01-Text | 6.77 MB |
Installation safety recommendations
Installation site requirements
Space and airflow requirements
Temperature, humidity, and altitude requirements
Installing or removing the server
Installing the chassis rails and slide rails
Connecting a mouse, keyboard, and monitor
Removing the server from a rack
Powering on and powering off the server
Deploying and registering UIS Manger
Installing the low mid air baffle or GPU module air baffle to a compute module
Installing the GPU module air baffle to a rear riser card
Installing riser cards and PCIe modules
Installing a riser card and a PCIe module in a compute module
Installing riser cards and PCIe modules at the server rear
Installing storage controllers and power fail safeguard modules
Installing a GPU module in a compute module
Installing a GPU module to a rear riser card
Installing an mLOM Ethernet adapter
Installing a PCIe Ethernet adapter
Installing a PCIe M.2 SSD in a compute module
Installing a PCIe M.2 SSD at the server rear
Installing an NVMe SSD expander module
Installing the NVMe VROC module
Installing and setting up a TCM or TPM
Installation and setup flowchart
Enabling the TCM or TPM in the BIOS
Configuring encryption in the operating system
Replacing a compute module and its main board
Removing the main board of a compute module
Installing a compute module and its main board
Replacing a compute module access panel
Replacing the chassis access panel
Replacing air baffles in a compute module
Replacing the power supply air baffle
Replacing a riser card air baffle
Replacing a riser card and a PCIe module
Replacing the riser card and PCIe module in a compute module
Replacing a riser card and PCIe module at the server rear
Replacing a storage controller
Replacing the power fail safeguard module for a storage controller
Replacing the GPU module in a compute module
Replacing a GPU module at the server rear
Replacing an mLOM Ethernet adapter
Replacing a PCIe Ethernet adapter
Replacing an M.2 transfer module and a PCIe M.2 SSD
Replacing the M.2 transfer module and a PCIe M.2 SSD in a compute module
Replacing an M.2 transfer module and a PCIe M.2 SSD at the server rear
Replacing the dual SD card extended module
Replacing an NVMe SSD expander module
Replacing the NVMe VROC module
Replacing the management module
Removing the management module
Installing the management module
Replacing the diagnostic panel
Connecting drive cables in compute modules
Storage controller cabling in riser cards at the server rear
Connecting the flash card on a storage controller
Connecting the NCSI cable for a PCIe Ethernet adapter
Connecting the front I/O component cable from the right chassis ear
Connecting the cable for the front VGA and USB 2.0 connectors on the left chassis ear
Monitoring the temperature and humidity in the equipment room
Appendix A Server specifications
Front panel view of the server
Front panel view of a compute module
Main board of a compute module
Appendix B Component specifications
DRAM DIMM rank classification label
Drive configurations and numbering
Riser card and system board port mapping relationship
800 W high-voltage power supply
850 W high-efficiency Platinum power supply
Diagnostic panel specifications
Storage options other than HDDs and SDDs
Security bezels, slide rail kits, and CMA
Appendix C Managed hot removal of NVMe drives
Performing a managed hot removal in Windows
Performing a managed hot removal in Linux
Performing a managed hot removal from the CLI
Performing a managed hot removal from the Intel® ASM Web interface
Appendix D Environment requirements
About environment requirements
General environment requirements
Operating temperature requirements
Safety information
Safety sign conventions
To avoid bodily injury or damage to the server or its components, make sure you are familiar with the safety signs on the server chassis or its components.
Table 1 Safety signs
Sign |
Circuit or electricity hazards are present. Only H3C authorized or professional server engineers are allowed to service, repair, or upgrade the server. WARNING! To avoid bodily injury or damage to circuits, do not open any components marked with the electrical hazard sign unless you have authorization to do so. |
Electrical hazards are present. Field servicing or repair is not allowed. WARNING! To avoid bodily injury, do not open any components with the field-servicing forbidden sign in any circumstances. |
The surface or component might be hot and present burn hazards. WARNING! To avoid being burnt, allow hot surfaces or components to cool before touching them. |
The server or component is heavy and requires more than one people to carry or move. WARNING! To avoid bodily injury or damage to hardware, do not move a heavy component alone. In addition, observe local occupational health and safety requirements and guidelines for manual material handling. |
The server is powered by multiple power supplies. WARNING! To avoid bodily injury from electrical shocks, make sure you disconnect all power supplies if you are performing offline servicing. |
Power source recommendations
Power instability or outage might cause data loss, service disruption, or damage to the server in the worst case.
To protect the server from unstable power or power outage, use uninterrupted power supplies (UPSs) to provide power for the server.
To avoid bodily injury or damage to the server, read the following information carefully before you operate the server.
General operating safety
To avoid bodily injury or damage to the server, follow these guidelines when you operate the server:
· Only H3C authorized or professional server engineers are allowed to install, service, repair, operate, or upgrade the server.
· Make sure all cables are correctly connected before you power on the server.
· Place the server on a clean, stable table or floor for servicing.
· To avoid being burnt, allow the server and its internal modules to cool before touching them.
Electrical safety
WARNING! If you put the server in standby mode (system LED in amber) with the power on/standby button on the front panel, the power supplies continue to supply power to some circuits in the server. To remove all power for servicing safety, you must first press the button until the system LED turns into steady amber, and then remove all power cords from the server. |
To avoid bodily injury or damage to the server, follow these guidelines:
· Always use the power cords that came with the server.
· Do not use the power cords that came with the server for any other devices.
· Power off the server when installing or removing any components that are not hot swappable.
Rack mounting recommendations
To avoid bodily injury or damage to the equipment, follow these guidelines when you rack mount a server:
· Mount the server in a standard 19-inch rack.
· Make sure the leveling jacks are extended to the floor and the full weight of the rack rests on the leveling jacks.
· Couple the racks together in multi-rack installations.
· Load the rack from the bottom to the top, with the heaviest hardware unit at the bottom of the rack.
· Get help to lift and stabilize the server during installation or removal, especially when the server is not fastened to the rails. As a best practice, a minimum of four people are required to safely load or unload a rack. A fifth person might be required to help align the server if the server is installed higher than check level.
· For rack stability, make sure only one unit is extended at a time. A rack might get unstable if more than one server unit is extended.
· Make sure the rack is stable when you operate a server in the rack.
· To maintain correct airflow and avoid thermal damage to the server, use blanks to fill empty rack units.
ESD prevention
Preventing electrostatic discharge
To prevent electrostatic damage, follow these guidelines:
· Transport or store the server with the components in antistatic bags.
· Keep the electrostatic-sensitive components in the antistatic bags until they arrive at an ESD-protected area.
· Place the components on a grounded surface before removing them from their antistatic bags.
· Avoid touching pins, leads, or circuitry.
· Make sure you are reliably grounded when touching an electrostatic-sensitive component or assembly.
Grounding methods to prevent electrostatic discharge
The following are grounding methods that you can use to prevent electrostatic discharge:
· Wear an ESD wrist strap and make sure it makes good skin contact and is reliably grounded.
· Take adequate personal grounding measures, including wearing antistatic clothing, static dissipative shoes, and antistatic gloves.
· Use conductive field service tools.
· Use a portable field service kit with a folding static-dissipating work mat.
Cooling performance
Poor cooling performance might result from improper airflow and poor ventilation and might cause damage to the server.
To ensure good ventilation and proper airflow, follow these guidelines:
· Install blanks if the following module slots are empty:
¡ Compute module slots.
¡ Drive bays.
¡ Rear riser card bays.
¡ PCIe slots.
¡ Power supply slots.
· Do not block the ventilation openings in the server chassis.
· To avoid thermal damage to the server, do not operate the server for long periods in any of the following conditions:
¡ Access panel open or uninstalled.
¡ Air baffles uninstalled.
¡ PCIe slots, drive bays, or power supply slots empty.
· If the server is stacked in a rack with other devices, make sure there is a minimum clearance of 2 mm (0.08 in) below and above the server.
Battery safety
The server's management module contains a system battery, which is designed with a lifespan of 5 to 10 years.
If the server no longer automatically displays the correct date and time, you might need to replace the battery. When you replace the battery, follow these safety guidelines:
· Do not attempt to recharge the battery.
· Do not expose the battery to a temperature higher than 60°C (140°F).
· Do not disassemble, crush, puncture, short external contacts, or dispose of the battery in fire or water.
· Dispose of the battery at a designated facility. Do not throw the battery away together with other wastes.
Preparing for installation
Prepare a rack that meets the rack requirements and plan an installation site that meets the requirements of space and airflow, temperature, humidity, equipment room height, cleanliness, and grounding.
Rack requirements
IMPORTANT: As a best practice to avoid affecting the server chassis, install power distribution units (PDUs) with the outputs facing backwards. If you install PDUs with the outputs facing the inside of the server, please perform onsite survey to make sure the cables won't affect the server rear. |
The server is 4U high. The rack for installing the server must meet the following requirements:
· A standard 19-inch rack.
· A clearance of more than 50 mm (1.97 in) between the rack front posts and the front rack door.
· A minimum of 1200 mm (47.24 in) in depth as a best practice. For installation limits for different rack depth, see Table 2.
Table 2 Installation limits for different rack depths
Rack depth |
Installation limits |
1000 mm (39.37 in) |
· H3C cable management arm (CMA) is not supported. · A clearance of 60 mm (2.36 in) is reserved from the server rear to the rear rack door for cabling. · The slide rails and PDUs might hinder each other. Perform onsite survey to determine the PDU installation location and the proper PDUs. If the PDUs hinder the installation and movement of the slide rails anyway, use other methods to support the server, a tray for example. |
1100 mm (43.31 in) |
Make sure the CMA does not hinder PDU installation at the server rear before installing the CMA. If the CMA hinders PDU installation, use a deeper rack or change the installation locations of PDUs. |
1200 mm (47.24 in) |
Make sure the CMA does not hinder PDU installation or cabling. If the CMA hinders PDU installation or cabling, change the installation locations of PDUs. For detailed installation suggestions, see Figure 1. |
Figure 1 Installation suggestions for a 1200 mm deep rack (top view)
(1) 1200 mm (47.24 in) rack depth |
(2) A minimum of 50 mm (1.97 in) between the rack front posts and the front rack door |
(3) 830 mm (32.68 in) between the rack front posts and the rear of the chassis, including power supply handles at the server rear (not shown in the figure) |
(4) 830 mm (32.68 in) server depth, including chassis ears |
(5) 950 mm (37.40 in) between the front rack posts and the CMA |
(6) 860 mm (33.86 in) between the front rack posts and the rear ends of the slide rails |
For convenient maintenance and heat dissipation, make sure the following requirements are met:
· The passage for server transport is a minimum of 1500 mm (59.06 in) wide.
· A minimum clearance of 1200 mm (47.24 in) is reserved from the front of the rack to the front of another rack or row of racks.
· A minimum clearance of 800 mm (31.50 in) is reserved from the back of the rack to the rear of another rack or row of racks.
· A minimum clearance of 1000 mm (39.37 in) is reserved from the rack to any wall.
· The air intake and outlet vents of the server are not blocked.
· The front and rear rack doors are adequately ventilated to allow ambient room air to enter the cabinet and allow the warm air to escape from the cabinet.
· The air conditioner in the equipment room provides sufficient air flow for heat dissipation of devices in the room.
Figure 2 Airflow through the server
(1) to (8) Directions of the airflow into the chassis and power supplies |
(9) to (10) Directions of the airflow out of the chassis |
To ensure correct operation of the server, make sure the room temperature, humidity, and altitude meet the requirements as described in "Appendix C Environment requirements."
Cleanliness requirements
Mechanically active substances buildup on the chassis might result in electrostatic adsorption, which causes poor contact of metal components and contact points. In the worst case, electrostatic adsorption can cause communication failure.
Table 3 Mechanically active substance concentration limit in the equipment room
Substance |
Particle diameter |
Concentration limit |
Dust particles |
≥ 5 µm |
≤ 3 x 104 particles/m3 (No visible dust on desk in three days) |
Dust (suspension) |
≤ 75 µm |
≤ 0.2 mg/m3 |
Dust (sedimentation) |
75 µm to 150 µm |
≤ 1.5 mg/(m2h) |
Sand |
≥ 150 µm |
≤ 30 mg/m3 |
The equipment room must also meet limits on salts, acids, and sulfides to eliminate corrosion and premature aging of components, as shown in Table 4.
Table 4 Harmful gas limits in an equipment room
Gas |
Maximum concentration (mg/m3) |
SO2 |
0.2 |
H2S |
0.006 |
NO2 |
0.04 |
NH3 |
0.05 |
Cl2 |
0.01 |
Grounding requirements
Correctly connecting the server grounding cable is crucial to lightning protection, anti-interference, and ESD prevention. The server can be grounded through the grounding wire of the power supply system and no external grounding cable is required.
Installation tools
Table 5 lists the tools that you might use during installation.
Picture |
Name |
T25 Torx screwdriver |
For captive screws inside chassis ears. |
T30 Torx screwdriver (Electric screwdriver) |
For captive screws on processor heatsinks. |
T15 Torx screwdriver (shipped with the server) |
For replacing the management module. |
T10 Torx screwdriver (shipped with the server) |
For screws on PCIe modules. |
Flat-head screwdriver |
For replacing processors or the management module. |
Phillips screwdriver |
For screws on PCIe M.2 SSDs. |
Cage nut insertion/extraction tool |
For insertion and extraction of cage nuts in rack posts. |
Diagonal pliers |
For clipping insulating sleeves. |
Tape measure |
For distance measurement. |
Multimeter |
For resistance and voltage measurement. |
ESD wrist strap |
For ESD prevention when you operate the server. |
Antistatic gloves |
Antistatic clothing |
Ladder |
For high-place operations. |
Interface cable (such as an Ethernet cable or optical fiber) |
For connecting the server to an external network. |
Monitor (such as a PC) |
For displaying the output from the server. |
Installing the server
As a best practice, install hardware options to the server (if needed) before installing the server in the rack. For more information about how to install hardware options, see "Installing hardware options."
Install the chassis rails to the server and the slide rails to the rack. For information about installing the rails, see the installation guide shipped with the rails.
Rack-mounting the server
WARNING! To avoid bodily injury, slide the server into the rack with caution for the sliding rails might squeeze your fingers. |
1. Remove the screws from both sides of the server, as shown in Figure 3.
Figure 3 Removing the screws from both sides of the server
2. Remove the security bezel, if any. For more information, see "Replacing the security bezel."
3. (Optional.) Remove the compute modules if the server is too heavy for mounting. For more information, see "Removing a compute module."
4. Install the chassis handles. For more information, see the labels on the handles.
5. Lift the server and slide the server into the rack along the slide rails, as shown in Figure 4.
Remove the chassis handles as you slide the server into the rack. For more information, see the labels on the handles.
Figure 4 Rack-mounting the server
6. Secure the server, as shown in Figure 5:
a. Push the server until the chassis ears are flush against the rack front posts, as shown by callout 1.
b. Unlock the latches of the chassis ears, as shown by callout 2.
c. Fasten the captive screws inside the chassis ears and lock the latches, as shown by callout 3.
7. Install the removed compute modules. For more information, see "Installing a compute module."
CAUTION: To avoid errors such as drive identification failure, make sure each compute module is installed into the correct slot. You can view the compute module label pasted on the module's package to determine the correct slot. |
8. Install the removed security bezel. For more information, see "Installing the security bezel."
(Optional) Installing the CMA
Install the CMA if the server is shipped with the CMA. For information about how to install the CMA, see the installation guide shipped with the CMA.
Connecting external cables
Cabling guidelines
WARNING! To avoid electric shock, fire, or damage to the equipment, do not connect communication equipment to RJ-45 Ethernet ports on the server. |
· For heat dissipation, make sure no cables block the inlet or outlet air vents of the server.
· To easily identify ports and connect/disconnect cables, make sure the cables do not cross.
· Label the cables for easy identification of the cables.
· Wrap unused cables onto an appropriate position on the rack.
· To avoid damage to cables when extending the server out of the rack, do not route the cables too tight if you use the CMA.
The server provides a maximum of two VGA connectors for connecting a monitor.
· One on the front panel provided by the left chassis ear.
· One on the rear panel.
IMPORTANT! The two VGA connectors on the server cannot be used at the same time. |
The server does not provide ports for standard PS2 mouse and keyboard. To connect a PS2 mouse and keyboard, you must prepare a USB-to-PS2 adapter.
1. Connect one plug of a VGA cable to a VGA connector on the server, and fasten the screws on the plug.
Figure 6 Connecting a VGA cable
2. Connect the other plug of the VGA cable to the VGA connector on the monitor, and fasten the screws on the plug.
3. Connect the mouse and keyboard.
¡ For a USB mouse and keyboard, directly connect the USB connectors of the mouse and keyboard to the USB connectors on the server.
¡ For a PS2 mouse and keyboard, insert the USB connector of the USB-to-PS2 adapter to a USB connector on the server. Then, insert the PS2 connectors of the mouse and keyboard into the PS2 receptacles of the adapter.
Figure 7 Connecting a PS2 mouse and keyboard by using a USB-to-PS2 adapter
Connecting an Ethernet cable
Perform this task before you set up a network environment or log in to the HDM management interface through the HDM network port to manage the server.
Install an mLOM or PCIe Ethernet adapter. For more information, see "Installing Ethernet adapters."
1. Determine the network port on the server.
¡ To connect the server to the external network, use an Ethernet port on an Ethernet adapter.
¡ To log in to the HDM management interface, use the HDM dedicated network port or shared network port. For the position of the HDM network port, see "Rear panel view."
2. Determine the type of the Ethernet cable.
Verify the connectivity of the cable by using a link tester.
If you are replacing the Ethernet cable, make sure the new cable is of the same type with the old cable or compatible with the old cable.
3. Label the Ethernet cable by filling in the names and numbers of the server and the peer device on the label.
As a best practice, use labels of the same kind for all cables.
If you are replacing the Ethernet cable, label the new cable with the same number as the number of the old cable.
4. Connect one end of the Ethernet cable to the network port on the server and the other end to the peer device.
Figure 8 Connecting an Ethernet cable
5. Verify network connectivity.
After powering on the server, use the ping command to test the network connectivity. If the connection between the server and the peer device fails, make sure the Ethernet cable is correctly connected.
6. Secure the Ethernet cable. For information about how to secure cables, see "Securing cables."
Connecting a USB device
Perform this task before you install the operating system of the server or transmit data through a USB device.
The server provides six USB connectors.
· Five external USB connectors on the front and rear panels for connecting USB devices that are designed to be installed and removed very often:
¡ Two USB 2.0 connectors provided by the left chassis ear on the front panel.
¡ One USB 3.0 connector provided by the right chassis ear on the front panel.
¡ Two USB 3.0 connectors on the rear panel.
· One internal USB 3.0 connector for connecting USB devices that are not designed to be installed and removed very often.
Guidelines
Before connecting a USB device, make sure the USB device can operate correctly and then copy data to the USB device.
USB devices are hot swappable. However, to connect a USB device to the internal USB connector or remove a USB device from the internal USB connector, power off the server first.
As a best practice for compatibility, purchase H3C certified USB devices.
Connecting a USB device to the internal USB connector
1. Power off the server. For more information, see "Powering off the server."
2. Disconnect all the cables from the management module.
3. Remove the management module. For more information, see "Removing the management module."
4. Connect the USB device. For the location of the internal USB connector, see "Management module components."
5. Install the management module. For more information, see "Installing the management module."
6. Reconnect the removed cables to the management module.
7. Power on the server. For more information, see "Powering on the server."
8. Verify that the server can identify the USB device.
If the server fails to identify the USB device, download and install the driver of the USB device. If the server still fails to identify the USB device after the driver is installed, replace the USB device.
Connecting a USB device to an external USB connector
1. Connect the USB device.
2. Verify that the server can identify the USB device.
Connecting the power cord
Guidelines
WARNING! To avoid damage to the equipment or even bodily injury, use the power cord that ships with the server. |
Before connecting the power cord, make sure the server and components are installed correctly.
1. Insert the power cord plug into the power receptacle of a power supply at the rear panel, as shown in Figure 9.
Figure 9 Connecting the power cord
2. Connect the other end of the power cord to the power source, for example, the power strip on the rack.
3. Secure the power cord to avoid unexpected disconnection of the power cord.
a. (Optional.) If the cable clamp is positioned too near the power cord and blocks the power cord plug connection, press down the tab on the cable mount and slide the clamp backward.
Figure 10 Sliding the cable clamp backward
b. Open the cable clamp, place the power cord through the opening in the cable clamp, and then close the cable clamp, as shown by callouts 1, 2, 3, and 4 in Figure 11.
Figure 11 Securing the power cord
c. Slide the cable clamp forward until it is flush against the edge of the power cord plug, as shown in Figure 12.
Figure 12 Sliding the cable clamp forward
Securing cables
Securing cables to the CMA
For information about how to secure cables to the CMA, see the installation guide shipped with the CMA.
Securing cables to slide rails by using cable straps
You can secure cables to either left slide rails or right slide rails by using the cable straps provided with the server. As a best practice for cable management, secure cables to left slide rails.
When multiple cable straps are used in the same rack, stagger the strap location, so that the straps are adjacent to each other when viewed from top to bottom. This positioning will enable the slide rails to slide easily in and out of the rack.
To secure cables to slide rails by using cable straps:
1. Hold the cables against a slide rail.
2. Wrap the strap around the slide rail and loop the end of the cable strap through the buckle.
3. Dress the cable strap to ensure that the extra length and buckle part of the strap are facing outside of the slide rail.
Figure 13 Securing cables to a slide rail
1. Power down the server. For more information, see "Powering off the server."
2. Disconnect all peripheral cables from the server.
3. Extend the server from the rack, as shown in Figure 14.
a. Open the latches of the chassis ears.
b. Loosen the captive screws.
c. Slide the server out of the rack, during which install the chassis handles in sequence. For information about installing the chassis handles, see the labels on the handles.
Figure 14 Extending the server from the rack
4. Place the server on a clean, stable surface.
Important information
If the server is connected to external storage devices, make sure the server is the first device to power off and then the last device to power on. This restriction prevents the server from mistakenly identifying the external storage devices as faulty devices.
Before you power on the server, you must complete the following tasks:
· Install the server and internal components correctly.
· Connect the server to a power source.
Powering on the server by pressing the power on/standby button
Press the power on/standby button to power on the server.
The server exits standby mode and supplies power to the system. The system power LED changes from steady amber to flashing green and then to steady green. For information about the position of the system power LED, see "LEDs and buttons."
Powering on the server from the HDM Web interface
1. Log in to the HDM.
For information about how to log in to HDM, see the firmware update guide for the server.
2. In the navigation pane, select Power Manager > Power Control, and then power on the server.
For more information, see HDM online help.
Powering on the server from the remote console interface
1. Log in to HDM.
2. Log in to a remote console and then power on the server.
For information about how to log in to a remote console, see HDM online help.
Configuring automatic power-on
You can configure automatic power-on from HDM or the BIOS.
To configure automatic power-on from HDM:
1. Log in to HDM.
2. In the navigation pane, select Power Manager > Meter Power.
The meter power configuration page opens.
3. Click the Automatic power-on tab and then select Always power on.
4. Click Save.
To configure automatic power-on from the BIOS, set AC Restore Settings to Always Power On. For more information, see the BIOS user guide for the server.
Guidelines
Before powering off the server, you must complete the following tasks:
· Back up all critical data.
· Make sure all services have stopped or have been migrated to other servers.
Powering off the server from its operating system
1. Connect a monitor, mouse, and keyboard to the server.
2. Shut down the operating system of the server.
3. Disconnect all power cords from the server.
Powering off the server by pressing the power on/standby button
IMPORTANT: This method forces the server to enter standby mode without properly exiting applications and the operating system. If an application stops responding, you can use this method to force a shutdown. As a best practice, do not use this method when the applications and the operating system are operating correctly. |
1. Press and hold the power on/standby button until the system power LED turns into steady amber.
2. Disconnect all power cords from the server.
Powering off the server from the HDM Web interface
1. Log in to HDM.
2. In the navigation pane, select Power Manager > Power Control, and then power off the server.
Powering off the server from the remote console interface
1. Log in to HDM.
2. Log in to a remote console and then power off the server.
Configuring the server
The following information describes the procedures to configure the server after the server installation is complete.
