- 10-MPLS Configuration Guide
- 01-Basic MPLS configuration
- 02-Static LSP configuration
- 03-LDP configuration
- 04-MPLS TE configuration
- 05-Static CRLSP configuration
- 06-RSVP configuration
- 07-Tunnel policy configuration
- 08-MPLS L3VPN configuration
- 09-MPLS L2VPN configuration
- 10-L2VPN access to L3VPN or IP backbone configuration
- 11-MPLS OAM configuration
- 12-MPLS protection switching configuration
- 13-MCE configuration
- 14-VPLS configuration
| 00-Preface | 81.12 KB |
Preface
This configuration guide describes the fundamentals and configuration procedures for MPLS features, including basic MPLS, MPLS TE, MPLS L3VPN, and MPLS L2VPN.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the MSR 5600 routers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
