- H3C S7500X Switch Series Installation Guide-6W105
- 01-Chapter 1 Preparing for Installation
- 02-Chapter 2 Installing the Switch
- 03-Chapter 3 Installing FRUs
- 04-Chapter 4 Connecting Your Switch to the Network
- 05-Chapter 5 Replacement Procedures
- 06-Appendix A Chassis Views and Technical Specifications
- 07-Appendix B FRUs and Compatibility Matrixes
- 08-Appendix C LEDs
- 09-Appendix D Cables
- 10-Appendix E Engineering Labels for Cables
- 11-Appendix F Cable Management
06-Appendix A Chassis Views and Technical Specifications | 5.84 MB |
6 Appendix A Chassis views and technical specifications
Chassis views
S7500X switch series includes the following models:
· S7503X
· S7503X-PoE
· S7506X
· S7506X-PoE
· S7506X-S
· S7506X-S-MF
· S7510X
· S7510X-PoE
The figures in this section are for illustration only.
S7503X
Figure 6-1 S7503X front panel
(2) MPU section |
(3) Service module section |
(4) Fan tray section |
S7503X-PoE
Figure 6-2 S7503X-PoE front and rear panels
(1) Power module section |
(2) MPU section |
(5) PoE power input terminals (reserved) |
S7506X
Figure 6-3 S7506X front panel
(1) Service module section |
(2) MPU section |
(3) Power module section |
S7506X-PoE
Figure 6-4 S7506X-PoE front panel
(2) MPU section |
S7506X-S
Figure 6-5 S7506X-S front panel
(2) MPU section |
S7506X-S-MF
Figure 6-6 S7506X-S-MF front panel
(2) MPU section |
S7510X
Figure 6-7 S7510X front panel
(2) MPU section |
S7510X-PoE
Figure 6-8 S7510X-PoE front panel
(2) MPU section |
Technical specifications
Weights and dimensions
Table 6-1 Chassis weights and dimensions
Model |
Weight (fully configured) |
Height |
Width |
Depth |
S7503X |
< 35 kg (77.16 lb) |
216 mm (8.50 in)/5 RU |
436 mm (17.17 in) |
420 mm (16.54 in) |
S7503X-PoE |
436 mm (17.17 in) |
420 mm (16.54 in) |
S7506X |
< 75 kg (165.34 lb) |
575 mm (22.64 in)/13 RU |
436 mm (17.17 in) |
420 mm (16.54 in) |
S7506X-PoE |
436 mm (17.17 in) |
420 mm (16.54 in) |
S7506X-S |
436 mm (17.17 in) |
420 mm (16.54 in) |
S7506X-S-MF |
436 mm (17.17 in) |
420 mm (16.54 in) |
S7510X |
< 95 kg (209.44 lb) |
708 mm (27.87 in)/16 RU |
436 mm (17.17 in) |
420 mm (16.54 in) |
S7510X-PoE |
436 mm (17.17 in) |
420 mm (16.54 in) |
NOTE: · A rack unit (RU) is 44.45 mm (1.75 in). It is a used as a measurement for the rack height. · Net weight is the chassis weight, excluding the weights of cards, power modules and other removable modules. |
Table 6-2 Card weights and dimensions
Model |
Weight |
Height |
Width |
Depth |
LSQM2SUPA0 |
1.35 kg (2.98 lb) |
45 mm (1.77 in) |
199 mm (7.83 in) |
355 mm (13.98 in) |
LSQM2SUPB0 |
1.45 kg (3.20 lb) |
45 mm (1.77 in) |
199 mm (7.83 in) |
355 mm (13.98 in) |
LSQM3SUPA0 |
1.35 kg (2.98 lb) |
45 mm (1.77 in) |
199 mm (7.83 in) |
355 mm (13.98 in) |
LSQM1MPUSA0 |
3.25 kg (7.16 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1MPUSC0 |
3.70 kg (7.16 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1SRP4Y06A0 |
2.90 kg (6.39 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1MPUS06S0 |
3.25 kg (7.16 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1MPUS10B0 |
3.40 kg (8.16 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1MPUS10C0 |
3.70 kg (8.16 lb) |
45 mm (1.77 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1TGS24QSFD0 |
3.00 kg (6.61 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1CQGS12SG0 |
3.20 kg (7.05 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1CGS2FE0 |
2.82 kg (6.22 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1QGS24RSG0 |
