07-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath IPS Comware 7 Command References (R8560 R8660)-6W60007-Network Management and Monitoring Command Reference
13-Process monitoring and maintenance commands
13-Process monitoring and maintenance commands 244.48 KB
Supported storage media depend on the device model. The examples in this chapter use the flash memory.
The display memory, display process, display process cpu, monitor process and monitor thread commands display information about both user processes and kernel threads. In these commands, "process" refers to both user processes and kernel threads.
display exception context
Use display exception context to display context information of process exceptions.
display exception context [ count value ] [ slot slot-number [ cpu cpu-number ] ]
context-admin
count value: Specifies the number of context information entries, in the range of 1 to 20. The default value is 1.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays context information of process exceptions on the IRF master device.
cpu cpu-number: Specifies a CPU by its number.
The system generates a context information entry for each process exception. A context information entry includes the process ID, the crash time, the core dump file directory, stack information, and register information.
# Display the exception context information on the x86-based 32-bit terminal.
<Sysname> display exception context
Index 1 of 1
Crashed PID: 120 (routed)
Crash signal: SIGBUS
Crash time: Tue Apr  9 17:14:30 2013
Core file path:
flash:/core/node0_routed_120_7_20130409-171430_1365527670.core
#0  0xb7caba4a
#1  0x0804cb79
#2  0xb7cd77c4
#3  0x08049f45
Backtrace stopped.
                          Registers' content
  eax:0xfffffffc   ebx:0x00000003   ecx:0xbfe244ec   edx:0x0000000a
  esp:0xbfe244b8   ebp:0xbfe244c8   esi:0xffffffff   edi:0xbfe24674
  eip:0xb7caba4a eflag:0x00000292    cs:0x00000073    ss:0x0000007b
   ds:0x0000007b    es:0x0000007b    fs:0x00000000    gs:0x00000033
# Display the exception context information on the x86-based 64-bit terminal.
Index 1 of 1
Crashed PID: 121 (routed)
Crash time: Sun Mar 31 11:12:21 2013
Core file path:
flash:/core/node0_routed_121_7_20130331-111221_1364728341.core
#0  0x00007fae7dbad20c
#1  0x00000000004059fa
#2  0x00007fae7dbd96c0
#3  0x0000000000402b29
Backtrace stopped.
                          Registers' content
       rax:0xfffffffffffffffc       rbx:0x00007fff88a5dd10
       rcx:0xffffffffffffffff       rdx:0x000000000000000a
       rsi:0x00007fff88a5dd10       rdi:0x0000000000000003
       rbp:0x00007fff88a5dcf0       rsp:0x00007fff88a5dcf0
        r8:0x00007fae7ea587e0        r9:0x0000000000000079
       r10:0xffffffffffffffff       r11:0x0000000000000246
       r12:0x0000000000405b18       r13:0x00007fff88a5ff7a
       r14:0x00007fff88a5de30       r15:0x0000000000000000
       rip:0x00007fae7dbad20c      flag:0x0000000000000246
        cs:0x0000000000000033        ss:0x000000000000002b
        ds:0x0000000000000000        es:0x0000000000000000
        fs:0x0000000000000000        gs:0x0000000000000000
   fs_base:0x00007fae80a5d6a0   gs_base:0x0000000000000000
   orig_ax:0x00000000000000e8
# Display the exception context information on the PowerPC-based 32-bit terminal.
Index 1 of 1
Crashed PID: 133 (routed)
Crash time: Wed Apr 10 15:47:49 2013
Core file path:
flash:/core/node0_routed_133_7_20130410-154749_1365608869.core
#0  0x184720bc
#1  0x10006b4c
Backtrace stopped.
                          Registers' content
grp00: 0x000000ee 0x7ffd6ad0 0x1800f440 0x00000004
grp04: 0x7ffd6af8 0x0000000a 0xffffffff 0x184720bc
grp08: 0x0002d200 0x00000003 0x00000001 0x1847209c
grp12: 0x10006b4c 0x10020534 0xd6744100 0x00000000
grp16: 0x00000000 0xa0203ff0 0xa028b12c 0xa028b13c
grp20: 0xa028b148 0xa028b168 0xa028b178 0xa028b190
grp24: 0xa028b1a8 0xa028b1b8 0x00000000 0x7ffd6c08
grp28: 0x10006cac 0x7ffd6f92 0x184c1b84 0x7ffd6ae0
  nip:0x184720bc    lr:0x10006b4c    cr:0x38000022   ctr:0x1847209c
  msr:0x0002db00   xer:0x00000000   ret:0xfffffffc dsisr:0x08000000
  gr3:0x00000003    mq:0x00000000  trap:0x00000c00   dar:0x1833114c
# Display the exception context information on the PowerPC-based 64-bit terminal.
Index 1 of 1
Crashed PID: 172 (routed)
Crash time: Sat Sep 15 16:53:16 2007
Core file path:
flash:/core/node1_routed_172_7_20070915-165316_1189875196.core
#0  0x00000fff803c66b4
#1  0x0000000010009b94
#2  0x00000fff80401814
Backtrace stopped.
                          Registers' content
     grp00: 0x00000000000000ee 0x00000fffffd04840
     grp02: 0x00000fff80425c28 0x0000000000000004
     grp04: 0x00000fffffd048c0 0x000000000000000a
     grp06: 0xffffffffffffffff 0x00000fff803c66b4
     grp08: 0x000000008002d000 0x0000000000000000
     grp10: 0x0000000000000000 0x0000000000000000
     grp12: 0x0000000000000000 0x00000fff80a096b0
     grp14: 0x000000007b964c00 0x000000007b7d0000
     grp16: 0x0000000000000001 0x000000000000000b
     grp18: 0x0000000000000031 0x0000000000a205b8
     grp20: 0x0000000000a20677 0x0000000000000000
     grp22: 0x000000007bb91014 0x0000000000000000
     grp24: 0xc0000000005ae1c8 0x0000000000000000
     grp26: 0xc0000001f00bff20 0xc0000001f00b0000
     grp28: 0x00000fffffd04a30 0x000000001001aed8
     grp30: 0x00000fffffd04fae 0x00000fffffd04840
       nip:0x00000fff803c66b4        lr:0x0000000010009b94
        cr:0x0000000058000482       ctr:0x00000fff803c66ac
       msr:0x000000008002d000       xer:0x0000000000000000
       ret:0xfffffffffffffffc     dsisr:0x0000000000000000
       gr3:0x0000000000000003     softe:0x0000000000000001
      trap:0x0000000000000c00       dar:0x00000fff8059d14c
# Display the exception context information on the MIPS-based 32-bit terminal.
Index 1 of 1
Crashed PID: 182 (routed)
Crash time: Sun Jan  2 08:11:38 2013
Core file path:
flash:/core/node4_routed_182_10_20130102-081138_1293955898.core
#0  0x2af2faf4
#1  0x00406d8c
Backtrace stopped.
                          Registers' content
 zero:0x00000000   at:0x1000dc00   v0:0x00000004   v1:0x00000003
   a0:0x00000003   a1:0x7fd267e8   a2:0x0000000a   a3:0x00000001
   t0:0x00000000   t1:0xcf08fa14   t2:0x80230510   t3:0xfffffff8
   t4:0x69766520   t5:0x00000000   t6:0x63cc6000   t7:0x44617461
   s0:0x7fd26f81   s1:0x00401948   s2:0x7fd268f8   s3:0x803e1db0
   s4:0x803e1da0   s5:0x803e1d88   s6:0x803e1d70   s7:0x803e1d60
   t8:0x00000008   t9:0x2af2fae0   k0:0x00000000   k1:0x00000000
   gp:0x2af9a3a0   sp:0x7fd267c0   s8:0x7fd267c0   ra:0x00406d8c
   sr:0x0000dc13   lo:0xef9db265   hi:0x0000003f  bad:0x2add2010
cause:0x00800020   pc:0x2af2faf4
# Display the exception context information on the MIPS-based 64-bit terminal.
Index 1 of 1
Crashed PID: 270 (routed)
Crash time: Wed Mar 27 12:39:12 2013
Core file path:
flash:/core/node16_routed_270_10_20130327-123912_1364387952.core
#0  0x0000005555a3bcb4
#1  0x0000000120006c1c
Backtrace stopped.
