02-Layer 2-LAN Switching Configuration Guide
HomeSupportSwitchesS12500X-AF SeriesConfigure & DeployConfiguration GuidesH3C S12500X-AF Switch Series Configuration Guides(R3606)-6W10002-Layer 2-LAN Switching Configuration Guide
10-Loop detection configuration
10-Loop detection configuration 124.80 KB
Configuring loop detection
About loop detection
The loop detection mechanism performs periodic checking for Layer 2 loops. The mechanism immediately generates a log when a loop occurs so that you are promptly notified to adjust network connections and configurations. You can configure loop detection to shut down the looped interface. Logs are maintained in the information center. For more information, see Network Management and Monitoring Configuration Guide.
Loop detection frame format
The device detects loops by sending detection frames and then checking whether these frames return to any interface on the device. If they do, the device considers that the interface is on a looped link.
Loop detection usually works within a VLAN. If a detection frame is returned with a different VLAN tag than it was sent out with, an inter-VLAN loop has occurred. To remove the loop, examine the QinQ or VLAN mapping configuration for incorrect settings. For more information about QinQ and VLAN mapping, see "Configuring QinQ" and "Configuring VLAN mapping."
Figure 1 Ethernet frame header for loop detection
The Ethernet frame header of a loop detection frame contains the following fields:
·     DMACDestination MAC address of the frame, which is the multicast MAC address 010f-e200-0007. When a loop detection-enabled device receives a frame with this destination MAC address, it performs the following operations:
¡     Sends the frame to the CPU.
¡     Floods the frame in the VLAN from which the frame was originally received.
·     SMACSource MAC address of the frame, which is the bridge MAC address of the sending device.
·     TPIDType of the VLAN tag, with the default value of 0x8100.
·     TCITag control information, including the priority and VLAN ID.
·     TypeProtocol type, with the value of 0x8918.
Figure 2 Inner frame header for loop detection
The loop detection header of a loop detection frame contains the following fields:
·     CodeProtocol sub-type, which is 0x0001, indicating the loop detection type.
·     VersionProtocol version, which is reserved. This field is fixed at 0x0000.
·     LengthLength of the frame. The value includes the inner header, but excludes the Ethernet header.
·     ReservedThis field is reserved.
Frames for loop detection are encapsulated as TLV triplets.
Table 1 TLVs supported by loop detection
TLV
Remarks
End of PDU
End of a PDU.
Optional.
Device ID
Bridge MAC address of the sending device.
Required.
Port ID
ID of the PDU sending port.
Optional.
Port Name
Name of the PDU sending port.
Optional.
System Name
Device name.
Optional.
Chassis ID
Chassis ID of the sending port.
Optional.
Slot ID
Slot ID of the sending port.
Optional.
Sub Slot ID
Sub-slot ID of the sending port.
Optional.
Loop detection interval
Loop detection is a continuous process as the network changes. Loop detection frames are sent at the loop detection interval to determine whether loops occur on interfaces and whether loops are removed.
Loop protection actions
When the device detects a loop on an interface, it generates a log but performs no action on the interface by default. You can configure the device to take one of the following actions:
·     Block—Disables the interface from learning MAC addresses and blocks the interface.
·     No-learning—Disables the interface from learning MAC addresses.
·     Shutdown—Shuts down the interface to disable it from receiving and sending any frames.
Port status auto recovery
When the device configured with the block or no-learning loop action detects a loop on an interface, it performs the action and waits three loop detection intervals. If the device does not receive a loop detection frame within three loop detection intervals, it performs the following operations:
·     Automatically sets the interface to the forwarding state.
·     Notifies the user of the event.
When the device configured with the shutdown action detects a loop on an interface, the following events occur:
1.     The device automatically shuts down the interface.
2.     The device automatically sets the interface to the forwarding state after the detection timer set by using the shutdown-interval command expires. For more information about the shutdown-interval command, see Fundamentals Command Reference.
3.     The device shuts down the interface again if a loop is still detected on the interface when the detection timer expires.
This process is repeated until the loop is removed.
Incorrect recovery can occur when loop detection frames are discarded to reduce the load. To avoid this, use the shutdown action, or manually remove the loop.
Loop detection tasks at a glance
To configure loop detection, perform the following tasks:
1.     Enabling loop detection
¡     Enabling loop detection globally
¡     Enabling loop detection on an
2.     (Optional) Setting the loop protection action
¡     Setting the global loop protection action
¡     Setting the loop protection action on an interface
3.     (Optional) Setting the loop detection interval
Restrictions and guidelines for loop detection configuration
You can enable loop detection globally or on a per-interface basis. When an interface receives a detection frame in any VLAN, the loop protection action is triggered on that interface, regardless of whether loop detection is enabled on it.
2.     Globally enable loop detection.
loopback-detection global enable vlan { vlan-id--list | all }
By default, loop detection is globally disabled.
Enabling loop detection on an interface
2.     Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
3.     Enable loop detection on the interface.
loopback-detection enable vlan { vlan-id--list | all }
By default, loop detection is disabled on interfaces.
Restrictions and guidelines for loop protection action configuration
You can set the loop protection action globally or on a per-interface basis. The global action applies to all interfaces. The per-interface action applies to the individual interfaces. The per-interface action takes precedence over the global action.
2.     Set the global loop protection action.
loopback-detection global action shutdown
By default, the device generates a log but performs no action on the interface on which a loop is detected.
2.     Enter interface view.
3.     Set the loop protection action on the interface.
loopback-detection action { block | no-learning | shutdown }
Support for the keywords of this command varies with interface type. For more information, see Layer 2LAN Switching Command Reference.