3.39 kg (7.47 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2GT24PTSSC0 |
3.21 kg (7.08 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2GT24TSSC0 |
2.95 kg (6.50 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM3GP44TSSC0 |
3.00 kg (6.61 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1GP40TS8FD0 |
3.20 kg (7.05 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2GP40TS8FD0 |
3.10 kg (6.83 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2GP44TSSC0 |
3.00 kg (6.61 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2GP24TSSC0 |
2.85 kg (6.28 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1TGS48RFE0 |
3.60 kg (7.94 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1TGS48RSG0 |
3.50 kg (7.72 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2TGS48SG0 |
3.30 kg (7.28 lb) |
40 mm (1.57 in) |
40 mm (1.57 in) |
399 mm (15.71 in) |
LSQM1TGS16GPSA0 |
3.50 kg (7.72 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1TGS24FD0 |
3.00 kg (6.61 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1TGS16FD0 |
2.91 kg (6.42 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2TGS16SF0 |
3.05 kg (6.72 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2GP24TSSA0 |
2.85 kg (6.28 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1TGS12EC0 |
3.30 kg (7.28 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1GP48FD0 |
3.10 kg (6.83 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1XPT12TSFD0 |
3.45 kg (7.61 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2XPT12TSFD0 |
3.45 kg (7.61 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1PT24TSSC0 |
2.90 kg (6.39 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1PT8TSSC0 |
2.75 kg (6.06 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2GP48SA0 |
3.00 kg (6.61 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2GP24SA0 |
2.81 kg (6.19 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1TGT24FD0 |
3.40 kg (7.50 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1GT48FD0 |
3.40 kg (7.50 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2GT48SA0 |
3.18 kg (7.01 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2GT48SC0 |
3.18 kg (7.01 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM4GV48SA0 |
3.05 kg (6.72 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM4GV48SC0 |
3.05 kg (6.72 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSU1WCME0 |
4.00 kg (8.82 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSU3WCMD0 |
3.62 kg (7.98 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1WCMX20 |
4.00 kg (8.82 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1WCMX40 |
4.00 kg (8.82 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1FWDSC0 |
3.80 kg (8.38 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSU1FWCEA0 |
3.90 kg (8.60 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSU3FWCEA0 |
3.90 kg (8.60 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSUM1FWCEAB0 |
3.90 kg (8.60 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSU1NSCEA0 |
3.90 kg (8.60 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1NSDSC0 |
3.80 kg (8.38 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSU1IPSBEA0 |
3.90 kg (8.60 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1IPSDSC0 |
3.80 kg (8.38 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1ACGDSC0 |
3.80 kg (8.38 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1ADEDSC0 |
3.80 kg (8.38 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSU1ADECEA0 |
