12-WLAN Advanced Features Command Reference
HomeSupportWirelessvAC1000 Virtual Access ControllerReference GuidesCommand ReferencesH3C vAC1000 Virtual Access Controller Command References(R5435P03)-6W10012-WLAN Advanced Features Command Reference
09-WLAN process maintenance commands
09-WLAN process maintenance commands 72.08 KB
display maintain cpu-usage history
Use display maintain cpu-usage history to display CPU usage history of a WLAN process.
display maintain cpu-usage history process process-name [ days-ago days ] [ start-time value ] [ interval interval ]
process-name: Specifies a process by its name, a case-insensitive string of 1 to 15 characters.
days-ago days: Specifies the number of past days, in the range of 1 to 7. If you do not specify this option, the command displays CPU history information for the current day.
start-time value: Specifies the start hour, in the range of 0 to 23. The default value is 0. If you specify 3, the command displays the CPU history after 3 o'clock.
interval interval: Specifies the statistics collection interval. The value can be 1, 5, or 20 minutes. The default value is 5.
# Display the CPU usage of process stamgr every five minutes from 9:00 yesterday.
<Sysname> display maintain cpu-usage history process stamgr days-ago 1 start-time 9
CPU utilization rate
Process: stamgr  Time: 2017-07-20 09:00  Interval: 5min
100|
 90|
 80|
 70|
 60|                                    **    *
 50|                                 ***  **** **
 40|                     ************            *********
 30|   ******************                                 *********
 20|***                                                            *********
 10|
  0+-----------+-----------+-----------+-----------+-----------+-----------+
 09:00       10:00       11:00       12:00       13:00       14:00       15:00
Process
Process name.
Time
Start time.
Interval
Statistics collection interval.
display maintain memory-usage history
Use display maintain memory-usage history to display memory usage history of a WLAN process.
display maintain memory-usage history process process-name [ days-ago days ] [ start-time value ] [ interval interval ]
days-ago days: Specifies the number of past days, in the range of 1 to 7. If you do not specify this option, the command displays history information in the current day.
start-time value: Specifies the start hour, in the range of 0 to 23. The default value is 0. If you specify 3, the command displays the memory usage history after 3 o'clock.
interval interval: Specifies the statistics collection interval. The value can be 5, 20, or 60 minutes. The default value is 20.
# Display the memory usage of process apmgr every 20 minutes from yesterday.
<Sysname> display maintain memory-usage history process apmgr days-ago 1
Memory utilization
Process: apmgr  Time: 2017-07-20 00:00  Interval: 20min
(MB)
2048|
1792|                                     ***
1536|
1280|                                 ****   *****
1024|                     ************            *********
 768|   ******************                                 *********
 512|***                                                            *********
 256|
   0+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+--+
    0  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23  0
Process
Process name.
Time
Start time.
Interval
display wlan statistics global
Use display wlan statistics global to display global WLAN statistics.
In a non-IRF network, the command displays global WLAN statistics on the device. For example, in an AC hierarchy network, the command displays statistics on the central AC if executed on the central AC, and displays statistics on a local AC if executed on the local AC.
# Display global WLAN statistics.
<Sysname> display wlan statistics global
Local ACs (online/total)          : 10/12
APs (online/total)                : 1000/1200
APs (online/offline) in 300s      : 50/20
Sensor APs/WIPS APs/WLOC APs      : 210/33/112
Clients online                    : 1000
Clients (online/offline) in 300s  : 1000/2000
User authentication information:
 Auth type   Online users   Online in 300s   Offline in 300s   Failed in 300s
 802.1X      200            200              300               100
 MAC         300            300              500               100
 Portal      500            500              1200              100
BSS information:
 Slot number   Service templates   BSSs
 0             500                 444
Number of online local ACs and total number of local ACs.
This field is available only on the central AC in an AC hierarchy network.
APs (online/total)
Number of online APs and total number of APs.
Numbers of APs coming online and going offline in the past 300 seconds, respectively.
Numbers of APs enabled with WLAN probe, WIPS, and wireless location, respectively.
Clients online
Number of online clients.
Number of clients coming online and going offline in the past 300 seconds, respectively.
Auth type
Authentication type:
·     Portal.
·     802.1X.
·     MAC.
Online users
Number of users that have passed authentication and come online.
Online in 300s
Number of users that came online in the past 300 seconds.
Offline in 300s
Number of users that went offline in the past 300 seconds.
Failed in 300s
Number of users that failed authentication in the past 300 seconds.
Slot number
This field is not available in the current software version.
Slot number.
Service templates
Number of created service templates.
BSSs
Number of BSSs.
maintain enable
Use maintain enable to enable WLAN process maintenance.
Use undo maintain enable to disable WLAN process maintenance.
maintain enable
WLAN process maintenance is disabled.
This feature enables the system to monitor the CPU usage, memory usage, and thread state of the apmgr, stamgr, and portal processes.
# Enable WLAN process maintenance.
[Sysname] maintain enable
maintain inactive-process restart enable
Use maintain inactive-process restart enable to enable defunct process restart.
Use undo maintain inactive-process restart enable to disable defunct process restart.
Defunct process restart is disabled.
CAUTION
CAUTION:
Restarting a main WLAN process affects wireless services. Please configure this feature under the guidance of professionals and use this feature with caution.
This feature enables the system to restart the apmgr, stamgr, and portal processes when they enter defunct state.
This feature takes effect only when WLAN process maintenance is enabled.
# Enable defunct process restart.
[Sysname] maintain inactive-process restart enable
maintain enable
maintain process inactive-time
maintain monitor process
Use maintain monitor process to enable maintenance of the specified process.
Use undo maintain monitor process to disable maintenance of the specified process.
maintain monitor process process-name
undo maintain monitor process process-name
Maintenance of a process is disabled.
process-name: Specifies the name of a process, a case-sensitive string of 1 to 15 characters.
Make sure WLAN process maintenance is enabled before you execute this command. The command execution will fail if WLAN process maintenance is disabled.
This feature enables the system to monitor the CPU usage and memory usage of the specified process.
# Enable maintenance of the WIPS process.
[Sysname] maintain monitor process wips
maintain enable
Use maintain process inactive-time to set the inactive timeout for a process.
Use undo maintain process inactive-time to restore the default.
maintain process process-name inactive-time value
undo maintain process process-name inactive-time
The inactive timeout is 10 minutes.
process-name: Specifies the name of a process.
value: Specifies the inactive timeout in the range of 5 to 30 seconds.
When WLAN process maintenance is enabled, the system periodically sends a message to each monitored process to examine the process state. If the system fails to receive any response from a process when the inactive timeout expires, the system determines that the process is in defunct state.
You can set the inactive timeout only for the apmgr, stamgr, and portal processes.
The configuration starts to take effect the first time the system sends a message upon execution of the command.
# Set the inactive timeout for process apmgr.
[Sysname] maintain process apmgr inactive-time 20
maintain process memory-threshold
Use maintain process memory-threshold to set the memory usage threshold.
Use undo maintain process memory-threshold to restore the default.
maintain process process-name memory-threshold value
undo maintain process process-name memory-threshold
The memory usage threshold is 300 MB.
value: Specifies the memory usage threshold in the range of 50 to 1000 MB.
The system outputs a log entry when the memory usage of the specified process exceeds the threshold.
You can set the threshold only for the apmgr, stamgr, and portal processes.
# Set the memory usage threshold to 100 MB for process apmgr.
[Sysname] maintain process apmgr memory-threshold 100
