- 09-IP Multicast Command Reference
- 01-IGMP snooping commands
- 02-Multicast routing and forwarding commands
- 03-IGMP commands
- 04-PIM commands
- 05-MSDP commands
- 06-Multicast VPN commands
- 07-MLD snooping commands
- 08-IPv6 multicast routing and forwarding commands
- 09-MLD commands
- 10-IPv6 PIM commands
03-IGMP commands | 242.38 KB |
display igmp proxy routing-table
display igmp user-authorization
igmp last-member-query-interval
igmp other-querier-present-interval
igmp user-vlan-aggregation dot1q
last-member-query-count (IGMP view)
last-member-query-interval (IGMP view)
other-querier-present-interval (IGMP view)
startup-query-count (IGMP view)
startup-query-interval (IGMP view)
IGMP commands
The following compatibility matrixes show the support of hardware platforms for IGMP:
Hardware |
IGMP compatibility |
MSR610 |
Yes |
Yes |
MSR810-LMS, MSR810-LUS |
No |
MSR810-SI, MSR810-LM-SI |
No |
MSR810-LMS-EA, MSR810-LME |
No |
MSR1004S-5G |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3610-G, MSR3620-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
MSR2600-10-X1-WiNet |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
display igmp group
Use display igmp group to display information about IGMP multicast groups (multicast groups that hosts have joined through IGMP).
display igmp [ vpn-instance vpn-instance-name ] group [ group-address | interface interface-type interface-number ] [ static | verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about IGMP multicast groups on the public network.
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays information about all IGMP multicast groups.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about IGMP multicast groups for all interfaces.
static: Specifies IGMP multicast groups that hosts have joined statically. If you do not specify this keyword, the command displays information about IGMP multicast groups that hosts have joined dynamically.
verbose: Displays detailed information.
# Display information about IGMP multicast groups that hosts have dynamically joined on the public network.
<Sysname> display igmp group
IGMP groups in total: 3
GigabitEthernet1/0/1(10.10.1.20):
IGMP groups reported in total: 3
Group address Last reporter Uptime Expires
225.1.1.1 10.10.1.10 00:02:04 00:01:15
225.1.1.2 10.10.1.10 00:02:04 00:01:15
225.1.1.3 10.10.1.10 00:02:04 00:01:15
IGMP groups in total |
Total number of IGMP multicast groups. |
IGMP groups reported in total |
Total number of IGMP multicast groups that hosts attached to the interface have joined dynamically. |
Group address |
Multicast group address. |
Last reporter |
Address of the last host that reported its membership to the multicast group. |
Uptime |
Length of time since the multicast group was reported. |
Expire |
Remaining lifetime for the multicast group. This field displays Off if the timer is disabled. |
# Display detailed information about IGMP multicast group 232.1.1.1 that hosts have dynamically joined on the public network. In this example, the router is configured with IGMP SSM mappings.
<Sysname> display igmp group 232.1.1.1 verbose
Group: 232.1.1.1
Uptime: 00:00:34
Exclude expires: 00:04:16
Mapping expires: 00:02:16
Last reporter: 10.10.1.10
Last-member-query-counter: 0
Last-member-query-timer-expiry: Off
Mapping last-member-query-counter: 0
Mapping last-member-query-timer-expiry: Off
Group mode: Exclude
Version1-host-present-timer-expiry: Off
Version2-host-present-timer-expiry: 00:02:11
Mapping version1-host-present-timer-expiry: Off
Source list (sources in total: 1):
Source: 10.1.1.1
Uptime: 00:00:03
V3 expires: 00:04:16
Group |
Uptime |
Exclude expires |
Remaining lifetime for the multicast group in Exclude mode. This field displays Off if the timer is disabled. |
Mapping expires |
Remaining time for the multicast group specified in IGMP SSM mappings. This field is displayed only when the device is configured with IGMP SSM mappings. |
Last reporter |
Address of the last host that reported its membership to this multicast group. |
Last-member-query-counter |
Number of IGMP group-specific queries or IGMP source-and-group-specific queries sent for the multicast group. |
Last-member-query-timer-expiry |
Remaining time for the last member query timer for the multicast group. This field displays Off if the timer is disabled. |
Mapping last-member-query-counter |
Number of IGMP group-specific queries or IGMP source-and-group-specific queries sent for the multicast group specified in IGMP SSM mappings. This field is displayed only when the device is configured with IGMP SSM mappings. |
Mapping last-member-query-timer-expiry |
Remaining time for the last member query timer of the multicast group specified in IGMP SSM mappings. This field displays Off if the timer is disabled. This field is displayed only when the device is configured with IGMP SSM mappings. |
Group mode |
Multicast source filtering mode: · Include—Include mode. · Exclude—Exclude mode. For a device that runs IGMPv1 or IGMPv2: · If IGMP SSM mappings are not configured, this field displays Exclude. · If IGMP SSM mappings are configured, this field displays Include or Exclude depending on the SSM mappings and the multicast groups that the host joins. |
