- 10-MPLS Command Reference
- 01-Basic MPLS commands
- 02-Static LSP commands
- 03-LDP commands
- 04-MPLS TE commands
- 05-Static CRLSP commands
- 06-RSVP commands
- 07-Tunnel policy commands
- 08-MPLS L3VPN commands
- 09-MPLS L2VPN commands
- 10-VPLS commands
- 11-L2VPN access to L3VPN or IP backbone commands
- 12-MPLS OAM commands
- 13-MPLS protection switching commands
- 14-MCE commands
12-MPLS OAM commands | 185.14 KB |
MPLS OAM commands
The following compatibility matrixes show the support of hardware platforms for MPLS OAM:
Hardware |
MPLS OAM compatibility |
MSR610 |
No |
Yes |
MSR810-LMS, MSR810-LUS |
Yes |
MSR810-SI, MSR810-LM-SI |
Yes |
MSR810-LMS-EA, MSR810-LME |
Yes |
MSR1004S-5G |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3610-G, MSR3620-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
MSR2600-10-X1-WiNet |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
Yes |
bfd discriminator
Use bfd discriminator to set local and remote discriminators for the BFD session used to verify PW connectivity.
Use undo bfd discriminator to restore the default.
bfd discriminator local local-id remote remote-id
No local or remote discriminators are set for the BFD session used to verify PW connectivity. The system automatically assigns local and remote discriminators to the BFD session.
Cross-connect PW view
VSI static PW view
VSI LDP PW view
Cross-connect backup PW view
VSI static backup PW view
VSI LDP backup PW view
local local-id: Specifies the local discriminator value for the BFD session.
The following compatibility matrixes show the support of hardware platforms for the local discriminator:
Hardware |
Parameter compatibility |
Value range |
MSR610 |
No |
N/A |
Yes |
1 to 32768 |
No |
N/A |
No |
N/A |
Yes |
1 to 32768 |
MSR1004S-5G |
Yes |
1 to 32768 |
Yes |
1 to 32768 |
MSR2600-10-X1 |
Yes |
1 to 32768 |
MSR 2630 |
Yes |
1 to 32768 |
Yes |
1 to 32768 |
No |
N/A |
Yes |
1 to 32768 |
Yes |
1 to 32768 |
Yes |
1 to 32768 |
Yes |
1 to 32768 |
Yes |
1 to 32768 |
Yes |
1 to 32768 |
MSR3640-X1-HI |
Yes |
1 to 32768 |
Hardware |
Value range |
Yes |
1 to 32768 |
MSR830-4LM-WiNet |
Yes |
1 to 32768 |
Yes |
1 to 32768 |
Yes |
1 to 32768 |
MSR2600-6-WiNet |
Yes |
1 to 32768 |
Yes |
1 to 32768 |
MSR2630-WiNet |
Yes |
1 to 32768 |
MSR3600-28-WiNet |
Yes |
1 to 32768 |
MSR3610-X1-WiNet |
Yes |
1 to 32768 |
Yes |
1 to 32768 |
Hardware |
Value range |
MSR860-6EI-XS |
Yes |
1 to 32768 |
MSR860-6HI-XS |
Yes |
1 to 32768 |
MSR2630-XS |
Yes |
1 to 32768 |
MSR3600-28-XS |
Yes |
1 to 32768 |
MSR3610-XS |
Yes |
1 to 32768 |
MSR3620-XS |
Yes |
1 to 32768 |
MSR3610-I-XS |
Yes |
1 to 32768 |
MSR3610-IE-XS |
Yes |
1 to 32768 |
MSR3620-X1-XS |
Yes |
1 to 32768 |
MSR3640-XS |
Yes |
1 to 32768 |
MSR3660-XS |
Yes |
1 to 32768 |
Hardware |
Value range |
MSR810-LM-GL |
Yes |
1 to 32768 |
MSR810-W-LM-GL |
Yes |
1 to 32768 |
MSR830-6EI-GL |
Yes |
1 to 32768 |
MSR830-10EI-GL |
Yes |
1 to 32768 |
MSR830-6HI-GL |
Yes |
1 to 32768 |
MSR830-10HI-GL |
Yes |
1 to 32768 |
MSR1004S-5G-GL |
Yes |
1 to 32768 |
MSR2600-6-X1-GL |
Yes |
1 to 32768 |
MSR3600-28-SI-GL |
No |
N/A |
remote remote-id: Specifies the remote discriminator value for the BFD session, in the range of 1 to 4294967295.
A BFD session for PW connectivity verification can be established in one of the following modes:
· Static mode—Specify the local and remote discriminator values by using the bfd discriminator command. You must specify the discriminators on both the local and remote PEs. Make sure the local discriminator and remote discriminator on the local PE are the same as the remote discriminator and local discriminator on the remote PE, respectively. Otherwise, the BFD session cannot be established for the PW.
· Dynamic mode—If you do not specify local and remote discriminators, the system automatically runs MPLS ping to negotiate the discriminator values.
# In VSI LDP PW view, set both the local and remote discriminator values to 1 for the BFD session used to verify PW connectivity.
[Sysname] vsi ttt
[Sysname-vsi-ttt] pwsignaling ldp
[Sysname-vsi-ttt-ldp] peer 22.22.2.2 pw-id 1 pw-class ttt
[Sysname-vsi-ttt-ldp-22.22.2.2-1] bfd discriminator local 1 remote 1
display l2vpn pw bfd
mpls bfd enable
vccv bfd
vccv cc
bfd ip-router-alert
Use bfd ip-router-alert to add the Router Alert option in BFD packets for LSP connectivity verification.
