15-High Availability Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5426P02)-6W10415-High Availability Command Reference
04-Load balancing commands
04-Load balancing commands 566.74 KB
Load balancing commands· 1
activate (link group view) 2
auto-alloc address· 2
bandwidth busy-protection enable (transparent DNS proxy view) 3
bandwidth busy-protection enable (virtual server view) 4
bandwidth busy-rate (link view) 4
bandwidth interface statistics enable· 6
bandwidth weight 6
class· 7
connection-limit (virtual server view) 7
connection-limit max (link view) 8
cost 9
cost weight 9
default dns-server-pool 10
default link-group· 10
default-class action· 11
description· 12
display loadbalance action· 13
display loadbalance alg· 14
display loadbalance class· 15
display loadbalance dns-proxy· 16
display loadbalance dns-proxy statistics· 18
display loadbalance dns-server 18
display loadbalance dns-server statistics· 20
display loadbalance dns-server-pool 21
display loadbalance isp· 24
display loadbalance link· 25
display loadbalance link out-interface statistics· 29
display loadbalance link statistics· 30
display loadbalance link-group· 31
display loadbalance policy· 34
display loadbalance proximity· 35
display loadbalance snat-pool 36
display parameter-profile· 37
display sticky· 38
display sticky-group· 40
display virtual-server 42
display virtual-server statistics· 44
dns-server-pool (LB action view) 45
dns-server-pool (DNS server view) 46
fail-action (link group view) 46
fallback-action continue· 47
forward all 48
frequency· 48
ip· 49
ip address (transparent DNS proxy view) 50
ip address (DNS server view) 50
ip address (ISP view) 51
ip mask· 52
ip range (SNAT address pool view) 52
ipv6· 53
ipv6 address (transparent DNS proxy view) 54
ipv6 address (DNS server view) 54
ipv6 address (ISP view) 55
ipv6 prefix· 56
ipv6 range· 56
isp· 57
lb-policy (transparent DNS proxy view) 57
lb-policy (virtual server view) 58
link (DNS server view) 59
link-group (LB action view) 59
link-group (link view) 60
loadbalance action· 61
loadbalance alg· 61
loadbalance alg all-enable· 62
loadbalance class· 63
loadbalance dns-proxy· 63
loadbalance dns-server 64
loadbalance dns-server-pool 65
loadbalance isp file· 65
loadbalance isp name· 66
loadbalance link· 66
loadbalance link-group· 67
loadbalance log enable bandwidth-busy· 68
loadbalance log enable base· 68
loadbalance log enable nat 69
loadbalance policy· 69
loadbalance probe-template· 70
loadbalance proximity· 71
loadbalance region· 71
loadbalance schedule-test ip· 72
loadbalance schedule-test ipv6· 73
loadbalance snat-pool 74
match· 75
match acl 76
match app-group· 76
match class· 77
match default 78
match destination· 79
match destination domain-name· 80
match domain-name· 80
match interface· 81
match isp· 82
match source· 82
match user 83
match user-group· 84
max-bandwidth (link view) 85
max-number 86
override-limit enable· 86
parameter 87
parameter-profile· 88
port (transparent DNS proxy view) 88
port (DNS server view) 89
port (virtual server view) 89
predictor (DNS server pool view) 90
predictor (link group view) 91
priority (DNS server view) 93
priority (link view) 93
probe (DNS server pool view) 94
probe (DNS server view) 95
probe (link group view) 96
probe (link view) 96
proximity enable (link group view) 97
rate-limit bandwidth (link view) 98
rate-limit bandwidth (virtual server view) 99
rate-limit connection (link view) 99
rate-limit connection (virtual server view) 100
reset loadbalance connections· 101
reset loadbalance dns-proxy statistics· 101
reset loadbalance dns-server statistics· 101
reset loadbalance link statistics· 102
reset loadbalance proximity· 102
reset virtual-server statistics· 103
router interface· 103
router ip· 104
router ipv6· 105
rtt weight 105
selected-link· 106
selected-server (DNS server pool view) 106
service enable (transparent DNS proxy view) 107
service enable (virtual server view) 108
set ip tos (LB action view) 108
set ip tos (parameter profile view) 109
shutdown (link view) 109
skip current-dns-proxy· 110
slow-online (link group view) 110
slow-shutdown enable (link view) 111
snat-pool (link group view) 112
snmp-agent trap enable loadbalance· 112
sticky-group· 113
success-criteria (DNS server pool view) 114
success-criteria (DNS server view) 114
success-criteria (link group view) 115
success-criteria (link view) 116
timeout (proximity view) 117
timeout (sticky group view) 117
timeout (template view) 118
topology region· 118
transparent enable (link group view) 119
ttl weight 120
virtual ip address· 120
virtual ipv6 address· 121
virtual-server (system view) 121
virtual-server-pool 122
weight (DNS server view) 123
weight (link view) 123
The following compatibility matrixes show the support of hardware platforms for load balancing:
Hardware series
Model
Product code
Load balancing compatibility
WX1800H series
WX1804H
EWP-WX1804H-PWR-CN
Yes
WX2500H series
WX2508H-PWR-LTE
WX2510H
WX2510H-F
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
Yes
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
No
WX3500H series
WX3508H
WX3510H
WX3520H
WX3520H-F
WX3540H
EWP-WX3508H
EWP-WX3510H
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
No
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
No
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
No
Access controller modules
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
No
Hardware series
Model
Product code
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
Yes
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
No
WX5800H series
WX5860H
EWP-WX5860H-GL
No
Use activate to set the criteria to determine whether a link group is available.
Use undo activate to restore the default.
activate lower lower-percentage upper upper-percentage
undo activate
A link group is available when a minimum of one link is available.
Link group view
lower lower-percentage: Specifies the lower percentage value in the range of 1 to 99.
upper upper-percentage: Specifies the upper percentage value in the range of 1 to 99. The upper percentage value must be greater than or equal to the lower percentage value.
When the percentage of available links in a primary link group is smaller than the lower percentage value, the primary link group becomes unavailable. Then the backup link group takes over. When the percentage of available links in a primary link group is greater than the upper percentage value, the primary link group becomes available again to process services.
If no backup link group is configured on the virtual server, this configuration does not take effect.
# Set the lower percentage value to 20 and upper percentage value to 80 for the link group lg.
[Sysname] loadbalance link-group lg
[Sysname-lb-lgroup-lg] activate lower 20 upper 80
auto-alloc address
Use auto-alloc address to enable the device to automatically obtain the IP address of a DNS server.
Use undo auto-alloc address to disable the device from automatically obtaining the IP address of a DNS server.
auto-alloc address
The device is disabled from automatically obtaining the IP address of a DNS server.
DNS server view
This command is mutually exclusive with the ip address and ipv6 address commands.
Before configuring this command, you must configure the router interface command. Otherwise, the IP address of the DNS server cannot be obtained.
If the device obtains multiple DNS server IP addresses, it uses the smallest available IP address.
# Enable the device to automatically obtain the IP address of DNS server ds1.
[Sysname] loadbalance dns-server ds1
[Sysname-lb-ds-ds1] auto-alloc address
Use bandwidth busy-protection enable to enable the link protection feature for a transparent DNS proxy.
Use undo bandwidth busy-protection enable to disable the link protection feature for a transparent DNS proxy.
The link protection feature is disabled for a transparent DNS proxy.
Transparent DNS proxy view
This feature enables a transparent DNS proxy to select a DNS server from the DNS server pool based on the link bandwidth ratio. If the bandwidth ratio of a link exceeds the specified value, the corresponding DNS server is not selected.
If the link bandwidth ratio of all DNS servers in the DNS server pool exceeds the specified value, the link protection feature is automatically disabled. If the link bandwidth ratio of any DNS server drops below the specified value, the link protection feature is automatically enabled, and the corresponding DNS server is selected.
# Enable the link protection feature for transparent DNS proxy dns-proxy1.
[Sysname] loadbalance dns-proxy dns-proxy1
[Sysname-lb-dp-udp-dns-proxy1] bandwidth busy-protection enable
Use bandwidth busy-protection enable to enable the link protection feature.
Use undo bandwidth busy-protection enable to disable the link protection feature.
The link protection feature is disabled.
Virtual server view
The link protection feature takes effect only when bandwidth statistics collection by interfaces is enabled.
# Enable the link protection feature for the IP-type virtual server vs3.
<Sysname>system-view
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] bandwidth busy-protection enable
Use bandwidth busy-rate to set the bandwidth ratio for an LB link.
Use undo bandwidth busy-rate to restore the default.
bandwidth [ inbound | outbound ] busy-rate busy-rate-number [ recovery recovery-rate-number ]
undo bandwidth [ inbound | outbound ] busy-rate
The bandwidth ratio is 70.
LB link view
inbound: Specifies the inbound bandwidth ratio.
outbound: Specifies the outbound bandwidth ratio.
busy-rate-number: Specifies bandwidth ratio in the range of 1 to 100.
recovery recovery-rate-number: Specifies bandwidth recovery ratio in the range of 1 to 100. By default, if the bandwidth ratio is greater than 10, the bandwidth recovery ratio equals the bandwidth ratio minus 10; if the bandwidth ratio is smaller than or equal to 10, the bandwidth recovery ratio equals the bandwidth ratio.
If the bandwidth of an LB link exceeds the maximum expected bandwidth multiplied by the bandwidth ratio, the LB link is busy and will not be selected. If the bandwidth of the LB link drops below the maximum expected bandwidth multiplied by the bandwidth recovery ratio, the LB link participates in scheduling again.
If you do not specify the inbound or outbound keyword, this command sets the total bandwidth ratio.
The bandwidth ratio equals the current bandwidth divided by the maximum bandwidth of the LB link. If the maximum bandwidth is not limited, the supported maximum bandwidth is used for calculating the bandwidth ratio.
The bandwidth recovery ratio must be smaller than or equal to the bandwidth ratio of an LB link.
This command takes effect only on new sessions and does not take effect on existing sessions.
# Set the total bandwidth ratio and bandwidth recovery ratio for the LB link lk1 to 90 and 85.
[Sysname] loadbalance link lk1
[Sysname-lb-link-link1] bandwidth busy-rate 90 recovery 85
Use bandwidth interface statistics enable to enable bandwidth statistics collection by interfaces.
Use undo bandwidth interface statistics enable to disable bandwidth statistics collection by interfaces.
Bandwidth statistics collection by interfaces is disabled.
Virtual server view
# Enable bandwidth statistics collection by interfaces for the IP-type virtual server vs3.
[Sysname-vs-ip-vs3] bandwidth interface statistics enable
bandwidth weight
Use bandwidth weight to set the bandwidth weight for proximity calculation.
Use undo bandwidth weight to restore the default.
bandwidth { inbound | outbound } weight bandwidth-weight
undo bandwidth { inbound | outbound } weight
The inbound or outbound bandwidth weight for proximity calculation is 100.
Proximity view
inbound: Specifies the inbound bandwidth weight.
outbound: Specifies the outbound bandwidth weight.
bandwidth-weight: Specifies the bandwidth weight for proximity calculation, in the range of 0 to 255. A larger value indicates a higher bandwidth weight.
# Set the inbound bandwidth weight for proximity calculation to 200.
[Sysname] loadbalance proximity
[Sysname-lb-proximity] bandwidth inbound weight 200
# Set the outbound bandwidth weight for proximity calculation to 200.
[Sysname-lb-proximity] bandwidth outbound weight 200
class
Use class to specify an LB action for the specified LB class.
Use undo class to delete an LB class.
class class-name [ insert-before before-class-name ] action action-name
undo class class-name
No LB action is specified for the LB class.
LB policy view
class-name: Specifies an LB class by its name, a case-insensitive string of 1 to 63 characters.
insert-before before-class-name: Inserts the target class before an LB class (which must already be referenced by the current LB policy), a case-insensitive string of 1 to 63 characters.
action-name: Specifies an LB action by its name, a case-insensitive string of 1 to 63 characters.
This command sets an LB action for packets matching the specified LB class.
You can specify an LB action for different LB classes.
A DNS LB policy can reference DNS LB actions only.
# Specify the LB action lba1 for the LB class lbc1 in the DNS LB policy lbp1, and insert lbc1 before the LB class lbc0.
[Sysname] loadbalance policy lbp1 type dns
[Sysname-lbp-dns-lbp1] class lbc1 insert-before lbc0 action lba1
Use connection-limit max to set the maximum number of connections of a virtual server.
Use undo connection-limit max to restore the default.
connection-limit max max-number
The maximum number of connections of a virtual server is 0, which means the number is not limited.
Virtual server view
max-number: Specifies the maximum number of connections, in the range of 0 to 4294967295. If the value of this argument takes 0, the number is not limited.
# Set the maximum number of connections for the IP-type virtual server vs3 to 10000.
[Sysname-vs-ip-vs3] connection-limit max 10000
Use connection-limit max to set the maximum number of connections of a link.
The maximum number of connections of a link is 0, which means the number is not limited.
Link view
# Set the maximum number of connections of the link lk to 10000.
[Sysname-lb-link-lk] connection-limit max 10000
cost
Use cost to set the link cost for proximity calculation.
Use undo cost to restore the default.
cost cost-value
undo cost
The link cost for proximity calculation is 0.
Link view
cost-value: Specifies the link cost for proximity calculation, in the range of 0 to 10240.
# Set the link cost for proximity calculation to 200 for the link lk1.
[Sysname-lb-link-lk1] cost 200
cost weight
Use cost weight to set the cost weight for proximity calculation.
Use undo cost weight to restore the default.
cost weight cost-weight
undo cost weight
The cost weight for proximity calculation is 100.
Proximity view
cost-weight: Specifies the cost weight for proximity calculation, in the range of 0 to 255. A larger value indicates a higher cost weight.
# Set the cost weight for proximity calculation to 200.
[Sysname-lb-proximity] cost weight 200
Use default dns-server-pool to specify the default (primary) DNS server pool for a transparent DNS proxy.
Use undo default dns-server-pool to restore the default.
default dns-server-pool pool-name [ sticky sticky-name ]
No default DNS server pool is specified for a transparent DNS proxy.
pool-name: Specifies a primary DNS server pool by its name, a case-insensitive string of 1 to 63 characters.
sticky sticky-name: Specifies a sticky group by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a sticky group, the DNS server pool does not correspond to any sticky group.
If you execute the default dns-server-pool command multiple times, the most recent configuration takes effect.
# Specify the primary DNS server pool dns-pool1 and the sticky group st1 for the transparent DNS proxy dns-proxy1.
[Sysname-lb-dp-udp-dns-proxy1] default dns-server-pool dns-pool1 sticky st1
default link-group
Use default link-group to specify the default (primary) link group.
Use undo default link-group to restore the default.
default link-group link-group-name [ backup backup-link-group-name ] [ sticky sticky-name ]
No default link group is specified.
Link-IP virtual server view
link-group-name: Specifies a primary link group by its name, a case-insensitive string of 1 to 63 characters.
backup backup-link-group-name: Specifies a backup link group by its name, a case-insensitive string of 1 to 63 characters.
When the primary link group is available (contains links), the virtual server forwards packets through the primary link group. When the primary link group is not available, the virtual server forwards packets through the backup link group.
# Specify the primary link group link1, the backup link group link2, and the sticky group sg1 for the link-IP-type virtual server vs3.
[Sysname] virtual-server vs3 type link-ip
[Sysname--vs-link-ip-vs3] default link-group link1 backup link2 sticky sg1
Use default-class action to specify the default LB action.
Use undo default-class to restore the default.
default-class action action-name
undo default-class
No default LB action is specified.
LB policy view
This command sets the default LB action for packets that fail to match any LB class.
# Specify the default LB action lba1 for the DNS LB policy lbp1.
[Sysname-lbp-dns-lbp1] default-class action lba1
description
Use description to configure a description.
No description is configured.
ISP view
LB action view
LB class view
LB policy view
Parameter profile view
Sticky group view
Virtual server view
Link group view
Link view
DNS server view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description LB action LBA1 for the DNS LB action lba1.
