HomeSupportConfigure & DeployConfiguration GuidesH3C S6805 & S6825 & S6850 & S9850 Configuration Guides-Release 66xx-6W10309-Security Configuration Guide
25-Microsegmentation configuration
25-Microsegmentation configuration 160.48 KB
Configuring microsegmentation
About microsegmentation
The microsegmentation feature, also called group-based security segregation, controls traffic based on groups the traffic assigned to. For example, you can group servers in data centers based on specific criteria and apply traffic control policies to different groups.
Basic concepts
Microsegment
A microsegment groups endpoints (such as servers) based on specific criteria. Each microsegment has a globally unique ID.
Group-based policy
A group-based policy (GBP) is a microsegment-based traffic control policy can be implemented by using the following functions:
·     PBR—A policy node corresponds to a GBP and controls communication between microsegments through the apply next-hop or apply output-interface null0 action. For more information about PBR, see Layer 3—IP Routing Configuration Guide.
·     QoS policy—A class-behavior association corresponds to a GBP and controls communication between microsegments through the filter deny or filter permit action in the traffic behavior. For more information about QoS policy, see QoS configuration ACL and QoS Configuration Guide.
·     Packet filtering—A packet filter corresponds to a GBP and controls communication between microsegments through the permit or deny rule in an ACL. For more information about packet filtering, see ACL configuration ACL and QoS Configuration Guide.
Components of microsegmentation
As shown in Figure 1, the microsegmentation feature contains the microsegment, ACL, and GBP settings. A GBP can be a QoS policy, a packet filter, or a PBR policy node.
This feature controls whether members in different microsegments can communicate. The GBP takes effect on the local end of a link. To control bidirectional traffic, configure this feature on both ends. Intermediate nodes do not require the configuration of this feature.
This feature can be used in IP, VXLAN, and EVPN networks. In an IP network, all settings must be configured on the Layer 3 gateway devices. In a VXLAN or EVPN network, all settings must be configured on the VTEPs.
Figure 1 Microsegmentation configuration workflow
How microsegmentation works
The microsegmentation feature works in the same way in IP, VXLAN, and EVPN networks. As shown in Figure 2, this section takes unidirectional traffic in an IP network as an example to illustrate how this feature works. This example uses a QoS policy as the GBP.
1.     After receiving a packet sent from Host A to Host D, Device A obtains its source IP address (192.168.1.2) and destination IP address (192.168.1.5).
2.     Device A searches the FIB table for the source IP address according to the longest match rule and determines that Host A belongs to microsegment 1.
3.     Device A searches the FIB table for the destination IP address according to the longest match rule and determines that Host B belongs to microsegment 2.
4.     Device A matches microsegment 1 and microsegment 2 against ACLs and executes one of the following actions in the QoS policy on matching packets:
¡     Forwards matching packets if the action is filter permit.
¡     Drops matching packets if the action is filter deny.
Figure 2 Forwarding of Layer 3 packets in an IP network
The microsegmentation feature works in the same way for cross-device packet forwarding.
Restrictions: Software version compatibility with microsegmentation
This feature is supported only in Release 6616 and later.
Restrictions and guidelines: Microsegmentation configuration
When you use this feature to control unidirectional inter-VPN traffic, follow these restrictions and guidelines:
·     On the source PE device, if the route guiding traffic forwarding is a network route, you must add the destination address of the route to a microsegment as a member.
·     On the destination PE device, if the route is a host route, you must add the destination address of the route to a microsegment as a member.
In Release 6635 and later, uRPF is automatically enabled when microsegmentation is enabled, and then you cannot configure uRPF at the CLI. After microsegmentation is enabled, the route table capacity is halved. In Release 6616 and Release 6616P01, to use a QoS policy, routing policy, or packet filter to match packets by microsegment, you must first enable uRPF. After uRPF is enabled, the route table capacity is halved.
To ensure correct forwarding on leaf and border devices on a VXLAN or EVPN network when a network route is used to match a microsegment member, make sure hosts have come online on the leaf devices.
In an EVPN network, if you configure the same members for microsegments on a leaf node and a border device, you must configure the same microsegment IDs to ensure correct traffic forwarding.
