- H3C S7500X Switch Series Installation Guide-6W105
- 01-Chapter 1 Preparing for Installation
- 02-Chapter 2 Installing the Switch
- 03-Chapter 3 Installing FRUs
- 04-Chapter 4 Connecting Your Switch to the Network
- 05-Chapter 5 Replacement Procedures
- 06-Appendix A Chassis Views and Technical Specifications
- 07-Appendix B FRUs and Compatibility Matrixes
- 08-Appendix C LEDs
- 09-Appendix D Cables
- 10-Appendix E Engineering Labels for Cables
- 11-Appendix F Cable Management
07-Appendix B FRUs and Compatibility Matrixes | 272.35 KB |
7 Appendix B FRUs and compatibility matrixes
For the compatibility between transceiver modules and cards, see H3C S7500X Switch Series Cards and Transceiver Modules Compatibility Matrixes.
MPUs
Model |
Specifications |
Flash memory |
NVRAM |
SDRAM |
Ports |
LSQM2SUPA0 |
2 GB |
1 MB |
2 GB |
· 1 × console port · 1 × USB console port · 2 × management Ethernet ports (one 10/100/1000BASE-T copper port and one SFP port) · 1 × USB port |
LSQM2SUPB0 |
4 GB |
1 MB |
4 GB |
· 1 × console port · 1 × USB console port · 2 × management Ethernet ports (one 10/100/1000BASE-T copper port and one SFP port) · 1 × USB port · 2 × SMB coaxial clock output ports · 2 × SMB coaxial clock input ports · 2 × high-precision time synchronization ports (Both ports are used for input by default. When both the ports are used for input, only port 1 is valid.) |
LSQM3SUPA0 |
4 GB |
1 MB |
4 GB |
LSQM1MPUSA0 |
2 GB |
1 MB |
4 GB |
· 1 × console port · 1 × USB console port · 4 × management Ethernet ports (two 10/100/1000BASE-T copper ports and two SFP ports) · 1 × USB port |
LSQM1MPUSC0 |
2 GB |
1 MB |
4 GB |
LSQM1SRP4Y06A0 |
2 GB |
1 MB |
4 GB |
· 1 × console port · 1 × USB console port · 2 × management Ethernet ports (one RJ-45 port and one SFP port) · 1 × USB port · 4 × SFP28 ports |
LSQM1MPUS06S0 |
4 GB |
1 MB |
4 GB |
· 1 × console port · 1 × USB console port · 2 × management Ethernet ports (one RJ-45 port and one SFP port) |
LSQM1MPUS10B0 |
2 GB |
1 MB |
4 GB |
LSQM1MPUS10C0 |
2 GB |
1 MB |
4 GB |
NOTE: · Among the management Ethernet ports on an MPU, only port 0 is available during the startup of the switch. · To connect an SFP management Ethernet port on the MPUs, make sure the peer port operates at 1000 Mbps in full-duplex mode. · The USB ports on the MPUs do not support USB extension cables. |
Table 7-2 MPU and switch compatibility matrix
MPU model |
Switch model |
S7503X S7503X-PoE |
S7506X S7506X-PoE |
S7506X-S S7506X-S-MF |
S7510X S7510X-PoE |
LSQM2SUPA0 |
Yes |
No |
No |
No |
LSQM2SUPB0 |
Yes |
No |
No |
No |
LSQM3SUPA0 |
Yes |
No |
No |
No |
LSQM1MPUSA0 |
No |
Yes |
No |
No |
LSQM1MPUSC0 |
No |
Yes |
No |
No |
LSQM1SRP4Y06A0 |
No |
Yes |
Yes |
No |
LSQM1MPUS06S0 |
No |
Yes |
Yes |
No |
LSQM1MPUS10B0 |
No |
No |
No |
Yes |
LSQM1MPUS10C0 |
No |
No |
No |
Yes |
NOTE: To verify compatibility of an MPU with the software version you are using, see the release notes for the device. |
Service modules
Follow these restrictions and guidelines to use service modules:
· For the switch models and system software versions that a service module is compatible with, see the service module manual.
· A combo interface is a logical interface that contains an SFP port and an RJ-45 Ethernet port. Only one of them can be activated at a time.
· After you convert 40G ports on an LSQM1CQGS12SG0 interface module to 100G ports, only ports 1, 4, 7, and 10 are available.
