08-IP Multicast Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SR6600 SR6600-X Routers Configuration Guides(V7)-R7809-6W30008-IP Multicast Configuration Guide
11-IPv6 PIM configuration
11-IPv6 PIM configuration 966.23 KB
IPv6 PIM overview·· 1
IPv6 PIM modes· 1
IPv6 PIM-DM·· 1
Neighbor discovery· 1
SPT building· 1
Graft 2
Assert 3
IPv6 PIM-SM·· 3
Neighbor discovery· 4
DR election· 4
RP discovery· 4
Embedded RP· 6
Anycast RP· 7
RPT building· 8
IPv6 multicast source registration· 8
Switchover to SPT· 9
Assert 10
IPv6 BIDIR-PIM·· 10
Neighbor discovery· 10
RP discovery· 10
DF election· 11
Bidirectional RPT building· 11
IPv6 administrative scoping· 13
IPv6 administrative scoping mechanism·· 13
Relationship between IPv6 admin-scoped zones and the IPv6 global-scoped zone· 14
IPv6 PIM-SSM·· 15
Neighbor discovery· 15
DR election· 16
SPT building· 16
Relationship among IPv6 PIM protocols· 16
IPv6 PIM support for VPNs· 17
Protocols and standards· 17
Configuring IPv6 PIM·· 0
Restrictions and guidelines: IPv6 PIM configuration· 0
Configuring IPv6 PIM-DM·· 0
IPv6 PIM-DM tasks at a glance· 0
Prerequisites for IPv6 PIM-DM·· 0
Enabling IPv6 PIM-DM·· 0
Configuring the state refresh feature· 1
Setting the IPv6 PIM-DM graft retry timer 2
Configuring IPv6 PIM-SM·· 2
IPv6 PIM-SM tasks at a glance· 2
Prerequisites for IPv6 PIM-SM·· 2
Enabling IPv6 PIM-SM·· 3
Configuring static RPs· 3
Configuring C-RPs· 4
Configuring C-BSRs· 4
Configuring an IPv6 PIM domain border 5
Disabling BSM semantic fragmentation· 5
Disabling the device from forwarding BSMs out of their incoming interfaces· 6
Configuring Anycast RP· 6
Configuring IPv6 multicast source registration· 7
Configuring the switchover to SPT· 8
Configuring IPv6 BIDIR-PIM·· 8
IPv6 BIDIR-PIM tasks at a glance· 8
Prerequisites for IPv6 BIDIR-PIM·· 8
Enabling IPv6 BIDIR-PIM·· 9
Configuring static RPs· 9
Configuring C-RPs· 10
Configuring C-BSRs· 10
Configuring an IPv6 PIM domain border 11
Disabling BSM semantic fragmentation· 11
Disabling the device from forwarding BSMs out of their incoming interfaces· 12
Setting the maximum number of IPv6 BIDIR-PIM RPs· 12
Configuring IPv6 PIM-SSM·· 13
IPv6 PIM-SSM tasks at a glance· 13
Prerequisites for IPv6 PIM-SSM·· 13
Enabling IPv6 PIM-SM·· 13
Specifying the IPv6 SSM group range· 13
Configuring common IPv6 PIM features· 14
Common IPv6 PIM feature tasks at a glance· 14
Configuring an IPv6 multicast source policy· 14
Configuring an IPv6 PIM hello policy· 15
Configuring IPv6 PIM hello message options· 15
Dropping hello messages without the Generation ID option· 17
Configuring common IPv6 PIM timers· 17
Setting the maximum size of a join or prune message· 19
Enabling BFD for IPv6 PIM·· 19
Enabling IPv6 PIM passive mode· 19
Enabling IPv6 PIM NSR· 20
Enabling NBMA mode for IPv6 ADVPN tunnel interfaces· 20
Enabling SNMP notifications for IPv6 PIM·· 21
Display and maintenance commands for IPv6 PIM·· 21
IPv6 PIM configuration examples· 22
Example: Configuring IPv6 PIM-DM·· 22
Example: Configuring non-scoped IPv6 PIM-SM·· 25
Example: Configuring admin-scoped IPv6 PIM-SM·· 28
Example: Configuring IPv6 BIDIR-PIM·· 34
Example: Configuring IPv6 PIM-SSM·· 38
Troubleshooting IPv6 PIM·· 41
A multicast distribution tree cannot be correctly built 41
IPv6 multicast data is abnormally terminated on an intermediate device· 41
An RP cannot join an SPT in IPv6 PIM-SM·· 42
An RPT cannot be built or IPv6 multicast source registration fails in IPv6 PIM-SM·· 42
IPv6 PIM overview
IPv6 Protocol Independent Multicast (IPv6 PIM) provides IPv6 multicast forwarding by leveraging IPv6 unicast static routes or IPv6 unicast routing tables generated by any IPv6 unicast routing protocol. IPv6 PIM uses the underlying IPv6 unicast routing to generate an IPv6 multicast routing table without relying on any particular IPv6 unicast routing protocol.
IPv6 PIM uses the RPF mechanism to implement IPv6 multicast forwarding. For more information about RPF, see "Configuring IPv6 multicast routing and forwarding."
IPv6 PIM modes
Based on the implementation mechanism, IPv6 PIM includes the following modes:
·     IPv6 Protocol Independent Multicast–Dense Mode (IPv6 PIM-DM).
·     IPv6 Protocol Independent Multicast–Sparse Mode (IPv6 PIM-SM).
·     IPv6 Bidirectional Protocol Independent Multicast (IPv6 BIDIR-PIM).
·     IPv6 Protocol Independent Multicast Source-Specific Multicast (IPv6 PIM-SSM).
In this document, an IPv6 PIM domain refers to a network composed of IPv6 PIM devices.
IPv6 PIM-DM
IPv6 PIM-DM uses the push mode for multicast forwarding and is suitable for small networks with densely distributed IPv6 multicast members.
IPv6 PIM-DM assumes that all downstream nodes want to receive IPv6 multicast data from a source, so IPv6 multicast data is flooded to all downstream nodes on the network. Branches without downstream receivers are pruned from the forwarding trees, leaving only those branches that contain receivers. When the pruned branch has new receivers, the graft mechanism turns the pruned branch into a forwarding branch.
In IPv6 PIM-DM, the multicast forwarding paths for an IPv6 multicast group constitute a forwarding tree. The forwarding tree is rooted at the IPv6 multicast source and has multicast group members as its "leaves." Because the forwarding tree consists of the shortest paths from the IPv6 multicast source to the receivers, it is also called a "shortest path tree (SPT)."
IPv6 PIM-DM mechanisms include neighbor discovery, SPT building, graft, and assert.
Neighbor discovery
In an IPv6 PIM domain, each IPv6 PIM interface periodically multicasts IPv6 PIM hello messages to all other IPv6 PIM devices on the local subnet. Through the exchanging of hello messages, all IPv6 PIM devices determine their IPv6 PIM neighbors, maintain IPv6 PIM neighboring relationship with other devices, and build and maintain SPTs.
SPT building
The process of building an SPT is the flood-and-prune process:
1.     In an IPv6 PIM-DM domain, the IPv6 multicast data from the IPv6 multicast source S to the IPv6 multicast group G is flooded throughout the domain. A device performs an RPF check on the IPv6 multicast data. If the check succeeds, the device creates an (S, G) entry and forwards the data to all downstream nodes in the network. In the flooding process, all the devices in the IPv6 PIM-DM domain create the (S, G) entry.
2.     The nodes without downstream receivers are pruned. A device that has no downstream receivers multicasts a prune message to all IPv6 PIM devices on the subnet. When the upstream node receives the prune message, it removes the receiving interface from the (S, G) entry. In this way, the upstream stream node stops forwarding subsequent packets addressed to that IPv6 multicast group down to this node.
An (S, G) entry contains an IPv6 multicast source address S, an IPv6 multicast group address G, an outgoing interface list, and an incoming interface.
A prune process is initiated by a leaf device. As shown in Figure 1, the device interface that does not have any downstream receivers initiates a prune process by sending a prune message toward the IPv6 multicast source. This prune process goes on until only necessary branches are left in the IPv6 PIM-DM domain, and these necessary branches constitute an SPT.
Figure 1 SPT building
The pruned state of a branch has a finite holdtime timer. When the timer expires, IPv6 multicast data is again forwarded to the pruned branch. The flood-and-prune cycle takes place periodically to maintain the forwarding branches.
Graft
A previously pruned branch might have new downstream receivers. To reduce the latency for resuming the forwarding capability of this branch, a graft mechanism is used as follows:
1.     The node that needs to receive the IPv6 multicast data sends a graft message to its upstream node, telling it to rejoin the SPT.
2.     After receiving this graft message on an interface, the upstream node adds the receiving interface to the outgoing interface list of the (S, G) entry. It also sends a graft-ack message to the graft sender.
3.     If the graft sender receives a graft-ack message, the graft process finishes. Otherwise, the graft sender continues to send graft messages at a graft retry interval until it receives an acknowledgment from its upstream node.
Assert
On a subnet with more than one multicast device, the assert mechanism shuts off duplicate multicast flows to the network. It does this by electing a unique multicast forwarder for the subnet.
Figure 2 Assert mechanism
As shown in Figure 2, after Device A and Device B receive an (S, G) packet from the upstream node, they both forward the packet to the local subnet. As a result, the downstream node Device C receives two identical multicast packets. In addition, both Device A and Device B, on their downstream interfaces, receive a duplicate packet forwarded by the other. After detecting this condition, both devices send an assert message to all IPv6 PIM devices on the local subnet through the interface that received the packet. The assert message contains the IPv6 multicast source address (S), the IPv6 multicast group address (G), and the metric preference and metric of the IPv6 unicast route/MBGP route/static multicast route to the IPv6 multicast source. By comparing these parameters, either Device A or Device B becomes the unique forwarder of the subsequent (S, G) packets on the subnet. The comparison process is as follows:
1.     The device with a higher metric preference to the IPv6 multicast source wins.
2.     If both devices have the same metric preference to the IPv6 multicast source, the device with a smaller metric to the IPv6 multicast source wins.
3.     If both devices have the same metric, the device with a higher IPv6 link-local address on the downstream interface wins.
IPv6 PIM-SM
IPv6 PIM-DM uses the flood-and-prune cycles to build SPTs for IPv6 multicast data forwarding. Although an SPT has the shortest paths from the IPv6 multicast source to the receivers, it is built with a low efficiency. Therefore, IPv6 PIM-DM is not suitable for large- and medium-sized networks.
IPv6 PIM-SM uses the pull mode for IPv6 multicast forwarding, and it is suitable for large-sized and medium-sized networks with sparsely and widely distributed IPv6 multicast group members.
IPv6 PIM-SM assumes that no hosts need IPv6 multicast data. A multicast receiver must express its interest in the IPv6 multicast data for an IPv6 multicast group before the data is forwarded to it. A rendezvous point (RP) is the core of an IPv6 PIM-SM domain. Relying on the RP, SPTs and rendezvous point trees (RPTs) are established and maintained to implement IPv6 multicast data forwarding. An SPT is rooted at the IPv6 multicast source and has the RPs as its leaves. An RPT is rooted at the RP and has the receiver hosts as its leaves.
IPv6 PIM-SM mechanisms include neighbor discovery, DR election, RP discovery, Anycast RP, RPT building, multicast source registration, switchover to SPT, and assert.
Neighbor discovery
IPv6 PIM-SM uses the same neighbor discovery mechanism as IPv6 PIM-DM does. For more information, see "Neighbor discovery."
DR election
A designated router (DR) is required on both the source-side network and receiver-side network. A source-side DR acts on behalf of the IPv6 multicast source to send register messages to the RP. The receiver-side DR acts on behalf of the receiver hosts to send join messages to the RP.
IMPORTANT
IMPORTANT:
MLD must be enabled on the device that acts as the receiver-side DR. Otherwise, the receiver hosts attached to the DR cannot join any IPv6 multicast groups. For more information about MLD, see "Configuring MLD."
Figure 3 DR election
As shown in Figure 3, the DR election process is as follows:
1.     The devices on the shared-media LAN send hello messages to one another. The hello messages contain the DR priority for DR election. The device with the highest DR priority is elected as the DR.
2.     The device with the highest IPv6 link-local address wins the DR election under one of the following conditions:
¡     All the devices have the same DR election priority.
¡     A device does not support carrying the DR priority in hello messages.