Microsegmentation tasks at a glance
To configure microsegmentation, perform the following tasks:
·     Configuring a microsegment
·     Configuring an ACL
·     Configure a GBP. Choose one option as needed:
¡     Configuring PBR
¡     Configuring a QoS policy
¡     Configuring packet filtering
·     (Optional.) Configuring the microsegment extended community attribute
Perform this task in an EVPN network to avoid extended community attribute conflicts.
·     (Optional.) Configuring the network address match method for microsegments
Prerequisites for microsegmentation configuration
This feature can be used in IP, VXLAN, and EVPN networks. For information about configuring these features, see the relevant configuration guides.
To control bidirectional traffic, you must configure the same microsegment settings on the two ends.
2.     Create a microsegment and enter microsegment view.
microsegment microsegment-id [ name microsegment-name ]
3.     Add a member to the microsegment.
member ipv4 ipv4-address { mask | mask-length } [ vpn-instance vpn-instance-name ]
member ipv6 ipv6-address prefix-length [ vpn-instance vpn-instance-name ]
By default, a microsegment does not contain members.
4.     Return to system view.
5.     Enable microsegmentation.
microsegment enable
By default, microsegmentation is disabled.
Configuring an ACL
To control bidirectional traffic, you must configure an ACL on both ends and configure an ACL rule with swapped source and destination microsegments on the two ends.
If you use a PBR policy node or a QoS policy as the GBP, the ACL rules must be permit rules. The apply action or QoS action is taken on matching packets.
If you use a packet filter as the GBP, the ACL rules can be permit or deny rules. Matching packets are permitted or denied.
2.     Create an IPv4 or IPv6 advanced ACL and enter its view. Choose one option as needed:
¡     acl [ ipv6 ] number acl-number [ name acl-name ] [ match-order { auto | config } ]
¡     acl [ ipv6 ] { advanced | basic } { acl-number | name acl-name } [ match-order { auto | config } ]
3.     Configure a rule.
For more information, see the rule command in ACL and QoS Command Reference.
In the rule command, the destination microsegment microsegment-id and source microsegment microsegment-id options must be specified, and other parameters can be configured as needed.
Configuring a GBP
Configuring PBR
You can control communication between microsegments by referencing an ACL and specifying a next hop (permitting traffic) or the output interface NULL0 (dropping traffic) in a PBR policy.
To control bidirectional traffic, you must configure PBR on both ends.
2.     Create a node for a policy, and enter its view.
3.     Set an ACL match criterion for the node.
By default, no ACL match criterion is set.
4.     Configure an action for the node. Choose one option as needed:
¡     Set a next hop.
apply next-hop ip-address
¡     Set NULL0 as the output interface.
By default, no action is configured.
5.     Return to system view.
6.     Specify the policy for interface PBR.
ip policy-based-route policy-name
By default, no interface policy is applied to an interface.
You can use the traffic filtering action in a QoS policy to control communication between microsegments.
2.     Define a traffic class.
a.     Create a traffic class and enter traffic class view.
b.     Configure a match criterion.
if-match acl [ ipv6 ] { acl-number | name acl-name }
By default, no match criterion is configured.
Only IPv4 and IPv6 advanced ACLs can be used to match packets.
c.     Return to system view.
3.     Define a traffic behavior.
a.     Create a traffic behavior and enter traffic behavior view.
b.     Configure a traffic filtering action.
filter { deny | permit }
By default, no traffic filtering action is configured.
4.     Define a QoS policy.
a.     Create a QoS policy and enter QoS policy view.
qos policy policy-name
b.     Associate the traffic class with the traffic behavior in the QoS policy.
classifier classifier-name behavior behavior-name
By default, a traffic class is not associated with a traffic behavior.
5.     Apply the QoS policy to an interface.
a.     Enter interface view.
b.     Apply the QoS policy to the inbound direction of the interface.
qos apply policy policy-name inbound [ share-mode ]
By default, no QoS policy is applied to an interface.
You can apply an ACL to the inbound direction of an interface to control communication between microsegments.
2.     Enter interface view.
3.     Apply an ACL to the inbound direction of the interface.
packet-filter [ ipv6 ] { acl-number | name acl-name } inbound [ share-mode ]
By default, no ACL is applied to an interface.