Use undo bfd ip-router-alert to remove the Router Alert option from BFD packets for LSP connectivity verification.
bfd ip-router-alert
The device adds the Router Alert option in BFD packets for LSP connectivity verification.
Execute the undo bfd ip-router-alert command on the local device if the peer device cannot identify the Router Alert option in BFD packets.
This command takes effect only on BFD sessions that come up after this command is executed.
# Remove the Router Alert option from BFD packets.
[Sysname] undo bfd ip-router-alert
Use display l2vpn pw bfd to display BFD information for PWs.
display l2vpn pw bfd [ peer peer-ip pw-id pw-id ]
peer peer-ip pw-id pw-id: Specifies a PW. The peer-ip argument specifies the LSR ID for the peer PE of the PW. The pw-id argument specifies the PW ID in the range of 1 to 4294967295. If you do not specify a PW, this command displays BFD information for all PWs.
# Display BFD information for all PWs.
<Sysname> display l2vpn pw bfd
Total number of sessions: 1, 1 up, 0 down, 0 init
FEC Type: PW FEC-128
FEC Info:
Peer IP: 22.22.2.2
PW ID: 1
VSI Index: 0 Link ID: 8
Local Discr: 514 Remote Discr: 514
Source IP: 11.11.1.1 Destination IP: 127.0.0.2
Session State: Up Session Role: Active
Template Name: -
Peer IP |
LSR ID of the peer PE. |
VSI Index |
Index of the VSI to which the PW belongs. This field is displayed when the PW is a VPLS PW. |
Connection ID |
ID of the cross-connect to which the PW belongs. This field is displayed when the PW is an MPLS L2VPN PW. |
Link ID |
Link ID of the PW. |
Local Discr |
Local discriminator of the BFD session. |
Remote Discr |
Remote discriminator of the BFD session. |
Source IP |
Source IP of the BFD session, which is the MPLS LSR ID of the local PE. |
Destination IP |
Destination IP address of the BFD session, which is on subnet 127.0.0.0/8. |
Session State |
BFD session state: · Init—BFD session is in initialization state. · Up—BFD session is up. · Down—BFD session is down. |
Session Role |
Role of the local PE in the BFD session: · Active—Sender of the BFD session. · Passive—Receiver of the BFD session. |
Template Name |
Name of the BFD session parameter template. |
bfd discriminator
vccv bfd
vccv cc
display mpls bfd
Use display mpls bfd to display BFD information for LSP tunnels or MPLS TE tunnels.
display mpls bfd [ ipv4 ipv4-address mask-length | te tunnel tunnel-number ]
ipv4 ipv4-address mask-length: Specifies an FEC by a destination IP address and mask length. The mask length is in the range of 0 to 32.
te tunnel tunnel-number: Specifies an MPLS TE tunnel by the tunnel interface number.
If you do not specify any parameters, this command displays BFD information for all LSP tunnels and all MPLS TE tunnels.
<Sysname> display mpls bfd ipv4 22.22.2.2 32
FEC Type: LSP
FEC Info:
Destination: 22.22.2.2
Mask Length: 32
NHLFE ID: 1025
Local Discr: 513 Remote Discr: 513
Source IP: 11.11.1.1 Destination IP: 127.0.0.1
Session State: Up Session Role: Passive
Template Name: -
# Display BFD information about MPLS TE tunnel 1. In this example, BFD control packet mode is used.
<Sysname> display mpls bfd te tunnel 1
FEC Type: TE Tunnel
FEC Info:
Source : 100.1.1.1
Destination: 200.1.1.1
Tunnel ID : 1
LSP ID : 100
NHLFE ID: 1025
Template Name: -
# Display BFD information for MPLS TE tunnel interface tunnel 1. In this example, BFD echo packet mode is used.
FEC Type: TE Tunnel
FEC Info:
Source : 100.1.1.1
Tunnel ID : 1
LSP ID : 100
NHLFE ID: 1025
Local Discr: 513
Source IP: 11.11.1.1 Destination IP: 200.1.1.1
Session State: Up
Template Name: -
Local Discr |
Remote Discr |
Source IP |
Source IP address of the BFD session, which is the MPLS LSR ID of the local PE. |
Destination IP |
If BFD control packet mode is used, this field displays the destination IP address of the BFD session. At the ingress node, it is an address on subnet 127.0.0.0/8. At the egress node, it is the MPLS LSR ID of the ingress node. If BFD echo packet mode is used, this field displays the destination IP address of the tunnel to be inspected. |
Session State |
Session Role |
Role of the local PE in the BFD session: · Active—Initiator of the BFD session. · Passive—Responder of the BFD session. |
Template Name |
mpls bfd (for LSP)
mpls bfd (for TE tunnel)
mpls bfd (for LSP)
Use mpls bfd to enable BFD for LSPs associated with an FEC.
