18-EVPN Configuration Guide
HomeSupportSwitchesS7500X SeriesConfigure & DeployConfiguration GuidesH3C S7500X Switch Series Configuration Guides-Release758X-6W10018-EVPN Configuration Guide
Table of Contents
Related Documents
00-Preface
00-Preface 100.71 KB
Preface
This configuration guide describes fundamentals and configuration of Ethernet Virtual Private Network (EVPN). EVPN is a Layer 2 VPN technology that provides both Layer 2 and Layer 3 connectivity between distant network sites across an IP or MPLS network. EVPN uses MP-BGP in the control plane and Virtual eXtensible LAN (VXLAN) or MPLS in the data plane.
·           Audience.
·           Conventions.
·           Documentation feedback.
Audience
·           Network planners.
·           Field technical support and servicing engineers.
·           Network administrators working with the S7500E switch series.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