If the DR fails, its IPv6 PIM neighbor lifetime expires, and the other devices initiate a new DR election.
RP discovery
An RP is the core of an IPv6 PIM-SM domain. An IPv6 multicast group can have only one RP for IPv6 multicast forwarding, and an RP can be designated to multiple IPv6 multicast groups.
RP selection mechanism
An RP can be statically configured, dynamically elected, or extracted from an IPv6 multicast address with embedded RP. The embedded RP takes precedence over the static RP and the dynamic RP. The priorities of the static RP and the dynamic RP depend on whether the static RP is preferred when the static RP is configured.
·     If the static RP is preferred, the static RP takes precedence over the dynamic RP. The dynamic RP takes services over only when the static RP fails.
·     If the static RP is not preferred, the dynamic RP takes precedence over the static RP. The static RP takes services over only when the dynamic RP fails.
Static RPs
A static RP can avoid a single point of failure and save network bandwidth that is consumed by frequent communications between C-RPs and the BSR.
Dynamic RP election
Dynamic RP election is implemented through the BSR mechanism. BSR mechanism includes the following roles:
·     Candidate-RPs (C-RPs)—An RP is dynamically elected from C-RPs to provide services to an IPv6 multicast group.
·     BSR—A BSR is the core of the administrative core of the IPv6 PIM-SM domain. It is responsible for collecting and advertising RP information in the whole domain. An IPv6 PIM-SM domain has only one BSR, and the BSR is elected from C-BSRs.
·     Candidate-BSRs (C-BSRs)—Any devices in the IPv6 PIM-SM domain can act as C-BSRs and the BSR is elected from the C-BSRs. Once the BSR fails, a new BSR is elected from the C-BSRs to avoid multicast traffic interruption.
A device can act as a C-RP and a C-BSR at the same time.
Figure 4 Information exchange between C-RPs and BSR
As shown in Figure 4, an RP is elected as follows:
1.     Each C-BSR sends a BSM to other devices in the IPv6 PIM-SM domain.
2.     When a C-BSR receives a BSM from another C-BSR, it compares its own priority with the priority carried in the message. The C-BSR with a higher priority wins the BSR election. If a tie exists in the priority, the C-BSR with a higher IPv6 address wins. The loser uses the winner's BSR address to replace its own BSR address and no longer regards itself as the BSR. The winner retains its own BSR address and continues to regard itself as the BSR.
3.     Each C-RP periodically unicasts an advertisement message to the BSR. An advertisement message contains the address of the advertising C-RP and the IPv6 multicast group range to which it is designated.
4.     The BSR collects these advertisement messages and organizes the C-RP information into an RP-set, which is a database of mappings between IPv6 multicast groups and RPs. The BSR encapsulates the RP-set information in the BSMs and advertises the BSMs to the entire IPv6 PIM-SM domain.
5.     All devices in the IPv6 PIM-SM domain select an RP for an IPv6 multicast group based on the following rules:
a.     The C-RP that is designated to the smallest IPv6 multicast group range wins.
b.     If the C-RPs are designated to the same group ranges, the C-RP with the highest priority wins.
c.     If the C-RPs have the same priority, the C-RP with the largest hash value wins. The hash value is calculated through the hash algorithm.
d.     If the C-RPs have the same hash value, the C-RP with the highest IP address wins.
Embedded RP
The embedded RP mechanism enables a device to resolve the RP address from an IPv6 multicast group address to map the IPv6 multicast group to an RP. This RP can take the place of the configured static RP or the RP dynamically elected by the bootstrap mechanism. A DR does not need to learn the RP address beforehand. Figure 5 shows the format of an IPv6 multicast group address with embedded RP.
Figure 5 Format of an IPv6 multicast address with embedded RP
http://www.h3c.com/cn/res/200803/05/20080305_333537_image004_336046_30003_0.gif
As shown in Figure 5, the requirements for each field are as follows:
·     First 8 bits—Fixed to 0xFF.
·     Flags—The R, P, and, T bits must be set to 1.
·     Reserved—Contains 4 bits and must be set to 0.
·     RIID—Contains 4 bits and indicates the RP interface ID.
·     Plen—Contains 8 bits and indicates the valid length (in bits) of the RP address prefix. This field value cannot be greater than 64 and cannot be 0.
·     Network prefix—Contains 64 bits and indicates the prefix of the RP address. The valid length of the prefix is determined by the Plen field.
·     Group ID—Reduced to 32 bits and indicates the ID of the IPv6 multicast group.
The process of discovering an embedded RP is as follows:
·     At the receiver side, a receiver host initiates an MLD report to join an IPv6 multicast group. Upon receiving the MLD report, the receiver-side DR resolves the RP address embedded in the IPv6 multicast group address and uses the RP for the IPv6 multicast group.
·     At the IPv6 multicast source side, the IPv6 multicast source sends an IPv6 multicast packet to an IPv6 multicast group. Upon receiving the IPv6 multicast packet, the source-side DR resolves the RP address embedded in the IPv6 multicast address and uses the RP for the IPv6 multicast group.
Anycast RP
IPv6 PIM-SM requires only one active RP to serve each IPv6 multicast group. If the active RP fails, the multicast traffic might be interrupted. The Anycast RP mechanism enables redundancy backup among RPs by configuring multiple RPs with the same IPv6 address for one multicast group. An IPv6 multicast source registers with the closest RP or a receiver-side DR joins the closest RP to implement source information synchronization.
Anycast RP has the following benefits:
·     Optimal RP path—An IPv6 multicast source registers with the closest RP to build an optimal SPT. A receiver joins the closest RP to build an optimal RPT.
·     Redundancy backup among RPs—When an RP fails, the RP-related sources will register with the closest available RPs and the receiver-side DRs will join the closest available RPs. This provides redundancy backup among RPs.
Anycast RP is implemented by using either of the following methods:
·     Anycast RP through MSDP—In this method, you can configure multiple RPs with the same IP address for one multicast group and configure MSDP peering relationships between them. For more information about Anycast RP through MSDP, see "Configuring MSDP."
·     Anycast RP through IPv6 PIM-SM—In this method, you can configure multiple RPs for one IPv6 multicast group and add them to an Anycast RP set. This method introduces the following concepts:
¡     Anycast RP set—A set of RPs that are designated to the same IPv6 multicast group.
¡     Anycast RP member—Each RP in the Anycast RP set.
¡     Anycast RP member address—IPv6 address of each Anycast RP member for communication among the RP members.
¡     Anycast RP address—IPv6 address of the Anycast RP set for communication within the IPv6 PIM-SM domain. It is also known as RPA.
As shown in Figure 6, RP 1, RP 2, and RP 3 are members of an Anycast RP set.
Figure 6 Anycast RP through IPv6 PIM-SM
The following describes how Anycast RP through IPv6 PIM-SM is implemented:
a.     RP 1 receives a register message destined to RPA. Because the message is not from other Anycast RP members (RP 2 or RP 3), RP 1 considers that the register message is from the DR. RP 1 changes the source IPv6 address of the register message to its own IPv6 address and sends the message to the other members (RP 2 and RP 3).
If a device acts as both a DR and an RP, it creates a register message, and then forwards the message to the other RP members.
b.     After receiving the register message, RP 2 and RP 3 find out that the source address of the register message is an Anycast RP member address. They stop forwarding the message to other devices.
In Anycast RP implementation, an RP must forward the register message from the DR to other Anycast RP members to synchronize IPv6 multicast source information.
RPT building
Figure 7 RPT building in an IPv6 PIM-SM domain
As shown in Figure 7, the process of building an RPT is as follows:
1.     When a receiver wants to join the IPv6 multicast group G, it uses an MLD message to inform the receiver-side DR.
2.     After getting the receiver information, the DR sends a join message, which travels hop by hop to the RP for the IPv6 multicast group.
3.     The devices along the path from the DR to the RP form an RPT branch. Each device on this branch adds to its forwarding table a (*, G) entry, where the asterisk (*) represents any IPv6 multicast source. The RPT is rooted at the RP and has the DR as its leaf.
When the IPv6 multicast data addressed to the IPv6 multicast group G reaches the RP, the RP forwards the data to the DR along the established RPT. Finally, the DR forwards the IPv6 multicast data to the receiver hosts.
When a receiver is no longer interested in the IPv6 multicast data addressed to the IPv6 multicast group G, the receiver-side DR sends a prune message. The prune message goes hop by hop along the RPT to the RP. After receiving the prune message, the upstream node deletes the interface that connects to this downstream node from the outgoing interface list. At the same time, the upstream device checks for the existence of receivers for that IPv6 multicast group. If no receivers for the IPv6 multicast group exist, the device continues to forward the prune message to its upstream device.
The IPv6 multicast source uses the registration process to inform an RP of its presence.
Figure 8 IPv6 multicast source registration
As shown in Figure 8, the IPv6 multicast source registers with the RP as follows:
1.     The IPv6 multicast source S sends the first multicast packet to the IPv6 multicast group G. When receiving the multicast packet, the source-side DR that directly connects to the IPv6 multicast source encapsulates the packet into a register message and unicasts the message to the RP.
2.     After the RP receives the register message, it decapsulates it and forwards it down to the RPT. Meanwhile, it sends an (S, G) source-specific join message toward the IPv6 multicast source. The devices along the path from the RP to the IPv6 multicast source constitute an SPT branch. Each device on this branch creates an (S, G) entry in its forwarding table.
3.     The subsequent IPv6 multicast data from the IPv6 multicast source are forwarded to the RP along the SPT. When the IPv6 multicast data reaches the RP along the SPT, the RP forwards the data to the receivers along the RPT. Meanwhile, it unicasts a register-stop message to the source-side DR to prevent the DR from unnecessarily encapsulating the data.
Switchover to SPT
In an IPv6 PIM-SM domain, only one RP and one RPT provide services for a specific IPv6 multicast group. Before the switchover to SPT occurs, the source-side DR encapsulates all IPv6 multicast data in register messages and sends them to the RP. After receiving these register messages, the RP decapsulates them and forwards them to the receiver-side DR along the RPT.
IPv6 multicast forwarding along the RPT has the following weaknesses:
·     Encapsulation and decapsulation are complex on the source-side DR and the RP.
·     The path for an IPv6 multicast packet might not be the shortest one.
·     The RP might be overloaded by IPv6 multicast traffic bursts.
To eliminate these weaknesses, IPv6 PIM-SM allows an RP or the receiver-side DR to initiate the switchover to SPT when the traffic rate exceeds a specific threshold:
·     The RP initiates the switchover to SPT:
The RP periodically checks the multicast packet forwarding rate. If the RP finds that the traffic rate exceeds the specified threshold, it sends an (S, G) source-specific join message toward the IPv6 multicast source. The devices along the path from the RP to the IPv6 multicast source constitute an SPT branch. The subsequent IPv6 multicast data is forwarded to the RP along the SPT without being encapsulated into register messages.
For more information about the switchover to SPT initiated by the RP, see "IPv6 multicast source registration."
·     The receiver-side DR initiates the switchover to SPT:
The receiver-side DR periodically checks the forwarding rate of the multicast packets that the IPv6 multicast source S sends to the IPv6 multicast group G. If the forwarding rate exceeds the specified threshold, the DR initiates the switchover to SPT as follows:
a.     The receiver-side DR sends an (S, G) source-specific join message toward the IPv6 multicast source. The devices along the path create an (S, G) entry in their forwarding table to constitute an SPT branch.
b.     When the multicast packets reach the device where the RPT and the SPT branches, the device drops the multicast packets that travel along the RPT. It then sends a prune message with the RP bit toward the RP.
c.     After receiving the prune message, the RP forwards it toward the IPv6 multicast source (supposed only one receiver exists). Thus, the switchover to SPT is completed. The subsequent IPv6 multicast packets for the IPv6 multicast group travel along the SPT from the IPv6 multicast source to the receiver hosts.
With the switchover to SPT, IPv6 PIM-SM builds SPTs more economically than IPv6 PIM-DM does.
Assert
IPv6 PIM-SM uses a similar assert mechanism as IPv6 PIM-DM does. For more information, see "Assert."
IPv6 BIDIR-PIM
In some many-to-many applications, such as a multi-side video conference, multiple receivers of an IPv6 multicast group might be interested in the IPv6 multicast data from multiple IPv6 multicast sources. With IPv6 PIM-DM or IPv6 PIM-SM, each device along the SPT must create an (S, G) entry for each IPv6 multicast source, consuming a lot of system resources.
