13-Voice Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR810[2600][3600] Routers Configuration Guides(V7)-R0809-6W40013-Voice Configuration Guide
02-Voice entity configuration
02-Voice entity configuration 251.74 KB
Configuring voice entities· 1
About voice entities· 1
Types of voice entities· 1
Incoming voice entities and outgoing voice entities· 1
Restrictions: Hardware compatibility with voice entities· 2
Restrictions: Licensing requirements for voice entities· 3
Voice entities tasks at a glance· 3
Configuring a POTS entity· 4
POTS entity tasks at a glance· 4
Creating a POTS entity and configuring basic parameters· 4
Configuring codecs for a POTS entity· 5
Configuring a POTS entity to register with the registrar 6
Configuring DTMF for a POTS entity· 7
Setting a DSCP value for a POTS entity· 7
Configuring the playout delay for a POTS entity· 8
Enabling VAD for a POTS entity· 8
Configuring a POTS entity to play ringback tones· 9
Configuring options related to dial program·· 9
Configuring a VoIP entity· 10
VoIP entity tasks at a glance· 10
Creating a VoIP entity and configuring basic parameters· 11
Configuring codecs for a VoIP entity· 12
Configuring DTMF for a VoIP entity· 13
Enabling VAD for a VoIP entity· 13
Setting a DSCP value for a VoIP entity· 14
Configuring the playout delay for a VoIP entity· 15
Configuring a VoIP entity to play ringback tones· 15
Configuring options related to dial program·· 16
Configuring an IVR entity· 16
IVR entity tasks at a glance· 16
Creating an IVR entity and configuring basic parameters· 17
Configuring codecs for an IVR entity· 17
Configuring an IVR entity to register with the registrar 18
Configuring DTMF for an IVR entity· 19
Setting a DSCP value for an IVR entity· 19
Enabling VAD for an IVR entity· 20
Configuring options related to dial program·· 20
Setting the RTP timeout period· 21
Setting the maximum duration of DSP-buffered data· 21
Enabling SIP logging· 23
Display and maintenance commands for voice entities· 24
Voice entities identify the originators and the terminators of calls, what protocols used to process the calls, and which routes used to forward the calls.
Voice entities include POTS entities, VoIP entities, and IVR entities. You can configure voice entities based on the types of connected devices.
Figure 1 Voice entities
·     POTS entity—A POTS entity connects to a local telephone or a PSTN network. When connecting to a local telephone, a POTS entity maintains local number information. When connecting to a PSTN network, a POTS entity maintains call destination information.
·     VoIP entity—Connects to the IP side. A VoIP entity uses SIP to make VoIP calls. VoIP entities include the following categories:
¡     Dynamic and static VoIP entities.
¡     Incoming and outgoing VoIP entities.
A static incoming VoIP entity maintains the called information such as called number and call destination. Other types of VoIP entities are used in SRST. For more information, see "Configuring SRST."
·     IVR entity—Sets a customizable IVR system. For more information about IVR entities, see "Configuring customizable IVR."
Each call has an incoming voice entity and an outgoing voice entity on the device.
·     Incoming voice entity—Matches incoming calls. The device selects an incoming voice entity for an incoming call based on the calling number, the called number, or the PSTN interface. Incoming voice entities are used in the call pickup service and SIP register authentication.
·     Outgoing voice entity—Matches outgoing calls. The device selects an outgoing voice entity for an outgoing call based on the called number. Outgoing voice entities are used to route calls to call destinations.
Figure 2 Incoming voice entities and outgoing voice entities
Hardware
Voice entity compatibility
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK
Yes for only VoIP entities and IVR entities
MSR810-LMS, MSR810-LUS
No
MSR810-LMS-EA, MSR810-LME
No
MSR2600-6-X1
No
MSR2600-10-X1
Yes
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
No
No
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD
No
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC
Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes
MSR3610-G, MSR3620-G
No
Hardware
MSR810-W-WiNet, MSR810-LM-WiNet
MSR830-4LM-WiNet
No
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
No
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
No
MSR2600-6-WiNet
No
MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
No
MSR3600-28-WiNet
No
MSR3610-X1-WiNet
No
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
No
Hardware
MSR2630-XS
No
MSR3600-28-XS
No
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
No
MSR3610-IE-XS
No
Hardware
MSR810-LM-GL
MSR810-W-LM-GL
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
To support voice entities, some device models require the Voice Software License. For more information, see license management in Fundamentals Configuration Guide.