[Sysname] loadbalance action lba1 type dns
[Sysname-lba-dns-lba1] description LB action LBA1
Use display loadbalance action to display LB action information.
display loadbalance action [ name action-name ]
name action-name: Specifies an LB action by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all LB actions.
# Display information about all LB actions.
<Sysname> display loadbalance action
LB action: lba3
  Description: sina
  Type: Link-generic
  State: Active
  Forward type: link group
  Link group: lg1 (in use)
  Backup link group: lg2
  Sticky:
  IP ToS:
  Fallback-action: None
LB action: lba4
  Description: xx
  Type: DNS
  State: Active
  Forward type: DNS server pool
  DNS server pool: dsp1
  Sticky: st
  IP ToS:
  Fallback-action: Disabled
  Busy-action: Force
LB action
LB action name.
Description for the LB action.
LB action type:
·     DNS.
·     Link-generic.
LB action state:
·     Active.
·     Inactive.
Forward type
Packet forwarding mode of the LB action:
·     Drop—Discards packets.
·     Forward—Forwards packets.
·     Link group—Forwards packets through the link group (applicable to link-generic LB actions).
·     DNS server pool—Forwards packets through the DNS server pool (applicable to DNS LB actions).
·     Skip current DNS proxy (applicable to DNS LB actions).
·     Redirect—Redirects packets.
·     Response—Responds to client requests by using a file.
Link group
Default link group name. (in use) indicates the link group is in use.
Backup link group
Backup link group name. (in use) indicates the link group is in use.
IP ToS
ToS field value of IP packets.
Fallback-action
Action taken upon load balancing failure:
·     None—Does not take any action.
·     Continue—Matches the next rule.
Busy-action
Action taken upon busyness:
·     Force—Assigns packets to links or DNS servers regardless of whether they are busy.
DNS server pool
DNS server pool name. This field is displayed only when the packet forwarding mode is DNS server pool.
Use display loadbalance alg to display the ALG status for all protocols.
# Display the ALG status for all protocols.
<Sysname> display loadbalance alg
LB ALG:
  DNS         : Enable
  FTP         : Enable
  H323        : Disabled
  ICMP-ERROR  : Enable
  ILS         : Disabled
  MGCP        : Disabled
  NBT         : Disabled
  PPTP        : Enable
  RSH         : Disabled
  RTSP        : Enable
  SCCP        : Disabled
  SIP         : Disabled
  SQLNET      : Disabled
  TFTP        : Disabled
  XDMCP       : Disabled
Use display loadbalance class to display LB class information.
display loadbalance class [ name class-name ]
name class-name: Specifies an LB class by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all LB classes.
# Display information about all LB classes.
<Sysname> display loadbalance class
LB class: lbc3
  Description:
  Type: Link-generic
  Match type: Match-any
  Match rule:
    match 1 class cla3
    match 2 source ip address 1.2.3.0 24
    match 3 source ipv6 address 1::12
    match 4 acl ipv4 number 3002
    match 5 acl ipv6 number 3003
    match 6 acl ipv4 name ccc
    match 7 acl ipv6 name ddd
    match 8 isp name isp2
    match 9 user u1
    match 10 user-group lb-group
    match 11 interface GE1/0/1
LB class: lbc4
  Description:
  Type: DNS
  Match rule:
    match 1 class cla2
    match 8 destination ip address 1.2.3.0 24
    match 9 destination ipv6 address 1::12
    match 10 domain-name www.h3c.com
LB class
LB class name.
Description for the LB class.
LB class type:
·     DNS.
·     Link-generic.
Match type
Match type for the LB class:
·     Match-all—Requires matching all rules of the LB class.
·     Match-any—Requires matching any rule of the LB class.
Match rule
Match rules for the LB class.
Use display loadbalance dns-proxy to display transparent DNS proxy information.
display loadbalance dns-proxy [ brief | name dns-proxy-name ]
brief: Displays brief transparent DNS proxy information. If you do not specify this keyword, the command displays detailed transparent DNS proxy information.
name dns-proxy-name: Specifies a transparent DNS proxy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all transparent DNS proxies.
# Display brief information about all transparent DNS proxies.
<Sysname> display loadbalance dns-proxy brief
DNS proxy     State       Type    VPN instance    IP address     Port
dns-proxy1    Active      UDP                     1.2.3.0/24     53
dns-proxy2    Inactive    UDP                     --             5353
# Display information about transparent DNS proxy dns-proxy1.
<Sysname> display loadbalance dns-proxy name dns-proxy1
DNS proxy: dns-proxy1
  Type: UDP
  State: Active
  Service state: Enabled
  VPN instance:
  IPv4 address: 1.2.3.0/24
  IPv6 address: --
  Port: 53
  DNS server pool: dns-pool1
  Sticky: st
  LB policy: dns-policy1
  Connection synchronization: Enabled
  Sticky synchronization: Enabled
  Bandwidth busy protection: Disabled
DNS proxy
Transparent DNS proxy name.
Transparent DNS proxy type. Only UDP is supported.
Transparent DNS proxy state:
·     Active—The transparent DNS proxy is available.
·     Inactive—The transparent DNS proxy is unavailable for any reason except that the transparent DNS proxy feature is disabled.
·     Inactive (disabled)—The transparent DNS proxy is unavailable because the transparent DNS proxy feature is disabled.
Service state
Transparent DNS proxy state: Enabled or Disabled.
VPN instance
This field is not supported in the current software version.VPN instance to which the transparent DNS proxy belongs.
DNS server pool
Default DNS server pool used by the transparent DNS proxy.
Sticky
Sticky group used by the transparent DNS proxy.
Link protection state: Enabled or Disabled.
Use display loadbalance dns-proxy statistics to display transparent DNS proxy statistics.
display loadbalance dns-proxy statistics [ name dns-proxy-name ]
name dns-proxy-name: Specifies a transparent DNS proxy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics for all transparent DNS proxies.
# Display statistics for the transparent DNS proxy dns-proxy1.
<Sysname> display loadbalance dns-proxy statistics name dns-proxy1
Received requests: 100
Dropped requests: 2
Received responses: 98
Dropped responses: 0
DNS proxy
Received requests
Number of DNS requests received by the transparent DNS proxy.
Dropped requests
Number of DNS requests dropped by the transparent DNS proxy.
Received responses
Number of DNS responses received by the transparent DNS proxy.
Dropped responses
Number of DNS responses dropped by the transparent DNS proxy.
Use display loadbalance dns-server to display DNS server information.
display loadbalance dns-server [ brief | name dns-server-name ]
brief: Displays brief DNS server information. If you do not specify this keyword, the command displays detailed DNS server information.
name dns-server-name: Displays detailed information about a DNS server. The dns-server-name argument specifies a DNS server by its name, a case-insensitive string of 1 to 63 characters.
If you do not specify any parameter, the command displays detailed information about all DNS servers.
If no health monitoring method is specified, the device determines that all obtained DNS server IP addresses are available. If a health monitoring method is specified, the device determines that only the DNS server IP addresses that pass health monitoring are available.
# Display brief information about all DNS servers.
<Sysname> display loadbalance dns-server brief
(*) – Auto-alloc address using
DNS server   Address             Port    Link         State         DNS server pool
ds1          10.150.100.100(*)   0       link1        Active        dns_pool
ds2          20.150.100.100      5353    link2        Probe-failed  dns_pool
ds3          --                  0       link3        Inactive      dns_pool
ds4          --(*)               0       link3        Inactive      dns_pool
# Display detailed information about DNS server ds1.
<Sysname> display loadbalance dns-server name ds1
DNS server: ds1
  Description:
  State: Active
  Auto-alloc address: Enabled
  IPv4 address: 10.150.100.100(*)
                10.160.100.1
                10.154.60.2
  IPv6 address: --
  Port: 0 (port number in original packet)
  Link: link1
  Weight: 100
  Priority: 4
  Probe information:
    Probe success criteria: All
    Probe method      State
    t4                Succeeded
Table 5 Command output
DNS server
DNS server name.
Address
IP address of the DNS server. The asterisk (*) indicates that the IP address is automatically obtained and is being used. If all obtained IP addresses are unavailable, this field displays --(*). If no IP address is obtained and no IP address is manually configured, this field displays two hyphens (--).
Link
Link of the DNS server.
Parent state/State
DNS server state:
·     Active—The DNS server is available.
·     Busy—The DNS server is busy. When the DNS server is in Active state and enabled with the link protection feature, this field displays Busy if the maximum expected bandwidth is reached.
·     Inactive—The DNS server is unavailable, because the configuration is not complete or the server is not referenced.
·     Probe-failed—Health monitoring has failed.
·     Unknown—Health monitoring is not configured.
Description for the DNS server.
Auto-alloc address
Whether the device is enabled to automatically obtain the IP address of a DNS server: Disabled or Enabled.
IPv4 address
IPv4 address of the DNS server.
IPv6 address
IPv6 address of the DNS server.
Port
Port number of the DNS server. 0 means the port number in the packet is used.
Weight
Weight of the DNS server.
Priority
Priority of the DNS server.
Probe information
Detailed health monitoring information for the DNS server.
Health monitoring success criteria for the DNS server:
·     All—Health monitoring succeeds only when all the specified health monitoring methods succeed.
·     At least—Health monitoring succeeds when a specified minimum number of health monitoring methods succeed.
Probe method
Name of the NQA template used by the health monitoring method.
State of the health monitoring method:
·     Failed—Health monitoring has failed.
·     In progress—Health monitoring is in progress.
·     Invalid—Health monitoring is unavailable (because the configuration of the NQA template is not complete), or the DNS server is unavailable.
·     Succeeded—Health monitoring has succeeded.
Use display loadbalance dns-server statistics to display DNS server statistics.
display loadbalance dns-server statistics [ name dns-server-name ]
name dns-server-name: Specifies a DNS server by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics for all DNS servers.
# Display statistics for the DNS server ds1.
<Sysname> display loadbalance dns-server statistics name ds1
DNS server: ds1
Send requests: 98
Dropped requests: 2
Send responses: 98
Table 6 Command output
DNS server
DNS server name.
Received requests
Number of DNS requests received by the DNS server.
Send requests
Number of DNS requests sent by the DNS server.
Dropped requests
Number of DNS requests dropped by the DNS server.
Received responses
Number of DNS responses received by the DNS server.
Send responses
Number of DNS responses sent by the DNS server.
Dropped responses
Number of DNS responses dropped by the DNS server.
Use display loadbalance dns-server-pool to display DNS server pool information.
display loadbalance dns-server-pool [ brief | name pool-name ]
brief: Displays brief DNS server pool information. If you do not specify this keyword, the command displays detailed DNS server pool information.
name pool-name: Displays detailed information about a DNS server pool. The pool-name argument specifies a DNS server pool by its name, a case-insensitive string of 1 to 63 characters.
If you do not specify any parameter, the command displays detailed information about all DNS server pools.
# Display brief information about all DNS server pools.
<Sysname> display loadbalance dns-server-pool brief
Predictor: RR - Round robin, RD - Random,
           BW - Bandwidth, MBW - Max bandwidth,
           IBW - Inbound bandwidth, OBW - Outbound bandwidth,
           MIBW - Max inbound bandwidth, MOBW - Max outbound bandwidth,
           HASH(SIP) - Hash address source IP,
           HASH(DIP) - Hash address destination IP,
           HASH(SIP-PORT) - Hash address source IP-port
DNS server pool    Predictor     Total    Active
dns-pool           RR            3        2
dns-pool1          RR            0        0
dns-pool2          RD            3        0
# Display detailed information about DNS server pool dns-pool.
<Sysname> display loadbalance dns-server-pool name dns-pool
Description:
Predictor: Round robin
Selected server: Enabled
Min servers: 3
  Max servers: 5
Probe information:
  Probe success criteria: At-least 2
  Probe method: t4
Total DNS servers: 3
Active DNS servers: 0
DNS server list:
Name        State         Address          port    Link        Weight   Priority
ds1         Active        10.150.100.100   0       link1       100      4
ds2         Probe-failed  20.150.100.100   5353    link2       100      4
ds3         Inactive      --               0       link3       100      4
Table 7 Command output
Predictor
Scheduling algorithm of the DNS server pool:
·     RR—Weighted round robin algorithm.
·     RD—Random algorithm.
·     BW—Bandwidth algorithm.
·     IBW—Inbound bandwidth algorithm.
·     OBW—Outbound bandwidth algorithm.
·     MBW—Maximum bandwidth algorithm.
·     MIBW—Maximum inbound bandwidth algorithm.
·     MOBW—Maximum outbound bandwidth algorithm.
·     HASH(SIP)—Hash algorithm based on source IP address.
·     HASH(DIP)—Hash algorithm based on destination IP address.
·     HASH(SIP-PORT)—Hash algorithm based on source IP address and port number.
DNS server pool
Total
Total number of DNS servers.
Active
Number of active DNS servers.
Description for the DNS server pool.
Selected server
State of DNS server limit to participate in scheduling: disabled or enabled. If the state is enabled, the following fields are displayed:
·     Min servers—Minimum number of DNS servers that can participate in scheduling.
·     Max servers—Maximum number of DNS servers that can participate in scheduling.
Probe information
Detailed health monitoring information for the DNS server pool.
Health monitoring success criteria for the DNS server pool:
Probe method
Total DNS servers
Active DNS servers
Name
DNS server name.
DNS server state:
·     Busy—The DNS server is busy. When the DNS server is in Active or Ramp state and enabled with link protection, this field displays Busy if the maximum expected bandwidth is reached.
Address
Port
Link
Name of the link corresponding to the DNS server.
Weight
Priority
Use display loadbalance isp to display ISP information.
display loadbalance isp [ ip ipv4-address | ipv6 ipv6-address | name isp-name ]
ip ipv4-address: Specifies an IPv4 address. If you do not specify this option, the command displays information about all ISPs.
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify this option, the command displays information about all ISPs.
name isp-name: Specifies an ISP by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all ISPs.
# Display information about all ISPs.
<Sysname> display loadbalance isp
(*) - User-defined object
Last successful auto update time: 04:09:00 UTC Fri 03/16/2012
Last auto update time: 04:09:00 UTC Fri 03/16/2012
Last auto update result: Successful
  ISP update count: 1
LB ISP: isp1
    Whois maintainer object name:
        MAINT-CHINANET
    Description: ISP1
    IPv4 address/Mask length: --
    IPv6 address/Prefix length: --
LB ISP: isp2(*)
    Description:
        1.2.3.0/32(*)           1.2.3.4/32              3.3.3.6/32(*)
        192.168.6.131/32(*)     192.168.195.189/32(*)
        1::2/128
        FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF/128(*)
# Display information about the ISP corresponding to the IP address 1.2.3.0.
<Sysname> display loadbalance isp ip 1.2.3.0
ISP name            Source                   IPv4 address/Mask length
isp2                user-set                 1.2.3.0/28
isp2                user-set                 1.2.3.0/29
isp2                user-set                 1.2.3.0/30
isp2                file-load                1.2.3.0/31
                    auto-update
isp2                user-set                 1.2.3.0/32
                    file-load
# Display information about the ISP corresponding to the IPv6 address 1::1234.
<Sysname> display loadbalance isp ipv6 1::1234
ISP name            Source                   IPv6 address/Prefix length
isp2                user-set                 1::1234/126
isp2                user-set                 1::1234/127
isp2                file-load                1::1234/128
Table 8 Command output
(*) indicates that the ISP information is manually configured. If the ISP information is also imported from a file, (*) is not displayed.
Time of the most recent successful update.
Time of the most recent update.
Result of the most recent auto update:
·     Successful.
·     Failed to connect to WHOIS server.
·     Connection failed.
·     Failed to query DNS (which means failed to send DNS requests).
ISP update count
Number of ISPs in the most recent update.
LB ISP
ISP name.
Description for the ISP.
Source
Source of the ISP:
·     user-set—Manually configured.
·     file-load—Imported from a file.
·     auto-update—ISP auto update.
