01-gRPC configuration | 263.63 KB |
Telemetry technology based on gRPC
Restrictions and guidelines: gRPC configuration
Configuring the gRPC dial-in mode
gRPC dial-in mode configuration tasks at a glance
Specifying a PKI domain for SSL communication with collectors
Enabling gRPC logging in dial-in mode
Configuring the gRPC dial-out mode
gRPC dial-out mode configuration tasks at a glance
Enabling gRPC logging in dial-out mode
Display and maintenance commands for gRPC
Example: Configuring the gRPC dial-in mode
Example: Configuring the gRPC dial-out mode
Proto definition files in dial-in mode
Proto definition file in dial-out mode
Obtaining proto definition files
Example: Developing a gRPC collector-side application
Generating the C++ code for the proto definition files
Developing the collector-side application (dial-in mode)
Developing the collector-side application (dial-out mode)
Appendix: Methods and attributes for gNMI operations
Configuring gRPC
About gRPC
gRPC is an open source remote procedure call (RPC) system initially developed at Google. It uses HTTP 2.0 for transport and provides network device configuration and management methods that support multiple programming languages.
gRPC protocol stack layers
Table 1 describes the gRPC protocol stack layers.
Table 1 gRPC protocol stack layers
Layer |
Content layer |
Defines the data of the service module. Two peers must notify each other of the data models that they are using. |
Protocol buffer encoding layer |
Encodes data by using the protocol buffer code format. |
gRPC layer |
Defines the protocol interaction format for remote procedure calls. |
HTTP 2.0 layer |
Carries gRPC. |
TCP layer |
Provides connection-oriented reliable data links. |
Network architecture
As shown in Figure 1, the gRPC network uses the client/server model. It uses HTTP 2.0 for packet transport.
Figure 1 gRPC network architecture
The gRPC network uses the following mechanism:
1. The gRPC server listens to connection requests from clients at the gRPC service port.
2. A user runs the gRPC client application to log in to the gRPC server, and uses methods provided in the .proto file to send requests.
3. The gRPC server responds to requests from the gRPC client.
The device can act as the gRPC server or client.
Telemetry is a remote data collection technology for monitoring device performance and operating status. H3C telemetry technology uses gRPC to push data from the device to the collectors on the NMSs. As shown in Figure 2, after a gRPC connection is established between the device and NMSs, the NMSs can subscribe to data of modules on the device.
Figure 2 Telemetry technology based on gRPC
Telemetry modes
The device supports the following telemetry modes:
· Dial-in mode—The device acts as a gRPC server and the collectors act as gRPC clients. A collector initiates a gRPC connection to the device to subscribe to device data.
Dial-in mode applies to small networks where collectors need to deploy configurations to devices.
Dial-in mode supports the following types of operations:
¡ Get—Obtains device status and settings.
¡ CLI—Executes commands on the device.
¡ gNMI—gRPC Network Management Interface operations, which include the following subtypes of operations:
- gNMI Capabilities—Obtains the capacities of the device.
- gNMI Get—Obtains the status and settings of the device.
- gNMI Set—Deploys settings to the device.
- gNMI Subscribe—Subscribes to data push services provided by the device. The data might be generated by periodical data collection or event-triggered data collection. The functionality of this type of operation is similar to the functionality of the dial-out mode.
· Dial-out mode—The device acts as a gRPC client and the collectors act as gRPC servers. The device initiates gRPC connections to the collectors and pushes device data to the collectors as configured.
Dial-out mode applies to larger networks where a large number of devices need to be monitored.
Protocols
RFC 7540, Hypertext Transfer Protocol version 2 (HTTP/2)
Disabling the gRPC service deletes all gRPC settings.
To configure the gRPC dial-in mode, perform the following tasks:
1. (Optional.) Specifying a PKI domain for SSL communication with collectors
2. Configuring the gRPC service
4. (Optional.) Enabling gRPC logging in dial-in mode
To implement SSL communication with collectors, you must specify a PKI domain. For more information about PKI domain configuration, see PKI configuration in Security Configuration Guide.
Perform this task before enabling the gRPC service. If you enable the gRPC service before performing this task, the configuration does not take effect.
For the device to establish gRPC connections to collectors successfully, make sure the PKI domain already exists and has correct certificate and key settings. For more information about PKI domains, see PKI configuration in Security Configuration Guide.
1. Enter system view.
2. Specify a PKI domain for SSL communication with collectors.
grpc pki domain domain-name
By default, no PKI domain is specified for SSL communication with collectors.
2. Enable the gRPC service.
grpc enable
By default, the gRPC service is disabled.
3. (Optional.) Set the gRPC service port number.
grpc port port-number
By default, the gRPC service port number is 50051.
Changing the gRPC service port number reboots the gRPC service and terminates all gRPC sessions to the gRPC server.
4. (Optional.) Set the gRPC session idle timeout timer.
grpc idle-timeout minutes
By default, the gRPC session idle timeout timer is 5 minutes.
Configuring a gRPC user
For gRPC clients to establish gRPC sessions with the device, you must configure local users for the gRPC clients on the device.
2. Add a local user with the device management right.
3. Configure a password for the user.
By default, no password is configured for a local user. A non-password-protected user can pass authentication after providing the correct username and passing attribute checks.
4. Assign user role network-admin to the user.
By default, a local user is assigned the network-operator role.
5. Authorize the user to use the HTTPS service.
service-type https
By default, no service types are authorized to a local user.
For more information about the local-user, password, authorization-attribute, and service-type commands, see AAA configuration in Security Command Reference.
To identify gRPC issues, enable gRPC operations logging in dial-in mode.
This feature generates gRPC operation logs in dial-in mode and sends them to the information center.