To configure a voice entity, perform the following tasks:
1.     Configure a voice entity
¡     Configuring a POTS entity
¡     Configuring a VoIP entity
¡     Configuring an IVR entity
2.     (Optional.) Setting the RTP timeout period
3.     (Optional.) Setting the maximum duration of DSP-buffered data
4.     (Optional.) Enabling SIP logging
To configure a POTS entity, perform the following tasks:
1.     Creating a POTS entity and configuring basic parameters
2.     (Optional.) Configuring codecs for a POTS entity
3.     (Optional.) Configuring a POTS entity to register with the registrar
4.     (Optional.) Configuring DTMF for a POTS entity
5.     (Optional.) Setting a DSCP value for a POTS entity
6.     (Optional.) Configuring the playout delay for a POTS entity
7.     (Optional.) Enabling VAD for a POTS entity
8.     (Optional.) Configuring a POTS entity to play ringback tones
9.     (Optional.) Configuring options related to dial program
Upon receiving a call, the device selects an incoming POTS entity by comparing the call information with POTS entity attributes in the following order:
1.     Called number with the called number string configured by the incoming called-number command.
2.     Calling number with the calling number string configured by the answer-address command.
3.     Calling number with the number template configured by the match-template command.
Once the call matches a POTS entity, the device stops matching and routes the call based on the attributes of the matching POTS entity.
2.     Enter voice view.
voice-setup
3.     Enter dial program view.
dial-program
4.     Create a POTS entity and enter its view.
entity entity-number pots
By default, no POTS entities exist.
5.     (Optional.) Configure a description for the POTS entity.
6.     Configure a number template for the POTS entity.
match-template match-string
The POTS entity uses the number template to match phone numbers. For example, the match-template 20 command matches all numbers beginning with 20.
7.     Bind a voice interface to the POTS entity.
line line-number
By default, no voice interface is bound to a POTS entity.
8.     (Optional.) Configure a number string for the POTS entity to match incoming calls. Choose the options to configure as needed:
¡     Configure a called number string.
incoming called-number called-number-string
If the called number string of a POTS entity matches the called number of a call, the device uses the POTS entity as the incoming voice entity of the call.
¡     Configure a calling number string.
answer-address calling-number-string
If the calling number string of a POTS entity matches the calling number of a call, the device uses the POTS entity as the incoming voice entity of the call.
By default, no number string is configured to match incoming calls. A call does not use a voice entity as an incoming voice entity.
9.     Enable the POTS entity.
By default, a POTS entity is enabled.
By default, a POTS entity has four codecs g729r8, g711alaw, g711ulaw, and g723r53 in descending order of priority.
You can use one of the following methods to configure codecs for a POTS entity:
·     Configure codecs for a POTS entity.
·     Create a codec template, assign priorities to codecs in the codec template, and bind the codec template to a POTS entity.
A call can be established only when the calling party and the called party use the same codec. You can use the display voice sip call command (see Voice Command Reference) to view the codec used by two parties.
Configuring a codec for a POTS entity
voice-setup
dial-program
4.     Enter POTS entity view.
5.     Configure a codec for the POTS entity.
codec { g711alaw | g711ulaw | g723r53 | g723r63 | g726r16 | g726r24 | g726r32 | g726r40 | g729a | g729br8 | g729r8 } [ bytes payload-size ]
By default, no codec is configured for a POTS entity.
Binding a codec template to a POTS entity
voice-setup
3.     Create a codec template and enter its view.
voice class codec tag
4.     Assign a priority to a codec in the codec template.
codec preference priority { g711alaw | g711ulaw | g723r53 | g723r63 | g726r16 | g726r24 | g726r32 | g726r40 | g729a | g729br8 | g729r8 } [ bytes payload-size ]
5.     Return to voice view.
6.     Enter dial program view.
dial-program
7.     Enter POTS entity view.
8.     Bind the codec template to the POTS entity.
voice-class codec tag
By default, no codec template is bound to a POTS entity.