                          Registers' content
      zero:0x0000000000000000        at:0x0000000000000014
        v0:0x0000000000000004        v1:0x0000000000000003
        a0:0x0000000000000003        a1:0x000000ffff899d90
        a2:0x000000000000000a        a3:0x0000000000000001
        a4:0x0000005555a9b4e0        a5:0x0000000000000000
        a6:0xffffffff8021349c        a7:0x20696e206368616e
        t0:0x0000000000000000        t1:0xffffffff80105068
        t2:0xffffffff80213890        t3:0x0000000000000008
        s0:0x0000005555a99c40        s1:0x000000ffff89af5f
        s2:0x0000000120007320        s3:0x0000005555a5f470
        s4:0x000000ffff899f80        s5:0xffffffff803cc6c0
        s6:0xffffffff803cc6a8        s7:0xffffffff803cc690
        t8:0x0000000000000002        t9:0x0000005555a3bc98
        k0:0x0000000000000000        k1:0x0000000000000000
        gp:0x0000000120020460        sp:0x000000ffff899d70
        s8:0x000000ffff899d80        ra:0x0000000120006c1c
        sr:0x000000000400fff3        lo:0xdf3b645a1cac08c9
        hi:0x000000000000007f       bad:0x000000555589ba84
     cause:0x0000000000800020        pc:0x0000005555a3bcb4
Filed
Crashed PID
ID of the crashed process.
Crash signal
Signals that led to the crash:
·     SIGABRT—Abort.
·     SIGBUS—Bus error.
·     SIGFPE—Erroneous arithmetic operation.
·     SIGILL—Illegal hardware instructions.
·     SIGQUIT—Quit signal sent by the controlling terminal.
·     SIGSEGV—Invalid memory access.
·     SIGSYS—Invalid system call.
·     SIGTRAP—Trap message.
·     SIGXCPU—CPU usage limit exceeded.
·     SIGXFSZ—File size limit exceeded.
·     SIGUNKNOW—Unknown reason.
Crash time
Time when the crash occurred.
Core file path
Directory where the core dump file is saved.
Backtrace stopped
All stack information has been displayed.
reset exception context
display exception filepath
Use display exception filepath to display the core dump file directory.
display exception filepath [ slot slot-number [ cpu cpu-number ] ]
context-admin
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the core dump file directory on the master device.
# Display the core dump file directory on the specified slot.
<Sysname> display exception filepath slot 1
The exception filepath on slot 1 is flash:.
display kernel deadloop
Use display kernel deadloop to display kernel thread deadloop information.
display kernel deadloop show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of deadloops to display, in the range of 1 to 20.
offset: Specifies the offset between the starting deadloop and the most recent deadloop, in the range of 0 to 19. The default value is 0.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays kernel thread deadloop information on the master device.
This command is supported only on the default context.
# Display brief information about the most recent kernel thread deadloop.
<Sysname> display kernel deadloop 1
----------------- Deadloop record 1 -----------------
Description          : BUG: soft lockup - CPU#0 stuck for 61! [comsh: 16306]
Recorded at          : 2013-05-01  11:16:00.823018
Occurred at          : 2013-05-01  11:16:00.823018
Instruction address  : 0x4004158c
Thread               : comsh (TID: 16306)
Context              : thread context
Slot                 : 1
Cpu                  : 0
VCPU ID              : 0
Kernel module info   : module name (mrpnc) module address (0xe332a000)
# Display detailed information about the most recent kernel thread deadloop.
<Sysname> display kernel deadloop 1 verbose
Slot                 : 1
Cpu                  : 0
VCPU ID              : 0
Last 5 thread switches : migration/0 (11:16:00.823018)-->
                         swapper (11:16:00.833018)-->
                         kthreadd (11:16:00.833518)-->
                         swapper (11:16:00.833550)-->
                         disk (11:16:00.833560)
Register content:
Reg:       r0, Val = 0x00000000 ; Reg:       r1, Val = 0xe2be5ea0 ;
Reg:       r2, Val = 0x00000000 ; Reg:       r3, Val = 0x77777777 ;
Reg:       r4, Val = 0x00000000 ; Reg:       r5, Val = 0x00001492 ;
Reg:       r6, Val = 0x00000000 ; Reg:       r7, Val = 0x0000ffff ;
Reg:       r8, Val = 0x77777777 ; Reg:       r9, Val = 0x00000000 ;
Reg:      r10, Val = 0x00000001 ; Reg:      r11, Val = 0x0000002c ;
Reg:      r12, Val = 0x057d9484 ; Reg:      r13, Val = 0x00000000 ;
Reg:      r14, Val = 0x00000000 ; Reg:      r15, Val = 0x02000000 ;
Reg:      r16, Val = 0xe2be5f00 ; Reg:      r17, Val = 0x00000000 ;
Reg:      r18, Val = 0x00000000 ; Reg:      r19, Val = 0x00000000 ;
Reg:      r20, Val = 0x024c10f8 ; Reg:      r21, Val = 0x057d9244 ;
Reg:      r22, Val = 0x00002000 ; Reg:      r23, Val = 0x0000002c ;
Reg:      r24, Val = 0x00000002 ; Reg:      r25, Val = 0x24000024 ;
Reg:      r26, Val = 0x00000000 ; Reg:      r27, Val = 0x057d9484 ;
Reg:      r28, Val = 0x0000002c ; Reg:      r29, Val = 0x00000000 ;
Reg:      r30, Val = 0x0000002c ; Reg:      r31, Val = 0x00000000 ;
Reg:       cr, Val = 0x84000028 ; Reg:      nip, Val = 0x057d9550 ;
Reg:      xer, Val = 0x00000000 ; Reg:       lr, Val = 0x0186eff0 ;
Reg:      ctr, Val = 0x682f7344 ; Reg:      msr, Val = 0x00784b5c ;
Reg:     trap, Val = 0x0000b030 ; Reg:      dar, Val = 0x77777777 ;
Reg:    dsisr, Val = 0x40000000 ; Reg:   result, Val = 0x00020300 ;
Dump stack (total 1024 bytes, 16 bytes/line):
0xe2be5ea0: 02 be 5e c0 24 00 00 24 00 00 00 00 05 7d 94 84
0xe2be5eb0: 00 00 00 04 00 00 00 00 00 00 00 28 05 8d 34 c4
0xe2be5ec0: 02 be 60 a0 01 86 ef f0 00 00 00 00 00 00 00 00
0xe2be5ed0: 02 04 05 b4 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5ee0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5ef0: 95 47 73 35 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5f00: a0 e1 64 21 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5f10: 00 00 00 00 00 00 00 00 00 00 00 00 01 e9 00 00
0xe2be5f20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be5f30: 00 00 00 00 00 00 00 00 02 be 66 c0 02 be 66 d0
0xe2be5f40: 02 be 61 e0 00 00 00 02 00 00 00 00 02 44 b3 a4
0xe2be5f50: 02 be 5f 90 00 00 00 08 02 be 5f e0 00 00 00 08
0xe2be5f60: 02 be 5f 80 00 ac 1b 14 00 00 00 00 00 00 00 00
0xe2be5f70: 05 b4 5f 90 02 be 5f e0 00 00 00 30 02 be 5f e0
0xe2be5f80: 02 be 5f c0 00 ac 1b f4 00 00 00 00 02 45 00 00
0xe2be5f90: 00 03 00 00 00 00 00 00 02 be 5f e0 00 00 00 30
0xe2be5fa0: 02 be 5f c0 00 ac 1b 14 61 f1 2e ae 02 45 00 00
0xe2be5fb0: 02 44 b3 74 02 be 5f d0 00 00 00 30 02 be 5f e0
0xe2be5fc0: 02 be 60 60 01 74 ff f8 00 00 00 00 00 00 08 00
0xe2be5fd0: 02 be 5f f0 00 e8 93 7e 02 be 5f f8 02 be 5f fc
0xe2be5fe0: 00 00 00 00 00 00 00 00 00 00 00 00 02 be 60 18
0xe2be5ff0: 02 be 60 10 00 e9 65 98 00 00 00 58 00 00 2a 4f
0xe2be6000: 02 be 60 10 00 00 00 00 00 00 00 00 02 be 60 68
0xe2be6010: 02 be 60 40 00 e8 c6 a0 00 00 11 17 00 00 00 00
0xe2be6020: 02 be 60 40 00 00 00 00 00 00 00 00 02 be 60 98
0xe2be6030: 02 27 00 00 00 00 00 00 00 00 00 00 02 be 60 68
0xe2be6040: 02 be 60 60 00 00 00 01 00 00 b0 30 02 be 60 98
0xe2be6050: 00 00 00 04 02 21 00 00 00 00 00 00 01 e9 00 00
0xe2be6060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0xe2be6070: 00 00 00 00 00 00 00 00 02 be 66 c0 02 be 66 d0
0xe2be6080: 02 be 61 e0 00 00 00 02 00 00 00 00 02 be 61 70
0xe2be6090: 00 00 00 00 02 21 00 00 05 8d 34 c4 05 7d 92 44
Call trace:
Function Address = 0x8012a4b4
Function Address = 0x8017989c
Function Address = 0x80179b30
Function Address = 0x80127438
Function Address = 0x8012d734
Function Address = 0x80100a00
Function Address = 0xe0071004
Function Address = 0x8016ce0c
Function Address = 0x801223a0
Instruction dump:
41a2fe9c 812300ec 800200ec 7f890000 409efe8c 80010014 540b07b9 40a2fe80
4bfffe6c 80780290 7f64db78 4804ea35 <807f002c> 38800000 38a00080 3863000c
Description for the kernel thread deadloop, including the CPU number, thread running time, thread name, and thread number.