With the information center, you can configure log destinations and output rules. For more information about the information center, see Network Management and Monitoring Configuration Guide.
gRPC operation logging might degrade device performance if gRPC operations are frequent. As a best practice, use gRPC operation logging only when necessary and log only gRPC operations of interest if gRPC operation logging is enabled.
2. Enable gRPC logging in dial-in mode. Choose the options to configure as needed:
¡ Enable gRPC logging for RPC operations in dial-in mode.
grpc log dial-in rpc { all | { cli | get }* }
By default, gRPC logging is disabled for RPC operations in dial-in mode.
¡ Enable gRPC logging for gNMI operations in dial-in mode.
grpc log dial-in gnmi { all | { capabilities | get | set | subscribe }* }
By default, gRPC logging is enabled for gNMI Set operations and disabled for other gNMI operations in dial-in mode.
To configure the gRPC dial-out mode, perform the following tasks:
6. (Optional.) Enabling gRPC logging in dial-out mode
Enabling the gRPC service
grpc enable
Configuring sensors
The device uses sensors to sample data. A sensor path indicates a data source.
A sensor path supports either event-trigged or periodic data collection.
· Event-triggered—The device pushes data from the sensor path to the collector when certain events occur. For information about event-triggered sensor paths, see NETCONF XML API Event Reference for the module.
· Periodic—The device pushes data from the sensor path to the collector at intervals. For information about periodic sensor paths, see the NETCONF XML API references for the module except for NETCONF XML API Event Reference.
You can execute the sensor path command multiple times to configure multiple sensor paths or multiple data push conditions for the same sensor path. A sensor path can have a maximum of five data push conditions. The device pushes data of the sensor path to collectors only when all relevant conditions are met.
For sensor path ifmgr/statistics, you can specify a maximum of 64 interface filtering conditions. The device will push the data of the specified interfaces in the sensor path to collectors. If you do not specify any interface filtering conditions, the device pushes the data of all interfaces in the sensor path to collectors.
Use the [ifindex=”index”] format to specify an interface filtering condition.
· The index represents an interface type and number or an interface index, a case-insensitive string of 1 to 99 characters.
· The last character for index can be wildcard character (*), for example, sensor path ifmgr/statistics[ifindex="HundredGigE1/0/*"].
If you specify filtering conditions for this command, you cannot specify data push conditions, and vice versa.
2. Enter telemetry view.
telemetry
3. Create a sensor group and enter sensor group view.
sensor-group group-name
4. Specify a sensor path.
sensor path path [ condition node node operator operator value value ]
Configuring collectors
Collectors are used to receive sampled data from network devices. For the device to communicate with collectors, you must create a destination group and add collectors to the destination group.
As a best practice, configure a maximum of five destination groups. If you configure too many destination groups, system performance might degrade.
To configure a collector that resides in a VPN instance, configure the VPN instance first. For more information about VPN instance configuration, see MPLS L3VPN configuration in MPLS Configuration Guide.
telemetry
3. Create a destination group and enter destination group view.
destination-group group-name
4. Specify a collector.
IPv4:
ipv4-address ipv4-address [ port port-number ] [ vpn-instance vpn-instance-name ]
IPv6:
ipv6-address ipv6-address [ port port-number ] [ vpn-instance vpn-instance-name ]
The IPv6 address of a collector cannot be an IPv6 link-local address. For more information about IPv6 link-local addresses, see IPv6 basics configuration in Layer 3—IP Services Configuration Guide.
To specify multiple collectors, execute this command multiple times. One collector must have a different address, port, or VPN instance than the other collectors.
Configuring a subscription
A subscription binds sensor groups to destination groups. Then, the device pushes data from the specified sensors to the collectors.
telemetry
3. Create a subscription and enter subscription view.
subscription subscription-name
4. (Optional.) Set the DSCP value of packets sent to collectors.
dscp dscp-value
By default, the DSCP value of packets sent to collectors is 0.
A greater DSCP value represents a higher priority.
5. (Optional.) Specify the source IP address for packets sent to collectors.
source-address { ipv4-address | interface interface-type interface-number | ipv6 ipv6-address }
By default, the device uses the primary IPv4 address of the output interface for the route to the collectors as the source address.
Changing the source address causes the device to reconnect to the gRPC server.
6. Specify a sensor group.
sensor-group group-name [ sample-interval [ msec ] interval ]
Specify the sample-interval interval option for periodic sensor paths and only for periodic sensor paths.
¡ If you specify the option for event-triggered sensor paths, the sensor paths do not take effect.
¡ If you do not specify the option for periodic sensor paths, the device does not sample or push data.
To change the data collection interval for a sensor group specified for a subscription, you must remove the sensor group from the subscription first.
7. Specify a destination group.
To identify gRPC issues, enable gRPC data collection logging in dial-out mode.
This feature generates gRPC data collection logs in dial-out mode and sends them to the information center.
2. Enable gRPC logging in dial-out mode.
grpc log dial-out { all | { event | sample }* }
By default, gRPC logging is disabled in dial-out mode.
Task |
Command |
Display gRPC information. |
display grpc |
gRPC configuration examples
These configuration examples describe only CLI configuration tasks on the device. The collectors need to run an extra application. For information about collector-side application development, see "Example: Developing a gRPC collector-side application."
As shown in Figure 3, configure the gRPC dial-in mode on the device so the device acts as the gRPC server and the gRPC client can subscribe to LLDP events on the device.
1. Assign IP addresses to interfaces on the gRPC server and client and configure routes. Make sure the server and client can reach each other.
2. Configure the device as the gRPC server:
# Enable the gRPC service.
[Device] grpc enable
# Create a local user named test. Set the password to test, and assign the network-admin user role and HTTPS service to the user.