IPv6 BIDIR-PIM addresses the problem. Derived from IPv6 PIM-SM, IPv6 BIDIR-PIM builds and maintains a bidirectional RPT, which is rooted at the RP and connects the IPv6 multicast sources and the receivers. Along the bidirectional RPT, the IPv6 multicast sources send IPv6 multicast data to the RP, and the RP forwards the data to the receivers. Each device along the bidirectional RPT needs to maintain only one (*, G) entry, saving system resources.
IPv6 BIDIR-PIM is suitable for a network with dense IPv6 multicast sources and receivers.
IPv6 BIDIR-PIM mechanisms include neighbor discovery, RP discovery, DF election, and bidirectional RPT building.
Neighbor discovery
IPv6 BIDIR-PIM uses the same neighbor discovery mechanism as IPv6 PIM-SM does. For more information, see "Neighbor discovery."
RP discovery
IPv6 BIDIR-PIM supports static RPs and dynamic RP election but does not support embedded RP. It uses the same RP discovery mechanism as IPv6 PIM-SM does. For more information, see "RP discovery." In IPv6 BIDIR-PIM, an RPF interface is the interface toward an RP, and an RPF neighbor is the address of the next hop to the RP.
DF election
On a subnet with multiple multicast devices, duplicate multicast packets might be forwarded to the RP. To address this issue, IPv6 BIDIR-PIM uses a designated forwarder (DF) election mechanism to elect a unique DF on each subnet. Only the DFs can forward IPv6 multicast data to the RP.
DF election is not necessary for an RPL.
Figure 9 DF election
As shown in Figure 9, without the DF election mechanism, both Device B and Device C can receive IPv6 multicast packets from Device A. They also can forward the packets to downstream devices on the local subnet. As a result, the RP (Device E) receives duplicate IPv6 multicast packets.
With the DF election mechanism, once receiving the RP information, Device B and Device C multicast a DF election message to all IPv6 PIM devices on the subnet to initiate a DF election process. The election message carries the RP's address, and the route preference and metric of the unicast route to the RP. A DF is elected as follows:
1.     The device with higher route preference becomes the DF.
2.     If the devices have the same route preference, the device with lower metric becomes the DF.
3.     If the devices have the same metric, the device with the higher IP address becomes the DF.
A bidirectional RPT comprises a receiver-side RPT and a source-side RPT. The receiver-side RPT is rooted at the RP and takes the devices that directly connect to the receivers as leaves. The source-side RPT is also rooted at the RP but takes the devices that directly connect to the IPv6 multicast sources as leaves. The processes for building these two RPTs are different.
Figure 10 RPT building at the receiver side
As shown in Figure 10, the process for building a receiver-side RPT is the same as the process for building an RPT in IPv6 PIM-SM:
1.     When a receiver wants to join the IPv6 multicast group G, it uses an MLD message to inform the directly connected device.
2.     After receiving the message, the device sends a join message, which is forwarded hop by hop to the RP for the IPv6 multicast group.
3.     The devices along the path from the receiver's directly connected device to the RP form an RPT branch. Each device on this branch adds a (*, G) entry to its forwarding table.
After a receiver host leaves the IPv6 multicast group G, the directly connected device multicasts a prune message to all IPv6 PIM devices on the subnet. The prune message goes hop by hop along the reverse direction of the RPT to the RP. After receiving the prune message, an upstream node removes the interface that connects to the downstream node from the outgoing interface list. At the same time, the upstream device checks the existence of receivers for that IPv6 multicast group. If no receivers for the IPv6 multicast group exist, the device continues to forward the prune message to its upstream device.
Figure 11 RPT building at the IPv6 multicast source side
As shown in Figure 11, the process for building a source-side RPT is relatively simple:
1.     When an IPv6 multicast source sends multicast packets to the IPv6 multicast group G, the DF in each subnet unconditionally forwards the packets to the RP.
2.     The devices along the path from the source's directly connected device to the RP constitute an RPT branch. Each device on this branch adds a (*, G) entry to its forwarding table.
After a bidirectional RPT is built, the IPv6 multicast sources send multicast traffic to the RP along the source-side RPT. Then, the RP forwards the traffic to the receivers along the receiver-side RPT.
IMPORTANT
IMPORTANT:
If a receiver and a source are at the same side of the RP, the source-side RPT and the receiver-side RPT might meet at a node before reaching the RP. In this case, the multicast packets from the IPv6 multicast source to the receiver are directly forwarded by the node, instead of by the RP.
Typically, an IPv6 PIM-SM domain or an IPv6 BIDIR-PIM domain contains only one BSR, which is responsible for advertising RP-set information within the entire domain. Information about all IPv6 multicast groups is forwarded within the network that the BSR administers. This is called the "IPv6 non-scoped BSR mechanism."
To implement refined management, you can divide an IPv6 PIM-SM domain or IPv6 BIDIR-PIM domain into an IPv6 global-scoped zone and multiple IPv6 administratively-scoped zones (admin-scoped zones). This is called the "IPv6 administrative scoping mechanism."
The administrative scoping mechanism effectively releases stress on the management in a single-BSR domain and enables provision of zone-specific services through private group addresses.
An IPv6 admin-scoped zone is designated to particular IPv6 multicast groups with the same scope field value in their group addresses. Zone border routers (ZBRs) form the boundary of an IPv6 admin-scoped zone. Each IPv6 admin-scoped zone maintains one BSR for IPv6 multicast groups with the same scope field value. IPv6 multicast protocol packets, such as assert messages and BSMs, of these IPv6 multicast groups cannot cross the boundary of the IPv6 admin-scoped zone for the group range. The IPv6 multicast group ranges to which different IPv6 admin-scoped zones are designated can have intersections. However, the IPv6 multicast groups in an IPv6 admin-scoped zone are valid only within its local zone, and theses IPv6 multicast groups are regarded as private group addresses.
The IPv6 global-scoped zone can be regarded as a special IPv6 admin-scoped zone, and it maintains a BSR for the IPv6 multicast groups with the scope field value as 14.
The IPv6 global-scoped zone and each IPv6 admin-scoped zone have their own C-RPs and BSRs. These devices are effective only on their respective zones, and the BSR election and the RP election are implemented independently. Each IPv6 admin-scoped zone has its own boundary. The IPv6 multicast information within a zone cannot cross this boundary in either direction. You can have a better understanding of the IPv6 global-scoped zone and IPv6 admin-scoped zones based on geographical locations and the scope field values.
·     In view of geographical locations:
An IPv6 admin-scoped zone is a logical zone for particular IPv6 multicast groups with the same scope field value. The IPv6 multicast packets for such IPv6 multicast groups are confined within the local IPv6 admin-scoped zone and cannot cross the boundary of the zone.
Figure 12 Relationship in view of geographical locations
As shown in Figure 12, for the IPv6 multicast groups with the same scope field value, the IPv6 admin-scoped zones must be geographically separated and isolated. The IPv6 global-scoped zone includes all devices in the IPv6 PIM-SM domain or IPv6 BIDIR-PIM domain. IPv6 multicast packets that do not belong to any IPv6 admin-scoped zones are forwarded in the entire IPv6 PIM-SM domain or IPv6 BIDIR-PIM domain.
·     In view of the scope field values:
In terms of the scope field values, the scope field in an IPv6 multicast group address shows the zone to which the IPv6 multicast group belongs.
Figure 13 IPv6 multicast address format
An IPv6 admin-scoped zone with a larger scope field value contains an IPv6 admin-scoped zone with a smaller scope field value. The zone with the scope field value of E is the IPv6 global-scoped zone. Table 1 lists the possible values of the scope field.
Table 1 Values of the Scope field
Value
Meaning
Remarks
0, F
Reserved
N/A
1
Interface-local scope
N/A
2
Link-local scope
N/A
3
Subnet-local scope
4
Admin-local scope
5
Site-local scope
6, 7, 9 through D
Unassigned
8
Organization-local scope
E
Global scope
IPv6 PIM-SSM
The ASM model includes IPv6 PIM-DM and IPv6 PIM-SM. The SSM model can be implemented by leveraging part of the IPv6 PIM-SM technique. It is also called "IPv6 PIM-SSM."
The SSM model provides a solution for source-specific multicast. It maintains the relationship between hosts and devices through MLDv2.
In actual applications, part of MLDv2 and IPv6 PIM-SM techniques are adopted to implement the SSM model. In the SSM model, because receivers have located an IPv6 multicast source, no RP or RPT is required. No source registration process is required for discovering IPv6 multicast sources in other IPv6 PIM domains.
IPv6 PIM-SSM mechanisms include neighbor discovery, DR election, and SPT building.
Neighbor discovery
IPv6 PIM-SSM uses the same neighbor discovery mechanism as IPv6 PIM-SM. For more information, see "Neighbor discovery."
DR election
IPv6 PIM-SSM uses the same DR election mechanism as IPv6 PIM-SM. For more information, see "DR election."
SPT building
The decision to build an RPT for IPv6 PIM-SM or an SPT for IPv6 PIM-SSM depends on whether the IPv6 multicast group that the receiver host joins is in the IPv6 SSM group range. The IPv6 SSM group range reserved by IANA is FF3x::/32, where "x" represents any legal address scope.
Figure 14 SPT building in IPv6 PIM-SSM
As shown in Figure 14, Host B and Host C are receivers. They send MLDv2 report messages to their DRs to express their interest in the multicast information that the IPv6 multicast source S sends to the IPv6 multicast group G.
After receiving a report message, the DR first checks whether the group address in the message is in the IPv6 SSM group range and does the following:
·     If the group address is in the IPv6 SSM group range, the DR sends a subscribe message hop by hop toward the IPv6 multicast source S. All devices along the path from the DR to the IPv6 multicast source create an (S, G) entry to build an SPT. The SPT is rooted the IPv6 multicast source S and has the receivers as its leaves. This SPT is the transmission channel in IPv6 PIM-SSM.
·     If the group address is not in the IPv6 SSM group range, the receiver-side DR sends a (*, G) join message to the RP. The IPv6 multicast source registers with the source-side DR.
In IPv6 PIM-SSM, the term "subscribe message" refers to a join message.
In an IPv6 PIM network, IPv6 PIM-DM cannot run together with IPv6 PIM-SM, IPv6 BIDIR-PIM, or IPv6 PIM-SSM. However, IPv6 PIM-SM, IPv6 BIDIR-PIM, and IPv6 PIM-SSM can run together. Figure 15 shows how the device selects one protocol from among them for a receiver trying to join a group.
For more information about MLD SSM mapping, see "Configuring MLD."
Figure 15 Relationship among IPv6 PIM protocols
To support IPv6 PIM for VPNs, a multicast device that runs IPv6 PIM maintains an independent set of IPv6 PIM neighbor table, IPv6 multicast routing table, BSR information, and RP-set information for each VPN.
After receiving an IPv6 multicast data packet, the multicast device checks which VPN the IPv6 data packet belongs to. Then, the device forwards the IPv6 packet according to the IPv6 multicast routing table for that VPN or creates an IPv6 multicast routing entry for that VPN.
·     RFC 3973, Protocol Independent Multicast-Dense Mode (PIM-DM): Protocol Specification(Revised)
·     RFC 4601, Protocol Independent Multicast-Sparse Mode (PIM-SM): Protocol Specification (Revised)
·     RFC 4610, Anycast-RP Using Protocol Independent Multicast (PIM)
·     RFC 3956, Embedding the Rendezvous Point (RP) Address in an IPv6 Multicast Address
·     RFC 5015, Bidirectional Protocol Independent Multicast (BIDIR-PIM)
·     RFC 5059, Bootstrap Router (BSR) Mechanism for Protocol Independent Multicast (PIM)
·     RFC 4607, Source-Specific Multicast for IP
·     Draft-ietf-ssm-overview-05, An Overview of Source-Specific Multicast (SSM)
All the interfaces on a device must operate in the same IPv6 PIM mode on the public network or the same VPN instance.
To avoid IPv6 PIM routing table exceptions, do not use the same RP to provide services for IPv6 PIM-SM and IPv6 BIDIR-PIM when both of them run on the IPv6 PIM network.
To configure IPv6 PIM-DM, perform the following tasks:
1.     Enabling IPv6 PIM-DM
2.     (Optional.) Configuring the state refresh feature
3.     (Optional.) Setting the IPv6 PIM-DM graft retry timer
4.     (Optional.) Configuring common IPv6 PIM features
Before you configure IPv6 PIM-DM, you must complete the following tasks:
·     Configure an IPv6 unicast routing protocol so that all devices in the domain can interoperate at the network layer.
