- H3C S7500X Switch Series Installation Guide-6W105
- 01-Chapter 1 Preparing for Installation
- 02-Chapter 2 Installing the Switch
- 03-Chapter 3 Installing FRUs
- 04-Chapter 4 Connecting Your Switch to the Network
- 05-Chapter 5 Replacement Procedures
- 06-Appendix A Chassis Views and Technical Specifications
- 07-Appendix B FRUs and Compatibility Matrixes
- 08-Appendix C LEDs
- 09-Appendix D Cables
- 10-Appendix E Engineering Labels for Cables
- 11-Appendix F Cable Management
02-Chapter 2 Installing the Switch | 4.21 MB |
Confirming installation preparations
Attaching slide rails and cage nuts to the rack
Installing cage nuts for attaching mounting brackets
Attaching accessories to the chassis
Installing mounting brackets and cable management bracket
(Optional) Installing an air filter
Mounting the switch in the rack
Connecting the grounding cable to a grounding strip
Grounding the switch through an AC power cord
Grounding the switch through the RTN wire of a DC power cord
2 Installing the switch
IMPORTANT: Keep the packages of the switch and the components for future use. |
NOTE: The chassis and FRU views in the figures in this section are for illustration only. |
Installation flow
Table 2-1 Installation flow description
Step |
Remarks |
Preparations before installation |
· For how to install slide rails, see "Installing slide rails." · For how to install cage nuts, see "Installing cage nuts for attaching mounting brackets" |
Accessories to be installed on the chassis: · For how to mount brackets and cable management brackets, see "Installing mounting brackets and cable management bracket." · For how to install an air filter (optional), see "(Optional) Installing an air filter." |
N/A |
N/A |
Before you install the switch in a rack, verify the following items:
· You have read the chapter "Preparing for installation" carefully and the installation site meets all the requirements.
· A 19-inch rack is ready for use. For how to install a rack, see the rack installation guide.
· The rack is sturdy and reliably grounded.
· The installation position on the rack is appropriate for the chassis.
· No debris exists inside or around the rack.
· The switch is ready for installation and has been carried to a place near the rack and convenient for moving.
IMPORTANT: To ensure the stability of the rack, mount the switch at the lowest possible position. To mount multiple switches on the rack, mount the heaviest switch at the bottom of the rack. |
Before installing the switch in a rack, attach slide rails to the rack. If the rack has slide rails, skip this section. Verify that the slide rails can support the weight of the switch before attaching it to the switch. For the weight of the switch, see "Weights and dimensions." As a best practice, order the H3C Slide Rail Accessories,500mm-800mm (LSTM2KSGD0) for the switch.
Determine the installation position of the switch in the rack as required. For the dimensions of the switch, see "Weights and dimensions."
The slide rail installation procedure varies by rack type The following installation procedure is for your reference only.
To install a slide rail:
1. Read the signs on the slide rails (see Table 2-2) to avoid installation mistakes.
Figure 2-2 Right slide rail
(1) Guide rail |
(2) Sign |
(3) Installation hole |
Table 2-2 Description for signs on the slide rails
Sign |
Meaning |
Remarks |
F/L |
Front end of the left slide rail |
Mount this end to the front left rack post. |
F/R |
Front end of the right slide rail |
Mount this end to the front right rack post. |
2. Mark the position on the rack for installing the slide rail.
¡ Make sure the bottom edge of the slide rail aligns with the middle of the narrower metal area between holes on a rack post, as shown in Figure 2-3.
¡ Each rack post requires six screws to secure the slide rail. You only need to mark the uppermost square hole and lowermost square hole for installation.
¡ Mark the square holes at the same height on the other three rack posts.
NOTE: One rack unit has three holes, the middle of which is an auxiliary installation hole, and the other two are standard installation holes. You can distinguish them by the space between each two holes. The space between a standard installation hole and an auxiliary installation hole is larger than the space between two adjacent standard installation holes. |
Figure 2-3 Locating the position on the rack for installing the slide rail
(1) Middle of the narrower metal area between holes |
3. Install six cage nuts on the square holes in each rack post, as shown in Figure 2-4.
Figure 2-4 Installing a cage nut
4. Align the installation holes on the front end of a slide rail with the cage nuts on the front rack post, and secure them with screws, as shown in Figure 2-5.
Figure 2-5 Attaching a slide rail to a front rack post
5. Keep the slide rail horizontally and adjust its length until the installation holes on the rear end of the slide rail touch the cage nuts on the rear rack post. Then fasten the screws.