[Device] local-user test
[Device-luser-manage-test] password simple test
[Device-luser-manage-test] authorization-attribute user-role network-admin
[Device-luser-manage-test] service-type https
[Device-luser-manage-test] quit
3. Configure the gRPC client.
a. Prepare a PC and install the gRPC environment on the PC. For more information, see the user guide for the gRPC environment.
b. Obtain the H3C proto definition file and uses the protocol buffer compiler to generate code of a specific language, for example, Java, Python, C/C++, or Go.
c. Create a client application to call the generated code.
d. Start the application to log in to the gRPC server.
When an LLDP event occurs on the gRPC server, verify that the gRPC client receives the event.
As shown in Figure 4, the device is connected to a collector. The collector uses port 50050.
Configure gRPC dial-out mode on the device so the device pushes the device capability information of its interface module to the collector at 10-second intervals.
# Configure IP addresses as required so the device and the collector can reach each other. (Details not shown.)
# Create a sensor group named test, and add sensor path ifmgr/devicecapabilities/.
[Device] telemetry
[Device-telemetry] sensor-group test
[Device-telemetry-sensor-group-test] sensor path ifmgr/devicecapabilities/
[Device-telemetry-sensor-group-test] quit
# Create a destination group named collector1. Specify a collector that uses IPv4 address 192.168.2.1 and port number 50050.
[Device-telemetry] destination-group collector1
[Device-telemetry-destination-group-collector1] ipv4-address 192.168.2.1 port 50050
[Device-telemetry-destination-group-collector1] quit
# Configure a subscription named A to bind sensor group test with destination group collector1. Set the data collection interval to 10 seconds.
[Device-telemetry] subscription A
[Device-telemetry-subscription-A] sensor-group test sample-interval 10
[Device-telemetry-subscription-A] destination-group collector1
[Device-telemetry-subscription-A] quit
# Verify that the collector receives the device capability information of the interface module from the device at 10-second intervals. (Details not shown.)
Protocol buffer code
Protocol buffer code format
Google Protocol Buffers provide a flexible mechanism for serializing structured data. Different from XML code and JSON code, the protocol buffer code is binary and provides higher performance.
Table 2 compares a protocol buffer code format example and the corresponding JSON code format example.
Table 2 Protocol buffer and JSON code format examples
Protocol buffer code format example |
Corresponding JSON code format example |
{ 1:“H3C” 2:“H3C” 3:“H3C Simware” 4:“Syslog/LogBuffer” 5:"notification": { "Syslog": { "LogBuffer": { "BufferSize": 512, "BufferSizeLimit": 1024, "DroppedLogsCount": 0, "LogsCount": 100, "LogsCountPerSeverity": { "Alert": 0, "Critical": 1, "Debug": 0, "Emergency": 0, "Error": 3, "Informational": 80, "Notice": 15, "Warning": 1 }, "OverwrittenLogsCount": 0, "State": "enable" } }, "Timestamp": "1527206160022" } } |
{ "producerName": "H3C", "deviceName": "H3C", "deviceModel": "H3C Simware", "sensorPath": "Syslog/LogBuffer", "jsonData": { "notification": { "Syslog": { "LogBuffer": { "BufferSize": 512, "BufferSizeLimit": 1024, "DroppedLogsCount": 0, "LogsCount": 100, "LogsCountPerSeverity": { "Alert": 0, "Critical": 1, "Debug": 0, "Emergency": 0, "Error": 3, "Informational": 80, "Notice": 15, "Warning": 1 }, "OverwrittenLogsCount": 0, "State": "enable" } }, "Timestamp": "1527206160022" } } } |
You can define data structures in a proto definition file. Then, you can compile the file with utility protoc to generate code in a programing language such as Java and C++. Using the generated code, you can develop an application for a collector to communicate with the device.
H3C provides proto definition files for both dial-in mode and dial-out mode.
Public proto definition files
Dial-in mode supports the following public proto definition files:
· grpc_service.proto—Defines the public RPC methods in dial-in mode.
· gnmi.proto—Defines the public RPC methods for gNMI operations.
· gnmi_ext.proto—Defines the expanded message structures required by file gnmi.proto.
Files gnmi.proto and gnmi_ext.proto are from Google. For information about the download paths, see "Obtaining proto definition files."
The grpc_service.proto file is provided by H3C. The following are the contents of the file:
syntax = "proto2";
package grpc_service;
message GetJsonReply { // Reply to the Get method
required string result = 1;
message SubscribeReply { // Subscription result
message ConfigReply { // Configuration result
message ReportEvent { // Subscribed event
required string token_id = 1; // Login token_id
required string stream_name = 2; // Event stream name
required string event_name = 3; // Event name
required string json_text = 4; // Subscription result, a JSON string
message GetReportRequest{ // Obtains the event subscription result
required string token_id = 1; // Returns the token_id upon a successful login
message LoginRequest { // Login request parameters
required string user_name = 1; // Username
required string password = 2; // Password
message LoginReply { // Reply to a login request
message LogoutRequest { // Logout parameter
required string token_id = 1; // token_id
message LogoutReply { // Reply to a logout request
required string result = 1; // Logout result
message SubscribeRequest { // Event stream name
required string stream_name = 1;
message CliConfigArgs { // Sends a configuration command and the parameters to the device
required int64 ReqId = 1; // Request ID of the command
required string cli = 2; // Command line of the configuration command
message CliConfigReply { // Reply to a configuration command execution request
required int64 ResReqId = 1; // Request ID, which corresponds to that in CliConfigArgs
required string output = 2; // Output from the command
required string errors = 3; // Command execution result
message DisplayCmdArgs { // Sends a display command and the parameters to the device
required string cli = 2; // Command line of the display command
message DisplayCmdReply { // Reply to a display command execution request
required int64 ResReqId = 1; // Request ID, which corresponds to that in DisplayCmdArgs
service GrpcService { // gRPC methods
rpc Login (LoginRequest) returns (LoginReply) {} // Login method
rpc Logout (LogoutRequest) returns (LogoutReply) {} // Logout method
rpc SubscribeByStreamName (SubscribeRequest) returns (SubscribeReply) {} // Event subscription method
rpc GetEventReport (GetReportRequest) returns (stream ReportEvent) {} // Method for obtaining the subscribed event
rpc CliConfig (CliConfigArgs) returns (stream CliConfigReply) {} // Method for executing a configuration command and returning the execution result
rpc DisplayCmdTextOutput(DisplayCmdArgs) returns(stream DisplayCmdReply) {} // Method for executing a display command and returning the execution result
Proto definition files for service modules
The dial-in mode supports proto definition files for the following service modules: Device, Ifmgr, IPFW, LLDP, and Syslog.