Version1-host-present-timer-expiry |
Remaining time for the IGMPv1 host present timer. This field displays Off if the timer is disabled. This field is displayed only when the device runs IGMPv2 or IGMPv3. |
Version2-host-present-timer-expiry |
Remaining time for the IGMPv2 host present timer. This field displays Off if the timer is disabled. This field is displayed only when the device runs IGMPv3. |
Mapping version1-host-present-timer-expiry |
Remaining time for the IGMPv1 host present timer when the device is configured with IGMP SSM mappings. This field displays Off if the timer is disabled. This field is displayed only when the device is configured with IGMP SSM mappings. |
Source list (sources in total) |
List of multicast sources and total number of multicast sources. This field is displayed only when the device runs IGMPv3 or when the device is configured with IGMP SSM mappings. |
Source |
Multicast source address. This field is displayed only when the device runs IGMPv3 or when the device is configured with IGMP SSM mappings. |
Uptime |
Length of time since the multicast source was reported. This field is displayed only when the device runs IGMPv3 or when the device is configured with IGMP SSM mappings. |
V3 expires |
Remaining time for the multicast source when the device runs IGMPv3. This field displays Off if the timer is disabled and displays three hyphens (---) if the multicast source is specified in IGMP SSM mappings. This field is displayed only when the device runs IGMPv3 or when the device is configured with IGMP SSM mappings. |
Mapping expires |
Remaining time for the multicast source specified in IGMP SSM mappings. This field is displayed only when the device is configured with IGMP SSM mappings. |
Number of IGMP group-specific queries or IGMP group-and-source-specific queries sent for the multicast source and group. This field is displayed only when the device runs IGMPv3 or is configured with IGMP SSM mappings. |
Remaining time for the last member query timer for the multicast source and group. This field displays Off if the timer is disabled. This field is displayed only when the device runs IGMPv3 or is configured with IGMP SSM mappings. |
# Display information about IGMP multicast groups that hosts have statically joined on the public network.
<Sysname> display igmp group static
Entries in total: 2
Group address Source address Interface Expires
225.1.1.1 0.0.0.0 GE1/0/1 Never
225.2.2.2 1.1.1.1 GE1/0/1 Never
Entries in total |
Total number of the multicast groups that hosts have joined statically. |
Group address |
Source address |
Multicast source address. |
Interface name. |
Expires |
Remaining lifetime for the multicast group. This field always displays Never because the multicast group never expires. |
reset igmp group
display igmp interface
Use display igmp interface to display IGMP information for interfaces.
display igmp [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ host | proxy ] [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IGMP information for interfaces on the public network.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IGMP information for all IGMP-enabled interfaces.
host: Displays information about the interfaces enabled with the IGMP host feature. If you do not specify this keyword, the command displays IGMP information for interfaces enabled with IGMP and those enabled with the IGMP host feature. For more information about the IGMP host feature, see VXLAN Configuration Guide.
proxy: Displays the IGMP proxy interface information. If you do not specify this keyword, the command displays IGMP information about all interfaces.
verbose: Displays detailed IGMP information.
# Display detailed IGMP information for GigabitEthernet 1/0/1 (non-proxy interface) on the public network.
<Sysname> display igmp interface gigabitethernet 1/0/1 verbose
IGMP is enabled.
IGMP version: 2
Query interval for IGMP: 125s
Other querier present time for IGMP: 255s
Maximum query response time for IGMP: 10s
Last member query interval: 1s
Last member query count: 2
Startup query interval: 31s
Startup query count: 2
General query timer expiry (hh:mm:ss): 00:00:54
Querier for IGMP: 10.10.1.20 (This router)
IGMP activity: 1 join(s), 0 leave(s)
Multicast routing on this interface: Enabled
Robustness: 2
Require-router-alert: Disabled
Fast-leave: Disabled
Startup-query: Off
Other-querier-present-timer-expiry (hh:mm:ss): Off
Authorization: Disabled
Join-by-session: Disabled
User-VLAN-aggregation: Disabled
IGMP groups reported in total: 1
# Display detailed IGMP information for all IGMP proxy interfaces on the public network.
<Sysname> display igmp interface proxy verbose
GigabitEthernet1/0/2(20.10.1.20):
IGMP proxy is enabled.
IGMP version: 2
Version1-querier-present-timer-expiry (hh:mm:ss): Off
# Display detailed IGMP information for all interfaces enabled with the IGMP host feature on the public network.
<Sysname> display igmp interface host verbose
GigabitEthernet1/0/3(30.10.1.20):
IGMP host is enabled.
