- 07-Network Management and Monitoring Command Reference
- 01-Information center commands
- 02-Fast log output commands
- 03-Packet capture commands
- 04-Monitor Link commands
- 05-CWMP commands
- 06-Interface collaboration commands
- 07-System maintenance and debugging commands
- 08-NQA commands
- 09-BFD commands
- 10-Track commands
- 11-NTP commands
- 12-EAA commands
- 13-Process monitoring and maintenance commands
- 14-NETCONF commands
- 15-SNMP commands
- 16-RMON commands
- 17-Event MIB commands
- 18-NetStream commands
- 19-Sampler commands
- 20-Process placement commands
18-NetStream commands | 55.60 KB |
Session-based NetStream commands
display session-based netstream aggregation-cache
session-based netstream enable
session-based netstream export host
session-based netstream export source ip
session-based netstream timeout
Use display session-based netstream aggregation-cache to display session-based NetStream statistics.
display session-based netstream aggregation-cache { app | app-profile | app-user } *
context-admin
context-operator
app: Specifies the app aggregation mode.
app-profile: Specifies the app-profile aggregation mode.
app-user: Specifies the app-user aggregation mode.
To display session-based NetStream statistics in an aggregation mode, you must enable the aggregation mode by using the session-based netstream aggregation command.
# Display statistics about session-based NetStream in app aggregation mode.
<Sysname> display session-based netstream aggregation-cache app
Active entries :1
Timeout time for session-based NetStream entries :10
AppID InPkts InBytes OutPkts OutBytes
22742 4 240 4 240
Total Sessions : 1
Current Sessions : 1
SubsCribers : 1
# Display statistics about session-based NetStream in app-profile aggregation mode.
<Sysname> display session-based netstream aggregation-cache app-profile
Active entries :1
AppID ProfileID InPkts InBytes OutPkts OutBytes
22742 0 4 240 4 240
New Sessions : 0
# Display statistics about session-based NetStream in app-user aggregation mode.
<Sysname> display session-based netstream aggregation-cache app-user
Active entries :1
AppID UserIp InPkts InBytes OutPkts OutBytes
22742 8.8.8.8 4 240 4 240
Total Sessions : 1
Active entries |
Number of active session-based NetStream entries. |
Timeout time for session-based NetStream entries |
Maximum period of time in minutes a session-based NetStream entry can be cached before being exported to NetStream servers. |
App ID |
Application layer protocol ID. |
UserIP |
User IP address. |
ProfileID |
Traffic rule ID in bandwidth management. |
InPkts |
Number of upstream packets. |
InBytes |
Number of upstream bytes. |
OutPkts |
Number of downstream packets. |
OutBytes |
Number of downstream bytes. |
Total sessions |
Total number of sessions. |
New sessions |
Number of new sessions established in the current statistics collection interval. |
Current sessions |
Number of concurrent sessions at the time the display session-based netstream aggregation-cache command was executed. |
SubsCribers |
Total number of users in the current statistics collection interval. |
Use session-based netstream aggregation to enable session-based NetStream aggregation modes.
Use undo session-based netstream aggregation to disable session-based NetStream aggregation modes.
session-based netstream aggregation { app | app-profile | app-user } *
undo session-based netstream aggregation { app | app-profile | app-user } *
All session-based NetStream aggregation modes are disabled.
context-admin
app: Specifies the app aggregation mode, which aggregates traffic by application layer protocol ID.
app-profile: Specifies the app-profile aggregation mode, which aggregates traffic by application layer protocol ID and profile ID.
app-user: Specifies the app-user aggregation mode, which aggregates traffic by application layer protocol ID and user IP address.
# Enable the app aggregation mode for session-based NetStream aggregation.
[Sysname] session-based netstream aggregation app
Use session-based netstream enable to enable session-based NetStream.
Use undo session-based netstream enable to disable session-based NetStream.
Session-based NetStream is disabled.
context-admin
# Enable session-based NetStream.
[Sysname] session-based netstream enable
Use session-based netstream export host to specify a destination host for session-based NetStream data export.
Use undo session-based netstream export host to restore the default.
session-based netstream export host ip-address udp-port [ vpn-instance vpn-instance-name ]
No destination host is specified for session-based NetStream data export.
context-admin
ip-address: Specifies the IP address of the destination host.
udp-port: Specifies the destination UDP port number in the range of 0 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the destination host belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the destination host is on the public network, do not specify this option.
# Export session-based NetStream data to UDP port 9020 on host 172.16.1.1.
[Sysname] session-based netstream export host 172.16.1.1 9020
Use session-based netstream export source ip to specify a source IP address for session-based NetStream packets.
Use undo session-based netstream export source ip to restore the default.
session-based netstream export source ip ip-address
The source IP address of session-based NetStream packets is the primary IP address of the output interface.
context-admin
ip-address: Specifies an IP address.
# Specify 172.16.1.1 as the source IP address for session-based NetStream packets.
[Sysname] session-based netstream export source ip 172.16.1.1
Use session-based netstream timeout to set the aging timer for session-based NetStream entries.
Use undo session-based netstream timeout to restore the default.
session-based netstream timeout minutes
A session-based NetStream entry is automatically aged out and exported after being cached for 5 minutes.
context-admin
minutes: Sets the aging timer in minutes. The value range is 1 to 10.
When the aging timer for a session-based NetStream entry expires, statistics about the entry is cleared from the cache and exported to the NetStream servers.
# Set the aging timer for session-based NetStream entries to 5 minutes.
[Sysname] session-based netstream timeout 10
