19-EVI Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR Router Series Comware 7 Configuration Guides-R0615-6W20219-EVI Configuration Guide
Table of Contents
Related Documents
01-Text
01-Text 708.47 KB
Configuring EVI 1
Overview·· 1
Layer 2 connectivity extension issues· 1
Network topologies· 2
Terminology· 3
Working mechanism·· 4
Placement of Layer 3 gateways· 7
ARP flood suppression·· 7
Selective flooding· 8
Multihoming· 8
Path MTU·· 11
Compatibility information·· 11
Feature and hardware compatibility· 11
Command and hardware compatibility· 11
Licensing requirements· 12
EVI configuration task list 12
Configuring EVI basic features· 12
Configuring a site ID·· 13
Configuring an EVI tunnel 13
Assigning a network ID to the EVI tunnel 14
Specifying extended VLANs on the EVI tunnel 15
Configuring ENDP·· 15
Enabling EVI on transport-facing physical interfaces· 16
Tuning EVI IS-IS parameters· 17
EVI IS-IS configuration task list 17
Creating an EVI IS-IS process· 17
Changing the designated site VLAN·· 18
Optimizing an EVI IS-IS network· 18
Specifying a routing policy for an EVI IS-IS process· 22
Enabling adjacency change logging· 23
Configuring SNMP notifications and context for EVI IS-IS·· 23
Configuring Graceful Restart for an EVI IS-IS process· 24
Increasing the maximum number of MAC entries in an LSP for an EVI IS-IS process· 24
Configuring VLAN mappings· 25
Enabling EVI ARP flood suppression·· 25
Enabling EVI flooding for all destination-unknown frames· 26
Enabling selective flooding for a MAC address· 26
Displaying and maintaining EVI 27
EVI configuration examples· 28
Single-homed EVI network configuration example· 28
Dual-homed EVI network configuration example· 36
Multiple-EVI-networks configuration example· 41
EVI Layer 2 multicast configuration example· 43
Index· 47
Configuring EVI
Overview
Ethernet Virtual Interconnect (EVI) is a MAC-in-IP technology that provides Layer 2 connectivity between distant Layer 2 network sites across an IP routed network. It is used for connecting geographically dispersed sites of a virtualized large-scale data center that requires Layer 2 adjacency (see Figure 1).
EVI enables long-distance virtual machine workload mobility and data mobility, disaster recovery, and business continuity. For example, virtual machines can move between data center sites without changing their IP addresses, so their movements are transparent to users and do not disrupt traffic.
Figure 1 Virtual machine migration
EVI resolves the following Layer 2 connectivity extension issues:
·          Site independence—EVI keeps protocol failures, such as broadcast storms, from propagating across sites.
·          Transport independence—EVI has no special requirements for site location or transport network type, except that the transport network can forward IP packets.
·          High availability—EVI supports redundant edge devices and has a loop-free mechanism to prevent loops for a multihomed network site.
·          Link efficiency—EVI optimizes the inter-site multicast and broadcast transmission mechanism and implements load-sharing on redundant links.
·          Site and transport transparency—EVI is both site and transport network transparent. It has no special site or transport network topology requirements.
·          Easy management and maintenance—EVI requires deployment only on edge devices and does not introduce any topology change or configuration within sites or the transport network.
Network topologies
As shown in Figure 2, an EVI network has one or multiple edge devices at each site. These sites are connected through virtual links and run the EVI IS-IS protocol to advertise their MAC address entries to each other. EVI maintains MAC routing information on the edge devices without changing the forwarding or routing information within the sites or the transport network.
Figure 2 EVI network
EVI supports multiple EVI networks on an edge device for extending different VLANs across the Layer 3 network. One EVI network can convey multiple VLANs, but one VLAN can map to only one EVI network. Each EVI network has separate network parameters and independently forwards traffic.
As shown in Figure 3, EVI network 1 extends VLAN 100 and VLAN 101 to Site 2, Site 3, and Site 4 for Web access traffic. EVI network 2 extends VLAN 4000 (the management VLAN) to all sites, and EVI network 3 extends VLANs 50 to 80 between Site 1 and Site 4 for database traffic.
Figure 3 Multiple EVI networks
Terminology
Edge device
An edge device performs typical Layer 2 learning and forwarding on the site-facing interfaces (internal interfaces) and performs tunneling and routing on the transport-facing interfaces.
EVI network ID
An edge device can belong to multiple EVI networks. Each EVI network is uniquely identified by a network ID.
EVI link
An EVI link is a bidirectional virtual Ethernet channel between a pair of edge devices in an EVI network. EVI links are conveyed on EVI tunnels. Each EVI link is uniquely identified by a pair of source and destination EVI tunnel IP addresses.
EVI tunnel
An EVI tunnel is a point-to-many automatic GRE tunnel that conveys EVI links for an EVI network. One EVI tunnel can provide services only for one EVI network.
EVI neighbor
All edge devices in an EVI network are EVI neighbors to one other.
ENDP
EVI Neighbor Discovery Protocol uses the client/server model to dynamically discover sites and edge devices, establish and maintain EVI links, and exchange network membership information in an EVI network.
ENDS
An EVI neighbor discovery server maintains all neighbor information in an EVI network. An EVI network can have up to two ENDSs.
ENDC
An EVI neighbor discovery client works with an ENDS to learn neighbor information and triggers EVI link setup between neighbors.
EVI IS-IS
EVI IS-IS establishes adjacencies and advertises MAC reachability information among edge devices at different sites in an EVI network. It also maps VLANs to redundant edge devices at a multihomed site to avoid loops and balance traffic.
EVI IS-IS runs independently of the Layer 3 routing protocols on the transport network and sites.
DED
Designated edge devices (DEDs) include inter-site DEDs and site DED.
An inter-site DED is elected from between the edge devices on each EVI link to send CSNP packets for LSDB synchronization.
A site DED is elected from among the redundant edge devices at a multihomed site to distribute extended VLANs among them so the traffic of a VLAN always enters or leaves the site from the same edge device.
Appointed edge forwarder
If an edge device is assigned by DED to forward and receive traffic for an extended VLAN, this edge device is the appointed edge forwarder for the extended VLAN. This extended VLAN is an active VLAN on the edge device.
Internal interface
Internal interfaces are site-facing Layer 2 interfaces that connect an edge device to switches or routers in the site.
Working mechanism
An edge device uses the following process to set up an EVI network and forward traffic at Layer 2 to remote sites:
1.        Runs ENDP to discover EVI neighbors and set up EVI links between neighbors.
2.        Runs EVI IS-IS to advertise MAC reachability information over EVI links in the EVI network.
3.        Forwards traffic based on MAC reachability information that has been received from other sites.
This section describes this process in detail.
Neighbor discovery
An EVI network runs ENDP to discover all its edge devices and establishes adjacencies among the edge devices in the following process:
1.        ENDS is enabled on one edge device, and ENDC is enabled on all other edge devices.
2.        The ENDCs register their IP addresses and other data with the ENDS.
3.        The ENDS updates its ENDC database with received data and sends the updated database to each ENDC.
4.        After receiving the register reply, the ENDCs establish an EVI link with each other.
For high availability, you can configure up to two ENDSs for an EVI network.
MAC address learning
MAC reachability information on an EVI edge device comes from the following sources:
·          MAC entries configured or learned in the data plane—The edge devices use the typical source-MAC-based learning mechanism to learn unicast MAC addresses in their local sites (called local MAC addresses).
If the device learns the source MAC address when it sends out a packet at the egress, execute the mac-address mac-learning ingress command. This command enables MAC address learning at the ingress to reduce flood traffic and accelerate populating of the MAC address table. For more information about MAC address learning, see MAC address table configuration in Layer 2—LAN Switching Configuration Guide.
·          MAC entries learned through EVI IS-IS—After completing neighbor discovery, the edge devices run EVI IS-IS in the control plane to establish adjacencies and advertise MAC reachability information that has been learned or configured in the data plane to each other over EVI links.
The mac-address max-mac-count command and the mac-address mac-learning enable command take effect only on local MAC addresses, which are learned in the data plane. They do not take effect on remote MAC addresses, which are learned in the control plane.
Unicast flow
For intra-site unicast flows, an edge device performs the typical MAC address table lookup, as shown in Figure 4.
Figure 4 Layer 2 forwarding in a site
The following forwarding process (see Figure 5) takes place for unicast flows between sites:
1.        The source edge device learns the source MAC address of the incoming Ethernet frame, and looks up the destination MAC address in its MAC table for the outgoing interface.