IGMP version: 2
GigabitEthernet1/0/1(10.10.1.20) |
Interface and its IP address. |
IGMP is enabled |
IGMP is enabled on the interface. |
IGMP version |
Version of IGMP that the interface runs. |
Query interval for IGMP |
IGMP general query interval, in seconds. |
Other querier present time for IGMP |
IGMP other querier present interval, in seconds. |
Maximum query response time for IGMP |
Maximum response time for IGMP general queries, in seconds. |
Last member query interval |
Interval for sending IGMP group-specific queries or IGMP group-and-source-specific queries, in seconds. |
Last member query count |
Number of IGMP group-specific queries or IGMP group-and-source-specific queries sent for the multicast group. |
Startup query interval |
Interval for sending IGMP general queries on startup, in seconds. |
Startup query count |
Number of IGMP general queries that the device sends on startup. |
General query timer expiry |
Remaining time for the IGMP general query timer. This field displays Off if the timer is disabled. |
Querier for IGMP |
IP address of the IGMP querier. This field is not displayed when the device runs IGMPv1 and the device is not the IGMP querier. NOTE: In IGMPv1, the PIM DR acts as the IGMP querier. You can use the display pim interface command to display PIM information. |
No querier elected |
No IGMP querier election is performed. This field is displayed when the device runs IGMPv1 and is not the IGMP querier. NOTE: In IGMPv1, the PIM DR acts as the IGMP querier. You can use the display pim interface command to display PIM information. |
IGMP activity: 1 join(s), 0 leave(s) |
Statistics of IGMP activities: · join(s)—Total number of multicast groups that this interface has joined. · leave(s)—Total number of multicast groups that this interface has left. |
Multicast routing on this interface |
Whether IP multicast routing is enabled: Enabled or Disabled. |
Robustness |
Robustness variable of the IGMP querier. |
Require-router-alert |
Whether the feature of dropping IGMP messages without Router-Alert is enabled: Enabled or Disabled, |
Fast-leave |
Whether the fast-leave processing feature is enabled: Enabled or Disabled. |
Startup-query |
Whether the IGMP querier sends IGMP general queries at the startup query interval on startup: · On—The IGMP querier performs the above action. · Off—The IGMP querier does not perform the above action. |
Other-querier-present-timer-expiry |
Remaining time for the other querier present timer. This field displays Off if the timer is disabled. |
Authorization |
Whether the multicast access control feature is enabled: Enabled or Disabled. |
Join-by-session |
Whether the per-session multicast forwarding feature is enabled: Enabled or Disabled. |
User-VLAN-aggregation |
Whether the multicast packet VLAN tagging feature is enabled: Enabled or Disabled. |
Total number of multicast groups that the interface has joined dynamically. This field is not displayed if the interface does not join multicast groups. |
IGMP proxy is enabled |
IGMP proxying is enabled on the interface. |
IGMP host is enabled |
The IGMP host feature is enabled on the interface. |
Version1-querier-present-timer-expiry |
Remaining time for the IGMPv1 querier present timer. This field displays Off if the timer is disabled. |
display igmp proxy group
Use display igmp proxy group to display information about multicast groups maintained by the IGMP proxy.
display igmp [ vpn-instance vpn-instance-name ] proxy group [ group-address | interface interface-type interface-number ] [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about multicast groups maintained by the IGMP proxy on the public network.
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays information about all multicast groups maintained by the IGMP proxy.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about multicast groups maintained by the IGMP proxy for all interfaces.
# Display information about multicast groups maintained by the IGMP proxy on the public network.
<Sysname> display igmp proxy group
IGMP proxy group records in total: 2
GigabitEthernet1/0/1(1.1.1.20):
Group address Member state Expires
225.1.1.1 Delay 00:00:02
225.1.1.2 Idle Off
# Display detailed information about multicast group 225.1.1.1 maintained by the IGMP proxy on the public network.
<Sysname> display igmp proxy group 225.1.1.1 verbose
Group: 225.1.1.1
Group mode: Include
Member state: Delay
Expires: 00:00:02
1.1.1.1
Table 5 Command output
IGMP groups records in total |
Total number of multicast groups maintained by the IGMP proxy. |
GigabitEthernet1/0/1(1.1.1.20) |
IGMP proxy interface and its IP address. |
Pending proxy group |
Pending multicast groups maintained by the IGMP proxy. |
Group address/Group |
Member state |
Member host states: · Delay—The member host has joined a group and started a delay timer. · Idle—The member host has joined a group, but didn't start a delay timer. |
Expires |
Remaining delay time for the member host to send a responding report. This field displays Off if the timer is disabled. |
Group mode |
Multicast source filtering mode: Include or Exclude. |
Source list |
Multicast source list for the multicast group maintained by the IGMP proxy. |
sources in total |
Total number of multicast sources. |
Use display igmp proxy routing-table to display multicast routing entries maintained by the IGMP proxy.
display igmp [ vpn-instance vpn-instance-name ] proxy routing-table [ source-address [ mask { mask-length | mask } ] | group-address [ mask { mask-length | mask } ] ] * [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays multicast routing entries maintained by the IGMP proxy on the public network.
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command displays multicast routing entries for all multicast sources maintained by the IGMP proxy.
group-address: Specifies a multicast group address by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays multicast routing entries for all multicast groups maintained by the IGMP proxy.
mask-length: Specifies a mask length of the multicast group address or multicast source address. For a multicast source address, the value range for this argument is 0 to 32. For a multicast group address, the value range for this argument is 4 to 32. The default value is 32 in both cases.
mask: Specifies a mask of the multicast group address or multicast source address. The default value is 255.255.255.255.
verbose: Displays detailed information about multicast routing entries maintained by the IGMP proxy.
# Display multicast routing entries maintained by the IGMP proxy on the public network.
<Sysname> display igmp proxy routing-table
Total 1 (*, G) entries, 2 (S, G) entries.