3.90 kg (8.60 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM2FWDSC0 |
3.30 kg (7.28 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1EPSB0 |
3.40 kg (8.16 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1SDNB0 |
3.40 kg (8.16 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
LSQM1WBCZ720X |
3.50 kg (7.72 lb) |
40 mm (1.57 in) |
399 mm (15.71 in) |
355 mm (13.98 in) |
NOTE: · Card dimensions are expressed in the H × W × D format. ¡ H—Height of the front panel of the card. ¡ W—Width of the front panel of the card. ¡ D—Depth from the front panel of the card to the connector. · The card models listed in Table 6-2 are marked on the card panels. They might be slightly different from the card models marked on the card packages. For example, LSU1WCME0 and LSUM1WCME0 identify the same card. LSU1WCME0 is marked on the card panel. When you order the card, you refer to it as LSUM1WCME0. |
Table 6-3 Power module adapter weights and dimensions
Model |
Weight |
Height |
Width |
Depth |
LSQM1PWRSPB |
4.95 kg (10.91 lb) |
128 mm (5.04 in) |
196 mm (7.72 in) |
380 mm (14.96 in) |
Table 6-4 Power module weights and dimensions
Model |
Weight |
Height |
Width |
Depth |
PSR320-A |
1.89 kg (4.17 lb) |
40 mm (1.57 in)/1 RU |
140 mm (5.51 in) |
350 mm (13.78 in) |
PSR650-A |
2.42 kg (5.34 lb) |
140 mm (5.51 in) |
350 mm (13.78 in) |
PSR650-D |
2.25 kg (4.96 lb) |
140 mm (5.51 in) |
350 mm (13.78 in) |
PSR650C-12A |
4.70 kg (10.36 lb) |
128 mm (5.04 in)/3 RU |
196 mm (7.72 in) |
380 mm (14.96 in) |
PSR650C-12D |
4.20 kg (9.26 lb) |
196 mm (7.72 in) |
380 mm (14.96 in) |
PSR1200-A |
2.56 kg (5.64 lb) |
140 mm (5.51 in) |
350 mm (13.78 in) |
PSR1200-D |
2.51 kg (5.53 lb) |
140 mm (5.51 in) |
350 mm (13.78 in) |
PSR1400-A |
6.35 kg (14.00 lb) |
196 mm (7.72 in) |
380 mm (14.96 in) |
PSR1400-D |
9.24 kg (20.37 lb) |
196 mm (7.72 in) |
380 mm (14.96 in) |
PSR1400-12D1 |
6.39 kg (14.09 lb) |
196 mm (7.72 in) |
380 mm (14.96 in) |
PSR2500-12AHD |
5.70 kg (12.57 lb) |
196 mm (7.72 in) |
380 mm (14.96 in) |
PSR2500-12D |
196 mm (7.72 in) |
380 mm (14.96 in) |
PSR2800-ACV |
9.87 kg (21.76 lb) |
196 mm (7.72 in) |
380 mm (14.96 in) |
PSR6000-ACV |
12.16 kg (26.81 lb) |
196 mm (7.72 in) |
380 mm (14.96 in) |
Table 6-5 Fan tray weights and dimensions
Model |
Weight |
Height |
Width |
Depth |
S7503X fan tray S7503X-PoE fan tray |
1.00 kg (2.20 lb) |
29 mm (1.14 in) |
167 mm (6.57 in) |
350 mm (13.78 in) |
S7506X fan tray S7506X-PoE fan tray S7506X-S fan tray |
2.20 kg (4.85 lb) |
29 mm (1.14 in) |
347 mm (13.66 in) |
367 mm (14.45 in) |
S7506X-S-MF fan tray |
0.70 kg (1.54 lb) |
27 mm (1.06 in) |
100 mm (3.94 in) |
347 mm (13.66 in) |
S7510X fan tray S7510X-PoE fan tray |
2.94 kg (6.48 lb) |
28 mm (1.10 in) |
497 mm (19.57 in) |
351 mm (13.82 in) |
Module power consumption
Card power consumption
A card has different power consumptions in static and dynamic states.
· Static power consumption (min)—Power consumed by the card when the following conditions exist:
¡ The card is running but all ports on the card are down.
¡ No transceiver modules are installed in the fiber ports on the card.
· Dynamic power consumption (max)—Power consumed by the card when all the ports on the card are link up and broadcast storm occurs.
Table 6-6 Card power consumption
Model |
Static power consumption (min) |
Dynamic power consumption (max) |
LSQM2SUPA0 |
9 W |
18 W |
LSQM2SUPB0 |
15 W |
21 W |
LSQM3SUPA0 |
9 W |
16 W |
LSQM1MPUSA0 |
60 W |
100 W |
LSQM1MPUSC0 |