Perform this task to configure a POTS entity to register with the registrar. If you do not want to register a number or you want to deregister a number from the registrar, you can use the undo register number command.
voice-setup
dial-program
5.     Configure the POTS entity to register with the registrar server.
register number
By default, a POTS entity initiates a registration to the registrar server after UA registration is configured.
For more information about this command, see SIP commands in Voice Command Reference.
There are the following ways to transmit DTMF tones:
·     Inband signaling—Sends DTMF tones in RTP packets.
·     Out-of-band signaling—Sends DTMF tones in SIP messages or sends DTMF tones in RFC 2883-compliant RTP messages (NTE mode). To use NTE mode, configure the outband nte command and the same payload type value on the originating and terminating sides. Otherwise, the originating side might fail to transmit DTMF tones. For more information about out-of-band DTMF, see "Configuring SIP."
voice-setup
dial-program
5.     Configure DTMF transmission.
outband { nte | sip }
By default, inband transmission is adopted.
6.     (Optional.) Set the value of the payload type used by NTE.
rtp payload-type nte value
By default, the value of the payload type used by NTE is 101.
When the device is connected to a device from another vendor, you cannot set the payload type field to any value forbidden by that device. A violation might cause an NTE negotiation failure.
You can set a DSCP value for IP packets carrying media streams to provide differentiated voice services.
You can configure the ip qos dscp command both globally (in SIP view) and for a specific POTS entity (in POTS entity view). The configuration in POTS entity view takes precedence over the global configuration. A POTS entity uses the global configuration only when the ip qos dscp command is not configured in POTS entity view. For information about configuring a DSCP value in SIP view, see "Configuring SIP."
voice-setup
dial-program
5.     Set a DSCP value for IP packets carrying media streams.
ip qos dscp { dscp-value | dscp-value-set } media
The default value is ef (101110), the global default value.
In an ideal voice network environment, the delay of each voice packet (time for each voice packet to travel from the sender to the receiver) is fixed. That is, the jitter is 0. In an actual voice network, the delay varies from packet to packet.
To smoothly play out voice packets received with different delay times, the receiver can buffer the voice packets for a period of time (playout delay time). By configuring playout delay, you can prevent delay variation (jitter) from affecting voice quality.
voice-setup
dial-program
5.     Configure the playout delay mode for the POTS entity.
playout-delay mode { adaptive | fixed }
The default mode is fixed.
6.     Configure the playout delay time.
playout-delay { initial milliseconds | maximum milliseconds | minimum milliseconds }
By default, the initial playout delay time is 30 milliseconds, the maximum playout delay time is 160 milliseconds, and the minimum playout delay time is 10 milliseconds.
The voice activity detection (VAD) feature discriminates between silence and speech on a voice connection according to their energies. With VAD, a POTS entity does not generate traffic during periods of silence.
voice-setup
dial-program
5.     Enable VAD for the POTS entity.
vad-on [ g711 | g723r53 | g723r63 | g729a | g729r8 ] *
By default, VAD is disabled for a POTS entity.
The G.726 codec does not support VAD. The G.729br8 codec always supports VAD.
The G.711 codec is supported only the following interface modules:
¡     HMIM-1VE1.
¡     HMIM-1VT1.
¡     HMIM-2VE1.
¡     HMIM-2VT1.
¡     SIC-1BSV.
¡     SIC-1VE1T1.
¡     SIC-2BSV.
¡     SIC-2FXS1FXO.
The G.711 codec is supported only if the DSP image is configured as the Microsoft-verified version.
If the terminating side of a call cannot play ringback tones, configure a POTS entity on the originating side to play ringback tones.
This feature does not take effect if the POTS entity is bound to an FXS or FXO interface.
voice-setup
dial-program
5.     Configure the POTS entity to play ringback tones.
send-ring
By default, a POTS entity on the originating side does not play ringback tones.
voice-setup
dial-program
For more information about the following commands in this view, see "Configuring dial programs."
