05-Layer 2 - WAN Access Configuration Guide
HomeSupportRoutersCR16000-F SeriesConfigure & DeployConfiguration GuidesH3C CR16000-F Routers Configuration Guides-Release795x-6W10005-Layer 2 - WAN Access Configuration Guide
01-PPP configuration
01-PPP configuration 321.74 KB
Configuring PPP· 1
About PPP· 1
PPP protocols· 1
PPP link establishment process· 1
PPP authentication· 2
PPP for IPv4· 2
PPP for IPv6· 3
Protocols and standards· 4
PPP tasks at a glance· 4
Enabling PPP encapsulation on an interface· 5
Configuring a VT interface· 5
Creating a VT interface· 5
Restoring the default settings for the VT interface· 6
Configuring PPP authentication· 6
About PPP authentication· 6
Configuring PAP authentication· 6
Configuring CHAP authentication (authenticator name is configured) 7
Configuring CHAP authentication (authenticator name is not configured) 8
Configuring MS-CHAP or MS-CHAP-V2 authentication· 9
Configuring the polling feature· 10
Configuring a VT interface not to perform keepalive detection when PPP users have traffic· 11
Enabling fast reply for keepalive packets· 11
Configuring PPP negotiation· 12
Configuring the PPP negotiation timeout time· 12
Configuring IPv4 address negotiation on the client 12
Configuring IPv4 address negotiation on the server 13
Configuring IPv6 address negotiation on the server 16
Enabling IP segment match· 18
Configuring DNS server IP address negotiation on the client 19
Configuring DNS server IP address negotiation on the server 19
Enabling PPP link quality monitoring· 20
Configuring magic number check for PPP· 20
Enabling MRU check for PPP packets· 21
Specifying that PPP users cannot come online successfully if the online requests do not carry usernames· 21
Enabling source IP check for PPP users· 22
Enabling PPP user blocking· 23
Configuring the nas-port-type attribute· 23
Suppressing adding PPP peer host routes to the local direct route table· 24
Enabling issuing ND prefix network routes· 24
Configuring PPP accounting· 25
Configuring the traffic accounting frequency mode for online PPP users· 25
Enabling PPP accounting· 25
Configuring PPP logging and service tracing objects· 25
Enabling logging for PPP users· 25
Configuring service tracing objects· 26
Display and maintenance commands for PPP· 26
PPP configuration examples· 29
Example: Configuring one-way PAP authentication· 29
Example: Configuring two-way PAP authentication· 31
Example: Configuring one-way CHAP authentication· 33
Example: Specifying an IP address for the client on the server interface· 35
Example: Specifying a PPP address pool on the server interface· 36
Example: Using the PPP address pool associated with an ISP domain· 38
Configuring MP· 40
About MP· 40
Benefit 40
Interface type· 40
Restrictions and guidelines: MP configuration· 40
MP tasks at a glance· 40
Configuring MP through an MP-group interface· 40
About MP-group interfaces· 40
Tasks at a glance· 40
Creating an MP-group interface· 41
Assigning a physical interface to the MP-group interface· 41
Configuring the polling feature on the MP-group interface· 41
Configuring MP parameters· 42
Restoring the default settings for the MP-group interface· 42
Configuring short sequence number header format negotiation· 43
Configuring the MP endpoint descriptor 43
Display and maintenance commands for MP· 44
MP configuration examples· 44
Example: Configuring an MP-group interface· 44
Configuring PPP
About PPP
Point-to-Point Protocol (PPP) is a point-to-point link layer protocol. It provides user authentication, supports synchronous/asynchronous communication, and allows for easy extension.
PPP protocols
PPP includes the following protocols:
·          Link control protocol (LCP)—Establishes, tears down, and monitors data links.
·          Network control protocol (NCP)—Negotiates the packet format and type for data links.
·          Authentication protocols—Authenticate users. Protocols include the following:
¡  Password Authentication Protocol (PAP).
¡  Challenge Handshake Authentication Protocol (CHAP).
¡  Microsoft CHAP (MS-CHAP).
¡  Microsoft CHAP Version 2 (MS-CHAP-V2).
Figure 1 shows the PPP link establishment process.
Figure 1 PPP link establishment process
1.        Initially, PPP is in Link Dead phase. After the physical layer goes up, PPP enters the Link Establishment phase (Establish).
2.        In the Link Establishment phase, the LCP negotiation is performed. The LCP configuration options include Authentication-Protocol, Async-Control-Character-Map (ACCM), Maximum-Receive-Unit (MRU), Magic-Number, Protocol-Field-Compression (PFC), Address-and-Control-Field-Compression (ACFC), and MP.
¡  If the negotiation fails, LCP reports a Fail event, and PPP returns to the Dead phase.
¡  If the negotiation succeeds, LCP enters the Opened state and reports an Up event, indicating that the underlying layer link has been established. At this time, the PPP link is not established for the network layer, and network layer packets cannot be transmitted over the link.
3.        If authentication is configured, the PPP link enters the Authentication phase, where PAP, CHAP, MS-CHAP, or MS-CHAP-V2 authentication is performed.
¡  If the client fails to pass the authentication, LCP reports a Fail event and enters the Link Termination phase. In this phase, the link is torn down and LCP goes down.
¡  If the client passes the authentication, LCP reports a Success event.
4.        If a network layer protocol is configured, the PPP link enters the Network-Layer Protocol phase for NCP negotiation, such as IPCP negotiation and IPv6CP negotiation.
¡  If the NCP negotiation succeeds, the link goes up and becomes ready to carry negotiated network-layer protocol packets.
¡  If the NCP negotiation fails, NCP reports a Down event and enters the Link Termination phase.
If the interface is configured with an IP address, the IPCP negotiation is performed. IPCP configuration options include IP addresses and DNS server IP addresses. After the IPCP negotiation succeeds, the link can carry IP packets.
5.        After the NCP negotiation is performed, the PPP link remains active until either of the following events occurs:
¡  Explicit LCP or NCP frames close the link.
¡  Some external events take place (for example, the intervention of a user).
PPP authentication
PPP supports the following authentication methods:
·          PAP—PAP is a two-way handshake authentication protocol using the username and password.
PAP sends username/password pairs in plain text over the network. If authentication packets are intercepted in transit, network security might be threatened. For this reason, it is suitable only for low-security environments.
·          CHAP—CHAP is a three-way handshake authentication protocol.
CHAP transmits usernames but not passwords over the network. It transmits the result calculated from the password and random packet ID by using the MD5 algorithm. It is more secure than PAP. The authenticator may or may not be configured with a username. As a best practice, configure a username for the authenticator, which makes it easier for the peer to verify the identity of the authenticator.
·          MS-CHAP—MS-CHAP is a three-way handshake authentication protocol.
MS-CHAP differs from CHAP as follows: MS-CHAP provides authentication retry. If the peer fails authentication, it is allowed to retransmit authentication information to the authenticator for reauthentication. The authenticator allows a peer to retransmit a maximum of three times.
·          MS-CHAP-V2—MS-CHAP-V2 is a three-way handshake authentication protocol.
MS-CHAP-V2 differs from CHAP as follows:
¡  MS-CHAP-V2 provides two-way authentication by piggybacking a peer challenge on the Response packet and an authenticator response on the Acknowledge packet.
¡  MS-CHAP-V2 supports authentication retry. If the peer fails authentication, it is allowed to retransmit authentication information to the authenticator for reauthentication. The authenticator allows a peer to retransmit a maximum of three times.
¡  MS-CHAP-V2 supports password change. If the peer fails authentication because of an expired password, it will send the new password entered by the user to the authenticator for reauthentication.
PPP for IPv4
On IPv4 networks, PPP negotiates the IP address and DNS server address during IPCP negotiation.
IP address negotiation enables one end to assign an IP address to the other.