Use undo mpls bfd to disable BFD for LSPs associated with an FEC.
mpls bfd dest-addr mask-length nexthop nexthop-address [ discriminator local local-id remote remote-id | echo ] [ template template-name ]
undo mpls bfd dest-addr mask-length nexthop nexthop-address
mpls bfd dest-addr mask-length [ echo ] [ template template-name ] [ backup-path template template-name ]
BFD is not used to verify LSP connectivity for an FEC.
dest-addr mask-length: Specifies an FEC by a destination IP address and mask length. The mask length is in the range of 0 to 32.
nexthop nexthop-address: Specifies the next hop address of the FEC. If you specify the FEC next hop, BFD verifies the specified LSP. If you do not specify a next hop, BFD verifies all LSPs for the FEC.
discriminator: Specifies discriminator values for the BFD session.
local local-id: Specifies the local discriminator value for the BFD session. The value range for the local-id argument is 1 to 32768.
echo: Enables the BFD echo packet mode. If you do not specify this keyword, the command enables the BFD control packet mode.
template template-name: Specifies a BFD session parameter template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a template, BFD control packet mode uses the multihop BFD session settings in system view, and BFD echo packet mode uses the default BFD session settings.
backup-path template template-name: Specifies a BFD session parameter template for the backup LSP. The template-name argument indicates the template name, a case-sensitive string of 1 to 63 characters. If you do not specify a template, BFD control packet mode uses the multihop BFD session settings in system view, and BFD echo packet mode uses the default BFD session settings.
After you execute both the mpls bfd enable command and the mpls bfd command, the device creates a BFD session for the LSP associated with the specified FEC.
If FRR is configured, you must use the mpls bfd command to create a BFD session for the primary LSP and a BFD session for the backup LSP. When one LSP fails, BFD can quickly detect the failure and notify the device to take an action, such as switching traffic to the other LSP. If BFD detects failures on both the primary and backup LSPs, the device does not forward traffic through the LSPs.
If you specify templates for both the primary and backup LSPs, specify greater interval settings for the template of the backup LSP than the primary LSP. This rule ensures that the BFD session for the new working LSP is up after a primary/backup LSP switchover.
The source address of the BFD session is the MPLS LSR ID of the local device. Before configuring BFD for the MPLS TE tunnel, perform the following tasks:
· Configure an MPLS LSR ID for the local device.
· Make sure a route is available on the remote device to reach the MPLS LSR ID.
When BFD control packet mode is used, a BFD session for LSP connectivity verification can be established in one of the following modes:
· Static mode—Specify the local and remote discriminator values by using the discriminator keyword in the mpls bfd command. You must enable BFD for MPLS and configure the mpls bfd command on both the local and remote devices. Make sure the discriminators configured on the local device match those configured on the remote device. A static BFD session verifies connectivity of a pair of LSPs in opposite directions between two devices.
· Dynamic mode—If you do not specify local and remote discriminators, the system automatically runs MPLS ping to negotiate the discriminator values. You must enable BFD for MPLS on both the local and remote devices, but the mpls bfd command is not needed on the remote PE. A dynamic BFD session verifies the connectivity of a unidirectional LSP from the local device to the remote device.
To enable the BFD echo packet mode, you must first execute the bfd echo-source-ip command on the local device to specify a source IP address for BFD echo packets.
You must specify the same BFD mode (BFD control or echo packet mode) for the LSPs (specified by next hop addresses) of the same FEC.
# Use BFD to verify the connectivity of the LSPs to destination 22.22.2.2/32.
[Sysname] mpls bfd enable
[Sysname] mpls bfd 22.22.2.2 32
# Use BFD to verify the connectivity of the LSP with destination 22.22.2.2/32 and next hop 12.0.0.2.
[Sysname] mpls bfd 22.22.2.2 32 nexthop 12.0.0.2
# Use BFD to verify the connectivity of the LSP with destination 22.22.2.2/32 and next hop 12.0.0.2. Set both the local and remote discriminators to 1, and use BFD session parameter template test.
[Sysname] mpls bfd 22.22.2.2 32 nexthop 12.0.0.2 discriminator local 1 remote 1 template test
bfd echo-source-ip (High Availability Command Reference )
display mpls bfd
mpls bfd enable
Use mpls bfd to enable BFD on an MPLS TE tunnel.
Use undo mpls bfd to restore the default.
mpls bfd [ [ discriminator local local-id remote remote-id | echo ] [ template template-name ] [ backup-path template template-name ] ]
undo mpls bfd
BFD is not enabled on an MPLS TE tunnel.
Tunnel interface view
backup-path template template-name: Specifies a BFD session parameter template for the MPLS TE backup tunnel. The template-name argument indicates the template name, a case-sensitive string of 1 to 63 characters. If you do not specify a template, BFD control packet mode uses the multihop BFD session settings in system view, and BFD echo packet mode uses the default BFD session settings.
After you execute both the mpls bfd enable command and the mpls bfd command, the device creates a BFD session for each CRLSP on the tunnel interface. When one CRLSP fails, BFD can quickly detect the failure and notify the device to take an action, such as switching traffic to the other CRLSP. If the two CRLSPs fail at the same time, the device puts the MPLS TE tunnel to down state so the tunnel does not receive traffic.
If you specify templates for both the primary and backup CRLSPs, specify greater interval settings for the template of the backup CRLSP than the primary CRLSP. This rule ensures that the BFD session for the new working CRLSP is up after a primary/backup CRLSP switchover.
