24-VXLAN Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR Router Series Comware 7 Configuration Guides-R0615-6W20224-VXLAN Configuration Guide
Table of Contents
Related Documents
00-Preface
00-Preface 100.80 KB
Preface
This configuration guide describes fundamentals and configuration of Virtual eXtensible LAN (VXLAN). VXLAN is a MAC-in-UDP technology that provides Layer 2 connectivity between distant network sites across an IP network. VXLAN is typically used in data centers for multitenant services
·          Audience.
·          Conventions.
·          Documentation feedback.
Audience
·          Network planners.
·          Field technical support and servicing engineers.
·          Network administrators.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