2.        If the outgoing interface is an EVI-Link interface instead of a physical port, the source edge device encapsulates the frame in a GRE header, and then adds an IP header and a link layer protocol header.
In the outer IP header, the source IP address is the source edge device's tunnel source IP address, and the destination IP address is the destination edge device's tunnel source IP address.
3.        The source edge device forwards the encapsulated packet out of the EVI link to the destination edge device across the IP transport network.
4.        The destination edge device removes the headers of the original Ethernet frame, looks up the destination MAC address in the MAC address table, and sends the frame out of the matching outgoing interface.
Figure 5 Layer 2 forwarding between sites
Multicast flow
Edge devices run IPv4 IGMP snooping on each extended VLAN and learn multicast router port and multicast member port information on EVI-Link interfaces for Layer 2 multicast forwarding as if they were Ethernet interfaces. In an extended VLAN, each edge device tunnels IGMP and PIM protocol packets to all its remote edge devices, and the remote edge devices flood the packets in the VLAN.
For a site-to-site multicast data frame in an extended VLAN, the following process (see Figure 6) takes place:
1.        The DR in a site sends out a multicast frame.
2.        The source edge device copies the frame and encapsulates one copy on each multicast member EVI-Link interface.
3.        The source edge device unicasts the encapsulated frames to the destination edge devices over the EVI links.
4.        Each destination edge device removes the headers of the multicast frame and copies the multicast frame on each multicast member interface.
5.        Each destination edge device sends the multicast frame out of all member interfaces to the destination hosts.
Figure 6 Multicast data frame forwarding process
Flooding flow
An edge device handles flooding by frame type, as follows:
·          Broadcast frame—Floods the frame to all interfaces in the VLAN where the frame has been received, including internal interfaces and EVI-Link interfaces. For ARP packets, you can use the ARP flood suppression feature (see "ARP flood suppression") to reduce ARP broadcasts.
·          Destination-unknown unicast or multicast frame—Floods the frame to all internal interfaces in the VLAN where the frame has been received. The edge device typically does not forward destination-unknown frames to other sites. If a site-to-site flooding is desirable for a special MAC address, use the selective flooding feature (see "Selective flooding").
To flood a frame to remote sites, an EVI edge device must replicate the frame, encapsulate each replica in one unicast frame for each destination site, and send the unicast frames to the remote edge devices.
For the hosts in an extended VLAN at a site, their Layer 3 gateway must be on the edge device at the local site rather than a remote site.
ARP flood suppression reduces ARP request broadcasts on the EVI network by enabling edge devices to reply to ARP requests on behalf of remote-site hosts.
As shown in Figure 7, this feature snoops ARP packets on an EVI tunnel interface to populate the ARP flood suppression table with remote MAC addresses. If an ARP request has a matching entry, the local edge device replies to the request on behalf of the remote-site host. If no match is found, the edge device floods the request to the EVI network.
ARP flood suppression uses the following workflow:
1.        Host IP1 in site A sends an ARP request to obtain the MAC address of IP2.
2.        Site A's edge device floods the ARP requests out of all interfaces, including the EVI tunnel interfaces.
3.        Site B's edge device de-encapsulates the ARP request and broadcasts the request.
4.        IP2 sends an ARP reply back to site A's edge device over the EVI link.
5.        Site A's edge device creates an ARP cache entry for the remote MAC address and forwards the reply to the requesting host.
6.        Site A's edge device replies to all subsequent requests for the MAC address of IP2.
Figure 7 ARP flood suppression
Selective flooding
Selective flooding enables an edge device to send an unknown unicast or multicast frame out of an EVI tunnel interface.
This feature is designed for special multicast addresses that require flooding across sites but cannot be added to a multicast forwarding table by IGMP snooping.
For example, you must configure selective flooding for PIM hellos, IGMP general query packets, and Microsoft NLBS cluster traffic to be sent out of an EVI tunnel interface.
Multihoming
EVI supports deploying two or more EVI edge devices to provide Layer 2 connectivity extension for a site. Deployment of redundant edge devices creates the risk of loops because EVI edge devices do not transmit spanning tree BPDUs across the transport network.
To remove loops in a multihomed network (see Figure 8), you can use IRF to virtualize multiple edge devices into one device, as shown in Figure 9. If IRF is not used, EVI IS-IS runs among the redundant edge devices to automatically designate each edge device as the traffic forwarder for a particular set of extended VLANs, as shown in Figure 10.
The redundant edge devices exchange EVI IS-IS hello packets in a designated site VLAN to elect a DED for exchanging extended VLAN information and assigning active VLANs among them. All edge devices have a user-configurable DED priority. The one with the highest DED priority is elected as the DED. The DED uses the following rules to assign active VLANs:
1.        If an extended VLAN is configured only on one edge device, the edge device is the appointed edge forwarder for the VLAN.
2.        If a set of extended VLANs is configured on at least two edge devices, the DED distributes the extended VLANs equally among the edge devices.
3.        When reassigning VLANs, the DED preferably assigns an edge device the active VLANs that were assigned to it in the previous assignment.
The traffic forwarder designation mechanism of EVI IS-IS makes sure an extended VLAN is active only on one edge device. For example, VLAN 1000 in Figure 10 is active only on site 1's Device B and site 2's Device D. Only these two edge devices can receive or forward VLAN 1000 traffic between the two sites.
Figure 8 Looped dual-homed EVI network
Figure 9 Edge devices in an IRF fabric
Figure 10 Active VLAN on an edge device
Path MTU
When encapsulating an Ethernet frame in EVI, the edge device does not modify the Ethernet frame, but it sets the DF bit in the IP header. For an Ethernet transport network, the total size of an EVI protocol packet increases by 46 bytes, and the total size of a data packet increases by 38 bytes. Because EVI does not support path MTU discovery, your EVI deployment must make sure the path MTU of the transport network is higher than the maximum size of EVI tunneled frames.
Hardware
EVI compatibility
MSR810/810-W/810-W-DB/810-LM/810-W-LM/810-10-PoE/810-LM-HK/810-W-LM-HK/810-LMS/810-LUS
No
MSR2600-6-X1/2600-10-X1
No
MSR 2630
No
MSR3600-28/3600-51
No
MSR3600-28-SI/3600-51-SI
No
MSR3610-X1/3610-X1-DP/3610-X1-DC/3610-X1-DP-DC
Yes
MSR 3610/3620/3620-DP/3640/3660
Yes
MSR5620/5660/5680
Yes
Hardware
EVI compatibility
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
Commands and descriptions for centralized devices apply to the following routers:
·          MSR810/810-W/810-W-DB/810-LM/810-W-LM/810-10-PoE/810-LM-HK/810-W-LM-HK/ 810-LMS/810-LUS.
·          MSR2600-6-X1/2600-10-X1.
·          MSR 2630.
·          MSR3600-28/3600-51.
·          MSR3600-28-SI/3600-51-SI.
·          MSR3610-X1/3610-X1-DP/3610-X1-DC/3610-X1-DP-DC.
·          MSR 3610/3620/3620-DP/3640/3660.
·          MSR810-LM-GL/810-W-LM-GL/830-6EI-GL/830-10EI-GL/830-6HI-GL/830-10HI-GL/2600-6-X1-GL/3600-28-SI-GL.
Commands and descriptions for distributed devices apply to the following routers:
·          MSR5620.
·          MSR 5660.
·          MSR 5680.
EVI requires a license to run on the device. For information about feature licensing, see Fundamentals Configuration Guide.
Perform the following tasks on all edge devices of an EVI network:
Tasks at a glance
Remarks
Configuring EVI basic features:
·         (Optional.) Configuring a site ID
·         (Required.) Configuring an EVI tunnel:
?  (Required.) Assigning a network ID to the EVI tunnel
?  (Required.) Specifying extended VLANs on the EVI tunnel
?  (Required.) Configuring ENDP
?  (Required.) Enabling EVI on transport-facing physical interfaces
An EVI tunnel can provide services for only one EVI network.
If a site is dual-homed, you must change its site ID.
An extended VLAN can be assigned to only one EVI network.
(Optional.) Tuning EVI IS-IS parameters
EVI IS-IS automatically runs on an EVI tunnel interface immediately after the interface is created.
You can tune EVI IS-IS parameters for optimizing network performance.
(Optional.) Configuring VLAN mappings
N/A
(Optional.) Enabling EVI ARP flood suppression
Perform this task to reduce ARP request broadcasts on an EVI network.
(Optional.) Enabling EVI flooding for all destination-unknown frames
Perform this task to flood frames with unknown MAC addresses to the EVI tunnel interface.