1. Power on the server. For information about the procedures, see "Powering on the server."
2. Verify that the health LED on the front panel is steady green, which indicates that the system is operating correctly. For more information about the health LED status, see "LEDs and buttons."
Updating firmware
IMPORTANT: Verify the hardware and software compatibility before firmware update. For information about the hardware and software compatibility, see the software release notes. |
You can update the following firmware from FIST or HDM:
· HDM.
· BIOS.
· CPLD.
· PDBCPLD.
· NDCPLD.
For information about the update procedures, see the firmware update guide for the server.
For information about deploying UIS Manager, see H3C UIS Manager Installation Guide.
For information about registering the licenses of UIS Manager, see H3C UIS Manager 6.5 License Registration Guide.
If you are installing multiple hardware options, read their installation procedures and identify similar steps to streamline the entire installation procedure.
1. Press the right edge of the security bezel into the groove in the right chassis ear on the server, as shown by callout 1 in Figure 15.
2. Press the latch at the other end, close the security bezel, and then release the latch to secure the security bezel into place. See callouts 2 and 3 in Figure 15.
3. Insert the key provided with the bezel into the lock on the bezel and lock the security bezel, as shown by callout 4 in Figure 15. Then, pull out the key and keep it safe.
CAUTION: To avoid damage to the lock, hold down the key while you are turning the key. |
Figure 15 Installing the security bezel
Installing SAS/SATA drives
Guidelines
The drives are hot swappable.
If you are using the drives to create a RAID, follow these restrictions and guidelines:
· To build a RAID (or logical drive) successfully, make sure all drives in the RAID are the same type (HDDs or SSDs) and have the same connector type (SAS or SATA).
· For efficient use of storage, use drives that have the same capacity to build a RAID. If the drives have different capacities, the lowest capacity is used across all drives in the RAID. Whether a drive with extra capacity can be used to build other RAIDs depends on the storage controller model. The following storage controllers do not allow the use of a drive for multiple RAIDs:
¡ RAID-LSI-9361-8i(1G)-A1-X.
¡ RAID-LSI-9361-8i(2G)-1-X.
¡ RAID-LSI-9460-8i(2G).
¡ RAID-LSI-9460-8i(4G).
¡ RAID-P460-B4.
¡ HBA-H460-B1.
· If the installed drive contains RAID information, you must clear the information before configuring RAIDs. For more information, see the storage controller user guide for the server.
1. Remove the security bezel, if any. For more information, see "Replacing the security bezel."
2. Press the latch on the drive blank inward with one hand, and pull the drive blank out of the slot, as shown in Figure 16.
Figure 16 Removing the drive blank
3. Install the drive:
a. Press the button on the drive panel to release the locking lever.
Figure 17 Releasing the locking lever
b. Insert the drive into the slot and push it gently until you cannot push it further.
c. Close the locking lever until it snaps into place.
Figure 18 Installing a drive
4. Install the security bezel. For more information, see "Installing the security bezel."
Verifying the installation
Use the following methods to verify that the drive is installed correctly:
· Verify the drive properties (including capacity) and state by using one of the following methods:
¡ Log in to HDM. For more information, see HDM online help.
¡ Access the BIOS. For more information, see the storage controller user guide for the server.
¡ Access the CLI or GUI of the server.
· Observe the drive LEDs to verify that the drive is operating correctly. For more information, see "Drive LEDs."
Installing NVMe drives
Guidelines
NVMe drives support hot insertion and managed hot removal.
Only one drive can be hot inserted at a time. To hot insert multiple NVMe drives, wait a minimum of 60 seconds for the previously installed NVMe drive to be identified before hot inserting another NVMe drive.
· Make sure the NVMe VROC module is installed before you create a RAID.
· For efficient use of storage, use drives that have the same capacity to build a RAID. If the drives have different capacities, the lowest capacity is used across all drives in the RAID. A drive with extra capacity cannot be used to build other RAIDs.
2. Remove the drive blank. For more information, see "Installing SAS/SATA drives."
3. Install the drive. For more information, see "Installing SAS/SATA drives."
4. Install the removed security bezel. For more information, see "Installing the security bezel."
· Access the CLI or GUI of the server to verify the drive properties (including capacity) and state.
Installing power supplies
Guidelines
CAUTION: To avoid hardware damage, do not use third-party power supplies. |
· The power supplies are hot swappable.
· The server provides four power supply slots. Before powering on the server, install two to achieve 1+1 redundancy, or install four power modules to achieve N+N redundancy.
· Make sure the installed power supplies are the same model. HDM will perform power supply consistency check and generate an alarm if the power supply models are different.
· Install power supplies in power supply slots 1 through 4 in sequence.
1. As shown in Figure 19, remove the power supply blank from the target power supply slot.
Figure 19 Removing the power supply blank
2. Align the power supply with the slot, making sure its fan is on the left.
3. Push the power supply into the slot until it snaps into place.
Figure 20 Installing a power supply
4. Connect the power cord. For more information, see "Connecting the power cord."
Use one of the following methods to verify that the power supply is installed correctly:
· Observe the power supply LED to verify that the power supply is operating correctly. For more information about the power supply LED, see LEDs in "Rear panel."
· Log in to HDM to verify that the power supply is operating correctly. For more information, see HDM online help.
Guidelines
· The server supports two compute modules: compute module 1 and compute module 2. For more information, see "Front panel."
· The server supports 24SFF and 8SFF compute modules. For more information, see "Front panel of a compute module."
The installation procedure is the same for 24SFF and 8SFF compute modules. This section uses an 8SFF compute module as an example.
To install a compute module:
1. Identify the installation location of the compute module. For more information about the installation location, see "Drive configurations and numbering."
2. Power off the server. For more information, see "Powering off the server."
3. Remove the security bezel, if any. For more information, see "Replacing the security bezel."
4. Press the latches at both ends of the compute module blank, and pull outward the blank, as shown in Figure 21.
Figure 21 Removing the compute module blank
5. Install the compute module:
a. Press the clips at both ends of the compute module inward to release the locking levers, as shown in Figure 22.
Figure 22 Releasing the locking levers
b. Push the module gently into the slot until you cannot push it further. Then, close the locking levers at both ends to secure the module in place, as shown in Figure 23.
CAUTION: To avoid module connector damage, do not use excessive force when pushing the module into the slot. |
Figure 23 Installing the compute module
6. Install the removed security bezel. For more information, see "Installing the security bezel."
7. Connect the power cord. For more information, see "Connecting the power cord."
8. Power on the server. For more information, see "Powering on the server."
Log in to HDM to verify that the compute module is operating correctly. For more information, see HDM online help.
Installing air baffles
For more information about air baffles available for the server, see "Air baffles."
3. Remove the compute module. For more information, see "Removing a compute module."
4. Remove the compute module access panel. For more information, see "Replacing a compute module access panel."
5. Remove the high mid air baffle. For more information, see "Replacing air baffles in a compute module."
6. Install the low mid air baffle or GPU module air baffle.
¡ To install the low mid air baffle, align the two pin holes with the guide pins on the processor socket and the cable clamp. Then, gently press down the air baffle onto the main board of the compute module, as shown in Figure 24.
Figure 24 Installing the low mid air baffle
¡ To install the GPU module air baffle, align the two pin holes with the guide pins (near the compute module front panel) in the compute module. Then, gently press down the air baffle onto the main board and push it forward until you cannot push it any further, as shown in Figure 25.
Figure 25 Installing the GPU module air baffle
7. Install a riser card and a PCIe module in the compute module. For more information, see "Installing a riser card and a PCIe module in a compute module."
8. Install the compute module access panel. For more information, see "Replacing a compute module access panel."
9. Install the compute module. For more information, see "Installing a compute module."
10. Install the removed security bezel. For more information, see "Installing the security bezel."
11. Connect the power cord. For more information, see "Connecting the power cord."
12. Power on the server. For more information, see "Powering on the server."
The GPU module air baffle hinders GPU module installation. Make sure GPU modules have been installed to the rear riser card before you install the GPU module air baffle.
To install the GPU module air baffle to a rear riser card:
2. Disconnect external cables from the riser card, if the cables hinder air baffle installation.
3. Remove the riser card. For more information, see "Replacing a riser card and PCIe module at the server rear."
4. Remove the riser card air baffle.
5. Install PCIe modules to the riser card. For more information, see "Installing riser cards and PCIe modules at the server rear."
6. If an installed PCIe module requires external cables, remove the air baffle panel closer to the PCIe module installation slot for the cables to pass through.
Figure 26 Removing an air baffle panel from the GPU module air baffle
7. Install the GPU module air baffle to the rear riser card. Tilt and insert the air baffle into the riser card, and then push the riser card until it snaps into place, as shown in Figure 27.
Figure 27 Installing the GPU module air baffle to the rear riser card
8. Install the rear riser card. For more information, see "Installing riser cards and PCIe modules at the server rear."
9. (Optional.) Connect external cables to the riser card.
10. Connect the power cord. For more information, see "Connecting the power cord."
11. Power on the server. For more information, see "Powering on the server."
The server provides two PCIe riser connectors and three PCIe riser bays. The three riser bays are at the server rear and each compute module provides one riser connector. For more information about the locations of the bays and connectors, see "Rear panel view" and "Main board components", respectively.
Guidelines
· You can install a small-sized PCIe module in a large-sized PCIe slot. For example, an LP PCIe module can be installed in an FHFL PCIe slot.
· A PCIe slot can supply power to the installed PCIe module if the maximum power consumption of the module does not exceed 75 W. If the maximum power consumption exceeds 75 W, a power cord is required.
· Make sure the number of installed PCIe modules requiring PCIe I/O resources does not exceed eleven. For more information about PCIe modules requiring PCIe I/O resources, see "PCIe modules."
· If a processor is faulty or absent, the corresponding PCIe slots are unavailable. For more information about processor and PCIe slot mapping relationship, see "Riser cards."
· For more information about riser card installation location, see Table 6.
Table 6 Riser card installation location
PCIe riser connector or bay |
Riser card name |
Available riser cards |
PCIe riser connector 0 (in a compute module) |
Riser card 0 |
· RS-FHHL-G3 · RS-GPU-R6900-G3 (available only for 8SFF compute modules) |
PCIe riser bay 1 (at the server rear) |
Riser card 1 |
· RS-4*FHHL-G3 · RS-6*FHHL-G3-1 |
PCIe riser bay 2 (at the server rear) |
Riser card 2 |
RS-6*FHHL-G3-2 |
PCIe riser bay 3 (at the server rear) |
Riser card 3 |
You can install an RS-GPU-R6900-G3 riser card only in an 8SFF compute module.
The installation method is the same for the RS-FHHL-G3 and RS-GPU-R6900-G3. This section uses the RS-FHHL-G3 as an example.
6. Install the low mid air baffle. For more information, see "Installing the low mid air baffle or GPU module air baffle to a compute module."
7. Install a PCIe module to the riser card:
a. Hold and rotate the latch upward to open it, as shown in Figure 28.
Figure 28 Opening the latch on the riser card
b. Insert the PCIe module into the slot along the guide rails and close the latch on the riser card, as shown in Figure 29.
Figure 29 Installing the PCIe module
c. Connect PCIe module cables, if any, to the PCIe module.
8. Install the riser card to the compute module, as shown in Figure 30:
a. Align the two pin holes on the riser card with the guide pins on the main board, and then insert the riser card in the PCIe riser connector.
b. Fasten the captive screws to secure the riser card to the main board.
Figure 30 Installing the riser card to the compute module
c. Connect PCIe module cables, if any, to the drive backplane.
9. Install the compute module access panel. For more information, see "Replacing a compute module access panel."
10. Install the compute module. For more information, see "Installing a compute module."
11. Install the removed security bezel. For more information, see "Installing the security bezel."
12. Connect the power cord. For more information, see "Connecting the power cord."
13. Power on the server. For more information, see "Powering on the server."
Log in to HDM to verify that the PCIe module on the riser card is operating correctly. For more information, see HDM online help.
The procedure is the same for installing RS-6*FHHL-G3-1 and RS-6*FHHL-G3-2 riser cards. This section uses the RS-6*FHHL-G3-1 riser card as an example.
2. Remove the riser card blank. As shown in Figure 31, hold the riser card blank with your fingers reaching into the holes on the blank and pull the blank out.
Figure 31 Removing the rear riser card blank
3. Install the PCIe module to the riser card:
a. Remove the riser card air baffle, if the PCIe module to be installed needs to connect cables. For more information, see "Replacing a riser card air baffle."
b. Open the riser card cover. As shown by callouts 1 and 2 in Figure 32, pressing the two locking tabs on the riser card cover, rotate the cover outward.
c. Pull the PCIe module blank out of the slot, as shown by callout 3.
Figure 32 Removing the PCIe module blank
d. Insert the PCIe module into the PCIe slot along the guide rails, and then close the riser card cover, as shown in Figure 33.
Figure 33 Installing a PCIe module to the riser card
e. Connect PCIe module cables, if any, to the PCIe module.
f. Install the removed riser card air baffle. For more information, see "Replacing a riser card air baffle."
4. Install the riser card to the server.
a. Unlock the riser card. As shown in Figure 34, rotate the latch on the riser card upward to release the ejector lever.
Figure 34 Unlocking the riser card
b. Install the riser card to the server. As shown in Figure 35, gently push the riser card into the bay until you cannot push it further, and then close the ejector lever to secure the riser card.
Figure 35 Installing the riser card to the server
5. Connect PCIe module cables, if any.
6. Connect the power cord. For more information, see "Connecting the power cord."
A power fail safeguard module provides a flash card and a supercapacitor. When a system power failure occurs, this supercapacitor can provide power for a minimum of 20 seconds. During this interval, the storage controller transfers data from DDR memory to the flash card, where the data remains indefinitely or until the controller retrieves the data.
Guidelines
Make sure the power fail safeguard module is compatible with its connected storage controller. For the compatibility matrix, see "Storage controllers."
The supercapacitor might have a low charge after the power fail safeguard module is installed or after the server is powered on. If the system displays that the supercapacitor has low charge, no action is required. The system will charge the supercapacitor automatically.
Install storage controllers only in PCIe slots on riser card 1.
You cannot install the HBA-H460-B1 or RAID-P460-B4 storage controller on a server installed with one of the following storage controllers:
· HBA-LSI-9300-8i-A1-X.
· HBA-LSI-9311-8i.
· HBA-LSI-9440-8i.
· RAID-LSI-9361-8i(1G)-A1-X.
· RAID-LSI-9361-8i(2G)-1-X.
· RAID-LSI-9460-8i(2G).
· RAID-LSI-9460-8i(4G).
· RAID-LSI-9460-16i(4G).
The procedure is the same for installing storage controllers of different models. This section uses the RAID-LSI-9361-8i(1G)-A1-X storage controller as an example.
To install a storage controller:
2. Disconnect external cables from the rear riser card if the cables hinder storage controller installation.
3. Remove riser card 1. For more information, see "Replacing a riser card and PCIe module at the server rear."
4. (Optional.) Install the flash card of the power fail safeguard module to the storage controller:
IMPORTANT: Skip this step if no power fail safeguard module is required or the storage controller has a built-in flash card. For information about storage controllers with a built-in flash card, see "Storage controllers." |
a. Install the two internal threaded studs supplied with the power fail safeguard module on the storage controller.
Figure 36 Installing the internal threaded studs
b. Use screws to secure the flash card on the storage controller.
Figure 37 Installing the flash card
5. Install the storage controller to the riser card:
a. (Optional.) Connect the flash card cable (P/N 0404A0VU) to the flash card.
Figure 38 Connecting the flash card cable to the flash card
b. Install the storage controller to the riser card. For more information, see "Installing riser cards and PCIe modules at the server rear."
c. (Optional.) Connect the flash card cable to the riser card. For more information, see "Connecting the flash card on a storage controller."
d. Connect the storage controller cable to the riser card. For more information see "Storage controller cabling in riser cards at the server rear."
e. Install the riser card air baffle. For more information, see "Replacing a riser card air baffle."
6. Install the riser card to the server. For more information, see "Installing riser cards and PCIe modules at the server rear."
7. (Optional.) Install the supercapacitor:
a. Remove the security bezel, if any. For more information, see "Replacing the security bezel."
b. Remove the corresponding compute module. For more information, see "Removing a compute module." For more information about the mapping relationship between PCIe slot and compute module, see "Riser cards."
c. Remove the compute module access panel. For more information, see "Replacing a compute module access panel."
d. Install the supercapacitor holder to the right air baffle. As shown in Figure 39, slide the holder gently until it snaps into place.
Figure 39 Installing the supercapacitor holder
e. Connect one end of the supercapacitor cable (P/N 0404A0VT) provided with the flash card to the supercapacitor cable, as shown in Figure 40.
Figure 40 Connecting the supercapacitor cable
f. Insert the cableless end of the supercapacitor into the holder. Pull a clip on the holder, insert the other end of the supercapacitor into the holder, and then release the clip, as shown in by callouts 1, 2, and 3 in Figure 41.
g. Connect the other end of the supercapacitor cable to supercapacitor connector 1 on the compute module main board, as shown by callout 4 in Figure 41.
Figure 41 Installing the supercapacitor and connecting the supercapacitor cable
h. Install the compute module access panel. For more information, see "Replacing a compute module access panel."
i. Install the compute module. For more information, see "Installing a compute module."
j. Install the removed security bezel. For more information, see "Installing the security bezel."
8. Connect the power cord. For more information, see "Connecting the power cord."
9. Power on the server. For more information, see "Powering on the server."
Log in to HDM to verify that the storage controller, flash card, and supercapacitor are operating correctly. For more information, see HDM online help.
Installing GPU modules
Guidelines
· A riser card is required when you install a GPU module.
· Make sure the number of installed GPU modules requiring PCIe I/O resources does not exceed eleven. For more information about GPU modules requiring PCIe I/O resources, see "GPU modules."
· The available GPU modules and installation positions vary by riser card model and position. For more information, see "GPU module and riser card compatibility."
· For heat dissipation purposes, if a 24SFF compute module and a GPU-P4-X or GPU-T4 GPU module are installed, do not install processors whose power exceeds 165 W. For more information about processor power, see "Processors."
Guidelines
You can install a GPU module only in an 8SFF compute module and an RS-GPU-R6900-G3 riser card is required for the installation.
For the GPU module to take effect, make sure processor 2 of the compute module is in position.
The procedure is the same for installing GPU modules GPU-P4-X, GPU-P40-X, GPU-T4, GPU-P100, GPU-V100, and GPU-V100-32G. This section uses the GPU-P100 as an example.
To install a GPU module in a compute module:
6. Install the GPU module air baffle to the compute module. For more information, see "Installing the low mid air baffle or GPU module air baffle to a compute module."
7. If the GPU module is dual-slot wide, attach the support bracket provided with the GPU module to the GPU module. As shown in Figure 42, align screw holes in the support bracket with the installation holes in the GPU module. Then, use screws to attach the support bracket to the GPU module.
Figure 42 Installing the GPU module support bracket
8. Install the GPU module and connect the GPU power cord:
a. Hold and rotate the latch upward to open it. For more information, see "Installing a riser card and a PCIe module in a compute module."
b. Connect the riser power end of the power cord (P/N 0404A0UC) to the riser card, as shown by callout 1 in Figure 43.
c. Insert the GPU module into PCIe slot 1 along the guide rails, as shown by callout 2 in Figure 43.
d. Connect the other end of the power cord to the GPU module and close the latch on the riser card, as shown by callouts 3 and 4 in Figure 43.
Figure 43 Installing a GPU module
9. Install the riser card on PCIe riser connector 0. Align the pin holes on the riser card with the guide pins on the main board, and place the riser card on the main board. Then, fasten the captive screws to secure the riser card into place, as shown in Figure 44.
Figure 44 Installing the riser card
10. Install the compute module access panel. For more information, see "Replacing a compute module access panel."
11. Install the compute module. For more information, see "Installing a compute module."
12. Install the removed security bezel. For more information, see "Installing the security bezel."
13. Connect the power cord. For more information, see "Connecting the power cord."
14. Power on the server. For more information, see "Powering on the server."
Guidelines
You can install GPU modules only to the riser card in riser bay 1 or 3.
To install only one GPU module to a rear riser card, install the GPU module in PCIe slot 2. To install two GPU modules to a rear riser card, install the GPU modules in PCIe slots 2 and 6.
The procedure is the same for GPU modules GPU-P4-X and GPU-T4. This section uses GPU module GPU-P4-X as an example.
2. Disconnect external cables from the riser card, if the cables hinder GPU module installation.
4. Install the GPU module to the riser card. For more information, see "Installing riser cards and PCIe modules at the server rear."
5. Install the GPU module air baffle to the riser card. For more information, see "Installing the GPU module air baffle to a rear riser card."
Guidelines
You can install an mLOM Ethernet adapter only in the mLOM Ethernet adapter connector on riser card 1. For more information about the connector location, see "Riser cards." When the mLOM Ethernet adapter is installed, PCIe slot 4 on riser card 1 becomes unavailable.
To install a PCIe Ethernet adapter that supports NCSI, install it in PCIe slot 3 on riser card 1. If you install the Ethernet adapter in another slot, NCSI does not take effect.
By default, port 1 on the mLOM Ethernet adapter acts as the HDM shared network port. If only a PCIe Ethernet adapter exists and the PCIe Ethernet adapter supports NCSI, port 1 on the PCIe Ethernet adapter acts as the HDM shared network port. You can configure another port on the PCIe Ethernet adapter as the HDM shared network port from the HDM Web interface. For more information, see HDM online help.
The procedure is the same for all mLOM Ethernet adapters. This section uses the NIC-GE-4P-360T-L3-M mLOM Ethernet adapter as an example.
2. Disconnect external cables from riser card 1, if the cables hinder mLOM Ethernet adapter installation.
4. Install the mLOM Ethernet adapter to the riser card:
a. Remove the screw from the mLOM Ethernet adapter slot and then remove the blank, as shown in Figure 45.
b. Open the riser card cover. For more information, see "Installing riser cards and PCIe modules at the server rear."
c. Remove the PCIe module in PCIe slot 4 on the riser card, if a PCIe module is installed. For more information, see "Replacing a riser card and PCIe module at the server rear."
Remove the PCIe module blank, if no PCIe module is installed. For more information, see "Installing riser cards and PCIe modules at the server rear."
d. Insert the mLOM Ethernet adapter into the slot along the guide rails, and fasten the screw to secure the Ethernet adapter into place, as shown in Figure 46. Then, close the riser card cover.
Figure 46 Installing an mLOM Ethernet adapter to the riser card
5. If you have removed the riser card air baffle, install the removed riser card air baffle. For more information, see "Replacing a riser card air baffle."
7. Connect network cables to the mLOM Ethernet adapter.
Log in to HDM to verify that the mLOM Ethernet adapter is operating correctly. For more information, see HDM online help.
2. Disconnect external cables from the target riser card if the cables hinder PCIe Ethernet adapter installation.
4. Install the PCIe Ethernet adapter to the riser card. For more information, see "Installing riser cards and PCIe modules."
5. (Optional.) If the PCIe Ethernet adapter supports NCSI, connect the NCSI cable from the PCIe Ethernet adapter to the NCSI connector on the riser card. For more information about the NCSI connector location, see "Riser cards." For more information about the cable connection method, see "Connecting the NCSI cable for a PCIe Ethernet adapter."
6. If you have removed the riser card air baffle, install the removed riser card air baffle. For more information, see "Replacing a riser card air baffle."
7. Install the riser card to the server. For more information, see "Installing riser cards and PCIe modules at the server rear."
8. Connect network cables to the PCIe Ethernet adapter.
9. Connect the power cord. For more information, see "Connecting the power cord."
10. Power on the server. For more information, see "Powering on the server."
Log in to HDM to verify that the PCIe Ethernet adapter is operating correctly. For more information, see HDM online help.
Installing PCIe M.2 SSDs
Guidelines
CAUTION: To avoid thermal damage to processors, do not install PCIe M.2 SSDs to a 24SFF compute module if an 8180, 8180M, 8168, 6154, 6146, 6144, or 6244 processor is installed in the compute module. |
An M.2 transfer module and a riser card are required to install PCIe M.2 SSDs.
