configure a description of first-node for jump node 1.
[Sysname-voice-ivr] node 1 jump
[Sysname-voice-ivr-node1] description first-node
dial-prefix
Use dial-prefix to configure a dial prefix for a call node.
Use undo dial-prefix to restore the default.
dial-prefix string
undo dial-prefix
No dial prefix exists.
Call node view
string: Specifies a dial prefix, a string of 1 to 31 characters. Valid characters are digits 0 through 9, pound sign (#), and asterisk (*).
Table 1 Description of characters in the string argument
Character |
0-9 |
Digits 0 through 9. |
Pound sign (#) or asterisk (*) |
Indicates a valid digit. |
After you configure a dial prefix, the device adds the prefix before each called number. If the called number plus the added prefix exceed 31 digits, the device sends only the first 31 digits.
# Specify 021 as the dial prefix for call node 1.
[Sysname-voice-dial-node1] dial-prefix 021
display voice ivr call-info
Use display voice ivr call-info to display IVR call information.
# Display IVR call information.
<Sysname> display voice ivr call-info
Index Called-Number Caller-Number Entity Node-Id Status
1 101 100 101 1 PLAY MEDIA
2 406 200 201 3 WAIT INPUT
3 606 300 301 6 CALL
4 806 400 401 9 IDLE
Index |
Index of the call information. |
Entity |
IVR entity number for the called number. |
Node-Id |
ID of the node that is being executed. |
Status |
Current status: · IDLE—The node is idle. · PLAY MEDIA—The node is playing a media file. · WAIT INPUT—The node is waiting for user input. · CALL—The node is calling a number. |
display voice media-play
Use display voice media-play to display playing information.
# Display playing information.
<Sysname> display voice media-play
Index Codec Media-Id Play-Times Status Type
1 g729r8 1001 3 play PSTN:1/0
2 g711alaw 1002 2 stop IP:100.1.1.1
3 g711ulaw 1003 2 stop IP:100.1.1.1
4 g723r53 1004 2 stop IP:100.1.1.1
Index |
Index of the playing information. |
Codec |
Codec type of the played media file: · g711alaw. · g711ulaw. · g723r53. · g729r8. |
Media-Id |
ID of the played media file. |
Play-Times |
Number of times that the media file is to be played. |
Status |
Current status of the media file: · play—The media file is being played. · stop—The media file is not played. |
Type |
Current call type: · PSTN—The call is from the PSTN side. In the above example, PSTN:1/0 indicates that the call came in from the voice interface 1/0. · IP—The call is from the IP side. |
display voice media-source
Use display voice media-source to display media file information.
# Display media file information.
<Sysname> display voice media-source
Codec Media-Id source Size (Bytes) Read-Num Cache-Num
g729r8 1000 cfa0:/wav/g7 69304 1 1
29r8/0.wav
Codec |
Codec type of the media file. |
Media-Id |
ID of the media file. |
Source |
Name and location of the media file. |
Size (Bytes) |
Size of the media file in bytes. |
Read-Number |
Number of the read control block for the media file. |
Cache-Number |
Number of the cache for the media file. |
global-input-error
Use global-input-error to configure a global policy for handling input errors.
Use undo global-input-error to restore the default.
global-input-error { media-play media-id [ play-times ] | repeat repeat-times } *
The system does not play voice prompts for input errors and terminates the call after three times of input errors.
IVR management view
media-play media-id: Specifies a media file by its ID in the range of 0 to 2147483647. A node plays the specified media file when an input error occurs.
play-times: Specifies the number of times for playing the media file, in the range of 1 to 255. The default is 1.
repeat repeat-times: Specifies the maximum number of input errors allowed, in the range of 0 to 255. The default is 3. After an input error occurs, the system executes the node again. When the maximum number of input errors are reached, the system terminates the call.
# Configure a global policy for handling input errors as follows:
· The media file with ID 10002 is played after an input error occurs.
· The media file is played twice.
· The call is terminated after five times of input errors.
[Sysname-voice-ivr] global-input-error media-play 10002 2 repeat 5
input-error
global-timeout
Use global-timeout to configure a global policy for handling input timeouts.
Use undo global-timeout to restore the default.
global-timeout { expires seconds| media-play media-id [ play-times ] | repeat repeat-times } *
undo global-timeout
The timeout time is 10 seconds. The system does not play voice prompts for input timeouts and terminates the call after three times of input timeouts.