(Optional.) Enabling selective flooding for a MAC address
Perform this task for special multicast MAC addresses that require Layer 2 inter-site forwarding but cannot be learned into the MAC address table.
All tasks in this section are required for setting up an EVI network.
By default, all edge devices in an EVI network have a site ID of 0.
To uniquely identify the sites in an EVI network, you can change their site IDs. To avoid site ID conflict, follow these guidelines when you configure site IDs:
·          The edge devices at a dual-homed site cannot use the default site ID. You must manually assign the same site ID to them.
·          The edge device at a single-homed site can use the default or manually assigned site ID. Site conflict does not occur if the edge devices at different sites all use the default site ID.
·          Manually assigned site IDs must be unique among sites.
When the site IDs of two devices conflict, EVI IS-IS isolates the device with the lower MAC address. The isolated device can only receive EVI IS-IS hello packets. It cannot exchange EVI IS-IS packets with other neighbors. To identify isolated devices, use the display evi isis brief command or the display evi isis peer command.
To assign a site ID to the device:
Step
Remarks
1.       Enter system view.
N/A
2.       Assign a site ID to the device.
evi site-id site-id
The default site ID is 0.
Step
Remarks
3.       Enter system view.
N/A
4.       Create an EVI tunnel interface and enter tunnel interface view.
interface tunnel number mode evi
By default, no tunnel interface exists.
The endpoints of a tunnel must use the same tunnel mode.
For more information about this command, see tunneling commands in Layer 3—IP Services Command Reference.
5.       Specify a source IP address or interface for the tunnel.
source { ipv4-address | interface-type interface-number }
By default, no source IP address or source interface is specified for any tunnel.
The source interface can be a Layer 3 Ethernet interface, Layer 3 aggregate interface, VLAN interface, or Layer 3 loopback interface. For more information about the source command, see tunneling commands in Layer 3—IP Services Command Reference.
EVI uses the specified address or the primary IP address of the specified source interface as the source IP address of tunneled packets on the transport network.
EVI networks can share a tunnel source IP address or interface.
IMPORTANT IMPORTANT:
To avoid forwarding failure, do not use a GRE tunnel interface or its IP address (configure with the ip address command in tunnel interface view) as the source interface or IP address of an EVI tunnel. For more information about GRE, see Layer 3—IP Services Configuration Guide.
6.       Configure the EVI link keepalive interval and the maximum number of keepalive transmissions.
keepalive [ seconds [ times ] ]
By default, a keepalive packet is sent every five seconds and the maximum number of transmissions is two.
If no reply is received from the remote end on an EVI link after the maximum number of keepalive transmissions is reached, the local end considers the EVI link as having failed.
7.       (Optional.) Generate a GRE key for tunneled packets based on their VLAN IDs.
gre key vlan-id
By default, EVI tunneled packets do not contain a GRE key.
The GRE key setting must be the same across an EVI network. Perform this step if any remote edge devices generate VLAN ID-based GRE keys for EVI tunneled packets.
In addition to the EVI-specific commands described in this section, you can configure generic tunnel interface commands on an EVI tunnel interface. These tunnel commands and tunneling basics are described in the tunneling configuration in Layer 3—IP Services Configuration Guide.
Assign the same network ID to the EVI tunnels of all edge devices in an EVI network.
On an edge device, the network ID assigned to an EVI tunnel must be unique.
To assign a network ID to an EVI tunnel:
Step
Remarks
N/A
2.       Enter tunnel interface view.
interface tunnel number [ mode evi ]
N/A
3.       Specify a network ID.
evi network-id number
By default, no network ID is specified.
When configuring extended VLANs, follow these guidelines:
·          You can specify an extended VLAN on only one EVI tunnel.
·          To avoid loops, do not assign transport-facing ports to extended VLANs.
·          To avoid data breach, make sure all edge devices in an EVI network maintain the same list of extended VLANs.
To assign extended VLANs to an EVI tunnel:
Step
Remarks
N/A
2.       Enter EVI tunnel interface view.
N/A
3.       Specify extended VLANs.
evi extend-vlan vlan-list
By default, no VLANs are specified as extended VLANs on any EVI tunnel.
To specify more extended VLANs, repeat this step.
Configuring ENDP
ENDP enables the edge devices in an EVI network to discovery each other.
Configure an edge device as an ENDS to provide registration services or as an ENDC to register with an ENDS.
Configuration guidelines
·          For redundancy, you can configure up to two ENDSs on an EVI tunnel interface. These two ENDSs work independently. The failure of one ENDS does not affect the neighbor discovery and EVI link maintenance in the EVI network.
·          When you enable ENDS on an EVI tunnel interface, an ENDC is automatically enabled. This ENDC uses the source address of the EVI tunnel as the ENDS address. As a result, you can use the evi neighbor-discovery client enable command to add only one ENDS address on an ENDS-enabled EVI tunnel interface.
·          To guarantee that each edge device can obtain the addresses of all its EVI neighbors, make sure the ENDSs are the same across the EVI network.
·          To improve security, enable ENDP authentication. For successful neighbor relationship establishment, make sure all authentication-enabled ENDCs and ENDSs in an EVI network use the same authentication key.
Configuring the edge device as an ENDS on the EVI tunnel
Step
Remarks
N/A
N/A
3.       Enable ENDS.
evi neighbor-discovery server enable
By default, ENDS is disabled.
On an ENDS-enabled tunnel interface, you can use the evi neighbor-discovery client enable command to add one more ENDS, and use the evi neighbor-discovery client register-interval command to modify the ENDC registration interval.
4.       (Optional.) Enable ENDP authentication.
evi neighbor-discovery authentication { cipher | simple } string
By default, ENDP authentication is disabled.
Configuring the edge device as an ENDC on the EVI tunnel
Step
Remarks
N/A
N/A
3.       Configure the edge device as the ENDC of an ENDS.
evi neighbor-discovery client enable server-ip
By default, ENDC is disabled.
If ENDS is enabled on the EVI tunnel interface, you can use this command to specify only one more ENDS.
If ENDS is disabled, you can repeat this command to specify up to two ENDSs.
ENDS address is the tunnel source address configured on an ENDS-enabled EVI tunnel interface.
All ENDSs and ENDCs in an EVI network must use the same authentication key.
5.       Configure the interval at which the ENDC updates its registration with ENDSs.
evi neighbor-discovery client register-interval interval
By default, an ENDC update its registration with an ENDS every 15 seconds.
Enable EVI on all physical interfaces that provide transport network access for EVI tunnels.
To enable EVI on an interface:
Step
Remarks
N/A
2.       Enter Layer 2 Ethernet interface view or Layer 3 Ethernet interface view.
N/A
3.       Enable EVI on the interface.
evi enable
By default, EVI is disabled on all interfaces.
EVI IS-IS automatically runs on an EVI link immediately after the link is set up. You can tune EVI IS-IS parameters to optimize the protocol performance.
All EVI IS-IS configuration tasks are optional.
Tasks at a glance
Remarks
N/A
The redundant edge devices at a site use the designated site VLAN to exchange EVI IS-IS hello packets for DED election and extended-VLAN assignment.
Optimizing an EVI IS-IS network:
·         Configuring the EVI IS-IS hello interval
·         Configuring the hello multiplier for calculating the adjacency hold time
·         Configuring the DED priority
·         Configuring the CSNP transmit interval
·         Configuring the minimum LSP transmit interval and the maximum number of LSPs sent at each interval
·         Configuring the maximum LSP lifetime
·         Configuring the LSP refresh interval
·         Associating an EVI tunnel interface with a track entry
·         Configuring preferred VLANs
Perform the EVI IS-IS network optimization tasks to enable fast EVI link failure detection, set appropriate MAC reachability information update interval, and control the volume of LSP and CSNP traffic on an EVI network.
Perform this task to advertise a subset of MAC addresses instead of all local MAC addresses to remote sites.
N/A
N/A
Perform this task for providing nonstop services.
Perform this task depending on the MAC address table size on the edge device.
Each EVI network has one EVI IS-IS process. Before you can configure settings in EVI IS-IS process view, you must create the process.
An EVI IS-IS process is created automatically when you perform any one of the following tasks on a tunnel interface:
·          Specify extended VLANs.
·          Perform network optimization tasks (see "Optimizing an EVI IS-IS network") except configuring the LSP refresh interval and the maximum LSP lifetime.
·          Configure VLAN mappings.
The ID of an automatically created process is the same as the EVI tunnel interface number.
Alternatively, you can use the evi-isis command to create an EVI IS-IS process manually.
To delete a manually created EVI IS-IS process, you must use the undo evi-isis command.
