- 15-WLAN Configuration Guide (AC)
- 01-WLAN hardware compatibility (ACs)
- 02-AP management configuration
- 03-Radio management configuration
- 04-WLAN access configuration
- 05-WLAN security configuration
- 06-WLAN authentication configuration
- 07-WIPS configuration
- 08-WLAN QoS configuration
- 09-WLAN roaming configuration
- 10-WLAN load balancing configuration
- 11-WLAN radio resource measurement configuration
- 12-Channel scanning configuration
- 13-Band navigation configuration
- 14-WLAN multicast optimization configuration
- 15-WLAN RRM configuration
- 16-WLAN IP snooping configuration
- 17-WLAN probe configuration
- 18-Spectrum management configuration
01-WLAN hardware compatibility (ACs) | 35.91 KB |
This following compatibility matrix describes MSR routers that can function as ACs and their compatible APs.
AC-capable MSR routers |
Compatible APs |
MSR810 MSR810-W MSR810-W-DB MSR810-LM MSR810-LM-HK MSR810-LM-CNDE-SJK MSR810-CNDE-SJK MSR810-W-LM MSR810-W-LM-HK MSR810-LME MSR2600-6-X1 MSR2600-10-X1 MSR2630 MSR3600-28 MSR3600-28-X1 MSR3600-28-X1-DP MSR3600-51 MSR3600-51-X1 MSR3600-51-X1-DP MSR3610 MSR3610-X1-DP MSR3610-X1-DC MSR3610-X1-DP-DC MSR3620 MSR3640 MSR3660 |
WA4320i-ACN WA4320H-ACN WA4320-ACN WA4320X WA4330-ACN WA4320-ACN-B WA4320H-ACN-HI WA4320-ACN-SI WA4320H WA4320H-EI WA5320 WA5320H WA5320E WA5320i WA5320-SI WA5530 WA5530-SI WA5620 WA5620i-ACN |
MSR810-W-WiNet MSR810-LM-WiNet MSR830-10BEI-WiNet MSR830-6BEI-WiNet MSR830-5BEI-WiNet MSR830-10PBEI-WiNet MSR830-10BHI-WiNet MSR830-6BHI-WiNet MSR830-4LM-WiNet MSR2600-6-WiNet MSR2600-10-X1-WiNet MSR2630-WiNet MSR3600-28-WiNet MSR3610-WiNet MSR3610-X1-WiNet MSR3620-WiNet MSR3620-DP-WiNet MSR3660-WiNet |
WA2620-WiNet WA2620E-WiNet WA5320-WiNet WA5320E-WiNet |
MSR2630-XS MSR3600-28-XS MSR3610-XS MSR3610-I-XS MSR3610-IE-XS MSR3620-XS |
N/A |
MSR810-LM-GL MSR810-W-LM-GL MSR830-6EI-GL MSR830-10EI-GL MSR830-6HI-GL MSR830-10HI-GL MSR2600-6-X1-GL |
WA510H-WW WA530-WW WA530X-WW WA536-WW WA538-WW WA560-WW |
MSR810-10-PoE MSR3610-X1 MSR3620-DP |
WA4320i-ACN WA4320H-ACN WA4320-ACN WA4320X WA4330-ACN WA4320-ACN-B WA4320H-ACN-HI WA4320-ACN-SI WA4320H WA4320H-EI WA5320 WA5320H WA5320E WA5320i WA5320-SI WA5530 WA5530-SI WA5620 WA5620i-ACN WA510H-WW WA530-WW WA530X-WW WA536-WW WA538-WW WA560-WW |
MSR3610-I-DP MSR3610-IE-DP MSR3610-IE-ES MSR3610-IE-EAD |
WA4320i-ACN WA4320H-ACN WA4320-ACN WA4320X WA4330-ACN WA4320-ACN-B WA4320H-ACN-HI WA4320-ACN-SI WA4320H WA4320H-EI WA5320 WA5320H WA5320E WA5320i WA5320-SI WA5530 WA5530-SI WA5620 WA5620i-ACN WA510H-WW WA530-WW WA530X-WW WA536-WW WA538-WW WA560-WW SIC-AP220 |