Use display loadbalance link to display LB link information.
display loadbalance link [ brief | name link-name ]
brief: Displays brief information about all LB links. If you do not specify this keyword, the command displays detailed LB link information.
name link-name: Displays detailed information about the specified LB link. The link-name argument specifies an LB link name, a case-insensitive string of 1 to 63 characters.
If you do not specify the brief keyword or the name link-name option, the command displays detailed information about all LB links.
# Display brief information about all LB links.
<Sysname> display loadbalance link brief
Link         Router IP/Interface    State        VPN instance     Link group
Lk1          192.168.1.1            Busy         --               lg
Lk2          192.168.2.1            Active       --               lg
Lk3          Dialer0                Inactive     --               lg
# Display detailed information about the LB link lk.
<Sysname> display loadbalance link name lk
Link: lk
  Description: lk
  State: Busy
  VPN instance: --
  Inherit VPN: Disabled
  Router IP: 1.2.3.4
  Router IPv6: --
  Link-group: lg
  Weight: 100
  Priority: 4
  Cost: 0
  Slow-shutdown: Disabled
  Connection limit: 0
  Rate limit:
    Connections: 10000
    Bandwidth: 10000 Kbytes/s
    Inbound bandwidth: 5000 Kbytes/s
    Outbound bandwidth: 5000 Kbytes/s
Bandwidth busy:
    Max bandwidth: 10000 Kbytes/s
    Max inbound bandwidth: 5000 Kbytes/s
    Max outbound bandwidth: 5000 Kbytes/s
    Busy rate: 80
    Inbound busy rate: 70
    Outbound busy rate: 60
    Busy recovery rate: 60
    Inbound busy recovery rate: 60
    Outbound busy recovery rate: 60
Probe information:
    Probe method                    State
t4                              Inactive
Link: lk2
  Description: link2
  State: Inactive
  VPN instance: --
  IPv4 address state: Active
  IPv6 address state: Inactive
  Router interface: Dialer0
  Link group: lg
  Weight: 150
  Priority: 3
  Cost: 100
  Slow shutdown: Enabled
  Connection limit: 10000
  Rate limit:
    Connections: 10000
  Bandwidth busy:
    Busy rate: 80
Probe information:
  Probe method                    State
  t4                              Inactive
Table 9 Command output
Link
LB link name.
Router IP/Interface
Gateway IP address or outgoing interface of the LB link.
Parent state/State
LB link state:
·     Active—The LB link is available.
·     Busy—The LB link is busy.
·     Inactive—The LB link is unavailable, because the configuration is not complete, the LB link is not referenced, or the virtual server is not enabled.
·     Ramp—Ramp-up phase of slow online.
·     Shutdown—The LB link is shut down.
·     Standby—Standby phase of slow online.
VPN instance
This field is not supported in the current software version.VPN instance of the LB link and source of the VPN instance.
·     Config—Manually configured.
·     Inherit—Inherited.
Link group
Link group to which the LB link belongs.
Description for the LB link.
Inherit VPN
This field is not supported in the current software version.State of VPN instance inheritance: Enabled or Disabled.
IPv4 address state
IPv4 address state of the LB link:
·     Active—An available IPv4 address is obtained through the outgoing interface of the LB link.
·     Inactive—No available IPv4 address is obtained through the outgoing interface of the LB link.
This field is displayed only if an outgoing interface is specified for an LB link.
IPv6 address state
IPv6 address state of the link:
·     Active—An available IPv6 address is obtained through the outgoing interface of the LB link.
·     Inactive—No available IPv6 address is obtained through the outgoing interface of the LB link.
Weight
Weight of the LB link.
Priority
Priority of the LB link.
Cost
Cost for proximity calculation.
Slow shutdown
Slow offline state of the LB link:
·     Disabled.
·     Enabled.
Connection limit
Maximum number of connections for the LB link.
Connection rate limit
Maximum number of connections per second for the LB link.
Rate limit
Rate limit of the LB link.
Connections
Bandwidth
Maximum bandwidth for the LB link in KBps.
Inbound bandwidth
Maximum inbound bandwidth for the LB link in KBps.
Outbound bandwidth
Maximum outbound bandwidth for the LB link in KBps.
Bandwidth busy
Bandwidth ratio.
Max bandwidth
Maximum expected bandwidth for the LB link in KBps.
Maximum inbound expected bandwidth for the LB link in KBps.
Maximum outbound expected bandwidth for the LB link in KBps.
Busy rate
Bandwidth ratio for the LB link.
Inbound busy rate
Inbound bandwidth ratio for the LB link.
Outbound busy rate
Outbound bandwidth ratio for the LB link.
Busy recovery rate
Bandwidth recovery ratio for the LB link.
Inbound bandwidth recovery ratio for the LB link.
Outbound bandwidth recovery ratio for the LB link.
Probe information
Detailed health monitoring information for the LB link.
Health monitoring success criteria for the LB link:
Probe method
·     Invalid—Health monitoring is unavailable (because the configuration of the NQA template is not complete), or the link is unavailable.
Use display loadbalance link out-interface statistics to display link outbound interface statistics.
display loadbalance link out-interface statistics [ name link-name ]
name link-name: Specifies a link by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays outbound interface statistics for all links.
If the link outbound interface is a logical interface, the rate statistics are calculated based on the interface traffic.
# Display outbound interface statistics for the link lk1.
<Sysname> display loadbalance link out-interface statistics name lk1
Loadbalance link: lk1
Input rate: 1524 bytes/s
  Output rate: 90 bytes/s
Loadbalance link
LB link name.
Input rate
Input rate of the outbound interface in Bps.
Output rate
Output rate of the outbound interface in Bps.
Use display loadbalance link statistics to display link statistics.
display loadbalance link statistics [ name link-name ]
# Display statistics for the link lk1.
<Sysname> display loadbalance link statistics name lk1
  Total connections: 1798
  Active connections: 788
  Max connections: 803
  Connections per second: 157
  Max connections per second: 163
  Downstream traffic: 333332 bytes
  Upstream traffic: 472054 bytes
  Throughput: 4396 bytes/s
  Inbound throughput: 1214 bytes/s
  Outbound throughput: 3128 bytes/s
  Max throughput: 4564 bytes/s
  Max inbound throughput: 1214 bytes/s
  Max outbound throughput: 3320 bytes/s
  Received packets: 1798
  Sent packets: 0
  Dropped packets: 0
Table 10 Command output
Loadbalance link
Link name.
Total connections
Total number of connections.
Active connections
Number of active connections.
Max connections
Maximum number of connections.
Number of connections per second.
Maximum number of connections per second.
Downstream traffic
Downstream traffic (in bytes) received by the LB device.
Upstream traffic
Upstream traffic (in bytes) sent by the LB device.
Throughput
Total packet throughput in Bps.
Inbound throughput
Inbound packet throughput in Bps.
Outbound throughput
Outbound packet throughput in Bps.
Max throughput
Maximum packet throughput in Bps.
Maximum inbound packet throughput in Bps.
Maximum outbound packet throughput in Bps.
Received packets
Number of received packets.
Sent packets
Number of sent packets.
Dropped packets
Number of dropped packets.
Use display loadbalance link-group to display link group information.
display loadbalance link-group [ brief | name link-group-name ]
brief: Displays brief information about all link groups. If you do not specify this keyword, the command displays detailed link group information.
name link-group-name: Specifies a link group by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all link groups.
If you do not specify any parameters, the command displays detailed information about all link groups.
A link is displayed as unavailable if the link group configuration is not complete, the link group is not referenced, or the virtual server is not enabled. This does not mean that the link is not available.
# Display brief information about all link groups.
<Sysname> display loadbalance link-group brief
Predictor: RR - Round robin, RD - Random, LC - Least connection,
           BW – Bandwidth, MBW – Max bandwidth,
           IBW – Inbound bandwidth, OBW – Outbound bandwidth,
           MIBW – Max inbound bandwidth, MOBW – Max outbound bandwidth,
NAT/SNAT: Y - Enabled, N - Disabled
Link group       Predictor    NAT   SNAT  Total  Active
lg               RR           Y     N     3      3
# Display detailed information about all link groups.
Link group: lg1
  Description:
  Predictor: Hash address
  Proximity: Disabled
  NAT: Enabled
  SNAT pool:
  Failed action: Keep
  Active threshold: Enabled
    Lower: 80
    Upper: 90
  Slow-online: Enabled
  Standby time: 5s
  Ramp-up time: 10s
  Selected link: Enabled
    Min link: 100
    Max link: 600
  Probe information:
    Probe method:
    aaa
    ddd
  Total link: 1
  Active link: 1
  Link list:
  Name             State         VPN instance    Router IP    Weight    Priority
  Link1            Inactive      --              1.2.3.4      4         100
Table 11 Command output
Link group
Link group name.
Description for the link group.
Predictor
Scheduling algorithm of the link group:
·     LC—Weighted least connection algorithm.
Proximity
Proximity state of the link group:
·     Disabled.
·     Enabled.
NAT
NAT state of the link group:
·     Disabled.
·     Enabled.
SNAT pool
Name of the SNAT address pool referenced by the link group.
Failed action
Fault processing method of the link group:
·     Keep—Keeps existing connections.
·     Reschedule—Redirects connections.
·     Reset—Terminates existing connections.
Active threshold
State of the criteria to determine that the link group is available: disabled or enabled. If the state is enabled, the following fields are displayed:
·     Lower—Lower percentage value.
·     Upper—Upper percentage value.
Slow-online
State of the slow online feature: disabled or enabled. If the state is enabled, the following fields are displayed:
·     Standby time.
·     Ramp-up time.
Selected link
State of link limit to participate in scheduling: disabled or enabled. If the state is enabled, the following fields are displayed:
·     Min server—Minimum number of links that participate in scheduling.
·     Max server—Maximum number of links that participate in scheduling.
Health monitoring success criteria for the link group:
·     At least X—Health monitoring succeeds when a minimum of X health monitoring methods succeed.
Probe method
Total link
Total number of links.
Active link
Number of active links.
Name
Link name.
Link state:
·     Active—The link is available.
·     Busy—The link is busy. When the link is in Active or Ramp state and enabled with bandwidth statistics collection and link protection, this field displays Busy if the maximum expected bandwidth is reached.
·     Inactive—The link is unavailable, because the configuration is not complete, the link is not referenced, or the virtual server is not enabled.
·     Shutdown—The link is shut down.
VPN instance
This field is not supported in the current software version.VPN instance of the link.
Router IP
IPv4 and IPv6 addresses of the link.
Weight
Weight of the link.
Priority
Priority of the link.
Use display loadbalance policy to display LB policy information.
display loadbalance policy [ name policy-name ]
name policy-name: Specifies an LB policy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all LB policies.
# Display information about all LB policies.
<Sysname> display loadbalance policy
LB policy: lbp3
  Description:
  Type: Link-generic
  Class: lbc3
  Action: lba3
  Default class action: lba3
LB policy: lbp4
  Description:
  Type: DNS
  Class: lbc4
  Action: lba4
  Default class action: lba4
Table 12 Command output
LB policy
LB policy name.
Description for the LB policy.
LB policy type:
·     DNS.
·     Link-generic.
Class
LB class for the LB policy.
Action
LB action for the LB class.
Default LB action.
Use display loadbalance proximity to display proximity entry information.
display loadbalance proximity [ ip [ ipv4-address ] | ipv6 [ ipv6-address ] ]
ip [ ipv4-address ]: Displays IPv4 proximity entry information. If you specify the ipv4-address argument, this command displays detailed information about the proximity entry corresponding to the IPv4 address. If you do not specify the ipv4-address argument, this command displays brief information about all IPv4 proximity entries.
ipv6 [ ipv6-address ]: Displays IPv6 proximity entry information. If you specify the ipv6-address argument, this command displays detailed information about the proximity entry corresponding to the IPv6 address. If you do not specify the ipv6-address argument, this command displays brief information about all IPv6 proximity entries.
If you do not specify the ip or ipv6 keyword, this command displays brief information about all IPv4 and IPv6 proximity entries.
# Display brief information about all IPv4 and IPv6 proximity entries for the public network.
<Sysname> display loadbalance proximity
(*) – Real server object
Slot :1
  IPv4 address/Mask length       Timeout     Best link
  1.2.3.0/24                     59          lk1
  1.2.15.0/24                    58          lk2
  IPv6 address/Prefix length     Timeout     Best link
  11:22::/96                     40          lk1
# Display detailed information about the proximity entry corresponding to the IP address 1.2.3.1 for the public network.
<Sysname> display loadbalance proximity ip 1.2.3.1
IPv4 address/Mask length: 1.2.3.0/24
Timeout: 40
Link list:
  lk1
  lk2
Table 13 Command output
This field is not supported in the current software version.The link corresponds to a real server object.
Slot
Card for which proximity entry information is displayed.
Timeout
Remaining time of the proximity entries, in seconds.
Link list
Links for the proximity entry. They are listed in descending priority order.
Use display loadbalance snat-pool to display SNAT address pool information.
display loadbalance snat-pool [ name pool-name ]
name pool-name: Specifies an SNAT address pool by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all SNAT address pools.
# Display information about all SNAT address pools.
<Sysname> display loadbalance snat-pool
SNAT pool: lbsp1
  Description:
  IPv4 range:
    Start address                       End address
    202.110.10.10                       202.110.10.15
  IPv6 range:
    2002::2                             2002::100
  ARP/ND interfaces:
    GigabitEthernet1/0/1
    GigabitEthernet1/0/3
SNAT pool: lbsp2
  Description:
  IPv4 range:
    203.110.10.10                       203.110.10.15
  IPv6 range:
    2003::2                             2003::100
  ARP/ND interfaces:
    GigabitEthernet1/0/2
Table 14 Command output
SNAT pool
SNAT address pool name.
Description for the SNAT address pool.
IPv4 range
IPv4 address range.
IPv6 range
IPv6 address range.
ARP/ND interfaces
Interfaces from which gratuitous ARP packets and ND packets are sent out.
Use display parameter-profile to display parameter profile information.
display parameter-profile [ name parameter-name ]
name parameter-name: Specifies a parameter profile by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all parameter profiles.
# Display information about all parameter profiles.
<Sysname> display parameter-profile
Parameter profile: pp1
  Description:
  Type: IP
  IP ToS: 20
Table 15 Command output
Parameter profile
Parameter profile name.
Description for the parameter profile.
Parameter profile type:
IP.
IP ToS
ToS field of the IP packets sent to the server.
display sticky
Use display sticky to display sticky entry information.
display sticky { dns-proxy [ dns-proxy-name ] | virtual-server [ virtual-server-name ] } [ class class-name | default-class | default-dns-server-pool | default-link-group ]
dns-proxy dns-proxy-name: Specifies a transparent DNS proxy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays sticky entry information for all transparent DNS proxies.
virtual-server virtual-server-name: Specifies a virtual server by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays sticky entry information for all virtual servers.
class class-name: Specifies an LB class by its name, a case-insensitive string of 1 to 63 characters.
default-class: Specifies the default LB action.
default-dns-server-pool: Specifies the default DNS server pool.
default-link-group: Specifies the default link group.
# Display sticky entry information for all virtual services.
<Sysname> display sticky virtual-server
Virtual server name: vs4
  Sticky zone type: Default link group
  Class name:
  Sticky group name: sg3
  Sticky method: Both IP and port
  Timeout: 60
Sticky entry                      Link                  Expired time Count
192.168.6.206/2606                Dialer0               57           0
192.168.6.40/80
192.168.6.206/2605                192.168.6.206/0       55           0
192.168.6.40/80
# Display sticky entry information for all transparent DNS proxies.
<Sysname> display sticky dns-proxy
DNS proxy name: dns-proxy1
  Sticky zone type: Default DNS server pool
  Sticky group name: st
  Sticky method: Source IP
  Timeout: 60
Sticky entry               DNS server           Expired time   Count
192.168.6.206/2606         192.168.6.206/0      57             0
DNS proxy name: dns-proxy3
  Sticky zone type: Default class
  Timeout: 60
Table 16 Command output
Sticky zone type
Sticky entry source:
·     Class—Generated by the class and action in the policy referenced by the virtual service.