(172.168.0.12, 227.0.0.1)
Upstream interface: GigabitEthernet1/0/1
Downstream interfaces (1 in total):
1: GigabitEthernet1/0/2
Protocol: IGMP
(*, 225.1.1.1)
Protocol: STATIC
(2.2.2.2, 225.1.1.1)
Downstream interfaces (2 in total):
1: LoopBack1
Protocol: STATIC
2: GigabitEthernet1/0/2
Protocol: PROXY
# Display detailed information about multicast routing entries maintained by the IGMP proxy on the public network.
<Sysname> display igmp proxy routing-table verbose
Protocol: IGMP
Querier state: Querier
Join/Prune state:Join
Non-downstream interfaces: None
(*, 225.1.1.1)
Protocol: STATIC
Non-downstream interfaces (1 in total):
Protocol: IGMP
Querier state: Non-querier
1: LoopBack1
Protocol: STATIC
Join/Prune state: Join
Protocol: PROXY
Table 6 Command output
Total 1 (*, G) entries, 2 (S, G) entries |
Total number of (*, G) entries, and the total number of (S, G) entries. |
(172.168.0.12, 227.0.0.1) |
(S, G) entry. |
Upstream interface |
Incoming interface of the (S, G) entry. |
Downstream interfaces (1 in total) |
Outgoing interfaces of the (S, G) entry, and the total number of outgoing interfaces. |
Non-downstream interfaces (1 in total) |
Non-outgoing interfaces of the (S, G) entry, and the total number of non-outgoing interfaces. |
1: GigabitEthernet1/0/2 |
Index of an interface, and the interface. |
Protocol |
Protocol type: · IGMP—Dynamic IGMP. · PROXY—IGMP proxy. · STATIC—Static IGMP. |
Querier state |
Querier state: · Querier. · Non-querier. |
Join/Prune state |
Joined or pruned state of the interface: · NI—Default state. · Join—Joined state. · Prune—Pruned state. |
display igmp ssm-mapping
Use display igmp ssm-mapping to display IGMP SSM mappings.
display igmp [ vpn-instance vpn-instance-name ] ssm-mapping group-address
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about the IGMP SSM mappings on the public network.
# Display IGMP SSM mappings for multicast group 232.1.1.1 on the public network.
<Sysname> display igmp ssm-mapping 232.1.1.1
Group: 232.1.1.1
Source list:
1.2.3.4
5.5.5.5
10.1.1.1
100.1.1.10
Table 7 Command output
Group |
Source list |
List of multicast source addresses. |
Use display igmp user-authorization to display information about authorized IGMP users.
display igmp user-authorization [ interface interface-type interface-number ]
interface-type interface-number: Specifies an interface by its interface type and number. If you do not specify an interface, this command displays information about authorized IGMP users on all interfaces.
# Display information about all authorized IGMP users.
<Sysname> display igmp user-authorization
Authorized users in total: 3
User name: user1@isp1
Access type: PPP
Interface: Virtual-Access0
Access interface: Virtual-Access0
Maximum programs for order: 4
User profile: profile1
Authorized programs list:
225.0.0.1
User name: user2
Access type: Portal
Interface: Multicast-UA0
Access interface: GigabitEthernet1/0/1.1
VLAN ID: 100
Second VLAN ID: 10
225.0.0.1
225.0.0.2
225.0.0.3
User name: user3
Access type: Portal
Interface: Multicast-UA1
Access interface: GigabitEthernet1/0/2
225.0.0.1
225.0.0.2
Table 8 Command output
Authorized users in total |
Total number of access users. |
Access type |
Access type: · Portal. · PPP. |
User interface. |
Access interface |
Interface through which the user accesses the BRAS. |
VLAN ID |
Outer VLAN ID for the user. |
Second VLAN ID |
Inner VLAN ID for the user. |
Maximum programs for order |
Maximum number of the multicast groups that the user can join. |
User profile |
User profile name of the authorized user. The user can join multicast groups permitted by the IGMP user access control policy in the user profile. To configure an IGMP user access control policy, use the igmp access-policy command. |
Authorized programs list |
List of the multicast groups that the user is authorized to join. |
igmp
Use igmp to enter IGMP view.
Use undo igmp to delete the configurations in IGMP view.
undo igmp [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command applies to the public network.
# Enter IGMP view for the public network.
[Sysname] igmp
[Sysname-igmp]
# Enter IGMP view for the VPN instance mvpn.
[Sysname] igmp vpn-instance mvpn
[Sysname-igmp-mvpn]
igmp access-policy
Use igmp access-policy to configure an IGMP user access policy.
Use undo igmp access-policy to delete an IGMP user access policy.
igmp access-policy ipv4-acl-number
undo igmp access-policy ipv4-acl-number
No IGMP user access policies exist. IGMP users are not authorized to join any multicast groups.
User profile view
ipv4-acl-number: Specifies an IPv4 basic or advanced ACL number, in the range of 2000 to 3999. IGMP users can join only multicast groups that the ACL permits. If the ACL does not exist or does not have valid rules, IGMP users cannot join multicast groups.
You can configure multiple IGMP user access policies by using this command multiple times. An IGMP report is permitted if it matches one of the access policies.
When you configure a rule in the IPv4 ACL, follow these restrictions and guidelines:
· An ACL rule containing the vpn-instance vpn-instance option does not take effect.
· In a basic ACL, the source source-address source-wildcard option specifies a multicast group address.
