20-OpenFlow Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR Router Series Comware 7 Configuration Guides-R0615-6W20220-OpenFlow Configuration Guide
Table of Contents
Related Documents
00-Preface
00-Preface 100.52 KB
Preface
This configuration guide describes OpenFlow fundamentals and configuration, including OpenFlow instance, controllers for an OpenFlow switch, OpenFlow timers, and dynamic MAC address support. OpenFlow separates the data forwarding and routing decision functions. A controller makes routing decisions and assigns flow table entries to an OpenFlow switch. An OpenFlow switch matches and forwards packets by using the flow table entries obtained from a controller.
·          Audience.
·          Conventions.
·          Documentation feedback.
Audience
·          Network planners.
·          Field technical support and servicing engineers.
·          Network administrators.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