Recorded at
Time when the kernel thread deadloop was recorded, with microsecond precision.
Occurred at
Time when the kernel thread deadloop occurred, with microsecond precision.
Instruction address
Instruction address for the kernel thread deadloop.
Thread
Name and number of the kernel thread deadloop.
Context
Context for the kernel thread deadloop.
Cpu
Number of the CPU where the kernel thread ran.
VCPU ID
Number of the CPU core where the kernel thread ran.
Kernel module info
Information about kernel modules that had been loaded when the kernel thread deadloop was detected, including:
·     Module name—Kernel module name.
·     Module address—Memory address of the module.
Last five kernel thread switches on the CPU before the kernel thread deadloop was detected, including kernel thread name and kernel thread switching time with microsecond precision.
Register content
Register information:
·     Reg—Name of a register.
·     Val—Value saved in a register.
Dump stack
Stack information.
Call trace
Function call stack information, which shows the instruction address of a called function at each level.
Instruction dump
Instruction code when the kernel thread deadloop was detected. ffffffff indicates an illegitimate instruction code.
No information to display
No kernel thread deadloop information.
reset kernel deadloop
display kernel deadloop configuration
Use display kernel deadloop configuration to display kernel thread deadloop detection configuration.
display kernel deadloop configuration [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the kernel thread deadloop detection configuration for the master device.
# Display kernel thread deadloop detection configuration.
<Sysname> display kernel deadloop configuration
Thread dead loop detection: Enabled
Dead loop timer (in seconds): 20
Cores with dead loop detection enabled: 0-1
Dead loop action threshold: 2 consecutive dead loops
Threads excluded from monitoring: 1
  TID:     15   Name: co0
Dead loop timer (in seconds): n
Time interval (in seconds) to identify a kernel thread deadloop. A kernel thread deadloop occurs if a kernel thread runs more than n seconds.
Kernel threads excluded from kernel thread deadloop detection. This field appears only if the monitor kernel deadloop exclude-thread command is configured.
Name
Kernel thread name.
TID
Kernel thread number.
No thread is excluded from monitoring
All kernel threads are monitored by kernel thread deadloop detection.
display kernel exception
Use display kernel exception to display kernel thread exception information.
display kernel exception show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of kernel exceptions to display, in the range of 1 to 20.
offset: Specifies the offset between the starting exception and the most recent exception, in the range of 0 to 19. The default value is 0.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays kernel thread exception information of the master device.
If an exception occurs to a running kernel thread, the system automatically records the exception information.
# Display brief information about the most recent kernel thread exception.
<Sysname> display kernel exception 1
----------------- Exception record 1 -----------------
Description          : Oops[#0]
Recorded at          : 2017-05-01  11:16:00.823018
Occurred at          : 2017-05-01  11:16:00.823018
Slot                 : 1
Cpu                  : 0
VCPU ID              : 0
                       module name (disk) module address (0xe00bd000)
# Display detailed information about the most recent kernel thread exception.
<Sysname> display kernel exception 1 verbose
Slot                 : 1
Cpu                  : 0
VCPU ID              : 0
                       module name (12500) module address (0xe00bd000)
Register content:
Call trace:
Instruction dump:
For more information about the command output, see Table 2.
reset kernel exception
display kernel reboot
Use display kernel reboot to display reboot information of member devices.
display kernel reboot show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of reboots to display, in the range of 1 to 20.
offset: Specifies the offset between the starting reboot and the most recent reboot, in the range of 0 to 19. The default value is 0.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays reboot information of the master device. Reboot information of member devices is recorded in the memory of the master device. If the master device is powered off, the reboot information is lost.
# Display brief information about the most recent reboot.
<Sysname> display kernel reboot 1
----------------- Reboot record 1 -----------------
Reason               : 0x31
Slot                 : 1
Target Slot          : 1
Cpu                  : 0
Target CPU           : 7
VCPU ID              : 0
# Display detailed information about the most recent reboot.
<Sysname> display kernel reboot 1 verbose
Reason               : 0x31
Slot                 : 1
Target Slot          : 1
Cpu                  : 0
Target CPU           : 7
VCPU ID              : 0
Call trace:
Recorded at
Time when the reboot was recorded, with microsecond precision.
Occurred at
Time when the reboot occurred, with microsecond precision.
Reason
Reboot reason.
Thread
Name and number of the kernel thread that was running when the reboot occurred.
Context
Context where the reboot occurred.
Slot
Number of the slot that triggered the reboot.
Target Slot
Number of the rebooted slot.
Cpu
Number of the CPU that triggered the reboot.
Target CPU
Number of the CPU that rebooted.
VCPU ID
Number of the CPU core that triggered the reboot.
Kernel module info
Information about kernel modules that had been loaded when the reboot occurred, including the kernel module names and memory addresses.
Last five kernel thread switches that occurred on the CPU before the reboot, including the kernel thread names and kernel thread switching time points, with microsecond precision.
Dump stack
Stack information for the threads that were running when the reboot occurred.
Call trace
Function call stack information.
No reboot information exists.
reset kernel reboot
display kernel starvation
Use display kernel starvation to display kernel thread starvation information.
display kernel starvation show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
show-number: Specifies the number of thread starvations to display, in the range of 1 to 20.
offset: Specifies the offset between the starting starvation and the most recent starvation, in the range of 0 to 19. The default value is 0.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays kernel thread starvation information of the master device.
# Display brief information about the most recent kernel thread starvation.
<Sysname> display kernel starvation 1
----------------- Starvation record 1 -----------------
Description          : INFO: task comsh: 16306 blocked for more than 10 seconds.
Slot                 : 1
Cpu                  : 0
VCPU ID              : 0
# Display detailed information about the most recent kernel thread starvation.
<Sysname> display kernel starvation 1 verbose
Slot                 : 1
Cpu                  : 0
VCPU ID              : 0
Register content:
Call trace:
Instruction dump:
For detailed information about the command output, see Table 2.
reset kernel starvation
display kernel starvation configuration
Use display kernel starvation configuration to display kernel thread starvation detection configuration.
display kernel starvation configuration [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays kernel thread starvation detection configuration on the master device.