· In an advanced ACL, the source source-address source-wildcard option specifies a multicast source address. The destination dest-address dest-wildcard option specifies a multicast group address.
To match the following IGMP reports, set the source source-address source-wildcard option to 0.0.0.0:
¡ IGMPv1 and IGMPv2 reports.
¡ IGMPv3 IS_EX and IGMPv3 TO_EX reports that do not carry multicast source addresses.
· Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
# Configure an access policy in user profile abc to authorize IGMP users to join multicast group 225.1.1.2.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 225.1.1.2 0
[Sysname] user-profile abc
[Sysname-user-profile-abc] igmp access-policy 2000
igmp authorization-enable
Use igmp authorization-enable to enable the multicast access control feature.
Use undo igmp authorization-enable to disable the multicast access control feature.
The multicast access control feature is disabled.
Layer 3 Ethernet interface/subinterface view
Layer 3 aggregate interface/subinterface view
VT interface view
This command takes effect only on local online users. Non-local users and offline users are not affected.
# Enable the multicast access control feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] igmp authorization-enable
igmp enable
Use igmp enable to enable IGMP on an interface.
Use undo igmp enable to disable IGMP on an interface.
undo igmp enable
IGMP is disabled on an interface.
Interface view
This command takes effect only when IP multicast routing is enabled on the public network or for the VPN instance to which the interface belongs.
Other IGMP configurations on the interface take effects only when IGMP is enabled on the interface.
# Enable IP multicast routing on the public network, and enable IGMP on GigabitEthernet 1/0/1.
[Sysname] multicast routing
[Sysname-mrib] quit
[Sysname-GigabitEthernet1/0/1] igmp enable
multicast routing
igmp fast-leave
Use igmp fast-leave to enable fast-leave processing on an interface.
Use undo igmp fast-leave to disable fast-leave processing on an interface.
igmp fast-leave [ group-policy ipv4-acl-number ]
Fast-leave processing is disabled. The IGMP querier sends IGMP group-specific or group-and-source-specific queries after receiving a leave message.
Interface view
ipv4-acl-number: Specifies an IPv4 basic ACL by its number in the range of 2000 to 2999. If you specify an ACL, the fast-leave processing feature takes effect only on the multicast groups that the ACL permits. The feature takes effect on all multicast groups when one of the following conditions exists:
· You do not specify an ACL.
· The specified ACL does not exist.
· The specified ACL does not have valid rules.
The fast-leave processing feature enables an IGMP querier to suppress IGMP group-specific or group-and-source-specific queries upon receiving IGMP leave messages permitted by the ACL.
When you configure a rule in the IPv4 basic ACL, follow these restrictions and guidelines:
· The source source-address source-wildcard option specifies a multicast group address.
# Enable fast-leave processing on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] igmp fast-leave
igmp group-policy
Use igmp group-policy to configure a multicast group policy on an interface to control the multicast groups that hosts attached to the interface can join.
Use undo igmp group-policy to delete the multicast group policy on an interface.
igmp group-policy ipv4-acl-number [ version-number ]
No multicast group policy exists on an interface. Hosts attached to the interface can join any multicast groups.
Interface view
ipv4-acl-number: Specifies an IPv4 basic or advanced ACL by its number in the range of 2000 to 3999. Hosts can join only the multicast groups that the ACL permits. If the ACL does not exist or does not have valid rules, hosts cannot join any multicast groups.
version-number: Specifies an IGMP version in the range of 1 to 3. By default, this command takes effect on IGMP reports of all versions.
A multicast group policy filters IGMP reports to control the multicast groups that the hosts can join.
This command does not take effect on static member interfaces because static member interfaces do not send IGMP reports.
# Configure a multicast group policy on GigabitEthernet 1/0/1 so that hosts attached to the interface can join only multicast group 225.1.1.1.
[Sysname] acl basic 2005
[Sysname-acl-ipv4-basic-2005] rule permit source 225.1.1.1 0
[Sysname-acl-ipv4-basic-2005] quit
[Sysname-GigabitEthernet1/0/1] igmp group-policy 2005
igmp join-by-session
Use igmp join-by-session to enable per-session multicast forwarding.
Use undo igmp join-by-session to restore the default.
Multicast data is forwarded on a per-interface basis.
This feature enables an interface to send a separate copy of multicast data to each user attached to the interface.
The igmp join-by-session and igmp user-vlan-aggregation dot1q commands are mutually exclusive. You cannot configure them on the same device.
# Enable per-session multicast forwarding on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] igmp join-by-session
igmp last-member-query-count
Use igmp last-member-query-count to set the IGMP last member query count on an interface.
Use undo igmp last-member-query-count to restore the default.
igmp last-member-query-count count
The IGMP last member query count equals the IGMP querier's robustness variable.
Interface view
count: Specifies an IGMP last member query count in the range of 1 to 255.
You can set the IGMP last member query count for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP last member query count to 6 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] igmp last-member-query-count 6
Use igmp last-member-query-interval to set the IGMP last member query interval on an interface.
Use undo igmp last-member-query-interval to restore the default.
igmp last-member-query-interval interval
The IGMP last member query interval is 1 second.
Interface view
interval: Specifies an IGMP last member query interval in the range of 1 to 25 seconds.