5.     Configure permitted calling numbers.
caller-permit calling-string
By default, a POTS entity permits all calling numbers.
6.     Set the priority of the POTS entity.
priority priority-order
By default, the priority level is 0.
The smaller the number, the higher the priority.
7.     Set the maximum number of calls allowed by the POTS entity.
max-conn max-number
By default, the number of calls allowed by a POTS entity is not limited.
8.     Configure a dial prefix for the POTS entity
dial-prefix string
9.     Bind a number substitution rule list to the POTS entity.
substitute { called | calling } list-number
By default, no number substitution rule list is bound to a POTS entity (no number substitution is performed).
10.     Bind a subscriber group to the POTS entity.
caller-group { deny | permit } group-id
By default, no subscriber group is bound to a POTS entity (any calling number is allowed to originate calls).
11.     Configure the number sending mode.
send-number { digit-number | all | truncate }
By default, the truncate mode is used.
To configure a VoIP entity, perform the following tasks:
1.     Creating a VoIP entity and configuring basic parameters
2.     (Optional.) Configuring codecs for a VoIP entity
3.     (Optional.) Configuring DTMF for a VoIP entity
4.     (Optional.) Enabling VAD for a VoIP entity
5.     (Optional.) Setting a DSCP value for a VoIP entity
6.     (Optional.) Configuring the playout delay for a VoIP entity
7.     (Optional.) Configuring a VoIP entity to play ringback tones
8.     (Optional.) Configuring options related to dial program
Upon receiving a call, the device selects an incoming VoIP entity by comparing the call information with VoIP entity attributes in the following order:
3.     Calling number with the number template configured by the match-template command. The VoIP entity uses the number template to match phone numbers. For example, the match-template 20 command matches all numbers beginning with 20.
Once the call matches a VoIP entity, the device stops matching and routes the call based on the attributes of the matching VoIP entity.
voice-setup
dial-program
4.     Create a VoIP entity and enter its view.
entity entity-number voip
5.      (Optional.) Configure a description for the VoIP entity.
6.     Configure a number template for the VoIP entity.
7.     Configure the destination IP address.
address sip ip ip-address [ port port-number ]
For more information about this command, see Voice Command Reference.
8.     (Optional.) Configure number string for the VoIP entity to match incoming calls. Choose the options to configure as needed:
If the called number of a VoIP entity matches the called number of a call, the device uses the VoIP entity as the incoming voice entity of the call.
If the calling number of a VoIP entity matches the calling number of a call, the device uses the VoIP entity as the incoming voice entity of the call.
9.     Enable the VoIP entity.
By default, a VoIP entity is enabled.
By default, a VoIP entity has four codecs g729r8, g711alaw, g711ulaw, and g723r53 in descending order of priority.
You can use one of the following methods to configure codecs for a VoIP entity:
·     Configure codecs directly for a VoIP entity.
·     Create a codec template, assign priorities to codecs in the codec template, and bind the codec template to a VoIP entity.
Configuring a codec for a VoIP entity
voice-setup
dial-program
4.     Enter VoIP entity view.
5.     Configure a codec for the VoIP entity.
By default, no codec is configured for a VoIP entity.
Binding a codec template to a VoIP entity
voice-setup
dial-program
7.     Enter VoIP entity view.
8.     Bind the codec template to the VoIP entity.
By default, no codec template is bound to a VoIP entity.
·     Out-of-band signaling—Sends DTMF tones in SIP messages or sends DTMF tones in RFC 2883-compliant RTP packets (NTE mode). To use the NTE mode, configure command outband nte and the same payload type value on both the originating and terminating sides. Otherwise, the originating side might fail to transmit DTMF tones. For more information about out-of-band DTMF, see "Configuring SIP."
voice-setup
dial-program
5.     Configure out-of-band DTMF signaling.
By default, inband DTMF signaling is used.
6.     Set the value of the payload type used by NTE.
The voice activity detection (VAD) feature discriminates between silence and speech on a voice connection according to their energies. With VAD, a POTS entity does not generate traffic during periods of silence in an active voice connection.
voice-setup
dial-program
5.     Enable VAD for a VoIP entity.
By default, VAD is disabled for a VoIP entity.