·     Default class—Generated by the default action in the policy referenced by the virtual service.
·     Default DNS server pool—Generated by the default DNS server pool of the transparent DNS proxy.
·     Default link group—Generated by the default primary or backup link group of the virtual service.
Class name
LB class name. The LB class name is displayed only when the sticky entries are generated by the class and action.
Sticky group name
Name of the sticky group that generates the sticky entries.
Sticky method
Sticky method corresponding to the sticky entries:
·     Source IP—Source IPv4 address sticky method.
·     Source IPv6—Source IPv6 address sticky method.
·     Source IP and port—Source IPv4 address + source port sticky method.
·     Source IPv6 and port—Source IPv6 address + source port sticky method.
·     Destination IP—Destination IPv4 address sticky method.
·     Destination IPv6—Destination IPv6 address sticky method.
·     Destination IP and port—Destination IPv4 address + destination port sticky method.
·     Destination IPv6 and port—Destination IPv6 address + destination port sticky method.
·     Both IP—Source IPv4 address + destination IPv4 address sticky method.
·     Both IPv6—Source IPv6 address + destination IPv6 address sticky method.
·     Both IP and port—Source IPv4 address + source port + destination IPv4 address + destination port sticky method.
·     Both IPv6 and port—Source IPv6 address + source port + destination IPv6 address + destination port sticky method.
Timeout
Timeout time of the sticky entries, in seconds.
Sticky entry
Key value corresponding to the sticky entry.
DNS server
IP address and port number of the DNS server.
Link
Outbound next hop IP address and port number of the link or outgoing interface of the link.
Expired time
Remaining lifetime of the sticky entry. If the reference count is not 0, the configured value is displayed.
Count
Reference count of the sticky entry.
Use display sticky-group to display sticky group information.
display sticky-group [ name group-name ]
name group-name: Specifies a sticky group by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all sticky groups.
# Display information about all sticky groups.
<Sysname> display sticky-group
Sticky group: sg1
  Description:
  Timeout: 60
  Override limit: Disabled
  Stickiness-over-busyness: Enabled
  Sticky group type: Address-port
    Method: Both IP and port
      Mask: 32
Table 17 Command output
Sticky group
Sticky group name.
Description for the sticky group.
Timeout
Timeout time for sticky entries in seconds.
Override limit
Whether the feature of ignoring the limits for sessions that match sticky entries is enabled: Enabled or Disabled.
Whether the stickiness-over-busyness feature is enabled: Enabled or Disabled.
Sticky group type
Sticky group type:
Address-port—Address and port.
Table 18 Detailed information for sticky groups
Sticky group type
Address-port
Method
Sticky method:
Mask
Mask length for the sticky method. This field is displayed only for IPv4 sticky methods.
Prefix
Prefix length for the sticky method. This field is displayed only for IPv6 sticky methods.
Use display virtual-server to display virtual server information.
display virtual-server [ brief | name virtual-server-name ]
brief: Displays brief virtual server information. If you do not specify this keyword, the command displays detailed virtual server information.
name virtual-server-name: Displays information about the specified virtual server. The virtual-server-name argument specifies a virtual server name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about all virtual servers.
# Display brief information about all virtual servers.
<Sysname> display virtual-server brief
Virtual server   State    Type      VPN instance     Virtual address     Port
vs3              Active   LINK-IP                    51.139.4.100/32     0
# Display detailed information about the virtual server lk.
<Sysname> display virtual-server name lk
Virtual server: lk
  Description:
  Type: Link-IP
  State: Active
  VPN instance: --
  Virtual IPv4 address: 1.1.1.1/32
  Virtual IPv6 address: 1001::1/128
  Port: 0
  Primary link group: lg1 (in use)
  Sticky: sg3
  LB policy: lbp2
  LB limit-policy:
  Rate limit:
    Connections: 10000
  Connection synchronization: Disabled
  Sticky synchronization: Disabled
  Interface bandwidth statistics: Disabled
  Route advertisement: Disabled
  ARP/ND interfaces:
Table 19 Command output
Virtual server
Virtual server name.
Virtual server state:
·     Active—The virtual server is available.
·     Inactive—The virtual server is unavailable.
·     Inactive (disabled)—The virtual server is unavailable because the virtual server is disabled.
Virtual server type: Link-IP.
VPN instance
This field is not supported in the current software version.Name of the VPN instance to which the virtual server belongs.
Virtual address
IPv4 address and mask of the virtual server.
Port
Port number of the virtual server. 0 means any port.
Description of the virtual server.
IPv6 address and prefix of the virtual server.
Primary link group
Default primary link group name. (in use) indicates the link group is in use.
Backup link group
Default backup link group name. (in use) indicates the link group is in use.
Sticky
Default sticky group name.
LB policy
LB policy referenced by the virtual server.
IP parameter profile
IP parameter profile referenced by the virtual server. This field is displayed only if an IP parameter profile is configured.
Connection limit
Maximum number of connections of the virtual server.
Rate limit
Rate limit of the virtual server.
Connections
Maximum number of connections per second of the virtual server.
Bandwidth
Maximum bandwidth for the virtual server in KBps.
Inbound bandwidth
Maximum inbound bandwidth for the virtual server in KBps.
Outbound bandwidth
Maximum outbound bandwidth for the virtual server in KBps.
Use display virtual-server statistics to display virtual server statistics.
display virtual-server statistics [ name virtual-server-name ]
name virtual-server-name: Specifies a virtual server by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays statistics of all virtual servers.
# Display statistics for the virtual server vs.
<Sysname> display virtual-server statistics name vs
Virtual server: vs
  Total connections: 979
  Active connections: 618
  Max connections: 661
  Connections per second: 146
  Max connections per second: 156
  Client input: 333332 bytes
  Client output: 472054 bytes
  Throughput: 4088 bytes/s
  Outbound throughput: 2874 bytes/s
  Max throughput: 4368 bytes/s
  Max outbound throughput: 3154 bytes/s
  Received packets: 979
  Sent packets: 0
  Dropped packets: 0
  Received requests: 0
Table 20 Command output
Virtual server
Total connections
Active connections
Max connections
Client input
Traffic (in bytes) received from the client.
Client output
Traffic (in bytes) sent to the client.
Throughput
Inbound throughput
Outbound throughput
Max throughput
Max throughput
Max throughput
Received packets
Sent packets
Number of packets sent by the virtual server to the client.
Dropped packets
dns-server-pool (LB action view)
Use dns-server-pool to specify a DNS server pool for guiding packet forwarding.
Use undo dns-server-pool to restore the default.
No DNS server pool is specified for guiding packet forwarding.
DNS LB action view
pool-name: Specifies a DNS server pool by its name, a case-insensitive string of 1 to 63 characters.
This command is mutually exclusive with the forward all or skip current-dns-proxy command. If you configure one command, the other command (if configured) is automatically cancelled.
# Specify the DNS server pool dsp and the sticky group sg1 for DNS LB action lba1.
[Sysname-lba-dns-lba1] dns-server-pool dsp sticky st1
forward all
dns-server-pool (DNS server view)
Use dns-server-pool to specify a DNS server pool for a DNS server.
A DNS server does not belong to any DNS server pool.
DNS server view
You can specify a DNS server pool that has not been created.
# Specify DNS server pool dns-pool1 for DNS server ds1.
[Sysname-lb-ds-ds1] dns-server-pool dns-pool1
fail-action (link group view)
Use fail-action to specify the fault processing method for a link group.
Use undo fail-action to restore the default.
fail-action { keep | reschedule | reset }
undo fail-action
The fault processing method is to keep existing connections.
Link group view
keep: Keeps the connection with the failed link. Keeping or terminating the connection depends on the timeout mechanism of the protocol.
reschedule: Redirects the connection to another available link in the link group.
reset: Terminates the connection with the failed link by sending RST packets (for TCP packets) or ICMP unreachable packets (for other types of packets).
The fault processing method applies when the link that processes packets fails.
# Specify the fault processing method for the link group lg as reschedule.
[Sysname-lb-lgroup-lg] fail-action reschedule
fallback-action continue
Use fallback-action continue to match the next rule upon failure to find an available server.
Use undo fallback-action continue to restore the default.
The next rule is not matched when no servers are available for the current LB action.
LB action view
This command enables packets to match the next rule in an LB policy when no servers are available for the current LB action.
# Match the next rule upon failure to find a DNS server for the DNS LB action a2.
[Sysname] loadbalance action a2 type dns
[Sysname-lba-dns-a2] fallback-action continue
forward all
Use forward all to configure the packet forwarding mode.
Use undo forward to restore the default.
forward all
undo forward
The packet forwarding mode is to discard packets.
DNS/Link-generic LB action view
In DNS LB action view, this command is mutually exclusive with the dns-server-pool or skip current-dns-proxy command. In link-generic LB action view, the forward all and link-group commands are mutually exclusive. If you configure one command, the other command (if configured) is automatically cancelled.
# Configure the packet forwarding mode for the DNS LB action lba1.
[Sysname-lba-dns-lba1] forward all
dns-server-pool
link-group (LB action view)
frequency
Use frequency to set the probe interval for a load balancing probe template.
Use undo frequency to restore the default.
frequency interval
undo frequency
The probe interval is 300 seconds.
Load balancing probe template view
interval: Specifies the probe interval in the range of 1 to 604800 seconds.
This command specifies the interval for sending probe packets.
# Set the probe interval to 3600 seconds for ICMP probe template icmptplt.
[Sysname] loadbalance probe-template icmp icmptplt
[Sysname-lb-pt-icmp-icmptplt] frequency 3600
ip
Use ip to configure the IPv4 sticky method.
Use undo ip to restore the default.
ip [ port ] { both | destination | source } [ mask mask-length ]
undo ip
No IPv4 sticky method is configured.
Sticky group view
port: Specifies the sticky method as IPv4 address + port number. If you do not specify this keyword, the sticky method is IPv4 address.
both: Specifies the sticky method as source IPv4 address + destination IPv4 address (if you do not specify the port keyword), or source IPv4 address + source port number + destination IPv4 address + destination port number (if you specify the port keyword).
destination: Specifies the sticky method as destination IPv4 address if you do not specify the port keyword, or destination IPv4 address + destination port number if you specify the port keyword.
source: Specifies the sticky method as source IPv4 address if you do not specify the port keyword, or source IPv4 address + source port number if you specify the port keyword.
mask mask-length: Specifies the mask length for the sticky method.
# Configure the sticky method for the address and port-based sticky group sg1 as source IPv4 address.
[Sysname] sticky-group sg1 type address-port
[Sysname-sticky-address-port-sg1] ip source
# Configure the sticky method for the address and port-based sticky group sg1 as source IPv4 address + source port number.
[Sysname-sticky-address-port-sg1] ip port source
sticky-group
ip address (transparent DNS proxy view)
Use ip address to specify an IPv4 address for a transparent DNS proxy.
Use undo ip address to restore the default.
ip address ipv4-address [ mask-length | mask ]
undo ip address
No IPv4 address is specified for a transparent DNS proxy.
ipv4-address: Specifies an IPv4 address, which cannot be a loopback address, multicast address, broadcast address, or an address in the format of 0.X.X.X.
mask-length: Specifies a mask length in the range of 0 to 32.
mask: Specifies a subnet mask.
A transparent DNS proxy processes a DNS request only when the destination IP address and port number of the DNS request match those of the transparent DNS proxy.
If server load balancing is configured, configure different IP addresses and port numbers for the transparent DNS proxy and the virtual server of the UDP type.
# Specify the IPv4 address for transparent DNS proxy dns-proxy1 as 1.2.3.4/24.
[Sysname] loadbalance dns-proxy dns_proxy1
[Sysname-lb-dp-udp-dns-proxy1] ip address 1.2.3.4 24
ip address (DNS server view)
Use ip address to specify an IPv4 address for a DNS server.
undo ip address
No IPv4 address is specified for a DNS server.
DNS server view
# Specify the IPv4 address for DNS server ds1 as 1.2.3.4.
[Sysname] loadbalance dns-server ds1
[Sysname-lb-ds-ds1] ip address 1.2.3.4
ip address (ISP view)
Use ip address to configure an IPv4 address for an ISP.
ip address ipv4-address { mask-length | mask }
undo ip address ipv4-address { mask-length | mask }
No IPv4 address is configured for an ISP.
ISP view
mask-length: Specifies the mask length for the IPv4 address, in the range of 0 to 32.
mask: Specifies the mask for the IPv4 address.
# Configure the IPv4 address for the ISP isp1 as 1.1.1.1.
[Sysname] loadbalance isp name isp1
[Sysname-lbisp-isp1] ip address 1.1.1.1 24
ip mask
Use ip mask to set the mask length for IPv4 proximity entries.
Use undo ip mask to restore the default.
ip mask { mask-length | mask }
undo ip mask
The mask length for IPv4 proximity entries is 24.
Proximity view
mask-length: Specifies the mask length for IPv4 proximity entries, in the range of 0 to 32. A value of 0 indicates the natural mask.
mask: Specifies the mask for IPv4 proximity entries.
# Set the mask length for IPv4 proximity entries to 30.
[Sysname-lb-proximity] ip mask 30
ip range (SNAT address pool view)
Use ip range to specify an IPv4 address range for an SNAT address pool.
Use undo ip range to restore the default.
ip range start start-ipv4-address end end-ipv4-address
undo ip range
No IPv4 address range is specified for an SNAT address pool.
start start-ipv4-address: Specifies the start IPv4 address.
end end-ipv4-address: Specifies the end IPv4 address, which must be greater than or equal to the start IPv4 address.
An SNAT address pool can have a maximum of 256 IPv4 addresses. No overlapping IPv4 addresses are allowed in different SNAT address pools.
# Specify IPv4 address range 1.1.1.1 to 1.1.1.100 for the SNAT address pool lbsp.
[Sysname] loadbalance snat-pool lbsp
[Sysname-lbsnat-pool-lbsp] ip range start 1.1.1.1 end 1.1.1.100
ipv6
Use ipv6 to configure the IPv6 sticky method.
Use undo ipv6 to restore the default.
ipv6 [ port ] { both | destination | source } [ prefix prefix-length ]
undo ipv6
No IPv6 sticky method is configured.
Sticky group view
port: Specifies the sticky method as IPv6 address + port number. If you do not specify this keyword, the sticky method is IPv6 address.
both: Specifies the sticky method as source IPv6 address + destination IPv6 address if you do not specify the port keyword, or source IPv6 address + source port number + destination IPv6 address + destination port number if you specify the port keyword.
destination: Specifies the sticky method as destination IPv6 address if you do not specify the port keyword, or destination IPv6 address + destination port number if you specify the port keyword.
source: Specifies the sticky method as source IPv6 address if you do not specify the port keyword, or source IPv6 address + source port number if you specify the port keyword.
prefix prefix-length: Specifies the prefix length for the sticky method.
# Configure the sticky method for the address- and port-based sticky group sg1 as source IPv6 address.
[Sysname-sticky-address-port-sg1] ipv6 source
# Configure the sticky method for the address- and port-based sticky group sg1 as source IPv6 address + source port number.
[Sysname-sticky-address-port-sg1] ipv6 port source
sticky-group
ipv6 address (transparent DNS proxy view)
Use ipv6 address to configure an IPv6 address for a transparent DNS proxy.
Use undo ipv6 address to restore the default.
ipv6 address ipv6-address [ prefix-length ]
undo ipv6 address
No IPv6 address is configured for a transparent DNS proxy.
Transparent DNS proxy view
ipv6-address: Specifies an IPv6 address, which cannot be a loopback address, IPv6 multicast address, link-local address, or all-zero address (If the prefix length is 0, you can specify the all-zero address.).
prefix-length: Specifies a prefix length for the IPv6 address, in the range of 0 to 128.