A MAC/IP advertisement route carries microsegment IDs in a BGP extended community attribute and advertises microsegment settings to a peer through the extended community attribute. For more information about MAC/IP advertisement routes, see EVPN overview in EVPN Configuration Guide.
To avoid attribute conflicts, you can perform this task to modify the microsegment extended community attribute value.
Software version and feature compatibility
This feature is supported only in Release 6635 and later.
By default, BGP is not run, and no BGP instance exists.
3.     Set the microsegment extended community attribute value.
extcommunity-type microsegment-id microsegment-type-value
The default setting is 83ff (hexadecimal).
4.     (Optional.) Display the microsegment extended community attribute value in BGP EVPN routes and the microsegment ID.
display bgp l2vpn evpn
For more information about this command, see EVPN commands in EVPN Command Reference.
5.     (Optional.) Display the microsegment IDs carried in routes.
display ip routing-table
For more information about this command, see IP basics commands in Layer 3—IP Routing Command Reference.
The device determines the segment membership of packets by matching the source and destination IP addresses of packets. The following match methods are available:
·     Exact match—The mask lengths of the source and destination IP addresses must be equal to those of members in microsegments. For example, a packet sourced from 10.10.10.1/24 matches member 10.10.10.0/24 instead of 10.10.10.0/23.
·     Longest match—The mask lengths of the source and destination IP addresses can be greater than or equal to those of members in microsegments. For example, a packet sourced from 10.10.10.1/24 matches member 10.10.10.0/16.
The device uses different match methods for different member types of microsegments:
·     Host addresses (IPv4 addresses with a 32-bit mask and IPv6 addresses with a 128-bit prefix) use the longest match method, which cannot be modified.
·     The default route (0.0.0.0/0 or 0::0/0) uses the exact match method, which cannot be modified.
·     Network addresses (IPv4 addresses with a 1-bit to 31-bit mask and IPv6 addresses with a 1-bit to 127-bit prefix) use the exact match method by default. You can configure the longest match method for this member type.
The longest match method helps you simplify configuration when you need to add a large number of network addresses to a microsegment. For example, to match network addresses 10.10.10.0/24, 10.10.20.0/24, and 10.10.30.0/24 to microsegment 1, you need to execute only the member ipv4 10.10.10.0/16 command if you use longest match.
2.     Configure the network address match method for microsegments.
microsegment subnet-match longest
By default, exact match is used for network addresses.
Display and maintenance commands for microsegmentation
Display microsegment configuration.
display microsegment [ microsegment-id | name microsegment-name ]
Microsegmentation configuration examples
Example: Configuring microsegmentation by using a QoS policy as the GBP in an IP network
As shown in Figure 3, configure microsegmentation to meet the following requirements:
·     Host A, Host B, and the general server can access the file server.
·     Host A and the general server cannot access each other. Host B and the general server cannot access each other.
Figure 3 Network diagram
Analysis
1.     Add Host A and Host B to microsegment 1.
2.     Add the general server to microsegment 2, and add the file server to microsegment 3.
3.     Configure a QoS policy to allow microsegment 1 and microsegment 3 to communicate, allow microsegment 2 and microsegment 3 to communicate, and prevent microsegment 1 and microsegment 2 from communicating.
Before configuring microsegmentation, make sure the devices can reach one another.
Configuring Device A
1.     Configure microsegments:
# Create microsegment 1, and add the IP addresses of Host A and Host B as its members.
[DeviceA] microsegment 1 name EPG1
[DeviceA-microsegment-1] member ipv4 192.168.1.1 32
[DeviceA-microsegment-1] member ipv4 192.168.2.1 32
[DeviceA-microsegment-1] quit
# Create microsegment 2, and add the IP address of the general server as its member.
[DeviceA] microsegment 2 name EPG2
[DeviceA-microsegment-2] member ipv4 192.168.3.1 32
[DeviceA-microsegment-2] quit
# Create microsegment 3, and add the IP address of the file server as its member.
[DeviceA] microsegment 3 name EPG3
[DeviceA-microsegment-3] member ipv4 192.168.4.1 32
[DeviceA-microsegment-3] quit
# Enable microsegmentation.
[DeviceA] microsegment enable
2.     Configure ACLs:
# Create an IPv4 advanced ACL named EPG1-EPG3, configure a rule to match the IP packets from microsegment 1 to microsegment 3.