The following are the contents of the Device.proto file, which defines the RPC methods for the Device module:
syntax = "proto2";
import "grpc_service.proto";
package device;
message DeviceBase { // Structure for obtaining basic device information
optional string HostName = 1; // Device name
optional string HostOid = 2; // sysoid
optional uint32 MaxChassisNum = 3; // Maximum number of chassis
optional uint32 MaxSlotNum = 4; // Maximum number of slots
optional string HostDescription = 5; // Device description
message DevicePhysicalEntities { // Structure for obtaining physical entity information of the device
message Entity {
optional uint32 PhysicalIndex = 1; // Entity index
optional string VendorType = 2; // Vendor type
optional uint32 EntityClass = 3; // Entity class
optional string SoftwareRev = 4; // Software version
optional string SerialNumber = 5; // Serial number
optional string Model = 6; // Model
repeated Entity entity = 1;
service DeviceService { // RPC methods
rpc GetJsonDeviceBase(DeviceBase) returns (grpc_service.GetJsonReply) {} // Method for obtaining basic device information
rpc GetJsonDevicePhysicalEntities(DevicePhysicalEntities) returns (grpc_service.GetJsonReply) {} // Method for obtaining physical entity information of the device
The grpc_dialout.proto file defines the public RPC methods in dial-out mode. The following are the contents of the file:
syntax = "proto2";
package grpc_dialout;
message DeviceInfo{ // Pushed device information
required string producerName = 1; // Vendor name
required string deviceName = 2; // Device name
required string deviceModel = 3; // Device model
message DialoutMsg{ // Format of the pushed data
required DeviceInfo deviceMsg = 1; // Device information described by DeviceInfo
required string sensorPath = 2; // Sensor path, which corresponds to xpath in NETCONF
required string jsonData = 3; // Sampled data, a JSON string
message DialoutResponse{ // Response from the collector. Reserved. The value is not processed.
required string response = 1;
service GRPCDialout { // Data push method
rpc Dialout(stream DialoutMsg) returns (DialoutResponse);
To obtain files gnmi.proto and gnmi_ext.proto, access the following download links:
· https://github.com/openconfig/gnmi/tree/master/proto/gnmi/gnmi.proto
· https://github.com/openconfig/gnmi/tree/master/proto/gnmi_ext/gnmi_ext.proto
To obtain other proto definition files, contact H3C Support.
Use a language (for example, C++) to develop a gRPC collector-side application on Linux to achieve the following goals:
· Collect device data by using Get, gNMI Capabilities, gNMI Get, or gNMI Subscribe operations in dial-in mode or by using dial-out mode.
· Send settings to the device by using gNMI Set or CLI operations in dial-in mode.
1. Obtain proto definition files.
¡ For Get operations in dial-in mode, obtain the grpc_service.proto file and proto definition files for service modules.
¡ For gNMI operations in dial-in mode, obtain files grpc_service.proto, gnmi.proto, and gnmi_ext.proto.
¡ For CLI operations in dial-in mode, obtain the grpc_service.proto file.
¡ For dial-out mode, obtain the grpc_dialout.proto file.
2. Obtain utility protoc from https://github.com/google/protobuf/releases.
3. Obtain the protobuf plug-in for C++ (protobuf-cpp) from https://github.com/google/protobuf/releases.
Dial-in mode
# Copy the required proto definition files to the current directory, for example, grpc_service.proto and BufferMonitor.proto.
$protoc --plugin=./grpc_cpp_plugin --grpc_out=. --cpp_out=. *.proto
Dial-out mode
# Copy proto definition file grpc_dialout.proto to the current directory.
$ protoc --plugin=./grpc_cpp_plugin --grpc_out=. --cpp_out=. *.proto
In dial-in mode, the application needs to provide the code to be run on the gRPC client.
The C++ code generated from the proto definition files already encapsulates the service classes. For the gRPC client to initiate RPC requests, you only need to call the RPC method in the application.
The application performs the following operations:
· Log in to obtain the token_id.
· Prepare parameters for the RPC method, use the service classes generated from the proto definition files to call the RPC method, and resolve the returned result.
· Log out.
Using Get operations
Service classes GrpcService and BufferMonitorService are used in this example.
To develop the collector-side application:
1. Create a GrpcServiceTest class.
# In the class, use the GrpcService::Stub class generated from grpc_service.proto. Implement login and logout with the Login and Logout methods generated from grpc_service.proto.
class GrpcServiceTest
public:
/* Constructor functions */
GrpcServiceTest(std::shared_ptr<Channel> channel): GrpcServiceStub(GrpcService::NewStub(channel)) {}
/* Member functions */
int Login(const std::string& username, const std::string& password);
void Logout();
void listen();
Status listen(const std::string& command);
/* Member variable */
std::string token;
private:
std::unique_ptr<GrpcService::Stub> GrpcServiceStub; // Use the GrpcService::Stub class generated from grpc_service.proto.
