HomeSupportConfigure & DeployConfiguration GuidesH3C MSR810[2600][3600] Routers Configuration Guides(V7)-R0809-6W40001-Fundamentals Configuration Guide
13-License management
13-License management 156.45 KB
Managing licenses
About licenses
License-based features, such as Comware software package, RTC terminal access, POS terminal access, AP online, IPS signature database, ACG signature database, SSL VPN, and Web caching., require licenses to run on your device.
License types
Licenses include trial licenses and formal licenses. Trial licenses typically have time limits. Purchase and install a formal license for a license-based feature before its trial license expires, so that the feature is still usable.
Licenses for different device types
(In standalone mode.) You must purchase a license key for the entire device. To license the device, use the license key and the device's SN and DID to register an activation file and install the activation file on the device.
(In IRF mode.) You must purchase a license key for each IRF member device. To license an IRF member device, use the license key and the member's SN and DID to register an activation file and install the activation file on the IRF member device. An IRF member device is licensed even if the device joins another IRF fabric.
License classification
Licenses for devices include package licenses and feature licenses.
H3C website provides the same license registration procedure for package licenses and feature licenses.
Comware package license
For the support of hardware platforms for Comware packages, the following matrixes show the necessity of Comware package license:
Hardware
Comware package license necessity
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK
No
MSR810-LMS, MSR810-LUS
No
MSR810-LMS-EA, MSR810-LME
No
MSR2600-6-X1, MSR2600-10-X1
No
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
No
No
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD
No
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC
No
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes:
·     MSR 3610
·     MSR 3620
·     MSR 3640
·     MSR 3660
No: MSR3620-DP
MSR3610-G, MSR3620-G
No
Hardware
MSR810-W-WiNet, MSR810-LM-WiNet
No
MSR830-4LM-WiNet
No
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
No
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
No
MSR2600-6-WiNet, MSR2600-10-X1-WiNet
No
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
No
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
Yes:
·     MSR3610-WiNet
·     MSR3620-10-WiNet
·     MSR3620-WiNet
·     MSR3660-WiNet
No: MSR3620-DP-WiNet
Hardware
MSR2630-XS
No
MSR3600-28-XS
No
MSR3610-XS
No
MSR3620-XS
No
MSR3610-I-XS
No
MSR3610-IE-XS
No
Hardware
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
The device software image includes the following software:
·     Boot ROM image
·     System image
·     Feature packages:
¡     Data feature package—Includes the features such as MPLS and DLSw.
¡     Security feature package—Includes the features such as VPN.
¡     Voice feature package—Includes the features such as BUSYOUT and voice.
The Boot ROM image and system image are required for the system to work, and they do not need any licenses.
The feature packages are all license-based features. You must register and activate the license for a feature to run on your device.
After a Comware package license is correctly installed, the system will automatically search the storage media for a matching feature package. If no match is found, you are required to load the feature package and install it. If a match is found, the system will install the feature package. If the installation fails because of device poweroff or reboot, you are required to manually install the feature package when the device is powered on again. Use the display boot-loader command to verify that the feature package is installed successfully.
IMPORTANT
IMPORTANT:
During the installation of feature packages, do not execute the save command. The violation will cause configuration loss.
Feature license
ATC license
The following compatibility matrixes show the support of hardware platforms for ATC license:
Hardware
ATC license compatibility
No
No
No
No
MSR 2630
No
No
No
No
Yes
Yes
Yes
Yes
Hardware
No
MSR830-4LM-WiNet
No
No
No
No
MSR2630-WiNet
No
MSR3600-28-WiNet
No
MSR3610-X1-WiNet
Yes
Yes
Hardware
MSR2630-XS
No
MSR3600-28-XS
No
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
Hardware
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
To use the RTC terminal access feature, you must install ATC licenses.
IP POS license
The following compatibility matrixes show the support of hardware platforms for IP POS license:
Hardware
IP POS license compatibility
No
No
No
No
MSR 2630
No
No
No
No
No
No
No
Yes
Hardware
No
MSR830-4LM-WiNet
No
No
No
No
MSR2630-WiNet
No
MSR3600-28-WiNet
No
MSR3610-X1-WiNet
No
No
Hardware
MSR2630-XS
No
MSR3600-28-XS
No
MSR3610-XS
No
MSR3620-XS
No
MSR3610-I-XS
No
MSR3610-IE-XS
No
Hardware
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
The IP POS licenses control the number of TCP connections between the device and POS terminals. To establish TCP connections to POS terminals, you must install IP POS licenses. With the activation file of an IP POS license installed, the device can establish 256 TCP connections to POS terminals. You can increase the number of TCP connections between the device and POS terminals by installing multiple IP POS licenses.