¡     HMIM-1VE1.
¡     HMIM-1VT1.
¡     HMIM-2VE1.
¡     HMIM-2VT1.
¡     SIC-1BSV.
¡     SIC-1VE1T1.
¡     SIC-2BSV.
¡     SIC-2FXS1FXO.
You can configure the ip qos dscp command both globally (in SIP view) and for a specific VoIP entity (in VoIP entity view).The configuration in VoIP entity view takes precedence over the global configuration. A VoIP entity uses the global configuration only when the ip qos dscp command is not configured in VoIP entity view. For information about configuring a DSCP value in SIP view, see "Configuring SIP."
voice-setup
dial-program
In an ideal voice network environment, the delay of each voice packet (time for each voice packet to transmit from the sender to the receiver) is fixed. That is, the jitter is 0. In an actual voice network, the delay varies from packet to packet.
voice-setup
dial-program
5.     Configure the playout delay mode for the VoIP entity.
By default, the playout delay mode is fixed.
6.     Set the playout delay time.
If the terminating side of a call cannot play ringback tones, configure a VoIP entity on the originating side to play ringback tones.
voice-setup
dial-program
5.     Configure the VoIP entity to play ringback tones.
send-ring
By default, a VoIP entity on the originating side does not play ringback tones.
voice-setup
dial-program
5.     Configure the permitted calling numbers.
By default, a voice entity permits all calling numbers.
6.     Set the maximum number of calls allowed by the VoIP entity.
max-conn max-number
By default, the number of calls allowed by a VoIP entity is not limited.
7.     Set the priority of the VoIP entity.
8.     Bind a number substitution rule list to the VoIP entity.
By default, no number substitution rule list is bound to a VoIP entity.
9.     Bind a subscriber group to the VoIP entity.
By default, no subscriber group is bound to a VoIP entity.
To configure an IVR entity, perform the following tasks:
1.     Creating an IVR entity and configuring basic parameters
2.     (Optional.) Configuring codecs for an IVR entity
3.     (Optional.) Configuring an IVR entity to register with the registrar
4.     (Optional.) Configuring DTMF for an IVR entity
5.     (Optional.) Setting a DSCP value for an IVR entity
6.     (Optional.) Enabling VAD for an IVR entity
7.     (Optional.) Configuring options related to dial program
voice-setup
dial-program
4.     Create an IVR entity and enter its view.
entity entity-number ivr
5.     (Optional.) Configure a description for the IVR entity.
6.     Configure a number template for the IVR entity.
7.     Configure a root node for the IVR entity.
ivr-root node-id
8.     Enable the IVR entity.
By default, an IVR entity is enabled.
By default, an IVR entity has four codecs g729r8, g711alaw, g711ulaw, and g723r53 in descending order of priority.
You can use one of the following methods to configure codecs for an IVR entity:
·     Configure codecs directly for an IVR entity.
·     Create a codec template, assign priorities to codecs in the codec template, and bind the codec template to an IVR entity.
Configuring a codec for an IVR entity
voice-setup
dial-program
4.     Enter IVR entity view.
5.     Specify a codec for the IVR entity.
By default, no codec is configured for an IVR entity.
Binding a codec template to an IVR entity
voice-setup
dial-program
7.     Enter IVR entity view.
8.     Bind the codec template to the IVR entity.
By default, no codec template is bound to an IVR entity.
Perform this task to configure an IVR entity to register with the registrar. If you do not want to register a number or you want to deregister a number from the registrar, you can use the undo register number command.
voice-setup
dial-program
5.     Configure the IVR entity to register with the registrar.
register-number
By default, an IVR entity initiates a registration to the registrar after UA registration is configured.
There are two ways to transmit DTMF tones:
·     Out-of-band signaling—Sends DTMF tones in SIP messages or RFC 2883-compliant RTP packets (NTE mode). To use the NTE mode, configure the outband nte command and the same payload type value on both the originating and terminating sides. Otherwise, the originating side might fail to transmit DTMF tones.
voice-setup
dial-program
5.     Configure out-of-band DTMF by using NTE mode.
outband nte
6.     Configure the value of the NTE payload type.
By default, the value of the NTE payload type is 101.