# Configure the IPv6 address for transparent DNS proxy dns-proxy1 as 1::2:3/112.
[Sysname] loadbalance dns-proxy dns-proxy1
[Sysname-lb-dp-udp-dns-proxy1] ipv6 address 1::2:3 112
ipv6 address (DNS server view)
Use ipv6 address to configure an IPv6 address for a DNS server.
undo ipv6 address
No IPv6 address is configured for a DNS server.
DNS server view
ipv6-address: Specifies an IPv6 address, which cannot be a loopback address, IPv6 multicast address, link-local address, or all-zero address.
# Configure the IPv6 address for DNS server ds1 as 1001::1.
[Sysname-lb-ds-ds1] ipv6 address 1001::1
ipv6 address (ISP view)
Use ipv6 address to configure an IPv6 address for an ISP.
ipv6 address ipv6-address prefix-length
undo ipv6 address ipv6-address prefix-length
No IPv6 address is configured for an ISP.
ISP view
prefix-length: Specifies the prefix length for the IPv6 address, in the range of 1 to 128.
# Configure the IPv6 address for the ISP isp1 as 200::1.
[Sysname-lbisp-isp1] ipv6 address 200::1 100
ipv6 prefix
Use ipv6 prefix to configure the prefix length for IPv6 proximity entries.
Use undo ipv6 prefix to restore the default.
ipv6 prefix prefix-length
undo ipv6 prefix
The prefix length for IPv6 proximity entries is 96.
Proximity view
prefix-length: Specifies the prefix length for IPv6 proximity entries, in the range of 1 to 128.
# Specify the prefix length for IPv6 proximity entries as 64.
[Sysname] loadbalance proximity
[Sysname-lb-proximity] ipv6 prefix 64
ipv6 range
Use ip range to specify an IPv6 address range for an SNAT address pool.
ipv6 range start start-ipv6-address end end-ipv6-address
undo ipv6 range
No IPv6 address range is specified for an SNAT address pool.
start start-ipv6-address: Specifies the start IPv6 address.
end end-ipv6-address: Specifies the end IPv6 address, which must be greater than or equal to the start IPv6 address.
An SNAT address pool can have a maximum of 65536 IPv6 addresses. No overlapping IPv6 addresses are allowed in different SNAT address pools.
# Specify IPv6 address range 1001::1 to 1001::100 for the SNAT address pool lbsp.
[Sysname-lbsnat-pool-lbsp] ipv6 range start 1001::1 end 1001::100
isp
Use isp to add an ISP to a region.
Use undo isp to delete an ISP from a region.
isp isp-name
undo isp isp-name
A region does not contain any ISPs.
Region view
# Add the ISP isp-ct to the region region-ct.
[Sysname] loadbalance region region-ct
[Sysname-lb-region-region-ct] isp isp-ct
loadbalance region
lb-policy (transparent DNS proxy view)
Use lb-policy to specify an LB policy to be referenced by a transparent DNS proxy.
Use undo lb-policy to restore the default.
lb-policy policy-name
undo lb-policy
No LB policy is referenced by a transparent DNS proxy.
By referencing an LB policy, a transparent DNS proxy implements load balancing for matching packets based on the packet contents.
A transparent DNS proxy can reference only a DNS policy template.
# Specify the LB policy dns-policy1 to be referenced by transparent DNS proxy dns-proxy1.
[Sysname-lb-dp-udp-dns-proxy1] lb-policy dns-policy1
lb-policy (virtual server view)
Use lb-policy to specify an LB policy to be referenced by the specified virtual server.
undo lb-policy
No LB policy is referenced by a virtual server.
Virtual server view
By referencing an LB policy, the virtual server implements load balancing for matching packets based on the packet contents.
# Specify the LB policy lbp1 to be referenced by the IP-type virtual server vs3.
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] lb-policy lbp1
link (DNS server view)
Use link to associate a link with a DNS server.
Use undo link to restore the default.
link link-name
undo link
No link is associated with a DNS server.
DNS server view
A DNS server can be associated with only one link. A link can be associated with multiple DNS servers.
# Associate link link1 with DNS server ds1.
[Sysname-lb-ds-ds1] link link1
Use link-group to specify the primary link group.
Use undo link-group to restore the default.
link-group link-group-name [ backup backup-link-group-name ] [ sticky sticky-name ]
undo link-group
No primary link group is specified.
LB action view
link-group-name: Specifies a primary link group name, a case-insensitive string of 1 to 63 characters.
backup backup-link-group-name: Specifies a backup link group name, a case-insensitive string of 1 to 63 characters.
sticky sticky-name: Specifies the name of the sticky group corresponding to the link group. It is a case-insensitive string of 1 to 63 characters.
The link-group and forward all commands are mutually exclusive. If you configure one command, the other command (if configured) is automatically cancelled.
When the primary link group is available (contains links), packets are forwarded through the primary link group. When the primary link group is not available, packets are forwarded through the backup link group.
# Specify the primary link group lg, the backup link group lgb, and the sticky group sg1 for the link-generic LB action lba1.
[Sysname] loadbalance action lba1 type link-generic
[Sysname-lba-link-generic-lba1] server-farm sf backup sfb sticky sg1
forward all
link-group (link view)
Use link-group to specify a link group for a link.
undo link-group
A link does not belong to any link group.
Link view
link-group-name: Specifies a link group name, a case-insensitive string of 1 to 63 characters.
The device selects the best link from the matching link group to perform link load balancing.
# Specify the link group lkg1 for the link lk1.
[Sysname] loadbalance link lk1
[Sysname-lb-link-lk1] link-group lkg1
loadbalance action
Use loadbalance action to create an LB action and enter its view, or enter the view of an existing LB action.
Use undo loadbalance action to delete the specified LB action.
loadbalance action action-name [ type { dns | link-generic } ]
undo loadbalance action action-name
No LB actions exist.
action-name: Specifies the LB action name, a case-insensitive string of 1 to 63 characters.
type { dns | link-generic }: Specifies an LB action type.
·     dns: DNS load balancing action.
·     link-generic: Link load balancing action.
When you create an LB action, you must specify the LB action type. You can enter an existing LB action view without entering the type of the LB action.
# Create the LB action lba1 with the DNS type, and enter LB action view.
[Sysname] loadbalance action lba1 type dns
loadbalance alg
Use loadbalance alg to enable ALG for the specified protocols.
Use undo loadbalance alg to disable ALG for the specified protocols.
loadbalance alg { dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
undo loadbalance alg { dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
ALG is enabled for the DNS, FTP, PPTP, and RTSP protocols and ICMP error packets.
dns: Specifies the DNS protocol.
ftp: Specifies the FTP protocol.
h323: Specifies the H.323 protocol.
icmp-error: Specifies the ICMP error packets.
ils: Specifies the Internet Locator Service (ILS) protocol.
mgcp: Specifies the Media Gateway Control Protocol (MGCP).
nbt: Specifies the NetBIOS over TCP/IP (NBT) protocol.
pptp: Specifies the Point-to-Point Tunneling Protocol (PPTP).
rsh: Specifies the Remote Shell (RSH) protocol.
rtsp: Specifies the Real Time Streaming Protocol (RTSP).
sccp: Specifies the Skinny Client Control Protocol (SCCP).
sip: Specifies the Session Initiation Protocol (SIP).
sqlnet: Specifies the SQLNET protocol.
tftp: Specifies the TFTP protocol.
xdmcp: Specifies the X Display Manager Control Protocol (XDMCP).
The ALG feature distributes parent and child sessions to the same link.
# Enable ALG for TFTP.
[Sysname] loadbalance alg tftp
loadbalance alg all-enable
Use loadbalance alg all-enable to enable ALG for all protocols.
Use loadbalance alg all-disable to disable ALG for all protocols.
# Enable ALG for all protocols.
[Sysname] loadbalance alg all-enable
loadbalance class
Use loadbalance class to create an LB class and enter its view, or enter the view of an existing LB class.
Use undo loadbalance class to delete the specified LB class.
loadbalance class class-name [ type { dns| link-generic } [ match-all | match-any ] ]
undo loadbalance class class-name
No LB classes exist.
class-name: Specifies the LB class name, a case-insensitive string of 1 to 63 characters.
[ match-all | match-any ]: Requires matching all rules or any rule of the LB class. match-all is the default match mode.
When you create an LB class, you must specify an LB class type. You can enter an existing LB class view without entering the type of the LB class.
# Create the LB class lbc1 with the DNS type, and enter LB class view.
[Sysname] loadbalance class lbc1 type dns
[Sysname-lbc-dns-lbc1]
Use loadbalance dns-proxy to create a transparent DNS proxy and enter its view, or enter the view of an existing transparent DNS proxy.
Use undo loadbalance dns-proxy to delete a transparent DNS proxy.
loadbalance dns-proxy dns-proxy-name type udp
undo loadbalance dns-proxy dns-proxy-name
No transparent DNS proxies exist.
dns-proxy-name: Specifies the transparent DNS proxy name, a case-insensitive string of 1 to 63 characters.
type udp: Specifies the transparent DNS proxy type as UDP.
# Create the UDP transparent DNS proxy dns-proxy1, and enter UDP transparent DNS proxy view.
[Sysname] loadbalance dns-proxy dns-proxy1 type udp
Use loadbalance dns-server to create a DNS server and enter its view, or enter the view of an existing DNS server.
Use undo loadbalance dns-server to delete a DNS server.
loadbalance dns-server dns-server-name
undo loadbalance dns-server dns-server-name
No DNS servers exist.
dns-server-name: Specifies the DNS server name, a case-insensitive string of 1 to 63 characters.
# Create the DNS server ds1, and enter DNS server view.
[Sysname-lb-ds-ds1]
Use loadbalance dns-server-pool to create a DNS server pool and enter its view, or enter the view of an existing DNS server pool.
Use undo loadbalance dns-server-pool to delete a DNS server pool.
loadbalance dns-server-pool pool-name
undo loadbalance dns-server-pool pool-name
No DNS server pools exist.
pool-name: Specifies the DNS server pool name, a case-insensitive string of 1 to 63 characters.
# Create the DNS server pool dns-pool1, and enter DNS server pool view.
[Sysname] loadbalance dns-server-pool dns-pool1
[Sysname-lb-dspool-dns-pool1]
loadbalance isp file
Use loadbalance isp file to import an ISP file.
Use undo loadbalance isp file to delete an ISP file.
loadbalance isp file isp-file-name
isp-file-name: Specifies the ISP file name, a case-insensitive string of 1 to 255 characters.
The system keeps the imported information intact when detecting the following problems:
·     The file does not exist.
·     The file name is invalid.
·     File decryption occurs.
If the system quits the import operation because of IP address parsing failure, the system performs the following operations:
·     Clears the most recently imported information.
·     Saves the information imported this time.
You cannot delete the imported ISP and its IPv4 or IPv6 address. If the manually configured and imported ISP information overlaps, you can delete the manually configured ISP information.
To perform an active/standby MPU switchover, make sure the standby MPU has the same ISP file as the active MPU.
# Import the ISP file isp2.
[Sysname] loadbalance isp file isp2
Use loadbalance isp name to create an ISP and enter its view, or enter the view of an existing ISP.
Use undo loadbalance isp name to delete the specified ISP.
loadbalance isp name isp-name
undo loadbalance isp name isp-name
No ISPs exist.
isp-name: Specifies the ISP name, a case-insensitive string of 1 to 63 characters.
# Create ISP isp1, and enter ISP view.
loadbalance link
Use loadbalance link to create an LB link and enter its view, or enter the view of an existing LB link.
Use undo loadbalance link to delete an LB link.
loadbalance link link-name
undo loadbalance link link-name
No LB links exist.
link-name: Specifies the LB link name, a case-insensitive string of 1 to 63 characters.
Each physical link connected to the external network corresponds to an LB link.
# Create the LB link lk1, and enter LB link view.
Use loadbalance link-group to create a link group and enter its view, or enter the view of an existing link group.
Use undo loadbalance link-group to delete a link group.
loadbalance link-group link-group-name
undo loadbalance link-group link-group-name
No link groups exist.
link-group-name: Specifies the link group name, a case-insensitive string of 1 to 63 characters.
You can add links that contain similar functions to a link group to facilitate management.
# Create the link group lg, and enter link group view.
[Sysname] loadbalance link-group lg
loadbalance log enable bandwidth-busy
Use loadbalance log enable bandwidth-busy to enable load balancing link busy state logging.
Use undo loadbalance log enable bandwidth-busy to disable load balancing link busy state logging.
Load balancing link busy state logging is disabled.
Load balancing link busy state logging records busy states for all links.
# Enable load balancing link busy state logging.
[Sysname] loadbalance log enable bandwidth-busy
loadbalance log enable base
Use loadbalance log enable base to enable load balancing basic logging.
Use undo loadbalance log enable base to disable load balancing basic logging.
Load balancing basic logging is enabled.
Load balancing basic logging generates logs for the following events:
·     The state of a link,or link group changes.
·     The health monitoring result of a link changes.
·     The number of connections on a virtual server or link reaches or drops below the upper limit.
·     The connection establishment rate on a virtual server or link reaches or drops below the upper limit.
·     A primary/backup link group switchover occurs between link groups specified for a virtual server.
·     A primary/backup link group switchover occurs between link groups specified for an LB action.
# Enable load balancing basic logging.
[Sysname] loadbalance log enable base
loadbalance log enable nat
Use loadbalance log enable nat to enable load balancing NAT logging.
Use undo loadbalance log enable nat to disable load balancing NAT logging.
Load balancing NAT logging is disabled.
Load balancing NAT logging records NAT session information, including IP address and port translation information and access information.
# Enable load balancing NAT logging.
[Sysname] loadbalance log enable nat
loadbalance policy
Use loadbalance policy to create an LB policy and enter its view, or enter the view of an existing LB policy.
Use undo loadbalance policy to delete the specified LB policy.
loadbalance policy policy-name [ type { dns | link-generic } ]
undo loadbalance policy policy-name
No LB policies exist.
policy-name: Specifies the LB policy name, a case-insensitive string of 1 to 63 characters.
type { dns | link-generic }: Specifies an LB policy type.
·     dns: DNS load balancing policy.
·     link-generic: Link load balancing policy.
When you create an LB policy, you must specify the LB policy type. You can enter existing LB policy view without entering the type of the LB policy.
# Create the LB policy lbp1 with the DNS type, and enter LB policy view.
[Sysname] loadbalance policy lbp1 type dns
[Sysname-lbp-dns-lbp1]
Use loadbalance probe-template to create a load balancing probe template and enter its view, or enter the view of an existing load balancing probe template.
Use undo loadbalance probe-template to delete a load balancing probe template.
loadbalance probe-template icmp template-name
undo loadbalance probe-template icmp template-name
No load balancing probe templates exist.
icmp: Specifies the ICMP-type template.
template-name: Specifies a template name, a case-insensitive string of 1 to 32 characters.
# Create a load balancing probe template named icmptplt, and enter load balancing probe template view.
Use loadbalance proximity to create proximity and enter its view, or enter the view of the existing proximity.
Use undo loadbalance proximity to delete proximity view and clear all configuration in proximity view.
# Create proximity and enter its view.
loadbalance region
Use loadbalance region to create a region and enter its view, or enter the view of an existing region.
Use undo loadbalance region to delete a region.
loadbalance region region-name
undo loadbalance region region-name
No regions exist.
region-name: Specifies the region name, a case-insensitive string of 1 to 63 characters.
A region contains network segments corresponding to different ISPs.
# Create the region isp-ct, and enter region view.
[Sysname] loadbalance region isp-ct
[Sysname-lb-region-isp-ct]
loadbalance schedule-test ip
Use loadbalance schedule-test ip to perform an IPv4 load balancing test.
loadbalance schedule-test ip protocol { protocol-number | icmp | tcp | udp } destination destination-address destination-port destination-port source source-address source-port source-port
protocol { protocol-number | icmp | tcp | udp }: Specifies a protocol by its number in the range of 0 to 255 or by its name. For ICMP (1), TCP (6), and UDP (17), you can enter the protocol number or protocol name.
destination destination-address: Specifies the destination IPv4 address.
destination-port destination-port: Specifies the destination port number in the range of 0 to 65535. This option is not supported by some protocols.
source source-address: Specifies the source IPv4 address.
source-port source-port: Specifies the source port number in the range of 0 to 65535. This option is not supported by some protocols.