·     Enable IPv6 multicast routing.
With IPv6 PIM-DM enabled on interfaces, devices can establish IPv6 PIM neighbor relationship and process IPv6 PIM messages from their IPv6 PIM neighbors.
As a best practice, enable IPv6 PIM-DM on all non-border interfaces of devices when you deploy an IPv6 PIM-DM domain.
2.     Enable IPv6 multicast routing and enter IPv6 MRIB view.
ipv6 multicast routing [ vpn-instance vpn-instance-name ]
By default, IPv6 multicast routing is disabled.
For more information about this command, see IP Multicast Command Reference.
3.     Return to system view.
4.     Enter interface view.
5.     Enable IPv6 PIM-DM.
ipv6 pim dm
By default, IPv6 PIM-DM is disabled.
·     State refresh capability—Enables the IPv6 PIM device that is directly connected to the source to periodically send state refresh messages. It also enables other PIM devices to refresh pruned state timers after receiving the state refresh messages. Use this feature to prevent the pruned interfaces from resuming multicast forwarding.
·     State refresh interval—Determines the interval at which a device sends state refresh messages.
·     Wait time before accepting a new state refresh message—A device might receive duplicate state refresh messages within a short time. To prevent this situation, you can adjust the amount of time that the device must wait to accept a new state refresh message. If the device receives a new state refresh message before the timer expires, it discards the message. If the device receives a new state refresh message after the timer expires, it accepts the message, refreshes its own IPv6 PIM-DM state, and resets the waiting timer.
·     Hop limit value of state refresh messagesThe hop limit value of a state refresh message decrements by 1 whenever it passes a device before it is forwarded to the downstream node. The state refresh message is not forwarded when the hop limit comes down to 0. A state refresh message with a large hop limit value might cycle on a small network. To control the propagation scope of state refresh messages, configure an appropriate hop limit value based on the network size on the device directly connected with the IPv6 multicast source.
Perform this task on all devices in the IPv6 PIM-DM domain.
2.     Enter interface view.
3.     Enable the state refresh feature.
ipv6 pim state-refresh-capable
By default, the state refresh feature is enabled.
4.     Return to system view.
5.     Enter IPv6 PIM view.
ipv6 pim [ vpn-instance vpn-instance-name ]
6.     Set the state refresh interval.
The default setting is 60 seconds.
7.     Set the amount of time that the device must wait to accept a new state refresh message.
state-refresh-rate-limit time
The default setting is 30 seconds.
8.     Set the hop limit value of state refresh messages.
state-refresh-hoplimit hoplimit-value
The default setting is 255.
Perform this task to adjust the interval at which the device retransmits a graft message if it does not receive a graft-ack message from the upstream device.
3.     Set the IPv6 PIM-DM graft retry timer.
ipv6 pim timer graft-retry interval
By default, the IPv6 PIM-DM graft retry timer is 3 seconds.
To configure IPv6 PIM-SM, perform the following tasks:
1.     Enabling IPv6 PIM-SM
2.     Configuring static RPs
As a best practice, configure a static RP when only one dynamic RP exists in the network.
3.     Configure dynamic RP election:
¡     Configuring C-RPs
¡     Configuring C-BSRs
¡     (Optional.) Configuring an IPv6 PIM domain border
¡     (Optional.) Disabling BSM semantic fragmentation
¡     (Optional.) Disabling the device from forwarding BSMs out of their incoming interfaces
As a best practice, configure dynamic RPs when multiple IPv6 PIM devices exist in the network.
4.     (Optional.) Configuring Anycast RP
5.     (Optional.) Configuring IPv6 multicast source registration
6.     (Optional.) Configuring the switchover to SPT
7.     (Optional.) Configuring common IPv6 PIM features
Before you configure IPv6 PIM-SM, you must complete the following tasks:
With IPv6 PIM-SM enabled on interfaces, devices can establish IPv6 PIM neighbor relationship and process IPv6 PIM messages from their IPv6 PIM neighbors.
As a best practice, enable IPv6 PIM-SM on all non-border interfaces of devices when you deploy an IPv6 PIM-SM domain.
5.     Enable IPv6 PIM-SM.
ipv6 pim sm
By default, IPv6 PIM-SM is disabled.
If only one dynamic RP exists on a network, you can configure a static RP to avoid communication interruption caused by single-point failures. The static RP can also avoid waste of bandwidth caused by frequent message exchanges between C-RPs and the BSR.
In the IPv6 PIM-SM domain, you can configure the same static RP for multiple IPv6 multicast groups by using the same RP address but different ACLs.
You do not need to enable IPv6 PIM for an interface to be configured as a static RP.
If you configure multiple static RPs for an IPv6 multicast group, only the static RP with the highest IPv6 address takes effect.
The static RP configuration must be the same on all devices in the IPv6 PIM-SM domain.
2.     Enter IPv6 PIM view.
3.     Configure a static RP for IPv6 PIM-SM.
static-rp ipv6-rp-address [ ipv6-acl-number | preferred ] *
When both a static RP and a dynamically elected RP exist on the network, you can specify the preferred keyword to give priority to the static RP. The dynamic RP is used only when the static RP fails. If you do not specify the preferred keyword, the dynamic RP takes priority and the static RP is used only when the dynamic RP fails.
Configuring C-RPs
To avoid C-RP spoofing, configure a C-RP policy to filter C-RP advertisement messages by using an ACL that specifies the packet source address range and multicast group addresses.
Configure C-RPs on devices that reside in the backbone network.
Because the RP and other devices exchange a large amount of information in the BIDIR-PIM domain, reserve a large bandwidth between C-RPs and other devices.
You must configure the same C-RP policy on all C-BSRs in the IPv6 PIM-SM domain because every C-BSR might become the BSR.
The device might use the BSR RP hash algorithm described in RFC 4601 or in RFC 2362 to calculate the RP for a multicast group. To ensure consistent group-to-RP mappings on all PIM devices in the IPv6 PIM-SM domain, specify the same BSR RP hash algorithm on the devices.
3.     Configure a C-RP.
c-rp ipv6-address [ advertisement-interval adv-interval | { group-policy ipv6-acl-number | scope scope-id } | holdtime hold-time | priority priority ] *
4.     (Optional.) Configure a C-RP policy.
crp-policy ipv6-acl-number
By default, no C-RP policies are configured. All C-RP advertisement messages are regarded as legal.
5.     (Optional.) Configure the device to use the BSR RP hash algorithm described in RFC 2362.
bsr-rp-mapping rfc2362
By default, the device uses the BSR RP hash algorithm described in RFC 4601.
Configuring C-BSRs
You must configure C-BSRs when you configure dynamic RP election.
To prevent a legal BSR from being replaced by a malicious host, configure a BSR policy to filter BSR messages by using an ACL that specifies the legal BSR addresses.
Configure C-BSRs on devices that reside in the backbone network.
Because the BSR and other devices exchange a large amount of information in the IPv6 PIM-SM domain, reserve a large bandwidth between the C-BSR and other devices.
The C-BSR configuration on the devices in the IPv6 PIM-SM domain must be the same.
3.     Configure a C-BSR.
c-bsr ipv6-address [ scope scope-id ] [ hash-length hash-length | priority priority ] *
4.     (Optional.) Configure a BSR policy.
bsr-policy ipv6-acl-number
By default, no BSR policies are configured. All bootstrap messages are regarded as legal.
An IPv6 PIM domain border determines the transmission boundary of bootstrap messages. Bootstrap messages cannot cross the domain border in either direction. A number of IPv6 PIM domain border interfaces partition a network into different IPv6 PIM-SM domains.
3.     Configure an IPv6 PIM domain border.
ipv6 pim bsr-boundary
By default, an interface is not an IPv6 PIM domain border.
BSM semantic fragmentation enables a BSR to split a BSM into multiple BSM fragments (BSMFs) if the BSM exceeds the MTU. In this way, a non-BSR device can update the RP-set information for a group range after receiving all BSMFs for the group range. The loss of one BSMF only affects the RP-set information of the group ranges that the fragment contains.
If a device does not support BSM semantic fragmentation, it regards a BSMF as a BSM and updates the RP-set information each time it receives a BSMF. It learns only part of the RP-set information, which further affects the RP election. Therefore, if such a device exists in the IPv6 PIM-SM domain, you must disable BSM semantic fragmentation on all C-BSRs.
3.     Disable BSM semantic fragmentation.
undo bsm-fragment enable
By default, BSM semantic fragmentation is enabled.
By default, the device forwards BSMs out of their incoming interfaces. This default setting ensures that all devices on the subnet can receive BSMs even when they have inconsistent routing information. However, this default setting results in duplicated IPv6 multicast traffic. If you are sure that all the devices on the subnet have consistent routing information, you can disable the device from forwarding BSMs out of their incoming interfaces.
3.     Disable the device from forwarding BSMs out of their incoming interfaces.
undo bsm-reflection enable
To prevent the other Anycast RP member devices from discarding the BSM sent by the BSR, make sure the Anycast RP address is different from the BSR address.
As a best practice to ensure network performance, configure a maximum of 16 Anycast RP members for an Anycast RP set.
As a best practice, configure the IPv6 address of a loopback interface as the RP member address.
If you configure IPv6 addresses of multiple interfaces on the same device as RP member addresses, the lowest IPv6 address takes effect. The rest of the interface addresses become backup RP member addresses.
You must add the device where the Anycast RP resides as an RP member to the Anycast RP set.
You must configure a static RPs or C-RPs in the IPv6 PIM-SM domain before you configure the Anycast RP. Use the address of the static RP or the dynamically elected RP as the Anycast RP address.
3.     Configure Anycast RP.
anycast-rp ipv6-anycast-rp-address ipv6-member-address
You can repeat this command to add multiple RP member addresses to an Anycast RP set.
·     IPv6 PIM register policy—An IPv6 PIM register policy enables an RP to filter register messages by using an ACL that specifies the IPv6 multicast sources and groups. The policy limits the multicast groups to which the RP is designated. If a register message is denied by the ACL or does not match the ACL, the RP discards the register message and sends a register-stop message to the source-side DR. The registration process stops.
·     Checksum computing method for register messages—For information integrity of a register message, you can configure the device to calculate the checksum based on the entire register message. If a device cannot calculate the checksum based on the entire register message, you can configure the device to calculate the checksum based on the register message header.
·     Register suppression time—The source-side DR stops sending register messages encapsulated with IPv6 multicast data and starts a register-stop timer upon receiving a register-stop message from the RP. Before the register-stop timer expires, the DR sends a null register message (a register message without encapsulated IPv6 multicast data) to the RP and starts a register probe timer. If the DR receives a register-stop message before the register probe timer expires, it resets its register-stop timer. If the DR does not receive a register-stop message when the register probe timer expires, the DR starts sending register messages with encapsulated data again.
The register-stop timer is set to a random value chosen uniformly from (0.5 × register_suppression_time minus register_probe_time) to (1.5 × register_suppression_time minus register_probe_time). The register_probe_time is (5 seconds). You can adjust the register suppression time.
On all C-RP devices, configure an IPv6 PIM register policy and the checksum computing method for register messages.
On all devices that might become the source-side DR, set the register suppression time.
3.     Configure an IPv6 PIM register policy.
register-policy ipv6-acl-number
By default, no IPv6 register policy is configured. All IPv6 register messages are regarded as legal.
4.     Configure the device to calculate the checksum based on the entire register message.
register-whole-checksum
By default, the device calculates the checksum based on the header of a register message.
5.     Set the register suppression time.
Both the receiver-side DR and RP can monitor the traffic rate of passing-by IPv6 multicast packets and thus trigger the switchover from RPT to SPT. The monitor function is not available on switches.
Some devices cannot encapsulate IPv6 multicast data in register messages destined to the RP. As a best practice to avoid IPv6 multicast data forwarding failures, do not disable the switchover to SPT on C-RPs that might become the RP.
3.     Configure the switchover to SPT.
spt-switch-threshold { traffic-rate | immediacy | infinity } [ group-policy ipv6-acl-number ]
By default, the first IPv6 multicast data packet triggers the RPT to SPT switchover.
To configure IPv6 BIDIR-PIM, perform the following tasks:
1.     Enabling IPv6 BIDIR-PIM
As a best practice, configure a static R when only one dynamic RP exists in the network.