An interface can act as a client or a server during IP address negotiation:
·          Client—Obtains an IP address from the server. Use the client mode when the device accesses the Internet through an ISP.
·          Server—Assigns an IP address to the client. Before you configure the IP address of the server, you must perform one of the following tasks:
¡  Configure a local address pool and associate the pool with the ISP domain.
¡  Specify an IP address or an address pool for the client on the interface.
When IP address negotiation is enabled on a client, the server selects an IP address for the client in the following sequence:
1.        If the AAA server configures an IP address or address pool for the client, the server selects that IP address or an IP address from the pool. The IP address or address pool is configured on the AAA server instead of the PPP server. For information about AAA, see AAA configuration in BRAS Services Configuration Guide.
2.        If an address pool is associated with the ISP domain used during client authentication, the server selects an IP address from the pool.
3.        If an IP address or address pool is specified for the client on the interface of the server, the server selects that IP address or an IP address from that pool.
DNS server address negotiation
IPCP negotiation can determine the DNS server IP address.
When the device is connected to a host, configure the device as the server to assign the DNS server IP address to the host.
When the device is connected to an ISP access server, configure the device as the client. Then, the device can obtain the DNS server IP address from the ISP access server.
PPP for IPv6
On IPv6 networks, PPP negotiates only the IPv6 interface identifier instead of the IPv6 address and IPv6 DNS server address during IPv6CP negotiation. All authentication users have to obtain IPv6 global unicast addresses and IPv6 DNS server addresses by using ND or DHCPv6 protocols.
IPv6 address assignment
A host can get an IPv6 global unicast address through the following methods:
·          NDRA—The host obtains an IPv6 prefix in an RA message. The host then generates an IPv6 global unicast address by combining the IPv6 prefix and the negotiated IPv6 interface identifier. The IPv6 prefix in the RA message is determined in the following sequence:
¡  IPv6 prefix authorized by AAA.
¡  Prefix in the ND prefix pool authorized by AAA.
¡  RA prefix configured on the interface.
¡  Prefix of the IPv6 global unicast address configured on the interface.
The ND prefix pool authorized by AAA and the IA_NA method are mutually exclusive. For information about the ND protocol, see DHCPv6 configuration in BRAS Services Configuration Guide.
·          DHCPv6 (IA_NA)—The host requests an IPv6 global unicast address through DHCPv6. The server assigns an IPv6 address to the host from the address pool authorized by AAA. If no AAA-authorized address pool exists, DHCPv6 uses the address pool that matches the server's IPv6 address to assign an IPv6 address to the host. For information about DHCPv6, see DHCPv6 configuration in BRAS Services Configuration Guide.
·          DHCPv6 (IA_PD)—A client-side device requests prefixes through DHCPv6 and assigns them to downstream hosts. The hosts then use the prefixes to generate global IPv6 addresses. This method uses the same principle of selecting address pools as the DHCPv6 (IA_NA) method.
The device can assign a host an IPv6 address in either of the following ways:
·          When the host connects to the device directly or through a bridge device, the device can use the NDRA method or the IA_NA method.
·          When the host accesses the device through a router, the device can use the IA_PD method to assign an IPv6 prefix to the router. The router assigns the prefix to the host to generate an IPv6 global unicast address.
IPv6 DNS server address assignment
On IPv6 networks, two methods are available for the IPv6 DNS server address assignment:
·          AAA authorizes the IPv6 DNS server address and assigns this address to the host through RA messages.
·          The DHCPv6 client requests an IPv6 DNS server address from the DHCPv6 server.
RFC 1661: The Point-to-Point Protocol (PPP)
To configure PPP, perform the following tasks:
1.        Enabling PPP encapsulation on an interface
2.        Configuring a VT interface
¡  Creating a VT interface
¡  Restoring the default settings for the VT interface
In PPPoE and L2TP application environments, you must configure VT interfaces. For information about PPPoE and L2TP, see PPPoE configuration and L2TP configuration in BRAS Services Configuration Guide.
3.        Configuring PPP authentication
¡  Configuring PAP authentication
¡  Configuring CHAP authentication (authenticator name is configured)
¡  Configuring CHAP authentication (authenticator name is not configured)
¡  Configuring MS-CHAP or MS-CHAP-V2 authentication
Configure PPP authentication for high-security environments.
4.        (Optional.) Configuring the polling feature
5.        (Optional.) Configuring a VT interface not to perform keepalive detection when PPP users have traffic
6.        (Optional.) Enabling fast reply for keepalive packets
7.        (Optional.) Configuring PPP negotiation
¡  Configuring the PPP negotiation timeout time
¡  Configuring IPv4 address negotiation on the client
¡  Configuring IPv4 address negotiation on the server
¡  Configuring IPv6 address negotiation on the server
¡  Enabling IP segment match
¡  Configuring DNS server IP address negotiation on the client
¡  Configuring DNS server IP address negotiation on the server
8.        (Optional.) Enabling PPP link quality monitoring
9.        (Optional.) Configuring magic number check for PPP
10.     (Optional.) Enabling MRU check for PPP packets
11.     (Optional.) Specifying that PPP users cannot come online successfully if the online requests do not carry usernames
12.     (Optional.) Enabling source IP check for PPP users
13.     (Optional.) Enabling PPP user blocking
14.     (Optional.) Configuring the nas-port-type attribute
15.     (Optional.) Suppressing adding PPP peer host routes to the local direct route table
16.     (Optional.) Enabling issuing ND prefix network routes
17.     (Optional.) Configuring PPP accounting
¡  Configuring the traffic accounting frequency mode for online PPP users
¡  Enabling PPP accounting
18.     (Optional.) Configuring PPP logging and service tracing objects
¡  Enabling logging for PPP users
¡  Configuring service tracing objects
1.        Enter system view.
2.        Enter interface view.
3.        Enable PPP encapsulation on the interface.
link-protocol ppp
By default, all interfaces except Ethernet interfaces, VLAN interfaces, and ATM interfaces use PPP as the link layer protocol.
About VT interfaces
Virtual-template (VT) interfaces are logical interfaces manually created on devices. A VT interface can implement the functionality of a physical WAN interface with PPP encapsulation enabled. For a VT interface to work properly, you must bind it to a physical interface.
In PPPoE and L2TP applications, you can use VT interfaces to implement related functions of PPP. For more information about PPPoE and L2TP, see PPPoE configuration and L2TP configuration in BRAS Services Configuration Guide.
This command is available only in standard mode. For more information about the system operating modes, see device management in Fundamentals Configuration Guide.
2.        Create a VT interface and enter its view.
interface virtual-template number
3.        (Optional.) Set the interface description.
By default, the description of a VT interface is interface name Interface, for example, Virtual-Template1 Interface.
4.        (Optional.) Set the MTU size of the interface.
mtu size
The default setting varies by card model.
5.        (Optional.) Set the expected bandwidth of the VT interface.
bandwidth bandwidth-value
By default, the expected bandwidth (in kbps) is the interface baud rate divided by 1000.
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you execute it on a live network.
The default command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands. Use the undo forms of these commands or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
2.        Enter VT interface view.
3.        Restore the default settings for the interface.
default
You can configure several authentication modes simultaneously. In LCP negotiation, the authenticator negotiates with the peer in the sequence of configured authentication modes until the LCP negotiation succeeds. If the response packet from the peer carries a recommended authentication mode, the authenticator directly uses the authentication mode if it finds the mode configured.
Restrictions and guidelines for PAP authentication
For local AAA authentication, the username and password of the peer must be configured on the authenticator.
For remote AAA authentication, the username and password of the peer must be configured on the remote AAA server.
The username and password configured for the peer must be the same as those configured on the peer by using the ppp pap local-user command.