# Perform an IPv4 load balancing test for the TCP protocol.
<Sysname> loadbalance schedule-test ip protocol tcp destination 7.7.7.7 destination-port 4 source 2.2.2.2 source-port 5
    Matched virtual server: vs2
    Matched default link group: lg
    Forward type: Forwarding to link
    Selected link: link2
        Scheduling algorithm: Predictor
Table 21 Command output
Forward type
Forwarding mode:
·     The destination address is not supported. Load balancing is not performed.
·     Forward all—Forwards packets.
·     Forwarding to link—Forwards packets to the link.
·     Drop—Drops packets.
·     Redirect—Redirects packets.
·     Waiting—Enqueues packets.
Drop reason
Packet drop reason:
·     Number of connections or bandwidth for the virtual server exceeded the limit.
·     No class matched and no valid default link group configured.
·     No valid link in the link group.
·     Action is drop.
·     A sticky entry was matched but the number of connections or bandwidth for the link exceeded the limit.
·     A class was matched but no valid link group exists in the action of the class.
·     Queue overflow (which means the wait queue is full).
Scheduling algorithm used to select the link:
·     Predictor—The link is selected by using the scheduling algorithm.
·     Sticky method—The link is selected by using the sticky method.
·     Proximity—The link is selected by using the proximity feature.
loadbalance schedule-test ipv6
Use loadbalance schedule-test ipv6 to perform an IPv6 load balancing test.
loadbalance schedule-test ipv6 protocol { protocol-number | icmpv6 | tcp | udp } destination destination-address destination-port destination-port source source-address source-port source-port
protocol { protocol-number | icmpv6 | tcp | udp }: Specifies a protocol by its number in the range of 0 to 255 or by its name. For ICMPv6 (58), TCP (6), and UDP (17), you can enter the protocol number or protocol name.
destination destination-address: Specifies the destination IPv6 address.
source source-address: Specifies the source IPv6 address.
# Schedule an IPv6 load balancing test for the ICMPv6 protocol.
<Sysname> loadbalance schedule-test ipv6 protocol icmpv6 destination 10::1 source 12::2
Table 22 Command output
Forward type
Forwarding mode:
Drop reason
Packet drop reason:
·     Action is drop.
Use loadbalance snat-pool to create an SNAT address pool and enter its view, or enter the view of an existing SNAT address pool.
Use undo loadbalance snat-pool to delete the specified SNAT address pool.
loadbalance snat-pool pool-name
undo loadbalance snat-pool pool-name
No SNAT address pools exist.
pool-name: Specifies the SNAT address pool name, a case-insensitive string of 1 to 63 characters.
# Create the SNAT address pool lbsp, and enter SNAT address pool view.
match
Use match to specify the proximity probe method for packets.
Use undo match to restore the default.
match [ match-id ] tcp { lb-probe lb-template | probe nqa-template }
undo match match-id
No proximity probe method is specified.
Proximity view
match-id: Specifies a proximity probe method by its ID in the range of 1 to 65535. If the rule does not exist, the command creates the proximity probe method. If the rule already exists, the command modifies the proximity probe method. If you do not specify this argument, the system automatically assigns an available rule ID with the smallest available ID.
tcp: Specifies TCP packets.
lb-probe lb-template: Specifies a load balancing probe template by its name, a case-insensitive string of 1 to 32 characters.
probe nqa-template: Specifies an NQA template by its name, a case-insensitive string of 1 to 32 characters.
If the match command is configured, the specified proximity probe method applies. If no packets match the type in the match command or the match command is not configured, the default proximity probe method specified by using the match default command applies.
You can specify only one proximity probe method for each type of packets.
If both the match command and the match default command are configured, specify the same template type in the two commands as a best practice for both templates to take effect. If you specify different template types, the NQA template does not take effect.
# Create the ICMP-type NQA template t4, and specify the NQA template as the proximity probe method for TCP packets.
[Sysname] nqa template icmp t4
[Sysname-nqatplt-icmp-t4] quit
[Sysname-lb-proximity] match tcp probe t4
match default
match acl
Use match class to create an ACL match rule or modify an existing ACL match rule.
Use undo match to delete a match rule.
match [ match-id ] acl [ ipv6 ] { acl-number | name acl-name }
undo match match-id
No match rules exist.
LB class view
match-id: Specifies a match rule by its ID in the range of 1 to 65535. If you do not specify this argument, the system automatically assigns an available rule ID with the smallest number.
ipv6: Specifies an IPv6 ACL. If you do not specify this keyword, the command creates an IPv4 ACL.
acl-number: Specifies the ACL number in the range of 2000 to 3999.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter.
If the specified ACL does not exist, this rule is not matched.
You can create a maximum of 65535 match rules for an LB class.
# Create an ACL match rule for the DNS LB class lbc1.
[Sysname-lbc-dns-lbc1] match acl 2000
match app-group
Use match app-group to create an application group match rule or modify an existing application group match rule.
Use undo match app-group to delete a match rule.
match [ match-id ] app-group group-name
undo match match-id
Link-generic LB class view
match-id: Specifies a match rule ID in the range of 1 to 65535. If you do not specify this argument, the system automatically assigns an available rule ID with the smallest number.
app-group group-name: Specifies an application group by its name, a case-insensitive string of 1 to 63 characters.
If the specified application group does not exist, the rule does not take effect.
# Create an application group match rule for the link-generic LB class lbc1.
[Sysname] loadbalance class lbc1 type link-generic
[Sysname-lbc-link-generic-lbc1] match app-group http
app-group (Security Command Reference)
match class
Use match class to create a match rule that references an LB class or modify an existing match rule that references an LB class.
match [ match-id ] class class-name
undo match match-id
An LB class does not have a match rule.
LB class view
class-name: Specifies an LB class by its name, a case-insensitive string of 1 to 63 characters, to be referenced by the match rule. The current LB class cannot be referenced.
A match rule cannot reference an LB class that has already been referenced.
# Create a match rule that references the LB class lbc2 for the DNS LB class lbc1.
[Sysname-lbc-dns-lbc1] match class lbc2
match default
Use match default to specify the default proximity probe method.
Use undo match default to restore the default.
match default { lb-probe lb-template | probe nqa-template }
undo match default
The default proximity probe method is not specified.
Proximity view
If the match command is configured, the specified proximity probe method applies. If no packets match the type in the match command or the match command is not configured, the default proximity probe method applies.
If both the match command and the match default command are configured, you must specify the same template type (load balancing or NQA) in the two commands as a best practice for both templates to take effect. If you specify different template types, the NQA template does not take effect.
# Create the ICMP-type NQA template t4, and specify the NQA template as the default proximity probe method.
[Sysname-lb-proximity] match default probe t4
match
nqa template (Network Management and Monitoring Command Reference)
match destination
Use match destination to create a destination IP address match rule or modify an existing destination IP address match rule.
match [ match-id ] destination { ip address ipv4-address [ mask-length | mask ] | ipv6 address ipv6-address [ prefix-length ] }
undo match match-id
DNS/Link-generic LB class view
ip address ipv4-address: Specifies an IPv4 address.
mask-length: Specifies a mask length in the range of 0 to 32. The default is 32.
mask: Specifies a subnet mask. The default is 255.255.255.255.
ipv6 address ipv6-address: Specifies an IPv6 address.
prefix-length: Specifies a prefix length in the range of 0 to 128. The default is 128.
# Create a match rule to match destination IPv4 address 1.1.1.1/32 for the DNS LB class lbc1.
[Sysname-lbc-dns-lbc1] match destination ip address 1.1.1.1
# Create a match rule to match destination IPv4 address 1.1.1.1/32 for the link-generic LB class lbc2.
[Sysname] loadbalance class lbc2 type link-generic
[Sysname-lbc-link-generic-lbc2] match destination ip address 1.1.1.1
match destination domain-name
Use match destination domain-name to create a domain name match rule or modify an existing domain name match rule.
match [ match-id ] destination domain-name domain-name
undo match match-id
domain-name: Specifies a domain name, a case-insensitive string of 1 to 253 characters. Each dot-separated part in the domain name can contain a maximum of 63 characters. The domain name can contain letters, digits, hyphens (-), underscores (_), dots (.), and wildcards (asterisks and question marks).
When you use wildcards (asterisks and question marks) in a domain name, follow these guidelines:
·     The wildcards can substitute any characters except for dots (.).
·     An asterisk (*) can substitute a character string.
·     A question mark (?) can substitute a single character.
# Create a domain name match rule for the link-generic LB class lbc1 to match domain name www.abc.com.
[Sysname-lbc-link-generic-lbc1] match destination domain-name www.aaa.com
match domain-name
Use match domain-name to create a domain name match rule or modify an existing domain name match rule.
match [ match-id ] domain-name domain-name
undo match match-id
DNS LB class view
# Create a domain name match rule for DNS LB class lbc1 to match domain name www.abc.com.
[Sysname-lbc-dns-lbc1] match domain-name www.abc.com
match interface
Use match interface to create an interface match rule or modify an existing interface match rule.
match [ match-id ] interface interface-type interface-number
undo match match-id
interface interface-type interface-number: Specifies an interface by its type and number. The interface type can be Layer 3 Ethernet interface and Layer 3 aggregate interface.
If the specified interface does not exist, the rule does not take effect.
# Create an interface match rule for the link-generic LB class lbc1 to match interface GigabitEthernet 1/0/1.
[Sysname-lbc-link-generic-lbc1] match interface gigabitethernet 1/0/1
match isp
Use match isp to create an ISP match rule or modify an existing ISP match rule.
match [ match-id ] isp isp-name
undo match match-id
LB class view
isp-name: Specifies an ISP name, a case-insensitive string of 1 to 63 characters.
If the specified ISP does not exist or is not configured with an IP network segment, this rule is not matched.
# Create an ISP match rule for the link-generic LB class lbc1. Specify the ISP name as isp1.
[Sysname-lbc-link-generic-lbc1] match isp isp1
match source
Use match source to create a source IP address match rule or modify an existing source IP address match rule.
match [ match-id ] source { ip address ipv4-address [ mask-length | mask ] | ipv6 address ipv6-address [ prefix-length ] }
undo match match-id
LB class view
source: Specifies the match rule type as source IP address.
# Create a match rule that matches source IP address 1.1.1.1/32 for the link-generic LB class lbc1.
[Sysname-lbc-link-generic-lbc1] match source ip address 1.1.1.1
match user
Use match user to create a user match rule or modify an existing user match rule.
match [ match-id ] [ identity-domain domain-name ] user user-name
undo match match-id
identity-domain domain-name: Matches the user in an identity domain. The domain-name argument represents the identity domain name, a case-insensitive string of 1 to 255 characters excluding question marks (?). If you do not specify this option, the system matches the user among users that do not belong to any identity domain.
user-name: Specifies a username, a case-sensitive string of 1 to 55 characters.
If the specified user does not exist, the rule does not take effect.
# Create a user match rule for the link-generic LB class lbc1 to match user u1 in identity domain domain1.
[Sysname-lbc-link-generic-lbc1] match identity-domain domain1 user u1
display loadbalance class
match user-group
Use match user-group to create a user group match rule or modify an existing user group match rule.
match [ match-id ] [ identity-domain domain-name ] user-group user-group-name
undo match match-id
identity-domain domain-name: Matches the user group in an identity domain. The domain-name argument represents the identity domain name, a case-insensitive string of 1 to 255 characters excluding question marks (?). If you do not specify this option, the system matches the user group among user groups that do not belong to any identity domain.
user-group-name: Specifies a user group by its name, a case-insensitive string of 1 to 200 characters.
If the specified user group does not exist, the rule does not take effect.
# Create a user group match rule for the link-generic LB class lbc1 to match user group lb-group in identity domain domain1.
[Sysname-lbc-link-generic-lbc1] match identity-domain domain1 user-group lb-group
max-bandwidth (link view)
Use max-bandwidth to set the maximum expected bandwidth of an LB link.
Use undo max-bandwidth to restore the default.
max-bandwidth [ inbound | outbound ] bandwidth-value
undo max-bandwidth [ inbound | outbound ]
The maximum expected bandwidth of an LB link is not limited.
Link view
inbound: Specifies the maximum inbound expected bandwidth.
outbound: Specifies the maximum outbound expected bandwidth.
bandwidth-value: Specifies the maximum expected bandwidth in the range of 0 to 4294967295 in KBps. The value 0 means the bandwidth is not limited.
If you do not specify the inbound or outbound keyword, the maximum expected bandwidth equals the inbound expected bandwidth plus the outbound expected bandwidth.
This command takes effect only on new sessions and does not take effect on existing sessions.
In addition to being used for link protection, the maximum expected bandwidth is used for remaining bandwidth calculation in the bandwidth algorithm, maximum bandwidth algorithm, and dynamic proximity algorithm.
# Set the maximum expected bandwidth of the LB link lk1 to 1 KBps.
[Sysname-lb-link-lk1] max-bandwidth 1
# Set the maximum inbound expected bandwidth of the LB link lk1 to 1 KBps.
[Sysname-lb-link-lk1] max-bandwidth inbound 1
# Set the maximum outbound expected bandwidth of the LB link lk1 to 1 KBps.
[Sysname-lb-link-lk1] max-bandwidth outbound 1
max-number
Use max-number to set the maximum number of proximity entries.
Use undo max-number to restore the default.
max-number number
undo max-number
The maximum number of proximity entries is not set.
Proximity view
number: Specifies the maximum number of proximity entries, in the range of 0 to 10000000. The default value is 0, which indicates that the maximum number of proximity entries is not limited.
# Set the maximum number of proximity entries to 100.
[Sysname-lb-proximity] max-number 100
override-limit enable
Use override-limit enable to ignore the limits for sessions that match sticky entries.
Use undo override-limit enable to remove the configuration.
The session limits apply to sessions that match sticky entries.
Sticky group view
Use this command to ignore the following limits for sessions that match sticky entries:
·     Bandwidth and connection parameters on links.
·     Bandwidth ratios and maximum expected bandwidths for links.
·     LB connection limit policies on virtual servers.
# Ignore the limits for sessions that match sticky entries generated in the sticky group st.
[Sysname] sticky-group st type address-port
[Sysname-sticky-address-port-st] override-limit enable
parameter
Use parameter to specify a parameter profile to be referenced by a virtual server.
Use undo parameter to restore the default.
parameter ip profile-name
undo parameter ip
No parameter profile is referenced by a virtual server.
Virtual server view
ip: Specifies the IP parameter profile type.
profile-name: Specifies a parameter profile by its name, a case-insensitive string of 1 to 63 characters.
The virtual server references the parameter profile to implement analysis, processing, and optimization for service traffic.
# Specify the IP parameter profile pp2 to be referenced by the IP-type virtual server vs3.
[Sysname-vs-ip-vs3] parameter ip pp2
parameter-profile
Use parameter-profile to create a parameter profile and enter its view, or enter the view of an existing parameter profile.
Use undo parameter-profile to delete the specified parameter profile.
parameter-profile profile-name [ type ip ]
undo parameter-profile profile-name
No parameter profiles exist.
profile-name: Specifies a parameter profile name, a case-insensitive string of 1 to 63 characters.
type ip: Specifies the IP parameter profile type.
You can configure advanced parameters through the parameter profile. The virtual server references the parameter profile to implement analysis, processing, and optimization for service traffic.
# Create the IP parameter profile pp2, and enter parameter profile view.
[Sysname] parameter-profile pp2 type ip
[Sysname-para-ip-pp2]
port (transparent DNS proxy view)
Use port to configure the port number of a transparent DNS proxy.
Use undo port to restore the default.
port port-number
undo port
The port number of a transparent DNS proxy is 53.
port-number: Specifies a port number in the range of 1 to 65535.
A transparent DNS proxy processes a DNS request only when the destination IP address and port number of the DNS request matches those of the transparent DNS proxy.