2. Customize the Login method.
# Call the Login method of the GrpcService::Stub class to allow a user who provides the correct the username and password to log in.
int GrpcServiceTest::Login(const std::string& username, const std::string& password)
LoginRequest request; // Username and password.
request.set_user_name(username);
request.set_password(password);
LoginReply reply;
ClientContext context;
// Call the Login method.
Status status = GrpcServiceStub->Login(&context, request, &reply);
if (status.ok())
std::cout << "login ok!" << std::endl;
std::cout <<"token id is :" << reply.token_id() << std::endl;
token = reply.token_id(); // The login succeeds. The token is obtained.
return 0;
else{
std::cout << status.error_code() << ": " << status.error_message()
<< ". Login failed!" << std::endl;
return -1;
3. Initiate an RPC request to the device.
In this example, the application subscribes to interface packet drop events.
rpc SubscribePortQueDropEvent(PortQueDropEvent) returns (grpc_service.SubscribeReply) {}
4. Create the BufMon_GrpcClient class to encapsulate the RPC method.
# Use the BufferMonitorService::Stub class generated from BufferMonitor.proto to call the RPC method.
class BufMon_GrpcClient
public:
BufMon_GrpcClient(std::shared_ptr<Channel> channel): mStub(BufferMonitorService::NewStub(channel))
std::string BufMon_Sub_AllEvent(std::string token);
std::string BufMon_Sub_BoardEvent(std::string token);
std::string BufMon_Sub_PortOverrunEvent(std::string token);
std::string BufMon_Sub_PortDropEvent(std::string token);
/* Get entries */
std::string BufMon_Sub_GetStatistics(std::string token);
std::string BufMon_Sub_GetGlobalCfg(std::string token);
std::string BufMon_Sub_GetBoardCfg(std::string token);
std::string BufMon_Sub_GetNodeQueCfg(std::string token);
std::string BufMon_Sub_GetPortQueCfg(std::string token);
private:
std::unique_ptr<BufferMonitorService::Stub> mStub; // Use the class generated from BufferMonitor.proto.
5. Use std::string BufMon_Sub_PortDropEvent(std::string token) to implement interface packet drop event subscription.
std::string BufMon_GrpcClient::BufMon_Sub_PortDropEvent(std::string token)
std::cout << "-------BufMon_Sub_PortDropEvent-------- " << std::endl;
PortQueDropEvent stNodeEvent;
PortQueDropEvent_PortQueDrop* pstParam = stNodeEvent.add_portquedrop();
UINT uiIfIndex = 0;
UINT uiQueIdx = 0;
UINT uiAlarmType = 0;
std::cout<<"Please input interface queue info : ifIndex queIdx alarmtype " << std::endl;
cout<<"alarmtype : 1 for ingress; 2 for egress; 3 for port headroom"<<endl;
std::cin>>uiIfIndex>>uiQueIdx>>uiAlarmType; // Set the subscription parameters and interface index.
pstParam->set_ifindex(uiIfIndex);
pstParam->set_queindex(uiQueIdx);
pstParam->set_alarmtype(uiAlarmType);
/* Token needs to be added to context */ // Set the token_id to be returned after a successful login
std::string key = "token_id";
std::string value = token;
context.AddMetadata(key, value);
SubscribeReply reply;
Status status = mStub->SubscribePortQueDropEvent(&context,stNodeEvent,&reply); // Call the RPC method.
return reply.result();
6. Use a loop to listen for event reports.
# Implement this method in the GrpcServiceTest class.
void GrpcServiceTest::listen()
GetReportRequest reportRequest;
ReportEvent reportedEvent;
/* Add the token to the request */
reportRequest.set_token_id(token);
std::unique_ptr< ClientReader< ReportEvent>> reader(GrpcServiceStub->GetEventReport(&context, reportRequest)); // Use GetEventReport (which is generated from grpc_service.proto) to obtain event information.
std::string streamName;
std::string eventName;
std::string jsonText;
std::string token;
JsonFormatTool jsonTool;
std::cout << "Listen to server for Event" << std::endl;
while(reader->Read(&reportedEvent) ) // Read the received event report.
streamName = reportedEvent.stream_name();
eventName = reportedEvent.event_name();
jsonText = reportedEvent.json_text();
token = reportedEvent.token_id();
std::cout << "/***********EVENT COME**************/" << std::endl;
std::cout << "TOKEN: " << token << std::endl;
std::cout << "StreamName: "<< streamName << std::endl;
std::cout << "EventName: " << eventName << std::endl;
std::cout << "JsonText without format: " << std::endl << jsonText << std::endl;
std::cout << std::endl;
std::cout << "JsonText Formated: " << jsonTool.formatJson(jsonText) << std::endl;
Status status = reader->Finish();
std::cout << "Status Message:" << status.error_message() << "ERROR code :" << status.error_code();
} // Login and RPC request finished.
7. To log out, call the Logout method.
void GrpcServiceTest:: Logout ()
LogoutRequest request;
request.set_token_id(token);
LogoutReply reply;
Status status = mStub->Logout(&context, request, &reply);
std::cout << "Logout! :" << reply.result() << std::endl;
Using gNMI Capabilities operations
See step 1 in "Using Get operations."