To ensure high availability, install two PCIe M.2 SSDs of the same model.
You can install a maximum of two PCIe M.2 SSDs on an M.2 transfer module. The installation procedure is the same for the two SSDs.
7. Install the PCIe M.2 SSD to the M.2 transfer module:
a. Install the internal threaded stud supplied with the transfer module onto the transfer module, as shown in Figure 47.
Figure 47 Installing the internal threaded stud
b. Insert the connector of the SSD into the socket, and push down the other end of the SSD. Then, fasten the screw provided with the transfer module to secure the SSD into place, as shown in Figure 48.
Figure 48 Installing a PCIe M.2 SSD to the M.2 transfer module
8. Install the M.2 transfer module to the riser card. For more information, see "Installing a riser card and a PCIe module in a compute module."
9. Install the riser card to the compute module. For more information, see "Installing a riser card and a PCIe module in a compute module."
2. Disconnect external cables from the riser card, if any.
4. Install the PCIe M.2 SSD to the M.2 transfer module. For more information, see "Installing a PCIe M.2 SSD in a compute module."
5. Install the M.2 transfer module to the riser card. For more information, see "Installing riser cards and PCIe modules at the server rear."
7. Reconnect the external cables to the riser card.
Installing SD cards
Guidelines
To achieve 1+1 redundancy and avoid storage space waste, install two SD cards with the same capacity as a best practice.
4. Orient the SD card with its golden plating facing the dual SD card extended module and insert the SD card into the slot, as shown in Figure 49.
Figure 49 Installing an SD card
5. Installing the extended module to the management module. Align the two blue clips on the extended module with the bracket on the management module, and slowly insert the extended module downwards until it snaps into space, as shown in Figure 50.
Figure 50 Installing the dual SD card extended module
6. Install the management module. For more information, see "Installing the management module."
7. Reconnect the removed cables to the management module.
Guidelines
A riser card in a compute module is required when you install an NVMe SSD expander module.
An NVMe SSD expander module is required only when NVMe drives are installed. For configurations that require an NVMe expander module, see "Drive configurations and numbering."
The procedure is the same for installing a 4-port NVMe SSD expander module and an 8-port NVMe SSD expander module. This section uses a 4-port NVMe SSD expander module as an example.
To install an NVMe SSD expander module:
7. Connect the four NVMe data cables to the NVMe SSD expander module, as shown in Figure 51.
Make sure you connect the ports on the module with the correct NVMe data cable. For more information, see "Connecting drive cables."
Figure 51 Connecting an NVMe data cable to the NVMe SSD expander module
8. Install the NVMe SSD expander module to the compute module by using a riser card. For more information, see "Installing riser cards and PCIe modules."
9. Connect the NVMe data cables to the drive backplane. For more information, see "Connecting drive cables in compute modules."
Make sure you connect the ports on the drive backplane with the correct NVMe data cable. For more information, see "Connecting drive cables."
Installing the NVMe VROC module
1. Identify the NVMe VROC module connector on the management module. For more information, see "Management module components."
3. Disconnect all the cables from the management module.
4. Remove the management module. For more information, see "Removing the management module."
5. Insert the NVMe VROC module onto the NVMe VROC module connector on the management module, as shown in Figure 52.
Figure 52 Installing the NVMe VROC module
Installing a drive backplane
Guidelines
The installation locations of drive backplanes vary by drive configuration. For more information, see "Drive configurations and numbering."
When installing a 4SFF NVMe drive backplane, paste the stickers provided with the backplane over the drive number marks on the front panel of the corresponding compute module. This helps users identify NVMe drive bays. Make sure the numbers on the stickers correspond to the numbers on the front panel of the compute module. For more information about drive numbers, see "Drive configurations and numbering."
The procedure is the same for installing a 4SFF drive backplane and a 4SFF NVMe drive backplane. This section uses a 4SFF drive backplane as an example.
To install a 4SFF drive backplane:
5. Remove the air baffles that might hinder the installation in the compute module. For more information, see "Replacing air baffles in a compute module."
6. Install the drive backplane. Place the backplane against the slot and fasten the captive screw on the backplane, as shown in Figure 53.
Figure 53 Installing the 4SFF drive backplane
7. Connect cables to the drive backplane. For more information, see "Connecting drive cables in compute modules."
8. Install the removed air baffles. For more information, see "Replacing air baffles in a compute module."
10. Install drives. For more information, see "Installing SAS/SATA drives."
Installing a diagnostic panel
Guidelines
You can install a diagnostic panel in compute module 1.
Install the diagnostic panel in the last drive bay of drive cage bay 1 if drive cage bay 2 is not installed with a drive backplane. In any other conditions, install the diagnostic panel in the last drive bay of drive cage bay 2. For more information about the locations, see "Front panel view of a compute module."
Identify the diagnostic panel cable before you install the diagnostic panel. The P/N for the cable is 0404A0SP.
3. Remove the drive or blank in the slot for the installation. For more information about removing a drive, see "Replacing a SAS/SATA drive." For more information about removing a drive blank, see "Installing SAS/SATA drives."
4. Install the diagnostic panel:
a. Connect the diagnostic panel cable (P/N 0404A0SP), as shown in Figure 54.
Figure 54 Connecting the diagnostic panel cable
b. Push the diagnostic panel into the slot until it snaps into place, as shown in Figure 55.
Figure 55 Installing the diagnostic panel
5. Install the removed security bezel. For more information, see "Installing the security bezel."
Installing processors
Guidelines
· To avoid damage to the processors or main board, only H3C-authorized personnel and professional server engineers are allowed to install a processor.
· Make sure the processors are the same model if multiple processors are installed.
· The pins in the processor socket are very fragile. Make sure a processor socket cover is installed on an empty processor socket.
· To avoid ESD damage, put on an ESD wrist strap before performing this task, and make sure the wrist strap is reliably grounded.
· To ensure good ventilation of the processors, do not install any PCIe modules in a 24SFF compute module installed with 8180, 8180M, 8168, 6154, 6146, 6144, or 6244 processors.
· For the server to operate correctly, make sure processor 1 of compute module 1 is always in position.
· The server provides four processor sockets for processor installation. Identify the installation locations of processors as shown in Table 7.
Table 7 Process installation locations
Number of processors |
Installation locations |
1 |
Socket 1 of compute module 1. |
2 |
· For processors of model 5xxx, install a processor in socket 1 of compute module 1 and the other in socket 1 of compute module 2. · For processors of model 6xxx or 8xxx, install both processors in compute module 1. |
4 |
Install the processors in all sockets. |
· For the location of compute modules, see "Front panel view of the server." For the location of processor sockets, see "Main board components."
1. Back up all server data.
4. Remove the compute module. For more information, see "Removing a compute module."
5. Remove the compute module access panel. For more information, see "Replacing a compute module access panel."
6. Remove the air baffles that might hinder the installation in the compute module. For more information, see "Replacing air baffles in a compute module."
7. Install a processor onto the retaining bracket, as shown in Figure 56:
CAUTION: To avoid damage to the processor, always hold the processor by its edges. Never touch the gold contacts on the processor bottom. |
a. As shown by callout 1, align the small triangle on the processor with the alignment triangle in the retaining bracket, and align the guide pin on the bracket with the notch on the triangle side of the processor.
b. As shown by callout 2, lower the processor gently and make sure the guide pins on the opposite side of the bracket fit snugly into notches on the processor.
Figure 56 Installing a processor onto the retaining bracket
8. Install the retaining bracket onto the heatsink:
CAUTION: When you remove the protective cover over the heatsink, be careful not to touch the thermal grease on the heatsink. |
a. Lift the cover straight up until it is removed from the heatsink, as shown in Figure 57.
Figure 57 Removing the protective cover
b. Install the retaining bracket onto the heatsink. As shown in Figure 58, align the alignment triangle on the retaining bracket with the cut-off corner of the heatsink. Place the bracket on top of the heatsink, with the four corners of the bracket clicked into the four corners of the heatsink.
Figure 58 Installing the processor onto the heatsink
9. Remove the processor socket cover.
CAUTION: · Take adequate ESD preventive measures when you remove the processor socket cover. · Be careful not to touch the pins on the processor socket, which are very fragile. Damage to pins will incur main board replacement. · Keep the pins on the processor socket clean. Make sure the socket is free from dust and debris. |
Hold the cover by the notches on its two edges and lift it straight up and away from the socket. Put the cover away for future use.
Figure 59 Removing the processor socket cover
10. Install the retaining bracket and heatsink onto the server, as shown in Figure 60.
a. Place the heatsink on the processor socket. Make sure the alignment triangle on the retaining bracket and the pin holes in the heatsink are aligned with the cut-off corner and guide pins of the processor socket, respectively, as shown by callout 1.
b. Fasten the captive screws on the heatsink in the sequence shown by callouts 2 through 5.
CAUTION: Use an electric screwdriver and set the torque to 1.4 Nm (12 in-lbs) when fastening the screws. Failure to do so may result in poor contact of the processor and the main board or damage to the pins in the processor socket. |
Figure 60 Attaching the retaining bracket and heatsink to the processor socket
11. Install DIMMs. For more information, see "Installing DIMMs."
12. Install the removed air baffles. For more information, see "Replacing air baffles in a compute module."
13. Install the compute module access panel. For more information, see "Replacing a compute module access panel."
14. Install the compute module. For more information, see "Installing a compute module."
15. Install the removed security bezel. For more information, see "Installing the security bezel."
16. Connect the power cord. For more information, see "Connecting the power cord."
17. Power on the server. For more information, see "Powering on the server."
Log in to HDM to verify that the processor is operating correctly. For more information, see HDM online help.
Installing DIMMs
The server supports DCPMMs and DRAM DIMMs (both LRDIMM and RDIMM supported). Compared with DRAM DIMMs, DCPMMs provide larger capacity and can protect data from getting lost in case of unexpected system failures.
Both DCPMMs and DRAM DIMMs are referred to as DIMMs in this document, unless otherwise stated.
Guidelines
WARNING! The DIMMs are not hot swappable. |
You can install a maximum of 12 DIMMs for each processor, six DIMMs per memory controller. For more information, see "DIMM slots."
For a DIMM to operate at 2933 MHz, make sure the following conditions are met:
· Use Cascade Lake processors that support 2933 MHz data rate.
· Use DIMMs with a maximum of 2933 MHz data rate.
· Install only one DIMM per channel.
The supported DIMMs vary by processor model, as shown in Table 8.
Table 8 Supported DIMMs of a processor
Processor |
Supported DIMMs |
Skylake |
Only DRAM DIMMs. |
Cascade Lake |
· Only DRAM DIMMs. · Mixture of DCPMM and DRAM DIMMs. |
Jintide-C series |
Only DRAM DIMMs. |
Guidelines for installing only DRAM DIMMs
When you install only DRAM DIMMs, follow these restrictions and guidelines:
· Make sure all DRAM DIMMs installed on the server have the same specifications.
· Make sure the corresponding processor is present before powering on the server.
· Make sure the number of ranks per channel does not exceed eight.
· For the memory mode setting to take effect, make sure the following installation requirements are met when you install DRAM DIMMs for a processor:
Memory mode |
DIMM requirements |
Independent |
· If only one processor is present, see Figure 61. · If two processors of model 6xxx or 8xxx are present, see Figure 62. · If two processors of model 5xxx are present, see Figure 63. · If four processors are present, see Figure 64. |
Mirror Partial Mirror |
· A minimum of two DIMMs for a processor. · This mode does not support DIMM population schemes that are not recommended in Figure 61, Figure 62, Figure 63, and Figure 64. · If only one processor is present, see Figure 61. · If two processors of model 6xxx or 8xxx are present, see Figure 62. · If two processors of model 5xxx are present, see Figure 63. · If four processors are present, see Figure 64. |
Memory Rank Sparing |
· A minimum of 2 ranks per channel. · If only one processor is present, see Figure 61. · If two processors of model 6xxx or 8xxx are present, see Figure 62. · If two processors of model 5xxx are present, see Figure 63. · If four processors are present, see Figure 64. |
NOTE: If the DIMM configuration does not meet the requirements for the configured memory mode, the system uses the default memory mode (Independent mode). For more information about memory modes, see the BIOS user guide for the server. |
Figure 61 DIMM population schemes (one processor present)
Figure 62 DIMM population schemes (two processors of model 6xxx or 8xxx present)
Figure 63 DIMM population schemes (two processors of model 5xxx present)
Figure 64 DIMM population schemes (four processors present)
Guidelines for mixture installation of DCPMMs and DRAM DIMMs
When you install DRAM DIMMs and DCPMMs on the server, follow these restrictions and guidelines:
· Make sure the corresponding processors are present before powering on the server.
· Make sure all DRAM DIMMs have the same product code and all DCPMMs have the same product code.
· As a best practice to increase memory bandwidth, install DRAM and DCPMM DIMMs in different channels.
· A channel supports a maximum of one DCPMM.
· As a best practice, install DCPMMs symmetrically across the two memory processing units for a processor.
· To install both DRAM DIMM and DCPMM in a channel, install the DRAM DIMM in the white slot and the DCPMM in the black slot. To install only one DIMM in a channel, install the DIMM in the white slot if the DIMM is DCPMM.
5. Remove the riser card in the compute module, if any. For more information, see "Replacing the riser card and PCIe module in a compute module."
6. Disconnect the cable between the supercapacitor and the main board, if the supercapacitor is installed over the target DIMM slot.
7. Remove air baffles in the compute module. For more information, see "Replacing air baffles in a compute module."
8. Install a DIMM:
a. Identify the location of the DIMM slot.
Figure 65 DIMM slots numbering
b. Open the DIMM slot latches.
c. Align the notch on the DIMM with the connector key in the DIMM slot and press the DIMM into the socket until the latches lock the DIMM in place, as shown in Figure 66.
To avoid damage to the DIMM, do not use force to press the DIMM into the socket when you encounter resistance. Instead, re-align the notch with the connector key, and then reinsert the DIMM again.
9. Install the removed air baffles. For more information, see "Replacing air baffles in a compute module."
10. Reconnect the cable between the supercapacitor and the main board.
11. Install the removed riser card in the compute module. For more information, see "Installing a riser card and a PCIe module in a compute module."
12. Install the compute module access panel. For more information, see "Replacing a compute module access panel."
13. Install the compute module. For more information, see "Installing a compute module."
14. Install the removed security bezel. For more information, see "Installing the security bezel."
15. Connect the power cord. For more information, see "Connecting the power cord."
16. Power on the server. For more information, see "Powering on the server."
Use one of the following methods to verify that the memory size is correct:
· Access the GUI or CLI of the server:
¡ In the GUI of a windows OS, click the Start icon in the bottom left corner, enter msinfo32 in the search box, and then click the msinfo32 item.
¡ In the CLI of a Linux OS, execute the cat /proc/meminfo command.
· Log in to HDM. For more information, see HDM online help.
· Access the BIOS. For more information, see the BIOS user guide for the server.
If the memory size is incorrect, re-install or replace the DIMM.
NOTE: It is normal that the CLI or GUI of the server OS displays a smaller memory size than the actual size if the mirror or memory rank sparing memory mode is enabled. In this situation, you can verify the memory size from HDM. |
Installing and setting up a TCM or TPM
Installation and setup flowchart
Figure 67 TCM/TPM installation and setup flowchart
Installing a TCM or TPM
Guidelines
· Do not remove an installed TCM or TPM. Once installed, the module becomes a permanent part of the management module.
· When installing or replacing hardware, H3C service providers cannot enable the TCM or TPM or the encryption technology. For security reasons, only the customer can enable these features.
· When replacing the management module, do not remove the TCM or TPM from the management module. H3C will provide a TCM or TPM with the spare management module for management module, TCM, or TPM replacement.
· Any attempt to remove an installed TCM or TPM from the management module breaks or disfigures the TCM or TPM security rivet. Upon locating a broken or disfigured rivet on an installed TCP or TPM, administrators should consider the system compromised and take appropriate measures to ensure the integrity of the system data.
· H3C is not liable for blocked data access caused by improper use of the TCM or TPM. For more information, see the encryption technology feature documentation provided by the operating system.
The installation procedure is the same for a TPM and a TCM. The following information uses a TPM to show the procedure.
To install a TPM:
4. Install the TPM:
a. Press the TPM into the TPM connector on the management module, as shown in Figure 68.
b. Insert the rivet pin as shown by callout 1 in Figure 69.
c. Insert the security rivet into the hole in the rivet pin and press the security rivet until it is firmly seated, as shown by callout 2 in Figure 69.
Figure 69 Installing the security rivet
6. Reconnect the cables to the management module.
Enabling the TCM or TPM in the BIOS
By default, the TCM and TPM are enabled for a server. For more information about configuring the TCM or TPM from the BIOS, see the BIOS user guide for the server.
You can log in to HDM to verify that the TCM or TPM is operating correctly. For more information, see HDM online help.
Configuring encryption in the operating system
For more information about this task, see the encryption technology feature documentation that came with the operating system.
The recovery key/password is generated during BitLocker setup, and can be saved and printed after BitLocker is enabled. When using BitLocker, always retain the recovery key/password. The recovery key/password is required to enter Recovery Mode after BitLocker detects a possible compromise of system integrity or firmware or hardware change.
For security purposes, follow these guidelines when retaining the recovery key/password:
· Always store the recovery key/password in multiple locations.
· Always store copies of the recovery key/password away from the server.
· Do not save the recovery key/password on the encrypted hard drive.
For more information about Microsoft Windows BitLocker drive encryption, visit the Microsoft website at http://technet.microsoft.com/en-us/library/cc732774.aspx.
Replacing hardware options
If you are replacing multiple hardware options, read their replacement procedures and identify similar steps to streamline the entire replacement procedure.
1. Insert the key provided with the bezel into the lock on the bezel and unlock the security bezel, as shown by callout 1 in Figure 70.
2. Press the latch at the left end of the bezel, open the security bezel, and then release the latch, as shown by callouts 2 and 3 in Figure 70.
3. Pull the right edge of the security bezel out of the groove in the right chassis ear to remove the security bezel, as shown by callout 4 in Figure 70.
Figure 70 Removing the security bezel
4. Install a new security bezel. For more information, see "Installing the security bezel."
To configure RAID settings after the drive is replaced, see the storage controller user guide for the server.
2. Observe the drive LEDs to verify that the drive is not selected by the storage controller and is not performing a RAID migration or rebuilding. For more information about drive LEDs, see "Drive LEDs."
3. Remove the drive, as shown in Figure 71:
a. Press the button on the drive panel to release the locking lever, as shown by callout 1.
b. Hold the locking lever and pull the drive out of the slot, as shown by callout 2.
4. Install a new drive. For more information, see "Installing SAS/SATA drives."
5. Install the removed security bezel, if any. For more information, see "Installing the security bezel."
Verifying the replacement
For information about the verification, see "Installing SAS/SATA drives."
Replacing an NVMe drive
The drives support hot insertion and managed hot removal.
1. Identify the NVMe drive to be removed and perform managed hot removal for the drive. For more information about managed hot removal, see "Appendix D Managed hot removal of NVMe drives."
2. Remove the security bezel, if any. For more information, see "Replacing the security bezel."
3. Remove the drive. For more information, see "Replacing a SAS/SATA drive."
For information about the verification, see "Installing NVMe drives."
Replacing a compute module and its main board
WARNING! To avoid bodily injury from hot surfaces, allow the server and its internal modules to cool before touching them. |
CAUTION: To prevent electrostatic discharge, place the removed parts on an antistatic surface or in antistatic bags. |
3. Remove the compute module:
a. Press the clips at both ends of the compute module inward to release the locking levers.
Figure 72 Unlocking a compute module
b. As shown by callout 1 in Figure 73, press the locking levers downward to disengage the compute module from the midplane.
c. As shown by callout 2 in Figure 73, pull the compute module out of the server.
Figure 73 Removing a compute module
Removing the main board of a compute module
1. Remove the compute module. For more information, see "Removing a compute module."
2. Remove the components in the compute module:
a. Remove the drives. For more information, see "Replacing a SAS/SATA drive."
b. Remove the compute module access panel. For more information, see "Replacing a compute module access panel."
c. Disconnect all the cables from the main board.
d. Remove the riser card and PCIe module, if any. For more information, see "Replacing the riser card and PCIe module in a compute module."
e. Remove the air baffles. For more information, see "Replacing air baffles in a compute module."
f. Remove the DIMMs. For more information, see "Replacing a DIMM."
g. Remove the processors and heatsinks. For more information, see "Removing a processor."
h. Remove the drive backplanes. For more information, see "Replacing drive backplanes."
3. Remove the main board:
a. Remove the 16 screws on the main board, as shown in Figure 74.
Figure 74 Removing the screws on a main board
b. Lift the cable clamp and the riser card bracket from the main board, as shown by callouts 1 and 2 Figure 75.
c. Lift the main board slowly out of the compute module, as shown by callout 3 in Figure 75.
Figure 75 Removing the cable clamp, riser card bracket, and main board
Installing a compute module and its main board
1. Install the main board in the compute module:
a. Align the installation holes on the main board with the screw holes on the compute module, as shown by callout 1 in Figure 76. Then, place the main board slowly in the compute module.
b. Put the cable clamp and the riser card bracket onto the main board, as shown by callouts 2 and 3 in Figure 76. Make sure the installation holes on the cable clamp and the riser card bracket are aligned with the screw holes on the main board.
Figure 76 Installing the main board, cable clamp, and riser card bracket
c. Fasten the 16 screws on the main board, as shown in Figure 77.
Figure 77 Securing the screws on a main board
2. Install the components in the compute module:
a. Install drive backplanes. For more information, see "Installing a drive backplane."
b. Install processors and heatsinks. For more information, see "Installing processors."
c. Install DIMMs. For more information, see "Installing DIMMs."
d. Install air baffles in the compute module. For more information, see "Replacing air baffles in a compute module."
e. (Optional.) Installing the riser card and PCIe module. For more information, see "Installing a riser card and a PCIe module in a compute module."
f. Connect cables to the main board.
g. Install drives. For more information, see "Installing SAS/SATA drives."
Log in to HDM to verify that each component in the compute module is operating correctly and no alert is generated. For more information, see HDM online help.
Replacing access panels
CAUTION: To avoid thermal damage to the server, do not operate the server for long periods with the access panel open or uninstalled. |
The procedure is the same for 8SFF and 24SFF compute modules. This section uses an 8SFF compute module as an example.
To replace the access panel of a compute module:
1. Power off the server. For more information, see "Powering off the server."
4. Remove the compute module access panel as shown in Figure 78:
a. Pressing the locking tabs on both sides of the access panel, slide the access panel backward, as shown by callout 1.
b. Lift the access panel to remove it, as shown by callout 2.
Figure 78 Removing the access panel
5. Install a new compute module access panel, as shown in Figure 79:
a. Place the access panel on top of the compute module. Make sure the pegs inside the access panel are aligned with the grooves on both sides of the compute module.
b. Slide the access panel toward the front of the compute module until it snaps into place.
Figure 79 Installing a compute module access panel
6. Install the compute module. For more information, see "Installing a compute module."
7. Install the security bezel. For more information, see "Installing the security bezel."
Replacing the chassis access panel
To replace the chassis access panel:
2. Remove the server from the rack, if the space over the server is insufficient. For more information, see "Removing the server from a rack."
3. Remove the chassis access panel. The removal process is the same for the compute module access panel and chassis access panel. For more information, see "Replacing a compute module access panel."
4. Install a new access panel, as shown in Figure 80.
a. Place the access panel on top of the server, with the standouts on the inner side of the access panel aligned with the square holes at the server rear.
b. Slide the access panel toward the server front until it snaps into place.
Figure 80 Installing the chassis access panel
5. Rack-mount the server. For more information, see "Installing the server."
Replacing a power supply
If more than one operating power supply is present, you can replace a power supply without powering off the server.
2. Remove the power cord from the power supply, as shown in Figure 81:
a. Press the tab to disengage the ratchet from the tie mount, slide the cable clamp outward, and then release the tab, as shown by callouts 1 and 2.
b. Open the cable clamp and remove the power cord out of the clamp, as shown by callouts 3 and 4.
c. Unplug the power cord, as shown by callout 5.