· To avoid interface module damage, do not install an LSQM1CGS2FE0 or LSQM1CQGS12SG0 interface module in slot 10 on an S7510X switch.
· Follow these guidelines to use services modules on an S7503X switch:
¡ Do not use an LSQM1TGS16FD0 interface module with the following modules:
- EC interface modules.
- OAA modules: LSU1FWCEA0, LSU3FWCEA0, LSU3WCMD0, LSU1ADECEA0, LSU1NSCEA0, LSUM1FWCEAB0, LSU1IPSBEA0, LSU1WCME0, LSQM1WCMX40, and LSQM1WCMX20.
¡ Do not use FD interface modules (except the LSQM1TGS16FD0) with the following modules:
- SA interface modules.
¡ Do not use an FE interface module, LSQM1EPSB0 module, or LSQM1SDNB0 module with the following modules:
Interface modules
Table 7-3 Interface module specifications
Model |
Port quantity |
Port type |
Available transceiver modules and network cables |
LSQM1TGS24QSFD0 |
26 |
· 2 × 40GBASE-R-QSFP+ fiber ports or 1 × 100G QSFP28 fiber port · 24 × 10GBASE-R-SFP+ fiber ports |
· QSFP28 transceiver module · QSFP28 DAC cable · QSFP+ transceiver module · QSFP+ DAC cable · QSFP+ to SFP+ DAC cable · 10-GE SFP+ transceiver module · 10-GE SFP+ DAC cable · GE SFP transceiver module |
LSQM1CQGS12SG0 |
12 |
· 12 × 40GBASE-R QSFP+ fiber ports or 4 × 100GBASE-R QSFP28 fiber ports |
· QSFP28 transceiver module · QSFP28 DAC cable · QSFP+ transceiver module · QSFP+ DAC cable · QSFP+ to SFP+ DAC cable |
LSQM1CGS2FE0 |
2 |
100GBASE-R QSFP28 fiber port |
· QSFP28 transceiver module · QSFP28 DAC cable |
LSQM1QGS24RSG0 |
24 |
40GBASE-R QSFP+ fiber port |
LSQM2GT24PTSSC0 |
48 |
· 4 × 10GBASE-R SFP+/LC fiber ports · 20 × 1000BASE-X-SFP/LC fiber ports · 24 × 10/100/1000BASE-T-RJ45 copper ports |
· 10-GE SFP+ transceiver module · 10-GE SFP+ DAC cable · FE/GE SFP transceiver module · Category 5 twisted-pair cable |
LSQM2GT24TSSC0 |
28 |
· 4 × 10GBASE-R SFP+/LC fiber ports · 24 × 10/100/1000BASE-T-RJ45 copper ports |
· 10-GE SFP+ transceiver module · 10-GE SFP+ DAC cable · GE SFP transceiver module · Category 5 twisted-pair cable |
LSQM3GP44TSSC0 |
48 |
· 4 × 10GBASE-R-SFP+ fiber ports (support for MACsec) · 44 × 1000BASE-X-SFP fiber ports (support for MACsec) |
· 10-GE SFP+ transceiver module · 10-GE SFP+ DAC cable · FE/GE SFP transceiver module |
LSQM1GP40TS8FD0 |
48 |
· 8 × 10GBASE-R SFP+/LC fiber ports · 40 × 1000BASE-X-SFP/LC fiber ports |
LSQM2GP40TS8FD0 |
48 |
LSQM2GP44TSSC0 |
48 |
· 4 × 10GBASE-R SFP+/LC fiber ports · 44 × 1000BASE-X-SFP/LC fiber ports |
LSQM2GP24TSSC0 |
28 |
· 4 × 10GBASE-R SFP+/LC fiber ports · 24 × 1000BASE-X-SFP/LC fiber ports |
LSQM1TGS48RFE0 |
48 |
10GBASE-R-SFP+ fiber port |
LSQM1TGS48RSG0 |
48 |
LSQM2TGS48SG0 |
48 |
10GBASE-R SFP+/LC fiber port |
LSQM1TGS16GPSA0 |
40 |
· 16 × 10GBASE-R-SFP+/LC fiber ports · 24 × 1000BASE-X-SFP/LC fiber ports |
LSQM1TGS24FD0 |
24 |
LSQM1TGS16FD0 |
16 |
LSQM2TGS16SF0 |
16 |
LSQM2GP24TSSA0 |
28 |
· 4 × 10GBASE-R/ SFP+/LC fiber ports · 24 × 1000BASE-X-SFP/LC fiber ports |
· 10-GE SFP+ transceiver module · FE/GE SFP transceiver module |
LSQM1TGS12EC0 |
12 |
10-GE SFP+ transceiver module |
LSQM1GP48FD0 |
48 |
1000BASE-X-SFP/LC fiber port |
LSQM1XPT12TSFD0 |
20 |
· 12 × 10G EPON OLT/SC fiber ports · 8 × 10GBASE-R-SFP+/LC fiber ports |
· XFP EPON transceiver module · 10-GE SFP+ transceiver module · 10-GE SFP+ DAC cable · GE SFP transceiver module |
LSQM2XPT12TSFD0 |
20 |
· SFP+ EPON transceiver module · 10-GE SFP+ transceiver module · 10-GE SFP+ DAC cable · GE SFP transceiver module |
LSQM1PT24TSSC0 |
26 |
· 2 × 10GBASE-R SFP+/LC fiber ports · 24 × 1000BASE-PX-SFP/SC fiber ports |