# Display kernel thread starvation detection configuration.
<Sysname> display kernel starvation configuration
Thread starvation detection: Disabled
Starvation timer (in seconds): 10
  TID:    123   Name: co0
Table 5 Command output
Starvation timer (in seconds): n
Time interval (in seconds) to identify a kernel thread starvation. A kernel thread starvation occurs if a kernel thread does not run within n seconds.
Kernel threads excluded from kernel thread starvation detection.
Name
Kernel thread name.
TID
monitor kernel starvation enable
monitor kernel starvation exclude-thread
monitor kernel starvation time
display process
Use display process to display process state information.
display process [ all | job job-id | name process-name ] [ slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
all: Specifies all processes. With the all keyword or without any parameters, the command displays state information for all processes.
job job-id: Specifies a process by its job ID, in the range of 1 to 2147483647. Each process has a fixed job ID.
name process-name: Specifies a process by its name, a case-insensitive string of 1 to 15 characters that must not contain question marks or spaces.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays process state information on the master device.
# Display state information for the process scmd.
<Sysname> display process name scmd
                             Job ID: 1
                                PID: 1
                         Parent JID: 0
                         Parent PID: 0
                    Executable path: /sbin/scmd
                           Instance: 0
                            Respawn: OFF
                      Respawn count: 1
             Max. spawns per minute: 0
                       Last started: Wed Jun  1 14:45:46 2013
                      Process state: sleeping
                          Max. core: 0
                               ARGS: -
    TID  LAST_CPU    Stack      PRI    State   HH:MM:SS:MSEC  Name
      1      0          0K      120      S     0:0:5:220      scmd
Table 6 Command output
Job ID
Job ID of the process. The job ID never changes.
PID
Number of the process. The number identifies the process, and it might change as the process restarts.
Parent JID
Job ID of the parent process.
Parent PID
Number of the parent process.
Executable path
Executable path of the process. For a kernel thread, this field displays a hyphen (-).
Instance
Instance number of the process. Whether a process can run multiple instances depends on the software implementation.
Respawn
Indicates whether the process restarts when an error occurs:
·     ON—The process automatically restarts.
·     OFF—The process does not automatically restarts.
Respawn count
Times that the process has restarted. The starting value is 1.
Maximum number of times that the process can restart within one minute. If the threshold is reached, the system automatically shuts down the process.
Last started
Time when the most recent restart occurred.
Process state
State of the process:
·     running—Running or waiting in the queue.
·     sleeping—Interruptible sleep.
·     traced or stopped—Stopped.
·     uninterruptible sleep—Uninterruptible sleep.
·     zombie—The process has quit, but some resources are not released.
Max. core
Maximum number of core dump files that the process can create. 0 indicates that the process never creates a core dump file. A process creates a core dump file after it abnormally restarts. If the number of core dump files reaches the maximum value, no more core dump files are created. Core dump files are helpful for troubleshooting.
ARGS
Parameters carried by the process during startup. If the process carries no parameters, this field displays a hyphen (-).
TID
Thread ID.
LAST_CPU
Number of the CPU on which the process is last scheduled.
Stack
Stack size.
PRI
Thread priority.
Thread state:
·     R—Running.
·     S—Sleeping.
·     T—Traced or stopped.
·     D—Uninterruptible sleep.
·     Z—Zombie.
HH:MM:SS:MSEC
Running time since the most recent start.
Name
Process name.
# Display state information for all processes.
<Sysname> display process all
    JID    PID %CPU %MEM STAT PRI TTY HH:MM:SS COMMAND
      1      1  0.0  0.0   S  120  -  00:00:04 scmd
      2      2  0.0  0.0   S  115  -  00:00:00 [kthreadd]
      3      3  0.0  0.0   S   99  -  00:00:00 [migration/0]
      4      4  0.0  0.0   S  115  -  00:00:05 [ksoftirqd/0]
      5      5  0.0  0.0   S   99  -  00:00:00 [watchdog/0]
      6      6  0.0  0.0   S  115  -  00:00:00 [events/0]
      7      7  0.0  0.0   S  115  -  00:00:00 [khelper]
      8      8  0.0  0.0   S  115  -  00:00:00 [kblockd/0]
      9      9  0.0  0.0   S  115  -  00:00:00 [ata/0]
     10     10  0.0  0.0   S  115  -  00:00:00 [ata_aux]
     11     11  0.0  0.0   S  115  -  00:00:00 [kseriod]
     12     12  0.0  0.0   S  120  -  00:00:00 [vzmond]
     13     13  0.0  0.0   S  120  -  00:00:00 [pdflush]
     14     14  0.0  0.0   S  120  -  00:00:00 [pdflush]
     15     15  0.0  0.0   S  115  -  00:00:00 [kswapd0]
     16     16  0.0  0.0   S  115  -  00:00:00 [aio/0]
     17     17  0.0  0.0   S  115  -  00:00:00 [scsi_eh_0]
     18     18  0.0  0.0   S  115  -  00:00:00 [scsi_eh_1]
     19     19  0.0  0.0   S  115  -  00:00:00 [scsi_eh_2]
     35     35  0.0  0.0   D  100  -  00:00:00 [lipc_topology]
---- More ----
Table 7 Command output
JID
Job ID of a process. It never changes.
PID
Number of a process.
%CPU
CPU usage in percentage (%).
%MEM
Memory usage in percentage (%).
STAT
State of a process:
·     R—Running.
·     S—Sleeping.
·     Z—Zombie.
PRI
Priority of a process for scheduling.
TTY
TTY used by a process. It displays a hyphen (-) for non-default contexts.
HH:MM:SS
Running time since the most recent start. If the running time reaches or exceeds 100 hours, this field displays only the number of hours.
COMMAND
Name and parameters of a process. If square brackets ([ ]) exist in a process name, the process is a kernel thread.
display process cpu
Use display process cpu to display CPU usage of all processes.
display process cpu [ slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays CPU usage of all processes on the master device.
# Display CPU usage for all processes.
<Sysname> display process cpu
CPU utilization in 5 secs: 16.8%; 1 min: 4.7%; 5 mins: 4.7%
    JID      5Sec      1Min      5Min    Name
      1      0.0%      0.0%      0.0%    scmd
      2      0.0%      0.0%      0.0%    [kthreadd]
      3      0.1%      0.0%      0.0%    [ksoftirqd/0]
Table 8 Command output
System CPU usage within the last 5 seconds, 1 minute, and 5 minutes.
JID
5Sec
CPU usage of the process within the last 5 seconds.
1Min
CPU usage of the process within the last minute.
5Min
CPU usage of the process within the last 5 minutes.
Name
Name of the process. If square brackets ([ ]) exist in a process name, the process is a kernel thread.
display process log
Use display process log to display log information for all user processes.
display process log [ slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays log information for all user processes on the master device.
# Display log information for all user processes.
<Sysname> display process log
Process       JobID  PID    Abort Core Exit Kill StartTime      EndTime
knotify       92     92     N     N    0    36   12-17 07:10:27 12-17 07:10:27
knotify       93     93     N     N    0    --   12-17 07:10:27 12-17 07:10:27
automount     94     94     N     N    0    --   12-17 07:10:27 12-17 07:10:28
knotify       111    111    N     N    0    --   12-17 07:10:28 12-17 07:10:28
comsh         121    121    N     N    0    --   12-17 07:10:30 12-17 07:10:30
knotify       152    152    N     N    0    --   12-17 07:10:31 12-17 07:10:31
autocfgd      155    155    N     N    0    --   12-17 07:10:31 12-17 07:10:31
pkg_update    122    122    N     N    0    --   12-17 07:10:30 12-17 07:10:31
Table 9 Command output
Process
Name of a user process.
JobID
Job ID of a user process.