Configuring the authenticator
3.        Configure the authenticator to authenticate the peer by using PAP.
ppp authentication-mode pap [ domain { isp-name | default enable isp-name } ]
By default, PPP authentication is disabled.
4.        Configure local or remote AAA authentication.
For more information about AAA authentication, see AAA configuration in BRAS Services Configuration Guide.
Configuring the peer
3.        Configure the PAP username and password sent from the peer to the authenticator when the peer is authenticated by the authenticator by using PAP.
ppp pap local-user username password { cipher | simple } string
By default, when being authenticated by the authenticator by using PAP, the peer sends null username and password to the authenticator.
For security purposes, the password specified in plaintext form and ciphertext form will be stored in encrypted form.
Restrictions and guidelines for CHAP authentication (authenticator name is configured)
When you configure the authenticator, follow these guidelines:
·          For local AAA authentication, the username and password of the peer must be configured on the authenticator.
·          For remote AAA authentication, the username and password of the peer must be configured on the remote AAA server.
·          The username and password configured for the peer must meet the following requirements:
¡  The username configured for the peer must be the same as that configured on the peer by using the ppp chap user command.
¡  The passwords configured for the authenticator and peer must be the same.
When you configure the peer, follow these guidelines:
·          For local AAA authentication, the username and password of the authenticator must be configured on the peer.
·          For remote AAA authentication, the username and password of the authenticator must be configured on the remote AAA server.
·          The username and password configured for the authenticator must meet the following requirements:
¡  The username configured for the authenticator must be the same as that configured on the authenticator by using the ppp chap user command.
·          The peer does not support the CHAP authentication password configured by using the ppp chap password command. CHAP authentication (authenticator name is configured) will apply even if the authentication name is configured.
3.        Configure the authenticator to authenticate the peer by using CHAP.
ppp authentication-mode chap [ domain { isp-name | default enable isp-name } ]
4.        Configure a username for the CHAP authenticator.
ppp chap user username
The default setting is null.
5.        Configure local or remote AAA authentication.
3.        Configure a username for the CHAP peer.
Restrictions and guidelines for CHAP authentication (authenticator name is not configured)
·          The username configured for the peer must be the same as that configured on the peer by using the ppp chap user command.
·          The password configured for the peer must be the same as that configured on the peer by using the ppp chap password command.
4.        Set the CHAP authentication password.
ppp chap password { cipher | simple } string
Restrictions and guidelines for MS-CHAP or MS-CHAP-V2 authentication
The device can only act as an authenticator for MS-CHAP or MS-CHAP-V2 authentication.
L2TP supports only MS-CHAP authentication.
MS-CHAP-V2 authentication supports password change only when using RADIUS.
As a best practice, do not set the authentication method for PPP users to none when MS-CHAP-V2 authentication is used.
For local AAA authentication, the username and password of the peer must be configured on the authenticator. For remote AAA authentication, the username and password of the peer must be configured on the remote AAA server. The username and password of the peer configured on the authenticator or remote AAA server must be the same as those configured on the peer.
If authentication name is configured, the username configured for the authenticator on the peer must be the same as that configured on the authenticator by using the ppp chap user command.
Configuring MS-CHAP or MS-CHAP-V2 authentication (authenticator name is configured)
3.        Configure the authenticator to authenticate the peer by using MS-CHAP or MS-CHAP-V2.
ppp authentication-mode { ms-chap | ms-chap-v2 } [ domain { isp-name | default enable isp-name } ]
4.        Configure a username for the MS-CHAP or MS-CHAP-V2 authenticator.
Configuring MS-CHAP or MS-CHAP-V2 authentication (authenticator name is not configured)
About the polling feature
The polling feature checks PPP link state.
On an interface that uses PPP encapsulation, the link layer sends keepalive packets at keepalive intervals to detect the availability of the peer. If the interface receives no response to keepalive packets when the keepalive retry limit is reached, it determines that the link fails and reports a link layer down event.
To set the keepalive retry limit, use the timer-hold retry command.
The value 0 disables an interface from sending keepalive packets. In this case, the interface can respond to keepalive packets from the peer.
On a slow link, increase the keepalive interval to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
The keepalive interval must be smaller than the negotiation timeout time.
3.        Set the keepalive interval.
timer-hold seconds
The default setting is 10 seconds for POS interfaces and serial interfaces and 60 seconds for VT interfaces.
4.        Set the keepalive retry limit.
timer-hold retry retries
The default setting is 5 for POS interfaces and serial interfaces and 3 for VT interfaces.
About configuring a VT interface not to perform keepalive detection when PPP users have traffic
If the configured keepalive interval (timer-hold seconds) or keepalive retry limit (timer-hold retry retries) is small, users might go offline because the interface cannot receive keepalive packets from the peer when congestion occurs in the network. To prevent keepalive packets from making the congestion deteriorate or causing users to frequently go offline, configure the ppp keepalive datacheck command.
With this feature configured, if the user traffic is updated within a keepalive interval, the keepalive timer is reset and delayed by 60 seconds. Therefore, keepalive packets are sent only when user traffic is not updated. For example, suppose you set the keepalive interval to 10 seconds by using the timer-hold command. If user traffic is updated at the 5th second, the keepalive timer is reset and delayed by 60 seconds, which is equivalent to setting the keepalive interval to 70 seconds. In this way, the sending of keepalive packets is delayed. If traffic is updated within the 70 seconds, the keepalive timer is reset and delayed by 60 seconds.
3.        Configure the VT interface not to perform keepalive detection when PPP users have traffic.
By default, keepalive packets are sent to detect online users after the keepalive interval expires no matter whether the user traffic is updated within a keepalive interval.
About fast reply for keepalive packets
This feature allows the hardware to automatically identify and reply to incoming keepalive requests, which can prevent DDoS attacks.
This feature is only supported by CSPEX (except CSPEX-1204 and CSPEX-1104-E) and CEPC cards.
2.        Enable fast reply for keepalive packets.
In standalone mode:
ppp keepalive fast-reply enable slot slot-number
In IRF mode:
ppp keepalive fast-reply enable chassis chassis-number slot slot-number
By default, fast reply is enabled for keepalive packets.
About PPP negotiation timeout time
The device starts the PPP negotiation timeout timer after sending a packet. If no response is received before the timer expires, the device sends the packet again.
If two ends of a PPP link vary greatly in the LCP negotiation packet processing rate, configure the delay timer on the end with a higher processing rate. The LCP negotiation delay timer prevents frequent LCP negotiation packet retransmission. After the physical layer comes up, PPP starts LCP negotiation when the delay timer expires. If PPP receives LCP negotiation packets before the delay timer expires, it starts LCP negotiation immediately.
3.        (Optional.) Configure the LCP negotiation delay timer.
ppp lcp delay milliseconds
By default, PPP starts LCP negotiation after the physical layer comes up.
4.        Configure the negotiation timeout time.
ppp timer negotiate seconds
The default setting is 3 seconds.
3.        Enable IP address negotiation.
ip address ppp-negotiate
By default, IP address negotiation is not enabled.
If you execute this command and the ip address command multiple times, the most recent configuration takes effect. For more information about the ip address command, see Layer 3—IP Services Command Reference.
About IP address negotiation on the server
Configure the server to assign an IP address to a client by using the following methods:
·          Method 1: Specify an IP address for the client on the server interface.
·          Method 2: Specify a PPP or DHCP address pool on the server interface.
·          Method 3: Associate a PPP or DHCP address pool with an ISP domain.
·          Method 4: Authorize an IP address to a client by using the AAA server.
Restrictions and guidelines for IP address negotiation on the server
For clients requiring no authentication, you can use either method 1 or method 2. When both method 1 and method 2 are configured, the most recent configuration takes effect.