When BFD control packet mode is used, a BFD session can be established in one of the following modes:
· Static mode—Specify the local and remote discriminators by using the discriminator keyword in the mpls bfd command. You must enable BFD for MPLS and configure the mpls bfd command on both the local and remote devices. Make sure the local discriminator and remote discriminator on the local device are the same as the remote discriminator and local discriminator on the remote device, respectively. A static BFD session verifies the connectivity of a pair of MPLS TE tunnels in opposite directions between two devices.
· Dynamic mode—If you do not specify local and remote discriminators, the system automatically runs MPLS ping to negotiate the discriminator values. You must enable BFD for MPLS on both the local and remote devices, but the mpls bfd command is not needed on the remote device. A dynamic BFD session verifies the connectivity of a unidirectional MPLS TE tunnel from the local device to the remote device.
# Enable the BFD control packet mode for MPLS TE tunnel interface Tunnel 1, and use the BFD session parameter template test.
[Sysname] interface tunnel 1
[Sysname-Tunnel1] mpls bfd template test
# Enable the BFD control packet mode for MPLS TE tunnel interface Tunnel 1, and set both the local and remote discriminators to 1.
[Sysname] interface Tunnel 1
[Sysname-Tunnel1] mpls bfd discriminator local 1 remote 1
# Enable the BFD echo packet mode for MPLS TE tunnel interface Tunnel 1.
[Sysname-Tunnel1] mpls bfd echo
bfd echo-source-ip (High Availability Command Reference)
display mpls bfd
mpls bfd enable
mpls bfd enable
Use mpls bfd enable to enable BFD for MPLS.
Use undo mpls bfd enable to disable BFD for MPLS.
mpls bfd enable
BFD for MPLS is disabled.
To use BFD to verify LSP, PW, or TE tunnel connectivity, you must use this command to enable BFD for MPLS. Otherwise, the BFD session cannot be established after you execute the vccv bfd or mpls bfd command (for LSP or for TE tunnel).
# Enable BFD for MPLS.
mpls periodic-tracert (for LSP)
Use mpls periodic-tracert to enable periodic tracert of LSPs for an FEC.
Use undo mpls periodic-tracert to disable periodic tracert of LSPs for an FEC.
mpls periodic-tracert dest-addr mask-length [ -a source-ip | -exp exp-value | -h ttl-value | -m wait-time | -rtos tos-value | -t time-out | -u retry-attempt | fec-check ] *
undo mpls periodic-tracert dest-addr mask-length
Periodic tracert of LSPs for an FEC is disabled.
-a source-ip: Specifies the source address for MPLS echo request packets. If you do not specify this option, the device uses the MPLS LSR ID as the source address for MPLS echo requests.
-exp exp-value: Specifies the EXP value for MPLS echo request packets, in the range of 0 to 7. The default is 0.
-h ttl-value: Specifies the maximum TTL value for MPLS echo request packets (the maximum number of hops to be inspected). The value range for the ttl-value argument is 1 to 255, and the default is 30.
-m wait-time: Specifies the interval at which tracert is performed. The value range is 15 to 120 minutes. The default is 60 minutes.
-rtos tos-value: Specifies the ToS value in the IP header of an MPLS echo reply packet. The value range is 0 to 7, and the default value is 6.
-t time-out: Specifies the timeout interval for the reply to an MPLS echo request. The value range is 0 to 65535 milliseconds, and the default is 2000 milliseconds.
-u retry-attempt: Specifies the maximum number of retransmissions of an MPLS echo request if no reply is received. The value range is 1 to 9, and the default value is 3.
fec-check: Checks the FEC stack at transit nodes.
The periodic MPLS tracert feature automatically traces an LSP tunnel at intervals. It locates errors on the LSP tunnel, verifies the consistency of the data plane and control plane, and records the detected errors into system logs. You can check the logs to monitor LSP connectivity.
If both BFD and periodic MPLS tracert are configured for an LSP, both feature take effect. When periodic MPLS tracert detects a data plane failure or an inconsistency between data plane and control plane, the device performs the following operations:
1. Deletes the BFD session for the LSP.
2. Re-establishes the BFD session based on the control plane.
Before you execute this command, execute the mpls bfd enable command.
# Enable periodic tracert for LSPs to destination 11.11.1.1/32.
[Sysname] mpls periodic-tracert 11.11.1.1 32
mpls bfd enable
mpls bfd (for LSP)
ping mpls ipv4
Use ping mpls ipv4 to verify MPLS LSP connectivity for an IPv4 prefix.
ping mpls [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v ] * ipv4 ipv4-address mask-length [ destination start-address [ end-address [ address-increment ] ] ] [ fec-type { generic | isis | ldp | ospf } ]
-a source-ip: Specifies the source address for MPLS echo request packets. If you do not specify this option, the device uses the primary IP address of the outgoing interface as the source address for MPLS echo requests.
-c count: Specifies the number of MPLS echo request packets to be sent with the same destination address in the IP header. The value range is 1 to 4294967295. The default is 5.
-h ttl-value: Specifies the TTL value for MPLS echo request packets, in the range of 1 to 255. The default is 255.
-m wait-time: Specifies the interval for sending MPLS echo request packets, in the range of 1 to 10000 milliseconds. The default is 200 milliseconds.
-r reply-mode: Specifies the reply mode of the receiver in response to MPLS echo request packets. The reply-mode argument can be 1, 2, 3, or 4. 1 means "Do not reply." 2 means "Reply by using a UDP packet." 3 means "Reply by using a UDP packet that carries the Router Alert option." 4 means "Reply by using a VCCV packet." The default is 2. The reply mode 4 is not available for MPLS LSP connectivity verification. If the reply mode 4 is specified, the remote end does not reply.
