00-Preface | 100.69 KB |
Preface
This command reference describes WLAN advanced feature related configuration commands. It includes the following feature modules:
· Bonjour gateway.
· Hotspot 2.0.
· WLAN mesh.
· Wireless location.
· WLAN forwarding.
· AC hierarchy.
· WSA.
· WLAN probe.
· WLAN process maintenance.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the vAC1000 virtual access controller.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