For clients requiring authentication, you can use one or more of the four methods. When multiple methods are configured, method 4 takes precedence over method 3, and method 3 takes precedence over method 1 or method 2. When both method 1 and method 2 are configured, the most recent configuration takes effect.
When you use method 4, enable DHCP on the AAA server by using the dhcp enable command and authorize an IP address to the client. For more information about the dhcp enable command, see DHCP commands in BRAS Services Command Reference.
PPP supports IP address assignment from a PPP or DHCP address pool. If you use a pool name that identifies both a PPP address pool and a DHCP address pool, the system uses the PPP address pool.
When assigning IP address to users through a PPP address pool, make sure the PPP address pool excludes the gateway IP address of the PPP address pool.
3.        Configure the interface to assign an IP address to the peer.
remote address ip-address
By default, an interface does not assign an IP address to the peer.
4.        Configure an IP address for the interface.
ip address ip-address
By default, no IP address is configured on an interface.
2.        Configure a PPP address pool.
ip pool pool-name start-ip-address [ end-ip-address ] [ group group-name ]
3.        (Optional.) Enable new IP address assignment.
ip pool pool-name allocate-new-ip enable
By default, new IP address assignment is disabled.
4.        (Optional.) Configure a gateway address for the PPP address pool.
ip pool pool-name gateway ip-address [ vpn-instance vpn-instance-name ]
By default, the PPP address pool is not configured with a gateway address.
5.        (Optional.) Configure a PPP address pool route.
ppp ip-pool route ip-address { mask-length | mask } [ vpn-instance vpn-instance-name ]
By default, no PPP address pool route exists.
The destination network of the PPP address pool route must include the PPP address pool.
6.        Enter interface view.
7.        Configure the interface to assign an IP address from the configured PPP address pool to the peer.
remote address pool pool-name
8.        Configure an IP address for the interface.
Specifying a DHCP address pool on the server interface
2.        Configure DHCP.
¡  If the server acts as a DHCP server, perform the following tasks:
-      Configure the DHCP server.
-      Configure a DHCP address pool on the server.
¡  If the server acts as a DHCP relay agent, perform the following tasks:
-      Configure the DHCP relay agent on the server.
-      Configure a DHCP address pool on the remote DHCP server.
-      Enable the DHCP relay agent to record relay entries.
-      Configure a DHCP relay address pool.
For information about configuring a DHCP server and a DHCP relay agent, see BRAS Services Configuration Guide.
3.        Enter interface view.
4.        Configure the interface to assign an IP address from the configured DHCP address pool to the peer.
5.        (Optional.) Configure the method of generating DHCP client IDs when PPP users act as DHCP clients.
remote address dhcp client-identifier { { callingnum | username } [ session-info ] | session-info }
By default, the method of generating DHCP client IDs when PPP users act as DHCP clients is not configured.
When DHCP client IDs are generated based on PPP usernames, make sure different users use different PPP usernames to come online.
6.        Configure an IP address for the interface.
Associating a PPP address pool with an ISP domain
By default, no PPP address pool is configured.
3.        (Optional.) Enable new IP address allocation.
By default, new IP address allocation is disabled.
6.        Enter ISP domain view.
domain name isp-name
7.        Associate the ISP domain with the configured PPP address pool for address assignment.
authorization-attribute ip-pool pool-name
By default, no PPP address pool is associated.
For more information about this command, see AAA commands in BRAS Services Command Reference.
8.        Return to system view.
9.        Enter interface view.
10.     Configure an IP address for the interface.
Associating a DHCP address pool with an ISP domain
2.        Configure DHCP.
3.        Enter ISP domain view.
4.        Associate the ISP domain with the configured DHCP address pool or DHCP relay address pool for address assignment.
By default, no DHCP address pool or DHCP relay address pool is associated.
5.        Return to system view.
7.        (Optional.) Configure the method of generating DHCP client IDs when PPP users act as DHCP clients.
Assigning an IPv6 address by using the NDRA method
1.        Enter interface view.
2.        Configure the interface to automatically generate a link-local address.
ipv6 address auto link-local
3.        Configure the prefix information in RA messages on the interface.
4.        Disable RA message suppression on the interface.
undo ipv6 nd ra halt
5.        Set the other stateful configuration flag (O) to 1 in RA advertisements to be sent.
ipv6 nd autoconfig other-flag
6.        Enable the DHCPv6 server.
ipv6 dhcp select server
7.        Return to system view.
8.        (Optional.) Configure a PPP IPv6 address network route.
ppp ipv6 route prefix/prefix-length [ vpn-instance vpn-instance-name ] [ preference preference | tag tag ] *
By default, no PPP IPv6 address network route is configured.
9.        Create an ISP domain and enter its view.
10.     Configure an IPv6 prefix authorized to the user in the ISP domain.
authorization-attribute ipv6-prefix ipv6-prefix prefix-length
Assigning an IPv6 address by using the IA_NA method
5.        Set the managed address configuration flag (M) to 1 in RA advertisements to be sent.
6.        Set the other stateful configuration flag (O) to 1 in RA advertisements to be sent.
7.        Enable the DHCPv6 server.
9.        Configure a DHCPv6 address pool and configure an ISP domain to authorize the address pool to users.
For more information, see DHCPv6 configuration and AAA configuration in BRAS Services Configuration Guide.
Assigning an IPv6 address by using the IA_PD method
3.        Disable RA message suppression on the interface.
4.        Enable the DHCPv6 server.
6.        Create a prefix pool and specify the prefix and the assigned prefix length for the pool.
ipv6 dhcp prefix-pool prefix-pool-number prefix prefix/prefix-len assign-len assign-len
7.        Create a DHCPv6 address pool and enter its view.
ipv6 dhcp pool pool-name
8.        Apply a prefix pool to the DHCPv6 address pool, so the DHCPv6 server can dynamically select a prefix from the prefix pool for the client.
prefix-pool prefix-pool-number [ preferred-lifetime preferred-lifetime valid-lifetime valid-lifetime ]
9.        Return to system view.
10.     Create an ISP domain and enter its view.
11.     Configure the user authorization attribute in the ISP domain.
authorization-attribute ipv6-pool pool-name
About IP segment match
This feature enables the local interface to check whether its IP address and the IP address of the remote interface are in the same network segment. If they are not, IPCP negotiation fails.
3.        Enable IP segment match.
ppp ipcp remote-address match
About DNS server IP address negotiation on the client
During PPP negotiation, the server will assign a DNS server IP address only for a client configured with the ppp ipcp dns request command. For some special devices to forcibly assign DNS server IP addresses to clients that do not initiate requests, configure the ppp ipcp dns admit-any command on these devices.
3.        Enable the device to request the peer for a DNS server IP address.
By default, a client does not request its peer for a DNS server IP address.
4.        Configure the device to accept the DNS server IP addresses assigned by the peer even though it does not request the peer for the DNS server IP addresses.
By default, a device does not accept the DNS server IP addresses assigned by the peer if it does not request the peer for the DNS server IP addresses.
This command is not necessary if the ppp ipcp dns request command is configured.
3.        Specify the primary and secondary DNS server IP addresses to be allocated to the peer in PPP negotiation.
ppp ipcp dns primary-dns-address [ secondary-dns-address ]
By default, a device does not allocate DNS server IP addresses to its peer if the peer does not request them.
After this command is configured, the server allocate DNS server IP addresses to a client that initiates requests.
About PPP link quality monitoring
PPP link quality monitoring (LQM) monitors the quality (packet loss ratio and packet error ratio) of PPP links (including those in MP bundles) in real time.
If PPP LQM is not enabled, each end of a PPP link periodically sends keepalives to its peer. If PPP LQM is enabled, Link Quality Reports (LQRs) packets replace keepalives to monitor the link.