PID
Abort
Indicates whether the process exited abnormally:
·     Y—Yes.
·     N—No.
Core
Indicates whether the process can generate core dump files:
·     Y—Yes.
·     N—No.
Exit
Process exit code. This field displays two hyphens (--) if the process was killed by a signal.
Kill
Code of the signal that killed the process. This field displays two hyphens (--) if the process exited instead of being killed.
StartTime
Time when the user process started.
EndTime
Time when the user process ended.
display process memory
Use display process memory to display memory usage of all user processes.
display process memory [ slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays memory usage of all user processes on the master device.
When a user process starts, it requests the following types of memory from the system:
·     Text memory—Stores code for the user process.
·     Data memory—Stores data for the user process.
·     Stack memory—Stores temporary data.
·     Dynamic memory—Heap memory dynamically assigned and released by the system according to the needs of the user process. To view dynamic memory information, execute the display process memory heap command.
# Display memory usage for all user processes.
<Sysname> display process memory
   JID       Text      Data      Stack    Dynamic    Name
     1        384      1800         16         36    scmd
     2          0         0          0          0    [kthreadd]
     3          0         0          0          0    [ksoftirqd/0]
     4          0         0          0          0    [watchdog/0]
     5          0         0          0          0    [events/0]
     6          0         0          0          0    [khelper]
    29          0         0          0          0    [kblockd/0]
    49          0         0          0          0    [vzmond]
    52          0         0          0          0    [pdflush]
---- More ----
Table 10 Command output
JID
Text
Text memory used by the user process, in KB. The value for a kernel thread is 0.
Data
Data memory used by the user process, in KB. The value for a kernel thread is 0.
Stack
Stack memory used by the user process, in KB. The value for a kernel thread is 0.
Dynamic
Dynamic memory used by the user process, in KB. The value for a kernel thread is 0.
Name
Name of the user process. If square brackets ([ ]) exist in a process name, the process is a kernel thread.
display process memory heap address
display process memory heap size
Use display process memory heap to display the heap memory usage of a user process.
display process memory heap job job-id [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
job job-id: Specifies a user process by its job ID, in the range of 1 to 2147483647.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the heap memory usage of the user process on the master device.
Heap memory comprises fixed-sized blocks such as 16-byte or 64-byte blocks. It stores data and variables used by the user process. When a user process starts, the system dynamically allocates heap memory to the process.
Each memory block has an address represented in hexadecimal format, which can be used to access the memory block. You can view memory block addresses by using the display process memory heap size command, and view memory block contents by using the display process memory heap address command.
# Display brief information about heap memory usage for the process identified by job ID 1.
<Sysname> display process memory heap job 1
Total virtual memory heap space(in bytes) :  2228224
Total physical memory heap space(in bytes) :  262144
Total allocated memory(in bytes)          :  161576
# Display detailed information about heap memory usage for the process identified by job ID 1.
<Sysname> display process memory heap job 1 verbose
Heap usage:
Size       Free      Used     Total     Free Ratio
16         8         52       60        13%
64         3         1262     1265      0.2%
128        2         207      209       1%
512        3         55       58        5.1%
4096       3         297      300       1%
8192       1         19       20        5%
81920      0         1        1         0%
Summary:
Total virtual memory heap space (in bytes)  :  2293760
Total physical memory heap space (in bytes) :  58368
Total allocated memory (in bytes)           :  42368
Table 11 Command output
Size
Size of each memory block, in bytes.
Free
Number of free memory blocks.
Used
Number of used memory blocks.
Total
Total number of memory blocks.
Free Ratio
Ratio of free memory to total memory. It helps identify fragment information.
Use display process memory heap address to display heap memory content starting from a specified memory block for a process.
display process memory heap job job-id address starting-address length memory-length [ slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
address starting-address: Specifies the starting memory block by its address.
length memory-length: Specifies the memory block length in the range of 1 to 1024 bytes.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays heap memory content information on the master device.
When a user process runs abnormally, the command helps locate the problem.
# Display 128-byte memory block content starting from the memory block 0xb7e30580 for the process job 1.
<Sysname> display process memory heap job 1 address b7e30580 length 128
B7E30580:  14 00 EF FF 00 00 00 00 E4 39 E2 B7 7C 05 E3 B7  .........9..|...
B7E30590:  14 00 EF FF 2F 73 62 69 6E 2F 73 6C 62 67 64 00  ..../sbin/slbgd.
B7E305A0:  14 00 EF FF 00 00 00 00 44 3B E2 B7 8C 05 E3 B7  ........D;......
B7E305B0:  14 00 EF FF 2F 73 62 69 6E 2F 6F 73 70 66 64 00  ..../sbin/ospfd.
B7E305C0:  14 00 EF FF 00 00 00 00 A4 3C E2 B7 AC 05 E3 B7  .........<......
B7E305D0:  14 00 EF FF 2F 73 62 69 6E 2F 6D 73 74 70 64 00  ..../sbin/mstpd.
B7E305E0:  14 00 EF FF 00 00 00 00 04 3E E2 B7 CC 05 E3 B7  .........>......
B7E305F0:  14 00 EF FF 2F 73 62 69 6E 2F 6E 74 70 64 00 00  ..../sbin/ntpd..
Use display process memory heap size to display the addresses of heap memory blocks with a specified size used by a process.
display process memory heap job job-id size memory-size [ offset offset-size ] [ slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
size memory-size: Specifies the memory block size in the range of 1 to 4294967295.
offset offset-size: Specifies an offset in the range of 0 to 4294967295. The default value is 128. For example, suppose the system allocates 100 16-byte memory blocks to process job 1, and the process has used 66 blocks. Then if you execute the display process memory heap job 1 size 16 offset 50 command, the output shows the addresses of the 51st through 66th 16-byte blocks used by the process.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays heap memory block address information on the master device.
The command displays memory block addresses in hexadecimal format. To view memory block content, execute the display process memory heap address command.
# Display the addresses of 16-byte memory blocks used by process job 1.
<Sysname> display process memory heap job 1 size 16
0xb7e300c0  0xb7e300d0  0xb7e300e0  0xb7e300f0
0xb7e30100  0xb7e30110  0xb7e30120  0xb7e30130
0xb7e30140  0xb7e30150  0xb7e30160  0xb7e30170
0xb7e30180  0xb7e30190  0xb7e301a0  0xb7e301b0
0xb7e301c0  0xb7e301d0  0xb7e301e0  0xb7e301f0
0xb7e30200  0xb7e30210  0xb7e30220  0xb7e30230
# Display the addresses of 16-byte memory blocks starting from the fifth block used by process job 1.
<Sysname> display process memory heap job 1 size 16 offset 4
exception filepath
Use exception filepath to specify the directory for saving core dump files.
Use undo exception filepath to remove the specified directory.
exception filepath directory
undo exception filepath directory
The directory for saving core dump files is the root directory of the default file system. For more information about the default file system, see file system management in Fundamentals Configuration Guide.
directory: Specifies the directory for saving core dump files. The directory must be the root directory of a file system.
The system will save core dump files to the core folder in the specified directory on the master. If the core folder does not exist in the specified directory, the system creates the core folder before saving core dump files.
You can use the command to change the directory if there are different types of storage media on the device.
If no directory is specified or the specified directory is not accessible, the system cannot save core dump files.
# Set the directory for saving core dump files.
<Sysname> exception filepath flash:/
process core
monitor kernel deadloop action threshold
Use monitor kernel deadloop action threshold to set kernel thread deadloop protection thresholds.
Use undo monitor kernel deadloop action threshold to restore default settings.
monitor kernel deadloop action threshold threshold [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel deadloop action threshold [ slot slot-number [ cpu cpu-number ] ]
The kernel thread deadloop protection threshold is 1. The device takes protection actions immediately after detecting a kernel thread deadloop.
threshold: Specifies the number of kernel thread deadloops for triggering protection actions, in the range of 1 to 20.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command applies to the master device.