When the device is connected to a device from another vendor, you cannot set the payload type field to any value forbidden by that device. Otherwise, an NTE negotiation failure might occur.
You can configure the ip qos dscp command both globally (in SIP view) and for a specific IVR entity (in IVR entity view).The configuration in IVR entity view takes precedence over the global configuration. An IVR entity uses the global configuration only when the ip qos dscp command is not configured in IVR entity view. For information about configuring a DSCP value in SIP view, see "Configuring SIP."
voice-setup
dial-program
The voice activity detection (VAD) feature discriminates between silence and speech on a voice connection according to their energies. With VAD, an IVR entity does not generate traffic during periods of silence in an active voice connection.
voice-setup
dial-program
5.     Enable VAD for the IVR entity.
By default, VAD is disabled for an IVR entity.
¡     HMIM-1VE1.
¡     HMIM-1VT1.
¡     HMIM-2VE1.
¡     HMIM-2VT1.
¡     SIC-1BSV.
¡     SIC-1VE1T1.
¡     SIC-2BSV.
¡     SIC-2FXS1FXO.
voice-setup
dial-program
By default, an IVR entity permits all calling numbers.
6.     Configure the priority of the IVR entity.
7.     Configure the maximum number of calls allowed by the IVR entity.
max-conn max-number
By default, the number of calls allowed by an IVR entity is not limited.
8.     Bind a number substitution rule list to the IVR entity.
By default, no number substitution rule list is bound to an IVR entity.
9.     Bind a subscriber group to the IVR entity.
By default, no subscriber group is bound to an IVR entity.
The device disconnects a call if it does not receive RTP traffic during the set timeout period.
voice-setup
3.     Set the RTP timeout period.
rtp-detect timeout value
By default, the RTP timeout period is 120 seconds.
VoIP voice data is buffered in the DSP buffer if a network latency or jitter exists. When the maximum duration of DSP-buffered data is reached, the device clears the DSP buffer to improve the quality of VoIP calls. You can adjust the maximum duration of DSP-buffered data.
Hardware and feature compatibility
Hardware
Feature compatibility
No
No
No
MSR2600-6-X1, MSR2600-10-X1
No
MSR 2630
No
No
No
No
No
No
Yes
No
Hardware
No
MSR830-4LM-WiNet
No
No
No
MSR2600-6-WiNet, MSR2600-10-X1-WiNet
No
MSR2630-WiNet
No
MSR3600-28-WiNet
No
MSR3610-X1-WiNet
No
Yes
Hardware
MSR2630-XS
No
MSR3600-28-XS
No
MSR3610-XS
No
MSR3620-XS
Yes
MSR3610-I-XS
No
MSR3610-IE-XS
No
Hardware
Command compatibility
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
When PCM pass-through is enabled, the set maximum duration of DSP-buffered data takes effect.
When PCM pass-through is disabled, one of the following rules applies:
·     If the set maximum duration of DSP-buffered data is in the range of 10 to 179 milliseconds, the default value (270 milliseconds) takes effect.
·     If the set maximum duration of DSP-buffered data is 0 or in the range of 180 to 480 milliseconds, the set value takes effect.
For more information about PCM pass-through, see "Configuring voice interfaces."
voice-setup
3.     Set the maximum duration of DSP-buffered data.
vqa-dsp-buffer maximum-time time
By default, the maximum duration of DSP-buffered data is 270 milliseconds.
SIP logging enables the device to log SIP call events and send the log messages to the information center. With the information center, you can set log message filtering and output rules, including output destinations. For more information about using the information center, see Network Management and Monitoring Configuration Guide.
voice-setup
3.     Enable SIP logging.
sip log enable
By default, SIP logging is disabled.
Display voice call information.
display voice call-info { tag | all }
Display the configuration of voice entities.
display voice entity { entity-tag | all | ivr | pots | voip }
Display control information about calls in progress.
display voice call