The system uses received LQR packets to measure the link quality. If two consecutive measured results are below the close-percentage, the system shuts down the link. Then the system measures the link quality at an interval that is ten times the LQR interval. If three consecutive measured results are higher than the PPP LQM resume-percentage, the system brings up the link.
A shut-down link must experience a minimum of 30 keepalive intervals before it can come up again. As a best practice, do not set the keepalive interval to a large value.
If you enable PPP LQM on both sides of a PPP link, make sure both sides have the same PPP LQM settings. Typically, there is no need to enable PPP LQM on both sides of a PPP link.
This feature does not affect existing users.
3.        Enable PPP LQM.
ppp lqm close-percentage close-percentage [ resume-percentage resume-percentage ]
By default, PPP LQM is disabled.
About magic number check for PPP
In the PPP link establishment process, the magic number is negotiated. After the negotiation, both the local end and the peer end save their magic numbers locally.
The local end sends Echo-Request packets carrying its own magic number. When magic number check is enabled on both the local end and the peer end, the peer end will compare its own magic number with the magic number in the received Echo-Request packets. If they are the same, the link status is considered as normal, and the peer end replies with Echo-Reply packets carrying its own magic number. The local end also compares its own magic number with the magic number carried in the received Echo-Reply packets.
A link is disconnected and LCP negotiation is restarted when either of the following events occurs on either end:
·          When fast reply for keepalive packets is enabled:
¡  The magic number check fails for five Echo-Request packets in total.
¡  The magic number check fails for five consecutive Echo-Reply packets.
·          When fast reply for keepalive packets is disabled, the magic number check fails for five consecutive Echo-Request or Echo-Reply packets.
Only the end with magic number check enabled can check the magic number in received Echo-Request or Echo-Reply packets.
3.        Enable magic number check for PPP.
ppp magic-number-check
By default, magic number check is disabled for PPP.
About MRU check for PPP packets
In PPP Link Establishment phase, the Maximum-Receive-Unit (MRU) value is negotiated in the LCP negotiation. When the MTUs of interfaces on the two end of a link are different, PPP uses the smaller MTU as the link MTU.
By default, the device does not perform MRU check if the MTU in a received PPP packet is larger than the negotiated MRU. With MRU check enabled, the device discards a received PPP packet if the MTU in the packet is larger than the negotiated MRU.
As a best practice to enhance system security, enable MRU check. Otherwise, a fake peer might attack the device by sending a large number of PPP packets with MTUs larger than the negotiated MRU.
2.        Enable MRU check for PPP packets.
ppp mru-check enable
By default, MRU check for PPP packets is disabled.
About specifying that PPP users cannot come online successfully if the online requests do not carry usernames
The username format is userid@isp-name. A username is considered as empty when both the user ID and ISP domain name are empty. If the user ID is empty but the ISP domain name is not empty, the username is considered as non-empty.
By default, when PPP user online requests do not carry the usernames (the usernames are empty), the following rules apply:
·          For PPPoE users, the user MAC addresses in the requests are used as the usernames.
·          For L2TP users, the calling numbers in the requests are used as the usernames.
If the network environment needs strictly checking the username validity, you can configure this feature. With this feature configured, when the device receives online requests without usernames from PPPoE or L2TP users, the device does not use the user MAC addresses or calling numbers in the requests as usernames for AAA authentication, and the device directly returns authentication failure to users.
When the device uses the user MAC addresses or calling numbers in the requests as the usernames for AAA authentication, neither the contents nor the format of the information will be modified.
3.        Specify that PPP users cannot come online successfully if the online requests do not carry usernames on the VT interface.
ppp username check
By default, PPP users can come online successfully if the online requests do not carry usernames.
About source IP check for PPP users
By default, if a matching PPP user can be queried based on a received PPP packet, the PPP packet is considered as valid and sent to the CPU for processing.
In a low-security environment, attackers might forge a large number of PPP packets from valid PPP users and send them to the device. As a result, a large number of system resources are occupied or even exhausted, and packets from valid PPP users cannot be timely processed.
To avoid such malicious attacks, you can enable source IP check for PPP users. With this feature enabled, after the device queries a matching PPP user based on a received PPP packet, the device identifies whether the source IP address of the packet is the same as the IP address in the PPP user information. If the IP addresses are the same, the device processes the packet normally. If the IP addresses are different, the device drops the packet.
This feature takes effect only on IPv4 packets of PPPoE and L2TP users.
In a router-initiated PPPoE network, do not enable this feature. Otherwise, the hosts attached to the PPPoE client cannot access network resources.
3.        Enable source IP check for PPP users.
ppp source-ip-check
By default, source IP check is disabled for PPP users.
About PPP user blocking
This feature blocks a PPP user for a period if the user fails authentication consecutively for the specified number of times within the detection period. This feature helps prevent illegal users from using the method of exhaustion to obtain the password, and reduces authentication packets sent to the authentication server. Packets from the blocked users will be discarded during the blocking period, and will be processed when the blocking period expires.
This feature identify users by username and domain name. Users that have the same username but belong to different domains are processes as different users.
2.        Enable PPP user blocking.
ppp authentication chasten auth-failure auth-period blocking-period
By default, a PPP user will be blocked for 300 seconds if the consecutive authentication failures of the user reach 6 times within 60 seconds.
About the nas-port-type attribute
The nas-port-type attribute is used for RADIUS authentication and accounting. For information about the nas-port-type attribute, see RFC 2865.
3.        Configure the nas-port-type attribute.
nas-port-type { 802.11 | adsl-cap | adsl-dmt | async | cable | ethernet | g.3-fax | hdlc | idsl | isdn-async-v110 | isdn-async-v120 | isdn-sync | piafs | sdsl | sync | virtual | wireless-other | x.25 | x.75 | xdsl }
By default, the nas-port-type attribute is determined by the service type and link type of the PPP user (see Table 1).
Table 1 Default nas-port-type attribute
Service type
Nas-port-type attribute
PPPoE
ethernet
L2TP
virtual
About suppressing adding PPP peer host routers to the local direct router table
By default, PPP automatically adds the peer host routes to the local direct route table after the PPP link negotiation succeeds. The PPP links do not strictly require that the peer routes and local routes are on the same network segment. When one end is configured with an incorrect IP address, the peer end will add the incorrect host route to the local direct route table. Then, the incorrect route will be advertised in the network. To solve this problem, perform this task to suppress adding PPP peer host routes to the local direct route table.
3.        Suppress adding PPP peer host routes to the local direct route table.
ppp peer hostroute-suppress
About issuing ND prefix network routes
One prefix per user means that each PPPoE or L2TP user separately uses an IPv6 address prefix. With this feature configured, the device generates a static route for each user based on the IPv6 prefix information that a PPPoE or L2TP user obtains when coming online.
In the current software version, one prefix per user is supported only when the ND prefix pool is used to allocate prefixes to users by using NDRA. When the ipv6 dhcp prefix-pool command is used to create a prefix pool, for the online users to obtain prefix information, you must set the prefix length to 64 bits.
This feature takes effect only on the PPPoE server and the LNS side of L2TP in a one-prefix-per-user network. For more information about L2TP, see L2TP configuration in BRAS Services Configuration Guide.
3.        Enable issuing ND prefix network routes.
ppp nd-prefix-route enable
By default, issuing ND prefix network routes is disabled.
About the traffic accounting frequency mode for online PPP users
The device support the following frequency modes:
·          fast—For high accuracy of the PPP user traffic statistics, specify this mode.
·          normal—For medium accuracy of the PPP user traffic statistics, specify this mode.
·          slow—For low accuracy of the PPP user traffic statistics, specify this mode.
2.        Configure the traffic accounting frequency mode for online PPP users.
ppp flow-statistics frequency { fast | normal | slow }
By default, the traffic accounting frequency mode for online PPP users is normal.