You can set the IGMP last member query interval for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP last member query interval to 6 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] igmp last-member-query-interval 6
igmp max-response-time
Use igmp max-response-time to set the maximum response time for IGMP general queries on an interface.
Use undo igmp max-response-time to restore the default.
igmp max-response-time time
The maximum response time for IGMP general queries is 10 seconds.
Interface view
time: Specifies the maximum response time for IGMP general queries, in the range of 1 to 3174 seconds.
You can set the maximum response time for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the maximum response time for IGMP general queries to 25 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] igmp max-response-time 25
max-response-time (IGMP view)
igmp non-stop-routing
Use igmp non-stop-routing to enable IGMP NSR.
Use undo igmp non-stop-routing to disable IGMP NSR.
The following compatibility matrixes show the support of hardware platforms for this command:
Hardware |
Command compatibility |
MSR610 |
No |
No |
No |
No |
No |
MSR1004S-5G |
No |
No |
MSR2600-10-X1 |
No |
MSR 2630 |
· In standalone mode: No · In IRF mode: Yes |
No |
No |
MSR3640-X1-HI |
No |
Hardware |
No |
MSR830-4LM-WiNet |
No |
No |
No |
MSR2600-6-WiNet |
No |
No |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
No |
No |
Hardware |
MSR860-6EI-XS |
No |
MSR860-6HI-XS |
No |
MSR2630-XS |
No |
MSR3600-28-XS |
MSR3610-XS |
MSR3620-XS |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
MSR3640-XS |
MSR3660-XS |
No |
Hardware |
MSR810-LM-GL |
No |
MSR810-W-LM-GL |
No |
MSR830-6EI-GL |
No |
MSR830-10EI-GL |
No |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
No |
MSR3600-28-SI-GL |
No |
IGMP NSR is disabled.
# Enable IGMP NSR.
[Sysname] igmp non-stop-routing
Use igmp other-querier-present-interval to set the IGMP other querier present timer on an interface.
Use undo igmp other-querier-present-interval to restore the default.
igmp other-querier-present-interval interval
The IGMP other querier present timer is calculated by using the following formula:
[ IGMP general query interval ] × [ IGMP querier's robustness variable ] + [ maximum response time for IGMP general queries ] / 2.
Interface view
interval: Specifies an IGMP other querier present timer in the range of 1 to 31744 seconds.
You can set the IGMP other querier present timer for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP other querier present timer to 125 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] igmp other-querier-present-interval 125
igmp proxy enable
Use igmp proxy enable to enable IGMP proxying on an interface.
Use to undo igmp proxy enable to disable IGMP proxying on an interface.
igmp proxy enable
IGMP proxying is disabled on an interface.
Interface view
# Enable IP multicast routing on the public network, and enable IGMP proxying on GigabitEthernet 1/0/1.
[Sysname] multicast routing-enable
[Sysname-GigabitEthernet1/0/1] igmp proxy enable
multicast routing
igmp proxy forwarding
Use igmp proxy forwarding to enable multicast forwarding on a non-querier interface.
Use undo igmp proxy forwarding to disable multicast forwarding on a non-querier interface.
Multicast forwarding is disabled for a non-querier interface.
Interface view
Typically, only IGMP queriers can forward multicast traffic but non-queriers cannot. This mechanism prevents multicast data from being repeatedly forwarded. If a router interface on the IGMP proxy failed the querier election, enable multicast forwarding on the interface to forward multicast data to attached receivers.
# Enable multicast forwarding on GigabitEthernet 1/0/1. (GigabitEthernet 1/0/1 is a non-querier interface on the IGMP proxy device.)
[Sysname-GigabitEthernet1/0/1] igmp proxy forwarding
igmp query-interval
Use igmp query-interval to set the IGMP general query interval on an interface.
Use undo igmp query-interval to restore the default.
igmp query-interval interval
The IGMP general query interval is 125 seconds.
Interface view
interval: Specifies an IGMP general query interval in the range of 1 to 31744 seconds.
You can set the IGMP general query interval for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP general query interval to 60 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] igmp query-interval 60
igmp robust-count
Use igmp robust-count to set the IGMP querier's robustness variable on an interface.
Use undo igmp robust-count to restore the default.
igmp robust-count count
The IGMP querier's robustness variable is 2.
Interface view
count: Specifies an IGMP querier's robustness variable in the range of 1 to 255.
The IGMP querier's robustness variable defines the number of times to retransmit queries if packet loss occurs. A higher robustness variable makes the IGMP querier more robust, but it increases timeout time for multicast groups.
You can set the IGMP querier's robustness variable for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP querier's robustness variable to 5 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] igmp robust-count 5
robust-count (IGMP view)
igmp startup-query-count
Use igmp startup-query-count to set the IGMP startup query count on an interface.
Use undo igmp startup-query-count to restore the default.
igmp startup-query-count count
The IGMP startup query count equals the IGMP querier's robustness variable.
Interface view
count: Specifies an IGMP startup query count in the range of 1 to 255.
You can set the IGMP startup query count for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP startup query count to 5 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] igmp startup-query-count 5
igmp startup-query-interval
Use igmp startup-query-interval to set the IGMP startup query interval on an interface.