3.     Configuring dynamic RPs
¡     Configuring C-RPs
¡     (Optional.) Setting the maximum number of IPv6 BIDIR-PIM RPs
You can configure static RPs, dynamic RPs, or both.
Before you configure IPv6 BIDIR-PIM, you must complete the following tasks:
·     Enable IPv6 PIM-SM.
As a best practice, enable IPv6 BIDIR-PIM on all non-border interfaces of devices when you deploy an IPv6 BIDIR-PIM.
2.     Enable IPv6 multicast routing and enter MRIB view.
ipv6 pim sm
6.     Return to system view.
7.     Enter IPv6 PIM view
8.     Enable IPv6 BIDIR-PIM.
bidir-pim enable
By default, IPv6 BIDIR-SM is disabled.
If only one dynamic RP exists on a network, you can configure a static RP to avoid communication interruption caused by single-point failures. The static RP can also avoid bandwidth waste caused by frequent message exchanges between C-RPs and the BSR.
The static RP configuration must be the same on all devices in the IPv6 BIDIR-PIM domain.
In an IPv6 BIDIR-PIM domain, you can configure the same static RP for different IPv6 multicast groups by using the same RP address but different ACLs.
You can specify an unused IP address for a static RP. This address must be on the same subnet as the link on which the static RP is configured. For example, if the IPv6 addresses of the interfaces at the two ends of a link are 1001::1/64 and 1001::2/64, you can specify the interface with IPv6 address 1001::100/64 as a static RP. As a result, the link becomes an RPL.
3.     Configure a static RP for IPv6 BIDIR-PIM.
static-rp ipv6-rp-address bidir [ ipv6-acl-number | preferred ] *
Configuring C-RPs
To guard against C-RP spoofing, configure a C-RP policy to filter C-RP advertisement messages by using an ACL that specifies the packet source address range and IPv6 multicast groups.
Because the RP and other devices exchange a large amount of information in the IPv6 BIDIR-PIM domain, reserve a large bandwidth between C-RPs and other devices.
You must configure the same C-RP policy on all C-BSRs in the IPv6 BIDIR-PIM domain.
The device might use the BSR RP hash algorithm described in RFC 4601 or in RFC 2362 to calculate the RP for a multicast group. To ensure consistent group-to-RP mappings on all PIM devices in the IPv6 BIDIR-PIM domain, specify the same BSR RP hash algorithm on the devices.
3.     Configure a C-RP to provide services for IPv6 BIDIR-PIM.
c-rp ipv6-address [ advertisement-interval adv-interval | { group-policy ipv6-acl-number | scope scope-id } | holdtime hold-time | priority priority ] * bidir
4.     (Optional.) Configure the device to use the RP hash algorithm described in RFC 2362.
Configuring C-BSRs
Because the BSRs and other devices exchange a large amount of information in the IPv6 BIDIR-PIM domain, reserve a large bandwidth between the C-BSRs and other devices.
The C-BSR configuration on all devices in the same IPv6 BIDIR-PIM domain must be the same.
By default, no C-BSRs exist.
By default, no BSR policy is configured. All bootstrap messages are regarded as legal.
An IPv6 PIM domain border determines the transmission boundary of bootstrap messages. Bootstrap messages cannot cross the domain border in either direction. A number of PIM domain border interfaces partition a network into different IPv6 BIDIR-PIM domains.
If a device does not support BSM semantic fragmentation, it regards a BSMF as a BSM and updates the RP-set information each time it receives a BSMF. It learns only part of the RP-set information, which further affects the RP election. Therefore, if such a device exists in the IPv6 BIDIR-PIM domain, you must disable BSM semantic fragmentation on all C-BSRs.
In an IPv6 BIDIR-PIM domain, one DF election per RP is implemented on all IPv6 PIM-enabled interfaces. To avoid unnecessary DF elections, do not configure multiple RPs for IPv6 BIDIR-PIM.
This configuration sets a limit on the number of IPv6 BIDIR-PIM RPs. If the number of RPs exceeds the limit, excess RPs do not take effect and can be used only for DF election rather than IPv6 multicast data forwarding. The system does not delete these excess RPs. They must be deleted manually.
3.     Set the maximum number of IPv6 BIDIR-PIM RPs.
bidir-rp-limit limit
By default, the maximum number of IPv6 BIDIR-PIM RPs is 32.
To configure IPv6 PIM-SSM, perform the following tasks:
2.     (Optional.) Configuring an IPv6 PIM hello policy
3.     (Optional.) Configuring common IPv6 PIM features
Before you configure IPv6 PIM-SSM, you must complete the following tasks:
·     Configure an IPv6 unicast IPv6 routing protocol so that all devices in the domain can interoperate at the network layer.
·     Enable MLDv2 on the IPv6 PIM devices that connect to IPv6 multicast receivers.
As a best practice, enable IPv6 PIM-SM on all non-border interfaces of devices when you deploy an IPv6 PIM-SSM domain.
ipv6 pim sm
When an IPv6 PIM-SM enabled interface receives an IPv6 multicast packet, it checks whether the IPv6 multicast group address of the packet is in the IPv6 SSM group range. If the IPv6 multicast group address is in this range, the IPv6 PIM mode for this packet is IPv6 PIM-SSM. If the IPv6 multicast group address is not in this range, the IPv6 PIM mode is IPv6 PIM-SM.
Configure the same IPv6 SSM group range on all devices in the entire IPv6 PIM-SM domain. Otherwise, IPv6 multicast information cannot be delivered through the IPv6 SSM model.
When a member of an IPv6 multicast group in the IPv6 SSM group range sends an MLDv1 report message, the device does not trigger a (*, G) join.
ipv6 pim
3.     Configure the IPv6 SSM group range.
ssm-policy ipv6-acl-number
The default range is FF3x::/32, where x can be any valid scope.
All the following tasks are optional.
·     Configuring an IPv6 PIM hello policy
·     Configuring IPv6 PIM hello message options
·     Dropping hello messages without the Generation ID option
·     Configuring common IPv6 PIM timers
·     Setting the maximum size of a join or prune message
·     Enabling BFD for IPv6 PIM
·     Enabling IPv6 PIM passive mode
·     Enabling IPv6 PIM NSR
·     Enabling NBMA mode for IPv6 ADVPN tunnel interfaces
·     Enabling SNMP notifications for IPv6 PIM
This feature enables the device to filter IPv6 multicast data by using an ACL that specifies the IPv6 multicast sources and the optional groups. It filters not only IPv6 multicast data packets but also IPv6 PIM register messages with IPv6 multicast data encapsulated. This also reduces the IPv6 multicast traffic on the network.
3.     Configure an IPv6 multicast source policy.
source-policy ipv6-acl-number
By default, no IPv6 multicast source policy is configured. The device does not filter IPv6 multicast data packets.
This feature enables the device to filter IPv6 PIM hello messages by using an ACL that specifies the packet source addresses. It is used to guard against IPv6 PIM message attacks and to establish correct IPv6 PIM neighboring relationships.
If hello messages of an existing IPv6 PIM neighbor are filtered out by the policy, the neighbor is automatically removed when its aging timer expires.
3.     Configure an IPv6 PIM hello policy.
ipv6 pim neighbor-policy ipv6-acl-number
By default, no IPv6 PIM hello policy is configured on an interface. All IPv6 PIM hello messages are regarded as legal.
In either an IPv6 PIM-DM domain or an IPv6 PIM-SM domain, hello messages exchanged among devices contain the following configurable options:
·     DR_Priority (for IPv6 PIM-SM only)—Priority for DR election. The device with the highest priority wins the DR election. You can configure this option for all the devices in a shared-media LAN that directly connects to the IPv6 multicast source or the receivers.
·     Holdtime—IPv6 PIM neighbor lifetime. If a device receives no hello message from a neighbor when the neighbor lifetime expires, it regards the neighbor failed or unreachable.
·     LAN_Prune_Delay—Delay of pruning a downstream interface on a shared-media LAN. This option has the LAN delay field, the override interval field, and the T bit.
The LAN delay defines the IPv6 PIM message propagation delay. The override interval defines a time period for a downstream device to override a prune message. The T bit specifies the capability of tracking downstream device status on upstream devices.
On the shared-media LAN, the propagation delay and override interval are used as follows:
¡     If a device receives a prune message on its upstream interface, it means that there are downstream devices on the shared-media LAN. If this device still needs to receive multicast data, it must send a join message to override the prune message within the override interval.
¡     When a device receives a prune message from its downstream interface, it does not immediately prune this interface. Instead, it starts a timer (the propagation delay plus the override interval). If interface receives a join message before the timer expires, the device does not prune the interface. Otherwise, the device prunes the interface.
·     Neighbor tracking—If you enable neighbor tracking on an upstream device, this device can track the states of the downstream nodes for which the joined state holdtime timer has not expired. All join messages from downstream devices are accepted.
If the propagation delay or override interval on different IPv6 PIM devices on a shared-media LAN is different, the largest ones apply.
If you enable neighbor tracking, you must enable it on all IPv6 PIM devices on a shared-media LAN or the upstream device to track join messages from every downstream device.
You can configure hello message options for all interfaces in IPv6 PIM view or for the current interface in interface view. The configuration made in interface view takes priority over the configuration made in IPv6 PIM view.
Configuring hello message options globally
3.     Set the DR priority.
The default setting is 1.
4.     Set the neighbor lifetime.
hello-option holdtime time
The default setting is 105 seconds.
5.     Set the IPv6 PIM message propagation delay for a shared-media LAN.
hello-option lan-delay delay
The default setting is 500 milliseconds.
6.     Set the override interval.
The default setting is 2500 milliseconds.
7.     Enable neighbor tracking.
hello-option neighbor-tracking
By default, neighbor tracking is disabled.
Configuring hello message options on an interface
ipv6 pim hello-option dr-priority priority
ipv6 pim hello-option holdtime time
5.     Set the IPv6 PIM message propagation delay.
ipv6 pim hello-option lan-delay delay
ipv6 pim hello-option override-interval interval
ipv6 pim hello-option neighbor-tracking
A device generates a generation ID for hello messages when an interface is enabled with IPv6 PIM. The generation ID is a random value, but it changes only when the status of the device changes. If an IPv6 PIM device finds that the generation ID in a hello message from the upstream device has changed, it assumes that the status of the upstream device has changed. In this case, it sends a join message to the upstream device for status update. You can configure an interface to drop hello messages without the generation ID options to promptly know the status of an upstream device.
3.     Enable the interface to drop hello messages without the Generation ID option.
ipv6 pim require-genid
By default, an interface accepts hello messages without the Generation ID option.
The following are common IPv6 PIM timers:
·     Hello intervalInterval at which an IPv6 PIM device sends hello messages to discover IPv6 PIM neighbors and maintain IPv6 PIM neighbor relationship.
·     Triggered hello delay—Maximum delay for sending a hello message to avoid collisions caused by simultaneous hello messages. After receiving a hello message, an IPv6 PIM device waits for a random time before sending a hello message. This random time is in the range of 0 to the triggered hello delay.
·     Join/Prune interval—Interval at which an IPv6 PIM device sends join/prune messages to its upstream devices for state update.
·     Joined/Pruned state holdtime—Time for which an IPv6 PIM device keeps the joined/pruned state for the downstream interfaces. This joined/pruned state holdtime is contained in a join/prune message.
·     IPv6 multicast source lifetime—Lifetime that an IPv6 PIM device maintains for an IPv6 multicast source. If a device does not receive subsequent IPv6 multicast data from the IPv6 multicast source S when the timer expires, it deletes the (S, G) entry for the IPv6 multicast source.
To prevent upstream neighbors from aging out, set the join/prune interval to be less than the join/pruned state holdtime.
You can configure common IPv6 PIM timers for all interfaces in IPv6 PIM view or for the current interface in interface view. The configuration made in interface view takes priority over the configuration made in IPv6 PIM view.
As a best practice, use the defaults for a network without special requirements.
Configuring common IPv6 PIM timers globally
3.     Set the hello interval.
timer hello interval
By default, the interval to send hello messages is 30 seconds.
4.     Set the join/prune interval.
timer join-prune interval
By default, the interval to send join/prune messages is 60 seconds.
This configuration takes effect after the current interval ends.
5.     Set the joined/pruned state holdtime.
holdtime join-prune time
By default, the joined/pruned state holdtime timer is 210 seconds.