See step 2 in "Using Get operations."
rpc Capabilities(CapabilityRequest) returns (CapabilityResponse);
4. Create the gnmi_client class to encapsulate the RPC method.
class gnmi_client
public:
explicit gnmi_client(const std::string &address,const std::string &tokenId);
bool TestCapabilities();
bool TestGet();
bool TestSet();
bool TestSubscribePool();
bool TestSubscribeOnce();
bool TestSubscribeStream();
bool TestSubscribeStreamWithAlias();
private:
void PrintCapabilityResponse(const gnmi::CapabilityResponse &response);
void PrintGetResponse(const gnmi::GetResponse &response);
void PrintSubscribeResponse(const gnmi::SubscribeResponse &response);
void PrintSubscribeRequest(const gnmi::SubscribeRequest &request);
void PrintGetRequest(const gnmi::GetRequest &request);
void PrintSetRequest(const gnmi::SetRequest &request);
void FillGetRequest(gnmi::GetRequest &request);
void FillSetRequest(gnmi::SetRequest &request);
void FillSubscribeRequestByOnce(gnmi::SubscribeRequest &request);
void FillSubscribeRequestByPool(gnmi::SubscribeRequest &request);
void FillSubscribeRequestByStream(gnmi::SubscribeRequest &request);
void FillSubscribePool(gnmi::SubscribeRequest &request);
void FillSubscribeAlias(gnmi::SubscribeRequest &request);
private:
std::unique_ptr<gnmi::gNMI::Stub> mStubGnmiService;
std::string mTokenID;
5. Use the TestCapabilities() method to obtain the capabilities.
bool gnmi_client::TestCapabilities()
CapabilityRequest request;
CapabilityResponse response;
context.AddMetadata("token_id", mTokenID);
std::cout << std::endl << "CapabilitiesRequest => " << std::endl;
Status ret = mStubGnmiService->Capabilities(&context,request,&response);
if( StatusCode::OK != ret.error_code() )
cout << "TestCapabilities ErrorMessage:" << ret.error_message() << endl;
return false;
else
PrintCapabilityResponse(response);
return true;
6. To log out, call the Logout method.
See step 7 in "Using Get operations."
Using gNMI Get operations
rpc Get(GetRequest) returns (GetResponse);
See step 4 in "Using gNMI Capabilities operations."
5. Use the TestGet() method to obtain the Device/Base/HostName.
bool gnmi_client::TestGet()
GetRequest request;
FillGetRequest(request);
PrintGetRequest(request);
GetResponse response;
Status ret = mStubGnmiService->Get(&context,request,&response);
cout << "TestGet ErrorMessage:" << ret.error_message() << endl;
return false;
else
PrintGetResponse(response);
return true;
void gnmi_client::FillGetRequest(gnmi::GetRequest &request)
auto prefix = request.mutable_prefix();
auto pathelem01 = prefix->add_elem();
pathelem01->set_name("Device");
auto path1 = request.add_path();
auto pathelem02 = path1->add_elem();
pathelem02->set_name("Base");
auto pathelem03 = path1->add_elem();
pathelem03->set_name("HostName");
Using gNMI Set operations
This example uses the Device module.
rpc Set(SetRequest) returns (SetResponse)
4. Create a gNMITest class to encapsulate the RPC method.
Use the gNMI::Stub class that is automatically created by gnmi.proto to call the RPC method.
class gNMITest
public:
gNMITest(std::shared_ptr<Channel> channel, const std::string tokenId ):
mStubGrpcService(GrpcService::NewStub(channel)),
mStubgNMIService(gNMI::NewStub(channel)),
mTokenID(tokenId ){}
SetResponse TestSetResponseInformation(SetRequest &request, const std::string tokenId);
/*---delete: Device/Base/HostName Restore the default for HostName -----------*/
SetResponse DeleteDeviceBaseHostName(); /* delete: Device Base/HostName*/
/* update: Device/Base/HostName, string_val("string_hostname") */
SetResponse UpdateDeviceBaseHostNameStringVal();
/* replace: Device/Base/HostName, string_val("string_hostname") */
REPL_001 SetResponse ReplaceDeviceBaseHostNameStringVal();
private:
std::unique_ptr<GrpcService::Stub> mStubGrpcService;
std::unique_ptr<gNMI::Stub> mStubgNMIService;
5. Use customized methods to perform gNMI Set operations on service data, for example, on the Device module.
// Call the Set method to implement communication between client and server and get the response.
SetResponse gNMITest::TestSetResponseInformation(SetRequest &request, const std::string tokenId)
SetResponse reply;
context.AddMetadata("token_id", tokenId);
/* Call the Set method */
Status ret = mStubgNMIService->Set(&context,request,&reply);
if( StatusCode::OK != ret.error_code())
std::cout<<"error: "<<ret.error_message()<<std::endl;
return reply;
// Delete operation
SetResponse gNMITest:: DeleteDeviceBaseHostName () /* prefix == Device/Base */
SetRequest request;
/* SetRequest->prefix */
Path *path01 = request.mutable_prefix();
PathElem *pathelem01 = path01->add_elem();
PathElem *pathelem02 = path01->add_elem();
/* SetRequest->delete */
Path *path02 = request.add_delete_();
PathElem *pathelem03 = path02->add_elem();
/* Gather response info. */
return TestSetResponseInformation(request, mTokenID);
// Update operation
SetResponse gNMITest::UpdateDeviceBaseHostNameStringVal()
SetRequest request;
/* SetRequest->update */
Update *update01 = request.add_update();
Path *path02 = update01->mutable_path();
TypedValue *typevalue01 = update01->mutable_val();
typevalue01->set_string_val("string_hostname");
// Replace operation
SetResponse gNMITest::ReplaceDeviceBaseHostNameStringVal()
SetRequest request;
/* SetRequest->replace */
Update *replace01 = request.add_replace();
Path *path02 = replace01->mutable_path();
TypedValue *typevalue01 = replace01->mutable_val();
Using gNMI Subscribe operations
rpc Subscribe(stream SubscribeRequest) returns (stream SubscribeResponse);