[DeviceA] acl advanced name EPG1-EPG3
[DeviceA-acl-ipv4-adv-EPG1-EPG3] rule 0 permit ip source microsegment 1 destination microsegment 3
[Device-acl-ipv4-adv-EPG1-EPG3] quit
# Create an IPv4 advanced ACL named EPG1-EPG2, configure a rule to match the IP packets from microsegment 1 to microsegment 2.
[DeviceA] acl advanced name EPG1-EPG2
[DeviceA-acl-ipv4-adv-EPG1-EPG2] rule 0 permit ip source microsegment 1 destination microsegment 2
[DeviceA-acl-ipv4-adv-EPG1-EPG2] quit
3.     Configuring a QoS policy:
# Create a traffic class named CLASSIFIER-GBP13, and use ACL EPG1-EPG3 as the match criterion.
[DeviceA] traffic classifier CLASSIFIER-GBP13
[DeviceA-classifier-CLASSIFIER-GBP13] if-match acl name EPG1-EPG3
[DeviceA-classifier-CLASSIFIER-GBP13] quit
# Create a traffic behavior named BEHAVIOR-GBP13, and configure a permit action.
[DeviceA] traffic behavior BEHAVIOR-GBP13
[DeviceA-behavior-BEHAVIOR-GBP13] filter permit
[DeviceA-behavior-BEHAVIOR-GBP13] quit
# Create a traffic class named CLASSIFIER-GBP12, and use ACL EPG1-EPG2 as the match criterion.
[DeviceA] traffic classifier CLASSIFIER-GBP12
[DeviceA-classifier-CLASSIFIER-GBP12] if-match acl name EPG1-EPG2
[DeviceA-classifier-CLASSIFIER-GBP12] quit
# Create a traffic behavior named BEHAVIOR-GBP12, and configure a deny action.
[DeviceA] traffic behavior BEHAVIOR-GBP12
[DeviceA-behavior-BEHAVIOR-GBP12] filter deny
[DeviceA-behavior-BEHAVIOR-GBP12] quit
# Create a QoS policy named GBP1, and associate the configured traffic classes and traffic behaviors in the QoS policy.
[DeviceA] qos policy GBP1
[DeviceA-qospolicy-GBP1] classifier CLASSIFIER-GBP13 behavior BEHAVIOR-GBP13
[DeviceA-qospolicy-GBP1] classifier CLASSIFIER-GBP12 behavior BEHAVIOR-GBP12
[DeviceA-qospolicy-GBP1] quit
# Apply QoS policy GBP1 to the inbound direction of Vlan-interface 11.
[DeviceA] interface vlan-interface 11
[DeviceA-Vlan-interface11] qos apply policy GBP1 inbound
[DeviceA-Vlan-interface11] quit
# Apply QoS policy GBP1 to the inbound direction of Vlan-interface 12.
[DeviceA] interface vlan-interface 12
[DeviceA-Vlan-interface12] qos apply policy GBP1 inbound
[DeviceA-Vlan-interface12] quit
Configuring Device D
<DeviceD> system-view
[DeviceD] microsegment 1 name EPG1
[DeviceD-microsegment-1] member ipv4 192.168.1.1 32
[DeviceD-microsegment-1] member ipv4 192.168.2.1 32
[DeviceD-microsegment-1] quit
[DeviceD] microsegment 2 name EPG2
[DeviceD-microsegment-2] member ipv4 192.168.3.1 32
[DeviceD-microsegment-2] quit
[DeviceD] microsegment 3 name EPG3
[DeviceD-microsegment-3] member ipv4 192.168.4.1 32
[DeviceD-microsegment-3] quit
[DeviceD] microsegment enable
2.     Configure ACLs:
# Create an IPv4 advanced ACL named EPG3-EPG1, configure a rule to match the IP packets from microsegment 3 to microsegment 1.