Use undo igmp startup-query-interval to restore the default.
igmp startup-query-interval interval
The IGMP startup query interval equals one quarter of the IGMP general query interval.
Interface view
interval: Specifies an IGMP startup query interval in the range of 1 to 31744 seconds.
You can set the IGMP startup query interval for an interface in interface view or globally for all interfaces in IGMP view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IGMP startup query interval to 100 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] igmp startup-query-interval 100
igmp static-group
Use igmp static-group to configure an interface as a static group member of a multicast group.
Use undo igmp static-group to restore the default.
igmp static-group group-address [ source source-address ] [ dot1q vid vlan-list | dot1q vid vlan-id second-dot1q vlan-list ]
undo igmp static-group { all | group-address [ source source-address ] [ dot1q vid vlan-list | dot1q vid vlan-id second-dot1q vlan-list ] }
An interface is not a static group member of multicast groups.
Interface view
source source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, this command configures an interface as a static member of the multicast groups with all multicast source addresses.
dot1q vid vlan-list: Specifies a space-separated list of up to 10 outer VLAN ID items. Each item specifies an outer VLAN ID or a range of outer VLAN IDs in the form of start-vlan-id to end-vlan-id. The value range for VLAN IDs is 1 to 4094. If you specify this option, the command configures an interface as a single-VLAN-tagged static member interface for a multicast group. This option is supported in Layer 3 Ethernet subinterface view and Layer 3 aggregate subinterface view.
dot1q vid vlan-id second-dot1q vlan-list: Specifies the outer and inner VLAN IDs. The vlan-id argument specifies the outer VLAN ID in the range of 1 to 4094. The vlan-list argument specifies a space-separated list of up to 10 inner VLAN ID items. Each item specifies an inner VLAN ID or a range of inner VLAN IDs in the form of start-vlan-id to end-vlan-id. The value range for VLAN IDs is 1 to 4094. If you specify this option, the command configures an interface as a double-VLAN-tagged static member interface for a multicast group. This option is supported in Layer 3 Ethernet subinterface view and Layer 3 aggregate subinterface view.
all: Specifies all multicast groups that the interface has statically joined.
For multicast routing entries to be created, you must specify a multicast source if the specified multicast group is in the SSM group range.
For the same multicast group, the non-VLAN-based, single-VLAN-based, or double-VLAN-based static member interface configurations are mutually exclusive.
When you configure a subinterface as a non-VLAN-based static member interface, do not configure the igmp join-by-session or igmp user-vlan-aggregation dot1q command on this subinterface. If you configure either of the commands on the subinterface, static multicast forwarding entries cannot be created.
When you configure a subinterface as a VLAN-based static member interface, you must also configure the igmp join-by-session or igmp user-vlan-aggregation dot1q command on this subinterface. A static multicast forwarding entry can be created under either of the following conditions:
· When the igmp join-by-session command is configured, users that belong to the specified VLANs logs in.
· When the user-vlan-aggregation dot1q command is configured, the specified VLAN IDs are the same as or are included in the VLAN IDs specified in the igmp static-group command.
# Configure GigabitEthernet 1/0/1 as a static group member of multicast group 224.1.1.1.
[Sysname-GigabitEthernet1/0/1] igmp static-group 224.1.1.1
# Configure GigabitEthernet 1/0/1 as a static group member of multicast source and group (192.168.1.1, 232.1.1.1).
[Sysname-GigabitEthernet1/0/1] igmp static-group 232.1.1.1 source 192.168.1.1
# Enable per-session multicast forwarding on GigabitEthernet 1/0/1.1. Configure the subinterface as a static group member of multicast group 224.1.1.1 for users with outer VLAN ID 10 and inner VLAN IDs in the range of 10 to 20.
[Sysname] interface gigabitethernet 1/0/1.1
[Sysname-GigabitEthernet1/0/1.1] igmp join-by-session
[Sysname-GigabitEthernet1/0/1.1] igmp static-group 224.1.1.1 dot1q vid 10 second-dot1q 10 to 20
Use igmp user-vlan-aggregation dot1q to configure VLAN tagging on multicast packets.
Use undo igmp user-vlan-aggregation dot1q to restore the default.
igmp user-vlan-aggregation dot1q vid vlan-id [ second-dot1q vlan-id ]
The multicast packets are not tagged.
vid vlan-id: Specifies an outer VLAN ID in the range of 1 to 4094.
second-dot1q vlan-id: Specifies an inner VLAN ID in the range of 1 to 4094.
# Configure the multicast packets to be tagged with outer VLAN ID 10 and inner VLAN ID 20 on GigabitEthernet 1/0/1.1.
[Sysname-GigabitEthernet1/0/1.1] igmp user-vlan-aggregation dot1q vid 10 second-dot1q 20
igmp version
Use igmp version to specify an IGMP version on an interface.
Use undo igmp version to restore the default.
igmp version version-number
undo igmp version
The IGMP version on an interface is 2.
Interface view
CAUTION: For IGMP to operate correctly, specify the same IGMP version for all devices on the same subnet. |
# Specify IGMP version 1 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] igmp version 1
Use last-member-query-count to set the IGMP last member query count globally.
Use undo last-member-query-count to restore the default.