5. Create a subscribe method.
void gnmi_client::FillSubscribeRequestByOnce(gnmi::SubscribeRequest &request)
auto subscribeList = request.mutable_subscribe();
auto prefix = subscribeList->mutable_prefix();
pathelem01->set_name("LLDP");
auto subscribe = subscribeList->add_subscription();
auto path = subscribe->mutable_path();
auto pathelem02 = path->add_elem();
pathelem02->set_name("NeighborEvent");
auto pathelem03 = path->add_elem();
pathelem03->set_name("Neighbor");
(*pathelem03->mutable_key())["IfName"] = "xxx";
subscribeList->set_mode(::gnmi::SubscriptionList_Mode_ONCE);
subscribeList->set_encoding(::gnmi::JSON);
void gnmi_client::FillSubscribeRequestByPool(gnmi::SubscribeRequest &request)
pathelem02->set_name("CPUs");
pathelem03->set_name("CPU");
auto pathelem04 = path->add_elem();
pathelem04->set_name("CPUUsage");
subscribeList->set_mode(::gnmi::SubscriptionList_Mode_POLL);
void gnmi_client::FillSubscribeRequestByStream(gnmi::SubscribeRequest &request)
pathelem01->set_name("Diagnostic");
pathelem02->set_name("CPUEvent");
(*pathelem03->mutable_key())["Chassis#condition"] = "equal:1";
subscribe->set_mode(::gnmi::ON_CHANGE);
subscribe->set_sample_interval(1000);
subscribe->set_suppress_redundant(false);
subscribe->set_heartbeat_interval(1000);
subscribeList->set_mode(::gnmi::SubscriptionList_Mode_STREAM);
void gnmi_client::FillSubscribeAlias(gnmi::SubscribeRequest &request)
auto aliases = request.mutable_aliases();
auto alias = aliases->add_alias();
auto path = alias->mutable_path();
auto pathelem01 = path->add_elem();
alias->set_alias("#cpu_usage");
Using CLI operations
This example uses the CliConfig method in file grpc_service.proto.
4. Use the GrpcServiceTest class to encapsulate the RPC method in the same way you do for Get operations.
5. Use a customized method to support CliConfig operations.
// Make a thread to listen to the sever and get messages
Status GrpcServiceTest::listen(const std::string& command)
CliConfigArgs reportRequest;
CliConfigReply reportedEvent;
/* Add token to request */
reportRequest.set_reqid(12345678);
reportRequest.set_cli(command);
std::unique_ptr< ClientReader< CliConfigReply>> reader(mStub->CliConfig(&context, reportRequest));
std::string output;
int64 resreqid;
std::cout << "Command result" << std::endl;
while( reader->Read(&reportedEvent) )
streamName = reportedEvent.errors();
output = reportedEvent.output();
resreqid = reportedEvent.resreqid();
std::cout << "resreqid: "<< resreqid << std::endl;
std::cout << "errors: "<< streamName << std::endl;
std::cout << "output: \n"<< output << "\n"<< std::endl;
return status;
6. Use a loop in the main function to wait for commands.
Use the GrpcServiceTest class.
int main(int argc, char *argv[])
const char *cmd;
unsigned int i = 0;
unsigned int cycle = 0;
if (4 == argc)
g_server_address = argv[1];
g_username = argv[2];
g_password = argv[3];
std::cout << "server_address: " << g_server_address <<std::endl;
std::cout << "username: " << g_username << " " << "password: " << g_password << std::endl;
auto channel = grpc::CreateChannel(g_server_address,grpc::InsecureChannelCredentials());
// 1. Log in
GrpcServiceTest reporter(channel);
if(0 != reporter.Login(g_username, g_password))
return 0;
while(1)
{// 2. Read a command and execute the command
std::cout<<"\n\nPlease Input Command:\n";
getline(std::cin,g_command); // Read a command
Status status = reporter.listen(g_command);
if (!status.ok())
std::cout << status.error_code() << ": " << status.error_message() << std::endl;
break;
std::cout<<"Complete exec Command."<<std::endl;
return 0;
In dial-out mode, the application needs to provide the gRPC server code so the collector can receive and resolve data obtained from the device.
· Inherit the automatically generated GRPCDialout::Service class, overload the automatically generated RPC Dialout service, and resolve the fields.
· Register the RPC service with the specified listening port.
To develop the collector-side application in dial-out mode:
1. Inherit and overload RPC service Dialout.
# Create class DialoutTest and inherit GRPCDialout::Service.
class DialoutTest final : public GRPCDialout::Service { // Overload the automatically generated abstract class.
Status Dialout(ServerContext* context, ServerReader< DialoutMsg>* reader, DialoutResponse* response) override; // Implement RPC method Dialout.
2. Register the DialoutTest service as a gRPC service and specify the listening port.
using grpc::Server;
using grpc::ServerBuilder;
std::string server_address("0.0.0.0:60057"); // Specify the address and port to listen to.
DialoutTest dialout_test; // Define the object declared in step 1.
ServerBuilder builder;
builder.AddListeningPort(server_address, grpc::InsecureServerCredentials());// Add the listening port.
builder.RegisterService(&dialout_test); // Register the service.
std::unique_ptr<Server> server(builder.BuildAndStart()); // Start the service.
server->Wait();
3. Implement the Dialout method and data resolution.
Status DialoutTest::Dialout(ServerContext* context, ServerReader< DialoutMsg>* reader, DialoutResponse* response)
DialoutMsg msg;
while( reader->Read(&msg))
const DeviceInfo &device_msg = msg.devicemsg();
std::cout<< "Producer-Name: " << device_msg.producername() << std::endl;
std::cout<< "Device-Name: " << device_msg.devicename() << std::endl;
std::cout<< "Device-Model: " << device_msg.devicemodel() << std::endl;
std::cout<<"Sensor-Path: " << msg.sensorpath()<<std::endl;
std::cout<<"Json-Data: " << msg.jsondata()<<std::endl;
std::cout<<std::endl;
response->set_response("test");
return Status::OK;
4. After obtaining the DialoutMsg object (generated from the proto definition file) through the Read method, you can call the method to obtain the field values.
gNMI operations are intended for data tables and event tables.