-s packet-size: Specifies the length (excluding the IP header and UDP header) of an MPLS echo request packet. The value for the packet-size argument is 65 to 8100 bytes, and the default is 100 bytes.
-v: Displays detailed reply information. If you do not specify this keyword, the command displays brief reply information.
destination: Specifies the destination address in the IP header of MPLS echo requests. The default is 127.0.0.1.
start-address: Specifies the destination address or the start destination address. This address must be an address on subnet 127.0.0.0/8—a local loopback address. If you specify the start-address argument without the end-address argument, the start-address is the destination address in the IP header. The number of MPLS echo requests to be sent is determined by the -c count keyword. If you specify both start-address and end-address, you specify a range of destination addresses. The destination address increments by the value specified for the address-increment argument, starting from the start-address to the end-address. The number of MPLS echo requests to be sent with each of the destination addresses is determined by the -c count keyword.
end-address: Specifies the end destination address. This address must be an address on subnet 127.0.0.0/8—a local loopback address.
address-increment: Specifies the increment value by which the destination address in the IP header increases in turn. The value range is 1 to 16777215 and the default value is 1.
fec-type: Specifies the FEC type of the MPLS LSPs to be verified. If you do not specify this keyword, the FEC type is the protocol type of the specified FEC in the routing table.
generic: Represents LSPs of any FEC type.
is-is: Represents IS-IS signaled SRLSPs.
ldp: Represents LDP signaled LSPs.
ospf: Represents OSPF signaled SRLSPs.
# Verify the connectivity of LSPs to destination 3.3.3.9/32.
<Sysname> ping mpls ipv4 3.3.3.9 32
MPLS ping FEC 3.3.3.9/32 with 100 bytes of data:
100 bytes from 100.1.2.1: Sequence=1 time=49 ms
100 bytes from 100.1.2.1: Sequence=2 time=44 ms
100 bytes from 100.1.2.1: Sequence=3 time=60 ms
100 bytes from 100.1.2.1: Sequence=4 time=60 ms
100 bytes from 100.1.2.1: Sequence=5 time=76 ms
--- Ping statistics for FEC 3.3.3.9/32 ---
Round-trip min/avg/max = 44/57/76 ms
# Verify the connectivity of LSPs to destination 3.3.3.9/32, and specify the following parameters:
· Set the number of MPLS echo requests to be sent with the same destination address to 3.
· Display detailed reply information.
· Specify the range of destination addresses in IP headers as 127.0.0.1 to 127.0.0.3, and set the destination address increment value to 2. With these settings, the destination addresses are 127.0.0.1 and 127.0.0.3.
<Sysname> ping mpls –c 3 –v ipv4 3.3.3.9 32 destination 127.0.0.1 127.0.0.3 2
Destination address 127.0.0.1
100 bytes from 100.1.2.1: Sequence=1 time=49 ms Return Code=3(1)
Destination address 127.0.0.3
100 bytes from 100.1.2.1: Sequence=2 time=44 ms Return Code=3(1)
100 bytes from 100.1.2.1: Sequence=3 time=60 ms Return Code=3(1)
100 bytes from 100.1.2.1: Sequence=4 time=60 ms Return Code=3(1)
100 bytes from 100.1.2.1: Sequence=5 time=76 ms Return Code=3(1)
100 bytes from 100.1.2.1: Sequence=6 time=57 ms Return Code=3(1)
6 packets transmitted, 6 packets received, 0.0% packet loss
MPLS ping FEC 3.3.3.9/32 with 100 bytes of data |
Verify LSP connectivity for FEC 3.3.3.9/32 by sending 100-byte MPLS echo requests. |
Destination address |
Destination IP address in the IP header. |
100 bytes from 100.1.2.1 |
Received a 100-byte reply from 100.1.2.1. |
Sequence |
Sequence number of the reply, for determination of packet loss, disorder, or duplicate. |
time |
Packet round-trip delay. |
Return Code |
Return code. The number in parentheses represents a return subcode. Options include the following: · 1—The MPLS echo request packet content is incorrect. · 2—The packet contains unsupported TLVs. · 3—Egress node response. · 5—Downstream mapping mismatching. · 6—The upstream did not provide egress interface information. · 8—Transit node response. · 10—The label for the FEC is inconsistent with that in the label stack of the packet. · 11—No entry matches the label in the label stack of the packet. · 12—The protocol for the FEC is inconsistent with that in the label forwarding table. |
Ping statistics for FEC 3.3.3.9/32 |
LSP verification statistics. |
packets transmitted |
Number of MPLS echo requests sent. |
packets received |
Number of MPLS echo replies received. |
packet loss |
Percentage of unreplied packets to total request packets. |
Round-trip min/avg/max |
Minimum, average, and maximum round-trip delay. |
ping mpls out-labels
Use ping mpls out-labels to verify the MPLS LSP of the specified outgoing labels.
ping mpls [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v ] * out-labels out-label-value&<1-14> interface interface-type interface-number [ nexthop nexthop-address ]
-a source-ip: Specifies the source address of MPLS echo request packets. If you do not specify this option, the device uses the primary IP address of the outgoing interface as the source address of MPLS echo requests.