AC license
The following compatibility matrixes show the support of hardware platforms for AC license:
Hardware
AC license compatibility
Yes
No
Yes
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
No
Hardware
Yes
MSR830-4LM-WiNet
Yes
Yes
Yes
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
Yes
Hardware
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
No
The maximum number of online APs is determined by the default number of APs supported by the device and the number of AC licenses. Based on the allowed AP number, AC licenses include the following types:
·     AC licenses that allow a maximum of 1 online AP.
·     AC licenses that allow a maximum of 4 online APs.
·     AC licenses that allow a maximum of 8 online APs.
·     AC licenses that allow a maximum of 16 online APs.
·     AC licenses that allow a maximum of 32 online APs.
·     AC licenses that allow a maximum of 128 online APs.
You can increase the number of allowed online APs by installing multiple AC licenses.
The following matrixes show the allowed maximum online AP counts of MSR routers for AC licenses:
Hardware
Maximum number of allowed online APs
16
16
32
MSR 2630
64
64
64
256
256
256
Hardware
16
MSR830-4LM-WiNet
16
16
16
32
MSR2630-WiNet
64
MSR3600-28-WiNet
64
MSR3610-X1-WiNet
256
256
Hardware
MSR2630-XS
32
MSR3600-28-XS
64
MSR3610-XS
256
MSR3620-XS
256
MSR3610-I-XS
256
MSR3610-IE-XS
256
Hardware
MSR810-LM-GL
16
MSR810-W-LM-GL
16
MSR830-6EI-GL
16
MSR830-10EI-GL
16
MSR830-6HI-GL
16
MSR830-10HI-GL
16
MSR2600-6-X1-GL
32
MSR3600-28-SI-GL
N/A
IPS license
The following compatibility matrixes show the support of hardware platforms for IPS license:
Hardware
IPS license compatibility
Yes
No
Yes
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
Hardware
Yes
MSR830-4LM-WiNet
Yes
Yes
Yes
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
Yes
Hardware
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
No
To update the IPS signature database, you must install IPS licenses on the device.
IPS licenses are time-based licenses, including licenses valid for 1 year and licenses valid for 3 years. You can increase the validity period of using the IPS signature database update feature by installing multiple IPS licenses.
ACG license
The following compatibility matrixes show the support of hardware platforms for ACG license:
Hardware
ACG license compatibility
Yes
No
Yes
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
Hardware
Yes
MSR830-4LM-WiNet
Yes
Yes
Yes
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
Yes
Hardware
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
No
To update the ACG signature database, you must install ACG licenses on the device.
ACG licenses are time-based licenses, including licenses valid for 1 year and licenses valid for 3 years. You can increase the validity period of using the ACG signature database update feature by installing multiple ACG licenses.
SSL VPN license
The following compatibility matrixes show the support of hardware platforms for SSL VPN license:
Hardware
SSL VPN license compatibility
Yes
No
Yes
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
Hardware
Yes
MSR830-4LM-WiNet
Yes
Yes
Yes
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
Yes
Hardware
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
No
To allow SSL VPN users to come online, you must install SSL VPN licenses on the device. The SSL VPN licenses control the number of online SSL VPN users. Based on the allowed user number, SSL VPN licenses include the following types:
·     SSL VPN licenses that allow a maximum of 30 online SSL VPN users.
·     SSL VPN licenses that allow a maximum of 200 online SSL VPN users.
You can increase the number of allowed online SSL VPN users by installing multiple SSL VPN licenses.
Web cache license
The following compatibility matrixes show the support of hardware platforms for Web cache license:
Hardware
Web cache license compatibility
Yes
No
No
Yes
MSR 2630
Yes
Yes
No
Yes
Yes
Yes
Yes
Yes
Hardware
Yes
MSR830-4LM-WiNet
Yes
Yes
Yes
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
Yes
Hardware
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
No
To use the Web caching feature, you must install the activation file for the Web cache license.
Restrictions and guidelines: License management
License operations
Make sure no one else is performing license management tasks on the device you are working with.
Activation file operations
When you manage activation files, follow these restrictions and guidelines:
·     Do not open and edit the files to avoid file corruption.
·     Do not modify the names of the files to avoid licensing error.
·     For licensed features to function correctly, do not delete files that are usable or in use in the flash:/license directory. The license management feature uses this directory for license management.
License consistency in an IRF fabric
(In IRF mode.) For licensed features to function correctly in an IRF fabric, make sure all IRF member devices are installed with the same licenses.
License registration and installation flowchart
Figure 1 License registration and installation flowchart
License management tasks at a glance
To manage licenses, perform the following tasks:
1.     Identifying the license storage
2.     (Optional.) Compressing the license storage
3.     Obtaining required information for license registrationObtaining required information for license registration
4.     Registering a license
5.     Installing a license
6.     Managing installed licenses
¡     Uninstalling a license
¡     Transferring a license
¡     Recovering an activation file
To identify the license storage, execute the following command in any view:
display license feature
From the command output, view the Total and Usage fields to examine whether the remaining license storage is sufficient for installing new licenses. If the remaining license storage is not sufficient, compress the license storage.