6.     Set the IPv6 multicast source lifetime.
source-lifetime time
By default, the IPv6 multicast source lifetime is 210 seconds.
Configuring common IPv6 PIM timers on an interface
ipv6 pim timer hello interval
4.     Set the triggered hello delay.
ipv6 pim triggered-hello-delay delay
The default setting is 5 seconds.
5.     Set the join/prune interval.
ipv6 pim timer join-prune interval
6.     Set the joined/pruned state holdtime.
ipv6 pim holdtime join-prune time
The default setting is 210 seconds.
The loss of an oversized join or prune message might result in loss of massive information. You can set a small value for the size of a join or prune message to reduce the impact.
3.     Set the maximum size of a join or prune message.
jp-pkt-size size
The default setting is 1200 bytes.
If a DR on a shared-media network fails, a new DR election process will start after the DR ages out. However, it might take a long period of time before other devices detect the link failures and trigger a new DR election. To start a new DR election process immediately after the original DR fails, you can enable BFD for IPv6 PIM to detect link failures among IPv6 PIM neighbors.
You must enable BFD for IPv6 PIM on all IPv6 PIM devices on a shared-media network. For more information about BFD, see High Availability Configuration Guide.
You must enable IPv6 PIM-DM or IPv6 PIM-SM on an interface before you configure this feature on the interface.
3.     Enable BFD for IPv6 PIM.
ipv6 pim bfd enable
By default, BFD is disabled for IPv6 PIM.
To guard against IPv6 PIM hello spoofing, you can enable IPv6 PIM passive mode on a receiver-side interface. The interface cannot receive or forward IPv6 PIM protocol messages (excluding register, register-stop and C-RP-Adv messages), and acts as the DR on the subnet. In IPv6 BIDIR-PIM, it also acts as the DF.
This feature takes effect only when IPv6 PIM-DM or IPv6 PIM-SM is enabled on the interface.
To avoid duplicate multicast data transmission and flow loop, do not enable this feature on a shared-media LAN with multiple IPv6 PIM devices.
3.     Enable IPv6 PIM passive mode on the interface.
ipv6 pim passive
By default, IPv6 PIM passive mode is disabled on an interface.
This feature enables IPv6 PIM to back up protocol state information, including IPv6 PIM neighbor information and routes, from the active process to the standby process. The standby process immediately takes over when the active process fails. Use this feature to avoid route flapping and forwarding interruption for IPv6 PIM when an active/standby switchover occurs.
2.     Enable IPv6 PIM NSR.
ipv6 pim non-stop-routing
By default, IPv6 PIM NSR is disabled.
This feature allows IPv6 ADVPN tunnel interfaces to forward IPv6 multicast data only to target spokes and hubs. For more information about ADVPN, see Layer 3IP Services Configuration Guide.
This feature is not available for IPv6 PIM-DM.
This feature takes effect only when IPv6 PIM-SM is enabled.
In an IPv6 BIDIR-PIM domain, make sure RPs do not reside on IPv6 ADVPN tunnel interfaces or on the subnet where IPv6 ADVPN tunnel interfaces are located.
Do not configure MLD features on IPv6 ADVPN tunnel interfaces that are enabled with NBMA mode.
3.     Enable NBMA mode.
ipv6 pim nbma-mode
By default, NBMA mode is disabled.
This command is applicable only to IPv6 ADVPN tunnel interfaces.
To report critical IPv6 PIM events to an NMS, enable SNMP notifications for IPv6 PIM. For PIM event notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
2.     Enable SNMP notifications for IPv6 PIM.
snmp-agent trap enable pim6 [ candidate-bsr-win-election | elected-bsr-lost-election | neighbor-loss ] *
By default, SNMP notifications for IPv6 PIM are enabled.
Display and maintenance commands for IPv6 PIM
Display register-tunnel interface information.
display interface [ register-tunnel [ interface-number ] ] [ brief [ description| down ] ]
Display BSR information in the IPv6 PIM-SM domain.
display ipv6 pim [ vpn-instance vpn-instance-name ] bsr-info
Display information about the routes used by IPv6 PIM.
display ipv6 pim [ vpn-instance vpn-instance-name ] claimed-route [ ipv6-source-address ]
Display C-RP information in the IPv6 PIM-SM domain.
display ipv6 pim [ vpn-instance vpn-instance-name ] c-rp [ local ]
Display DF information in the IPv6 BIDIR-PIM domain.
display ipv6 pim [ vpn-instance vpn-instance-name ] df-info [ ipv6-rp-address ]
Display IPv6 PIM information on an interface.
display ipv6 pim [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ verbose ]
Display IPv6 PIM neighbor information.
display ipv6 pim [ vpn-instance vpn-instance-name ] neighbor [ ipv6-neighbor-address | interface interface-type interface-number | verbose ] *
Display IPv6 PIM routing entries.
display ipv6 pim [ vpn-instance vpn-instance-name ] routing-table [ ipv6-group-address [ prefix-length ] | ipv6-source-address [ prefix-length ] | flags flag-value | fsm | incoming-interface interface-type interface-number | mode mode-type | outgoing-interface { exclude | include | match } interface-type interface-number ] *
Display RP information in the IPv6 PIM-SM domain.
display ipv6 pim [ vpn-instance vpn-instance-name ] rp-info [ ipv6-group-address ]
Display statistics for IPv6 PIM packets.
display ipv6 pim statistics
Display remote end information maintained by IPv6 PIM for IPv6 ADVPN tunnel interfaces.
display ipv6 pim [ vpn-instance vpn-instance-name ] nbma-link [ interface { interface-type interface-number } ]
IPv6 PIM configuration examples
Example: Configuring IPv6 PIM-DM
As shown in Figure 16:
·     OSPFv3 runs on the network.
·     VOD streams are sent to receiver hosts in multicast. The receiver groups of different organizations form stub networks, and a minimum of one receiver host exists on each stub network. The entire IPv6 PIM domain is operating in the dense mode.
·     Host A and Host C are IPv6 multicast receivers on two stub networks N1 and N2.
·     MLDv1 runs between Router A and N1, and between Router B, Router C, and N2.
Figure 16 Network diagram
Table 2 Interface and IPv6 address assignment
Device
IPv6 address
Device
IPv6 address
Router A
GE2/0/1
1001::1/64
Router C
GE2/0/2
3001::1/64
Router A
GE2/0/2
1002::1/64
Router D
GE2/0/1
4001::1/64
Router B
GE2/0/1
2001::1/64
Router D
GE2/0/2
1002::2/64
Router B
GE2/0/2
2002::1/64
Router D
GE2/0/3
2002::2/64
Router C
GE2/0/1
2001::2/64
Router D
GE2/0/4
3001::2/64
1.     Assign an IPv6 address and prefix length to each interface, as shown in Figure 16. (Details not shown.)
2.     Configure OSPFv3 on the routers in the IPv6 PIM-DM domain. (Details not shown.)
3.     Enable IPv6 multicast routing, MLD, and IPv6 PIM-DM:
# On Router A, enable IPv6 multicast routing.
[RouterA-mrib6] quit
# Enable MLD on GigabitEthernet 2/0/1 (the interface that connects to the stub network).
[RouterA] interface gigabitethernet 2/0/1
[RouterA-GigabitEthernet2/0/1] mld enable
[RouterA-GigabitEthernet2/0/1] quit
# Enable IPv6 PIM-DM on GigabitEthernet 2/0/2.
[RouterA] interface gigabitethernet 2/0/2
[RouterA-GigabitEthernet2/0/2] ipv6 pim dm
[RouterA-GigabitEthernet2/0/2] quit
# Enable IPv6 multicast routing, MLD, and IPv6 PIM-DM on Router B and Router C in the same way Router A is configured. (Details not shown.)
# On Router D, enable IPv6 multicast routing, and enable IPv6 PIM-DM on each interface.
<RouterD> system-view
[RouterD] ipv6 multicast routing
[RouterD-mrib6] quit
[RouterD] interface gigabitethernet 2/0/1
[RouterD-GigabitEthernet2/0/1] ipv6 pim dm
[RouterD-GigabitEthernet2/0/1] quit
[RouterD] interface gigabitethernet 2/0/2
[RouterD-GigabitEthernet2/0/2] ipv6 pim dm
[RouterD-GigabitEthernet2/0/2] quit
[RouterD] interface gigabitethernet 2/0/3
[RouterD-GigabitEthernet2/0/3] ipv6 pim dm
[RouterD-GigabitEthernet2/0/3] quit
[RouterD] interface gigabitethernet 2/0/4
[RouterD-GigabitEthernet2/0/4] ipv6 pim dm
[RouterD-GigabitEthernet2/0/4] quit
# Display IPv6 PIM information on Router D.
[RouterD] display ipv6 pim interface
 Interface           NbrCnt HelloInt   DR-Pri    DR-Address
 GE2/0/1             0      30         1         FE80::A01:201:1
                                                 (local)
 GE2/0/2             1      30         1         FE80::A01:201:2
                                                 (local)
 GE2/0/3             1      30         1         FE80::A01:201:3
                                                 (local)
 GE2/0/4             1      30         1         FE80::A01:201:4
                                                 (local)
# Display IPv6 PIM neighboring relationship on Router D.
[RouterD] display ipv6 pim neighbor
 Total Number of Neighbors = 3
 Neighbor        Interface           Uptime   Expires  Dr-Priority
 FE80::A01:101:1 GE2/0/2             00:04:00 00:01:29 1
 FE80::B01:102:2 GE2/0/3             00:04:16 00:01:29 1
 FE80::C01:103:3 GE2/0/4             00:03:54 00:01:17 1
# Send an MLD report from Host A to join IPv6 multicast group FF0E::101. (Details not shown.)
# Send IPv6 multicast data from IPv6 multicast source 4001::100/64 to IPv6 multicast group FF0E::101. (Details not shown.)
# Display IPv6 PIM multicast routing table information on Router A.
[RouterA] display ipv6 pim routing-table
 (*, FF0E::101)
     Protocol: pim-dm, Flag: WC
     UpTime: 00:01:24
     Upstream interface: NULL
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
         1: GigabitEthernet2/0/1
             Protocol: mld, UpTime: 00:01:20, Expires: -
 (4001::100, FF0E::101)
     Protocol: pim-dm, Flag: ACT
     UpTime: 00:01:20
     Upstream interface: GigabitEthernet2/0/2
         Upstream neighbor: 1002::2
         RPF prime neighbor: 1002::2
             Protocol: pim-dm, UpTime: 00:01:20, Expires: -
# Display IPv6 PIM multicast routing table information on Router D.
[RouterD] display ipv6 pim routing-table
     UpTime: 00:02:19
     Upstream interface: GigabitEthernet2/0/1
         1: GigabitEthernet2/0/2
             Protocol: pim-dm, UpTime: 00:02:19, Expires: -
·     Routers on the SPT path (Router A and Router D) have the correct (S, G) entries.
·     Router A has the correct (*, G) entry.
Example: Configuring non-scoped IPv6 PIM-SM
As shown in Figure 17:
·     VOD streams are sent to receiver hosts in multicast. The receivers of different subnets form stub networks, and a minimum of one receiver host exist in each stub network. The entire IPv6 PIM-SM domain contains only one BSR.
·     Host A and Host C are multicast receivers on the stub networks N1 and N2.
·     Specify GigabitEthernet 2/0/3 on Router E as a C-BSR and a C-RP. The C-RP is designated to the IPv6 multicast group range FF0E::101/64. Specify GigabitEthernet 2/0/2 of Router D as a static RP on all the routers to back up the dynamic RP.
Figure 17 Network diagram
Table 3 Interface and IPv6 address assignment
Device
IPv6 address
Device
IPv6 address
Router A
GE2/0/1
1001::1/64
Router D
GE2/0/1
4001::1/64
Router A
GE2/0/2
1002::1/64
Router D
GE2/0/2
1002::2/64
Router A
GE2/0/3
1003::1/64
Router D
GE2/0/3
4002::1/64
Router B
GE2/0/1
2001::1/64
Router E
GE2/0/1
3001::2/64
Router B
GE2/0/2
2002::1/64
Router E
GE2/0/2
2002::2/64
Router C
GE2/0/1
2001::2/64
Router E
GE2/0/3
1003::2/64
Router C
GE2/0/2
3001::1/64
Router E
GE2/0/4
4002::2/64
1.     Assign an IPv6 address and prefix length to each interface, as shown in Figure 17. (Details not shown.)
2.     Configure OSPFv3 on all routers in the IPv6 PIM-SM domain. (Details not shown.)
3.     Enable IPv6 multicast routing, and enable MLD and IPv6 PIM-SM:
# Enable IPv6 PIM-SM on the other interfaces.
[RouterA-GigabitEthernet2/0/2] ipv6 pim sm
[RouterA] interface gigabitethernet 2/0/3
[RouterA-GigabitEthernet 2/0/3] ipv6 pim sm
[RouterA-GigabitEthernet 2/0/3] quit
# Enable IPv6 multicast routing, MLD and IPv6 PIM-SM on Router B and Router C in the same way Router A is configured. (Details not shown.)