-exp exp-value: Specifies the EXP value of MPLS echo request packets, in the range of 0 to 7. The default is 0.
-h ttl-value: Specifies the TTL value of MPLS echo request packets, in the range of 1 to 255. The default is 255.
-r reply-mode: Specifies the reply mode of the receiver in response to MPLS echo request packets. The reply-mode argument can be 1, 2, 3, or 4. The default is 2.
· 1—Do not reply.
· 2—Reply by using a UDP packet.
· 3—Reply by using a UDP packet that carries the Router Alert option.
· 4—Reply by using a VCCV packet. The reply mode 4 is not available for MPLS LSP connectivity verification. If the reply mode 4 is specified, the remote end does not reply.
out-labels out-label-value&<1-14>: Specifies a space-separated list of up to 14 outgoing labels, corresponding to the labels from top to bottom in the label stack. The value range for the out-label-value argument is 0, 3, and 16 to 1048575.
interface interface-type interface-number: Specifies the outgoing interface by the interface type and number.
nexthop nexthop-address: Specifies the next hop IP address.
To verify connectivity of a specific LSP, first execute the display mpls lsp command to identify the outgoing interface and next hop for the outgoing labels to be specified.
# In an LDP network, verify the connectivity of the LSP with outgoing label 2173, outgoing interface GigabitEthernet 1/0/1, and next hop IP address 10.1.1.2/32.
<Sysname> ping mpls out-labels 2173 interface gigabitethernet 1/0/1 nexthop 10.1.1.2
MPLS ping out-labels 2173 with 100 bytes of data:
100 bytes from 20.1.1.2: Sequence=1 time=1 ms
100 bytes from 20.1.1.2: Sequence=3 time=1 ms
100 bytes from 20.1.1.2: Sequence=4 time=1 ms
--- Ping statistics for out-labels ---
Round-trip min/avg/max = 1/1/1 ms
<Sysname>%Oct 11 09:26:52:882 2018 Sysname LSPV/6/LSPV_PING_STATIS_INFO: -MDC=1; Ping statistics for out-labels 2173: 5 packets transmitted, 5 packets received, 0.0% packets loss, round-trip min/avg/max = 1/1/1 ms.
# In an SR-MPLS to LDP interworking network, configure the source node to verify the LSP with outgoing label 17030, outgoing interface GigabitEthernet 1/0/2, and next hop 100.1.1.2/32.
<Sysname> ping mpls out-labels 17030 interface gigabitethernet 1/0/2 nexthop 100.1.1.2
MPLS ping out-labels 17030 with 100 bytes of data:
100 bytes from 20.1.1.2: Sequence=1 time=3 ms
100 bytes from 20.1.1.2: Sequence=2 time=2 ms
100 bytes from 20.1.1.2: Sequence=3 time=2 ms
100 bytes from 20.1.1.2: Sequence=4 time=2 ms
Round-trip min/avg/max = 1/2/3 ms
<Sysname>%Oct 11 10:12:45:434 2018 Sysname LSPV/6/LSPV_PING_STATIS_INFO: -MDC=1; Ping statistics for out-labels 17030: 5 packets transmitted, 5 packets received, 0.0% packets loss, round-trip min/avg/max = 1/2/3 ms.
MPLS ping out-labels out-label-value with 100 bytes of data |
Verify LSP connectivity for the specified outgoing labels (out-label-value) by sending 100-byte MPLS echo requests. |
100 bytes from 20.1.1.2 |
Received a 100-byte reply from 20.1.1.2. |
Sequence |
time |
Return Code |
Ping statistics for out-labels |
packets received |
packet loss |
ping mpls pw
Use ping mpls pw to verify LDP PW or static PW connectivity.
ping mpls [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v ] * pw ip-address pw-id pw-id
-a source-ip: Specifies the source address for MPLS echo request packets. If you do not specify this option, the device uses its MPLS LSR ID as the source address for MPLS echo requests.
-c count: Specifies the number of MPLS echo request packets to be sent. The value range is 1 to 4294967295. The default is 5.
ip-address: Specifies the IP address of the peer PE.
pw-id pw-id: Specifies the ID of the PW to the peer PE, in the range of 1 to 4294967295.
If you execute this command for a down PW, the ping operation might fail because of negotiation issues at the two ends of the PW. In this case, the device prompts not support for PW ping.
# Verify the connectivity of PW 301 to peer PE 3.3.3.9.
<Sysname> ping mpls pw 3.3.3.9 pw-id 301
MPLS ping PW 3.3.3.9 301 with 100 bytes of data:
--- Ping statistics for PW 3.3.3.9 301 ---
For the command output, see Table 3.
ping mpls te
Use ping mpls te to verify MPLS TE tunnel connectivity.
ping mpls [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v ] * te tunnel interface-number
Parameter
-c count: Specifies the number of MPLS echo request packets to be sent, in the range of 1 to 4294967295. The default is 5.
-r reply-mode: Specifies the reply mode of the receiver in response to MPLS echo request packets. The reply-mode argument can be 1, 2, 3, or 4. 1 means "Do not reply." 2 means "Reply by using a UDP packet." 3 means "Reply by using a UDP packet that carries the Router Alert option." 4 means "Reply by using a VCCV packet." The default is 2. The reply mode 4 is not available for MPLS TE tunnel connectivity verification. If the mode is specified, the remote end does not reply.