· SFP EPON transceiver module · GE SFP transceiver module · 10-GE SFP+ transceiver module |
LSQM1PT8TSSC0 |
10 |
· 8 × 1000BASE-PX-SFP/SC fiber ports · 2 × 1000BASE-X-SFP/LC fiber ports |
LSQM2GP48SA0 |
48 |
LSQM2GP24SA0 |
24 |
LSQM1TGT24FD0 |
24 |
10GBASE-T-RJ45 copper port |
Category 6A/7 twisted-pair cable |
LSQ1TGS8SC0 |
48 |
10/100/1000BASE-T-RJ45 copper port |
LSQM1GT48FD0 |
48 |
LSQM2GT48SA0 |
48 |
LSQM2GT48SC0 |
48 |
LSQM4GV48SA0 |
48 |
LSQM4GV48SC0 |
48 |
OAA modules
Table 7-4 OAA module specifications
Model |
Ports |
Compatible transceiver modules and network cables |
LSU1WCME0 |
High-performance access controller module |
· 1 × console port · 1 ×100/1000BASE-T out-of-band management Ethernet port |
Category 5 or above twisted-pair cable |
LSU3WCMD0 |
· 1 × console port · 1 × CF card slot (supporting 256-MB, 512-MB, and 1-GB CF cards) · 2 × USB ports · 2 × 10/100/1000BASE-T copper ports · 2 × GE combo interfaces |
· Category 5 twisted-pair cable · GE SFP transceiver module |
LSQM1WCMX20 |
Access controller module |
· 1 × console port · 1 × 10/100/1000BASE-T out-of-band management Ethernet port |
LSQM1WCMX40 |
LSQM1FWDSC0 |
Firewall module |
· 1 × console port · 1 × USB port (reserved for future use) · 1 × GE Ethernet copper port · 1 × hard disk slot |
LSU1FWCEA0 |
Firewall module |
· 1 × console port · 1 × CF card slot (supporting 256-MB, 512-MB, and 1-GB CF cards) · 2 × USB ports (reserved) · 2 × GE combo interfaces |
LSU3FWCEA0 |
Firewall module |
· 1 × console port · 1 × CF card slot (supporting 256-MB, 512-MB, and 1-GB CF cards) · 2 × USB ports · 2 × GE combo interfaces |
LSUM1FWCEAB0 |
Firewall module |
· 1 × console port · 2 × USB ports · 2 × GE combo interfaces |
LSU1NSCEA0 |
10-GE high performance NetStream module |
· 1 × console port · 2 × USB ports (reserved) · 2 × GE combo interfaces |
· Category 5 or above twisted-pair cable · GE SFP transceiver module |
LSQM1NSDSC0 |
NetStream module |
LSU1IPSBEA0 |
Intrusion prevention system module |
LSQM1IPSDSC0 |
· 1 × console port · 1 × USB port (only for supplying power to a PFC) · 1 × 10/100/1000BASE-T copper port · 1 × hard disk slot |
LSQ1SSLSC0 |
SSL VPN module |
· 1 × console port · 1 × CF card slot (supporting 256-MB, 512-MB, and 1-GB CF cards) · 2 × USB ports |
LSQ1ACGASC0 |
Application control gateway module |
LSQM1ACGDSC0 |
· 1 × console port · 1 × USB port (reserved) · 1 × 10/100/1000BASE-T copper port · 1 × hard disk slot |
LSQM2ACGDSC0 |
LSQM1ADEDSC0 |
Application delivery engine module |
LSU1ADECEA0 |
LSQM2FWDSC0 |
High-performance service module |
· 1 × console port · 2 × USB ports · 2 × GE combo interfaces · 4 × 10GBASE-R fiber ports · 1 × hard disk |
· Category 5 twisted-pair cable · GE SFP transceiver module · 10-GE SFP+ transceiver module · 10-GE SFP+ DAC cable |
LSQM1EPSB0 |
EPS endpoint security module |
· 3 × USB 2.0 ports (only for debugging use) · 1 × VGA connector · 1 × 10/100/1000BASE-T management Ethernet port · 1 × console port (only for debugging use) |
LSQM1SDNB0 |
SDN automation module |
LSQM1WBCZ720X |
Multiservice access controller module |
· 3 × USB 2.0 ports (only for debugging use) · 1 × VGA connector · 1 × 1000BASE-T management Ethernet port · 1 × console port |
Power system
Follow these restrictions and guidelines to configure and use power modules for the switch:
· A chassis must be configured with a minimum of one power module. To improve power supply availability, you can configure a chassis with two power modules for redundancy.