IGMP view
You can set the IGMP last member query count globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP last member query count to 6 on the public network.
[Sysname] igmp
[Sysname-igmp] last-member-query-count 6
Use last-member-query-interval to set the IGMP last member query interval globally.
Use undo last-member-query-interval to restore the default.
IGMP view
You can set the IGMP last member query interval globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP last member query interval to 6 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] last-member-query-interval 6
Use max-response-time to set the maximum response time for IGMP general queries globally.
Use undo max-response-time to restore the default.
IGMP view
time: Specifies the maximum response time for IGMP general queries in the range of 1 to 3174 seconds.
You can set the maximum response time globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
#Set the global maximum response time for IGMP general queries to 25 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] max-response-time 25
Use other-querier-present-interval to set the IGMP other querier present timer globally.
Use undo other-querier-present-interval to restore the default.
IGMP view
You can set the IGMP other querier present timer globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP other querier present timer to 125 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] other-querier-present-interval 125
proxy multipath (IGMP view)
Use proxy multipath to enable load splitting on an IGMP proxy device.
Use undo proxy multipath to disable load splitting on an IGMP proxy device.
proxy multipath
The load splitting feature is disabled on the IGMP proxy device.
IGMP view
Use this feature when the IGMP proxy device has multiple proxy interfaces. All proxy interfaces on the IGMP proxy device share multicast traffic on a per-group basis. If you do not enable this feature, only the proxy interface with the highest IP address forwards multicast data.
# Enable load splitting on the IGMP proxy device on the public network.
[Sysname] igmp
[Sysname-igmp] proxy multipath
Use query-interval to set the IGMP general query interval globally.
Use undo query-interval to restore the default.
undo query-interval
IGMP view
You can set the IGMP general query interval globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP general query interval to 60 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] query-interval 60
igmp query-interval
reset igmp group
Use reset igmp group to clear dynamic IGMP multicast group entries.
reset igmp [ vpn-instance vpn-instance-name ] group { all | interface interface-type interface-number { all | group-address [ mask { mask | mask-length } ] [ source-address [ mask { mask | mask-length } ] ] } }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears dynamic IGMP multicast group entries on the public network.
all: Specifies all interfaces (the first all), or all IGMP multicast groups (the second all).
group-address: Specifies a multicast group by its IP address in the range of 224.0.0.0 to 239.255.255.255.
source-address: Specifies a multicast source address. If you do not specify a multicast source, this command clears dynamic IGMP multicast group entries for all multicast source addresses.
mask: Specifies an address mask. The default is 255.255.255.255.
mask-length: Specifies an address mask length. The default is 32. For a multicast group address, the value range for this argument is 4 to 32. For a multicast source address, the value range for this argument is 0 to 32.
CAUTION: This command might interrupt the multicast information transmission. |
# Clear dynamic IGMP multicast group entries for all interfaces on the public network.
<Sysname> reset igmp group all
# Clear all dynamic IGMP multicast group entries for GigabitEthernet 1/0/1 on the public network.
<Sysname> reset igmp group interface gigabitethernet 1/0/1 all
# Clear the dynamic IGMP multicast group entry of group 225.0.0.1 for GigabitEthernet 1/0/1 on the public network.
<Sysname> reset igmp group interface gigabitethernet 1/0/1 225.0.0.1
Use robust-count to set the IGMP querier's robustness variable globally.
Use undo robust-count to restore the default.
robust-count count
undo robust-count
IGMP view
The IGMP querier's robustness variable defines the number of times to retransmit queries if packet loss occurs. A higher robustness variable makes the IGMP querier more robust, but it increases the timeout time for multicast groups.
You can set the IGMP querier's robustness variable globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP querier's robustness variable to 5 on the public network.
[Sysname] igmp
[Sysname-igmp] robust-count 5
igmp robust-count
ssm-mapping (IGMP view)
Use ssm-mapping to configure an IGMP SSM mapping.
Use undo ssm-mapping to delete IGMP SSM mappings.
ssm-mapping source-address ipv4-acl-number
undo ssm-mapping { source-address | all }
No IGMP SSM mappings exist.
IGMP view
ipv4-acl-number: Specifies a basic ACL number in the range of 2000 to 2999. Multicast groups in IGMP reports permitted by the ACL are associated with the multicast source. If the ACL does not exist or does not have valid rules, no multicast groups are associated with the multicast source.
all: Specifies all IGMP SSM mappings.
# Configure an IGMP SSM mapping with multicast source 125.1.1.1 and multicast group range 232.1.1.0/24 on the public network.
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit source 232.1.1.1 0.0.0.255
[Sysname] igmp
[Sysname-igmp] ssm-mapping 125.1.1.1 2001
Use startup-query-count to set the IGMP startup query count globally.
Use undo startup-query-count to restore the default.
IGMP view
You can set the IGMP startup query count globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP startup query count to 5 on the public network.
[Sysname] igmp
[Sysname-igmp] startup-query-count 5
Use startup-query-interval to set the IGMP startup query interval globally.
Use undo startup-query-interval to restore the default.
IGMP view
You can set the IGMP startup query interval globally for all interfaces in IGMP view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IGMP startup query interval to 100 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] startup-query-interval 100