-rtos tos-value: Specifies the ToS value in the IP header of an MPLS echo reply packet. The value range is 0 to 7, and the default is 6.
-s packet-size: Specifies the length (excluding the IP header and UDP header) of an MPLS echo request packet. The value range for the packet-size argument is 65 to 8100 bytes, and the default is 100 bytes.
tunnel interface-number: Specifies an MPLS TE tunnel interface by the interface number. The specified MPLS TE tunnel interface must have already been created.
# Verify the connectivity of the MPLS TE tunnel for Tunnel 1.
<Sysname> ping mpls te tunnel 1
MPLS ping TE tunnel Tunnel1 with 100 bytes of data:
--- Ping statistics for TE tunnel Tunnel1 ---
tracert mpls ipv4
Use tracert mpls ipv4 to trace MPLS LSPs from the ingress node to the egress node for an IPv4 prefix. You can locate the error node according to the reply information.
tracert mpls [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out | -v | fec-check ] * ipv4 ipv4-address mask-length [ destination start-address [ end-address [ address-increment ] ] ] [ fec-type { generic | isis | ldp | ospf } ]
-a source-ip: Specifies the source address for MPLS echo request packets. If you do not specify this option, the command uses the primary IP address of the outgoing interface as the source address for MPLS echo requests.
-r reply-mode: Specifies the reply mode of the receiver in response to MPLS echo request packets. The reply-mode argument can be 1, 2, or 3. 1 means "Do not reply," 2 means "Reply by using a UDP packet," and 3 means "reply by using a UDP packet that carries the Router Alert option." The default is 2.
ipv4-address mask-length: Specifies an FEC by an IPv4 destination address and a mask length. The value range for the mask-length argument is 0 to 32.
start-address: Specifies the destination address or the start destination address. This address must be an address on subnet 127.0.0.0/8—a local loopback address. If you specify the start-address argument without the end-address argument, the start-address is the destination address in the IP header. If you specify both start-address and end-address, you specify a range of destination addresses. The destination address increments by the value specified for the address-increment argument, starting from the start-address to the end-address. The command performs a tracert for each of the destination addresses.
fec-type: Specifies the FEC type to be carried in an MPLS echo request packet. If you do not specify this keyword, the FEC type is the protocol type of the specified FEC in the routing table.
# Trace the path that the LSP (for FEC 5.5.5.9/32) traverses from the ingress node to the egress node. Specify the IP header destination address range as 127.1.1.1 to 127.1.1.2 and set the address increment value to 1. With these settings, the device performs a tracert for 127.1.1.1 and 127.1.1.2.
<Sysname> tracert mpls ipv4 5.5.5.9 32 destination 127.1.1.1 127.1.1.2 1
MPLS trace route FEC 5.5.5.9/32
Destination address 127.1.1.1
TTL Replier Time Type Downstream
0 Ingress 100.1.2.1/[1025]
1 100.1.2.1 1 ms Transit 100.2.4.1/[1024]
2 100.2.4.1 63 ms Transit 100.4.5.1/[3]
3 100.4.5.1 129 ms Egress
Destination address 127.1.1.2
0 Ingress 100.1.3.1/[1030]
1 100.1.3.1 1 ms Transit 100.3.4.1/[1024]
2 100.3.4.1 51 ms Transit 100.4.5.1/[3]
3 100.4.5.1 80 ms Egress
# Trace the path that the LSP (for FEC 5.5.5.9/32) traverses from the ingress node to the egress node. Display detailed reply information, specify the IP header destination address range as 127.1.1.1 to 127.1.1.2, and set the address increment value to 1. With these settings, the device performs a tracert for 127.1.1.1 and 127.1.1.2.
<Sysname> tracert mpls –v ipv4 5.5.5.9 32 destination 127.1.1.1 127.1.1.2 1
1 100.1.2.1 1 ms Transit 100.2.4.1/[1024] ReturnCode 8(1)
2 100.2.4.1 63 ms Transit 100.4.5.1/[3] ReturnCode 8(1)
3 100.4.5.1 129 ms Egress ReturnCode 3(1)
1 100.1.3.1 1 ms Transit 100.3.4.1/[1024] ReturnCode 8(1)
2 100.3.4.1 51 ms Transit 100.4.5.1/[3] ReturnCode 8(1)
3 100.4.5.1 80 ms Egress ReturnCode 3(1)
MPLS trace route FEC |
Trace the LSPs for the specified FEC. |
TTL |
Number of hops. |
Replier |
Address of the LSR that replied the request. |
Time |
Time used to receive the reply, in milliseconds. |
Type |
LSR type: Ingress, Transit, or Egress. |
Downstream |
Address of the downstream LSR and the label assigned by the downstream LSR. |
ReturnCode |
tracert mpls out-labels
Use tracert mpls out-labels to trace MPLS LSPs of the specified outgoing labels from the ingress node to the egress node of the LSPs. You can locate the error node according to the reply information.
tracert mpls [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out | -v | fec-check ]* out-labels out-label-value&<1-14> interface interface-type interface-number [ nexthop nexthop-address ]
-h ttl-value: Specifies the maximum TTL value of MPLS echo request packets (the maximum number of hops to be inspected). The value range for the ttl-value argument is 1 to 255, and the default is 30.