·          If EVI IS-IS settings exist on the EVI tunnel interface, the undo evi-isis command only deletes settings configured in EVI IS-IS process view.
·          If no EVI IS-IS settings exist on the EVI tunnel interface, the undo evi-isis command deletes both the EVI IS-IS process and all settings configured in EVI IS-IS process view.
An automatically created EVI IS-IS process is automatically deleted when you delete all EVI IS-IS settings from the EVI tunnel interface.
To create an EVI IS-IS process or enter its view:
Step
Remarks
N/A
2.       Create an EVI IS-IS process or enter EVI IS-IS process view.
evi-isis process-id
By default, no EVI IS-IS processes exist.
The process ID you specify must be the same as the EVI tunnel interface number.
The EVI IS-IS process takes effect after you configure extended VLANs on the tunnel interface.
EVI IS-IS uses the designated site VLAN to exchange hello packets within a site to discover redundant edge devices and map extended VLANs to edge devices.
This designated site VLAN must not be extended across any EVI network.
To change the designated site VLAN for EVI IS-IS:
Step
Remarks
N/A
2.       Specify a designated site VLAN.
evi designated-vlan vlan-id
The default designated site VLAN is VLAN 1.
Perform the tasks in this section to optimize an EVI IS-IS network for bandwidth efficiency and high performance.
EVI edge devices send EVI IS-IS hellos over EVI links to establish and maintain adjacencies and elect the inter-site DED on each EVI link.
EVI edge devices at a multihomed site also exchange EVI IS-IS hellos to elect the site DED for distributing extended VLANs among them.
Set the hello interval depending on the network convergence requirement and system resources.
·          To increase the speed of network convergence, decrease the hello interval.
·          To conserve resources, increase the hello interval.
The hello interval of a DED is one-third of the hello interval set with the evi isis timer hello command.
To configure the EVI IS-IS hello interval on an EVI tunnel interface:
Step
Remarks
N/A
N/A
3.       Configure the EVI IS-IS hello interval.
evi isis timer hello seconds
The default hello interval is 10 seconds.
If the edge device is a DED, its hello interval is one-third of the hello interval set with this command.
Adjacency hold time is the amount of time that the remote edge devices can retain the adjacency with the local edge device before an adjacency update.
·          If Graceful Restart is disabled, the adjacency hold time equals the EVI IS-IS hello interval multiplied by the hello multiplier.
·          If Graceful Restart is enabled, the adjacency hold time equals the greater of the following values:
?  The restart interval.
?  The EVI IS-IS hello interval multiplied by the hello multiplier.
Edge devices send their adjacency hold time in hello packets to update the adjacencies with their neighbors. An edge device removes the adjacency with a neighbor if it does not receive a hello packet from the neighbor before the timer expires.
To configure the multiplier for calculating the adjacency hold time on an EVI tunnel interface:
Step
Remarks
N/A
N/A
3.       Configure the multiplier for calculating the adjacency hold time.
evi isis timer holding-multiplier value
The default multiplier is 3.
The maximum adjacency hold time is 65535 seconds. If this value is exceeded, the actual adjacency hold time is set to 65535 seconds.
The edge devices on an EVI link exchange their DED priority in EVI IS-IS hello packets to elect the inter-site DED for periodic LSDB synchronization. You can use the evi isis timer csnp command to change the synchronization interval.
The edge devices at a multihomed site exchange their DED priority in EVI IS-IS hello packets to elect the site DED for distributing extended VLANs among them.
The edge device with higher DED priority is more likely to be elected as a site DED or inter-site DED. If two edge devices have the same DED priority, the device with the highest MAC address is elected.
To configure the DED priority of the edge device on an EVI tunnel interface:
Step
Remarks
N/A
N/A
3.       Configure the DED priority.
evi isis ded-priority priority
The default DED priority is 64.
This configuration takes effect only on DEDs.
The DEDs in an EVI network regularly send CSNP packets to advertise LSP summaries for LSDB synchronization.
To configure the CSNP transmit interval on a DED:
Step
Remarks
N/A
N/A
3.       Configure the CSNP transmit interval.
evi isis timer csnp seconds
By default, a DED sends CSNP packets every 10 seconds.
The edge device generates an LSP update when any LSDB content changes. For example, an LSP update is generated when a MAC address is removed or added.
To control EVI IS-IS LSP traffic on the EVI network:
Step
Remarks
N/A
N/A
3.       Configure the minimum LSP transmit interval and the maximum number of LSP segments sent at each interval.
evi isis timer lsp time [ count count ]
By default, the minimum LSP transmit interval is 100 milliseconds, and a maximum of five LSP segments can be sent at each interval.
Before the minimum transmit interval is reached, the EVI tunnel interface cannot send LSP segments.
EVI edge devices add a lifetime in each LSP they have advertised, and update LSPs regularly or when MAC reachability information changes. If an edge device does not receive an update for an LSP before the lifetime expires, the edge device removes the LSP from the LSDB and removes the MAC addresses advertised through the LSP from the data plane.
To specify the maximum lifetime of the LSPs generated by an EVI IS-IS process:
Step
Remarks
N/A
2.       Enter EVI IS-IS process view.
evi-isis process-id
N/A
3.       Configure the maximum LSP lifetime.
timer lsp-max-age seconds
The default maximum LSP lifetime is 1200 seconds.
The edge device sends LSP updates at the refresh interval to update MAC reachability information.
To change the LSP refresh interval:
Step
Remarks
N/A
evi-isis process-id
N/A
3.       Configure the LSP refresh interval.
timer lsp-refresh seconds
The default LSP refresh interval is 900 seconds.
The minimum LSP transmit interval and the maximum number of LSPs sent at each interval can affect the actual LSP refresh interval.
To avoid unnecessary age-outs, appropriately set the LSP refresh interval and the LSP lifetime.
EVI IS-IS uses a hello mechanism to monitor the connectivity of each EVI link on an EVI tunnel. To detect the connectivity of a particular EVI link more quickly, you can associate its tunnel interface with a track entry. The monitoring protocol used in this entry can only be BFD.
EVI IS-IS changes the state of an EVI-Link interface in response to the track entry state, as shown in Table 1.
Table 1 Action on the monitored EVI-Link in response to the track entry state change
Track entry state
State of the monitored EVI link
Action on the EVI-Link interface
Positive
The EVI link is operating correctly.
Places the EVI-Link interface in up state.
Negative
The EVI link has failed.
Places the EVI-Link interface in down state.
NotReady
The EVI link is not monitored.
This situation occurs when the Track module or the monitoring module is not ready (for example, the Track module is restarting or the monitoring settings are incomplete). In this situation, EVI cannot obtain information about the EVI link from the Track module.
N/A
For more information about configuring a track entry, see Track configuration in High Availability Configuration Guide.
To associate an EVI tunnel interface with a track entry:
Step
Remarks
N/A
N/A
3.       Associate a track entry with the tunnel interface.
evi isis track track-entry-number
By default, an EVI tunnel interface is not associated with any track entry.
You can associate an EVI tunnel interface with only one track entry.
At a dual-homed site, specify an extended VLAN as a preferred VLAN on the edge device you prefer to use as the appointed forwarder for the VLAN. The DED assigns an edge device its preferred VLANs as long as possible. If an extended VLAN is configured as a preferred VLAN on both edge devices, the DED uses the typical VLAN distribution rules to distribute the VLAN. For information about typical extended VLAN distribution, see "Multihoming."
After you remove the preferred VLAN configuration on an edge device, the DED continues to assign the VLAN to the edge device if the following requirements are met:
·          The EVI tunnel interface on the edge device is up.
·          The VLAN has not been configured as a preferred VLAN on another edge device.
IMPORTANT
IMPORTANT:
For a preferred VLAN to take effect, you must make sure it has been specified as an extended VLAN.
To configure preferred VLANs:
Step
Remarks
N/A
N/A
3.       Specify preferred VLANs.
evi isis preferred-vlan vlan-list
By default, no preferred VLANs are configured.
Repeat this command to add additional preferred VLANs.
You can configure a routing policy to match MAC reachability information that can be advertised to the remote EVI sites. The routing policy is also called a reachability information filtering policy.
The routing policy for EVI IS-IS can only contain the following filters:
·          MAC list.
·          VLAN list.
For more information about configuring routing policies, see Layer 3—IP Routing Configuration Guide.
To specify a routing policy for an EVI IS-IS process:
Step
Remarks
N/A
evi-isis process-id
N/A
3.       Specify a routing policy for the EVI IS-IS process.
filter-policy policy-name
By default, an EVI IS-IS process is not associated with any routing policy.