# Enable IPv6 multicast routing and IPv6 PIM-SM on Router D and Router E in the same way Router A is configured. (Details not shown.)
4.     Configure C-BSRs, C-RPs, and the static RP:
# On Router E, configure the service scope of RP advertisements.
<RouterE> system-view
[RouterE] acl ipv6 basic 2005
[RouterE-acl-ipv6-basic-2005] rule permit source ff0e::101 64
[RouterE-acl-ipv6-basic-2005] quit
# Configure GigabitEthernet 2/0/3 as a C-BSR and a C-RP, and configure GigabitEthernet 2/0/2 of Router D as the static RP.
[RouterE] ipv6 pim
[RouterE-pim6] c-bsr 1003::2
[RouterE-pim6] c-rp 1003::2 group-policy 2005
[RouterE-pim6] static-rp 1002::2
[RouterE-pim6] quit
# On Router A, configure GigabitEthernet 2/0/2 of Router D as a static RP.
[RouterA] ipv6 pim
[RouterA-pim6] static-rp 1002::2
[RouterA-pim6] quit
# Configure a static RP on Router B, Router C, and Router D in the same way Router A is configured. (Details not shown.)
# Display IPv6 PIM information on Router A.
[RouterA] display ipv6 pim interface
# Display BSR information on Router A.
[RouterA] display ipv6 pim bsr-info
 Scope: non-scoped
     State: Accept Preferred
     Bootstrap timer: 00:01:44
     Elected BSR address: 1003::2
       Priority: 64
       Hash mask length: 126
       Uptime: 00:11:18
# Display BSR information on Router E.
[RouterE] display ipv6 pim bsr-info
 Scope: non-scoped
     State: Elected
       Priority: 64
       Uptime: 00:11:18
     Candidate BSR address: 1003::2
       Priority: 64
# Display RP information on Router A.
[RouterA] display ipv6 pim rp-info
   BSR RP information:
 Scope: non-scoped
     Group/MaskLen: ff0e::/64
       RP address               Priority  HoldTime  Uptime    Expires
       1003::2                  192       180       00:05:19  00:02:11
Static RP information:
       RP address               ACL   Mode    Preferred
       1002::2                  ----  pim-sm  No
Example: Configuring admin-scoped IPv6 PIM-SM
As shown in Figure 18:
·     OSPFv3 runs on the network. VOD streams are sent to receiver hosts in multicast. The entire IPv6 PIM-SM domain is divided into IPv6 admin-scoped zone 1, IPv6 admin-scoped zone 2, and the IPv6 global-scoped zone. Router B, Router C, and Router D are ZBRs of the three zones, respectively.
·     Source 1 and Source 2 send different IPv6 multicast data to the IPv6 multicast group FF14::101. Host A receives the IPv6 multicast data only from Source 1, and Host B receives the IPv6 multicast data only from Source 2. Source 3 sends IPv6 multicast data to the IPv6 multicast group FF1E::202. Host C is an IPv6 multicast receiver for the IPv6 multicast group FF1E::202.
·     GigabitEthernet 2/0/2 of Router B acts as a C-BSR and a C-RP for IPv6 admin-scoped zone 1, and GigabitEthernet 2/0/1 of Router D acts as a C-BSR and a C-RP for IPv6 admin-scoped zone 2. Both of the two interfaces are designated to the IPv6 multicast groups with the scope field of 4. GigabitEthernet 2/0/1 of Router F acts as a C-BSR and a C-RP for the IPv6 global-scoped zone, and is designated to the IPv6 multicast groups with the scope field value of 14.
·     MLDv1 separately runs between Router A, Router E, Router I, and the receivers that directly connect to them.
Figure 18 Network diagram
Table 4 Interface and IPv6 address assignment
Device
IPv6 address
Device
IPv6 address
Router A
GE2/0/1
1001::1/64
Router E
GE2/0/2
3002::2/64
Router A
GE2/0/2
1002::1/64
Router E
GE2/0/3
6001::2/64
Router B
GE2/0/1
2001::1/64
Router F
GE2/0/1
8001::1/64
Router B
GE2/0/2
1002::2/64
Router F
GE2/0/2
6002::2/64
Router B
GE2/0/3
2002::1/64
Router F
GE2/0/3
2003::2/64
Router B
GE2/0/4
2003::1/64
Router G
GE2/0/1
9001::1/64
Router C
GE2/0/1
3001::1/64
Router G
GE2/0/2
8001::2/64
Router C
GE2/0/2
3002::1/64
Router H
GE2/0/1
4001::1/64
Router C
GE2/0/3
3003::1/64
Router H
GE2/0/2
3004::2/64
Router C
GE2/0/4
2002::2/64
Router I
GE2/0/1
5001::1/64
Router C
GE2/0/5
3004::1/64
Router I
GE2/0/2
4001::2/64
Router D
GE2/0/1
3003::2/64
Source 1
2001::100/64
Router D
GE2/0/3
6001::1/64
Source 2
3001::100/64
Router D
GE2/0/3
6002::1/64
Source 3
9001::100/64
Router E
GE2/0/1
7001::1/64
1.     Assign an IPv6 address and prefix length to each interface, as shown in Figure 18. (Details not shown.)
3.     Enable IPv6 multicast routing, MLD, and IPv6 PIM-SM:
# Enable MLD on the receiver-side interface (GigabitEthernet 2/0/1).
# Enable IPv6 PIM-SM on GigabitEthernet 2/0/2.
# Enable IPv6 multicast routing, MLD, and IPv6 PIM-SM on Router E and Router I in the same way Router A is configured. (Details not shown.)
# On Router B, enable IPv6 multicast routing, and enable IPv6 PIM-SM on each interface.
<RouterB> system-view
[RouterB] ipv6 multicast routing
[RouterB-mrib6] quit
[RouterB] interface gigabitethernet 2/0/1
[RouterB-GigabitEthernet2/0/1] ipv6 pim sm
[RouterB-GigabitEthernet2/0/1] quit
[RouterB] interface gigabitethernet 2/0/2
[RouterB-GigabitEthernet2/0/2] ipv6 pim sm
[RouterB-GigabitEthernet2/0/2] quit
[RouterB] interface gigabitethernet 2/0/3
[RouterB-GigabitEthernet2/0/3] ipv6 pim sm
[RouterB-GigabitEthernet2/0/3] quit
[RouterB] interface gigabitethernet 2/0/4
[RouterB-GigabitEthernet2/0/4] ipv6 pim sm
[RouterB-GigabitEthernet2/0/4] quit
# Enable IPv6 multicast routing and IPv6 PIM-SM on Router C, Router D, Router F, Router G, and Router H in the same way Router B is configured. (Details not shown.)
4.     Configure IPv6 admin-scoped zone boundaries:
# On Router B, configure GigabitEthernet 2/0/3 and GigabitEthernet 2/0/4 as the boundaries of IPv6 admin-scoped zone 1.
[RouterB-GigabitEthernet2/0/3] ipv6 multicast boundary scope 4
[RouterB-GigabitEthernet2/0/4] ipv6 multicast boundary scope 4
# On Router C, configure GigabitEthernet 2/0/4 and GigabitEthernet 2/0/5 as the boundaries of IPv6 admin-scoped zone 2.
<RouterC> system-view
[RouterC] interface gigabitethernet 2/0/4
[RouterC-GigabitEthernet2/0/4] ipv6 multicast boundary scope 4
[RouterC-GigabitEthernet2/0/4] quit
[RouterC] interface gigabitethernet 2/0/5
[RouterC-GigabitEthernet2/0/5] ipv6 multicast boundary scope 4
[RouterC-GigabitEthernet2/0/5] quit
# On Router D, configure GigabitEthernet 2/0/3 as the boundary of IPv6 admin-scoped zone 2.
[RouterD-GigabitEthernet2/0/3] ipv6 multicast boundary scope 4
5.     Configure C-BSRs and C-RPs:
# On Router B, configure GigabitEthernet 2/0/2 as a C-BSR and a C-RP for IPv6 admin-scoped zone 1.
[RouterB] ipv6 pim
[RouterB-pim6] c-bsr 1002::2 scope 4
[RouterB-pim6] c-rp 1002::2 scope 4
[RouterB-pim6] quit
# On Router D, configure GigabitEthernet 2/0/1 as a C-BSR and a C-RP for IPv6 admin-scoped zone 2.
[RouterD] ipv6 pim
[RouterD-pim6] c-bsr 3003::2 scope 4
[RouterD-pim6] c-rp 3003::2 scope 4
[RouterD-pim6] quit
# On Router F, configure GigabitEthernet 2/0/1 as a C-BSR and a C-RP for the IPv6 global-scoped zone.
<RouterF> system-view
[RouterF] ipv6 pim
[RouterF-pim6] c-bsr 8001::1
[RouterF-pim6] c-rp 8001::1
[RouterF-pim6] quit
# Display BSR information on Router B.
[RouterB] display ipv6 pim bsr-info
 Scope: non-scoped
     Bootstrap timer: 00:01:25
     Elected BSR address: 8001::1
       Priority: 64
       Uptime: 00:01:45
 Scope: 4
     State: Elected
     Bootstrap timer: 00:00:06
     Elected BSR address: 1002::2
       Priority: 64
       Uptime: 00:04:54
     Candidate BSR address: 1002::2
       Priority: 64
# Display BSR information on Router D.
[RouterD] display ipv6 pim bsr-info
 Scope: non-scoped
       Priority: 64
       Uptime: 00:01:45
   Scope: 4
     State: Elected
     Elected BSR address: 3003::2
       Priority: 64
       Uptime: 00:01:45
     Candidate BSR address: 3003::2
       Priority: 64
# Display BSR information on Router F.
[RouterF] display ipv6 pim bsr-info
 Scope: non-scoped
     State: Elected
     Bootstrap timer: 00:00:49
       Priority: 64
       Uptime: 00:01:11
     Candidate BSR address: 8001::1
       Priority: 64
# Display RP information on Router B.
[RouterB] display ipv6 pim rp-info
 BSR RP information:
   Scope: non-scoped
     Group/MaskLen: FF00::/8
       8001::1                  192       180       00:01:14  00:02:46
 Scope: 4
     Group/MaskLen: FF04::/16
       1002::2 (local)          192       180       00:02:03  00:02:56
     Group/MaskLen: FF14::/16
     Group/MaskLen: FF24::/16
     Group/MaskLen: FF34::/16
     Group/MaskLen: FF44::/16
     Group/MaskLen: FF54::/16
     Group/MaskLen: FF64::/16
     Group/MaskLen: FF74::/16
     Group/MaskLen: FF84::/16
     Group/MaskLen: FF94::/16
     Group/MaskLen: FFA4::/16
     Group/MaskLen: FFB4::/16
     Group/MaskLen: FFC4::/16
     Group/MaskLen: FFD4::/16
     Group/MaskLen: FFE4::/16
     Group/MaskLen: FFF4::/16
# Display RP information on Router F.
[RouterF] display ipv6 pim rp-info
 BSR RP information:
   Scope: non-scoped
       8001::1 (local)          192       180       00:10:28  00:02:31
Example: Configuring IPv6 BIDIR-PIM
As shown in Figure 19:
·     OSPFv3 runs on the network. VOD streams are sent to receiver hosts in IPv6 multicast. Source 1 and Source 2 send multicast data to IPv6 multicast group FF14::101. Host A and Host B are receivers of this IPv6 multicast group.
·     GigabitEthernet 2/0/1 of Router C acts as a C-BSR. Loopback 0 of Router C acts as a C-RP.
·     MLDv1 runs between Router B and Host A, and between Router D and Host B.