103 W |
168 W |
LSQM1SRP4Y06A0 |
37 W |
62 W |
LSQM1MPUS06S0 |
27 W |
42 W |
LSQM1MPUS10B0 |
67 W |
108 W |
LSQM1MPUS10C0 |
93 W |
182 W |
LSQM1TGS24QSFD0 |
60 W |
107 W |
LSQM1CQGS12SG0 |
55 W |
147 W |
LSQM1CGS2FE0 |
55 W |
77 W |
LSQM1QGS24RSG0 |
65 W |
198 W |
LSQM2GT24PTSSC0 |
36 W |
59 W |
LSQM2GT24TSSC0 |
32 W |
43 W |
LSQM3GP44TSSC0 |
34 W |
69 W |
LSQM1GP40TS8FD0 |
47 W |
96 W |
LSQM2GP40TS8FD0 |
42 W |
81 W |
LSQM2GP44TSSC0 |
31 W |
65 W |
LSQM2GP24TSSC0 |
27 W |
52 W |
LSQM1TGS48RFE0 |
50 W |
122 W |
LSQM1TGS48RSG0 |
60 W |
149 W |
LSQM2TGS48SG0 |
67 W |
152 W |
LSQM1TGS16GPSA0 |
28 W |
64 W |
LSQM1TGS24FD0 |
50 W |
104 W |
LSQM1TGS16FD0 |
54 W |
90 W |
LSQM2TGS16SF0 |
52 W |
75 W |
LSQM2GP24TSSA0 |
25 W |
49 W |
LSQM1TGS12EC0 |
82 W |
130 W |
LSQM1GP48FD0 |
49 W |
78 W |
LSQM1XPT12TSFD0 |
100 W |
162 W |
LSQM2XPT12TSFD0 |
100 W |
162 W |
LSQM1PT24TSSC0 |
80 W |
115 W |
LSQM1PT8TSSC0 |
56 W |
80 W |
LSQM2GP48SA0 |
28 W |
58 W |
LSQM2GP24SA0 |
24 W |
45 W |
LSQM1TGT24FD0 |
60 W |
112 W |
LSQM1GT48FD0 |
48 W |
65 W |
LSQM2GT48SA0 |
35 W |
45 W |
LSQM2GT48SC0 |
38 W |
48 W |
LSQM4GV48SA0 |
34 W |
44 W |
LSQM4GV48SC0 |
38 W |
48 W |
LSU1WCME0 |
125 W |
180 W |
LSU3WCMD0 |
118 W |
150 W |
LSQM1WCMX20 |
125 W |
180 W |
LSQM1WCMX40 |
125 W |
180 W |
LSQM1FWDSC0 |
115 W |
123 W |
LSU1FWCEA0 |
109 W |
157 W |
LSU3FWCEA0 |
109 W |
157 W |
LSUM1FWCEAB0 |
109 W |
157 W |
LSU1NSCEA0 |
109 W |
157 W |
LSQM1NSDSC0 |
115 W |
123 W |
LSU1IPSBEA0 |
109 W |
157 W |
LSQM1IPSDSC0 |
116 W |
124 W |
LSQM1ACGDSC0 |
116 W |
124 W |
LSQM1ADEDSC0 |
116 W |
124 W |
LSU1ADECEA0 |
109 W |
157 W |
LSQM2FWDSC0 |
60 W |
66 W |
LSQM1EPSB0 |
102 W |
124 W |
LSQM1SDNB0 |
102 W |
124 W |
LSQM1WBCZ720X |
160 W |
210 W |
Fan tray power consumption
The switch uses fan trays that can automatically adjust the fan speed based on the heat dissipation condition of the switch. The power consumed by a fan tray varies by fan speed. Table 6-7 shows the power consumption of different fan trays.
Table 6-7 Fan tray power consumption
Model |
Min fan tray power consumption |
Max fan tray power consumption |
S7503X S7503X-PoE |
7 W |
11 W |
S7506X S7506X-PoE S7506X-S |
24.5 W |
42.5 W |
S7506X-S-MF |
7.00 W |
14.00 W |
S7510X S7510X-PoE |
28 W |
48.5 W |
Total power consumption
For the S7503X, S7506X, S7506X-S, S7506X-S-MF, and S7510X switches, the total power consumption equals the system power consumption.
For the S7503X-PoE, S7506X-PoE, and S7510X-PoE switches, the total power consumption equals the system power consumption plus the PoE power consumption.
System power consumption
The total power consumption of the switch is the power consumptions of all operating cards and fan trays. It varies by the type and number of the operating cards and the fan tray power consumption.
· The minimum system power consumption is the total static power consumption of all cards plus the minimum fan tray power consumption. For example, an S7506X switch is installed with two LSQM1MPUS10C0 MPUs, three LSQM1GP48FD0 interface modules, and one fan tray. The minimum system power consumption of the switch is 2 × 93 + 3 × 49 + 24.5 = 357.5 W.
· The maximum system power consumption is the total dynamic power consumption of all cards plus the maximum fan tray power consumption. For example, an S7506X switch is installed with two LSQM1MPUS10C0 MPUs, three LSQM1GP48FD0 interface modules, and one fan tray. The maximum system power consumption of the switch is 2 × 182 + 3 × 78 + 42.5 = 640.5 W.