When the number of detected kernel thread deadloops reaches the kernel thread deadloop protection threshold, the device takes protection actions to remove the deadloops.
# Set the kernel thread deadloop protection threshold to 5.
[Sysname] monitor kernel deadloop action threshold 5
monitor kernel deadloop enable
Use monitor kernel deadloop enable to enable kernel thread deadloop detection.
Use undo monitor kernel deadloop enable to disable kernel thread deadloop detection.
monitor kernel deadloop enable [ slot slot-number [ cpu cpu-number [ core core-number&<1-64> ] ] ]
undo monitor kernel deadloop enable [ slot slot-number [ cpu cpu-number ] ]
Kernel thread deadloop detection is enabled.
core core-number&<1-64>: Specifies a maximum of 64 cores by their numbers. If you do not specify this option, all cores on the CPU are specified.
CAUTION
CAUTION:
Use this command only under the guidance of H3C Support. Inappropriate configuration can cause system breakdown. As a best practice, leave the default unchanged.
Kernel threads share resources in kernel space. If a kernel thread monopolizes the CPU for a long time, other threads cannot run, resulting in a deadloop.
This command enables the device to detect deadloops. If a thread occupies the CPU regularly, the device determines that a deadloop has occurred, logs the event, and reboots to resolve the issue.
# Enable kernel thread deadloop detection.
[Sysname] monitor kernel deadloop enable
monitor kernel deadloop time
Use monitor kernel deadloop exclude-thread to exclude a kernel thread from kernel thread deadloop detection.
Use undo monitor kernel deadloop exclude-thread to include a kernel thread in kernel thread deadloop detection.
monitor kernel deadloop exclude-thread tid [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel deadloop exclude-thread [ tid ] [ slot slot-number [ cpu cpu-number ] ]
Kernel thread deadloop detection monitors all kernel threads.
tid: Specifies a kernel thread by its ID, in the range of 1 to 2147483647. If you do not specify a kernel thread, the undo command restores the default.
You can exclude up to 128 kernel threads from kernel thread deadloop detection.
# Exclude kernel thread 15 from kernel thread deadloop detection.
[Sysname]monitor kernel deadloop exclude-thread 15
Use monitor kernel deadloop time to set the interval for identifying a kernel thread deadloop.
Use undo monitor kernel deadloop time to restore the default.
monitor kernel deadloop time time [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel deadloop time [ slot slot-number [ cpu cpu-number ] ]
The interval for identifying a kernel thread deadloop is 28 seconds.
time time: Specifies the interval for identifying a kernel thread deadloop, in the range of 1 to 65535 seconds.
If a kernel thread runs for the specified interval, kernel thread deadloop detection determines that a deadloop has occurred.
# Set the interval for identifying a kernel thread deadloop to 8 seconds.
[Sysname] monitor kernel deadloop time 8
Use monitor kernel starvation enable to enable kernel thread starvation detection.
Use undo monitor kernel starvation enable to disable kernel thread starvation detection.
monitor kernel starvation enable [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel starvation enable [ slot slot-number [ cpu cpu-number ] ]
Kernel thread starvation detection is disabled.
CAUTION
CAUTION:
Starvation occurs when a thread is unable to access shared resources.
The command enables the system to detect and report thread starvation. If a thread is not executed within an interval, the system considers that a starvation has occurred, and outputs a starvation message.
Thread starvation does not impact system operation. A starved thread can automatically run when certain conditions are met.
# Enable kernel thread starvation detection.
[Sysname] monitor kernel starvation enable
Use monitor kernel starvation exclude-thread to exclude a kernel thread from kernel thread starvation detection.
Use undo monitor kernel starvation exclude-thread to include a kernel thread in kernel thread starvation detection.
monitor kernel starvation exclude-thread tid [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel starvation exclude-thread [ tid ] [ slot slot-number [ cpu cpu-number ] ]
Kernel thread starvation detection, if enabled, monitors all kernel threads.
You can exclude up to 128 kernel threads from kernel thread starvation detection.
# Exclude kernel thread 15 from kernel thread starvation detection.
[Sysname] monitor kernel starvation exclude-thread 15
Use monitor kernel starvation time to set the interval for identifying a kernel thread starvation.
Use undo monitor kernel starvation time to restore the default.
monitor kernel starvation time time [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel starvation time [ slot slot-number [ cpu cpu-number ] ]
The interval for identifying a kernel thread starvation is 120 seconds.
time time: Specifies the interval for identifying a kernel thread starvation, in the range of 1 to 65535 seconds.
If a thread is not executed within the specified interval, the system considers that a starvation has occurred, and outputs a starvation message.
# Set the interval for identifying a kernel thread starvation to 120 seconds.
[Sysname] monitor kernel starvation time 120
monitor process
Use monitor process to display process statistics.
monitor process [ dumbtty ] [ iteration number ] [ slot slot-number [ cpu cpu-number ] ]
context-admin
dumbtty: Specifies dumbtty mode. In this mode, the command displays process statistics in descending order of CPU usage without refreshing statistics. If you do not specify this keyword, the command displays statistics for the top 10 processes in descending order of CPU usage in an interactive mode, and refreshes statistics every 5 seconds by default.
iteration number: Specifies the number of display times, in the range of 1 to 4294967295. If you specify the dumbtty keyword, the number argument is 1 by default. If neither the dumbtty keyword nor the number argument is specified, there is no limit to the display times and process statistics are refreshed every 5 seconds.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays process statistics for the master device.
If you do not specify the dumbtty keyword, the command displays process statistics in an interactive mode. In this mode, the system automatically determines the number of displayed processes according to the screen size, and does not display exceeding processes. You can also input interactive commands as shown in Table 12 to perform relevant operations.
Table 12 Interactive commands
Commands
? or h
Displays help information that includes available interactive commands.
1
Displays state information for physical CPUs. For example, if you enter 1 for the first time, the state of each physical CPU is displayed in a separate row. If you enter 1 again, the average value of all CPU states is displayed. If you enter 1 for the third time, separate states are displayed.
By default, the average value of all CPU states is displayed.
c
Sorts processes by CPU usage in descending order, which is the default setting.
d
Sets the interval for refreshing process statistics, in the range of 1 to 2147483647 seconds. The default value is 5 seconds.
f
Sorts processes by the number of open files in descending order. Files are identified by file descriptors (FDs).
k
Kills a process. Because the command can impact system operation, be cautious to use it.
l
Refreshes the screen.
m
Sorts processes by memory usage in descending order.
n
Changes the maximum number of processes displayed within a screen, in the range of 0 to 2147483647. The default value is 10. A value of 0 means no limit. Only processes not exceeding the screen size can be displayed.
q
Quits the interactive mode.
t
Sorts processes by running time in descending order.
Moves sort field to the next left column.
Moves sort field to the next right column.
# Display process statistics in dumbtty mode. In this mode, the system displays process statistics once, and then returns to command view.