[DeviceD] acl advanced name EPG3-EPG1
[DeviceD-acl-ipv4-adv-EPG3-EPG1] rule 0 permit ip source microsegment 3 destination microsegment 1
[DeviceD-acl-ipv4-adv-EPG3-EPG1] quit
# Create an IPv4 advanced ACL named EPG2-EPG1, configure a rule to match the IP packets from microsegment 2 to microsegment 1.
[DeviceD] acl advanced name EPG2-EPG1
[DeviceD-acl-ipv4-adv-EPG2-EPG1] rule 0 permit ip source microsegment 2 destination microsegment 1
[DeviceD-acl-ipv4-adv-EPG2-EPG1] quit
# Create an IPv4 advanced ACL named EPG2-EPG3, configure a rule to match the IP packets from microsegment 2 to microsegment 3.
[DeviceD] acl advanced name EPG2-EPG3
[DeviceD-acl-ipv4-adv-EPG2-EPG3] rule 0 permit ip source microsegment 2 destination microsegment 3
[DeviceD-acl-ipv4-adv-EPG2-EPG3] quit
# Create an IPv4 advanced ACL named EPG3-EPG2, configure a rule to match the IP packets from microsegment 3 to microsegment 2.
[DeviceD] acl advanced name EPG3-EPG2
[DeviceD-acl-ipv4-adv-EPG3-EPG2] rule 0 permit ip source microsegment 3 destination microsegment 2