Adjacency change logging enables an EVI IS-IS process to send a log message to the information center when an adjacency change occurs. With the information center, you can set log message filtering and output rules, including output destinations. For more information about using the information center, see Network Management and Monitoring Configuration Guide.
To enable adjacency change logging:
Step
Remarks
N/A
evi-isis process-id
N/A
3.       Enable adjacency change logging.
log-peer-change enable
By default, adjacency change logging is enabled.
To report critical EVI IS-IS events to an NMS, enable SNMP notifications for EVI IS-IS. For EVI IS-IS SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
In addition to the private EVI IS-IS MIB, EVI IS-IS shares the standard IS-IS MIB with IS-IS and other protocols that use IS-IS in the control plane. For SNMP to correctly identify a protocol's management information in the standard IS-IS MIB, you must configure a unique context for each of these protocols. If a protocol supports multiple processes, you must assign a unique context to each process.
The context names must be unique among all the protocols and their processes.
Context is a method introduced to SNMPv3 for multiple-instance management. For SNMPv1/v2c, you must specify a context name as a community name for protocol identification.
To configure SNMP notifications and context for an EVI IS-IS process:
Step
Remarks
N/A
2.       Enable EVI IS-IS notifications.
snmp-agent trap enable evi-isis [ adjacency-state-change | area-mismatch | buffsize-mismatch | id-length-mismatch | link-disconnect | lsp-parse-error | lsp-size-exceeded | max-seq-exceeded | maxarea-mismatch | new-ded | own-lsp-purge | protocol-support | rejected-adjacency | skip-sequence-number | topology-change | version-skew ] *
By default, all EVI IS-IS notifications are enabled.
3.       Enter EVI IS-IS process view.
evi-isis process-id
N/A
4.       Configure an SNMP context name for the EVI IS-IS process.
By default, no SNMP context name is configured for an EVI IS-IS process.
Enable Graceful Restart for the peer EVI IS-IS processes at two ends of an EVI tunnel to guarantee nonstop forwarding while the peer EVI IS-IS processes are re-establishing their adjacency after a process restart or active/standby switchover occurs.
·          The restart interval.
·          The EVI IS-IS hello interval multiplied by the hello multiplier.
If the edge device is a DED, its hello interval is one-third of the hello interval set by using the evi isis timer hello command.
To configure Graceful Restart for an EVI IS-IS process:
Step
Remarks
N/A
evi-isis process-id
N/A
3.       Enable Graceful Restart.
graceful-restart
By default, EVI IS-IS Graceful Restart is disabled.
4.       Configure the restart interval.
The default restart interval is 300 seconds.
If the restarting EVI process fails to complete re-establishing the adjacency with the peer EVI process, the EVI link goes down.
An EVI IS-IS process advertises all local MAC reachability information in one LSP. By default, an LSP can convey up to 55 x 210 MAC address entries.
To increase this number to accommodate all local MAC address entries, create virtual systems. Each virtual system represents an increase of 55 x 210 MAC address entries. If n virtual systems are created, the maximum number of MAC address entries in an LSP is (n+1) x 55 x 210.
To configure EVI IS-IS virtual system:
Step
Remarks
N/A
evi-isis process-id
N/A
3.       Create an EVI IS-IS virtual system.
virtual-system systemid
By default, no EVI IS-IS virtual systems exist.
* IMPORTANT:
The virtual system ID must be unique in the EVI network.
If two sites use different VLANs to convey the same service, you can configure a mapping between the VLANs at the two sites.
For example, site 1 uses VLAN 100 and site 2 uses VLAN 200 to transmit data service. At site 1, map VLAN 100 to VLAN 200. At site 2, map VLAN 200 to VLAN 100. When the edge device at site 1 receives MAC addresses from site 2 in VLAN 200, it adds the MAC addresses to VLAN 100 automatically. Likewise, when the edge device at site 2 receives MAC addresses from site 1 in VLAN 100, it adds the MAC addresses to VLAN 200 automatically.
In the mapping at site 1, VLAN 100 is the local VLAN, and VLAN 200 is the remote VLAN.
At a site, a VLAN can have only one mapping for a remote site. The local site considers a remote VLAN invalid if the remote VLAN has the same VLAN ID as the local VLAN in a mapping. The local site drops the MAC addresses received from the remote site in the VLAN. In the previous example, site 1 will drop a MAC address received from site 2 if the address is in VLAN 100.
To map a local VLAN to a remote VLAN:
Step
Remarks
N/A
N/A
3.       Map a local VLAN to a remote VLAN.
evi vlan-mapping local-vlan-id translated remote-vlan-id [ site site-id ]
By default, no VLAN mappings are configured.
You must specify the local VLAN and the remote VLAN as extended VLANs on the corresponding EVI tunnel interfaces.
Step
Remarks
N/A
N/A
3.       Enable EVI ARP flood suppression.
evi arp-suppression enable
By default, EVI ARP flood suppression is disabled.
4.       (Optional.) Display EVI ARP flood suppression entries.
·         Centralized devices in standalone mode:
display evi arp-suppression interface tunnel interface-number [ vlan vlan-id ] [ count ]
·         Distributed devices in standalone mode/centralized devices in IRF mode:
display evi arp-suppression interface tunnel interface-number [ vlan vlan-id ] [ slot slot-number ] [ count ]
·         Distributed devices in IRF mode:
display evi arp-suppression interface tunnel interface-number [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ count ]
The display commands are available in any view.
By default, the device floods unknown unicast and multicast frames only to internal interfaces. EVI flooding enables the device to flood all destination-unknown frames to an EVI tunnel interface.
To enable EVI flooding for all destination-unknown frames:
Step
Remarks
N/A
N/A
3.       Enable EVI flooding.
evi flooding enable
By default, EVI flooding is disabled.
CAUTION
CAUTION:
Do not configure selective flooding for local unicast MAC addresses. The setting might cause remote devices to drop packets destined for the MAC address.
If an application uses a special multicast address that requires flooding across sites and cannot be added to a multicast forwarding table by IGMP snooping, enable selective flooding for the multicast address.
To enable selective flooding for a MAC address:
Step
Remarks
N/A
N/A
3.       Enable selective flooding for the MAC address in a set of VLANs.
evi selective-flooding mac-address mac-address vlan vlan-id-list
By default, selective flooding is disabled for all MAC addresses.
On an ENDS, display IPv4 ENDS information.
display evi neighbor-discovery server summary
On an ENDS, display IPv4 neighbors that have registered with the ENDS.
display evi neighbor-discovery server member [ interface tunnel interface-number | [ local local-ip | remote client-ip ] [ vpn-instance vpn-instance-name ] ]
On an ENDS, display ENDS statistics.
display evi neighbor-discovery server statistics interface tunnel interface-number
Display IPv4 ENDC information.
display evi neighbor-discovery client summary
Display IPv4 neighbors that an ENDC has learned.
display evi neighbor-discovery client member [ interface tunnel interface-number | [ local local-ip | remote client-ip | server server-ip ] [ vpn-instance vpn-instance-name ] ]
Display ENDC statistics.
display evi neighbor-discovery client statistics interface tunnel interface-number
Display EVI-Link interface information for an EVI tunnel.
display evi link interface tunnel interface-number
Display brief EVI IS-IS process information.
display evi isis brief [ process-id ]
Display local MAC addresses.
display evi isis local-mac { dynamic | static } [ interface tunnel interface-number [ vlan vlan-id ] [ filtered | passed ] [ count ] ]
display evi isis local-mac nonadvertised [ interface tunnel interface-number [ vlan vlan-id ] [ count ] ]
Display remote MAC addresses.
display evi isis remote-mac [ interface tunnel interface-number [ vlan vlan-id ] [ count ] ]
Display EVI IS-IS link state database.
display evi isis lsdb [ local | lsp-id lspid | verbose ] * [ process-id ]
Display EVI IS-IS neighbors.
display evi isis peer [ process-id ]
Display EVI IS-IS information for a tunnel interface.
display evi isis tunnel [ tunnel-number ]
Display EVI IS-IS GR state.
display evi isis graceful-restart status [ process-id ]
Display remote MAC addresses (centralized devices in standalone mode).
display evi mac-address interface tunnel interface-number [ vlan vlan-id ] [ count ]
display evi mac-address interface tunnel interface-number mac-address mac-address vlan vlan-id
Display remote MAC addresses (distributed devices in standalone mode/centralized devices in IRF mode).
display evi mac-address interface tunnel interface-number [ vlan vlan-id ] [ slot slot-number ] [ count ]
display evi mac-address interface tunnel interface-number mac-address mac-address vlan vlan-id [ slot slot-number ]
Display remote MAC addresses (distributed devices in IRF mode).
display evi mac-address interface tunnel interface-number [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ count ]
display evi mac-address interface tunnel interface-number mac-address mac-address vlan vlan-id [ chassis chassis-number slot slot-number ]
Display EVI ARP flood suppression entries (centralized devices in standalone mode).