About PPP accounting
PPP accounting collects PPP statistics, including the numbers of received and sent PPP packets and bytes. AAA can use the PPP statistics for accounting. For more information about AAA, see AAA configuration in BRAS Services Configuration Guide.
3.        Enable PPP accounting.
ppp account-statistics enable [ acl { acl-number | name acl-name } ]
By default, PPP accounting is disabled.
About logging for PPP users
The PPP user logging feature enables the device to generate PPP logs and send them to the information center. Logs are generated after a user comes online, goes offline, or fails to come online. A log entry contains information such as the username, IP address, interface name, inner VLAN, outer VLAN, MAC address, and failure causes. For information about the log destination and output rule configuration in the information center, see Network Management and Monitoring Configuration Guide.
As a best practice, disable this feature to prevent excessive PPP log output.
2.        Enable logging for PPP users.
ppp access-user log enable [ successful-login | failed-login | normal-logout | abnormal-logout ] *
By default, logging is disabled for PPP users.
About service tracing objects
You can create service tracing objects to trace access user information, such as login and logout information. By specifying match parameters, you can trace the specific access users.
This feature is resource intensive. As a best practice, configure this feature only when troubleshooting devices.
A primary/standby switchover causes the service tracing object configuration to be ineffective.
2.        Configure service tracing object.
trace access-user object object-id { access-mode { lns | pppoe } | calling-station-id calling-station-id | c-vlan vlan-id | interface interface-type interface-number | ip-address ip-address | mac-address mac-address | s-vlan vlan-id | tunnel-id tunnel-id | username user-name } * [ aging time |  output { file file-name | syslog-server server-ip-address | vty } ] *
If you specify an interface, the service tracing object becomes ineffective when the slot or subslot that hosts the specified interface is rebooted.
Display BAS interface binding information.
display bas-interface
Display BAS interface information.
display interface [ bas-interface [ interface-number ] ] [ brief [ description | down ] ]
Display VT interface information.
display interface [ virtual-template [ interface-number ] ] [ brief [ description | down ] ]
Display PPP address pools.
display ip pool [ pool-name | group group-name ]
Display information about PPP access users.
In standalone mode:
display ppp access-user { ip-address ipv4-address [ vpn-instance ipv4-vpn-instance-name ] | ipv6-address ipv6-address [ vpn-instance ipv6-vpn-instance-name ] | mac-address mac-address [ interface interface-type interface-number [ s-vlan svlan-minimum [ svlan-maximum ] [ c-vlan cvlan-minimum [ cvlan-maximum ] ] ] ] | lac-ip lac-ip-address | lns-ip lns-ip-address | { domain domain-name | interface interface-type interface-number | ip-type { ipv4 | ipv6 | dual-stack } | pool pool-name | s-vlan svlan-minimum [ svlan-maximum ] [ c-vlan cvlan-minimum [ cvlan-maximum ] ] | service-type { hsi | stb | voip } | user-address-type { ds-lite | ipv6 | nat64 | private-ds | private-ipv4 | public-ds | public-ipv4 } | user-type { lac | lns | pppoe } | username user-name | vpn-instance vpn-instance-name } * } [ count | verbose ] [ slot slot-number ]
In IRF mode:
display ppp access-user { ip-address ipv4-address [ vpn-instance ipv4-vpn-instance-name ] | ipv6-address ipv6-address [ vpn-instance ipv6-vpn-instance-name ] | mac-address mac-address [ interface interface-type interface-number [ s-vlan svlan-minimum [ svlan-maximum ] [ c-vlan cvlan-minimum [ cvlan-maximum ] ] ] ] | lac-ip lac-ip-address | lns-ip lns-ip-address | { domain domain-name | interface interface-type interface-number | ip-type { ipv4 | ipv6 | dual-stack } | pool pool-name | s-vlan svlan-minimum [ svlan-maximum ] [ c-vlan cvlan-minimum [ cvlan-maximum ] ] | service-type { hsi | stb | voip } | user-address-type { ds-lite | ipv6 | nat64 | private-ds | private-ipv4 | public-ds | public-ipv4 } | user-type { lac | lns | pppoe } | username user-name | vpn-instance vpn-instance-name } * } [ count | verbose ] [ chassis chassis-number slot slot-number ]
Display information about TCP connections established by PPP users.
display ppp access-user tcp-connection interface interface-type interface-number session-id session-id
Display blocking information about PPPoE users.
display ppp chasten statistics
Display PPP chasten statistics.
display ppp chasten user { auth-failed | blocked } [ username user-name ]
Display offline reason statistics about PPP users.
In standalone mode:
display ppp offline-reason statistics [ slot slot-number ]
In IRF mode:
display ppp offline-reason statistics [ chassis chassis-number slot slot-number ]
Display PPP negotiation packet statistics.
In standalone mode:
display ppp packet statistics [ slot slot-number ]
In IRF mode:
display ppp packet statistics [ chassis chassis-number slot slot-number ]
Display service tracing object statistics.
display trace access-user [ object object-id ]
Log off a PPP user.
In standalone mode:
reset ppp access-user { ip-address ipv4-address [ vpn-instance ipv4-vpn-instance-name ] | ipv6-address ipv6-address [ vpn-instance ipv6-vpn-instance-name ] | mac-address mac-address [ interface interface-type interface-number [ s-vlan svlan-minimum [ svlan-maximum ] [ c-vlan cvlan-minimum [ cvlan-maximum ] ] ] ] | { domain domain-name | interface interface-type interface-number | ip-type { ipv4 | ipv6 | dual-stack } | pool pool-name | s-vlan svlan-minimum [ svlan-maximum ] [ c-vlan cvlan-minimum [ cvlan-maximum ] ] | service-type { hsi | stb | voip } | user-address-type { ds-lite | ipv6 | nat64 | private-ds | private-ipv4 | public-ds | public-ipv4 } | user-type { lac | lns | pppoe } | username user-name | vpn-instance vpn-instance-name } * } [ slot slot-number ]
In IRF mode:
reset ppp access-user { ip-address ipv4-address [ vpn-instance ipv4-vpn-instance-name ] | ipv6-address ipv6-address [ vpn-instance ipv6-vpn-instance-name ] | mac-address mac-address [ interface interface-type interface-number [ s-vlan svlan-minimum [ svlan-maximum ] [ c-vlan cvlan-minimum [ cvlan-maximum ] ] ] ] | { domain domain-name | interface interface-type interface-number | ip-type { ipv4 | ipv6 | dual-stack } | pool pool-name | s-vlan svlan-minimum [ svlan-maximum ] [ c-vlan cvlan-minimum [ cvlan-maximum ] ] | service-type { hsi | stb | voip } | user-address-type { ds-lite | ipv6 | nat64 | private-ds | private-ipv4 | public-ds | public-ipv4 } | user-type { lac | lns | pppoe } | username user-name | vpn-instance vpn-instance-name } * } [ chassis chassis-number slot slot-number ]
Unblock PPP users.
reset ppp chasten blocked-user [ username user-name ]
Clear offline reason statistics about PPP users.
In standalone mode:
reset ppp offline-reason statistics [ slot slot-number ]
In IRF mode:
reset ppp offline-reason statistics [ chassis chassis-number slot slot-number ]
Clear PPP negotiation packet statistics.
In standalone mode:
reset ppp packet statistics [ slot slot-number ]
In IRF mode:
reset ppp packet statistics [ chassis chassis-number slot slot-number ]
As shown in Figure 2, configure Router A to authenticate Router B by using PAP, but Router B not to authenticate Router A.