· The power modules installed on the switch must be the same type (AC or DC) and model.
· Make sure the maximum output power of a power module is greater than the total power consumption of the switch. As a best practice, reserve 20% of the maximum output power. For more information about the system power consumption and PoE power consumption, see "Total power consumption."
· If you want the switch to provide PoE power for PDs, order a power module that can be used for setting up a PoE system. Make sure the maximum PoE power provided by the power module is greater than the PoE power consumption. The requirements for setting up a PoE system vary by switch model. For more information about setting up a PoE system, see "(Optional) Setting up a PoE system."
Power modules
Table 7-5 shows the power modules available for the switch.
Table 7-5 Power module specifications (1)
Item |
PSR320-A |
PSR650-A |
PSR650-D |
PSR650C-12A |
Rated input voltage |
100 VAC to 240 VAC @ 50/60 Hz |
–48 VDC to –60 VDC |
Rated output voltage |
12 VDC |
12 VDC |
12 VDC |
12 VDC |
Max. input current |
10 A |
10 A |
25 A |
10 A |
Max. output current |
25 A |
54 A |
12 V: 54 A 3.3 V: 4 A |
54 A |
Max. system output capacity |
300 W |
650 W |
650 W |
650 W |
Support for PoE |
No |
No |
No |
No |
Max. PoE output capacity |
N/A |
N/A |
N/A |
N/A |
Table 7-6 Power module specifications (2)
Item |
PSR650C-12D |
PSR1200-A |
PSR1200-D |
PSR1400-A |
110 V |
220 V |
12 VDC |
· 12 VDC · 3.3 VDC |
12 VDC |
12 VDC |
25 A |
16 A |
42 A |
16 A |
16 A |
54 A |
· 100 A (12 V) · 4 A (3.3 V) |
96 A |
117 A |
650 W |
1213 W |
1213 W |
1150 W |
1400 W |
Support for PoE |
No |
No |
No |
No |
N/A |
N/A |
N/A |
N/A |
N/A |
Table 7-7 Power module specifications (3)
Item |
PSR1400-D |
PSR1400-12D1 |
PSR2500-12AHD |
PSR2500-12D |
· 100 VAC to 240 VAC @ 50/60 Hz · 240 to 380 VDC |
· 12 VDC · PoE: 48 VDC |
12 VDC |
12 VDC |
12 VDC |
190 A |
50 A |
16 A |
85 A |
· 12 VDC: 117 A · PoE: 140 A |
117 A |
90 to 180 VAC: 100 A |
180 to 290 VAC or 180 to 400 VDC: 208 A |
208 A |
1400 W |
1400 W |
1200 W |
2500 W |
2500 W |
Support for PoE |
Yes |
No |
No |
No |
6720 W |
N/A |
N/A |
N/A |
Table 7-8 Power module specifications (4)
Item |
PSR2800-ACV |
PSR6000-ACV |
110 V |
220 V |
110 V |
220 V |
A maximum of 16 A per input |
· 12 VDC: 96 A · PoE: 23 A |
· 12 VDC: 117 A · PoE: 28 A |
· 12 VDC: 96 A · One PoE input: 23 A · Two PoE inputs: 46 A · Three PoE inputs: 69 A |
· 12 VDC: 117 A · One PoE input: 34 A · Two PoE inputs: 68 A · Three PoE inputs: 100 A |
1150 W |
1400 W |
1150 W |
1400 W |
Support for PoE |
Yes |
Yes |
1150 W |
1400 W |
· One PoE input: 1200 W · Two PoE inputs: 2400 W · Three PoE inputs: 3600 W |
· One PoE input: 1800 W · Two PoE inputs: 3600 W · Three PoE inputs: 5300 W |
NOTE: The maximum PoE output power is 10000 W when the switch is fully configured with PSR1400-D or PSR6000-ACV power modules. |
Table 7-9 shows the compatibility between power modules and switches.