Figure 19 Network diagram
Table 5 Interface and IPv6 address assignment
Device
IPv6 address
Device
IPv6 address
Router A
GE2/0/1
1001::1/64
Router D
GE2/0/1
4001::1/64
Router A
GE2/0/2
1002::1/64
Router D
GE2/0/2
5001::1/64
Router B
GE2/0/1
2001::1/64
Router D
GE2/0/3
3001::2/64
Router B
GE2/0/2
1002::2/64
Source 1
1001::2/64
Router B
GE2/0/3
2002::1/64
Source 2
5001::2/64
Router C
GE2/0/1
2002::2/64
Receiver 1
2001::2/64
Router C
GE2/0/2
3001::1/64
Receiver 2
4001::2/64
Router C
Loop0
6001::1/128
1.     Assign an IPv6 address and prefix length to each interface, as shown in Figure 19. (Details not shown.)
2.     Configure OSPFv3 on the routers in the IPv6 BIDIR-PIM domain. (Details not shown.)
3.     Enable IPv6 multicast routing, IPv6 PIM-SM, IPv6 BIDIR-PIM, and MLD:
# On Router A, enable IPv6 multicast routing, enable IPv6 PIM-SM on each interface, and enable IPv6 BIDIR-PIM.
[RouterA-GigabitEthernet2/0/1] ipv6 pim sm
[RouterA] ipv6 pim
[RouterA-pim6] bidir-pim enable
[RouterA-pim6] quit
# On Router B, enable IPv6 multicast routing.
[RouterB-GigabitEthernet2/0/1] mld enable
# Enable IPv6 PIM-SM on other interfaces.
# Enable IPv6 BIDIR-PIM.
[RouterB] ipv6 pim
[RouterB-pim6] bidir-pim enable
[RouterB-pim6] quit
# On Router C, enable IPv6 multicast routing, enable IPv6 PIM-SM on each interface, and enable IPv6 BIDIR-PIM.
[RouterC] ipv6 multicast routing
[RouterC-mrib6] quit
[RouterC] interface gigabitethernet 2/0/1
[RouterC-GigabitEthernet2/0/1] ipv6 pim sm
[RouterC-GigabitEthernet2/0/1] quit
[RouterC] interface gigabitethernet 2/0/2
[RouterC-GigabitEthernet2/0/2] ipv6 pim sm
[RouterC-GigabitEthernet2/0/2] quit
[RouterC] interface loopback 0
[RouterC-LoopBack0] ipv6 pim sm
[RouterC-LoopBack0] quit
[RouterC] ipv6 pim
[RouterC-pim6] bidir-pim enable
# On Router D, enable IPv6 multicast routing.
[RouterD-GigabitEthernet2/0/1] mld enable
[RouterD-GigabitEthernet2/0/2] ipv6 pim sm
[RouterD-GigabitEthernet2/0/3] ipv6 pim sm
[RouterD] ipv6 pim
[RouterD-pim6] bidir-pim enable
[RouterD-pim6] quit
4.     On Router C, configure GigabitEthernet 2/0/1 as a C-BSR, and Loopback 0 as a C-RP for the entire IPv6 BIDIR-PIM domain.
[RouterC-pim6] c-bsr 2002::2
[RouterC-pim6] c-rp 6001::1 bidir
[RouterC-pim6] quit
1.     Display IPv6 BIDIR-PIM DF information:
# Display IPv6 BIDIR-PIM DF information on Router A.
[RouterA] display ipv6 pim df-info
 RP address: 6001::1
  Interface: GigabitEthernet2/0/1
    State     : Win        DF preference: 100
    DF metric : 2          DF uptime    : 00:07:15
    DF address: FE80::200:5EFF: FE71:2800 (local)
  Interface: GigabitEthernet2/0/2
    State     : Lose       DF preference: 100
    DF metric : 1          DF uptime    : 00:07:15
    DF address: FE80::20F:E2FF: FE38:4E01
# Display IPv6 BIDIR-PIM DF information on Router B.
[RouterB] display ipv6 pim df-info
 RP address: 6001::1
    DF address: FE80::20F:E2FF: FE38:4E01 (local)
  Interface: GigabitEthernet2/0/3
    State     : Lose       DF preference: 0
    DF metric : 0          DF uptime    : 00:07:15
    DF address: FE80::20F:E2FF: FE15:5601
# Display IPv6 BIDIR-PIM DF information on Router C.
[RouterC] display ipv6 pim df-info
 RP address: 6001::1
  Interface: Loop0
    State     : -          DF preference: -
    DF metric : -          DF uptime    : -
    DF address: -
    State     : Win        DF preference: 0
    DF address: FE80::20F:E2FF: FE15:5601 (local)
    DF address: FE80::20F:E2FF: FE15:5602 (local)
# Display IPv6 BIDIR-PIM DF information on Router D.
[RouterD] display ipv6 pim df-info
 RP address: 6001::1
    DF address: FE80::200:5EFF: FE71:2802 (local)
2.     Display information about DFs for IPv6 multicast forwarding:
# Display information about DFs for IPv6 multicast forwarding on Router A.
[RouterA] display ipv6 multicast forwarding df-info
Total 1 RPs, 1 matched
00001. RP address: 6001::1
     Flags: 0x0
     Uptime: 00:08:32
     RPF interface: GigabitEthernet2/0/2
     List of 1 DF interfaces:
# Display information about DFs for IPv6 multicast forwarding on Router B.
[RouterB] display ipv6 multicast forwarding df-info
     Flags: 0x0
     Uptime: 00:06:24
     RPF interface: GigabitEthernet2/0/3
# Display information about DFs for IPv6 multicast forwarding on Router C.
[RouterC] display ipv6 multicast forwarding df-info
     Flags: 0x0
     Uptime: 00:07:21
     RPF interface: LoopBack0
     List of 2 DF interfaces:
       2: GigabitEthernet2/0/2
# Display information about DFs for IPv6 multicast forwarding on Router D.
[RouterD] display ipv6 multicast forwarding df-info
     Flags: 0x0
     Uptime: 00:05:12
Example: Configuring IPv6 PIM-SSM
As shown in Figure 20:
·     The receivers receive VOD information through multicast. The receiver groups of different organizations form stub networks, and one or more receiver hosts exist in each stub network. The entire IPv6 PIM domain operates in the SSM mode.
·     Host A and Host C are IPv6 multicast receivers in two stub networks, N1 and N2.
·     The SSM group range is FF3E::/64.
·     MLDv2 runs between Router A and N1, and between Router B, Router C, and N2.
Figure 20 Network diagram
Table 6 Interface and IPv6 address assignment
Device
IPv6 address
Device
IPv6 address
Router A
GE2/0/1
1001::1/64
Router D
GE2/0/1
4001::1/64
Router A
GE2/0/2
1002::1/64
Router D
GE2/0/2
1002::2/64
Router A
GE2/0/3
1003::1/64
Router D
GE2/0/3
4002::1/64
Router B
GE2/0/1
2001::1/64
Router E
GE2/0/1
3001::2/64
Router B
GE2/0/2
2002::1/64
Router E
GE2/0/2
2002::2/64
Router C
GE2/0/1
2001::2/64
Router E
GE2/0/3
1003::2/64
Router C
GE2/0/2
3001::1/64
Router E
GE2/0/4
4002::2/64
1.     Assign an IPv6 address and prefix length for each interface, as shown in Figure 20. (Details not shown.)
2.     Configure OSPFv3 on the routers in the IPv6 PIM-SSM domain. (Details not shown.)
3.     Enable IPv6 multicast routing, MLD and IPv6 PIM-SM:
# Enable MLDv2 on GigabitEthernet 2/0/1 (the interface that connects to the stub network).
[RouterA-GigabitEthernet2/0/1] mld version 2
[RouterA-GigabitEthernet2/0/3] ipv6 pim sm
[RouterA-GigabitEthernet2/0/3] quit
4.     Configure the IPv6 SSM group range FF3E::/64 on Router A.
[RouterA] acl ipv6 basic 2000
[RouterA-acl-ipv6-basic-2000] rule permit source ff3e:: 64
[RouterA-acl-ipv6-basic-2000] quit
[RouterA] ipv6 pim
[RouterA-pim6] ssm-policy 2000
[RouterA-pim6] quit
5.     Configure the IPv6 SSM group range on Router B, Router C, Router D and Router E in the same way Router A is configured. (Details not shown.)
# Send an MLDv2 report from Host A to join IPv6 multicast source and group (4001::100/64, FF3E::101). (Details not shown.)
 (4001::100, FF3E::101)
     Protocol: pim-ssm, Flag:
     UpTime: 00:00:11
         Upstream neighbor: FE80::A01:201:2
         RPF prime neighbor: FE80::A01:201:3
             Protocol: mld, UpTime: 00:00:11, Expires: 00:03:25
     Protocol: pim-ssm, Flag: LOC
     UpTime: 00:08:02
             Protocol: pim-ssm, UpTime: 00:08:02, Expires: 00:03:25
The output shows that routers on the SPT path (Router A and Router D) have generated the correct (S, G) entries.
Troubleshooting IPv6 PIM
A multicast distribution tree cannot be correctly built
Symptom
No IPv6 multicast forwarding entries are established on the devices (including devices directly connected with multicast sources or receivers) in an IPv6 PIM network. This means that an IPv6 multicast distribution tree cannot be correctly built.
Solution
To resolve the problem:
1.     Use display ipv6 routing-table to verify that an IPv6 unicast route to the IPv6 multicast source or the RP is available.
2.     Use display ipv6 pim interface to verify IPv6 PIM information on each interface, especially on the RPF interface. If IPv6 PIM is not enabled on the interfaces, use ipv6 pim dm or ipv6 pim sm to enable IPv6 PIM-DM or IPv6 PIM-SM for the interfaces.
3.     Use display ipv6 pim neighbor to verify that the RPF neighbor is an IPv6 PIM neighbor.
4.     Verify that IPv6 PIM and MLD are enabled on the interfaces that directly connect to the IPv6 multicast sources or the receivers.
5.     Use display ipv6 pim interface verbose to verify that the same IPv6 PIM mode is enabled on the RPF interface on a device and the connected interface of the device's RPF neighbor.
6.     Use display current-configuration to verify that the same IPv6 PIM mode is enabled on all devices on the network. For IPv6 PIM-SM, verify that the BSR and C-RPs are correctly configured.
7.     If the problem persists, contact H3C Support.
IPv6 multicast data is abnormally terminated on an intermediate device
Symptom
An intermediate device can receive IPv6 multicast data successfully, but the data cannot reach the last-hop device. An interface on the intermediate device receives IPv6 multicast data but does not create an (S, G) entry in the IPv6 PIM routing table.
Solution
1.     Use display current-configuration to verify the IPv6 multicast forwarding boundary settings. Use ipv6 multicast boundary to change the multicast forwarding boundary settings to make the IPv6 multicast packet able to cross the boundary.
2.     Use display current-configuration to verify the IPv6 multicast source policy. Change the ACL rule defined in the source-policy command so that the source/group address of the IPv6 multicast data can pass ACL filtering.
3.     If the problem persists, contact H3C Support.
An RP cannot join an SPT in IPv6 PIM-SM
Symptom
An RPT cannot be correctly built, or an RP cannot join the SPT toward the IPv6 multicast source.
Solution
1.     Use display ipv6 routing-table to verify that an IPv6 unicast route to the RP is available on each device.
2.     Use display ipv6 pim rp-info to verify that the dynamic RP information is consistent on all devices.
3.     Use display ipv6 pim rp-info to verify that the same static RPs are configured on all devices on the network.
4.     If the problem persists, contact H3C Support.
An RPT cannot be built or IPv6 multicast source registration fails in IPv6 PIM-SM
Symptom
The C-RPs cannot unicast advertisement messages to the BSR. The BSR does not advertise BSMs containing C-RP information and has no IPv6 unicast route to any C-RP. An RPT cannot be correctly established, or the source-side DR cannot register the IPv6 multicast source with the RP.
Solution
1.     Use display ipv6 routing-table on each device to view routing table information. Verify that IPv6 unicast routes to the C-RPs and the BSR are available on each device and that a route is available between each C-RP and the BSR.
2.     Use display ipv6 pim bsr-info to verify that the BSR information exists on each device.
3.     Use display ipv6 pim rp-info to verify that the RP information is correct on each device.
4.     Use display ipv6 pim neighbor to verify that IPv6 PIM neighboring relationship has been correctly established among the devices.
5.     If the problem persists, contact H3C Support.