Figure 81 Removing the power cord
3. Holding the power supply by its handle and pressing the retaining latch with your thumb, pull the power supply slowly out of the slot, as shown in Figure 82.
Figure 82 Removing the power supply
4. Install a new power supply. For more information, see "Installing power supplies."
Use the following methods to verify that the power supply has been replaced correctly:
· Observe the power supply LED to verify that the power supply LED is steady or flashing green. For more information about the power supply LED, see LEDs in "Rear panel."
· Log in to HDM to verify that the power supply status is correct. For more information, see HDM online help.
5. If you are to remove the low mid air baffle, remove the riser card. If you are to remove a left or right air baffle, remove the supercapacitor and the supercapacitor holder attached to the air baffle.
For information about removing a riser card, see "Replacing a riser card and a PCIe module." For information about removing a supercapacitor, see "Replacing the power fail safeguard module for a storage controller."
6. Remove air baffles in a compute module. Hold and lift the air baffle out of the compute module, as shown in Figure 83.
The removal procedure is the same for the high mid air baffle, low mid air baffle, and bilateral air baffles. The following figure uses the high mid air baffle for illustration.
Figure 83 Removing the high mid air baffle in a compute module
7. Install new air baffles:
¡ To install the high mid air baffle, place the air baffle in the compute module. Make sure the two pin holes on the air baffle align with the guide pins on the main board and the cable clamp, as shown in Figure 84.
Figure 84 Installing the high mid air baffle
¡ To install the low mid air baffle, see "Installing the low mid air baffle or GPU module air baffle to a compute module" for more information.
¡ To install a left or right air baffle, place the air baffle in the compute module, as shown in Figure 85, with the standouts on the air baffle aligned with the notches on the side of the compute module.
The installation procedure is the same for the bilateral air baffles. The following figure uses the right air baffle for illustration.
Figure 85 Installing the right air baffle
8. Install the removed riser cards, if any. For more information, see "Replacing a riser card and a PCIe module."
9. Install the removed supercapacitor and supercapacitor holder. For more information, see "Installing storage controllers and power fail safeguard modules."
Replacing the power supply air baffle
2. Remove the server if the space over the server is insufficient. For more information, see "Removing the server from a rack."
3. Remove the chassis access panel. For more information, see "Replacing the chassis access panel."
4. Remove the power supply air baffle. Hold the notches on the air baffle and lift the air baffle out of the chassis, as shown in Figure 86.
Figure 86 Removing the power supply air baffle
5. Install the power supply air baffle. Place the air baffle in the chassis, as shown in Figure 87. Make sure the four standouts on the air baffle are aligned with the notches on the chassis.
Figure 87 Installing the power supply air baffle
6. Install the chassis access panel. For more information, see "Replacing the chassis access panel."
7. Mount the server in a rack. For more information, see "Installing the server."
2. Disconnect external cables from the riser card at the server rear if the cables hinder air baffle replacement.
4. Remove the air baffle in the riser card. Squeeze the clips at both sides of the air baffle, and lift the air baffle out of the riser card, as shown in Figure 88.
Figure 88 Removing the riser card air baffle
5. Install a new air baffle. Squeeze the clips at both sides of the air baffle, place the air baffle into place, and release the clips, as shown in Figure 89.
Make sure the standouts at both ends of the air baffle are aligned with the notches inside the riser card.
Figure 89 Installing a riser card air baffle
6. Install the riser card. For more information, see "Installing riser cards and PCIe modules at the server rear."
5. Remove the riser card in the compute module:
a. Disconnect all PCIe cables from the riser card.
b. Loosen the captive screw on the riser card, and lift the riser card slowly out of the compute module, as shown in Figure 90.
Figure 90 Removing the RS-FHHL-G3 riser card
6. Hold and rotate the latch upward to unlock the riser card, and then pull the PCIe module out of the slot, as shown in Figure 91.
Figure 91 Removing a PCIe module
7. Install a new riser card and PCIe module. For more information, see "Installing riser cards and PCIe modules."
The procedure is the same for all the riser cards at the server rear. This section uses the RS-6*FHHL-G3-1 riser card as an example.
2. Disconnect external cables from the riser card, if the cables hinder riser card replacement.
3. Remove the riser card, as shown in Figure 92:
a. As shown by callout 1, press the latch upward to release the ejector lever on the riser card.
b. As shown by callout 2, rotate the ejector lever down to disengage the riser card from the midplane, and then pull the riser card out of the riser bay.
Figure 92 Removing the riser card
4. Remove the PCIe module in the rear riser card.
a. If the PCIe module has any cables, remove the riser card air baffle first. For more information, see "Replacing a riser card air baffle."
b. Disconnect the cable between the PCIe module and the riser card, if any.
c. Open the riser card cover. For more information, see "Installing riser cards and PCIe modules at the server rear."
d. Remove the screw on the PCIe module, if any. Then, pull the module out of the riser card, as shown in Figure 93.
Figure 93 Removing a PCIe module in the riser card
5. Install a new PCIe module to the riser card. For more information, see "Installing riser cards and PCIe modules at the server rear."
7. (Optional.) Connect external cables to the riser card.
Log in to HDM to verify that the PCIe module in the riser card is operating correctly. For more information, see HDM online help.
Replacing a storage controller
Guidelines
To replace the storage controller with a controller of a different model, reconfigure RAID after the replacement. For more information, see the storage controller user guide for the server.
To replace the storage controller with a controller of the same model, make sure the following configurations remain the same after replacement:
· Storage controller operating mode.
· Storage controller firmware version.
· BIOS boot mode.
· First boot option in Legacy mode.
For more information, see the storage controller user guide and the BIOS user guide for the server.
Preparing for replacement
To replace the storage controller with a controller of the same model, identify the following information before the replacement:
· Storage controller location and cabling.
· Storage controller model, operating mode, and firmware version.
· BIOS boot mode.
To replace the storage controller with a controller of a different model, back up data in drives and then clear RAID information before the replacement.
The replacement procedure is the same for storage controllers of different models. This section uses the RAID-LSI-9361-8i(1G)-A1-X storage controller as an example.
To replace a storage controller:
2. Disconnect external cables from the riser card that holds the storage controller.
4. Disconnect cables from the storage controller.
5. Remove the storage controller. For more information, see "Replacing a riser card and PCIe module at the server rear."
6. Remove the power fail safeguard module as needed. For more information, see "Replacing the power fail safeguard module for a storage controller."
7. Install the removed power fail safeguard module to a new storage controller as needed. For more information, see "Replacing the power fail safeguard module for a storage controller."
8. Install the new storage controller. For more information, see "Installing storage controllers and power fail safeguard modules."
9. Install the riser card that holds the storage controller. For more information, see "Installing riser cards and PCIe modules at the server rear."
10. Connect the external cables to the riser card.
Log in to HDM to verify that the storage controller is in a correct state. For more information, see HDM online help.
CAUTION: To avoid server errors, do not replace the power fail safeguard module when a drive is performing RAID migration or rebuilding. The Fault/UID LED is off and the Present/Active LED is flashing green on a drive if the drive is performing migration or rebuilding. |
4. Disconnect cables that might hinder the replacement.
6. Remove the screws that secure the flash card on the storage controller, and then remove the flash card, as shown in Figure 94.
Figure 94 Removing the flash card on the storage controller
7. Remove the security bezel, if any. For more information, see "Replacing the security bezel."
8. Remove the compute module. For more information, see "Removing a compute module."
9. Remove the compute module access panel. For more information, see "Replacing a compute module access panel."
10. Remove the supercapacitor, as shown in Figure 95.
a. Disconnect the cable between the main board and the supercapacitor, as shown by callout 1.
b. Pull the clip on the supercapacitor holder, take the supercapacitor out of the holder, and then release the clip, as shown by callouts 2 and 3.
Figure 95 Removing the supercapacitor
11. Lift the retaining latch at the bottom of the supercapacitor holder, slide the holder to remove it, and then release the retaining latch, as shown in Figure 96.
Figure 96 Removing the supercapacitor holder
12. Install a new power fail safeguard module. For more information, see "Installing storage controllers and power fail safeguard modules."
Log in to HDM to verify that the flash card and the supercapacitor are in a correct state. For more information, see HDM online help.
Replacing a GPU module
Replacing the GPU module in a compute module
The replacement procedure is the same for the GPU-P40-X, GPU-P100, and GPU-V100 GPU modules. This section uses the GPU-P100 as an example.
To replace the GPU module in a compute module:
3. Remove the compute module. For more information, see "Removing a compute module."
4. Remove the compute module access panel. For more information, see "Replacing a compute module access panel."
5. Remove the riser card in the compute module. Loosen the captive screw on the riser card, and lift the riser card slowly out of the compute module, as shown in Figure 97.
Figure 97 Removing the riser card
6. Remove the GPU module from the riser card, as shown in Figure 98:
a. Hold and rotate the latch to the left to unlock the riser card, as shown by callout 1.
b. Disconnect the GPU power cord from the GPU module, as shown by callout 2.
c. Pull the GPU module out of the slot and then disconnect the GPU power cord from the riser card, as shown by callouts 3 and 4.
Figure 98 Removing a GPU module
7. Install a new GPU module. For more information, see "Installing a GPU module in a compute module."
Replacing a GPU module at the server rear
3. Remove the rear riser card and the GPU module. For more information, see "Replacing a riser card and PCIe module at the server rear."
4. Install a new GPU module to the riser card and install the riser card. For more information, see "Installing riser cards and PCIe modules at the server rear."
5. Reconnect the external cables to the riser card.
Replacing an Ethernet adapter
Replacing an mLOM Ethernet adapter
The procedure is the same for mLOM Ethernet adapters of different models. This section uses the NIC-GE-4P-360T-L3-M mLOM Ethernet adapter as an example.
2. Disconnect external cables from the riser card that holds the mLOM Ethernet adapter.
4. Remove the mLOM Ethernet adapter, as shown in Figure 99:
a. Open the riser card cover. For more information, see "Installing riser cards and PCIe modules at the server rear."
b. Remove the screw that secures the mLOM Ethernet adapter, and then pull the Ethernet adapter out of the slot, as shown in Figure 99.
Figure 99 Removing an mLOM Ethernet adapter
5. Install a new mLOM Ethernet adapter. For more information, see "Installing an mLOM Ethernet adapter."
Log in to HDM to verify that the mLOM Ethernet adapter is in a correct state. For more information, see HDM online help.
Replacing a PCIe Ethernet adapter
2. Disconnect external cables from the riser card that holds the PCIe Ethernet adapter.
3. Remove the riser card and the PCIe Ethernet adapter. For more information, see "Replacing a riser card and PCIe module at the server rear."
4. Install a new PCIe Ethernet adapter. For more information, see "Installing a PCIe Ethernet adapter."
5. If you have removed the riser card air baffle, install the removed riser card air baffle.. For more information, see "Replacing a riser card air baffle."
Log in to HDM to verify that the PCIe Ethernet adapter is in a correct state. For more information, see HDM online help.
Replacing an M.2 transfer module and a PCIe M.2 SSD
Replacing the M.2 transfer module and a PCIe M.2 SSD in a compute module
5. Remove the M.2 transfer module from the riser card. For more information, see "Replacing the riser card and PCIe module in a compute module."
6. Remove the PCIe M.2 SSD:
a. Remove the screw that secures the SSD on the transfer module. Tilt the SSD by the screw-side edge, and then pull the SSD out of the connector, as shown in Figure 100.
Figure 100 Removing a PCIe M.2 SSD
b. Remove the internal threaded stud on the transfer module, as shown in Figure 101.
Figure 101 Removing the internal threaded stud
7. Install a new M.2 transfer module and a new PCIe M.2 SSD. For more information, see "Installing a PCIe M.2 SSD in a compute module."
8. Install the compute module access panel. For more information, see "Replacing a compute module access panel."
9. Install the compute module. For more information, see "Installing a compute module."
10. Install the removed security bezel. For more information, see "Installing the security bezel."
11. Connect the power cord. For more information, see "Connecting the power cord."
12. Power on the server. For more information, see "Powering on the server."
Replacing an M.2 transfer module and a PCIe M.2 SSD at the server rear
2. Disconnect external cables from the riser card that holds the M.2 transfer module.
3. Remove the riser card and the M.2 transfer module. For more information, see "Replacing a riser card and PCIe module at the server rear."
4. Remove the PCIe M.2 SSD. For more information, see "Replacing the M.2 transfer module and a PCIe M.2 SSD in a compute module."
5. Install a new M.2 transfer and a new PCIe M.2 SSD to the riser card. For more information, "Installing a PCIe M.2 SSD at the server rear."
Replacing an SD card
To replace an SD card:
2. Disconnect all the cables from the management module.
3. Remove the management module. For more information, see "Removing the management module."
4. Press the SD card to release it and then pull the SD card out of the slot, as shown in Figure 102.
Figure 102 Removing an SD card
5. Install a new SD card. For more information, see "Installing SD cards."
7. Reconnect the cables to the management module.
Replacing the dual SD card extended module
To replace the dual SD card extended module:
4. Press the clip on the dual SD card extended module, as shown by callout 1 in Figure 103. Pull the module out of the connector, and then release the clip.
Figure 103 Removing the dual SD card extended module
5. Remove the SD cards installed on the extended module, as shown in Figure 102.
6. Install a new dual SD card extended module to the management module and install the removed SD cards. For more information, see "Installing SD cards."
7. Install the management module. For more information, see "Installing the management module."
8. Reconnect the cables to the management module.
Replacing an NVMe SSD expander module
The procedure is the same for replacing a 4-port NVMe SSD expander module and an 8-port NVMe SSD expander module. This section uses a 4-port NVMe SSD expander module as an example.
To replace an NVMe SSD expander module:
5. Remove the NVMe SSD expander module:
a. Disconnect the expander module from the front drive backplanes by removing the cables from the front drive backplanes.
b. Remove the PCIe riser card that holds the NVMe SSD expander module. For more information, see "Replacing the riser card and PCIe module in a compute module."
c. Disconnect cables from the NVMe SSD expander module, as shown in Figure 104.
Figure 104 Disconnecting cables from an NVMe SSD expander module
6. Install a new NVMe SSD expander module. For more information, see "Installing an NVMe SSD expander module."
7. Install the compute module access panel. For more information, see "Replacing a compute module access panel."
8. Install the compute module. For more information, see "Installing a compute module."
9. Install the removed security bezel. For more information, see "Installing the security bezel."
10. Connect the power cord. For more information, see "Connecting the power cord."
11. Power on the server. For more information, see "Powering on the server."
Log in to HDM to verify that the NVMe expander module is in a correct state. For more information, see HDM online help.
Replacing the NVMe VROC module
To replace the NVMe VROC module:
4. Hold the ring part of the NVMe VROC module and pull the module out of the management module, as shown in Figure 105.
Figure 105 Removing the NVMe VROC module
5. Install a new NVMe VROC module. For more information, see "Installing the NVMe VROC module."
Replacing a fan module
The fan modules are hot swappable. If sufficient space is available for replacement, you can replace a fan module without powering off the server or removing the server from the rack. The following procedure is provided based on the assumption that no sufficient space is available for replacement.
2. Remove the server from the rack. For more information, see "Removing the server from a rack."
4. Pinch the latches on both sides of the fan module to pull the fan module out of the slot, as shown in Figure 106.
Figure 106 Removing a fan module
5. Install a new fan module. Insert the fan module into the slot, as shown in Figure 107.
Figure 107 Installing a fan module
7. Rack-mount the server. For more information, see "Rack-mounting the server."
Log in to HDM to verify that the fan module is in a correct state. For more information, see HDM online help.
Replacing a processor
Guidelines
· To avoid damage to a processor or a compute module main board, only H3C authorized or professional server engineers can install, replace, or remove a processor.
· Make sure the processors on the server are the same model.
· The pins in the processor sockets are very fragile and prone to damage. Make sure a processor socket cover is installed on an empty processor socket.
· For the server to operate correctly, make sure processor 1 of compute module 1 is in position. For more information about processor locations, see "Main board components."
To avoid ESD damage, wear an ESD wrist strap before performing this task, and make sure the wrist strap is reliably grounded.
5. Remove the riser card and PCIe module in the compute module, if they hinder processor replacement. For more information, see "Replacing the riser card and PCIe module in a compute module."
6. Remove air baffles that might hinder the replacement in the compute module. For more information, see "Replacing air baffles in a compute module."
7. Remove the processor heatsink, as shown in Figure 108:
CAUTION: Be careful not to touch the pins on the processor socket, which are very fragile. Damage to pins will incur main board replacement. |
a. Loosen the captive screws in the same sequence as shown by callouts 1 to 4.
b. Lift the heatsink slowly to remove it, as shown by callout 5.
Figure 108 Removing a processor heatsink
8. Remove the processor retaining bracket from the heatsink, as shown in Figure 109:
a. Insert a flat-head tool (such as a flat-head screwdriver) into the notch marked with TIM BREAKER to pry open the retaining bracket, as shown by callout 1.
b. Press the four clips in the four corners of the bracket to release the retaining bracket.
You must press the clip shown by callout 2 and its cater-cornered clip outward, and press the other two clips inward as shown by callout 3.
NOTE: Callouts 2 and 3 show the upside-down views of the retaining bracket and the heatsink. |
c. Lift the retaining bracket to remove it from the heatsink, as shown by callout 4.
Figure 109 Removing the processor retaining bracket
9. Separate the processor from the retaining bracket with one hand pushing down and the other hand tilting the processor, as shown in Figure 110.
Figure 110 Separating the processor from the retaining bracket
1. Install the processor onto the retaining bracket. For more information, see "Installing processors."
2. Smear thermal grease onto the processor:
a. Clean the processor and heatsink with isopropanol wipes. Allow the isopropanol to evaporate before continuing.
b. Use the thermal grease injector to inject 0.6 ml of thermal grease to the five dots on the processor, 0.12 ml for each dot, as shown in Figure 111.
Figure 111 Smearing thermal grease onto the processor
3. Install the retaining bracket onto the heatsink. For more information, see "Installing processors."
4. Install the heatsink onto the server. For more information, see "Installing processors."
5. Paste bar code label supplied with the processor over the original processor label on the heatsink.
IMPORTANT: This step is required for you to obtain H3C's processor servicing. |
6. Install the removed air baffles in the compute module. For more information, see "Replacing air baffles in a compute module."
7. Install the removed riser card and PCIe module in the compute module. For more information, see "Installing a riser card and a PCIe module in a compute module."
Log in to HDM to verify that the processor is in a correct state. For more information, see HDM online help.
Replacing a DIMM
5. Remove the riser card and PCIe module in the compute module. For more information, see "Replacing the riser card and PCIe module in a compute module."
6. Remove air baffles in the compute module. For more information, see "Replacing air baffles in a compute module."
7. Open the DIMM slot latches and pull the DIMM out of the slot, as shown in Figure 112.
8. Install a new DIMM. For more information, see "Installing DIMMs."
9. Install the removed air baffles in the compute module. For more information, see "Replacing air baffles in a compute module."
10. Install the removed riser card and PCIe module in the compute module. For more information, see "Installing a riser card and a PCIe module in a compute module."
11. Install the compute module access panel. For more information, see "Replacing a compute module access panel."
12. Install the compute module. For more information, see "Installing a compute module."
13. Install the removed security bezel. For more information, see "Installing the security bezel."
14. Connect the power cord. For more information, see "Connecting the power cord."
15. Power on the server. For more information, see "Powering on the server."
During server startup, you can access BIOS to configure the memory mode of the newly installed DIMM. For more information, see the BIOS user guide for the server.
For information about the verification method, see "Installing DIMMs."
Replacing the system battery
The server comes with a system battery (Panasonic BR2032) installed on the management module, which supplies power to the real-time clock and has a lifespan of 5 to 10 years. If the server no longer automatically displays the correct date and time, you might need to replace the battery. As a best practice, use the Panasonic BR2032 battery to replace the old one.
NOTE: The BIOS will restore to the default settings after the replacement. You must reconfigure the BIOS to have the desired settings, including the system date and time. For more information, see the BIOS user guide for the server. |
Removing the system battery
4. Pinch the system battery by its top edge and lift the battery out of the battery holder slowly, as shown in Figure 113.
Figure 113 Removing the system battery
NOTE: For environment protection purposes, dispose of the used-up system battery at a designated site. |
Installing the system battery
1. Insert the system battery into the system battery holder on the management module, as shown in Figure 114.
Figure 114 Installing the system battery
2. Install the management module. For more information, see "Installing the management module."
3. Connect cables to the management module.
6. Access the BIOS to reconfigure the system date and time. For more information, see the BIOS user guide for the server.
Verify that the system date and time is displayed correctly on HDM or the connector monitor.
The procedure is the same for 4SFF, 4SFF NVMe, and 24SFF drive backplanes. This section uses a 4SFF drive backplane as an example.
To replace the drive backplane:
4. Remove the drives attached to the backplane. For more information, see "Replacing a SAS/SATA drive."
6. Remove the air baffles that might hinder the replacement in the compute module. For more information, see "Replacing air baffles in a compute module."
7. Disconnect all the cables from the backplane.
8. Loosen the captive screw on the backplane, slowly lift the backplane, and then pull it out of the compute module, as shown in Figure 115.
Figure 115 Removing a 4SFF SAS/SATA drive backplane
9. Install a new drive backplane. For more information, see "Installing a drive backplane."
10. Reconnect the cables to the backplane. For more information, see "Connecting drive cables."
11. Install the removed air baffles in the compute module. For more information, see "Replacing air baffles in a compute module."
13. Install the removed drives. For more information, see "Installing SAS/SATA drives."
Replacing the management module
3. Loosen the captive screw on the ejector lever of the management module, rotate the ejector lever outward, and then pull the module out of the server, as shown in Figure 116.
Figure 116 Removing the management module
4. Remove the dual SD card extended module. For more information, see "Replacing an NVMe SSD expander module."
5. Remove the NVMe VROC module. For more information, see "Replacing the NVMe VROC module."
1. Install the NVMe VROC module. For more information, see "Installing the NVMe VROC module."
2. Install the dual SD card extended module. For more information, see "Installing SD cards."
3. Install the TPM or TCM. For more information, see "Installing and setting up a TCM or TPM."
4. Push the management module into the slot, rotate the ejector lever inward, and then fasten the captive screw on the ejector lever to secure the module into place, as shown in Figure 117.
Figure 117 Installing the management module
5. Reconnect the cables to the management module.
Replacing the PDB
Removing the PDB
4. Remove the power supply air baffle. For more information, see "Replacing the power supply air baffle."
5. Remove all fan modules. For more information, see "Replacing a fan module."
6. Remove all power supplies. For more information, see "Replacing a power supply."
7. Remove the management module. For more information, see "Removing the management module."
8. Remove the PDB:
a. Disconnect cables from the PDB, as shown in Figure 118.
Figure 118 Disconnecting cables from the PDB
b. Press the locking tabs on the PDB to release the ejector levers of the PDB, as shown in Figure 119.
c. Pull up the extension handles on the ejector levers. Hold the handles and rotate the ejector levers downward, as shown by callouts 1 and 2 in Figure 120.
d. Pull the PDB out of the slot, as shown by callout 3 in Figure 120.
Installing the PDB
1. Install a new PDB:
a. Unlock the PDB. For more information, see "Removing the PDB."
b. Push the PDB into the slot until you cannot push it further, as shown by callout 1 in Figure 121.
c. Close the ejector levers, as shown by callout 2 in Figure 121.
d. Connect cables to the PDB, as shown in Figure 122.
Figure 122 Connecting cables to the PDB
3. Install the removed power supplies. For more information, see "Installing power supplies."
4. Install the removed fan modules. For more information, see "Replacing a fan module."
5. Install the power supply air baffle. For more information, see "Replacing the power supply air baffle."
8. Connect the power cord. For more information, see "Connecting the power cord."
9. Power on the server. For more information, see "Powering on the server."
Replacing the midplane
Removing the midplane
3. Remove the security bezel, if any. For more information, see "Replacing the security bezel."
4. Remove compute modules. For more information, see "Removing a compute module."
5. Remove the chassis access panel. For more information, see "Replacing the chassis access panel."
6. Remove the power supply air baffle. For more information, see "Replacing the power supply air baffle."
7. Remove fan modules. For more information, see "Replacing a fan module."
8. Remove power supplies. For more information, see "Replacing a power supply."
9. Remove the management module. For more information, see "Removing the management module."
10. Remove the PDB. For more information, see "Removing the PDB."
11. Remove riser cards at the server rear. For more information, see "Replacing a riser card and PCIe module at the server rear."