Table 7-9 Power module and switch compatibility matrix
Power module |
S7503X S7503X-PoE |
S7506X S7506X-S S7506X-S-MF |
S7506X-PoE |
S7510X |
S7510X-PoE |
PSR320-A |
l |
PSR650-A |
l |
PSR650-D |
l |
PSR1200-A |
PSR1200-D |
PSR650C-12A |
l |
l |
PSR650C-12D |
l |
l |
PSR1400-A |
l |
l |
l |
l |
PSR1400-D |
l |
l |
l |
l |
PSR1400-12D1 |
l |
l |
l |
l |
PSR2500-12AHD |
l |
l |
l |
l |
PSR2500-12D |
l |
l |
l |
l |
PSR2800-ACV |
l |
l |
PSR6000-ACV |
l |
l |
NOTE: · "l" indicates that the power module can be directly installed on the chassis. · "¡" indicates that you must first install a power module adapter on the chassis and then install the power module on the power module adapter. For more information about installing a power module and a power module adapter, see "Installing the power supply system." · "—" indicates that the power module cannot be installed on the chassis. |
Power cords
DC power cords
A DC power cord connects a DC power module to an external DC power source.
Table 7-10 DC power cords available for the power modules
DC power cord code |
DC power cord length |
DC power module |
0404A06T |
3 m (9.84 ft) |
PSR650-D/PSR650C-12D |
0404A01N |
5 m (16.40 ft) |
0404A01P |
10 m (32.81 ft) |
0404A073 |
20 m (65.62 ft) |
0404A0DU |
3 m (9.84 ft) |
PSR1200-D |
0404A07G |
3 m (9.84 ft) |
PSR1400-D/PSR1400-12D1/PSR2500-12D |
0404A08T |
10 m (32.81 ft) |
0404A08U |
20 m (65.62 ft) |
0404A072 |
25 m (82.02 ft) |
0404A0RL |
3 m (9.84 ft) |
PSR2500-12AHD (240 to 380 VDC) |
AC power cords
AC power cords are used for connecting the AC power modules of the switch to the external AC power source. Before you order an AC power cord, make sure you have read the following restrictions and guidelines:
· Select AC power cords according to the power of the power module.
· The connector type varies by country or region. Select a compliant connector type as needed.
· For the PSR320-A, PSR650-A, and PSR650C-12A power modules, select 10A AC power cords. For the connector types of different countries or regions, see Table 7-11.
· For the PSR1200-A, PSR1400-A, PSR2500-12AHD, PSR2800-ACV, and PSR6000-ACV power modules, select 16A AC power cords. For the connector types of different countries or regions, see Table 7-12. For the PSR2500-12AHD power module, select the 0404A0RP or 0404A0RQ AC power cord. The 0404A0RP and 0404A0RQ AC power cords can only be used for the PSR2500-12AHD power module.