# Specify the port number of transparent DNS proxy dns-proxy1 as 5353.
[Sysname-lb-dp-dns-proxy1] port 5353
display loadbalance dns-proxy
port (DNS server view)
Use port to configure the port number of a DNS server.
port port-number
undo port
The port number of a DNS server is 0.
DNS server view
port-number: Specifies a port number in the range of 0 to 65535. The value 0 means that the original port number is used.
# Specify the port number of DNS server ds1 as 5353.
[Sysname-lb-ds-ds1] port 5353
port (virtual server view)
Use port to configure the port number of a virtual server.
port { port-number [ to port-number ] } &<1-n>
undo port
The port number is 0 (indicates any port) for a virtual server.
Virtual server view
port-number [ to port-number ] &<1-n>: Specifies a space-separated list of up to n port number items. Each port number item specifies a port number or a range of port numbers in the form of start-port-number to end-port-number. The value range for the port-number argument is 0 to 65535 (0 means any port) and the value range for n is 1 to 8.
# Specify the port number of the link-IP-type virtual server vs3 as 8080.
[Sysname] virtual-server vs3 type link-ip
[Sysname-vs-link-ip-vs3] port 8080
predictor (DNS server pool view)
Use predictor to specify a scheduling algorithm for a DNS server pool.
Use undo predictor to restore the default.
predictor hash address { destination | source | source-ip-port } [ mask mask-length ] [ prefix prefix-length ]
predictor { random | round-robin | { bandwidth | max-bandwidth } [ inbound | outbound ] }
undo predictor
The scheduling algorithm for a DNS server pool is weighted round robin.
hash address: Specifies the hash algorithm based on the IP address.
destination: Specifies the hash algorithm based on the destination IP address.
source: Specifies the hash algorithm based on the source IP address.
source-ip-port: Specifies the hash algorithm based on the source IP address and port number.
mask mask-length: Specifies the mask length of the IPv4 address used in the hash algorithm. The value range for the mask-length argument is 0 to 32. The default is 32.
prefix prefix-length: Specifies the prefix length of the IPv6 address used in the hash algorithm. The value range for the prefix-length argument is 0 to 128. The default is 128.
random: Specifies the random algorithm, which randomly assigns DNS requests to DNS servers.
round-robin: Specifies the weighted round robin algorithm, which assigns DNS requests to DNS servers based on the weights of the DNS servers. A higher weight indicates more DNS requests will be assigned.
bandwidth: Specifies the bandwidth algorithm, which assigns DNS requests to DNS servers based on the weight and remaining bandwidth of the DNS servers. The weight value used in this algorithm is configured in DNS server view.
max-bandwidth: Specifies the maximum bandwidth algorithm, which always assigns DNS requests to the DNS server corresponding to the idle link with the largest remaining bandwidth.
inbound: Selects a DNS server based on the inbound bandwidth.
outbound: Selects a DNS server based on the outbound bandwidth.
If you do not specify the inbound or outbound keyword, the total bandwidth is used to select a DNS server.
In the bandwidth algorithm and maximum bandwidth algorithm, the remaining bandwidth is the maximum expected bandwidth minus the current bandwidth. If the maximum expected bandwidth is not configured, the remaining bandwidth is the maximum bandwidth of the link minus the current bandwidth.
# Specify the scheduling algorithm as random for DNS server pool dns-pool.
[Sysname-lb-dspool-dns-pool] predictor random
rate-limit bandwidth (link view)
predictor (link group view)
Use predictor to specify a scheduling algorithm for a link group.
predictor { least-connection | { bandwidth | max-bandwidth } [ inbound | outbound ] | random | round-robin }
undo predictor
The scheduling algorithm for a link group is weighted round robin.
Link group view
hash address: Performs the hash algorithm based on IP address.
destination: Performs the hash algorithm based on destination IP address.
source: Performs the hash algorithm based on source IP address.
source-ip-port: Performs the hash algorithm based on source IP address and port number.
mask mask-length: Specifies the IPv4 address mask length, in the range of 0 to 32. The default is 32.
prefix prefix-length: Specifies the IPv6 address prefix length, in the range of 0 to 128. The default is 128.
least-connection: Specifies the link-based weighted least connection algorithm. This algorithm always assigns new connections to the link with the fewest number of weighted active connections (the total number of active connections in all link groups divided by weight). The weight value used in this algorithm is configured in link view.
random: Specifies the random algorithm, which randomly assigns new connections to links.
round-robin: Specifies the weighted round robin algorithm, which assigns new connections to links based on the weights of links. A higher weight indicates more new connections will be assigned.
bandwidth: Specifies the bandwidth algorithm, which assigns packets to links based on the weight of the links and the bandwidth ratio. The weight value used in this algorithm is configured in link view.
max-bandwidth: Specifies the maximum bandwidth algorithm, which always assigns packets to the idle link with the largest remaining bandwidth.
inbound: Selects a link based on the inbound bandwidth.
outbound: Selects a link based on the outbound bandwidth.
If you do not specify the inbound or outbound keyword, the total bandwidth is used to select a link.
# Specify the scheduling algorithm random for the link group lg.
[Sysname-lb-lgroup-lg] predictor random
priority (DNS server view)
Use priority to set the priority of a DNS server.
Use undo priority to restore the default.
priority priority
undo priority
The priority of a DNS server is 4.
DNS server view
priority: Specifies the priority value in the range of 1 to 8. A greater value means a higher priority.
Typically, only the DNS servers with the highest priority participate in scheduling. If the number of such DNS servers is smaller than the required minimum number, more DNS servers are selected by priority in descending order. If the allowed maximum number is exceeded after DNS servers with a certain priority are added, only some of the DNS servers with that priority are added.
Use this command together with the selected-server command in DNS server pool view.
# Set the priority of DNS server ds1 to 3.
[Sysname-lb-ds-ds1] priority 3
selected-server (DNS server pool view)
priority (link view)
Use priority to set the priority of a link.
priority priority
undo priority
The priority of a link is 4.
Link view
Typically only the links with the highest priority participate in scheduling. If the number of such links is smaller than the required minimum number, more links are selected by priority in descending order.
# Set the priority of the link lk1 to 3.
[Sysname-lb-link-lk1] priority 3
selected-link
probe (DNS server pool view)
Use probe to specify a health monitoring method for a DNS server pool.
Use undo probe to restore the default.
probe template-name
undo probe template-name
No health monitoring method is specified for a DNS server pool.
template-name: Specifies an NQA template by its name, a case-insensitive string of 1 to 32 characters.
Use the nqa template command to create an NQA template to be referenced by the health monitoring method. The DNS server pool uses the parameters defined in the NQA template to detect the availability of DNS servers.
The health monitoring method configuration in DNS server view takes precedence over the configuration in DNS server pool view.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the DNS server pool dns-pool as t4.
[Sysname-lb-dspool-dns-pool] probe t4
success-criteria (DNS server pool view)
probe (DNS server view)
Use probe to specify a health monitoring method for a DNS server.
probe template-name
No health monitoring method is specified for a DNS server.
DNS server view
# Create the ICMP-type NQA template t4, and specify the health monitoring method for DNS server ds1 as t4.
[Sysname-lb-ds-ds1] probe t4
success-criteria (DNS server view)
probe (link group view)
Use probe to specify a health monitoring method for a link group.
probe template-name
No health monitoring method is specified for a link group.
Link group view
The link group uses the parameters defined in the NQA template to detect the availability of links.
The health monitoring method configuration in link view takes precedence over the configuration in link group view.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the link group lg as t4.
[Sysname-lb-lgroup-lg] probe t4
success-criteria (link group view)
probe (link view)
Use probe to specify a health monitoring method for an LB link.
probe template-name
No health monitoring method is specified for an LB link.
Link view
You can configure multiple health monitoring methods for an LB link. By default, health monitoring succeeds only when all the specified health monitoring methods succeed. You can use the success-criteria command to specify the health monitoring success criteria for the LB link.
# Create the ICMP-type NQA template t4, and specify the health monitoring method for the LB link lk1 as t4.
[Sysname-lb-link-lk1] probe t4
success-criteria (link view)
proximity enable (link group view)
Use proximity enable to enable the proximity feature for a link group.
Use undo proximity enable to disable the proximity feature for a link group.
proximity enable
The proximity feature is disabled for a link group.
Link group view
The proximity feature takes precedence over the scheduling algorithm in selecting a link. If no link is selected according to the proximity feature, the scheduling algorithm is used.
# Enable the proximity feature for the link group lg.
[Sysname-lb-lgroup-lg] proximity enable
Use rate-limit bandwidth to set the maximum bandwidth of a link.
Use undo rate-limit bandwidth to restore the default.
rate-limit bandwidth [ inbound | outbound ] bandwidth-value
undo rate-limit bandwidth [ inbound | outbound ]
The maximum bandwidth of a link is not limited.
Link view
inbound: Specifies the maximum inbound bandwidth.
outbound: Specifies the maximum outbound bandwidth.
bandwidth-value: Specifies the maximum bandwidth in the range of 0 to 4294967295 in KBps. The value 0 means the bandwidth is not limited.
If you do not specify the inbound or outbound keyword, the maximum bandwidth equals the inbound bandwidth plus the outbound bandwidth.
# Set the maximum bandwidth of the link lk1 to 1 KBps.
[Sysname-lb-link-lk1] rate-limit bandwidth 1
# Set the maximum inbound bandwidth of the link lk1 to 1 KBps.
[Sysname-lb-link-lk1] rate-limit bandwidth inbound 1
# Set the maximum outbound bandwidth of the link lk1 to 1 KBps.
[Sysname-lb-link-lk1] rate-limit bandwidth outbound 1
rate-limit bandwidth (virtual server view)
Use rate-limit bandwidth to set the maximum bandwidth of a virtual server.
The maximum bandwidth of a virtual server is not limited.
Virtual server view
# Set the maximum bandwidth of the IP-type virtual server vs3 to 1 KBps.
[Sysname-vs-ip-vs3] rate-limit bandwidth 1
# Set the maximum inbound bandwidth of the IP-type virtual server vs3 to 1 KBps.
[Sysname-vs-ip-vs3] rate-limit bandwidth inbound 1
# Set the maximum outbound bandwidth of the IP-type virtual server vs3 to 1 KBps.
[Sysname-vs-ip-vs3] rate-limit bandwidth outbound 1
rate-limit connection (link view)
Use rate-limit connection to set the maximum number of connections per second of a link.
Use undo rate-limit connection to restore the default.
rate-limit connection connection-number
The maximum number of connections per second of a link is 0.
Link view
connection-number: Specifies the maximum number of connections per second in the range of 0 to 4294967295. 0 means the number is not limited.
# Set the maximum number of connections per second of the link lk1 to 10000.
[Sysname-lb-link-lk1] rate-limit connection 10000
rate-limit connection (virtual server view)
Use rate-limit connection to set the maximum number of connections per second of a virtual server.
The maximum number of connections per second of a virtual server is 0.
Virtual server view
# Set the maximum number of connections per second of the IP-type virtual server vs3 to 10000.
[Sysname-vs-ip-vs3] rate-limit connection 10000
reset loadbalance connections
Use reset loadbalance connections to clear application layer connections.
This command clears all application layer connections, including reused idle connections.
# Clear application layer connections.
<Sysname> reset loadbalance connection
reset loadbalance dns-proxy statistics
Use reset loadbalance dns-proxy statistics to clear transparent DNS proxy statistics.
reset loadbalance dns-proxy statistics [ dns-proxy-name ]
dns-proxy-name: Specifies a transparent DNS proxy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics for all DNS transparent proxies.
# Clear statistics for transparent DNS proxy dns-proxy1.
<Sysname> reset loadbalance dns-proxy statistics dns-proxy1
display loadbalance dns-proxy statistics
reset loadbalance dns-server statistics
Use reset loadbalance dns-server statistics to clear DNS server statistics.
reset loadbalance dns-server statistics [ dns-server-name ]
dns-server-name: Specifies a DNS server by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics for all DNS servers.
# Clear statistics for DNS server ds1.
<Sysname> reset loadbalance dns-server statistics ds1
display loadbalance dns-server statistics
reset loadbalance link statistics
Use reset loadbalance link statistics to clear link statistics.
reset loadbalance link statistics [ link-name ]
link-name: Specifies a link by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics about all links.
# Clear statistics about all links.
<Sysname> reset loadbalance link statistics
reset loadbalance proximity
Use reset loadbalance proximity to clear proximity entry information.
reset loadbalance proximity [ ip [ ipv4-address ] | ipv6 [ ipv6-address ] ]
ip [ ipv4-address ]: Clears IPv4 proximity entry information. If you specify the ipv4-address argument, this command clears information about the proximity entry corresponding to the IPv4 address. If you do not specify the ipv4-address argument, this command clears information about all IPv4 proximity entries.
ipv6 [ ipv6-address ]: Clears IPv6 proximity entry information. If you specify the ipv6-address argument, this command clears information about the proximity entry corresponding to the IPv6 address. If you do not specify the ipv6-address argument, this command clears information about all IPv6 proximity entries.
If you do not specify the ip or ipv6 keyword, this command clears information about all IPv4 and IPv6 proximity entries for the public network.
# Clear information about all IPv6 proximity entries for the public network.
<Sysname> reset loadbalance proximity ipv6
reset virtual-server statistics
Use reset virtual-server statistics to clear virtual server statistics.
reset virtual-server statistics [ virtual-server-name ]
virtual-server-name: Clears statistics of the specified virtual server. The virtual-server-name argument specifies a virtual server name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command clears statistics of all virtual servers.
# Clear statistics of all virtual servers.
<Sysname> reset virtual-server statistics
display virtual-server statistics
router interface
Use router interface to specify an outgoing interface for an LB link.
Use undo router interface to delete the outgoing interface for an LB link.
router interface interface-type interface-number
No outgoing interface is specified for an LB link.
LB link view
interface-type interface-number: Specifies an outgoing interface.
In scenarios where IP addresses are obtained through PPPoE, use this command to dynamically obtain the outbound next hop IP address through the specified outgoing interface.
The specified outgoing interface must be an interface that can dynamically obtain IP addresses.
You can configure both this command and the router ip or router ipv6 command. The command configured later overwrites the command configured first.
# Specify Dialer0 as the outgoing interface for the LB link cnc.
[Sysname] loadbalance link cnc
[Sysname-lb-link-cnc] router interface Dialer0
router ip
Use router ip to specify the outbound next hop for an LB link.
Use undo router ip to restore the default.
router ip ipv4-address
undo router ip
The outbound next hop is not specified for an LB link.
LB link view
ipv4-address: Specifies an IPv4 address, which cannot be a loopback address, multicast address, broadcast address, or an address in the format of 0.X.X.X.
You can specify only one outbound next hop for an LB link.
# Specify the outbound next hop as 1.2.3.4 for the LB link lk1.
[Sysname-lb-link-lk1] router ip 1.2.3.4
router ipv6
Use router ipv6 to specify the outbound next hop for an LB link.
Use undo router ipv6 to restore the default.
router ipv6 ipv6-address
undo router ipv6
LB link view
ipv6-address: Specifies an IPv6 address, which cannot be an all-zero address, a multicast address, a loopback address, or a link-local address.
# Specify the outbound next hop as 8008::8  for the LB link lk1.
[Sysname-lb-link-lk1] router ipv6 8008::8
rtt weight
Use rtt weight to set the network delay weight for proximity calculation.
Use undo rtt weight to restore the default.
rtt weight rtt-weight
undo rtt weight
The network delay weight for proximity calculation is 100.
Proximity view
rtt-weight: Specifies the network delay weight for proximity calculation, in the range of 0 to 255. A larger value indicates a higher weight.
# Set the network delay weight for proximity calculation to 200.
[Sysname-lb-proximity] rtt weight 200
selected-link
Use selected-link to specify the number of links to participate in scheduling.
Use undo selected-link to restore the default.
selected-link min min-number max max-number
undo selected-link
The links with the highest priority participate in scheduling.