12. Remove the midplane, as shown in Figure 123:
a. Remove the eight screws that secure the midplane to the server, as shown by callout 1.
b. Pull the midplane outward and lift the midplane out of the chassis, as shown by callout 2.
Figure 123 Removing the midplane
Installing the midplane
1. Install a midplane, as shown in Figure 124:
a. Insert the midplane into the server along the slide rails, and push the midplane toward the server front until you cannot push it further, as shown by callout 1.
b. Fasten the eight screws to secure the midplane into place, as shown by callout 2.
Figure 124 Installing the midplane
2. Install the removed riser cards at the server rear. For more information, see "Installing riser cards and PCIe modules at the server rear."
3. Install the PDB. For more information, see "Installing the PDB."
4. Install the management module. For more information, see "Installing the management module."
5. Install the removed power supplies. For more information, see "Installing power supplies."
6. Install the removed fan modules. For more information, see "Replacing a fan module."
7. Install the power supply air baffle. For more information, see "Replacing the power supply air baffle."
8. Install the chassis access panel. For more information, see "Replacing the chassis access panel."
9. Install the removed compute modules. For more information, see "Installing a compute module."
11. Rack-mount the server. For more information, see "Rack-mounting the server."
12. Connect external cables to the rear riser cards as needed.
13. Connect the power cord. For more information, see "Connecting the power cord."
14. Power on the server. For more information, see "Powering on the server."
Replacing the diagnostic panel
To replace the diagnostic panel:
3. Remove the diagnostic panel, as shown in Figure 125:
a. Press the release button on the diagnostic panel, as shown by callout 1. The diagnostic panel pops out.
b. Hold the diagnostic panel by its front edge to pull it out of the slot, as shown by callout 2.
Figure 125 Removing the diagnostic panel
4. Install a new diagnostic panel. For more information, see "Installing a diagnostic panel."
5. Install the removed security bezel. For more information, see "Replacing the security bezel."
Replacing chassis ears
The procedure is the same for the left and right chassis ears. This section uses the left chassis ear as an example.
To replace the left chassis ear:
7. Disconnect the front VGA and USB 2.0 cable from the PDB, and pull the cable out of the cable cutout as shown in Figure 126.
Figure 126 Removing the front VGA and USB 2.0 cable
8. Remove the screws that secure the left chassis ear, and then pull the chassis ear until it is removed, as shown in Figure 127.
Figure 127 Removing the left chassis ear
9. Install a new left chassis ear. Attach the left chassis ear to the left side of the server, and use screws to secure it into place.
10. Insert the front VGA and USB 2.0 cable into cable cutout in the chassis and connect the cable to the PDB.
11. Install the power supply air baffle. For more information, see "Replacing the power supply air baffle."
12. Install the chassis access panel. For more information, see "Replacing the chassis access panel."
13. Install the compute modules. For more information, see "Installing a compute module."
15. Rack-mount the server. For more information, see "Rack-mounting the server."
Replacing the TPM/TCM
To avoid system damage, do not remove the installed TPM/TCM.
If the installed TPM/TCM is faulty, remove the management module, and contact H3C Support for management module and TPM/TCM replacement.
Connecting internal cables
Properly route the internal cables and make sure they are not squeezed.
24SFF SAS/SATA drive cabling
Connect SAS port 1 on the 24SFF drive backplane to SAS port A1 on the main board and connect SAS port 2 to SAS port A2, as shown in Figure 128. For information about the main board layout, see "Main board components."
Figure 128 24SFF SAS/SATA drive backplane connected to the main board
(1) and (3) Power cords |
(2) AUX signal cable |
(4) and (5) SAS/SATA data cables |
8SFF SAS/SATA drive cabling
Figure 129 8SFF SAS/SATA drive backplane connected to the main board
(1) and (3) AUX signal cables |
(2) and (4) Power cords |
(5) SAS/SATA data cable 1 (for drive cage bay 2/4) |
(6) SAS/SATA data cable 2 (for drive cage bay 1/3) |
8SFF NVMe drive cabling
To install 8SFF NVMe drives, you must install an 8-port NVMe SSD expander module to riser card 0 in the compute module.
When connecting NVMe data cables, make sure you connect the corresponding peer ports with the correct NVMe data cable, as shown in Figure 130.
Figure 130 8SFF NVMe drive backplane connected to the main board
(1) and (5) AUX signal cables |
(2) and (6) Power cords |
(3) and (4) NVMe data cables |
NOTE: In the figure, A1 to A4 and B1 to B4 represent data ports NVMe A1 to NVMe A4 and data ports NVMe B1 to B4 on the NVMe SSD expander module. NVMe 1 to NVMe 4 represents the labels on NVMe data cables. |
Hybrid 4SFF SAS/SATA and 4SFF NVMe drive cabling
To install 4SFF NVMe drives, you must install a 4-port NVMe SSD expander module to riser card 0 in the compute module.
Connect 4SFF SAS/SATA drives to the main board and connect 4SFF NVMe drives to the 4-port NVMe SSD expander module. When connecting NVMe data cables, make sure you connect the corresponding peer ports with the correct NVMe data cable, as shown in Figure 131.
Figure 131 Hybrid 4SFF SAS/SATA and 4SFF NVMe drive cabling
(3) SATA data cable |
NOTE: In the figure, 1 to 4 represent data ports NVMe 1 to NVMe 4 on the NVMe SSD expander module. NVMe 1 to NVMe 4 represents the labels on NVMe data cables. |
Figure 132 4SFF SAS/SATA drive backplane connected to the main board
(1) AUX signal cable |
(2) Power cord |
(3) SAS/SATA data cable |
Figure 133 4SFF NVMe drive cabling
(1) NVMe data cables |
(5) Power cord |
Storage controller cabling in riser cards at the server rear
When connecting storage controller data cables, make sure you connect the corresponding peer ports with the correct storage controller data cable. Use Table 9 and Table 10 to determine the ports to be connected and the cable to use.
Table 9 Storage controller cabling method (for all storage controllers except for the RAID-LSI-9460-16i(4G))
Location of drives |
Location of the storage controller |
Storage controller data cable |
Riser card SAS port |
Cabling method |
Compute module 1 |
Slot 1, 2, or 3 |
SAS PORT A1/B1 |
SAS port A1 |
See Figure 134. |
SAS PORT A2/B2 |
SAS port A2 |
Compute module 2 |
Slot 4, 5, or 6 |
SAS PORT A1/B1 |
SAS port B1 |
See Figure 135. |
SAS PORT A2/B2 |
SAS port B2 |
Table 10 Storage controller cabling method (for the RAID-LSI-9460-16i(4G) storage controller)
Storage controller data connector |
Cabling method |
Any compute module |
Any slot |
C0 |
SAS PORT A1/B1 |
SAS port A1 |
See Figure 136 and Figure 137. |
C1 |
SAS PORT A2/B2 |
SAS port A2 |
C2 |
SAS PORT A1/B1 |
SAS port B1 |
C3 |
SAS PORT A2/B2 |
SAS port B2 |
Figure 134 Connecting the storage controller cable in slot 3 (for all storage controllers except for the RAID-LSI-9460-16i(4G))
Figure 135 Connecting the storage controller cable in slot 6 (for all storage controllers except for the RAID-LSI-9460-16i(4G))
Figure 136 Connecting the storage controller cables in slot 3 (for the RAID-LSI-9460-16i(4G))
Figure 137 Connecting the storage controller cables in slot 6 (for the RAID-LSI-9460-16i(4G))
Connecting the flash card on a storage controller
When connecting a flash card cable and a supercapacitor cable, make sure you connect the correct supercapacitor connectors in the riser card and on the main board. Use Table 11 to determine the method for flash card and supercapacitor cabling.
Table 11 Flash card and supercapacitor cabling method
Supercapacitor connector on the riser card |
Supercapacitor connector on the main board |
Slot 1, 2, or 3 |
Supercapacitor connector 1 (See Figure 138) |
Supercapacitor connector 1 in compute module 1 |
Slot 4, 5, or 6 |
Supercapacitor connector 2 (See Figure 139) |
Supercapacitor connector 1 in compute module 2 |
Figure 138 Connecting the flash card on a storage controller in slot 3
Figure 139 Connecting the flash card on a storage controller in slot 6
Connecting the GPU power cord
The method for connecting the GPU power cord is the same for different GPU models. This section uses the GPU-P100 as an example.
Figure 140 Connecting the GPU power cord
Connecting the NCSI cable for a PCIe Ethernet adapter
Figure 141 Connecting the NCSI cable for a PCIe Ethernet adapter
Connecting the front I/O component cable from the right chassis ear
Figure 142 Connecting the front I/O component cable
Connecting the cable for the front VGA and USB 2.0 connectors on the left chassis ear
Figure 143 Connecting the cable for the front VGA and USB 2.0 connectors on the left chassis ear
Maintenance
The following information describes the guidelines and tasks for daily server maintenance.
Guidelines
· Keep the equipment room clean and tidy. Remove unnecessary devices and objects from the equipment room.
· Make sure the temperature and humidity in the equipment room meet the server operating requirements.
· Regularly check the server from HDM for operating health issues.
· Keep the operating system and software up to date as required.
· Make a reliable backup plan:
¡ Back up data regularly.
¡ If data operations on the server are frequent, back up data as needed in shorter intervals than the regular backup interval.
¡ Check the backup data regularly for data corruption.
· Stock spare components on site in case replacements are needed. After a spare component is used, prepare a new one.
· Keep the network topology up to date to facilitate network troubleshooting.
Maintenance tools
The following are major tools for server maintenance:
· Hygrothermograph—Monitors the operating environment of the server.
· HDM, FIST, and iFIST—Monitors the operating status of the server.
Maintenance tasks
Observing LED status
Observe the LED status on the front and rear panels of the server to verify that the server modules are operating correctly. For more information about the status of the front and rear panel LEDs, see "Front panel" and "Rear panel."
Monitoring the temperature and humidity in the equipment room
Use a hygrothermograph to monitor the temperature and humidity in the equipment room.
The temperature and humidity in the equipment room must meet the server requirements described in "Environment requirements."
Examining cable connections
Verify that the cables and power cords are correctly connected.
Guidelines
· Do not use excessive force when connecting or disconnecting cables.
· Do not twist or stretch the cables.
· Organize the cables appropriately. Make sure components to be installed or replaced do not and will not touch any cables.
Checklist
· The cable type is correct.
· The cables are correctly and firmly connected and the cable length is appropriate.
· The cables are in good condition and are not twisted or corroded at the connection point.
Technical support
· Log and sensor information:
¡ Log information:
- Event logs.
- HDM audit logs and update logs.
- SDS logs.
- Diagnostics logs.
For information about how to collect log information, see HDM and iFIST online help.
¡ Sensor information.
To collect the sensor information, you must log in to the HDM Web interface. For more information, see HDM online help.
· Product serial number.
· Product model and name.
· Snapshots of error messages and descriptions.
· Hardware change history, including installation, replacement, insertion, and removal of hardware.
· Third-party software installed on the server.
· Operating system type and version.
Appendix A Server specifications
A UIS-Cell 6000 G3 system contains a server hardware platform, an HCI core, and a management platform called UIS Manager. The following information provides only specifications of the hardware platform.
NOTE: The information in this document might differ from your product if it contains custom configuration options or features. |
The servers come in the models listed in Table 12. These models support different drive configurations.
Model |
Maximum drive configuration |
48SFF |
48 SFF SAS/SATA drives. |
32SFF |
· 24 SFF SAS/SATA drives and 8 SFF NVMe drives. · 28 SFF SAS/SATA drives and 4 SFF NVMe drives. · 32 SFF SAS/SATA drives. |
16SFF |
· 4 SFF SAS/SATA drives and 12 SFF NVMe drives. · 8 SFF SAS/SATA drives and 8 SFF NVMe drives. · 12 SFF SAS/SATA drives and 4 SFF NVMe drives. · 16 SFF SAS/SATA drives. · 16 SFF NVMe drives. |
Technical specifications
Item |
48SFF |
32SFF |
16SFF |
Dimensions (H × W × D) |
· Without a security bezel and chassis ears: 174.8 × 444 × 807.4 mm (6.88 × 17.48 × 31.79 in) · With a security bezel: 174.8 × 444 × 829.7 mm (6.88 × 17.48 × 32.67 in) |
Max. weight |
67 kg (147.71 lb) |
Processors |
4 × Intel Purley processors (Up to 3.8 GHz base frequency, maximum 205 W power consumption, 38.5 MB L3 cache, and a maximum of 28 cores per processor) |
Memory |
A maximum of 48 DIMMs Supports mixture of DCPMMs and DRAM DIMMs |
Max storage |
· SATA drives: 184.32 TB |
· SAS drives: 76.8 TB · SATA drives: 122.88 TB · SAS + NVMe drives: 57.6 + 64 TB · SATA + NVMe drives: 92.16 + 64 TB |
· SAS drives: 38.4 TB · SATA drives: 61.44 TB · NVMe drives: 128 TB · SAS + NVMe drives: 9.6 + 96 TB · SATA + NVMe drives: 15.36 + 96 TB |
Chipset |
Intel C622 Lewisburg chipset |
· 6 × USB connectors: ¡ 4 × USB 3.0 connectors (one on the right chassis ear, two at the server rear, and one in the management module) ¡ 2 × USB 2.0 connectors (provided by the left chassis ear) · 8 × SATA connectors (4 connectors on the main board of each compute module)(The connectors must be used with storage controllers) · 1 × RJ-45 HDM dedicated port at the server rear · 2 × VGA connectors (one at the server rear and one at the server front) · 1 × BIOS serial port at the server rear |
Expansion slots |
· 20 × PCIe 3.0 slots · 1 × mLOM Ethernet adapter connector · 1 × dual SD card extended module connector |
Optical drives |
External USB optical drives |
Power supplies |
4 × hot-swappable power supplies, N + N redundancy 800 W, 800 W 336V high-voltage, 850 W high-efficiency Platinum, 800 W –48VDC, 1200 W, and 1600 W power supplies |
Standards |
CE EMC CE RoHS CCC FCC ICES-003 VCCI |
Components
Figure 145 Server components
Table 13 Server components
(1) Chassis access panel |
N/A |
(2) Power supply air baffle |
Provides ventilation aisles for power supplies. |
(3) Dual SD card extended module |
Provides two SD card slots. |
(4) System battery |
Supplies power to the system clock. |
(5) Management module |
Provides system management and monitoring features, and a management network port, a VGA connector, and USB connectors. |
(6) NVMe VROC module |
Works with Intel VMD to provide RAID capability for the server to virtualize storage resources of NVMe drives. |
(7) PDB |
Used for installing power supplies and the management module, and provides cable connectors for the front I/O component, and VGA and USB 2.0 connectors. |
(8) Midplane |
Provides data and power channels in the server. |
(9) Fan module |
Supports hot swapping. Fans in the fan modules support N+1 redundancy. |
(10) Power supply |
Supplies power to the server and supports hot swapping and N+N redundancy. |
(11) Riser card blank |
Installed on an empty PCIe riser bays to ensure good ventilation. |
(12) Rear riser card 2 |
Installed on PCIe riser bay 2 at the server rear. |
(13) Rear riser cards 1 or 3 |
Installed on PCIe riser bay 1 or 3 at the server rear. |
(14) Riser card air baffle |
Provides ventilation aisles for PCIe modules in riser cards at the server rear. |
(15) Chassis |
N/A |
(16) Chassis ears |
Attach the server to the rack. The right ear is integrated with the front I/O component, and the left ear is integrated with VGA and USB 2.0 connectors. The serial label pull tab on the left ear provides the HDM default login settings and document QR code. |
(17) LCD |
The LCD is not supported currently. Displays basic server information and operating status, and allows users to perform basic server settings. |
(18) Diagnostic panel |
Displays information about faulty components for quick diagnosis. |
(19) Drive |
Drive for data storage. |
(20) Drive backplane |
Provides power and data channels for drives. |
(21) Right air baffle |
Provides ventilation aisles for processor heatsinks and DIMMs, and an installation location for a supercapacitor. |
(22) Compute module and its main board |
Integrates all compute module parts and components. |
(23) Supercapacitor |
Supplies power to the flash card of the power fail safeguard module, which enables the storage controller to back up data to the flash card for protection when power outage occurs. |
(24) Supercapacitor holder |
Secures a supercapacitor in the chassis. |
(25) Memory |
Stores computing data and data exchanged with external storage. |
(26) Low mid air baffle |
Used in a compute module when the RS-FHHL-G3 riser card is installed to provide ventilation aisles for DIMMs. |
(27) Riser card 0 |
Installed on the PCIe riser connector in a compute module. |
(28) Processor |
Integrates a memory processing unit and a PCIe controller to provide data processing capabilities for the server. |
(29) Processor retaining bracket |
Attaches a processor to the heatsink. |
(30) Processor heatsink |
Cools the processor. |
(31) Compute module access panel |
N/A |
Front panel
Front panel view of the server
Figure 146, Figure 147, and Figure 148 show the front panel views of 48SFF, 32SFF, and 16SFF servers, respectively.
Figure 146 48SFF front panel
(1) Serial label pull tab module |
(2) USB 2.0 connectors |
(3) VGA connector |
(4) Compute module 1 |
(5) SAS/SATA drive or diagnostic panel (optional) |
(6) USB 3.0 connector |
(7) Compute module 2 |
Figure 147 32SFF front panel
(3) VGA connector |
(4) Drive cage bay 1 |
(5) Compute module 1 |
(6) Drive cage bay 2 |
(7) SAS/SATA drive, NVMe drive, or diagnostic panel (optional) |
(8) USB 3.0 connector |
(9) Compute module 2 |
(3) VGA connector |
(9) Drive cage bay 4 |
(10) Compute module 2 |
(11) Drive cage bay 3 |
Front panel view of a compute module
Figure 149 and Figure 150 show the front panel views of 24SFF and 8SFF compute modules, respectively.
Figure 149 24SFF compute module front panel
(1) 24SFF SAS/SATA drives |
(2) Diagnostic panel (optional) |
Figure 150 8SFF compute module front panel
(1) Drive cage bay 1/3 for 4SFF SAS/SATA or NVMe drives (optional) |
(3) Drive cage bay 2/4 for 4SFF SAS/SATA or NVMe drives (optional) |
(4) Diagnostic panel (optional) |
NOTE: Drive cage bays 1 and 2 are for compute module 1, and drive cage bays 3 and 4 are for compute module 2. |
LEDs and buttons
The LED and buttons are the same on all server models. Figure 151 shows the front panel LEDs and buttons. Table 14 describes the status of the front panel LEDs.
Figure 151 Front panel LEDs and buttons
(1) Power on/standby button and system power LED |
(2) UID button LED |
(3) Health LED |
(4) mLOM Ethernet adapter Ethernet port LED |
Table 14 LEDs and buttons on the front panel
Button/LED |
Status |
· Steady green—The system has started. · Flashing green (1 Hz)—The system is starting. · Steady amber—The system is in Standby state. · Off—No power is present. Possible reasons: ¡ No power source is connected. ¡ No power supplies are present. ¡ The installed power supplies are faulty. ¡ The system power LED is not connected correctly. |
UID button LED |
· Steady blue—UID LED is activated. The UID LED can be activated by using the following methods: ¡ Press the UID button LED. ¡ Activate the UID LED from HDM. · Flashing blue: ¡ 1 Hz—The firmware is being upgraded or the system is being managed from HDM. ¡ 4 Hz—HDM is restarting. To restart HDM, press the UID button LED for eight seconds. · Off—UID LED is not activated. |
Health LED |
· Steady green—The system is operating correctly. · Flashing green (4 Hz)—HDM is initializing. · Flashing amber (0.5 Hz)—A predictive alarm has occurred. · Flashing amber (1 Hz)—A general alarm has occurred. · Flashing red (1 Hz)—A severe alarm has occurred. If a system alarm is present, log in to HDM to obtain more information about the system running status. |
· Steady green—A link is present on the port. · Flashing green (1 Hz)—The port is receiving or sending data. · Off—No link is present on the port. |
Ports
Table 15 Ports on the front panel
Port |
Type |
USB connector |
USB 3.0/2.0 |
Connects the following devices: · USB flash drive. · USB keyboard or mouse. · USB optical drive for operating system installation. |
VGA connector |
DB-15 |
Connects a display terminal, such as a monitor or KVM device. |
Rear panel
Rear panel view
Figure 152 shows the rear panel view.
Figure 152 Rear panel components
(1) Power supply 1 |
(2) Power supply 2 |
(3) VGA connector |
(4) BIOS serial port |
(5) HDM dedicated network port (1 Gbps, RJ-45, default IP address 192.168.1.2/24) |
(6) USB 3.0 connectors |
(7) Power supply 3 |
(8) Power supply 4 |
(9) PCIe riser bay 3: · PCIe slots 1 through 3 (processor 2 in compute module 1) · PCIe slots 4 through 6 (processor 2 in compute module 2) |
(10) PCIe riser bay 2: · PCIe slot 1 (processor 2 in compute module 1) · PCIe slot 2 (processor 1 in compute module 1) · PCIe slots 3, 4, and 6 (processor 1 in compute module 2) · PCIe slot 5 (processor 2 in compute module 2) |
(11) PCIe riser bay 1: · PCIe slots 1 through 3 (processor 1 in compute module 1) · PCIe slots 4 through 6 (processor 1 in compute module 2) |
NOTE: · If a processor is not present, the corresponding PCIe slots are unavailable. · Some PCIe modules require PCIe I/O resources. Make sure the number of PCIe modules requiring PCIe I/O resources does not exceed eleven. For more information, see "PCIe modules." |
LEDs
Figure 153 shows the rear panel LEDs. Table 16 describes the status of the rear panel LEDs.
(1) Power supply LED for power supply 1 |
(2) Power supply LED for power supply 2 |
(3) UID LED |
(4) Link LED of the Ethernet port |
(5) Activity LED of the Ethernet port |
(6) Power supply LED for power supply 3 |
(7) Power supply LED for power supply 4 |
Table 16 LEDs on the rear panel
LED |
Status |
Power supply LED |
· Steady green—The power supply is operating correctly. · Flashing green (1 Hz)—Power is being input correctly but the system is not powered on. · Flashing green (0.33 Hz)—The power supply is in standby state and does not output power. · Flashing green (2 Hz)—The power supply is updating its firmware. · Steady amber—Either of the following conditions exists: ¡ The power supply is faulty. ¡ The power supply does not have power input, but another power supply has correct power input. · Flashing amber (1 Hz)—An alarm has occurred on the power supply. · Off—No power supplies have power input, which can be caused by an incorrect power cord connection or power source shutdown. |
UID LED |
· Steady blue—UID LED is activated. The UID LED can be activated by using the following methods: ¡ Press the UID button LED. ¡ Enable UID LED from HDM. · Flashing blue: ¡ 1 Hz—The firmware is being updated or the system is being managed by HDM. ¡ 4 Hz—HDM is restarting. To restart HDM, press the UID button LED for eight seconds. · Off—UID LED is not activated. |
· Steady green—A link is present on the port. · Off—No link is present on the port. |
· Flashing green (1 Hz)—The port is receiving or sending data. · Off—The port is not receiving or sending data. |
Ports
Table 17 Ports on the rear panel
Port |
Type |
HDM dedicated network port |
RJ-45 |
Establishes a network connection to manage HDM from its Web interface. |
USB connector |
USB 3.0 |
VGA connector |
DB-15 |
BIOS serial port |
RJ-45 |
The BIOS serial port is used for the following purposes: · Log in to the server when the remote network connection to the server has failed. · Establish a GSM modem or encryption lock connection. |
Power receptacle |
Standard single-phase |
Connects the power supply to the power source. |
Main board of a compute module
8SFF and 24SFF compute modules have the same main board layout.
