12-Security Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR810[2600][3600] Routers Configuration Guides(V7)-R0809-6W40012-Security Configuration Guide
22-Object group configuration
22-Object group configuration 61.16 KB
Configuring object groups
About object groups
An object group is a group of objects that can be used by an ACL, object policy, or object group to identify packets. Object groups are divided into the following types:
·     IPv4 address object group—A group of IPv4 address objects used to match the IPv4 address in a packet or match the user from whom a packet comes.
·     IPv6 address object group—A group of IPv6 address objects used to match the IPv6 address in a packet or match the user from whom a packet comes.
·     Port object group—A group of port objects used to match the protocol port number in a packet.
·     Service object group—A group of service objects used to match the upper-layer service in a packet.
Configuring an IPv4 address object group
2.     Create an IPv4 address object group and enter its view.
object-group ip address object-group-name
The system has one default IPv4 address object group named any.
3.     (Optional.) Configure a description for the IPv4 address object group.
By default, an object group does not have a description.
4.     Configure an IPv4 address object.
[ object-id ] network { host { address ip-address | name host-name } | subnet ip-address { mask-length | mask } | range ip-address1 ip-address2 | group-object object-group-name }
5.     Exclude an IPv4 address or a subnet address from the IPv4 address object.
object-id network exclude { ip-address | subnet ip-address { mask-length | mask } }
By default, no IPv4 address or subnet address in an IPv4 address object is excluded.
6.     Exclude a host name from the IPv4 address object.
object-id network exclude host-name host-name
By default, no host name in an IPv4 address object is excluded.
7.     (Optional.) Specify a security zone for the IPv4 address object group.
security-zone security-zone-name
By default, no security zone is specified for an IPv4 address object group.
Configuring an IPv6 address object group
2.     Create an IPv6 address object group and enter its view.
object-group ipv6 address object-group-name
The system has one default IPv6 address object group named any.
3.     (Optional.) Configure a description for the IPv6 address object group.
4.     Configure an IPv6 address object.
[ object-id ] network { host { address ipv6-address | name host-name } | subnet ipv6-address prefix-length | range ipv6-address1 ipv6-address2 | group-object object-group-name }
5.     Exclude an IPv6 address or subnet address from the IPv6 address object.
object-id network exclude { ipv6-address | subnet ipv6-address prefix-length }
By default, no IPv6 address or subnet address in an IPv6 address object is excluded.
6.     Exclude a host name from the IPv6 address object.
By default, no host name in an IPv6 address object is excluded.
7.     (Optional.) Specify a security zone for the IPv6 address object group.
By default, no security zone is specified for an IPv6 address object group.
Configuring a port object group
2.     Create a port object group and enter its view.
object-group port object-group-name
The system has one default port object group named any.
3.     (Optional.) Configure a description for the port object group.
4.     Configure a port object.
[ object-id ] port { { eq | lt | gt } port | range port1 port2 | group-object object-group-name }
Configuring a service object group
2.     Create a service object group and enter its view.
object-group service object-group-name
The system has multiple default service object groups.
3.     (Optional.) Configure a description for the service object group.
4.     Configure a service object.
[ object-id ] service { protocol [ { source { { eq | lt | gt } port | range port1 port2 } | destination { { eq | lt | gt } port | range port1 port2 } } * | icmp-type icmp-code | icmpv6-type icmpv6-code ] | group-object object-group-name }
Renaming an object group
2.     Rename an object group.
object-group rename old-object-group-name new-object-group-name
You can only rename non-default object groups.
Display and maintenance commands for object groups
Display information about object groups.
display object-group [ { { ip | ipv6 } address | service | port } [ default ] [ name object-group-name ] | name object-group-name ]
Display IPv4 or IPv6 addresses for host names.
display object-group { ip | ipv6 } host { object-group-name object-group-name | name host-name } *