[DeviceD-acl-ipv4-adv-EPG3-EPG2] quit
# Create a traffic class named CLASSIFIER-GBP23, and use ACL EPG2-EPG3 as the match criterion.
[DeviceD] traffic classifier CLASSIFIER-GBP23
[DeviceD-classifier-CLASSIFIER-GBP23] if-match acl name EPG2-EPG3
[DeviceD-classifier-CLASSIFIER-GBP23] quit
# Create a traffic behavior named BEHAVIOR-GBP23, and configure a permit action.
[DeviceD] traffic behavior BEHAVIOR-GBP23
[DeviceD-behavior-BEHAVIOR-GBP23] filter permit
[DeviceD-behavior-BEHAVIOR-GBP23] quit
# Create a traffic class named CLASSIFIER-GBP21, and use ACL EPG2-EPG1 as the match criterion.
[DeviceD] traffic classifier CLASSIFIER-GBP21
[DeviceD-classifier-CLASSIFIER-GBP21] if-match acl name EPG2-EPG1
[DeviceD-classifier-CLASSIFIER-GBP21] quit
# Create a traffic behavior named BEHAVIOR-GBP21, and configure a deny action.
[DeviceD] traffic behavior BEHAVIOR-GBP21
[DeviceD-behavior-BEHAVIOR-GBP21] filter deny
[DeviceD-behavior-BEHAVIOR-GBP21] quit
# Create a QoS policy named GBP2, and associate the configured traffic classes and traffic behaviors in the QoS policy.
[DeviceD] qos policy GBP2
[DeviceD-qospolicy-GBP2] classifier CLASSIFIER-GBP23 behavior BEHAVIOR-GBP23
[DeviceD-qospolicy-GBP2] classifier CLASSIFIER-GBP21 behavior BEHAVIOR-GBP21
[DeviceD-qospolicy-GBP2] quit
# Apply QoS policy GBP2 to the inbound direction of Vlan-interface 14.
[DeviceD] interface vlan-interface 14
[DeviceD-Vlan-interface14] qos apply policy GBP2 inbound
[DeviceD-Vlan-interface14] quit
# Create a traffic class named CLASSIFIER-GBP31, and use ACL EPG3-EPG1 as the match criterion.
[DeviceD] traffic classifier CLASSIFIER-GBP31
[DeviceD-classifier-CLASSIFIER-GBP31] if-match acl name EPG3-EPG1
[DeviceD-classifier-CLASSIFIER-GBP31] quit
# Create a traffic behavior named BEHAVIOR-GBP31, and configure a permit action.
[DeviceD] traffic behavior BEHAVIOR-GBP31
[DeviceD-behavior-BEHAVIOR-GBP31] filter permit
[DeviceD-behavior-BEHAVIOR-GBP31] quit
# Create a traffic class named CLASSIFIER-GBP32, and use ACL EPG3-EPG2 as the match criterion.
[DeviceD] traffic classifier CLASSIFIER-GBP32
[DeviceD-classifier-CLASSIFIER-GBP32] if-match acl name EPG3-EPG2
[DeviceD-classifier-CLASSIFIER-GBP32] quit
# Create a traffic behavior named BEHAVIOR-GBP32, and configure a permit action.
[DeviceD] traffic behavior BEHAVIOR-GBP32
[DeviceD-behavior-BEHAVIOR-GBP32] filter permit
[DeviceD-behavior-BEHAVIOR-GBP32] quit
# Create a QoS policy named GBP3, and associate the configured traffic classes and traffic behaviors in the QoS policy.
[DeviceD] qos policy GBP3
[DeviceD-qospolicy-GBP3] classifier CLASSIFIER-GBP31 behavior BEHAVIOR-GBP31
[DeviceD-qospolicy-GBP3] classifier CLASSIFIER-GBP32 behavior BEHAVIOR-GBP32
[DeviceD-qospolicy-GBP3] quit
# Apply QoS policy GBP3 to the inbound direction of Vlan-interface 15.
[DeviceD] interface vlan-interface 15
[DeviceD-Vlan-interface15] qos apply policy GBP3 inbound
[DeviceD-Vlan-interface15] quit
# Verify that Host A and Host B cannot successfully ping the general server.
C:\> ping 192.168.3.1
Pinging 192.168.3.1 with 32 bytes of data:
Request timed out
Request timed out
Request timed out
Request timed out
Ping statistics for 192.168.3.1:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
The output shows that Host A and Host B cannot successfully ping the general server.
# Verify that Host A and Host B can successfully ping the file server.
C:\> ping 192.168.4.1
Pinging 192.168.40.100 with 32 bytes of data:
Reply from 192.168.10.100: bytes=32 time=1ms TTL=255
Reply from 192.168.10.100: bytes=32 time<1ms TTL=255
Ping statistics for 192.168.10.100:
    Minimum = 0ms, Maximum = 1ms, Average = 0ms
The output shows that Host A and Host B can successfully ping the file server.
# Display the configuration of each microsegment on Device A.
[DeviceA] display microsegment 1
Microsegment ID    : 1
Microsegment name  : EPG1
  IPv4 member:
    192.168.1.1/32
    192.168.2.1/32
[DeviceA] display microsegment 2
Microsegment ID    : 2
Microsegment name  : EPG2
  IPv4 member:
    192.168.3.1/32
[DeviceA] display microsegment 3
Microsegment ID    : 3
Microsegment name  : EPG3
  IPv4 member:
    192.168.4.1/32
# Display summary information about microsegments on Device A.
Microsegment status: Enabled
Total microsegments: 3
Microsegment list  :
  Microsegment ID  Members  Microsegment name
  1                2        EPG1
  2                1        EPG2
  3                1        EPG3
# Display the configuration of ACLs on Device A.
[DeviceA] display acl all
Advanced IPv4 ACL named EPG1-EPG2, 1 rule,
ACL's step is 5, start ID is 0
Advanced IPv4 ACL named EPG1-EPG3, 1 rule,
# Display the configuration and statistics of QoS policies for interfaces on Device A.
[DeviceA] display qos policy interface
Interface: Vlan-interface11
  Direction: Inbound
  Policy: GBP1
   Classifier: CLASSIFIER-GBP13
     Operator: AND
     Rule(s) :
      If-match acl name EPG1-EPG3
     Behavior: BEHAVIOR-GBP13
      Filter enable: Permit
   Classifier: CLASSIFIER-GBP12
     Operator: AND
     Rule(s) :
      If-match acl name EPG1-EPG2
     Behavior: BEHAVIOR-GBP12
      Filter enable: Deny
Interface: Vlan-interface12
  Direction: Inbound
  Policy: GBP1
     Operator: AND
     Rule(s) :
     Operator: AND
     Rule(s) :
      Filter enable: Deny
# Display the configuration of microsegments, and ACLs, and QoS policies on Device D. (Details not shown.)