Figure 154 Main board components
(1) SAS port B2 (×4 SAS ports) for PCIe riser bay 3 |
(2) SAS port B1 (×4 SAS ports) for PCIe riser bay 3 |
(3) Supercapacitor connector 2 for PCIe riser bay 3 |
(4) PCIe riser connector 0 for processor 2 |
(5) Supercapacitor connector 1 for PCIe riser bay 1 |
(6) SAS port A1 (×4 SAS ports) for PCIe riser bay 1 |
(7) SAS port A2 (×4 SAS ports) for PCIe riser bay 1 |
(8) LCD connector |
(10) Drive backplane AUX connector 1 |
(11) Drive backplane power connector 2 |
(12) Drive backplane AUX connector 2 |
For information about the supported PCIe riser cards and their installation locations, see "Riser cards."
DIMM slots
The server provides six DIMM channels per processor, 12 channels in total. Each channel contains one white-coded slot and one black-coded slot, as shown in Table 18.
Table 18 DIMM slot numbering and color-coding scheme
Processor |
DlMM slots |
Processor 1 |
A1 through A6 (white coded) A7 through A12 (black coded) |
Processor 2 |
B1 through B6 (white coded) B7 through B12 (black coded) |
8SFF and 24SFF compute modules have the same physical layout of the DIMM slots on the main board, as shown in Figure 155. For more information about the DIMM slot population rules, see the guidelines in "Installing DIMMs."
Figure 155 DIMM physical layout
Management module
Management module components
Figure 156 Management module components
(1) Dual SD card extended module slot |
(2) TPM/TCM connector |
(3) System maintenance switches |
(4) NVMe VROC module connector |
(5) System battery |
(6) Internal USB 3.0 connector |
Use the system maintenance switch if you forget HDM username, HDM password, or BIOS password, or need to restore default BIOS settings, as described in Table 19. To identify the location of the switch, see Figure 156.
Table 19 System maintenance switch
Item |
Remarks |
Switch 1 |
· OFF (default)—HDM login requires the username and password of a valid HDM user account. · ON—HDM login requires the default username and password. |
For security purposes, turn off the switch after you complete tasks with the default username and password as a best practice. |
Switch 5 |
· OFF (default)—Normal server startup. · ON—Restores the default BIOS settings. |
To restore the default BIOS settings, turn on the switch and then start the server. The default BIOS settings will be restored. Before the next server startup, power off the server and then turn off the switch to perform a normal server startup. |
Switch 6 |
· OFF (default)—Normal server startup. · ON—Clears all passwords from the BIOS at server startup. |
To clear all passwords from the BIOS, turn on the switch and then start the server. All the passwords will be cleared from the BIOS. Before the next server startup, turn off the switch to perform a normal server startup. |
Switches 2, 3, 4, 7, and 8 |
Reserved. |
N/A |
PDB
Figure 157 PDB components
(1) Front I/O connector |
(2) Front VGA and USB 2.0 connector |
Appendix B Component specifications
This appendix provides information about hardware options available for the server at the time of this writing. The hardware options available for the server are subject to change over time. For more information about hardware options supported by the server, visit the query tool at http://www.h3c.com/cn/home/qr/default.htm?id=367.
About component model names
The model name of a hardware option in this document might differ slightly from its model name label.
A model name label might add a prefix or suffix to the hardware-coded model name for purposes such as identifying the matching server brand or applicable region. For example, the DDR4-2666-8G-1Rx8-R memory model represents memory module labels including DDR4-2666-8G-1Rx8-R, DDR4-2666-8G-1Rx8-R-F, and DDR4-2666-8G-1Rx8-R-S, which have different suffixes.
Software compatibility
All the components are compatible with the following software versions:
· HDM-1.10.28P01 and later versions.
· BIOS-1.00.10P01 and later versions.
Processors
Table 20 SkyLake processors
Model |
Base frequency |
Power |
Number of cores |
Cache (L3) |
Supported max. data rate of DIMMs |
8180 |
2.5 GHz |
205 W |
28 |
38.50 MB |
2666 MHz |
8176 |
2.1 GHz |
165 W |
28 |
38.50 MB |
2666 MHz |
8170 |
2.1 GHz |
165 W |
26 |
35.75 MB |
2666 MHz |
8168 |
2.7 GHz |
205 W |
24 |
33.00 MB |
2666 MHz |
8164 |
2.0 GHz |
150 W |
26 |
35.75 MB |
2666 MHz |
8160 |
2.1 GHz |
150 W |
24 |
33.00 MB |
2666 MHz |
8158 |
3.0 GHz |
150 W |
12 |
25.00 MB |
2666 MHz |
8156 |
3.6 GHz |
105 W |
4 |
17.00 MB |
2666 MHz |
8153 |
2.0 GHz |
125 W |
16 |
22.00 MB |
2666 MHz |
6154 |
3.0 GHz |
200 W |
18 |
24.75 MB |
2666 MHz |
6152 |
2.1 GHz |
140 W |
22 |
30.25 MB |
2666 MHz |
6150 |
2.7 GHz |
165 W |
18 |
24.75 MB |
2666 MHz |
6148 |
2.4 GHz |
150 W |
20 |
27.50 MB |
2666 MHz |
6146 |
3.2 GHz |
165 W |
12 |
24.75 MB |
2666 MHz |
6144 |
3.5 GHz |
150 W |
8 |
24.75 MB |
2666 MHz |
6142 |
2.6 GHz |
150 W |
16 |
22.00 MB |
2666 MHz |
6140 |
2.3 GHz |
140 W |
18 |
24.75 MB |
2666 MHz |
6138 |
2.0 GHz |
125 W |
20 |
27.50 MB |
2666 MHz |
6136 |
3.0 GHz |
150 W |
12 |
24.75 MB |
2666 MHz |
6134 |
3.2 GHz |
130 W |
8 |
24.75 MB |
2666 MHz |
6132 |
2.6 GHz |
140 W |
14 |
19.25 MB |
2666 MHz |
6130 |
2.1 GHz |
125 W |
16 |
22.00 MB |
2666 MHz |
6128 |
3.4 GHz |
115 W |
6 |
19.25 MB |
2666 MHz |
6126 |
2.6 GHz |
125 W |
12 |
19.25 MB |
2666 MHz |
5122 |
3.6 GHz |
105 W |
4 |
16.50 MB |
2666 MHz |
5120 |
2.2 GHz |
105 W |
14 |
19.25 MB |
2400 MHz |
5118 |
2.3 GHz |
105 W |
12 |
16.5 MB |
2400 MHz |
5117 |
2.0 GHz |
105 W |
14 |
19.25 MB |
2400 MHz |
5115 |
2.4 GHz |
85 W |
10 |
13.75 MB |
2400 MHz |
8180M |
2.5 GHz |
205 W |
28 |
38.50 MB |
2666 MHz |
8176M |
2.1 GHz |
165 W |
28 |
38.50 MB |
2666 MHz |
8170M |
2.1 GHz |
165 W |
26 |
35.75 MB |
2666 MHz |
8160M |
2.1 GHz |
150 W |
24 |
33.00 MB |
2666 MHz |
6142M |
2.6 GHz |
150 W |
16 |
22.00 MB |
2666 MHz |
6140M |
2.3 GHz |
140 W |
18 |
24.75 MB |
2666 MHz |
6134M |
3.2 GHz |
130 W |
8 |
24.75 MB |
2666 MHz |
Table 21 Cascade Lake processors
Model |
Base frequency |
Power |
Number of cores |
Cache (L3) |
8276 |
2.2 GHz |
165 |
28 |
38.5 MB |
2933 MHz |
8260 |
2.4 GHz |
165 |
24 |
35.75 MB |
2933 MHz |
6252 |
2.1 GHz |
150 |
24 |
35.75 MB |
2933 MHz |
6248 |
2.5 GHz |
150 |
20 |
27.5 MB |
2933 MHz |
6244 |
3.6 GHz |
150 |
8 |
24.75 MB |
2933 MHz |
6242 |
2.8 GHz |
150 |
16 |
22 MB |
2933 MHz |
6230 |
2.1 GHz |
125 |
20 |
27.5 MB |
2933 MHz |
5220 |
2.2 GHz |
125 |
18 |
24.75 MB |
2666 MHz |
5218 |
2.3 GHz |
125 |
16 |
22 MB |
2666 MHz |
6240C |
2.6 GHz |
150 |
18 |
24.75 MB |
2933 MHz |
6246 |
3.3 GHz |
165 |
12 |
24.75 MB |
2933 MHz |
8253 |
2.2 GHz |
125 |
16 |
22 MB |
2933 MHz |
8268 |
2.9 GHz |
205 |
24 |
35.75 MB |
2900 MHz |
6234 |
3.3 GHz |
130 |
8 |
24.75 MB |
2933 MHz |
5222 |
3.8 GHz |
105 |
4 |
16.5 MB |
3800 MHz |
8280 |
2.7 GHz |
205 |
28 |
38.5 MB |
2700 MHz |
6238 |
2.1 GHz |
140 |
22 |
30.25 MB |
2933 MHz |
6254 |
3.1 GHz |
200 |
18 |
24.75 MB |
2933 MHz |
5215 |
2.5 GHz |
85 |
10 |
13.75 MB |
2666 MHz |
5217 |
3.0 GHz |
115 |
8 |
24.75 MB |
2667 MHz |
6226 |
2.7 GHz |
125 |
12 |
19.25 MB |
2933 MHz |
8276L |
2.2 GHz |
165 |
28 |
38.5 MB |
2700 MHz |
8255C |
2.5 GHz |
165 |
24 |
35.75 MB |
2933 MHz |
8276M |
2.2 GHz |
165 |
28 |
38.5 MB |
2200 MHz |
6254 |
3.1 GHz |
200 |
18 |
24.75 MB |
2933 MHz |
5218N |
2.3 GHz |
110 |
16 |
22 MB |
2666 MHz |
6230N |
2.3 GHz |
125 |
20 |
27.5 MB |
2933 MHz |
6262V |
1.9 GHz |
135 |
24 |
33 MB |
2400 MHz |
5215L |
2.5 GHz |
85 |
10 |
13.75 MB |
2666 MHz |
6222V |
1.8 GHz |
125 |
20 |
27.5 MB |
2400 MHz |
5215M |
2.5 GHz |
85 |
10 |
13.75 MB |
2666 MHz |
6240M |
2.6 GHz |
150 |
18 |
24.75 MB |
2933 MHz |
DIMMs
The server provides 6 DIMM channels per processor, 24 channels in total. Each DIMM channel has two DIMM slots and supports a maximum of eight ranks. For the physical layout of DIMM slots, see "DIMM slots."
DRAM specifications
Product code |
Model |
Type |
Capacity |
Data rate |
Rank |
0231A6SP |
DDR4-2666-16G-1Rx4-R |
RDIMM |
16 GB |
2666 MHz |
Single-rank |
0231A6SS |
DDR4-2666-32G-2Rx4-R |
RDIMM |
32 GB |
2666 MHz |
Dual-rank |
0231A8QJ |
DDR4-2666-64G-4Rx4-L |
LRDIMM |
64 GB |
2666 MHz |
Quad-rank |
0231AC4S |
DDR4-2933P-16G-1Rx4-R |
RDIMM |
16 GB |
2933 MHz |
Single-rank |
0231AC4V |
DDR4-2933P-16G-2Rx8-R |
RDIMM |
16 GB |
2933 MHz |
Dual-rank |
0231AC4T |
DDR4-2933P-32G-2Rx4-R |
RDIMM |
32 GB |
2933 MHz |
Dual-rank |
0231AC4N |
DDR4-2933P-64G-2Rx4-R |
RDIMM |
64 GB |
2933 MHz |
Dual-rank |
DCPMM specifications
Product code |
Model |
Type |
Capacity |
Data rate |
0231AC5R |
AP-128G-NMA1XBD128GQSE |
Apache Pass |
128 GB |
2666 MHz |
0231AC65 |
AP-512G-NMA1XBD512GQSE |
Apache Pass |
512 GB |
2666 MHz |
DRAM DIMM rank classification label
A DIMM rank is a set of memory chips that the system accesses while writing or reading from the memory. On a multi-rank DIMM, only one rank is accessible at a time.
To determine the rank classification of a DRAM DIMM, use the label attached to the DIMM, as shown in Figure 158.
Figure 158 DRAM DIMM rank classification label
Table 22 DIMM rank classification label description
Callout |
Remarks |
1 |
Capacity |
· 8GB. · 16GB. · 32GB. |
2 |
Number of ranks |
· 1R— One rank. · 2R—Two ranks. · 4R—Four ranks. · 8R—Eight ranks. |
3 |
Data width |
· ×4—4 bits. · ×8—8 bits. |
4 |
DIMM generation |
Only DDR4 is supported. |
5 |
Data rate |
· 2133P—2133 MHz. · 2400T—2400 MHz. · 2666V—2666 MHz. · 2933Y—2933 MHz. |
6 |
DIMM type |
· L—LRDIMM. · R—RDIMM. |
HDDs and SSDs
Drive specifications
SAS HDDs
Model |
Form factor |
Capacity |
Rate |
Rotating speed |
HDD-300G-SAS-12G-15K-SFF |
SFF |
300 GB |
12 Gbps |
15000 RPM |
HDD-300G-SAS-12G-10K-SFF-EP |
SFF |
300 GB |
12 Gbps |
10000 RPM |
HDD-600G-SAS-12G-15K-SFF-1 |
SFF |
600 GB |
12 Gbps |
15000 RPM |
HDD-900G-SAS-12G-10K-SFF |
SFF |
900 GB |
12 Gbps |
10000 RPM |
HDD-900G-SAS-12G-15K-SFF |
SFF |
900 GB |
12 Gbps |
15000 RPM |
HDD-1.2T-SAS-12G-10K-SFF |
SFF |
1.2 TB |
12 Gbps |
10000 RPM |
HDD-1.8T-SAS-12G-10K-SFF |
SFF |
1.8 TB |
12 Gbps |
10000 RPM |
HDD-2.4T-SAS-12G-10K-SFF |
SFF |
2.4 TB |
12 Gbps |
10000 RPM |
SATA HDDs
Model |
Form factor |
Capacity |
Rate |
Rotating speed |
HDD-1T-SATA-6G-7.2K-SFF-1 |
SFF |
1 TB |
6 Gbps |
7200 RPM |
HDD-2T-SATA-6G-7.2K-SFF |
SFF |
2 TB |
6 Gbps |
7200 RPM |
SATA SSDs
Model |
Vendor |
Form factor |
Capacity |
Rate |
SSD-240G-SATA-6G-EV-SFF-i-1 |
Intel |
SFF |
240 GB |
6 Gbps |
SSD-240G-SATA-6G-EM-SFF-i-2 |
Intel |
SFF |
240 GB |
6 Gbps |
SSD-480G-SATA-6G-EV-SFF-i-2 |
Intel |
SFF |
480 GB |
6 Gbps |
SSD-480G-SATA-6G-EM-SFF-i-3 |
Intel |
SFF |
480 GB |
6 Gbps |
SSD-480G-SATA-6G-SFF-EV-sa |
Intel |
SFF |
480 GB |
6 Gbps |
SSD-480G-SATA-6G-SFF-2 |
Micron |
SFF |
480 GB |
6 Gbps |
SSD-960G-SATA-6G-SFF-2 |
Micron |
SFF |
960 GB |
6 Gbps |
SSD-960G-SATA-6G-EM-SFF-i-2 |
Intel |
SFF |
960 GB |
6 Gbps |
SSD-960G-SATA-6G-EV-SFF-i |
Intel |
SFF |
960 GB |
6 Gbps |
SSD-960G-SATA-6G-EM-SFF-m |
Micron |
SFF |
960 GB |
6 Gbps |
SSD-1.92T-SATA-6G-EM-SFF-i-1 |
Intel |
SFF |
1.92 TB |
6 Gbps |
SSD-1.92T-SATA-6G-EV-SFF-i |
Intel |
SFF |
1.92 TB |
6 Gbps |
SSD-1.92T-SATA-6G-SFF-3 |
Micron |
SFF |
1.92 TB |
6 Gbps |
SSD-1.92T-SATA-6G-EM-SFF-m |
Micron |
SFF |
1.92 TB |
6 Gbps |
SSD-3.84T-SATA-6G-SFF |
Micron |
SFF |
3.84 TB |
6 Gbps |
SSD-3.84T-SATA-6G-EM-SFF-i |
Intel |
SFF |
3.84 TB |
6 Gbps |
SSD-3.84T-SATA-6G-EV-SFF-i |
Intel |
SFF |
3.84 TB |
6 Gbps |
SSD-480G-SATA-6G-EV-SFF-sa |
Samsung |
SFF |
480 GB |
6 Gbps |
SSD-960G-SATA-Ny1351-SFF-7 |
Seagate |
SFF |
960 GB |
6 Gbps |
SSD-480G-SATA-Ny1351-SFF-6 |
Seagate |
SFF |
480 GB |
6 Gbps |
SSD-960G-SATA-PM883-SFF |
Samsung |
SFF |
960 GB |
6 Gbps |
SSD-3.84T-SATA-PM883-SFF |
Samsung |
SFF |
3.84 TB |
6 Gbps |
SSD-1.92T-SATA-PM883-SFF |
Samsung |
SFF |
1.92 TB |
6 Gbps |
SAS SSDs
Model |
Vendor |
Form factor |
Capacity |
Rate |
SSD-3.2T-SAS3-SS530-SFF |
WD |
LFF |
3.2 TB |
12 Gbps |
SSD-400G-SAS3-SS530-SFF |
WD |
LFF |
400 GB |
12 Gbps |
SSD-800G-SAS3-SS530-SFF |
WD |
LFF |
800 GB |
12 Gbps |
SSD-1.6T-SAS3-SS530-SFF |
WD |
LFF |
1.6 TB |
12 Gbps |
NVMe SSDs
Model |
Vendor |
Form factor |
Capacity |
Rate |
SSD-375G-NVMe-SFF-i |
Intel |
SFF |
375 GB |
PCIe3.0 |
8 Gbps |
SSD-750G-NVMe-SFF-i |
Intel |
SFF |
750 GB |
PCIe3.0 |
8 Gbps |
SSD-1T-NVMe-SFF-i-1 |
Intel |
SFF |
1 TB |
PCIe3.0 |
8 Gbps |
SSD-1.6T-NVMe-EM-SFF-i |
Intel |
SFF |
1.6 TB |
PCIe3.0 |
8 Gbps |
SSD-2T-NVMe-SFF-i-1 |
Intel |
SFF |
2 TB |
PCIe3.0 |
8 Gbps |
SSD-3.2T-NVMe-EM-SFF-i |
Intel |
SFF |
3.2 TB |
PCIe3.0 |
8 Gbps |
SSD-4T-NVMe-SFF-i-2 |
Intel |
SFF |
4 TB |
PCIe3.0 |
8 Gbps |
SSD-6.4T-NVMe-EM-SFF-i |
Intel |
SFF |
6.4 TB |
PCIe3.0 |
8 Gbps |
SSD-7.68T-NVMe-EM-SFF-i |
Intel |
SFF |
7.68 TB |
PCIe3.0 |
8 Gbps |
SSD-8T-NVMe-SFF-i |
Intel |
SFF |
8 TB |
PCIe3.0 |
8 Gbps |
SSD-6.4T-NVMe-EM-SFF-mbl |
Memblaze |
SFF |
6.4 TB |
PCIe |
8 Gbps |
SSD-3.2T-NVMe-EM-SFF-mbl |
Memblaze |
SFF |
3.2 TB |
PCIe |
8 Gbps |
NVMe SSD PCIe accelerator modules
Model |
Form factor |
Capacity |
Rate |
Link width |
SSD-NVME-375G-P4800X |
HHHL |
375 GB |
PCIe |
8 Gbps |
×4 |
SSD-NVME-750G-P4800X |
HHHL |
750 GB |
PCIe |
8 Gbps |
×4 |
SSD-NVME-3.2T-PBlaze5 |
HHHL |
3.2 TB |
PCIe |
8 Gbps |
×8 |
SSD-NVME-6.4T-PBlaze5 |
HHHL |
6.4 TB |
PCIe |
8 Gbps |
×8 |
SSD-1.6T-NVME-PB516 |
HHHL |
1.6TB |
PCIe |
8 Gbps |
×8 |
Drive LEDs
The server supports SAS, SATA, and NVMe drives, of which SAS and SATA drives support hot swapping. You can use the LEDs on a drive to identify its status after it is connected to a storage controller.
Figure 159 shows the location of the LEDs on a drive.
(1) Fault/UID LED |
(2) Present/Active LED |
To identify the status of a SAS or SATA drive, use Table 23. To identify the status of an NVMe drive, use Table 24.
Table 23 SAS/SATA drive LED description
Fault/UID LED status |
Present/Active LED status |
Flashing amber (0.5 Hz) |
Steady green/Flashing green (4.0 Hz) |
A drive failure is predicted. As a best practice, replace the drive before it fails. |
Steady amber |
The drive is faulty. Replace the drive immediately. |
Steady blue |
The drive is operating correctly and is selected by the RAID controller. |
Off |
The drive is performing a RAID migration or rebuilding, or the system is reading or writing data to the drive. |
Off |
Steady green |
The drive is present but no data is being read or written to the drive. |
Off |
Off |
The drive is not securely installed. |
Table 24 NVMe drive LED description
Off |
The managed hot removal process is completed and the drive is ready for removal. |
Flashing amber (4 Hz) |
Off |
The drive is in hot insertion process. |
Steady amber |
Steady blue |
The drive is operating correctly and selected by the RAID controller. |
Off |
Off |
Steady green |
Off |
Off |
Drive configurations and numbering
The numbers of storage controllers in tables Table 25, Table 27, and Table 29 are applicable to all storage controllers.
48SFF server
Table 25 presents the drive configurations available for the 48SFF server and their compatible types of storage controllers and NVMe SSD expander modules. Table 26 shows drive population for the 48SFF server.
These drive configurations use the same drive numbering scheme, and drives with the same number are distinguished by the compute module they reside in, as shown in Figure 160.
Table 25 Drive, storage controller, and NVMe SSD expander configurations (48SFF server)
Drive configuration |
Storage controller |
NVMe SSD expander |
48SFF (48 SFF SAS/SATA drives) |
2 × storage controllers |
N/A |
48SFF (24 SFF SAS/SATA drives) |
1 × storage controller |
N/A |
Table 26 Drive population (48SFF server)
Compute module 1 |
Compute module 2 |
24 SFF SAS/SATA drives |
24SFF (24 SFF SAS/SATA drives) |
N/A |
NOTE: "N/A" indicates that the compute module is not required but a compute module blank must be installed. |
Figure 160 Drive numbering for 48SFF drive configurations (48SFF server)
NOTE: For the location of the compute modules, see "Front panel view of the server." |
32SFF server
Table 27 presents the drive configurations available for the 32SFF server and their compatible types of storage controllers and NVMe SSD expander modules. Table 28 shows drive population for the 32SFF server.
These drive configurations use the same drive numbering scheme, and drives with the same number are distinguished by the compute module they reside in, as shown in Figure 161.
Table 27 Drive, storage controller, and NVMe SSD expander configurations (32SFF server)
NVMe SSD expander |
32SFF (32 SFF SAS/SATA drives) |
N/A |
32SFF (28 SFF SAS/SATA drives and 4 SFF NVMe drives) |
1 × 4-port NVMe SSD expander module |
32SFF (24 SFF SAS/SATA drives and 8 SFF NVMe drives) |
1 × 8-port NVMe SSD expander module |
28SFF (28 SFF SAS/SATA drives) |
N/A |
28SFF (24 SFF SAS/SATA drives and 4 SFF NVMe drives) |
Table 28 Drive population (32SFF server)
Drive cage bay 1 in compute module 1 |
Drive cage bay 2 in compute module 1 |
Compute module 2 |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
NOTE: · To install 4 SFF SAS/SATA drives, a 4SFF SAS/SATA drive backplane is required. To install 4 SFF NVMe drives, a 4SFF NVMe drive backplane is required. · "/" indicates no drives are required but drive blanks must be installed. |
Figure 161 Drive numbering for the 32SFF configuration (32SFF server)
NOTE: For the location of the compute modules, see "Front panel view of the server." For the location of the drive cage bays, see "Front panel view of a compute module." |
16SFF server
Table 29 presents the drive configurations available for the 16SFF server and their compatible types of storage controllers and NVMe SSD expander modules. Table 30 shows drive population for the 16SFF server.