TIP: Install a screw in each mounting hole of the slide rail to ensure its weight bearing capacity. |
6. Repeat step 4 and step 5 to install the other slide rail. Make sure the two slide rails are at the same height so the device can be placed on them horizontally.
Figure 2-6 Installed slide rails
1. Determine and mark the cage nut installation holes on the front rack posts ,as shown in Figure 2-7.
2. Install cage nuts, as shown in Figure 2-4.
Figure 2-7 Installing cage nuts (S7506X switch)
NOTE: When preparing for installation, make sure the total height of the switches to be installed does not exceed the height of the rack. |
Before installing the switch in the rack, attach the mounting brackets and cable management bracket (shipped with the chassis) to the switch. The mounting brackets are used for attaching the chassis to the rack, and the cable management bracket is used for cabling the switch.
To attach the mounting brackets and cable management bracket to the switch:
1. Attach the cable management bracket to the left mounting bracket, as shown in Figure 2-9.
Figure 2-8 Attaching the cable management bracket to the left mounting bracket
2. Facing the front of the switch, mount the mounting bracket with the cable management bracket to the left of the switch, and mount the other mounting bracket to the right of the switch (where the fan tray is located).
Figure 2-9 Attaching the mounting brackets to the chassis (S7506X switch)
Air filters are optional components for the switch. If you have ordered an air filter, attach it to the left of the chassis before mounting the switch in the rack.
1. Unpack the air filter and fastening strips.
2. Align the screw holes in the fastening strip with the screw holes in the chassis, insert the screws into the screw holes, and then fasten the screws clockwise with a screwdriver, as shown by callout 1 in Figure 2-10.
3. Push the air filter in between the fastening strips, as shown by callout 2 in Figure 2-10.
4. Fasten the captive screws, as shown by callout 3 in Figure 2-10.
Figure 2-10 Installing an air filter (S7506X switch)
CAUTION: · Do not hold the handle of the fan tray, power module, or the back cover of the chassis, or the air vents of chassis to move the switch. Any attempt to carry the switch with these parts might cause equipment damage or even bodily injury. · Use a mechanical lift for switches of a high weight. · After placing the switch on the slide rails, do not leave go of your hands immediately because this might tip and damage the switch, and even cause bodily injury. |
To mount the switch in the rack:
1. Face the rear of the chassis towards the front of the rack.
2. Use a minimum of two people to lift the switch until the bottom of the switch is a little higher than the slide rails on the rack.
3. Place the switch on the slide rails and slide the switch along the slide rails until the mounting brackets on the switch touch the front rack posts.
4. Secure the chassis to the rack with mounting screws.
Figure 2-11 Installing the chassis in the rack (S7506X switch)
NOTE: If the screw holes in the mounting brackets cannot align with the cage nuts on the rack, verify that the bottom edge of the slide rail aligns with the middle of the narrowest metal area between holes and that the cage nuts are installed in the correct holes. |
CAUTION: Correctly grounding the switch is crucial to lightening protection and EMI prevention. Before you use the switch, make sure you have grounded it reliably. |
CAUTION: · Connect the grounding cable to the earthing system in the equipment room. Do not connect it to a fire main or lightning rod. · To guarantee the grounding effect, use the grounding cable provided with the switch. The grounding cable uses a two-hole lug for connecting the chassis and a ring terminal for connecting the grounding strip. It is compliant with the NEBS standard. |
When a grounding strip is available at the installation site, you can ground the switch by connecting the grounding cable to the grounding strip.
To connect the grounding cable to a grounding strip:
1. Unpack the grounding cable.
2. Remove the grounding screws from the grounding holes at the rear of the chassis.
3. Use grounding screws to attach the two-hole grounding lug of the grounding cable to the chassis.
Figure 2-12 Connecting the grounding cable to a grounding strip
CAUTION: · Make sure the AC power supply uses a three-wire cable with a protection wire, and the AC power cord is reliably grounded at the power distribution room or AC power supply transformer side. · Make sure the AC receptacle on the switch is correctly connected to the AC power supply. |
If the switch is AC powered and no grounding strip is available at the installation site, you can ground the switch through an AC power cord, as shown in Figure 2-13.
Figure 2-13 Grounding the switch through an AC power cord
CAUTION: Make sure the RTN busbar in the equipment room is reliably grounded. |
If the switch is powered by a –48 VDC power supply and no grounding strip is available at the installation site, you can ground the switch through the return (RTN) wire of a DC power cord, as shown in Figure 2-14.
Figure 2-14 Grounding the switch through the RTN wire of a DC power cord