IVR management view
expires seconds: Specifies the timeout time in the range of 1 to 255 seconds.
media-play media-id: Specifies a media file to be played after an input timeout occurs. The media-id argument represents the ID of the media file, in the range of 0 to 2147483647.
repeat repeat-times: Specifies the maximum number of input timeouts allowed, in the range of 0 to 255. After an input timeout occurs, the system executes the node again. When the maximum number of input timeouts are reached, the system terminates the call.
# Configure a global policy for handling input timeouts as follows:
· The timeout time is 20 seconds.
· The media file with ID 100001 is played.
· The media file is played once.
· The call is terminated after two times of input timeouts.
[Sysname-voice-ivr] global-timeout expires 20 media-play 100001 1 repeat 2
timeout
input extension
Use input extension to configure an extension secondary call for a node.
Use undo input to delete the configuration of an extension secondary call.
input number extension extension-number
undo input number
No extension secondary calls exist.
Call node view
number: Specifies an input number, a string of 1 to 31 characters that can include digits 0 through 9, pound sign (#), and asterisk (*).
extension-number: Specifies the extension number, a string of 1 to 31 characters that can include digits 0 through 9, pound sign (#), and asterisk (*).
You can configure a maximum of 10 extension secondary calls for a call node.
# Configure node 1 to execute an extension secondary call to the number 5000 when the subscriber dials the number 0.
[Sysname-voice-ivr-node1] extension 0 call 5000
input-error
Use input-error to configure an input error handling policy for a node.
Use undo input-error to restore the default.
input-error { end-call | goto-pre-node | goto-node node-id } [ media-play media-id [ play-times ] | repeat repeat-times ] *
undo input-error
The global input error handling policy is used.
Call node view
Jump node view
end-call: Terminates the call when the maximum number of input errors are reached.
goto-pre-node: Returns to the previous node when the maximum number of input errors are reached.
goto-node node-id: Jumps to a node specified by its ID when the maximum number of input errors are reached. The value range for the node-id argument is 1 to 256.
media-play media-id: Plays a media file specified by its ID when an input error occurs. The value range for the media-id argument is 0 to 2147483647.
play-times: Specifies the number of times for playing a media file, in the range of 1 to 255. The default is 1.
repeat repeat-times: Specifies the maximum number of input errors allowed. After an input error occurs, the system executes the node again. When the maximum number of input errors are reached, the system executes the configured action. The value range for the repeat-times argument is 0 to 255, and the default is 3.
# Configure an input error handling policy for Jump node 1 as follows:
· The media file with ID 10002 is played when an input error occurs.
[Sysname-voice-ivr-node1] input-error end-call media-play 10002 2 repeat 5
ivr-root
Use ivr-root to specify the root node (the first node to be executed) of an IVR entity.
Use undo ivr-root to restore the default.
ivr-root node-id
undo ivr-root
No root node is configured for an IVR voice entity.
IVR entity view
node-id: Specifies the ID of the root node, in the range 1 to 256.
# Specify node 1 as the root node of IVR entity 100.
[Sysname-voice] dial-program
[Sysname-voice-dial] entity 100 ivr
[Sysname-voice-dial-entity100] ivr-root 1
ivr-system
Use ivr-system to enter IVR management view.
Use undo ivr-system to delete all IVR settings in IVR management view and exit the view.
ivr-system
undo ivr-system
No IVR management view exists.
Voice view
# Enter IVR management view.
[Sysname-voice-ivr]
media-file
Use media-file to enter media resource management view.
media-file { g711alaw | g711ulaw | g723r53 | g729r8 }
Voice view
g711alaw: Enters g711alaw codec view.
g711ulaw: Enters g711ulaw codec view.
g723r53: Enters g723r53 codec view.
g729r8: Enters g729r8 codec view.
# Enter g729r8 codec view.
[Sysname-voice] media-file g729r8
[Sysname-voice-media-g729r8]
media-play
Use media-play to specify the media file to be played when a node is waiting for user input.
Use undo media-play to restore the default.
media-play media-id [ play-times ] [ force ]
undo media-play
No media file is played when a node is waiting for user input.
Call node view
Jump node view
force: Specifies that user input is valid only after the play of the media file ends. If you do not specify this keyword, user input is valid when the media file is played.
# Configure jump node 1 to play media file 10000 three times when waiting for user input and to accept user input after the play of the media file ends.
[Sysname-voice-ivr-node1] media-play 10000 3 force
node
Use node to create an IVR node and enter its view, or enter the view of an existing IVR node.
Use undo node to delete IVR nodes.
node node-id [ call | jump | service ]
undo node { node-id | all }
No IVR nodes exist.