These drive configurations use the same drive numbering scheme, and drives with the same number are distinguished by the compute module they reside in, as shown in Figure 162.
Table 29 Drive, storage controller, and NVMe SSD expander configurations (16SFF server)
NVMe SSD expander |
16SFF (16 SFF SAS/SATA drives) |
N/A |
16SFF (12 SFF SAS/SATA drives and 4 SFF NVMe drives) |
16SFF (8 SFF SAS/SATA drives and 8 SFF NVMe drives) |
16SFF (4 SFF SAS/SATA drives and 12 SFF NVMe drives) |
· 1 × 4-port NVMe SSD expander module · 1 × 8-port NVMe SSD expander module |
16SFF (16 SFF NVMe drives) |
N/A |
2 × 8-port NVMe SSD expander modules |
12SFF (12 SFF SAS/SATA drives) |
N/A |
12SFF (8 SFF SAS/SATA drives and 4 SFF NVMe drives) |
12SFF (4 SFF SAS/SATA drives and 8 SFF NVMe drives) |
2 × 4-port NVMe SSD expander modules |
12SFF (12 SFF NVMe drives) |
N/A |
8SFF (8 SFF SAS/SATA drives) |
N/A |
8SFF (4 SFF SAS/SATA drives and 4 SFF NVMe drives) |
8SFF (8 SFF NVMe drives) |
N/A |
N/A |
4SFF (4 SFF SAS/SATA drives) |
N/A |
4SFF (4 SFF NVMe drives) |
N/A |
Table 30 Drive population (16SFF server)
Drive cage bay 3 in compute module 2 |
Drive cage bay 4 in compute module 2 |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
N/A |
4 SFF NVMe drives |
N/A |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
4 SFF NVMe drives |
N/A |
N/A |
4 SFF NVMe drives |
N/A |
NOTE: · To install 4 SFF SAS/SATA drives, a 4SFF SAS/SATA drive backplane is required. To install 4 SFF NVMe drives, a 4SFF NVMe drive backplane is required. · "/" indicates no drives are required but drive blanks must be installed. · "N/A" indicates that the compute module is not required but a compute module blank must be installed. |
Figure 162 Drive numbering for the 16SFF drive configuration (16SFF server)
PCIe modules
Typically, the PCIe modules are available in the following standard form factors:
· LP—Low profile.
· FHHL—Full height and half length.
· FHFL—Full height and full length.
· HHHL—Half height and half length.
· HHFL—Half height and full length.
Some PCIe modules require PCIe I/O resources. Make sure the number of such installed PCIe modules does not exceed eleven.
Storage controllers
For some storage controllers, you can order a power fail safeguard module to prevent data loss from power outages. This module provides a flash card and a supercapacitor. When a system power failure occurs, the supercapacitor provides power for a minimum of 20 seconds. During this interval, the storage controller can transfer data from DDR memory to the flash card, where the data remains indefinitely or until the controller retrieves the data. If the storage controller contains a built-in flash card, you can order only a supercapacitor.
The following storage controllers require PCIe I/O resources.
HBA-LSI-9300-8i-A1-X
Item |
Specifications |
Form factor |
LP |
Connectors |
One ×8 mini-SAS-HD connector |
Number of internal ports |
8 internal SAS ports (compatible with SATA) |
Drive interface |
12 Gbps SAS 3.0 or 6 Gbps SATA 3.0 |
PCIe interface |
PCIe3.0 ×8 |
RAID levels |
Not supported |
Built-in cache memory |
N/A |
Supported drives |
· SAS HDD · SAS SSD · SATA HDD · SATA SSD The controller supports a maximum of 24 drives. |
Power fail safeguard module |
Not supported |
Firmware upgrade |
Online upgrade |
HBA-LSI-9311-8i
Item |
Specifications |
Form factor |
LP |
Connectors |
Drive interface |
PCIe interface |
PCIe3.0 ×8 |
RAID levels |
0, 1, 10, 1E |
N/A |
Supported drives |
Not supported |
Firmware upgrade |
Online upgrade |
HBA-LSI-9440-8i
Item |
Specifications |
Form factor |
LP |
Connectors |
Drive interface |
PCIe interface |
PCIe3.1 ×8 |
RAID levels |
0, 1, 5, 10, 50 |
N/A |
Supported drives |
Not supported |
Firmware upgrade |
Online upgrade |
RAID-LSI-9361-8i(1G)-A1-X
Item |
Specifications |
Form factor |
LP |
Connectors |
Drive interface |
PCIe interface |
PCIe3.0 ×8 |
RAID levels |
0, 1, 5, 6, 10, 50, 60 |
1 GB internal cache module (DDR3-1866 MHz) |
Supported drives |
BAT-LSI-G2-4U-B-X The power fail safeguard module is optional. |
Built-in flash card |
Not supported |
Supercapacitor connector |
Not supported The supercapacitor connector is on the flash card of the power fail safeguard module. |
Firmware upgrade |
Online upgrade |
RAID-LSI-9361-8i(2G)-1-X
Item |
Specifications |
Form factor |
LP |
Connectors |
Drive interface |
PCIe interface |
PCIe3.0 ×8 |
RAID level |
2 GB internal cache module (DDR3-1866 MHz) |
Supported drives |
Not supported |
Firmware upgrade |
Online upgrade |
RAID-LSI-9460-8i(2G)
Item |
Specifications |
Form factor |
LP |
Connectors |
Drive interface |
PCIe interface |
PCIe3.1 ×8 |
RAID levels |
2 GB internal cache module (DDR4-2133 MHz) |
Supported drives |
BAT-LSI-G3-4U-B The power fail safeguard module is optional. |
Supported |
Supported |
Firmware upgrade |
Online upgrade |
RAID-LSI-9460-8i(4G)
Item |
Specifications |
Form factor |
LP |
Connectors |
Drive interface |
PCIe interface |
PCIe3.1 ×8 |
RAID levels |
4 GB internal cache module (DDR4-2133 MHz) |
Supported drives |
Supported |
Supported |
Firmware upgrade |
Online upgrade |
Model |
Specifications |
EX-4NVMe-B |
4-port NVMe SSD expander module, which supports a maximum of 4 NVMe SSD drives. |
EX-8NVMe-B |
8-port NVMe SSD expander module, which supports a maximum of 8 NVMe SSD drives. |
GPU modules
The GPU-V100 and GPU-V100-32G modules require PCIe I/O resources.
GPU-P40-X
Item |
Specifications |
PCIe interface |
PCIe3.0 ×16 |
Form factor |
FH3/4FL, dual-slot wide |
Maximum power consumption |
250 W |
Memory size |
24 GB GDDR5 |
Memory bus width |
384 bits |
Memory bandwidth |
346 GB/s |
Power connector |
Available |
GPU-T4
Item |
Specifications |
PCIe interface |
PCIe3.0 ×16 |
Form factor |
LP, single-slot wide |
70 W |
Memory size |
16 GB GDDR6 |
Memory bus width |
256 bits |
Memory bandwidth |
320 GB/s |
Power connector |
N/A |
GPU-V100
Item |
Specifications |
PCIe interface |
PCIe3.0 ×16 |
Form factor |
250 W |
Memory size |
16 GB HBM2 |
Memory bus width |
4096 bits |
Memory bandwidth |
900 GB/s |
Power connector |
Available |
GPU-V100-32G
Item |
Specifications |
PCIe interface |
PCIe3.0 ×16 |
Form factor |
250 W |
Memory size |
32 GB HBM2 |
Memory bus width |
4096 bits |
Memory bandwidth |
900 GB/s |
Power connector |
Available |
GPU module and riser card compatibility
Riser card |
PCIe riser connector or bay |
PCIe slot |
Available GPU modules |
RS-GPU-R6900-G3 |
Connector 0 in a compute module |
Slot 1 |
· GPU-P40-X · GPU-T4 · GPU-V100 · GPU-V100-32G |
RS-4*FHHL-G3 |
Bay 1 or 3 at the server rear |
Slot 2 |
GPU-T4 |
Slot 3 |
Not supported |
Slot 4 |
Not supported |
Slot 6 |
GPU-T4 |
PCIe Ethernet adapters
In addition to the PCIe Ethernet adapters, the server also supports mLOM Ethernet adapters (see "mLOM Ethernet adapters").
NIC-GE-4P-360T-B2-1-X, CNA-10GE-2P-560F-B2-1-X PCIe, NIC-X540-T2-T-10Gb-2P, NIC-XXV710-F-B-25Gb-2P, and NIC-957454A4540C-B-100G-1P Ethernet adapters require PCIe I/O resources.
Table 31 PCIe Ethernet adapter specifications
Model |
Form factor |
Ports |
Connector |
Data rate |
Bus type |
NCSI |
CNA-10GE-2P-560F-B2-1-X |
LP |
2 |
SFP+ |
10 Gbps |
PCIe2.0 ×8 |
Not supported |
CNA-560T-B2-10Gb-2P-1-X |
LP |
2 |
RJ45 |
10 Gbps |
PCIe3.0 ×4 |
Not supported |
IB-MCX354A-FCBT-56/40Gb-2P-X |
LP |
2 |
40/56 Gbps |
PCIe3.0 ×8 |
Not supported |
IB-MCX354A-FCBT-56/40Gb-2P-1 |
LP |
2 |
QSFP |
40/56 Gbps |
PCIe3.0 ×8 |
Not supported |
IB-MCX555A-ECAT-100Gb-1P-1 |
LP |
1 |
QSFP28 |
100 Gbps |
PCIe3.0 ×16 |
Not supported |
IB-MCX453A-FCAT-56/40Gb-1P-1 |
LP |
1 |
QSFP28 |
56 Gbps |
PCIe3.0 ×8 |
Not supported |
NIC-10GE-2P-520F-B2-1-X |
LP |
2 |
SFP+ |
10 Gbps |
PCIe3.0 ×8 |
Not supported |
NIC-10GE-2P-530F-B2-1-X |
LP |
2 |
SFP+ |
10 Gbps |
PCIe2.0 ×8 |
Not supported |
NIC-620F-B2-25Gb-2P-1-X |
LP |
2 |
SFP28 |
25 Gbps |
PCIe3.0 ×8 |
Supported |
NIC-957454A4540C-B-100G-1P |
LP |
1 |
QSFP28 |
100 Gbps |
PCIe3.0 ×16 |
Not supported |
NIC-BCM957302-F-B-10Gb-2P |
LP |
2 |
SFP+ |
10 Gbps |
PCIe3.0 ×8 |
Not supported |
NIC-BCM957414-F-B-25Gb-2P |
LP |
2 |
SFP28 |
25 Gbps |
PCIe3.0 ×8 |
Not supported |
NIC-BCM957416-T-B-10Gb-2P |
LP |
2 |
SFP+ |
10 Gbps |
PCIe3.0 ×8 |
Not supported |
NIC-CAVIUM-F-B-25Gb-2P |
LP |
2 |
SFP28 |
25 Gbps |
PCIe3.0 ×8 |
Not supported |
NIC-GE-4P-360T-B2-1-X |
LP |
4 |
RJ-45 |
10/100/1000 Mbps |
PCIe2.0 ×4 |
Not supported |
NIC-MCX4121A-F-B-10Gb-2P |
LP |
2 |
SFP28 |
10 Gbps |
PCIe3.0 ×8 |
Not supported |
NIC-MCX415A-F-B-100Gb-1P |
LP |
1 |
QSFP28 |
100 Gbps |
PCIe3.0 ×16 |
Not supported |
NIC-MCX4121A-F-B-25Gb-2P |
LP |
2 |
SFP28 |
25 Gbps |
PCIe3.0 ×8 |
Not supported |
NIC-X540-T2-T-10Gb-2P |
LP |
2 |
RJ-45 |
10 Gbps |
PCIe2.0 ×8 |
Not supported |
NIC-X710DA2-F-B-10Gb-2P-2 |
LP |
2 |
SFP+ |
10 Gbps |
PCIe3.0 ×8 |
Not supported |
NIC-X710DA4-F-B-10Gb-4P |
LP |
4 |
SFP+ |
10 Gbps |
PCIe3.0 ×8 |
Not supported |
NIC-XXV710-F-B-25Gb-2P |
LP |
2 |
SFP28 |
25 Gbps |
PCIe3.0 ×8 |
Not supported |
IB-MCX354A-FCBT-56Gb/40Gb-2P |
LP |
2 |
QSFP |
40/56 Gbps |
PCIe3.0 ×8 |
Not supported |
NIC-OPA-100Gb-1P |
LP |
1 |
QSFP28 |
100 Gbps |
PCIe3.0 ×16 |
Not supported |
FC HBAs
FC-HBA-QLE2560-8Gb-1P-1-X, FC-HBA-QLE2562-8Gb-2P-1-X, FC-HBA-QLE2690-16Gb-1P-1-X, and FC-HBA-QLE2692-16Gb-2P-1-X FC HBAs require PCIe I/O resources.
Item |
Specifications |
Form factor |
LP |
Ports |
1 |
Connector |
SFP+ |
Data rate |
8 Gbps |
Item |
Specifications |
Form factor |
LP |
Ports |
2 |
Connector |
SFP+ |
Data rate |
8 Gbps |
Item |
Specifications |
Form factor |
LP |
Ports |
1 |
Connector |
SFP+ |
Data rate |
16 Gbps |
Item |
Specifications |
Form factor |
LP |
Ports |
2 |
Connector |
SFP+ |
Data rate |
16 Gbps |
FC-HBA-QLE2740-32Gb-1P
Item |
Specifications |
Form factor |
LP |
Ports |
1 |
Connector |
SFP+ |
Data rate |
32 Gbps |
FC-HBA-QLE2742-32Gb-2P
Item |
Specifications |
Form factor |
LP |
Ports |
2 |
Connector |
SFP+ |
Data rate |
32 Gbps |
FC-HBA-LPe32000-32Gb-1P-X
Item |
Specifications |
Form factor |
LP |
Ports |
1 |
Connector |
SFP+ |
Data rate |
32 Gbps |
FC-HBA-LPe32002-32Gb-2P-X
Item |
Specifications |
Form factor |
LP |
Ports |
2 |
Connector |
SFP+ |
Data rate |
32 Gbps |
HBA-8Gb-LPe12000-1P-1-X
Item |
Specifications |
Form factor |
LP |
Ports |
1 |
Connector |
SFP+ |
Data rate |
8 Gbps |
HBA-8Gb-LPe12002-2P-1-X
Item |
Specifications |
Form factor |
LP |
Ports |
2 |
Connector |
SFP+ |
Data rate |
8 Gbps |
HBA-16Gb-LPe31000-1P-1-X
Item |
Specifications |
Form factor |
LP |
Ports |
1 |
Connector |
SFP+ |
Data rate |
16 Gbps |
HBA-16Gb-LPe31002-2P-1-X
Item |
Specifications |
Form factor |
LP |
Ports |
2 |
Connector |
SFP+ |
Data rate |
16 Gbps |
In addition to mLOM Ethernet adapters, the server also supports PCIe Ethernet adapters (see "PCIe Ethernet adapters").
By default, port 1 on an mLOM Ethernet adapter acts as an HDM shared network port.
NIC-GE-4P-360T-L3-M
Item |
Specifications |
Form factor |
LP |
Ports |
4 |
Connector |
RJ-45 |
Data rate |
1000 Mbps |
Bus type |
1000BASE-X ×4 |
NCSI |
Supported |
NIC-10GE-2P-560T-L2-M
Item |
Specifications |
Form factor |
LP |
Ports |
2 |
Connector |
RJ-45 |
Data rate |
1/10 Gbps |
Bus type |
10G-KR ×2 |
NCSI |
Supported |
NIC-10GE-2P-560F-L2-M
Item |
Specifications |
Form factor |
LP |
Ports |
2 |
Connector |
SFP+ |
Data rate |
10 Gbps |
Bus type |
10G-KR ×2 |
NCSI |
Supported |
Riser cards
The PCIe slots in a riser card are numbered differently depending on the riser card model and the PCIe riser connector or bay that holds the riser card.
Riser card guidelines
Each PCIe slot in a riser card can supply a maximum of 75 W power to the PCIe module. You must connect a separate power cord to the PCIe module if it requires more than 75 W power.
If a processor is faulty or absent, the corresponding PCIe slots are unavailable.
RS-FHHL-G3
Item |
Specifications |
PCIe riser connector |
PCIe slots |
Slot 1: PCIe3.0 ×16 (16, 8, 4, 2, 1) for processor 2 of the compute module NOTE: The numbers in parentheses represent link widths. |
Form factors of PCIe modules |
FHHL |
Maximum power supplied per PCIe slot |
75 W |
Figure 163 RS-FHHL-G3 riser card
(1) PCIe slot 1 |
(2) GPU module power connector |
RS-GPU-R6900-G3
Item |
Specifications |
PCIe slots |
FHHL NOTE: The riser card supports double-wide GPU modules. |
75 W |
Figure 164 RS-GPU-R6900-G3 riser card
(1) PCIe slot 1 |
RS-4*FHHL-G3
Item |
Specifications |
PCIe riser bay |
PCIe slots |
· PCIe riser bay 1: ¡ Slot 2: PCIe3.0 ×16 (8, 4, 2, 1) for processor 1 in compute module 1 ¡ Slot 3: PCIe3.0 ×8 (8, 4, 2, 1) for processor 1 in compute module 1 ¡ Slot 4: PCIe3.0 ×8 (8, 4, 2, 1) for processor 1 in compute module 2 ¡ Slot 6: PCIe3.0 ×16 (8, 4, 2, 1) for processor 1 in compute module 2 · PCIe riser bay 3: ¡ Slot 2: PCIe3.0 ×16 (8, 4, 2, 1) for processor 2 in compute module 1 ¡ Slot 3: PCIe3.0 ×8 (8, 4, 2, 1) for processor 2 in compute module 1 ¡ Slot 4: PCIe3.0 ×8 (8, 4, 2, 1) for processor 2 in compute module 2 ¡ Slot 6: PCIe3.0 ×16 (8, 4, 2, 1) for processor 2 in compute module 2 NOTE: The numbers in parentheses represent link widths. |
FHHL NOTE: Slots 2 and 6 of the riser card support single-wide GPU modules. |
75 W |
Figure 165 RS-4*FHHL-G3 riser card
(1) PCIe slot 2 |
(2) PCIe slot 3 |
(3) PCIe slot 4 |
(4) PCIe slot 6 |
(5) mLOM Ethernet adapter connector |
(6) Supercapacitor connector 2 |
(7) NCSI connector |
(8) SAS port B2 (×4 SAS ports) |
(9) SAS port B1 (×4 SAS ports) |
(10) SAS port A2 (×4 SAS ports) |
(11) SAS port A1 (×4 SAS ports) |
(12) Supercapacitor connector 1 |
NOTE: PCIe slot 4 is unavailable if an mLOM Ethernet adapter is installed. |
RS-6*FHHL-G3-1
Item |
Specifications |
PCIe riser bay |
PCIe slots |
· PCIe riser bay 1: ¡ Slots 1 through 3: PCIe3.0 ×8 (8, 4, 2, 1) for processor 1 in compute module 1 ¡ Slots 4 through 6: PCIe3.0 ×8 (8, 4, 2, 1) for processor 1 in compute module 2 · PCIe riser bay 3: ¡ Slots 1 through 3: PCIe3.0 ×8 (8, 4, 2, 1) for processor 2 in compute module 1 ¡ Slots 4 through 6: PCIe3.0 ×8 (8, 4, 2, 1) for processor 2 in compute module 2 NOTE: The numbers in parentheses represent link widths. |
FHHL |
75 W |
Figure 166 RS-6*FHHL-G3-1 riser card
(1) PCIe slot 1 |
(2) PCIe slot 2 |
(3) PCIe slot 3 |
(4) PCIe slot 4 |
(5) PCIe slot 5 |
(6) PCIe slot 6 |
(7) mLOM Ethernet adapter connector |
(8) Supercapacitor connector 2 |
(9) NCSI connector |
(10) SAS port B2 (×4 SAS ports) |
(11) SAS port B1 (×4 SAS ports) |
(12) SAS port A2 (×4 SAS ports) |
(13) SAS port A1 (×4 SAS ports) |
(14) Supercapacitor connector 1 |
RS-6*FHHL-G3-2
Item |
Specifications |
PCIe riser bay |
Bay 2 at the server rear |
PCIe slots |
· Slot 1: PCIe3.0 ×8 (8, 4, 2, 1) for processor 2 in compute module 1 · Slot 2: PCIe3.0 ×8 (8, 4, 2, 1) for processor 1 in compute module 1 · Slots 3, 4, and 6: PCIe3.0 ×8 (8, 4, 2, 1) for processor 1 in compute module 2 · Slot 5: PCIe3.0 ×8 (8, 4, 2, 1) for processor 2 in compute module 2 NOTE: The numbers in parentheses represent link widths. |
FHHL |
75 W |
Figure 167 RS-6*FHHL-G3-2 riser card
(1) PCIe slot 1 |
(2) PCIe slot 2 |
(3) PCIe slot 3 |
(4) PCIe slot 4 |
(5) PCIe slot 5 |
(6) PCIe slot 6 |
Riser card and system board port mapping relationship
Riser card name |
Ports on the riser card |
Corresponding ports on the system board |
Riser card 0 |
N/A |
N/A |
Riser card 1 |
SAS port A1 |
SAS port A1 on compute module 1 |
SAS port A2 |
SAS port A2 on compute module 1 |
SAS port B1 |
SAS port A1 on compute module 2 |
SAS port B2 |
SAS port A2 on compute module 2 |
Supercapacitor port 1 |
Supercapacitor port 1 on compute module 1 |
Supercapacitor port 2 |
Supercapacitor port 1 on compute module 2 |
Riser card 2 |
N/A |
N/A |
Riser card 3 |
SAS port A1 |
SAS port B1 on compute module 1 |
SAS port A2 |
SAS port B2 on compute module 1 |
SAS port B1 |
SAS port B1 on compute module 2 |
SAS port B2 |
SAS port B2 on compute module 2 |
Supercapacitor port 2 on compute module 1 |
Supercapacitor port 2 on compute module 2 |
NOTE: · For more information about the SAS and supercapacitor ports on a riser card, see "Riser cards." · For more information about the SAS and supercapacitor ports on the system board, see "Main board of a compute module." |
Fan modules
The server must be configured with six hot swappable fan modules, each of which includes two fans. Figure 168 shows the layout of the fan modules in the chassis.
The fans support N+1 redundancy.
During system POST and operation, the server will be powered off through HDM if the temperature detected by any sensor in the server reaches the critical threshold. The server will be powered off directly if any key components such as processors exceed the upper threshold.
Air baffles
Compute module air baffles
Each compute module comes with two bilateral air baffles (a right air baffle and a left air baffle). You must install a low mid air baffle, high mid air baffle, or GPU module air baffle as required.
Table 32 lists air baffles available for a compute module and their installation locations and usage scenarios.
Table 32 Compute module air baffles
Name |
Picture |
Installation location |
Usage scenario |
High mid air baffle |
Above the DIMMs between the two processors. |
No riser card is installed in the compute module. |
A riser card is installed in the compute module. If the riser card carries a GPU module, install a GPU air baffle instead of a low mid air baffle. |
Bilateral air baffle |
Above the DIMMs at the right of processor 1, or the DIMMs at the left of processor 2. |
N/A |
GPU module air baffle |
A GPU module is installed in the compute module. |
NOTE: For more information about the air baffle locations, see "Main board components." |
The server comes with one power supply air baffle installed over the fan modules for heat dissipation of the power supplies. For more information about the air baffle location, see "Fan modules."
Figure 169 Power supply air baffle
Rear riser card air baffles
Each riser card at the server rear comes with a riser card air baffle installed over the four SAS connectors. An RS-4*FHHL-G3 riser card also comes with a GPU module air baffle. For more information about the air baffle location, see "Riser cards."