-r reply-mode: Specifies the reply mode of the receiver in response to MPLS echo request packets. The reply-mode argument can be 2 or 3. The default is 2.
To trace a specific LSP, first execute the display mpls lsp command to identify the outgoing interface and next hop for the outgoing labels to be specified.
# In an LDP network, trace the path of the LSP with outgoing label 2173, outgoing interface GigabitEthernet 1/0/1, and next hop IP address 10.1.1.2/32.
<Sysname> tracert mpls out-labels 2173 interface gigabitethernet 1/0/1 nexthop 10.1.1.2
MPLS trace route out-labels 2173
0 Ingress 10.1.1.2/[2173]
1 10.1.1.2 1 ms Transit 20.1.1.2/[1040127]
2 20.1.1.2 1 ms Egress
# In an SR-MPLS to LDP interworking network, trace the LSP with outgoing label 17030, outgoing interface GigabitEthernet 1/0/2, and next hop 100.1.1.2/32 on the source node.
<Sysname> tracert mpls out-labels 17030 interface gigabitethernet 1/0/2 nexthop 100.1.1.2
MPLS trace route out-labels 17030
0 Ingress 100.1.1.2/[17030]
1 100.1.1.2 1 ms Transit 10.1.1.2/[2173]
2 10.1.1.2 2 ms Transit 20.1.1.2/[1040127]
3 20.1.1.2 1 ms Egress
Table 6 Command output
MPLS trace route out-labels out-label-value |
Trace the LSPs for the specified outgoing labels. |
TTL |
Number of hops. |
Replier |
IP address of the LSR that replied the request. |
Time |
Packet round-trip delay, in milliseconds. |
Type |
Downstream |
Address of the downstream LSR and the outgoing label (label assigned by the downstream LSR). |
Return Code |
tracert mpls te
Use tracert mpls te to trace an MPLS TE tunnel from the ingress node to the egress node. You can locate the error node according to the reply information.
tracert mpls [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out | -v | fec-check ] * te tunnel interface-number
-r reply-mode: Specifies the reply mode of the receiver in response to MPLS echo request packets. The reply-mode argument can be 2 or 3. 2 means "Reply by using a UDP packet," and 3 means "reply by using a UDP packet that carries the Router Alert option." The default is 2.
tunnel interface-number: Specifies an existing MPLS TE tunnel interface by the interface number.
# Trace the path that MPLS TE tunnel 1 traverses from the ingress node to the egress node.
<Sysname> tracert mpls te tunnel 1
MPLS trace route TE tunnel Tunnel1
0 Ingress 10.4.5.1/[1025]
1 10.4.5.1 1 ms Transit 100.3.4.1/[1024]
2 100.3.4.1 63 ms Transit 100.1.2.1/[3]
3 100.1.2.1 129 ms Egress
For the command output, see Table 5.
vccv bfd
Use vccv bfd to configure BFD to verify PW connectivity.
Use undo vccv bfd to restore the default.
vccv bfd [ raw-bfd ] [ template template-name ]
undo vccv bfd
BFD is not used to verify PW connectivity.
PW class view
raw-bfd: Specifies the BFD packets to use PW-ACH encapsulation (without IP/UDP headers). This keyword takes effect only when the CC type is control word. If you do not specify this keyword, the BFD packets use IP/UDP encapsulation (with IP/UDP headers).
template template-name: Specifies a BFD session parameter template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a template, BFD uses the multihop BFD session parameters configured in system view.
After you execute this command and specify the PW class for a PW, the PEs use the specified encapsulation type to verify PW connectivity when the following conditions are met:
· Both PEs of the PW have configured BFD for the PW.
· The PEs use the same encapsulation type for BFD packets.
If any of the previous conditions are not met, the PEs do not use BFD to verify PW connectivity.
To use BFD for PW connectivity verification, you must execute the vccv bfd and mpls bfd enable commands on both ends of the PW.
# Configure BFD to verify PW connectivity and specify the BFD session parameter template as aaa.
[Sysname] pw-class test
[Sysname-pw-test] vccv bfd template aaa
mpls bfd enable
vccv cc
vccv cc
Use vccv cc to specify the VCCV control channel (CC) type.
Use undo vccv cc to restore the default.
vccv cc { control-word | router-alert | ttl }
undo vccv cc
No VCCV CC type is specified.
PW class view
control-word: Specifies the VCCV CC type as control word.
router-alert: Specifies the VCCV CC type as MPLS router alert label.
ttl: Specifies the VCCV CC type as TTL expiry (MPLS PW Label with TTL = 1).
The packets used to verify PW connectivity are collectively referred to as VCCV packets. A PE transfers VCCV packets through a CC.
CCs include the following types:
· Control word—Identifies VCCV packets through the control word (PW-ACH, PW Associated Channel Header). You can use this CC type only when the PW supports control word. For more information about control word, see MPLS Configuration Guide.
· MPLS router alert label—Identifies a VCCV packet by adding an MPLS router alert label before the PW label.
· TTL expiry—Identifies a VCCV packet by setting the TTL value of the PW label to 1.
After you execute this command and specify the PW class for a PW, the specified CC is used if both PEs have specified the same VCCV CC type. Otherwise, the PEs do not use any CC and they cannot establish a BFD session for the PW.
# Specify the VCCV CC type as MPLS router alert label.
[Sysname-pw-test] vccv cc router-alert
mpls bfd enable
vccv bfd
