03-Layer 2—LAN Switching Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6800[S6860][S6861] (R27xx) & S6820 (R630x) Switch Series Command Reference-6W10203-Layer 2—LAN Switching Command Reference
16-L2PT commands
16-L2PT commands 59.17 KB
L2PT commands
display l2protocol statistics
Use display l2protocol statistics to display Layer 2 Protocol Tunneling (L2PT) statistics.
display l2protocol statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a Layer 2 Ethernet or aggregate interface by its type and number. If you do not specify this option, the command displays L2PT statistics for all Layer 2 Ethernet and aggregate interfaces.
# Display L2PT statistics for all Layer 2 Ethernet and aggregate interfaces.
<Sysname> display l2protocol statistics
L2PT statistics information on interface Bridge-Aggregation1:
Protocol  Encapsulated      Decapsulated      Forwarded         Dropped
CDP       0                 0                 0                 0
DLDP      0                 3                 0                 0
EOAM      0                 2                 0                 0
GVRP      8                 4                 9                 2
LACP      0                 0                 0                 0
LLDP      0                 3                 0                 0
MVRP      0                 0                 0                 0
PAGP      0                 1                 0                 0
PVST      0                 0                 0                 0
STP       5                 5                 5                 0
Tunnel    N/A               N/A               100               10
VTP       0                 6                 0                 0
UDLD      0                 0                 0                 0
L2PT statistics information on interface Ten-GigabitEthernet1/0/1:
CDP       0                 0                 0                 0
DLDP      2                 3                 3                 0
EOAM      5                 2                 9                 0
GVRP      8                 4                 9                 2
LACP      0                 0                 0                 0
LLDP      3                 3                 3                 3
MVRP      0                 0                 0                 0
PAGP      5                 1                 7                 3
PVST      0                 0                 0                 0
STP       5                 5                 5                 0
VTP       0                 6                 0                 0
UDLD      0                 0                 0                 0
Encapsulated
Number of encapsulated packets.
The number increases by 1 when the interface receives and encapsulates a protocol packet from a customer network.
For protocol Tunnel, which represents tunneled packets, this field displays N/A.
Decapsulated
Number of decapsulated packets.
The number increases by 1 when the interface receives and decapsulates a tunneled packet from the service provider network.
Forwarded
Number of forwarded packets.
The number increases by 1 when the interface receives a protocol packet and forwards it.
The number increases by 1 for protocol Tunnel when the interface receives a tunneled packet and forwards it. If no interface of the PE is connected to customer networks, the number does not increase.
Dropped
Number of dropped packets.
The number increases by 1 when the interface receives a protocol packet and drops it. Protocol packets dropped by hardware are not counted.
The number increases by 1 for protocol Tunnel when the interface receives a tunneled packet and drops it.
l2protocol tunnel dot1q
Use l2protocol tunnel dot1q to enable L2PT for a protocol.
Use undo l2protocol tunnel dot1q to disable L2PT for a protocol.
In Layer 2 Ethernet interface view:
l2protocol { cdp | dldp | eoam | gvrp | lacp | lldp | mvrp | pagp | pvst | stp | udld | vtp } tunnel dot1q
undo l2protocol { cdp | dldp | eoam | gvrp | lacp | lldp | mvrp | pagp | pvst | stp | udld | vtp } tunnel dot1q
In Layer 2 aggregate interface view:
l2protocol { gvrp | mvrp | pvst | stp | vtp } tunnel dot1q
undo l2protocol { gvrp | mvrp | pvst | stp | vtp } tunnel dot1q
L2PT is disabled for all protocols.
cdp: Specifies CDP.
dldp: Specifies DLDP.
eoam: Specifies EOAM.
gvrp: Specifies GVRP.
lacp: Specifies LACP.
lldp: Specifies LLDP. L2PT for LLDP supports LLDP packets from only nearest bridge agents.
mvrp: Specifies MVRP.
pagp: Specifies PAgP.
pvst: Specifies PVST.
stp: Specifies STP.
udld: Specifies UDLD.
vtp: Specifies VTP.
Before you enable L2PT for a protocol on a port, perform the following tasks:
·     Enable the protocol on the CE, and disable the protocol on the port.
·     Enable L2PT only on customer-facing PE ports. If you enable L2PT on ports connected to the service provider network, L2PT determines that the ports are connected to a customer network.
·     Disable the protocol (for example, STP) on the PE ports connecting to an aggregate interface on a CE when the following conditions exist:
¡     The protocol is running on the aggregate interface on the CE.
¡     The aggregate interface on the CE connects to an L2PT-enabled port on the PE.
Do not enable L2PT on a port that is going to join a service loopback group.
You can enable L2PT on member ports of a Layer 2 aggregation group, but the configuration does not take effect.
# Disable STP and enable L2PT for STP on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] undo stp enable
[Sysname-Ten-GigabitEthernet1/0/1] l2protocol stp tunnel dot1q
# Disable STP and enable L2PT for STP on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] undo stp enable
[Sysname-Bridge-Aggregation1] l2protocol stp tunnel dot1q
l2protocol tunnel-dmac
Use l2protocol tunnel-dmac to set the destination multicast MAC address for tunneled packets.
Use undo l2protocol tunnel-dmac to restore the default.
l2protocol tunnel-dmac mac-address
The tunneled packets use 010f-e200-0003 as the destination multicast MAC address.
mac-address: Specifies a destination multicast MAC address. The available addresses are 0100-0ccd-cdd0, 0100-0ccd-cdd1, 0100-0ccd-cdd2, and 010f-e200-0003.
# Set the destination multicast MAC address to 0100-0ccd-cdd0 for tunneled packets.
[Sysname] l2protocol tunnel-dmac 0100-0ccd-cdd0
reset l2protocol statistics
Use reset l2protocol statistics to clear L2PT statistics.
reset l2protocol statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a Layer 2 Ethernet or aggregate interface by its type and number. If you do not specify this option, the command clears L2PT statistics on all Layer 2 Ethernet and aggregate interfaces.
# Clear L2PT statistics on all Layer 2 Ethernet and aggregate interfaces.
<Sysname> reset l2protocol statistics