Table 7-11 10A AC power cords used in different countries or regions
1 |
Connector type |
Code (Length) |
Countries or regions where the type of power cords conforms to local safety regulations and can be used legally |
Other countries or regions using this type of power cords |
Countries or regions seldom using this type of power cords |
I type |
04041104: 3 m (9.8 ft) |
Mainland China |
Connector outline |
Power cord outline |
Connector outline |
2 |
Connector type |
Code (Length) |
Countries or regions where the type of power cables conforms to local safety regulations and can be used legally |
B type |
04020728: 3 m (9.8 ft) |
Canada and U.S.A |
Mexico, Argentina, Brazil, Columbia, Venezuela, Thailand, Peru, Philippine, and A6 countries or regions |
Connector outline |
Connector outline |
3 |
Connector type |
Code (Length) |
F type |
04041056: 3 m (9.8 ft) |
Holland, Denmark, Sweden, Finland, Norway, Germany, France, Austria, Belgium, and Italy |
Indonesia, Turkey, Russia, and CIS |
Connector outline |
Connector outline |
4 |
Connector type |
Code (Length) |
G type |
04040890: 3 m (9.8 ft) |
U.K. |
Malaysia, Hong Kong, and Egypt |
Connector outline |
Connector outline |
5 |
Connector type |
Code (Length) |
B type |
04040887: 3 m (9.8 ft) |
Japan |
Connector outline |
Connector outline |
6 |
Connector type |
Code (Length) |
I type |
04040888: 3 m (9.8 ft) |
Australia |
Connector outline |
Connector outline |
7 |
Connector type |
Code (Length) |
J type |
04041119: 3 m (9.8 ft) |
Switzerland |
Connector outline |
Connector outline |
8 |
Connector type |
Code (Length) |
L type |
04041120: 3 m (9.8 ft) |
Italy |
Connector outline |
Connector outline |
9 |
Connector type |
Code (Length) |
D type |
0404A0Q0: 3 m (9.8 ft) |
India |
Connector outline |
Connector outline |
NOTE: The connector outline figures shown in Table 7-11 are connectors for connecting the device. |
Table 7-12 16A AC power cords used in different countries or regions
1 |
Connector type |
Code (Length) |
I type |
04043396: 3 m (9.8 ft) |
Mainland China |
Connector outline |
Connector outline |
2 |
Connector type |
Code (Length) |
C20 type |
0404A0C2: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Connector outline |
Connector outline |
3 |
Connector type |
Code (Length) |
N/A |
0404A0RP: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Connector outline |
Connector outline |
4 |
Code (Length) |
I type |
0404A0RQ: 3 m (9.8 ft) |
Mainland China |
N/A |
N/A |
Connector outline |
Connector outline |
5 |
Connector type |
Code (Length) |
B type |
0404A063: 3 m (9.8 ft) |
Canada and U.S.A |
Connector outline |
Connector outline |
6 |
Connector type |
Code (Length) |
F type |
0404A061: 3 m (9.8 ft) |
Connector outline |
Connector outline |
7 |
Connector type |
Code (Length) |
B type |
0404A062: 3 m (9.8 ft) |
Japan |
Connector outline |
Connector outline |
8 |
Connector type |
Code (Length) |
I type |
0404A01A: 3 m (9.8 ft) |
Australia |
Connector outline |
Connector outline |
9 |
Connector type |
Code (Length) |
D type |
0404A0PY: 3 m (9.8 ft) |
India |
Connector outline |
Connector outline |
NOTE: The connector outline figures shown in Table 7-12 are connectors for connecting devices. |
(Optional) PoE power system
PoE DC power cords
A PoE DC power cord is used to connect a PoE power module on the switch to an external DC power source.
Table 7-13 PoE DC power cords available for PoE power modules
PoE power module |
PoE DC power cord |
Cable length |
PSR2800-ACV/PSR6000-ACV |
0404A05U |
1 m (3.28 ft) |
PSR1400-D |
0404A07H |
3 m (9.84 ft) |
PoE AC power cords
The switch uses 16A PoE AC power cords. A PoE AC power cord is used to connect a PoE power module on the switch to an external AC power source. The connector type varies by country or region. For more information, see Table 7-12.
Fan trays
Table 7-14 Fan tray specifications
Fan tray |
Number of fan trays |
Number of fans |
Fan diameter |
Maximum air flow rate |
S7503X fan tray S7503X-PoE fan tray |
1 |
2 |
120 mm (4.72 in) |
166 CFM |
S7506X fan tray S7506X-PoE fan tray S7506X-S fan tray |
1 |
9 |
92 mm (3.62 in) |
495 CFM |
S7506X-S-MF fan tray |
3 |
3 (one small fan tray and two large fan trays) |
· Small fan tray: 80 mm (3.15 in) · Large fan tray: 92 mm (3.62 in) |
130 CFM |
S7510X fan tray S7510X-PoE fan tray |
1 |
6 |
92 mm (3.62 in) |
662 CFM |
1 |
4 |
120 mm (4.72 in) |
662 CFM |
The switch comes with the fan tray installed. To replace the fan tray, make sure the new fan tray is compatible with the switch.
