02-Virtual Technologies Configuration Guide
HomeSupportSwitchesS12500X-AF SeriesConfigure & DeployConfiguration GuidesH3C S12500X-AF Switch Series Configuration Guides(R26xx)-6W10202-Virtual Technologies Configuration Guide
Table of Contents
Related Documents
00-Preface
Download Book  (81.00 KB)
Preface
This configuration guide describes how to set up an IRF fabric of multiple S12500X-AF switches, including:
·          Plan the switch roles in the IRF fabric.
·          Connect the IRF links.
·          Detect IRF splits and maintain the IRF fabric.
·          Audience.
·          Conventions.
·          Documentation feedback.
Audience
·          Network planners.
·          Field technical support and servicing engineers.
·          Network administrators working with the S12500X-AF switch series.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
Wireless terminator unit.
Wireless terminator.
Represents a security card, such as a firewall, load balancing, NetStream, SSL VPN, IPS, or ACG card.
We appreciate your comments.