· Some data tables are periodically reported and some data tables are reported only when triggered. In the current software version, triggered data tables are not supported.
· All event tables are reported only when triggered.
Methods for adding columns in gNMI operations
Table 3 describes the methods for adding columns in gNMI operations.
Table 3 Methods for adding columns in gNMI operations
Request description |
Sample request |
Sample client-side code |
Set a column of the key. |
path: |
auto pathelem01 = path->add_elem(); |
Set an attribute for a column of the key. |
path: |
Set a column in a group of the key. |
path: |
Set an attribute for a column in a group
of the key. |
path: |
Set an attribute of a column through the
key: |
path: |
Set a column or column attribute in JSON: |
gNMI Get operation attributes
gNMI Get operations support the following attributes:
· regExp—Regular expression.
To implement a complex filtering with characters, you can add a regExp attribute to a specific column.
The following example obtains the interface descriptions that contain only characters in upper case:
pathelem01->set_name("Ifmgr");
pathelem02->set_name("Interfaces");
pathelem03->set_name("Interface");
auto pathelem04 = path1->add_elem();
pathelem04->set_name("Description");
(*pathelem04->mutable_key())["#regExp"] = "^[A-Z]*$";
· match—Conditional match.
Table 4 describes the conditional match operators.
Table 4 Conditional match operators
Operation |
Operator |
More than |
match="more:value" |
More than the specified value. The supported data types include date, digit, and string. |
Less than |
match="less:value" |
Less than the specified value. The supported data types include date, digit, and string. |
Not less than |
match="notLess:value" |
Not less than the specified value. The supported data types include date, digit, and string. |
Not more than |
match="notMore:value" |
Not more than the specified value. The supported data types include date, digit, and string. |
Equal to |
match="equal:value" |
Equal to the specified value. The supported data types include date, digit, string, OID, and BOOL. |
Not equal to |
match="notEqual:value" |
Not equal to the specified value. The supported data types include date, digit, string, OID, and BOOL. |
Include |
match="include:string" |
Includes the specified string. The supported data types include only string. |
Not include |
match="exclude:string" |
Excludes the specified string. The supported data types include only string. |
Start with |
match="startWith:string" |
Starts with the specified string. The supported data types include string and OID. |
End with |
match="endWith:string" |
Ends with the specified string. The supported data types include only string. |
The following example obtains extension information about the entity whose CPU usage is higher than 50%:
pathelem02->set_name("ExtPhysicalEntities");
pathelem03->set_name("Entity");
pathelem04->set_name("CpuUsage");
(*pathelem04->mutable_key())["#match"] = "more:50";
· valuetype—Attribute value type.
When obtaining interface information, the device cannot identify whether an integer value for the IfIndex or vrfindex column represents an interface name or index. To resolve the issue, you can use the valuetype attribute to specify the value type.
The valuetype attribute has the following values:
Value |
name |
The column is carrying a name. |
index |
The column is carrying an index. |
auto |
Default value. The device uses the value of the column as a name for interface matching. If no match is found, the device uses the value as an index for interface matching. |
The following example sets the valuetype attribute to index and set the index to 1 for IfIndex:
pathelem01->set_name("VLAN");
pathelem02->set_name("TrunkInterfaces");
(*pathelem03->mutable_key())["IfIndex"] = "1";
(*pathelem03->mutable_key())["IfIndex#valuetype"] = "index";
· count—Specifies the data entry quantity.
The example sets the count attribute:
pathelem01->set_name("Syslog");
pathelem02->set_name("Logs");
(*pathelem03->mutable_key())["count"] = "5";
pathelem03->set_name("Log");
(*pathelem03->mutable_key())["Index"] = "10";
· Value filtering
You can specify a value for a column in a table to implement full match filtering. If you specify values for multiple columns, the system returns the data that matches all the specified values.
The following example obtains information about interface whose IfIndex is 1.
gNMI Set operation attributes
gNMI Set operations support the following attributes:
· incremental—Adds configuration data to a column without affecting the original data. This attribute applies to a list column such as the vlan permitlist column.
This example adds VLANs 1 through 10 to an untagged VLAN list that has untagged VLANs 12 through 15.
pathelem02->set_name("HybridInterfaces");
Update *Update01 = request.add_update();
Path *path02 = Update01->mutable_path();
(*pathelem03->mutable_key())["IfName"] = "262";
(*pathelem03->mutable_key())["UntaggedVlanList#incremental"] = "true";
(*pathelem03->mutable_key())["UntaggedVlanList"] = "1-10";
When configuring an interface, the device cannot identify whether an integer value for the IfIndex or vrfindex column represents an interface name or index. To resolve the issue, you can use the valuetype attribute to specify the value type.
Value |
name |
index |
auto |
PathElem *pathelem04 = path02->add_elem();
pathelem04->set_name("Interface ");
(*pathelem04->mutable_key())["IfIndex"] = "1";
(*pathelem04->mutable_key())["IfIndex#valuetype"] = "index";
gNMI Subscribe operation attributes
gNMI Subscribe operations support the following attributes:
· All gNMI Get operation attributes. See "gNMI Get operation attributes."
These attributes are used for data table subscription.
· condition—Data pushing condition.
These attributes are used for event table subscription. Values for this attribute are as follows:
¡ more—More than.
¡ less—Less than.
¡ notLess—Not less than.
¡ notMore—Not more than.
¡ equal—Equal to.
¡ notEqual—Not equal to.
¡ include—Include.
¡ exclude—Not include.
¡ startWith—Start with.
¡ endWith—End with.
The following example monitors LLDP events:
(*pathelem03->mutable_key())["IfName"] = "GigabitEthernet2/0/1";
(*pathelem03->mutable_key())["IfName#condition"] = "equal";
