14-OAA Command Reference
HomeSupportSwitchesS10500X SeriesReference GuidesCommand ReferencesH3C S10500X Switch Series Command References-Release758X-6W10014-OAA Command Reference
02-OAP module commands
02-OAP module commands 36.97 KB
OAP module commands
oap connect
Use oap connect to log in to the CLI of an OAP module from the device. You can also use this command to log in to another operating system that is running on a card in the device.
In standalone mode:
oap connect slot slot-number
In IRF mode:
oap connect chassis chassis-number slot slot-number
slot slot-number: Specifies an OAP module by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an OAP module in an IRF member device by the member ID and slot number. (In IRF mode.)
To return to the CLI of the hosting device from the OAP module, press Ctrl+K.
This command is supported only on the default MDC.
# (In standalone mode.) Log in to the CLI of the OAP module in the specified slot.
<Sysname> oap connect slot 1
Press CTRL+K to quit.
Connected to OAP.
oap reboot
Use oap reboot to reboot an OAP module.
In standalone mode:
oap reboot slot slot-number
In IRF mode:
oap reboot chassis chassis-number slot slot-number
# (In standalone mode.) Reboot the OAP module in the specified slot.
<Sysname> oap reboot slot 1
This command might cause data loss on the hard disk if the card is not been shut down.
Continue? [Y/N]:y
Rebooting the OAP card by command…