Figure 2 Network diagram
1.        Configure Router A:
# Create a user account for Router B.
[RouterA] local-user userb class network
# Set a password for the user account.
[RouterA-luser-network-userb] password simple passb
# Set the service type of the user account to PPP.
[RouterA-luser-network-userb] service-type ppp
[RouterA-luser-network-userb] quit
# Enable PPP encapsulation on Serial 3/1/1:0. By default, an interface uses PPP encapsulation.
[RouterA] interface serial 3/1/1:0
[RouterA-Serial3/1/1:0] link-protocol ppp
# Set the authentication mode to PAP.
[RouterA-Serial3/1/1:0] ppp authentication-mode pap domain system
# Assign an IP address to Serial 3/1/1:0.
[RouterA-Serial3/1/1:0] ip address 200.1.1.1 16
[RouterA-Serial3/1/1:0] quit
# Configure local authentication for the PPP users in the default ISP domain (system).
[RouterA] domain name system
[RouterA-isp-system] authentication ppp local
2.        Configure Router B:
<RouterB> system-view
[RouterB] interface serial 3/1/1:0
[RouterB-Serial3/1/1:0] link-protocol ppp
# On Serial 3/1/1:0, configure the PAP username and password sent from Router B to Router A when Router B is authenticated by Router A using PAP.
[RouterB-Serial3/1/1:0] ppp pap local-user userb password simple passb
# Assign an IP address to Serial 3/1/1:0 of Router B.
[RouterB-Serial3/1/1:0] ip address 200.1.1.2 16
# Use the display interface serial command to display information about Serial 3/1/1:0 of Router B.
[RouterB-Serial3/1/1:0] display interface serial 3/1/1:0
Serial3/1/1:0
Current state: UP
Line protocol state: UP
Description: Serial3/1/1:0 Interface
Bandwidth: 64kbps
Hold timer: 10 seconds, retry times: 5
Internet address: 200.1.1.2/16 (primary)
Link layer protocol: PPP
LCP: opened, IPCP: opened
The output shows that:
·          The physical layer status and link layer status of the interface are both up.
·          The states of LCP and IPCP are both Opened, indicating that PPP negotiation has succeeded.
# Verify that Router A and Router B can ping each other.
[RouterB-Serial3/1/1:0] ping 200.1.1.1
5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss Ping 200.1.1.1 (200.1.1.1): 56 data bytes, press CTRL_C to break
56 bytes from 200.1.1.1: icmp_seq=0 ttl=128 time=3.197 ms
56 bytes from 200.1.1.1: icmp_seq=1 ttl=128 time=2.594 ms
56 bytes from 200.1.1.1: icmp_seq=2 ttl=128 time=2.739 ms
56 bytes from 200.1.1.1: icmp_seq=3 ttl=128 time=1.738 ms
56 bytes from 200.1.1.1: icmp_seq=4 ttl=128 time=1.744 ms
--- Ping statistics for 200.1.1.1 ---
round-trip min/avg/max/std-dev = 1.738/2.402/3.197/0.576 ms
As shown in Figure 3, configure Router A and Router B to authenticate each other.
Figure 3 Network diagram
# Configure the PAP username and password sent from Router A to Router B when Router A is authenticated by Router B using PAP.
[RouterA-Serial3/1/1:0] ppp pap local-user usera password simple passa
# Assign an IP address to Serial 3/1/1:0 of Router A.
# Create a user account for Router A on Router B.
[RouterB] local-user usera class network
[RouterB-luser-network-usera] password simple passa
[RouterB-luser-network-usera] service-type ppp
[RouterB-luser-network-usera] quit
# Set the authentication mode to PAP on Serial 3/1/1:0.
[RouterB-Serial3/1/1:0] ppp authentication-mode pap domain system
[RouterB-Serial3/1/1:0] quit
[RouterB] domain name system
[RouterB-isp-system] authentication ppp local
[RouterB-isp-system] display interface serial 3/1/1:0
Serial3/1/1:0
Current state: UP
Bandwidth: 64kbps
LCP opened, IPCP opened
# Verify that Router B can successfully ping Router A.
[RouterB-isp-system] ping 200.1.1.1
As shown in Figure 4, configure Router A to authenticate Router B by using CHAP.
Figure 4 Network diagram
Procedure (authenticator name is configured)
[RouterA-luser-network-userb] password simple hello
# On Serial 3/1/1:0, configure the username for Router A when Router A authenticates Router B.
[RouterA-Serial3/1/1:0] ppp chap user usera
# Set the authentication mode to CHAP on Serial 3/1/1:0.
[RouterA-Serial3/1/1:0] ppp authentication-mode chap domain system
[RouterB-luser-network-usera] password simple hello
# Configure the username for Router B when Router B is authenticated.
[RouterB-Serial3/1/1:0] ppp chap user userb
Procedure (authenticator name is not configured)
# On Serial 3/1/1:0, configure the username of Router B when Router B is authenticated.
# Set the default CHAP password on Serial 3/1/1:0.
[RouterB-Serial3/1/1:0] ppp chap password simple hello
Serial3/1/1:0
Current state: UP
Bandwidth: 64kbps
As shown in Figure 5, configure Router A to allocate an IP address to Serial 3/1/1:0 of Router B through PPP negotiation. The IP address is specified on Serial 3/1/1:0 of Router A.
Figure 5 Network diagram
# Configure an IP address to be assigned to the peer interface on Serial 3/1/1:0.
[RouterA-Serial3/1/1:0] remote address 200.1.1.10
# Configure an IP address for Serial 3/1/1:0.
2.        Enable IP address negotiation on Serial 3/1/1:0 of Router B.
[RouterB-Serial3/1/1:0] ip address ppp-negotiate
# Display summary information about Serial 3/1/1:0 on Router B.
[RouterB-Serial3/1/1:0] display interface serial 3/1/1:0 brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
Ser3/1/1:0         UP   UP       200.1.1.10
The output shows Serial 3/1/1:0 obtains IP address 200.1.1.10 through PPP negotiation.
# Verify that Router B can ping Serial 3/1/1:0 of Router A.
As shown in Figure 6, configure Router A to allocate an IP address from the PPP address pool on Serial 3/1/1:0 of Router A to Serial 3/1/1:0 of Router B through PPP negotiation.
Figure 6 Network diagram
# Configure PPP address pool aaa that contains IP addresses 200.1.1.10 through 200.1.1.20 for group AAA.
[RouterA] ip pool aaa 200.1.1.10 200.1.1.20 group AAA
# Configure a PPP address pool route.
[RouterA] ppp ip-pool route 200.1.1.1 24
# Configure Serial 3/1/1:0 to assign an IP address from aaa to the peer interface.
[RouterA-Serial3/1/1:0] remote address pool aaa
The output shows that Serial 3/1/1:0 has obtained IP address 200.1.1.10 through PPP negotiation.
[RouterB-Serial2/0] ping 200.1.1.1
# Display PPP address pool aaa on Serial 3/1/1:0 of Router A.
[RouterA-Serial3/1/1:0] display ip pool aaa
Group name: AAA
  In-use IP address count: 1
  Pool name       Start IP address    End IP address     Free    In use
  aaa             200.1.1.10          200.1.1.20         10      1
In-use IP addresses:
  IP address      Interface
  200.1.1.10      Ser3/1/1:0
The output shows that one IP address has been assigned.
As shown in Figure 7, configure Router A to allocate an IP address from the PPP address pool associated with the ISP domain to Serial 3/1/1:0 of Router B through PPP negotiation.
Figure 7 Network diagram
# Configure PPP address pool aaa that contains IP addresses 200.1.1.10 through 200.1.1.20 for the group AAA.
# Create a local user for Router B.
# Set a password for the local user.
[RouterA-luser-network-userb] password simple 123
# Set the service type to PPP for the local user.
# Create ISP domain bbb and associate aaa with bbb.
[RouterA] domain name bbb
[RouterA-isp-bbb] authorization-attribute ip-pool aaa
[RouterA-isp-bbb] quit
# Configure Serial 3/1/1:0 to authenticate the peer interface in bbb by using PAP.
[RouterA-Serial3/1/1:0] ppp authentication-mode pap domain bbb
# On Serial 3/1/1:0, configure the username and password for PAP authentication by Router A.
[RouterB-Serial3/1/1:0] ppp pap local-user userb password simple 123
# Enable IP address negotiation on Serial 3/1/1:0.
# Display the address pools on Serial 3/1/1:0 of Router A.
Group name: AAA
The output shows that one IP address of aaa has been assigned.