IVR management view
node-id: Specifies the node ID in the range 1 to 256.
call: Creates a call node, which executes a secondary call after the subscriber enters a number.
jump: Creates a jump node, which jumps to another node according to user input.
service: Creates a service node, which executes various operations, such as executing an immediate secondary call, jumping, terminating a call, and playing a media file.
all: Specifies all types of nodes.
# Create Jump node 1 and enter its view.
operation
Use operation to configure an operation for a service node.
Use undo operation to delete the configuration of the operation for a service node.
operation number { call-immediate call-number | end-call | goto-node node-id | goto-pre-node | media-play media-id [ play-times ] }
undo operation number
No operations are configured.
Service node view
number: Specifies the number of the configured operation, in the range 1 to 3.
call-immediate call-number: Executes an immediate secondary call. The call-number argument represents the extension number of the secondary call and can include digits 0 through 9, pound sign (#), and asterisk (*).
end-call: Terminates a call.
goto-node node-id: Jumps to a node specified by its ID in the range of 1 to 256.
goto-pre-node: Returns to the previous node.
media-play media-id: Plays a media file specified by its ID in the range of 0 to 2147483647.
# Configure service node 1 to end a call.
[Sysname-voice-ivr] node 1 service
[Sysname-voice-ivr-node1] operation 1 end-call
select-rule
select-rule
Use select-rule to specify the execution order of configured operations for a service node.
Use undo select-rule to restore the default.
select-rule 1st-operation 2nd-operation 3rd-operation
undo select-rule
The execution order is 1 > 2 > 3.
Service node view
1st-operation: Specifies the number of the operation to be executed first, in the range of 1 to 3.
2nd-operation: Specifies the number of the operation to be executed secondly, in the range of 1 to 3. The value for this argument cannot be the same as the value for 1st-operation.
3rd-operation: Specifies the number of the operation to be executed thirdly, in the range of 1 to 3. The value for this argument cannot be the same as the values for 1st-operation and 2nd-operation.
After a service node jumps to another node, returns to the previous node, or terminates a call, it does not execute the remaining operations.
# Specify the execution order of configured operations for node 1 as 1 > 3 > 2.
[Sysname-voice-ivr-node1] select-rule 1 3 2
operation
set-media
Use set-media to specify an ID for a media file.
Use undo set-media to delete IDs for media files.
set-media media-id file filename
undo set-media { media-id | all }
No ID is specified for a media file.
Media resource management view
media-id: Specifies an ID in the range 0 to 2147483647.
file filename: Specifies a media file by its name.
all: Specifies all media file IDs.
# Specify ID 10001 for the media file cfa0:/g729/ring.wav.
[Sysname-voice-media-g729r8] set-media 10001 file cfa0:/g729/ring.wav
timeout
Use timeout to configure an input timeout handling policy for a node.
Use undo timeout to restore the default.
timeout { end-call | goto-pre-node | goto-node node-id } [ expires seconds | media-play media-id [ play-times ] | repeat repeat-times ] *
undo timeout
The global input timeout handling policy is used.
Call node view
Jump node view
expires seconds: Specifies the timeout time in the range of 1 to 255 seconds. The default is 10 seconds.
end-call: Terminates a call when the maximum number of input timeouts are reached.
goto-pre-node: Returns to the previous node when the maximum number of input timeouts are reached.
goto-node node-id: Jumps to a node specified by its ID when the maximum number of input timeouts are reached. The value range for the node-id argument is 1 to 256.
media-play media-id: Plays a media file specified by its ID when an input timeout occurs. The value range for the media-id argument is 0 to 2147483647.
repeat repeat-times: Specifies the maximum number of input timeouts allowed. After an input timeout occurs, the system executes the node again. When the maximum number of input timeouts are reached, the system executes the configured action. The value range for the repeat-times argument is 0 to 255, and the default is 3.
# Configure Jump node to terminate a call after three times of input timeouts.
[Sysname-voice-ivr-node1] timeout end-call repeat 3
user-input
Use user-input to configure a jump operation for an input character.
Use undo user-input to delete the jump operation for an input character.
user-input character { end-call | goto-node node-id | goto-pre-node }
undo user-input character
No jump operation is configured for a character.
Jump node view
character: Specifies a character, which can be any of digits 0 through 9, pound sign (#), or asterisk (*).
You can configure a maximum of 12 jump operations for a jump node.
# Configure the node to terminate the call if the subscriber presses 0.
[Sysname-voice-ivr-node1] user-input 0 end-call