Compress the license storage to delete expired and uninstalled license information to ensure sufficient storage space for installing new licenses.
This command clears expired licenses and uninstalled licenses that are installed by using activation files.
If uninstalled licenses or expired licenses exist on the device, the compression operation will make the DID change. Before performing a compression, make sure all licenses registered with the old DID have been installed. You will be unable to install such licenses after the compression.
1.     Back up the Uninstall keys of uninstalled licenses.
When you uninstall an unexpired license, an Uninstall key is created. The Uninstall key is required for transferring the license.
2.     Make sure all licenses generated based on the old DID have been installed.
3.     Enter system view.
4.     Compress the license storage.
In standalone mode:
license compress
In IRF mode:
license compress slot slot-number
1.     Identify whether the required features need to be licensed on the device.
Execute the following command in any view:
2.     Execute the following command in any view to display the current license status.
In standalone mode:
display license [ activation-file ]
In IRF mode:
display license [ activation-file ] [ slot slot-number ]
3.     Obtain the license key by purchasing a license.
The authorization serial number in the Software License Certificate is the license key.
4.     Execute the following command in any view to obtain the SN and DID information.
In standalone mode:
display license device-id
In IRF mode:
display license device-id slot slot-number
5.     Back up the license key in case of loss.
About registering a license
License registration has the following procedures:
·     Registering licenses for the first time—Register a license for a device that has not previously been registered.
·     Registering upgrade licenses—Register licenses for capacity expansion, feature enhancement, or a time extension. This procedure is also applicable to the scenario that you register a new license for a device that has expired or uninstalled licenses.
If you do not know which registration procedure should be used, select registering licenses for the first time. If the selection is not correct, the website will display a message for the correct registration choice after you enter the required information.
If you cannot download the activation file due to problems such as operating system and browser errors, try to re-register the license. If the problem persists, contact H3C Support.
1.     Visit the H3C website at http://www.h3c.com/en/License/.
2.     Select Register the First Time.
3.     Enter the authorization serial number in the Input the license key field and click Submit.
A dialog box opens, displaying product categories matching the license key.
4.     In the dialog box, select a product category from the Product category dropdown list and click OK.
5.     Enter the device S/N.
6.     Upload the DID file.
7.     Enter the required contact information and verify code, select I accept all terms of H3C Legal Statement, and click Get activation key or file.
8.     Download the activation file to the PC.
A copy of the activation file will also be sent to the email address that you enter in the contact information.
2.     Select Register Upgrade Licenses.
6.     Upload the DID file and click Submit.
Restrictions and guidelines for license installation
When installing a license, the system automatically searches the storage media for a matching feature package. When a match is found, it stops searching and installs the package.
Installing an activation file
2.     Install an activation file.
In standalone mode:
license activation-file install license-file
In IRF mode:
license activation-file install license-file slot slot-number
About license uninstallation
Perform this task to uninstall an unexpired formal license when the license remains unused for a while or needs to be transferred to another device.
After uninstallation, Uninstall keys are generated, which will be used for license transfer.
Restrictions and guidelines for license uninstallation
Trial licenses cannot be transferred. Uninstall a trial license does not create any uninstallation information.
Expired licenses cannot be uninstalled.
A license that was uninstalled on a device cannot be re-installed on the device. It can only be transferred to another device.
Uninstalling an activation file
2.     Uninstall an activation file.
In standalone mode:
license activation-file uninstall license-file
In IRF mode:
license activation-file uninstall license-file slot slot-number
Only unexpired activation files can be uninstalled.
You can transfer a license from one device to another if the license has not expired.
1.     Log in to the source device, and uninstall the license to obtain the uninstallation information. For more information, see "Uninstalling a license."
2.     Obtain the Uninstall key of the license by using the display license command.
3.     Access the target device and obtain SN and DID information. For more information, see "Obtaining required information for license registration."
4.     Register a license for the target device. For more information, see "Registering a license."
During the license register, you must provide SN and DID information of the target device and the Uninstall key of the source device.
5.     Install the new license on the target device. For more information, see "Installing a license."
If you mistakenly delete an activation file, use the following procedure to recover the activation file:
1.     Use the copy command to copy the backup activation file to directory flash:/license.
2.     Use the display license command to verify that the state of the recovered activation file is In use.
3.     Restart the device if the license state is In use but the licensed feature cannot function correctly.
Display and maintenance commands for license management
Display detailed license information.
In standalone mode:
In IRF mode:
Display the SN and DID information.
In standalone mode:
In IRF mode:
Display brief feature license information.