Display EVI ARP flood suppression entries (distributed devices in standalone mode/centralized devices in IRF mode).
Display EVI ARP flood suppression entries (distributed devices in IRF mode).
Display VLAN mappings for EVI.
display evi vlan-mapping [ process-id [ vlan vlan-id ] ]
Clear EVI ARP flood suppression entries.
reset evi arp-suppression interface tunnel interface-number [ vlan vlan-id ]
Clear data for EVI IS-IS processes.
reset evi isis all [ process-id ]
Clear ENDP packet statistics on an ENDC.
reset evi neighbor-discovery client statistics interface tunnel interface-number
Clear ENDP packet statistics on an ENDS.
reset evi neighbor-discovery server statistics interface tunnel interface-number
Network requirements
As shown in Figure 11.
·          Use EVI to extend VLANs 21 through 100 across site 1, site 2, and site 3 over an IPv4 network.
·          Use network ID 1 to identify the EVI network.
·          Use Device A as an ENDS and all other edge devices as ENDCs for neighbor discovery.
·          Map site 1's VLAN 80 to site 2's VLAN 21 to convey the same service across the two sites.
·          Configure a routing policy on Device A to advertise MAC addresses in VLANs 21 to 90 to the remote sites.
Figure 11 Network diagram
Configuration procedure
1.        Configure routes for the sites to reach each other. (Details not shown.)
2.        Configure Device A:
# Configure the site ID.
[DeviceA] evi site-id 1
# Assign an IP address to GigabitEthernet 2/0/1.
[DeviceA] interface GigabitEthernet 2/0/1
[DeviceA-GigabitEthernet2/0/1] ip address 1.1.1.1 24
[DeviceA-GigabitEthernet2/0/1] quit
# Create an IPv4 EVI tunnel interface.
[DeviceA] interface tunnel 0 mode evi
# Set the network ID to 1 for the EVI tunnel interface.
[DeviceA-Tunnel0] evi network-id 1
# Specify the IP address of GigabitEthernet 2/0/1 as the source IP of the EVI tunnel.
[DeviceA-Tunnel0] source 1.1.1.1
# Set the tunnel keepalive interval to 20 seconds and the maximum number of transmissions to 2.
[DeviceA-Tunnel0] keepalive 20 2
# Specify extended VLANs on the EVI tunnel interface.
[DeviceA-Tunnel0] evi extend-vlan 21 to 100
# Configure Device A as an ENDS on the EVI tunnel interface.
[DeviceA-Tunnel0] evi neighbor-discovery server enable
# Map VLAN 80 to site 2's VLAN 21 on Tunnel 0.
[DeviceA-Tunnel0] evi vlan-mapping 80 translated 21 site 2
[DeviceA-Tunnel0] quit
# Configure the routing policy EVI-Filter to match MAC addresses in VLANs 21 to 90.
[DeviceA] route-policy EVI-Filter permit node 10
[DeviceA-route-policy-EVI-Filter-10] if-match vlan 21 to 90
[DeviceA-route-policy-EVI-Filter-10] quit
# Assign the policy to EVI IS-IS process 0.
[DeviceA] evi-isis 0
[DeviceA-evi-isis-0] filter-policy EVI-Filter
[DeviceA-evi-isis-0] quit
# Enable EVI on GigabitEthernet 2/0/1.
[DeviceA] interface gigabitethernet 2/0/1
[DeviceA-GigabitEthernet2/0/1] evi enable
3.        Configure Device B:
[DeviceB] evi site-id 2
[DeviceB] interface GigabitEthernet 2/0/1
[DeviceB-GigabitEthernet2/0/1] ip address 1.1.2.1 24
[DeviceB-GigabitEthernet2/0/1] quit
[DeviceB] interface tunnel 0 mode evi
[DeviceB-Tunnel0] evi network-id 1
[DeviceB-Tunnel0] source 1.1.2.1
[DeviceB-Tunnel0] keepalive 20 2
[DeviceB-Tunnel0] evi extend-vlan 21 to 100
# Configure Device B as an ENDC of Device A.
[DeviceB-Tunnel0] evi neighbor-discovery client enable 1.1.1.1
# Map VLAN 21 to site 1's VLAN 80 on Tunnel 0.
[DeviceB-Tunnel0] evi vlan-mapping 21 translated 80 site 1
[DeviceB-Tunnel0] quit
[DeviceB] interface gigabitethernet 2/0/1
[DeviceB-GigabitEthernet2/0/1] evi enable
4.        Configure Device C:
<DeviceC> system-view
[DeviceC] evi site-id 3
[DeviceC] interface gigabitethernet 2/0/1
[DeviceC-GigabitEthernet2/0/1] ip address 1.1.3.1 24
[DeviceC-GigabitEthernet2/0/1] quit
[DeviceC] interface tunnel 0 mode evi
[DeviceC-Tunnel0] evi network-id 1
[DeviceC-Tunnel0] source 1.1.3.1
[DeviceC-Tunnel0] keepalive 20 2
[DeviceC-Tunnel0] evi extend-vlan 21 to 100
# Configure Device C as an ENDC of Device A.
[DeviceC-Tunnel0] evi neighbor-discovery client enable 1.1.1.1
[DeviceC-Tunnel0] quit
[DeviceC-GigabitEthernet2/0/1] evi enable
1.        Verify the configuration on Device A:
# Display information about the EVI tunnel interface.
[DeviceA] display interface tunnel 0
Tunnel0
Current state: UP
Line protocol state: UP
Bandwidth: 64kbps
Maximum Transmit Unit: 64000
Internet protocol processing: disabled
Tunnel source 1.1.1.1
Tunnel keepalive enabled, Period(20 s), Retries(2)
Network ID 1
Tunnel protocol/transport GRE_EVI/IP
Last clearing of counters:  Never
# Display information about EVI-Link interfaces.
[DeviceA] display evi link interface tunnel 0
Interface     Status Source          Destination
EVI-Link0     UP     1.1.1.1         1.1.2.1
EVI-Link1     UP     1.1.1.1         1.1.3.1
# Display ENDS information.
[DeviceA] display evi neighbor-discovery server summary
Interface      Local Address   Network ID    Auth        Members   Vpn-instance
Tunnel0        1.1.1.1         1             disabled    3         [No Vrf]
# Display ENDC information.
[DeviceA] display evi neighbor-discovery client summary
                      Status: I-Init  E-Establish  P-Probe
Interface   Local Address   Server Address  Network ID  Reg  Auth      Status Vpn-instance
Tunnel0    1.1.1.1       1.1.1.1         1          15 disabled  E      [No Vrf]
# Display EVI neighbors registered with the ENDS.
[DeviceA] display evi neighbor-discovery server member
Interface: Tunnel0    Network ID: 1    Vpn-instance: [No Vrf]
IP Address: 1.1.1.1
Client Address  System ID         Expire    Created Time
1.1.1.1         000F-0001-0001    25        2013/01/01 00:00:43
1.1.2.1         000F-0001-0002    15        2013/01/01 01:00:46
1.1.3.1         000F-0001-0003    20        2013/01/01 01:02:13
# Display neighbor entries that Device A has learned.
[DeviceA] display evi neighbor-discovery client member
Local Address: 1.1.1.1
Server Address: 1.1.1.1
Neighbor        System ID         Created Time           Expire    Status
1.1.2.1         000F-0001-0002    2013/01/01 12:12:12    13        Up
1.1.3.1         000F-0001-0003    2013/01/01 12:12:12    12        Up
# Display VLAN mappings for EVI.
[DeviceA] display evi vlan-mapping
                         VLAN mappings for EVI IS-IS(0)
Local-VID  Peer-ID          Remote-VID  Interface   Remote-site
80         000F.0001.0002   21          EVI-Link0   2
# Verify that MAC addresses in VLAN 100 have been filtered by the routing policy on Device A.
[DeviceA] display evi isis local-mac dynamic
Process ID: 0
  Tunnel interface: Tunnel0
  VLAN ID: 100
    MAC address: 0001-0100-0001 (Filtered)
    MAC address: 0001-0100-0002 (Filtered)
    MAC address: 0001-0100-0003 (Filtered)
  VLAN ID: 80
    MAC address: 0001-0080-0001
    MAC address: 0001-0080-0002
    MAC address: 0001-0080-0003
# Verify that the routing policy on Device B and the VLAN mapping on Device A are working correctly.
[DeviceA] display evi isis remote-mac
Process ID: 0
  VLAN ID: 80
    MAC address: 0002-0021-0001
      Interface: EVI-Link0
          Flags: 0x2
    MAC address: 0002-0021-0002
          Flags: 0x2
    MAC address: 0002-0021-0003
          Flags: 0x2
  VLAN ID: 100
    MAC address: 0002-0100-0001
          Flags: 0x2
    MAC address: 0002-0100-0002
          Flags: 0x2
    MAC address: 0002-0100-0003
          Flags: 0x2
The output shows that Device A has received MAC addresses in VLAN 100 from Device B because Device B does not filter VLAN 100. The MAC addresses received from Device B in VLAN 21 have been added to VLAN 80.