Table 33 Rear riser card air baffles
Name |
Picture |
Functions |
At the left of the connectors on each server riser card. |
Provides ventilation aisles in rear riser cards. |
Between the NCSI connector and the mLOM Ethernet adapter connector. |
Provides ventilation aisles in an RS-4*FHHL-G3 riser card. |
Power supplies
The power supplies have an overtemperature protection mechanism. A power supply stops working when an overtemperature occurs and automatically recovers when the overtemperature condition is removed.
800 W power supply
Item |
Specifications |
Model |
PSR800-12A |
Rated input voltage range |
· 100 VAC to 240 VAC @ 50/60 Hz · 192 VDC to 288 VDC (240 HVDC power source) |
Maximum rated input current |
· 10.0 A @ 100 VAC to 240 VAC · 4.0 A @ 240 VDC |
Maximum rated output power |
800 W |
Efficiency at 50 % load |
Temperature requirements |
· Operating temperature: 0°C to 50°C (32°F to 122°F) · Storage temperature: –40°C to +70°C (–40°F to +158°F) |
Operating humidity |
5% to 90% |
Maximum altitude |
5000 m (16404.20 ft) |
Redundancy |
N+N redundancy |
Hot swappable |
Yes |
Cold backup |
Yes |
800 W high-voltage power supply
Item |
Specifications |
Model |
PSR800-12AHD |
· 100 VAC to 240 VAC @ 50/60 Hz · 180 VDC to 400 VDC (240 to 380 HVDC power source) |
· 10.0 A @ 100 VAC to 240 VAC · 3.8 A @ 240 VDC |
800 W |
94%, 80 Plus platinum level |
5% to 90% |
Maximum altitude |
Redundancy |
N+N redundancy |
Hot swappable |
Yes |
Cold backup |
Yes |
1200 W power supply
Item |
Specifications |
Model |
PSR1200-12A |
· 100 VAC to 127 VAC @ 50/60 Hz (1000 W) · 200 VAC to 240 VAC @ 50/60 Hz (1200 W) · 192 VDC to 288 VDC (240 HVDC power source) (1200 W) |
· 12.0 A @ 100 VAC to 240 VAC · 6.0 A @ 240 VDC |
1200 W |
5% to 90% |
Maximum altitude |
Redundancy |
N+N redundancy |
Hot swappable |
Yes |
Cold backup |
Yes |
1600 W power supply
Item |
Specifications |
Model |
PSR850-12A |
· 200 VAC to 240 VAC @ 50/60 Hz · 192 VDC to 288 VDC (240 HVDC power source) |
· 9.5 A @ 200 VAC to 240 VAC · 8.0 A @ 240 VDC |
1600 W |
5% to 90% |
Maximum altitude |
Redundancy |
N+N redundancy |
Hot swappable |
Yes |
Cold backup |
Yes |
800 W –48VDC power supply
Item |
Specifications |
Model |
DPS-800W-12A-48V |
–48 VDC to –60 VDC |
20.0 A @ –48 VAC to –60 VDC |
800 W |
92% |
· Operating temperature: 0°C to 55°C (32°F to 131°F) · Storage temperature: –40°C to +70°C (–40°F to +158°F) |
5% to 90% |
Maximum altitude |
Redundancy |
1+1 redundancy |
Hot swappable |
Yes |
Cold backup |
Yes |
850 W high-efficiency Platinum power supply
Item |
Specifications |
Model |
DPS-850W-12A |
· 10.0 A @ 100 VAC to 240 VAC · 4.4 A @ 240 VDC |
850 W |
5% to 85% |
Maximum altitude |
Redundancy |
N+N redundancy |
Hot swappable |
Yes |
Cold backup |
Yes |
Expander modules
Model |
Specifications |
DSD-EX-A-X |
Dual SD card extended module (supports RAID level 1) |
BP-4SFF |
4SFF SAS/SATA drive backplane |
BP-4SFF-NVMe |
4SFF NVMe drive backplane |
Diagnostic panels
Diagnostic panels provide diagnostics and troubleshooting capabilities. You can locate and troubleshoot component failures by using the diagnostic panels in conjunction with the event log generated in HDM.
NOTE: A diagnostic panel displays only one component failure at a time. When multiple component failures exist, the diagnostic panel displays all these failures one by one at intervals of 4 seconds. |
Diagnostic panel specifications
Model |
Specifications |
SD-SFF-A |
SFF diagnostic panel |
Diagnostic panel view
Figure 170 shows the error code and LEDs on a diagnostic panel.
Figure 170 Diagnostic panel view
(1) Error code |
(2) LEDs |
For more information about the LEDs and error codes, see "LEDs."
LEDs
The server is operating correctly when the error code is 00 and all LEDs on the diagnostic panel are off.
POST LED
LED status |
Error code |
Steady green |
Code for the current POST phase (in the range of 00 to 99) |
The server is performing POST without detecting any error. |
Flashing red |
The POST process encountered an error and stopped in the displayed phase. |
TEMP LED
LED status |
Error code |
Flashing red |
Temperature sensor ID |
A severe temperature warning is present on the component monitored by the sensor. This warning might occur because the temperature of the component has exceeded the upper threshold or dropped below the lower threshold. |
CAP LED
LED status |
Error code |
Flashing amber |
01 |
The system power consumption has exceeded the power cap value. |
Component LEDs
An alarm is present if a component LED has one of the following behaviors:
Use Table 34 to identify the faulty item if a component LED has one of those behaviors. To obtain records of component status changes, use the event log in HDM. For information about using the event log, see HDM online help.
Table 34 LED, error code and faulty item matrix
LED |
Error code |
Faulty item |
BRD |
01 |
PDB |
02 |
Management module |
03 |
Midplane |
11 |
Main board of compute module 1 |
12 |
Drive backplane for drive cage bay 2 of compute module 1 |
13 |
Drive backplane for drive cage bay 1 of compute module 1 |
21 |
Main board of compute module 2 |
22 |
Drive backplane for drive cage bay 4 of compute module 2 |
23 |
Drive backplane for drive cage bay 3 of compute module 2 |
91 |
mLOM Ethernet adapter |
NOTE: If the error code field displays 11 or 21 and any other code alternatively, replace the faulty item other than the main board. If the issue persists, replace the main board. |
CPU (processor) |
01 |
Processor 1 in compute module 1 |
02 |
Processor 2 in compute module 1 |
03 |
Processor 1 in compute module 2 |
04 |
Processor 2 in compute module 2 |
DIMM |
A1 through A9, AA, Ab, or AC |
Compute module 1: · A1 through A9—DIMMs in slots A1 through A9 · AA—DIMM in slot A10 · Ab—DIMM in slot A11 · AC—DIMM in slot A12 |
b1 through b9, bA, bb, or bC |
Compute module 1: · b1 through b9—DIMMs in slots B1 through B9 · bA—DIMM in slot B10 · bb—DIMM in slot B11 · bC—DIMM in slot B12 |
C1 through C9, CA, Cb, or CC |
Compute module 2: · C1 through C9—DIMMs in slots A1 through A9 · CA—DIMM in slot A10 · Cb—DIMM in slot A11 · CC—DIMM in slot A12 |
d1 through d9, dA, db, or dC |
Compute module 2: · d1 through d9—DIMMs in slots B1 through B9 · dA—DIMM in slot B10 · db—DIMM in slot B11 · dC—DIMM in slot B12 |
HDD |
00 through 23 |
Relevant drive in compute module 1 (24SFF) |
30 through 53 |
Relevant drive in compute module 2 (24SFF) |
00 through 07 |
Relevant drive in compute module 1 (8SFF) |
10 through 17 |
Relevant drive in compute module 2 (8SFF) |
PCIE |
01 |
PCIe module in PCIe slot 1 of riser card 0 in compute module 1 |
03 |
PCIe module in PCIe slot 1 of riser card 0 in compute module 2 |
11 through 16 |
PCIe modules in PCIe slots 1 through 6 of riser card 1 at server rear |
21 through 26 |
PCIe modules in PCIe slots 1 through 6 of riser card 2 at server rear |
31 through 36 |
PCIe modules in PCIe slots 1 through 6 of riser card 3 at server rear |
09 |
PCIe uplink between processors and the PCH for the mLOM Ethernet adapter |
PSU |
01 |
Power supply 1 |
02 |
Power supply 2 |
03 |
Power supply 3 |
04 |
Power supply 4 |
FAN |
01 through 06 |
Fan module 1 through Fan module 6 |
VRD |
01 |
PDB P5V voltage |
02 |
PDB P3V3_STBY voltage |
03 |
Management module P1V05_PCH_STBY voltage |
04 |
Management module PVNN_PCH_STBY voltage |
05 |
Management module P1V8_PCH_STBY voltage |
60 |
Compute module 1 HPMOS voltage |
61 |
Compute module 1 PVCCIO_CPU1 voltage |
62 |
Compute module 1 PVCCIN_CPU1 voltage |
63 |
Compute module 1 PVCCSA_CPU1 voltage |
64 |
Compute module 1 PVCCIO_CPU2 voltage |
65 |
Compute module 1 PVCCIN_CPU2 voltage |
66 |
Compute module 1 PVCCSA_CPU2 voltage |
67 |
Compute module 1 VDDQ/VPP_CPU1_ABC voltage |
68 |
Compute module 1 VDDQ/VPP_CPU1_DEF voltage |
69 |
Compute module 1 VTT_CPU1_ABC voltage |
6A |
Compute module 1 VTT_CPU1_DEF voltage |
6b |
Compute module 1 VDDQ/VPP_CPU2_ABC voltage |
6C |
Compute module 1 VDDQ/VPP_CPU2_DEF voltage |
6d |
Compute module 1 VTT_CPU2_ABC voltage |
6E |
Compute module 1 VTT_CPU2_DEF voltage |
70 |
Compute module 2 HPMOS voltage |
71 |
Compute module 2 PVCCIO_CPU1 voltage |
72 |
Compute module 2 PVCCIN_CPU1 voltage |
73 |
Compute module 2 PVCCSA_CPU1 voltage |
74 |
Compute module 2 PVCCIO_CPU2 voltage |
75 |
Compute module 2 PVCCIN_CPU2 voltage |
76 |
Compute module 2 PVCCSA_CPU2 voltage |
77 |
Compute module 2 VDDQ/VPP_CPU1_ABC voltage |
78 |
Compute module 2 VDDQ/VPP_CPU1_DEF voltage |
79 |
Compute module 2 VTT_CPU1_ABC voltage |
7A |
Compute module 2 VTT_CPU1_DEF voltage |
7b |
Compute module 2 VDDQ/VPP_CPU2_ABC voltage |
7C |
Compute module 2 VDDQ/VPP_CPU2_DEF voltage |
7d |
Compute module 2 VTT_CPU2_ABC voltage |
7E |
Compute module 2 VTT_CPU2_DEF voltage |
NOTE: · The term "CPU" in this table refers to processors. · For the location of riser cards at the server rear, see "Riser cards." |
Fiber transceiver modules
Model |
Central wavelength |
Connector |
Max transmission distance |
SFP-25G-SR-MM850-1-X |
850 nm |
LC |
100 m (328.08 ft) |
SFP-XG-SX-MM850-A1-X |
850 nm |
LC |
300 m (984.25 ft) |
SFP-XG-SX-MM850-E1-X |
850 nm |
LC |
300 m (984.25 ft) |
QSFP-100G-SR4-MM850 |
850 nm |
MPO |
100 m (328.08 ft) |
SFP-XG-LX-SM1310-E |
1310 nm |
LC |
10 km (32808.40 ft) |
Storage options other than HDDs and SDDs
Model |
Specifications |
DVD-RW-Mobile-USB-A |
Removable USB DVDRW drive module IMPORTANT: For this module to work correctly, you must connect it to a USB 3.0 connector. |
NVMe VROC modules
Model |
RAID levels |
Compatible NVMe SSDs |
NVMe-VROC-Key-S |
0, 1, 10 |
All NVMe drives and PCIe M.2 SSDs |
NVMe-VROC-Key-P |
0, 1, 5, 10 |
NVMe-VROC-Key-I |
0, 1, 5, 10 |
Intel NVMe drives and Intel PCIe M.2 SSDs |
TPM/TCM modules
Trusted platform module (TPM) is a microchip embedded in the management module. It stores encryption information (such as encryption keys) for authenticating server hardware and software. The TPM operates with drive encryption programs such as Microsoft Windows BitLocker to provide operating system security and data protection. For information about Microsoft Windows BitLocker, visit the Microsoft website at http://www.microsoft.com.
Trusted cryptography module (TCM) is a trusted computing platform-based hardware module with protected storage space, which enables the platform to implement password calculation.
Table 35 describes the TPM and TCM modules supported by the server.
Table 35 TPM/TCM specifications
Model |
Specifications |
TPM-2-X |
Trusted Platform Module 2.0 |
TCM-1-X |
Trusted Cryptography Module 1.0 |
Security bezels, slide rail kits, and CMA
CMA-2U-A |
2U CMA |
SL-4U-BB |
4U ball bearing rail |
RS-CH-A |
Chassis handle |
SEC-Panel-4U |
4U security bezel |
CAB-GPU-PWR-M |
GPU power cable module |
BAT-LSI-G2-4U-B-X |
LSI G2 supercapacitor B (compute module air baffle) |
BAT-LSI-G3-4U-B |
LSI G3 supercapacitor B (compute module air baffle) |
Appendix C Managed hot removal of NVMe drives
Managed hot removal of NVMe drives enables you to remove NVMe drives safely while the server is operating.
Use Table 36 to determine the managed hot removal method depending on the VMD status and the operating system. For more information about VMD, see the BIOS user guide for the server.
Table 36 Managed hot removal methods
VMD status |
Operating system |
Managed hot removal method |
Enabled |
Windows |
Linux |
Disabled (default status) |
N/A |
Contact the support. |
Performing a managed hot removal in Windows
Install Intel® Rapid Storage Technology enterprise (Intel® RSTe).
To obtain Intel® RSTe, use one of the following methods:
· Go to https://platformsw.intel.com/KitSearch.aspx to download the software.
· Contact Intel Support.
1. Stop reading data from or writing data to the NVMe drive to be removed.
2. Identify the location of the NVMe drive. For more information, see "Drive configurations and numbering."
3. Run Intel® RSTe.
4. Unmount the NVMe drive from the operating system, as shown in Figure 171:
¡ Select the NVMe drive to be removed from the Devices list.
¡ Click Activate LED to turn on the Fault/UID LED on the drive.
¡ Click Remove Disk.
Figure 171 Removing an NVMe drive
5. Observe the Fault/UID LED on the drive. If the Fault/UID LED turns steady blue and the drive is removed from the Devices list, remove the drive from the server.
For more information about the removal procedure, see "Replacing an NVMe drive."
Performing a managed hot removal in Linux
In Linux, you can perform a managed hot removal of NVMe drives from the CLI or by using Intel® Accelerated Storage Manager.
· Identify that your operating system is a non-SLES Linux operating system. SLES operating systems do not support managed hot removal of NVMe drives.
· To perform a managed hot removal by using Intel® ASM, install Intel® ASM.
To obtain Intel® ASM, use one of the following methods:
¡ Go to https://platformsw.intel.com/KitSearch.aspx to download the software.
¡ Contact Intel Support.
Performing a managed hot removal from the CLI
3. Access the CLI of the server.
4. Execute the lsblk | grep nvme command to identify the drive letter of the NVMe drive, as shown in Figure 172.
Figure 172 Identifying the drive letter of the NVMe drive to be removed
5. Execute the ledctl locate=/dev/drive_letter command to turn on the Fault/UID LED on the drive. The drive_letter argument represents the drive letter, for example, nvme0n1.
6. Execute the echo 1 > /sys/block/drive_letter/device/device/remove command to unmount the drive from the operating system. The drive_letter argument represents the drive letter, for example, nvme0n1.
7. Observe the Fault/UID LED on the drive. If the Fault/UID LED turns steady blue, remove the drive from the server.
Performing a managed hot removal from the Intel® ASM Web interface
3. Run Intel® ASM.
4. Click RSTe Management.
Figure 173 Accessing RSTe Management
5. Expand the Intel(R) VROC(in pass-thru mode) menu to view operating NVMe drives, as shown in Figure 174.
Figure 174 Viewing operating NVMe drives
6. Click the light bulb icon to turn on the Fault/UID LED on the drive, as shown in Figure 175.
Figure 175 Turning on the drive Fault/UID LED
7. Click the removal icon, as shown in Figure 176.
Figure 176 Removing an NVMe drive
8. In the dialog box that opens, click Yes.
Figure 177 Confirming the removal
9. Remove the drive from the server. For more information about the removal procedure, see "Replacing an NVMe drive."
Appendix D Environment requirements
About environment requirements
The operating temperature requirements for the server vary depending on the server model and hardware configuration. When the general and component-based requirements conflict, use the component-based requirement.
Be aware that the actual maximum operating temperature of the server might be lower than what is stated because of poor site cooling performance. In a real data center, the server cooling performance might decrease because of adverse external factors, including poor cabinet cooling performance, high power density inside the cabinet, or insufficient spacing between devices.
General environment requirements
Item |
Specifications |
Operating temperature |
Minimum: 5°C (41°F) Maximum: · For 32SFF and 48SFF drive configurations: 40°C (104°F) · For 16SFF drive configuration: 45°C (113°F) CAUTION: The maximum temperature varies by hardware option presence. For more information, see "Operating temperature requirements." |
Storage temperature |
8% to 90%, noncondensing |
Storage humidity |
5% to 95%, noncondensing |
Operating altitude |
–60 m to +3000 m (–196.85 ft to +9842.52 ft) The allowed maximum temperature decreases by 0.33 °C (32.59°F) as the altitude increases by 100 m (328.08 ft) from 900 m (2952.76 ft) |
Storage altitude |
–60 m to +5000 m (–196.85 ft to +16404.20 ft) |
Use Table 37 and Table 38 to determine the maximum operating temperature of the servers with 8 SFF drives in each compute module or 24 SFF drives in either compute module. A maximum server operating temperature applies if the server contains any options in its matching hardware option list.
NOTE: All maximum server operating temperature values are provided on the basis that the fan modules are installed as needed and operating correctly. For more information about fan modules, see "Fan modules." |
Table 37 Temperature requirements for the server with 8 SFF drives in each compute module
Maximum server operating temperature |
Hardware options |
30°C (86°F) |
GPU module GPU-V100 or GPU-V100-32G |
35°C (95°F) |
· A faulty fan · NVMe drives · GPU module GPU-P4-X, GPU-P40-X, GPU-P100, or GPU-T4 NOTE: With GPU-P4-X, GPU-P40-X, GPU-P100, or GPU-T4 installed, the server performance might degrade if a fan fails. |
40°C (104°F) |
· PCIe M.2 SSD · Any of the following processor models: ¡ 8180 ¡ 8180M ¡ 8168 ¡ 6154 ¡ 6146 ¡ 6144 ¡ 6244 |
45°C (113°F) |
None of the above hardware options or operating conditions exists |
Table 38 Temperature requirements for the server with 24 SFF drives in either compute module
Hardware options |
30°C (86°F) |
· Any of the following processor models wth a faulty fan: ¡ 8180 ¡ 8180M ¡ 8168 ¡ 6154 ¡ 6146 ¡ 6144 ¡ 6244 |
35°C (95°F) |
· GPU module GPU-P4-X or GPU-T4 · Any of the following processor models: ¡ 8180 ¡ 8180M ¡ 8168 ¡ 6154 ¡ 6146 ¡ 6144 ¡ 6244 NOTE: With GPU-P4-X or GPU-T4 installed, the server performance might degrade if a fan fails. |
40°C (104°F) |
Appendix E Product recycling
New H3C Technologies Co., Ltd. provides product recycling services for its customers to ensure that hardware at the end of its life is recycled. Vendors with product recycling qualification are contracted to New H3C to process the recycled hardware in an environmentally responsible way.
For product recycling services, contact New H3C at
· Tel: 400-810-0504
· E-mail: service@h3c.com
· Website: http://www.h3c.com
Appendix F Glossary
B |
BIOS |
Basic input/output system is non-volatile firmware pre-installed in a ROM chip on a server's management module. The BIOS stores basic input/output, power-on self-test, and auto startup programs to provide the most basic hardware initialization, setup and control functionality. |
C |
CPLD |
Complex programmable logic device is an integrated circuit used to build reconfigurable digital circuits. |
F |
FIST |
Fast Intelligent Scalable Toolkit provided by H3C for easy and extensible server management. It can guide users to configure a server quickly with ease and provide an API interface to allow users to develop their own management tools. |
G |
GPU module |
Graphics processing unit module converts digital signals to analog signals for output to a display device and assists processors with image processing to improve overall system performance. |
H |
HDM |
H3C Device Management is the server management control unit with which administrators can configure server settings, view component information, monitor server health status, and remotely manage the server. |
A module that supports hot swapping (a hot-swappable module) can be installed or removed while the server is running without affecting the system operation. |
I |
iFIST |
Integrated Fast Intelligent Scalable Toolkit is a management tool embedded in an H3C server. It allows users to manage the server it resides in and provides features such as RAID configuration, OS and driver installation, and health status monitoring. |
K |
KVM |
KVM is a management method that allows remote users to use their local video display, keyboard, and mouse to monitor and control the server. |
N |
NCSI |
NCSI enables a port on a PCIe or mLOM Ethernet adapter to function as a management network port and an Ethernet port at the same time. |
Network adapter |
A network adapter, also called a network interface card (NIC), connects the server to the network. |
An expander module that facilitates communication between the main board of a compute module and the front NVMe hard drives. The module is required if a front NVMe hard drive is installed. |
NVMe VROC module |
A module that works with Intel VMD to provide RAID capability for the server to virtualize storage resources of NVMe drives. |
R |
RAID |
Redundant array of independent disks (RAID) is a data storage virtualization technology that combines multiple physical hard drives into a single logical unit to improve storage and security performance. |
Redundancy |
A mechanism that ensures high availability and business continuity by providing backup modules. In redundancy mode, a backup or standby module takes over when the primary module fails. |
S |
Security bezel |
A locking bezel mounted to the front of a server to prevent unauthorized access to modules such as hard drives. |
U |
A unit of measure defined as 44.45 mm (1.75 in) in IEC 60297-1. It is used as a measurement of the overall height of racks, as well as equipment mounted in the racks. |
UPI |
Ultra Path Interconnect is a high-speed interconnection method for multiprocessor systems. It can provide a transfer speed of up to 10.4 GT/s. |
V |
VMD |
VMD provides hot removal, management and fault-tolerance functions for NVMe drives to increase availability, reliability, and serviceability. |
Appendix G Acronyms
Acronym |
Full name |
B |
BIOS |
C |
CMA |
Cable Management Arm |
CPLD |
D |
DCPMM |
Data Center Persistent Memory Module |
DDR |
Double Data Rate |
DIMM |
Dual In-Line Memory Module |
DRAM |
Dynamic Random Access Memory |
F |
FIST |
G |
GPU |
Graphics Processing Unit |
H |
HBA |
Host Bus Adapter |
HDD |
Hard Disk Drive |
HDM |
I |
IDC |
Internet Data Center |
iFIST |
integrated Fast Intelligent Scalable Toolkit |
K |
KVM |
Keyboard, Video, Mouse |
L |
LRDIMM |
Load Reduced Dual Inline Memory Module |
M |
mLOM |
Modular LAN-on-Motherboard |
N |
NCSI |
Network Controller Sideband Interface |
NVMe |
Non-Volatile Memory Express |
P |
PCIe |
Peripheral Component Interconnect Express |
PDB |
Power Distribution Board |
PDU |
Power Distribution Unit |
POST |
Power-On Self-Test |
R |
RDIMM |
Registered Dual Inline Memory Module |
S |
SAS |
Serial Attached Small Computer System Interface |
SATA |
Serial ATA |
SD |
Secure Digital |
SDS |
Secure Diagnosis System |
SFF |
Small Form Factor |
SSD |
Solid State Drive |
T |
TCM |
Trusted Cryptography Module |
TPM |
Trusted Platform Module |
U |
UID |
Unit Identification |
UPI |
Ultra Path Interconnect |
UPS |
Uninterruptible Power Supply |
USB |
Universal Serial Bus |
V |
VROC |
Virtual RAID on CPU |
VMD |
Volume Management Device |