Link group view
min min-number: Specifies the minimum number of links to participate in scheduling, in the range of 1 to 1000.
max max-number: Specifies the maximum number of links to participate in scheduling, in the range of 1 to 1000. The value of the max-number argument must be greater than or equal to the value of the min-number argument.
If the number of links available to participate in scheduling exceeds the max-number setting, the max-number setting applies.
If the number of links available to participate in scheduling is smaller than the min-number setting, more links are selected by priority in descending order.
# Configure the minimum number and maximum number of links in the link group lg to participate in scheduling as 20 and 30, respectively.
[Sysname-lb-lgroup-lg] selected-link min 20 max 30
Use selected-server to specify the number of DNS servers to participate in scheduling.
Use undo selected-server to restore the default.
selected-server min min-number max max-number
The DNS servers with the highest priority participate in scheduling.
min min-number: Specifies the minimum number of DNS servers to participate in scheduling, in the range of 1 to 1000.
max max-number: Specifies the maximum number of DNS servers to participate in scheduling, in the range of 1 to 1000. The value of the max-number argument must be greater than or equal to the value of the min-number argument.
If the number of DNS servers available to participate in scheduling exceeds the max-number setting, the max-number setting applies.
If the number of DNS servers available to participate in scheduling is less than the min-number setting, more DNS servers are selected by priority in descending order.
# Configure the minimum number and maximum number of DNS servers in DNS server pool dns-pool to participate in scheduling as 20 and 30, respectively.
[Sysname-lb-dspool-dns-pool] selected-server min 20 max 30
service enable (transparent DNS proxy view)
Use service enable to enable the transparent DNS proxy feature.
Use undo service enable to disable the transparent DNS proxy feature.
service enable
undo service enable
The transparent DNS proxy feature is disabled.
Transparent DNS proxy view
# Enable the transparent DNS proxy feature for transparent DNS proxy dns-proxy1.
[Sysname-lb-dp-udp-dns-proxy1] service enable
service enable (virtual server view)
Use service enable to enable a virtual server.
Use undo service enable to disable a virtual server.
service enable
undo service enable
A virtual server is disabled.
Virtual server view
# Enable the IP-type virtual server vs3.
[Sysname-vs-ip-vs3] service enable
set ip tos (LB action view)
Use set ip tos to set the ToS field value of IP packets sent to the server.
Use undo set ip tos to restore the default.
set ip tos tos-number
undo set ip tos
The ToS field of IP packets sent to the server is not changed.
LB action view
tos-number: Specifies the ToS field value in the range of 0 to 255.
# Set the ToS field value to 20 for IP packets sent to the server for the link-generic LB action lba1.
[Sysname-lba-link-generic-lba1] set ip tos 20
set ip tos (parameter profile view)
Use set ip tos to set the ToS field value of IP packets sent to the client.
undo set ip tos
The ToS field of IP packets sent to the client is not changed.
Parameter profile view
This command is available in IP parameter profile view only.
# Set the ToS field value to 20 for IP packets sent to the client for the IP parameter profile pp2.
[Sysname-para-ip-pp2] set ip tos 20
shutdown (link view)
Use shutdown to shut down a link.
Use undo shutdown to activate a link.
shutdown
A link is activated.
Link view
# Shut down the link lk1.
[Sysname-lb-link-lk1] shutdown
skip current-dns-proxy
Use skip current-dns-proxy to skip the current transparent DNS proxy.
Use undo skip current-dns-proxy to restore the default.
The forwarding mode is to discard packets.
DNS LB action view
This command enables DNS requests to skip the current transparent DNS proxy and match the next transparent DNS proxy or virtual server.
A DNS request can skip a maximum of five transparent DNS proxies and virtual servers.
This command is mutually exclusive with the dns-server-pool or forward all command. If you configure one command, the other command (if configured) is automatically cancelled.
# Skip the current transparent DNS proxy in DNS LB action lba1.
[Sysname-lba-dns-lba1] skip current-dns-proxy
slow-online (link group view)
Use slow-online to enable the slow online feature for a link group.
Use undo slow-online to disable the slow online feature for a link group.
slow-online [ standby-time standby-time ramp-up-time ramp-up-time ]
undo slow-online
The slow online feature is disabled for a link group.
Link group view
standby-time standby-time: Specifies the standby timer in the range of 0 to 600 seconds. The default is 5 seconds.
ramp-up-time ramp-up-time: Specifies the ramp-up timer in the range of 3 to 600 seconds. The default is 5 seconds.
The links newly added to a link group might be unable to immediately process large numbers of services assigned by the LB device. To resolve this issue, enable the slow online feature for the link group. The feature uses the standby timer and ramp-up timer. When a link is added, the LB device does not assign any service to the link until the standby timer expires.
When the standby timer expires, the ramp-up timer starts. During the ramp-up time, the LB device increases the service amount according to the processing capability of the link, until the ramp-up timer expires.
# Enable the slow online feature for the link group lg.
[Sysname-lb-lgroup-lg] slow-online
slow-shutdown enable (link view)
Use slow-shutdown enable to enable the slow offline feature for a link.
Use undo slow-shutdown enable to disable the slow offline feature for a link.
The slow offline feature is disabled for a link.
Link view
The shutdown command immediately terminates existing connections of a link. The slow offline feature ages out the connections, and does not establish new connections.
To enable the slow offline feature for a link, you must execute the slow-shutdown enable command and then the shutdown command. If you execute the shutdown command and then the slow-shutdown enable command, the slow offline feature does not take effect and the link is shut down.
# Enable the slow offline feature for the link lk1.
[Sysname] loadbalance link lk1
[Sysname-lb-link-lk1] slow-shutdown enable
snat-pool (link group view)
Use snat-pool to specify the SNAT address pool to be referenced by a link group.
Use undo snat-pool to restore the default.
snat-pool pool-name
undo snat-pool
No SNAT address pool is referenced by a link group.
Link group view
After a link group references an SNAT address pool, the LB device replaces the source address of packets it receives with an SNAT address before forwarding the packets.
# Specify the SNAT address pool lbsp to be referenced by the link group lg.
[Sysname-lb-lgroup-lg] snat-pool lbsp
snmp-agent trap enable loadbalance
Use snmp-agent trap enable loadbalance to enable SNMP notifications for load balancing.
Use undo snmp-agent trap enable loadbalance to disable SNMP notifications for load balancing.
All SNMP notifications are enabled for load balancing.
To report critical load balancing events to an NMS, enable SNMP notifications for load balancing. For load balancing event notifications to be sent correctly, you must also configure SNMP as described in the network management and monitoring configuration guide for the device.
# Disable SNMP notifications for load balancing.
[Sysname] undo snmp-agent trap enable loadbalance
sticky-group
Use sticky-group to create a sticky group and enter its view, or enter the view of an existing sticky group.
Use undo sticky-group to delete the specified sticky group.
sticky-group group-name [ type address-port ]
undo sticky-group group-name
No sticky groups exist.
group-name: Specifies a sticky group name, a case-insensitive string of 1 to 63 characters.
type address-port: Specifies the address-port sticky group type. When you create a sticky group, you must specify the sticky group type. You can enter an existing sticky group view without entering the type of the sticky group.
A sticky group uses a specific sticky method to distribute similar sessions to the same link. The sticky method applies to the first packet of a session. Subsequent packets of the session are distributed to the same link.
# Create the address- and port-type sticky group sg1 and enter sticky group view.
[Sysname] sticky-group sg1 type address-port
[Sysname-sticky-address-port-sg1]
Use success-criteria to specify the health monitoring success criteria for a DNS server pool.
Use undo success-criteria to restore the default.
success-criteria { all | at-least min-number }
Health monitoring succeeds only when all the specified health monitoring methods succeed.
all: Specifies the health monitoring success criteria as all successful health monitoring methods.
at-least min-number: Specifies the health monitoring success criteria as the specified minimum number of successful health monitoring methods, in the range of 1 to 4294967295.
If the min-number setting exceeds the number of existing health monitoring methods on the device, the number of existing health monitoring methods applies.
The health monitoring success criteria configuration in DNS server view takes precedence over the configuration in DNS server pool view.
# Configure the health monitoring success criteria for the DNS server pool dns-pool as a minimum number of 2 successful health monitoring methods.
[Sysname-lb-dspool-dns-pool] success-criteria at-least 2
Use success-criteria to specify the health monitoring success criteria for a DNS server.
DNS server view
# Configure the health monitoring success criteria for DNS server ds1 as a minimum number of 2 successful health monitoring methods.
[Sysname] loadbalance dns-server ds1
[Sysname-lb-ds-ds1] success-criteria at-least 2
Use success-criteria to specify the health monitoring success criteria for a link group.
Link group view
The health monitoring success criteria configuration in link view takes precedence over the configuration in link group view.
# Configure the health monitoring success criteria for the link group lg as a minimum number of 2 successful health monitoring methods.
[Sysname-lb-lgroup-lg] success-criteria at-least 2
Use success-criteria to specify the health monitoring success criteria for an LB link.
LB link view
# Configure the health monitoring success criteria for the LB link lk1 as a minimum number of 2 successful health monitoring methods.
[Sysname-lb-link-lk1] success-criteria at-least 2
timeout (proximity view)
Use timeout to set the timeout timer for proximity entries.
Use undo timeout to restore the default.
timeout timeout-value
undo timeout
The timeout timer for proximity entries is 60 seconds.
Proximity view
timeout-value: Specifies the timeout timer in the range of 60 to 3600 seconds.
# Set the timeout timer for proximity entries to 80 seconds.
[Sysname] loadbalance proximity
[Sysname-lb-proximity] timeout 80
timeout (sticky group view)
Use timeout to set the timeout timer for sticky entries.
undo timeout
The timeout timer for sticky entries is 60 seconds.
Sticky group view
timeout-value: Specifies the timeout timer in the range of 10 to 604800 seconds.
# Set the timeout timer for sticky entries to 100 seconds in the address- and port-type sticky group sg1.
[Sysname-sticky-address-port-sg1] timeout 100
timeout (template view)
Use timeout to set the timeout time for probe responses.
undo timeout
The timeout time for probe responses is 3 seconds.
Load balancing template view
timeout-value: Specifies the timeout time for probe responses, in the range of 1 to 60 seconds.
As a best practice, set the timeout time for probe responses to be smaller than the probe interval.
# Set the timeout time for probe responses to 5 seconds in the ICMP template icmptplt.
[Sysname] loadbalance probe-template icmp icmptplt
[Sysname-lb-pt-icmp-icmptplt] timeout 5
topology region
Use topology region to configure a topology.
Use undo topology region to restore the default.
topology region region-name { ip ipv4-address { mask-length | mask } | ipv6 ipv6-address prefix-length } [ weight weight-value ]
undo topology region region-name [ ip ipv4-address [ mask-length | mask ] | ipv6 ipv6-address [ prefix-length ] ]
No topologies exist.
region-name: Specifies a region by its name, a case-insensitive string of 1 to 63 characters.
ip ipv4-address: Specifies the IPv4 address of a virtual server.
mask-length: Specifies the mask length for the IPv4 address, in the range of 0 to 32. The default is 32.
mask: Specifies the mask for the IPv4 address. The default is 255.255.255.255.
ipv6 ipv6-address prefix-length: Specifies the IPv6 address of a virtual server.
prefix-length: Specifies the prefix length for the IPv6 address, in the range of 0 to 128. The default is 128.
weight-value: Specifies the weight of the topology, in the range of 1 to 255. The default weight is 100.
A topology associates the region where the local DNS server resides with the IP address of a virtual server.
When the static proximity algorithm (topology) is specified for the virtual server pool by using the predictor command, you must configure a topology.
When a DNS request matches multiple topology records, the topology record with the highest weight is selected.
You can execute this command multiple times to configure multiple IP address ranges for a region.
If you only specify a region when deleting a topology, all topologies for the region are deleted.
# Configure a topology by associating the region region-ct with the IPv4 address 1.2.3.4.
[Sysname] topology region region-ct ip 1.2.3.4 24 weight 200
loadbalance region
predictor (virtual server pool view)
transparent enable (link group view)
Use transparent enable to disable NAT for a link group.
Use undo transparent enable to enable NAT for a link group.
transparent enable
NAT is enabled for a link group.
Link group view
# Disable NAT for the link group lg.
[Sysname] loadbalance link-group lg
[Sysname-lb-lgroup-sinalab] transparent enable
ttl weight
Use ttl weight to set the TTL weight for proximity calculation.
Use undo ttl weight to restore the default.
ttl weight ttl-weight
undo ttl weight
The TTL weight for proximity calculation is 100.
Proximity view
ttl-weight: Specifies the TTL weight for proximity calculation, in the range of 0 to 255. A larger value indicates a higher weight.
# Set the TTL weight for proximity calculation to 200.
[Sysname-lb-proximity] ttl weight 200
virtual ip address
Use virtual ip address to configure an IPv4 address (VSIP) for a virtual server.
Use undo virtual ip address to restore the default.
virtual ip address ipv4-address [ mask-length | mask ]
No IPv4 address is configured for a virtual server.
Virtual server view
ipv4-address: Specifies an IPv4 address. It cannot be a loopback address, multicast address, broadcast address, or an address in the format of 0.X.X.X (with a mask length of 32).
# Configure the IPv4 address for the link-IP-type virtual server vs3 as 1.1.1.1/24.
[Sysname-vs-link-ip-vs3] virtual ip address 1.1.1.1 24
virtual ipv6 address
Use virtual ipv6 address to configure an IPv6 address (VSIP) for a virtual server.
Use undo virtual ipv6 address to restore the default.
virtual ipv6 address ipv6-address [ prefix-length ]
No IPv6 address is configured for a virtual server.
Virtual server view
ipv6-address: Specifies an IPv6 address, which cannot be a loopback address, IPv6 multicast address, link-local address, or all-zero address (when the prefix length is not 0).
# Configure the IPv6 address for the link-IP-type virtual server vs3 as 1001::1/64.
[Sysname-vs-link-ip-vs3] virtual ipv6 address 1001::1 64
virtual-server (system view)
Use virtual-server to create a virtual server and enter its view, or enter the view of an existing virtual server.
Use undo virtual-server to delete the specified virtual server.
virtual-server virtual-server-name [ type { link-ip ]
undo virtual-server virtual-server-name
No virtual servers exist.
virtual-server-name: Specifies the virtual server name, a case-insensitive string of 1 to 63 characters.
type link-ip: Specifies the link-IP virtual server type. When you create a virtual server, you must specify a virtual server type. You can enter an existing virtual server view without entering the type of the virtual server.
# Create the virtual server vs3 with the IP type, and enter virtual server view.
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3]
virtual-server-pool
Use virtual-server-pool to specify a virtual server pool for a DNS mapping.
Use undo virtual-server-pool to restore the default.
virtual-server-pool pool-name
undo virtual-server-pool pool-name
No virtual server pool is specified for a DNS mapping.
DNS mapping view
pool-name: Specifies the virtual server pool name, a case-insensitive string of 1 to 63 characters.
# Specify the virtual server pool pool1 for the DNS mapping dm1.
[Sysname] loadbalance dns-map dm1
[Sysname-lb-dm-dm1] virtual-server-pool pool1
weight (DNS server view)
Use weight to set the weight of a DNS server to be used by the weighted round robin algorithm and bandwidth algorithm.
Use undo weight to restore the default.
weight weight-value
undo weight
The weight of a DNS server is 100.
DNS server view
weight-value: Specifies the weight in the range of 1 to 255. A greater value means a higher priority in scheduling.
# Set the weight of the DNS server ds1 to 150.
[Sysname-lb-ds-ds1] weight 150
weight (link view)
Use weight to set the weight of a link to be used by the weighted round robin and weighted least connection algorithms.
weight weight-value
undo weight
The weight of a link is 100.
Link view
weight-value: Specifies the weight in the range of 1 to 255. For the weighted round robin or weighted least connection algorithm, a greater value means a higher priority to be referenced.
# Set the weight of the link lk1 to 150.
[Sysname-lb-link-lk1] weight 150