2.        Verify the configuration on Device B:
[DeviceB] display interface tunnel 0
Tunnel0
Current state: UP
Bandwidth: 64kbps
Tunnel source 1.1.2.1
Network ID 1
[DeviceB] display evi link interface tunnel 0
EVI-Link0     UP     1.1.2.1         1.1.1.1
EVI-Link1     UP     1.1.2.1         1.1.3.1
[DeviceB] display evi neighbor-discovery client summary
Tunnel0    1.1.2.1       1.1.1.1         1         15   disabled  E    [No Vrf]
# Display neighbor entries that Device B has learned.
[DeviceB] display evi neighbor-discovery client member
Local Address: 1.1.3.1
1.1.1.1        000F-0001-0001    2013/01/01 12:12:12    13        Up
1.1.3.1        000F-0001-0003    2013/01/01 12:12:12    13        Up
[DeviceB] display evi vlan-mapping
21         000F.0001.0001   80          EVI-Link0   1
# Verify that MAC addresses in VLAN 100 are not filtered.
[DeviceB] display evi isis local-mac dynamic
Process ID: 0
  VLAN ID: 100
  VLAN ID: 21
# Verify that the routing policy on Device A and the VLAN mapping on Device B are working correctly.
[DeviceB] display evi isis remote-mac
Process ID: 0
  VLAN ID: 21
          Flags: 0x2
          Flags: 0x2
          Flags: 0x2
The output shows that Device B does not have remote addresses in VLAN 100 because VLAN 100 does not match the routing policy on Device A. The MAC addresses received from Device A in VLAN 80 have been added to VLAN 21.
3.        Verify the configuration on Device C:
[DeviceC] display interface tunnel 0
Tunnel0
Current state: UP
Bandwidth: 64kbps
Tunnel source 1.1.3.1
Network ID 1
# Display information about EVI-Link interfaces on Device C.
[DeviceC] display evi link interface tunnel 0
EVI-Link0     UP     1.1.3.1         1.1.1.1
EVI-Link1     UP     1.1.3.1         1.1.2.1
[DeviceC] display evi neighbor-discovery client summary
Tunnel0    1.1.3.1       1.1.1.1         1         15  disabled  E     [No Vrf]
# Display neighbor entries that Device C has learned.
[DeviceC] display evi neighbor-discovery client member
1.1.2.1        000F-0000-0002    2013/01/01 12:12:12    13        Up
# Verify the routing policy and VLAN mapping settings on Device A and Device B are working correctly.
[DeviceC] display evi isis remote-mac
Process ID: 0
  VLAN ID: 21
      Interface: EVI-Link1
          Flags: 0x0
          Flags: 0x0
          Flags: 0x0
  VLAN ID: 80
          Flags: 0x0
          Flags: 0x0
          Flags: 0x0
  VLAN ID: 100
          Flags: 0x2
          Flags: 0x2
          Flags: 0x2
The output shows that Device C can receive MAC addresses in VLAN 100 from Device B but not from Device A, because only Device A filters VLAN 100. No VLAN mapping has been performed for MAC addresses received in VLAN 80 and VLAN 21 because Device C does not have VLAN mappings for the two VLANs.
4.        Verify that hosts in different sites can ping one another in the same extended VLAN.
As shown in Figure 12.
·          Deploy Device A and Device B to connect site 1 to the EVI network for redundancy. Use VLAN 2012 as the designated site VLAN.
·          Use Device B as an ENDS and all other edge devices as ENDCs for neighbor discovery.
Figure 12 Network diagram
# Assign an IP address to GigabitEthernet 2/0/2.
[DeviceA] interface GigabitEthernet 2/0/2
[DeviceA-GigabitEthernet2/0/2] ip address 1.1.1.1 24
[DeviceA-GigabitEthernet2/0/2] quit
# Specify the IP address of GigabitEthernet 2/0/2 as the source IP of the EVI tunnel.
# Configure Device A as an ENDC of Device B.
[DeviceA-Tunnel0] evi neighbor-discovery client enable 1.1.2.2
# Configure VLAN 2012 as the designated EVI IS-IS site VLAN, and assign GigabitEthernet 2/0/1 to the VLAN.
[DeviceA] vlan 2012
[DeviceA-vlan2012] port gigabitethernet 2/0/1
[DeviceA-vlan2012] quit
[DeviceA] evi designated-vlan 2012
# Enable EVI on GigabitEthernet 2/0/2.
[DeviceA] interface gigabitethernet 2/0/2
[DeviceA-GigabitEthernet2/0/2] evi enable
[DeviceB] evi site-id 1
[DeviceB] interface GigabitEthernet 2/0/2
[DeviceB-GigabitEthernet2/0/2] ip address 1.1.2.2 24
[DeviceB-GigabitEthernet2/0/2] quit
[DeviceB-Tunnel0] source 1.1.2.2
# Configure Device B as an ENDS on the EVI tunnel interface.
[DeviceB-Tunnel0] evi neighbor-discovery server enable
# Set a DED priority of 100 on the EVI tunnel interface.
[DeviceB-Tunnel0] evi isis ded-priority 100
# Specify VLAN 2012 as the designated EVI IS-IS site VLAN, and assign GigabitEthernet 2/0/1 to the VLAN.
[DeviceB] vlan 2012
[DeviceB-vlan2012] port gigabitethernet 2/0/1
[DeviceB-vlan2012] quit
[DeviceB] evi designated-vlan 2012
[DeviceB] interface gigabitethernet 2/0/2
[DeviceB-GigabitEthernet2/0/2] evi enable
[DeviceC] evi site-id 2
[DeviceC] interface GigabitEthernet 2/0/2
[DeviceC-GigabitEthernet2/0/2] ip address 1.1.3.3 24
[DeviceC-GigabitEthernet2/0/2] quit
[DeviceC-Tunnel0] source 1.1.3.3
# Configure Device C as an ENDC of Device B.
[DeviceC-Tunnel0] evi neighbor-discovery client enable 1.1.2.2
[DeviceC] interface gigabitethernet 2/0/2
[DeviceC-GigabitEthernet2/0/2] evi enable
Server Address: 1.1.2.2
1.1.2.2         c4ca-d94d-1385    2013/01/06 09:40:26    64        Up
1.1.3.3         c4ca-d94d-138d    2013/01/06 09:40:26    64        Up
EVI-Link0     UP     1.1.1.1         1.1.2.2
EVI-Link1     UP     1.1.1.1         1.1.3.3
# Display EVI IS-IS information for the EVI tunnel interface. Check the DED field and the LAV field to verify the DED role and active extended VLANs on Device A. Check the AEF field to verify the qualification of Device A as an appointed edge forwarder.
[DeviceA] display evi isis tunnel 0
Tunnel0
MTU: 1400
DED: No
DED priority: 64
Hello timer: 10s
Hello multiplier: 3
CSNP timer: 10s
LSP timer: 100ms
LSP transmit-throttle count: 5
AEF: Yes
EVI-Link0    DED: Yes
EVI-Link1    DED: No
LAV:
  61-100
The output shows that Device A is not elected the DED for site 1 because of its low DED priority. Device A can be an appointed edge forwarder for extended VLANs. VLAN 61 to VLAN 100 are active on Device A.