With loop detection enabled, the device sends loop detection frames at the loopback detection interval. A shorter interval offers more sensitive detection but consumes more resources. Consider the system performance and loop detection speed when you set the loop detection interval.
2.     Set the loop detection interval.
loopback-detection interval-time interval
The default loop detection interval is 30 seconds.
Display and maintenance commands for loop detection
Display the loop detection configuration and status.
display loopback-detection
Loop detection configuration examples
Example: Configuring basic loop detection functions
As shown in Figure 3, configure loop detection on Device A to meet the following requirements:
·     Device A generates a log as a notification.
·     Device A automatically shuts down the interface on which a loop is detected.
Figure 3 Network diagram
IMPORTANT
IMPORTANT:
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
By default, a physical port operates in Layer 3 mode. To configure a physical port as a Layer 2 interface, use the port link-mode command.
1.     Configure Device A:
# Create VLAN 100, and globally enable loop detection for the VLAN.
[DeviceA] vlan 100
[DeviceA-vlan100] quit
[DeviceA] loopback-detection global enable vlan 100
# Configure HundredGigE 1/0/1 and HundredGigE 1/0/2 as trunk ports, and assign them to VLAN 100.
[DeviceA] interface HundredGigE 1/0/1
[DeviceA-HundredGigE1/0/1] port link-type trunk
[DeviceA-HundredGigE1/0/1] port trunk permit vlan 100
[DeviceA-HundredGigE1/0/1] quit
[DeviceA] interface hundredgige 1/0/2
[DeviceA-HundredGigE1/0/2] port link-type trunk
[DeviceA-HundredGigE1/0/2] port trunk permit vlan 100
[DeviceA-HundredGigE1/0/2] quit
# Set the global loop protection action to shutdown.
[DeviceA] loopback-detection global action shutdown
# Set the loop detection interval to 35 seconds.
[DeviceA] loopback-detection interval-time 35
2.     Configure Device B:
# Create VLAN 100.
[DeviceB] vlan 100
[DeviceB–vlan100] quit
[DeviceB] interface hundredgige 1/0/1
[DeviceB-HundredGigE1/0/1] port link-type trunk
[DeviceB-HundredGigE1/0/1] port trunk permit vlan 100
[DeviceB-HundredGigE1/0/1] quit
[DeviceB] interface hundredgige 1/0/2
[DeviceB-HundredGigE1/0/2] port link-type trunk
[DeviceB-HundredGigE1/0/2] port trunk permit vlan 100
[DeviceB-HundredGigE1/0/2] quit
3.     Configure Device C:
# Create VLAN 100.
<DeviceC> system-view
[DeviceC] vlan 100
[DeviceC–vlan100] quit
[DeviceC] interface hundredgige 1/0/1
[DeviceC-HundredGigE1/0/1] port link-type trunk
[DeviceC-HundredGigE1/0/1] port trunk permit vlan 100
[DeviceC-HundredGigE1/0/1] quit
[DeviceC] interface hundredgige 1/0/2
[DeviceC-HundredGigE1/0/2] port link-type trunk
[DeviceC-HundredGigE1/0/2] port trunk permit vlan 100
[DeviceC-HundredGigE1/0/2] quit
# View the system logs on devices, for example, Device A.
[DeviceA]
%Feb 24 15:04:29:663 2013 DeviceA LPDT/4/LPDT_LOOPED: A loop was detected on HundredGigE1/0/1.
%Feb 24 15:04:29:664 2013 DeviceA LPDT/4/LPDT_VLAN_LOOPED: A loop was detected on HundredGigE1/0/1 in VLAN 100.
%Feb 24 15:04:29:667 2013 DeviceA LPDT/4/LPDT_LOOPED: A loop was detected on HundredGigE1/0/2.
%Feb 24 15:04:29:668 2013 DeviceA LPDT/4/LPDT_VLAN_LOOPED: A loop was detected on HundredGigE1/0/2 in VLAN 100.
%Feb 24 15:04:44:243 2013 DeviceA LPDT/5/LPDT_VLAN_RECOVERED: A loop was removed on HundredGigE1/0/1 in VLAN 100.
%Feb 24 15:04:44:243 2013 DeviceA LPDT/5/LPDT_RECOVERED: All loops were removed on HundredGigE1/0/1.
%Feb 24 15:04:44:248 2013 DeviceA LPDT/5/LPDT_VLAN_RECOVERED: A loop was removed on HundredGigE1/0/2 in VLAN 100.
%Feb 24 15:04:44:248 2013 DeviceA LPDT/5/LPDT_RECOVERED: All loops were removed on HundredGigE1/0/2.
·     Device A detected loops on HundredGigE 1/0/1 and HundredGigE 1/0/2 within a loop detection interval.
·     Loops on HundredGigE 1/0/1 and HundredGigE 1/0/2 were removed.
# Use the display loopback-detection command to display the loop detection configuration and status on devices, for example, Device A.
[DeviceA] display loopback-detection
Loop detection is enabled.
Loop detection interval is 35 second(s).
No loopback is detected.
The output shows that the device has removed the loops from HundredGigE 1/0/1 and HundredGigE 1/0/2 according to the shutdown action.
# Display the status of HundredGigE 1/0/1 on devices, for example, Device A.
[DeviceA] display interface hundredgige 1/0/1
HundredGigE1/0/1 current state: DOWN (Loop detection down)
The output shows that HundredGigE 1/0/1 is already shut down by the loop detection module.
# Display the status of HundredGigE 1/0/2 on devices, for example, Device A.
[DeviceA] display interface hundredgige 1/0/2
HundredGigE1/0/2 current state: DOWN (Loop detection down)
The output shows that HundredGigE 1/0/2 is already shut down by the loop detection module.