<Sysname> monitor process dumbtty
428 processes; 561 threads; 2336 fds
Thread states: 18 running, 543 sleeping, 0 stopped, 0 zombie
CPU0: 89.53% idle, 0.00% user, 7.14% kernel, 3.33% interrupt, 0.00% steal
CPU1: 94.81% idle, 0.47% user, 2.36% kernel, 2.36% interrupt, 0.00% steal
Memory: 31775M total, 26159M available, page size 4K
        JID        PID  PRI  State  FDs    MEM  HH:MM:SS    CPU   Name
        404        404  120    S    16  16432K  03:22:57   0.68%  diagd
          1          1  120    S    18  11136K  00:08:21   0.27%  scmd
        348        348  115    R     0      0K  05:54:40   0.15%  [kdrvfwd20]
        349        349  115    R     0      0K  05:57:55   0.14%  [kdrvfwd21]
        350        350  115    R     0      0K  05:52:45   0.14%  [kdrvfwd22]
        352        352  115    R     0      0K  05:47:38   0.14%  [kdrvfwd24]
        354        354  115    R     0      0K  05:38:52   0.14%  [kdrvfwd26]
        344        344  115    R     0      0K  05:41:15   0.13%  [kdrvfwd16]
        345        345  115    R     0      0K  05:34:40   0.13%  [kdrvfwd17]
        346        346  115    R     0      0K  05:33:35   0.13%  [kdrvfwd18]
        347        347  115    R     0      0K  05:22:29   0.13%  [kdrvfwd19]
        351        351  115    R     0      0K  05:39:24   0.13%  [kdrvfwd23]
        353        353  115    R     0      0K  05:29:42   0.13%  [kdrvfwd25]
        355        355  115    R     0      0K  05:26:17   0.13%  [kdrvfwd27]
        356        356  115    R     0      0K  05:28:52   0.13%  [kdrvfwd28]
        357        357  115    R     0      0K  05:26:31   0.13%  [kdrvfwd29]
# Display process statistics twice in dumbtty mode.
<Sysname> monitor process dumbtty iteration 2
Five seconds later, the system refreshes process statistics as follows (which is the same as executing the monitor process dumbtty command twice at a 5-second interval):
428 processes; 561 threads; 2338 fds
Thread states: 19 running, 542 sleeping, 0 stopped, 0 zombie
CPU0: 86.26% idle, 1.05% user, 8.99% kernel, 3.70% interrupt, 0.00% steal
CPU1: 90.44% idle, 1.06% user, 4.78% kernel, 3.72% interrupt, 0.00% steal
Memory: 31775M total, 26158M available, page size 4K
        404        404  120    R    18  16460K  03:23:03   0.50%  diagd
          1          1  120    S    18  11136K  00:08:21   0.24%  scmd
        344        344  115    R     0      0K  05:41:25   0.13%  [kdrvfwd16]
        348        348  115    R     0      0K  05:54:51   0.13%  [kdrvfwd20]
        349        349  115    R     0      0K  05:58:06   0.13%  [kdrvfwd21]
        350        350  115    R     0      0K  05:52:56   0.13%  [kdrvfwd22]
        352        352  115    R     0      0K  05:47:49   0.13%  [kdrvfwd24]
        345        345  115    R     0      0K  05:34:51   0.12%  [kdrvfwd17]
        346        346  115    R     0      0K  05:33:45   0.12%  [kdrvfwd18]
        347        347  115    R     0      0K  05:22:39   0.12%  [kdrvfwd19]
        351        351  115    R     0      0K  05:39:34   0.12%  [kdrvfwd23]
        353        353  115    R     0      0K  05:29:52   0.12%  [kdrvfwd25]
        354        354  115    R     0      0K  05:39:02   0.12%  [kdrvfwd26]
        356        356  115    R     0      0K  05:29:02   0.12%  [kdrvfwd28]
        357        357  115    R     0      0K  05:26:41   0.12%  [kdrvfwd29]
<Sysname>
# Display process statistics in interactive mode.
Thread states: 20 running, 541 sleeping, 0 stopped, 0 zombie
CPU: 98.21% idle, 0.17% user, 1.57% kernel, 0.05% interrupt, 0.00% steal
        348        348  115    R     0      0K  05:55:08   0.09%  [kdrvfwd20]
        349        349  115    R     0      0K  05:58:22   0.09%  [kdrvfwd21]
        350        350  115    R     0      0K  05:53:12   0.09%  [kdrvfwd22]
        352        352  115    R     0      0K  05:48:05   0.09%  [kdrvfwd24]
        344        344  115    R     0      0K  05:41:41   0.09%  [kdrvfwd16]
        351        351  115    R     0      0K  05:39:50   0.09%  [kdrvfwd23]
        404        404  120    S    16  16468K  03:23:12   0.09%  diagd
        353        353  115    R     0      0K  05:30:07   0.09%  [kdrvfwd25]
        354        354  115    R     0      0K  05:39:18   0.09%  [kdrvfwd26]
        345        345  115    R     0      0K  05:35:07   0.08%  [kdrvfwd17]
The system refreshes process statistics every 5 seconds. You can enter interactive commands to perform operation as follows:
·     Enter h or a question mark (?) to display help information as follows:
Help for interactive commands:
      ?,h    Show the available interactive commands
        1    Toggle SMP view: '1' single/separate states
        c    Sort by the CPU field(default)
        d    Set the delay interval between screen updates
        f    Sort by number of open files
        k    Kill a job
        l    Refresh the screen
        m    Sort by memory used
        n    Set the maximum number of processes to display
        q    Quit the interactive display
        t    Sort by run time of processes since last restart
        <    Move sort field to the next left column
        >    Move sort field to the next right column
Press any key to continue
·     Enter d, and then enter a number to modify the refresh interval. If you enter 3, statistics are refreshed every 3 seconds.
Enter the delay interval between updates(1~2147483647): 3
·     Enter n, and then enter a number to modify the maximum number of displayed processes. If you enter 5, statistics for five processes are displayed.
Enter the max number of processes to display(0 means unlimited): 5
CPU: 97.24% idle, 0.28% user, 2.41% kernel, 0.07% interrupt, 0.00% steal
        349        349  115    R     0      0K  05:59:31   0.14%  [kdrvfwd21]
        348        348  115    R     0      0K  05:56:16   0.14%  [kdrvfwd20]
        350        350  115    R     0      0K  05:54:20   0.14%  [kdrvfwd22]
        352        352  115    R     0      0K  05:49:12   0.14%  [kdrvfwd24]
        404        404  120    S    16  16480K  03:24:25   0.14%  diagd
·     Enter f to sort processes by FDs in descending order. (You can also enter command c, m, or t to sort processes.)
366 processes; 467 threads; 3408 fds
Thread states: 1 running, 466 sleeping, 0 stopped, 0 zombie
CPU: 98.41% idle, 0.41% user, 1.16% kernel, 0.02% interrupt, 0.00% steal
Memory: 3933M total, 2087M available, page size 4K
        570        570  120    S   402 121288K  00:02:47   0.00%  ntopd
        205        205  100    S   221  44496K  00:00:07   0.00%  dbmd
        549        549  120    S   111 288520K  00:52:52   0.03%  dpid
        502        502  125    S    80  25468K  00:00:24   0.00%  ipstackd
        208        208  105    S    66   2208K  00:00:00   0.00%  had
      70414      70414  125    S    65  16736K  00:00:21   0.00%  ip6stackd
        249        249  120    S    57  41100K  00:00:16   0.00%  aclmgrd
        521        521  120    S    56  51844K  00:38:49   0.03%  ospfd
        236        236  120    S    48  10364K  00:00:37   0.00%  aaad
        510        510  120    S    48  23092K  00:00:00   0.00%  l3vpnd
·     Enter k and then enter a JID to kill a process. If you enter 208, the process with the JID of 208 is killed.
Enter the JID to kill: 208
365 processes; 466 threads; 3341 fds
Thread states: 1 running, 465 sleeping, 0 stopped, 0 zombie
CPU: 98.33% idle, 0.45% user, 1.20% kernel, 0.02% interrupt, 0.00% steal
        205        205  100    S   220  44496K  00:00:07   0.00%  dbmd
        549        549  120    S   111 288520K  00:52:53   0.05%  dpid
        502        502  125    S    80  25468K  00:00:24   0.01%  ipstackd
        521        521  120    S    56  51844K  00:38:50   0.03%  ospfd
        236        236  120    S    48  10364K  00:00:37   0.01%  aaad
     136620     136620  120    S    48  49232K  00:06:08   0.03%  ospfv3d
·     Enter q to quit interactive mode.
Table 13 Command output
84 processes; 107 threads; 683 fds
Numbers of processes, threads, and open files.
JID
Job ID of a process, which never changes.
PID
ID of a process.
PRI
Priority level of a process.
State of a process:
·     R—Running.
·     S—Sleeping.
·     Z—Zombie.
FDs
Number of open files for a process.
MEM
Memory usage. It displays 0 for a kernel thread.
HH:MM:SS
Running time of a process since last restart.
CPU
CPU usage of a process.