Table 6-8 lists the max power consumption for the switch.
· Max system power consumption (full and max configuration)—Max system power consumption when the switch is fully configured with cards and fan trays that have the highest power consumptions.
· Max card and fan tray power consumption (full and max configuration)—Max card and fan tray power consumption when the switch is fully configured with cards and fan trays that have the highest power consumptions.
Table 6-8 Max system/Max card and fan tray power consumption in full and max configuration
Model |
Max system power consumption (full and max configuration) |
Max card and fan tray power consumption (full and max configuration) |
S7503X-AC S7503X-DC S7503X-PoE-AC S7503X-PoE-DC |
800 W |
641 W |
770 W |
641 W |
S7506X-AC S7506X-DC S7506X-PoE-AC S7506X-PoE-DC |
1950 W |
1567 W |
1870 W |
1567 W |
S7506X-S-AC S7506X-S-MF-AC |
1640 W |
1315 W |
S7506X-S-DC S7506X-S-MF-DC |
1570 W |
1315 W |
S7510X-AC S7510X-DC S7510X-PoE-AC S7510X-PoE-DC |
2980 W |
2393 W |
2850 W |
2393 W |
The power over Ethernet (PoE) power consumption refers to the power that all powered devices (PDs) receive from the switch.
The maximum PoE power consumption refers to the sum of the power consumption of all PDs when all power interfaces (PIs) are connected to PDs and the maximum PI power is reached. The maximum PoE power consumption is decided by the following items:
· Number of the PoE cards installed on the switch.
· Number of the PIs that each PoE card provides.
· Maximum PoE power that each PoE card can provide.
· Maximum PoE power that each slot on the switch can provide.
Each slot of the switch can provide a maximum PoE power of 1440 W.
Table 6-9 shows the specifications for each PoE card model.
For example, an S7506X-PoE switch is installed with three LSQM4GV48SA0 PoE cards. The maximum PoE power consumption of the switch is 3 × 1440 = 4320 W.
Table 6-9 PoE card specifications
Model |
PI quantity |
PI power |
Maximum PSE power |
Maximum number of PSEs for each switch model |
LSQM4GV48SA0 |
48 |
0 to 30 W |
1440 W |
· S7503X-PoE: 3 · S7506X-PoE: 6 · S7510X-PoE: 10 |
LSQM4GV48SC0 |
48 |
0 to 30 W |
1440 W |
NOTE: · The PoE power consumption is 0 if the switch does not supply PoE. · The maximum PoE power consumption of the S7510X switch is 10000 W. · For more information about PoE power supply, see "(Optional) Setting up a PoE system." |
Heat dissipation
Heat dissipation is measured in BTU/h, and 1 W equals 3.4121 BTU/h.
The heat dissipation of a switch depends on its power consumption. To calculate heat dissipation of the switch, assume 90% power consumption is converted to heat, and the efficiency of the power module is 90%. Heat dissipation/hour of the switch is 0.9 × (total power consumption of the cards plus power consumption of the fan tray)/0.9 × 3.4121.
Table 6-10 shows the heat dissipation for each switch model.
Model |
Heat dissipation (BTU/h) |
S7503X S7503X-PoE |
2187 |
S7506X S7506X-PoE |
5347 |
S7506X-S S7506X-S-MF |
4487 |
S7510X S7510X-PoE |
8165 |
For the power consumption of the cards and fan trays available for the switch, see "Module power consumption."
Noise
The switch uses fan trays that can adjust the fan speed automatically based on the device temperature. The sound pressure levels vary by fan speed. For more information, see Table 6-11.
Table 6-11 Sound pressure levels
Model |
Sound pressure level when the fan tray operates at low speed |
Sound pressure level when the fan tray operates at middle speed |
Sound pressure level when the fan tray operates at full speed |
S7503X S7503X-PoE |
52.2 dBA |
54.0 dBA |
56.0 dBA |
S7506X S7506X-PoE S7506X-S S7506X-S-MF |
53.6 dBA |
56.2 dBA |
57.7 dBA |
S7510X S7510X-PoE |
53.5 dBA |
55.8 dBA |
56.7 dBA |