[DeviceB] display evi neighbor-discovery client member interface tunnel 0
Local Address: 1.1.2.2
1.1.1.1         c4ca-d94d-1200    2013/01/06 09:40:30    74        Up
1.1.3.3         c4ca-d94d-138d    2013/01/06 09:40:15    74        Up
[DeviceB] display evi neighbor-discovery server member interface tunnel 0
IP Address: 1.1.2.2
1.1.1.1         c4ca-d94d-1200    64        2013/01/06 09:40:16
1.1.2.2         c4ca-d94d-1385    68        2013/01/06 09:32:00
1.1.3.3         c4ca-d94d-138d    67        2013/01/06 09:40:14
EVI-Link0     UP     1.1.2.2         1.1.1.1
EVI-Link1     UP     1.1.2.2         1.1.3.3
# Display EVI IS-IS information for the EVI tunnel interface. Check the DED field and the LAV field to verify the DED role and active extended VLANs on Device B. Check the AEF field to verify the qualification of Device B as an appointed edge forwarder.
[DeviceB] display evi isis tunnel 0
Tunnel0
MTU: 1400
DED: Yes
DED priority: 100
Hello timer: 10s
Hello multiplier: 3
CSNP timer: 10s
LSP timer: 100ms
AEF: Yes
EVI-Link0    DED: Yes
EVI-Link1    DED: Yes
LAV:
  21-60
The output shows that Device B is elected the DED for site 1 because of its high DED priority. Device B can be an appointed edge forwarder for extended VLANs. VLAN 21 to VLAN 60 are active on Device B.
Local Address: 1.1.3.3
1.1.1.1         c4ca-d94d-1200    2013/01/06 09:40:29    64        Up
1.1.2.2         c4ca-d94d-1385    2013/01/06 09:40:29    64        Up
EVI-Link0     UP     1.1.3.3         1.1.1.1
EVI-Link1     UP     1.1.3.3         1.1.2.2
Use EVI to connect the sites of the data center in Figure 13. To isolate different types of traffic and extend their VLANs to different sites, set up EVI networks as shown in Table 2.
Table 2 EVI networks
Traffic type
Network ID
Extended VLANs
Sites
Database
1
100, 101
2, 3, 4
Network management
2
4000
All sites
Web
3
50, 80
1, 4
In each EVI network, use the edge device at site 4 as an ENDS and all other edge devices as its ENDCs.
Figure 13 Network diagram
2.        Configure site 4:
<Site4> system-view
[Site4] evi site-id 4
[Site4] interface gigabitethernet 2/0/1
[Site4-GigabitEthernet2/0/1] ip address 172.16.4.1 24
[Site4-GigabitEthernet2/0/1] quit
# Configure the database EVI network.
[Site4] interface tunnel 101 mode evi
[Site4-Tunnel101] source 172.16.4.1
[Site4-Tunnel101] evi network-id 1
[Site4-Tunnel101] evi extend-vlan 100 101
[Site4-Tunnel101] evi neighbor-discovery server enable
[Site4-Tunnel101] quit
# Configure the network management EVI network.
[Site4] interface tunnel 102 mode evi
[Site4-Tunnel102] source 172.16.4.1
[Site4-Tunnel102] evi network-id 2
[Site4-Tunnel102] evi extend-vlan 4000
[Site4-Tunnel102] evi neighbor-discovery server enable
[Site4-Tunnel102] quit
# Configure the Web service EVI network.
[Site4] interface tunnel 103 mode evi
[Site4-Tunnel103] source 172.16.4.1
[Site4-Tunnel103] evi network-id 3
[Site4-Tunnel103] evi extend-vlan 50 to 80
[Site4-Tunnel103] evi neighbor-discovery server enable
[Site4-Tunnel103] quit
[Site4-GigabitEthernet2/0/1] evi enable
3.        Configure site 1:
<Site1> system-view
[Site1] evi site-id 1
[Site1] interface gigabitethernet 2/0/1
[Site1-GigabitEthernet2/0/1] ip address 172.16.1.1 24
[Site1-GigabitEthernet2/0/1] quit
[Site1] interface tunnel 102 mode evi
[Site1-Tunnel102] source 172.16.1.1
[Site1-Tunnel102] evi network-id 2
[Site1-Tunnel102] evi extend-vlan 4000
[Site1-Tunnel102] evi neighbor-discovery client enable 172.16.4.1
[Site1-Tunnel102] quit
[Site1] interface tunnel 103 mode evi
[Site1-Tunnel103] source 172.16.1.1
[Site1-Tunnel103] evi network-id 3
[Site1-Tunnel103] evi extend-vlan 50 to 80
[Site1-Tunnel103] evi neighbor-discovery client enable 172.16.4.1
[Site1-Tunnel103] quit
[Site1-GigabitEthernet2/0/1] evi enable
4.        Configure all the other sites in the same way that site 1 is configured. Make sure extended VLANs are correctly configured at each site.
# Display neighbors registered with the ENDS in each EVI network.
[Site4] display evi neighbor-discovery server member
Interface: Tunnel101    Network ID: 1    Vpn-instance: [No Vrf]
IP Address: 172.16.4.1
172.16.2.1      000F-0001-0002    25        2013/01/01 00:00:43
172.16.3.1      000F-0001-0003    15        2013/01/01 01:00:46
172.16.4.1      000F-0001-0004    20        2013/01/01 01:02:13
Interface: Tunnel102    Network ID: 2    Vpn-instance: [No Vrf]
172.16.1.1      000F-0001-0001    19        2013/01/01 00:19:31
172.16.5.1      000F-0001-0005    18        2013/01/01 01:04:32
Interface: Tunnel103    Network ID: 3    Vpn-instance: [No Vrf]
EVI Layer 2 multicast configuration example
Configure the EVI network (network ID 1) in Figure 14 to transmit multicast traffic for the multicast group at 228.8.8.8 in VLAN 100. The multicast source is connected to Device A in Site 1, and a receiver host is attached to Device B in Site 2.
In the EVI network, Device A is the ENDS, and Device B is the ENDC.
Figure 14 Network diagram
2.        Configure the Router:
# Enable IP multicast routing, and enable IGMP on VLAN-interface 100.
<Router> system-view
[Router] multicast routing
[Router-mrib] quit
[Router] vlan 100
[Router-vlan100] quit
[Router] interface vlan-interface 100
[Router-Vlan-interface100] ip address 100.100.1.1 24
[Router-Vlan-interface100] igmp enable
3.        Configure Device A:
# Enable selective flooding for PIM hellos (destination MAC 0100-5e00-0001, and destination IP 224.0.0.1) and IGMP general query packets (destination MAC 0100-5e00-000D, and destination IP 224.0.0.13). These destination MAC addresses cannot be learned in the data plane. Selective flooding enables these packets to be sent between sites.
[DeviceA-Tunnel0] evi selective-flooding mac-address 0100-5e00-0001 vlan 100
[DeviceA-Tunnel0] evi selective-flooding mac-address 0100-5e00-000D vlan 100
# Enable global IGMP snooping.
[DeviceA] igmp-snooping
[DeviceA-igmp-snooping] quit
# Create VLAN 100, assign GigabitEthernet 2/0/2 and GigabitEthernet 2/0/3 to the VLAN, and enable IGMP snooping in the VLAN.
[DeviceA] vlan 100
[DeviceA-vlan100] port gigabitethernet 2/0/2 to gigabitethernet 2/0/3
[DeviceA-vlan100] igmp-snooping enable
[DeviceA-vlan100] quit
4.        Configure Device B:
[DeviceB] igmp-snooping
[DeviceB-igmp-snooping] quit
# Create VLAN 100, assign GigabitEthernet 2/0/2 to the VLAN, and enable IGMP snooping in the VLAN.
[DeviceA] vlan 100
1.        On Device A:
# Display EVI-Link interface information.
# Display dynamic IGMP snooping forwarding entries.
[DeviceA] display igmp-snooping group
Total 1 entries.
VLAN 100: Total 1 entries.
  (0.0.0.0, 228.8.8.8)
    Host slots (0 in total):
    Host ports (1 in total):
      ELNK0                   (00:04:01)
2.        On Device B:
# Display Router port information.
[DeviceB] display igmp-snooping router-port
VLAN 100:
  Router slots (0 in total):
  Router ports (1 in total):
    ELNK0                   (00:02:35)
[DeviceB] display igmp-snooping group
Total 1 entries.
    Host slots (1 in total):
      chassis 1 slot 3
      GE2/0/2
Index
C D E L O T
C
Compatibility information,11
Configuring EVI basic features,12
Configuring VLAN mappings,25
D
Displaying and maintaining EVI,27
E
Enabling EVI ARP flood suppression,25
Enabling EVI flooding for all destination-unknown frames,26
Enabling selective flooding for a MAC address,26
EVI configuration examples,28
EVI configuration task list,12
L
Licensing requirements,11
O
Overview,1
T
Tuning EVI IS-IS parameters,16