Name
Name of a process. If square brackets ([ ]) exist in a process name, the process is a kernel thread.
monitor thread
Use monitor thread to display thread statistics.
monitor thread [ dumbtty ] [ iteration number ] [ slot slot-number [ cpu cpu-number ] ]
context-admin
dumbtty: Specifies dumbtty mode. In this mode, the command displays all thread statistics in descending order of CPU usage without refreshing statistics. If you do not specify the keyword, the command displays statistics for top 10 processes in descending order of CPU usage in an interactive mode, and refreshes statistics every 5 seconds by default.
iteration number: Specifies the number of display times, in the range of 1 to 4294967295. If you specify the dumbtty keyword, the number argument is 1 by default. If neither the dumbtty keyword nor the number argument is specified, there is no limit to the display times.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays thread statistics for the master device.
If you do not specify the dumbtty keyword, the command displays thread statistics in an interactive mode. In this mode, the system automatically determines the number of displayed thread processes according to the screen size and does not display exceeding processes. You can also input interactive commands as shown in Table 14 to perform relevant operations.
Table 14 Interactive commands
Commands
? or h
1
Displays one of the following items in turn when you press 1 again and again:
·     Values of parameters of physical CPUs.
·     Average values of parameters of all CPUs.
By default, the command displays the average values of parameters of all CPUs.
c
Sorts statistics by CPU usage in descending order. By default, the command sorts statistics by CPU usage in descending order.
d
Sets the interval for refreshing statistics. The default interval is 5 seconds.
k
Kills a process. Because the command can impact system operation, be cautious when you use it.
l
n
Changes the maximum number of threads displayed within a screen, in the range of 0 to 2147483647. The default value is 10. A value of 0 means no limit. Only threads not exceeding the screen size can be displayed.
q
Quits interactive mode.
t
Sorts statistics by the running time since the latest startup.
# Display thread statistics in dumbtty mode.
<Sysname> monitor thread dumbtty
Thread states: 1 running, 106 sleeping, 0 stopped, 0 zombie
CPU states: 83.19% idle, 1.68% user, 10.08% kernel, 5.04% interrupt
Memory: 755M total, 417M available, page size 4K
    JID    TID  LAST_CPU  PRI  State  HH:MM:SS   MAX    CPU    Name
   1175   1175      0     120    R    00:00:00     1  10.75%   top
      1      1      0     120    S    00:00:06     1   2.68%   scmd
    881    881      0     120    S    00:00:09     1   2.01%   diagd
    776    776      0     120    S    00:00:01     0   0.67%   [DEVD]
    866    866      0     120    S    00:00:11     1   0.67%   devd
      2      2      0     115    S    00:00:00     0   0.00%   [kthreadd]
      3      3      0     115    S    00:00:01     0   0.00%   [ksoftirqd/0]
      4      4      0      99    S    00:00:00     1   0.00%   [watchdog/0]
      5      5      0     115    S    00:00:00     0   0.00%   [events/0]
      6      6      0     115    S    00:00:00     0   0.00%   [khelper]
    796    796      0     115    S    00:00:00     0   0.00%   [kip6fs/1]
<Sysname>
# Display thread statistics in interactive mode.
CPU states: 94.43% idle, 0.76% user, 3.64% kernel, 1.15% interrupt
   1176   1176      0     120    R    00:00:01     1   3.42%   top
    866    866      0     120    S    00:00:12     1   0.85%   devd
    881    881      0     120    S    00:00:09     1   0.64%   diagd
      1      1      0     120    S    00:00:06     1   0.42%   scmd
   1160   1160      0     120    S    00:00:01     1   0.21%   sshd
          k      Kill a job
          n      Set the maximum number of threads to display
          t      Sort by run time of threads since last restart
Enter the delay interval between screen updates (1~2147483647): 3
·     Enter n, and then enter a number to modify the maximum number of displayed threads. If you enter 5, statistics for five threads are displayed.
Enter the max number of threads to display(0 means unlimited): 5
CPU states: 93.26% idle, 0.99% user, 4.23% kernel, 1.49% interrupt
   1176   1176      0     120    R    00:00:02     1   3.71%   top
      1      1      0     120    S    00:00:06     1   0.92%   scmd
    866    866      0     120    S    00:00:13     1   0.69%   devd
    881    881      0     120    S    00:00:10     1   0.69%   diagd
    720    720      0     115    D    00:00:01     0   0.23%   [TMTH]
·     Enter k and then enter a JID to kill a thread. If you enter 881, the thread with the JID of 881 is killed.
Enter the JID to kill: 881
83 processes; 106 threads
Thread states: 1 running, 105 sleeping, 0 stopped, 0 zombie
CPU states: 96.26% idle, 0.54% user, 2.63% kernel, 0.54% interrupt
Memory: 755M total, 418M available, page size 4K
   1176   1176      0     120    R    00:00:04     1   1.86%   top
    866    866      0     120    S    00:00:14     1   0.87%   devd
      1      1      0     120    S    00:00:07     1   0.49%   scmd
    730    730      0       0    S    00:00:04     1   0.12%   [DIBC]
    762    762      0     120    S    00:00:22     1   0.12%   [MNET]
Table 15 Command output
Numbers of processes and threads.
JID
Job ID of a thread, which never changes.
TID
ID of a thread.
LAST_CPU
Number of the CPU on which the most recent thread scheduling occurs.
PRI
Priority level of a thread.
State of a thread:
·     R—Running.
·     S—Sleeping.
·     Z—Zombie.
HH:MM:SS
Running time of a thread since last restart.
MAX
Longest time that a single thread scheduling occupies the CPU, in milliseconds.
CPU
CPU usage of a thread.
Name
Name of a thread. If square brackets ([ ]) exist in a thread name, the thread is a kernel thread.
process core
Use process core to enable or disable a process to generate core dump files for exceptions and set the maximum number of core dump files.
process core { maxcore value | off } { job job-id | name process-name } [ slot slot-number [ cpu cpu-number ] ]
A process generates a core dump file for the first exception and does not generate any core dump files for subsequent exceptions.
context-admin
off: Disables core dump file generation.
maxcore value: Enables core dump file generation and sets the maximum number of core dump files, in the range of 1 to 10.
name process-name: Specifies a process by its name, a case-insensitive string of 1 to 15 characters.
job job-id: Specifies a process by its job ID, in the range of 1 to 2147483647. The job ID does not change after the process restarts.
cpu cpu-number: Specifies a CPU by its number.
The command applies to all instances of a process.
The command enables the system to generate a core dump file each time the specified process crashes until the maximum number of core dump files is reached. A core dump file records the exception information.
Because core dump files consume system storage resources, you can disable core dump file generation for processes for which you do not need to review exception information.
# Disable core dump file generation for process routed.
<Sysname> process core off name routed
# Enable core dump file generation for process routed and set the maximum number of core dump files to 5.
<Sysname> process core maxcore 5 name routed
display exception context
exception filepath
Use reset exception context to clear context information for process exceptions.
reset exception context [ slot slot-number [ cpu cpu-number ] ]
context-admin
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears context information for process exceptions on the IRF master device.
# Clear context information for exceptions.
<Sysname> reset exception context
Use reset kernel deadloop to clear kernel thread deadloop information.
reset kernel deadloop [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears kernel thread deadloop information for the master device.
# Clear kernel thread deadloop information.
<Sysname> reset kernel deadloop
Use reset kernel exception to clear kernel thread exception information.
reset kernel exception [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears kernel thread exception information for the master device.
# Clear kernel thread exception information.
<Sysname> reset kernel exception
reset kernel reboot
Use reset kernel reboot to clear kernel thread reboot information.
reset kernel reboot [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears kernel thread reboot information for the master device.
# Clear kernel thread reboot information.
<Sysname> reset kernel reboot
Use reset kernel starvation to clear kernel thread starvation information.
reset kernel starvation [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears kernel thread starvation information for the master device.
# Clear kernel thread starvation information.
<Sysname> reset kernel starvation