Configuring MP
About MP
Multilink PPP (MP) allows you to bind multiple PPP links into one MP bundle for increasing bandwidth. If a packet is larger than the minimum packet size for fragmentation, MP fragments the packet and distributes the fragments across multiple PPP links to the peer. The peer reassembles them into one packet and passes the packet to the network layer.
Benefit
In addition to increasing bandwidth, MP also provides link-layer load sharing, which can implement backup. MP fragmentation can reduce transmission delay, especially on low-speed links.
Interface type
MP is available to all physical or virtual interfaces with PPP encapsulation enabled, including serial and PPPoE interfaces. In MP configuration, however, as a best practice, include only one type of interfaces in an MP bundle.
MP supports binding interfaces on the same LPU rather than on different LPUs. MP binding on different subcards on the same LPU is not supported.
Only subcards MIC-ET16L, MIC-CLP2L, and MIC-CLP4L support MP binding.
To configure MP, perform the following tasks:
1.        Configuring MP through an MP-group interface
2.        (Optional.) Configuring short sequence number header format negotiation
3.        (Optional.) Configuring the MP endpoint descriptor
MP-group interfaces are intended only for MP. On an MP-group interface, only one bundle is allowed, and links cannot be bundled according to the peer descriptor.
Tasks at a glance
To configure MP by using through an MP-group VT interface, perform the following tasks:
1.        Creating an MP-group interface
2.        Assigning a physical interface to the MP-group interface
3.        (Optional.) Configuring the polling feature on the MP-group interface
4.        (Optional.) Configuring MP parameters
5.        (Optional.) Restoring the default settings for the MP-group interface
2.        Create an MP-group interface and enter its view.
interface mp-group mp-number
The default setting is interface name Interface, for example, MP-group3/1/1 Interface.
4.        ((Optional.) Set the MTU size of the interface.
mtu size
The default setting is 1500 bytes.
5.        (Optional.) Set the expected bandwidth of the interface.
6.        (Optional.) Bring up the interface.
By default, an interface is up.
3.        Assign the interface to a specified MP-group interface, and enable MP for the interface.
ppp mp mp-group mp-number
By default, an interface is enabled with PPP.
MP-group interfaces use the polling feature to check link state.
A MP-group interface sends keepalives at keepalive intervals to detect the availability of the peer. If the interface fails to receive keepalives when the keepalive retry limit is reached, it tears down the link and reports a link layer down event.
The keepalive interval of 0 disables sending of keepalives.
On a slow link, increase the keepalive interval to prevent false shutdown of the interface. This situation might occur when keepalives are delayed because a large packet is being transmitted on the link.
2.        Enter MP-group interface  view.
timer-hold seconds
The default setting is 10 seconds.
The default setting is 5.
2.        Enter MP-group interface or dialer interface view.
3.        (Optional.) Set the maximum number of links in an MP bundle.
ppp mp max-bind max-bind-num
The default setting is 16.
The configuration takes effect after you execute the shutdown and undo shutdown command on the interface.
4.        (Optional.) Set the minimum size of MP fragments.
ppp mp min-fragment size
The default setting is 128 bytes.
5.        (Optional.) Configure the timer for MP to wait for the expected fragment.
ppp mp timer lost-fragment seconds
By default, the timer is 30 seconds.
6.        (Optional.) Disable MP fragmentation.
ppp mp fragment disable
By default, MP fragmentation is enabled.
7.        (Optional.) Enable the strict load sharing mode.
ppp mp load-sharing mode strict-round-robin
By default, an MP-group interface uses the smart load sharing mode.
default
About short sequence number header format negotiation
By default, an MP bundle receives and transmits fragments with long sequence numbers.
Configure this feature on the local end or peer that receives fragments with short sequence numbers.
·          To receive fragments with short sequence numbers, the local end should request the peer to transmit short sequence numbers during LCP negotiation. After the negotiation succeeds, the peer transmits fragments with short sequence numbers.
·          To transmit fragments with short sequence numbers, the local end should ask the peer to send a request for receiving short sequence numbers during LCP negotiation. After the negotiation succeeds, the local end transmits fragments with short sequence numbers.
The sequence number format (long or short) of an MP bundle depends on the configuration of the first channel joining the MP bundle.
To negotiate the use of short sequence numbers on a common MP bundle, configure this feature on all its channels.
Configuring this feature will cause PPP re-negotiation.
3.        Trigger MP short sequence number header negotiation, specifying that the interface receive fragments with short sequence numbers after the negotiation succeeds.
ppp mp short-sequence
By default, long sequence number header format negotiation is performed.
About the MP endpoint descriptor
When MP is configured by using an MP-group interface, the negotiating endpoints do not base their binding decisions on the endpoint descriptor. By default, the endpoint descriptor of an interface in an MP-group interface is the MP-group interface name. When you configure an endpoint descriptor for the interface, the configured MP endpoint descriptor takes effect.
If the endpoint descriptor exceeds 20 bytes, the first 20 bytes are taken as the endpoint descriptor.
3.        Configure the MP endpoint descriptor.
ppp mp endpoint endpoint
The endpoint option carries the device name on an interface.
Display and maintenance commands for MP
Display information about one or all MP-group interfaces.
display interface [ mp-group [ interface-number ] ] [ brief [ description | down ] ]
Display MP information.
display ppp mp [ interface interface-type interface-number ]
Clear the statistics for MP-group interfaces.
reset counters interface [ mp-group [ interface-number ] ]
MP configuration examples
Example: Configuring an MP-group interface
As shown in Figure 8, to enable MP for Serial 3/1/1:0 and Serial 3/1/2:0, configure an MP-group interface.
Figure 8 Network diagram
# Create an MP-group interface, and configure an IP address for it.
[RouterA] interface mp-group 3/1/1
[RouterA-MP-group3/1/1] ip address 1.1.1.1 24
# Configure interface Serial 2/1/1.
[RouterA-MP-group3/1/1] quit
[RouterA-Serial3/1/1:0] ppp mp mp-group 3/1/1
[RouterA-Serial3/1/1:0] shutdown
[RouterA-Serial3/1/1:0] undo shutdown
# Configure interface Serial 3/1/2:0.
[RouterA] interface serial 3/1/2:0
[RouterA-Serial3/1/2:0] link-protocol ppp
[RouterA-Serial3/1/2:0] ppp mp mp-group 3/1/1
[RouterA-Serial3/1/2:0] shutdown
[RouterA-Serial3/1/2:0] undo shutdown
[RouterA-Serial3/1/2:0] quit
[RouterB] interface mp-group 3/1/1
[RouterB-MP-group3/1/1] ip address 1.1.1.2 24
[RouterB-MP-group3/1/1] quit
# Configure interface Serial 3/1/1:0.
[RouterB-Serial3/1/1:0] ppp mp mp-group 3/1/1
[RouterB-Serial3/1/1:0] shutdown
[RouterB-Serial3/1/1:0] undo shutdown
[RouterB] interface serial 3/1/2:0
[RouterB-Serial3/1/2:0] link-protocol ppp
[RouterB-Serial3/1/2:0] ppp mp mp-group 3/1/1
[RouterB-Serial3/1/2:0] shutdown
[RouterB-Serial3/1/2:0] undo shutdown
[RouterB-Serial3/1/2:0] quit
# Display MP information on Router A.
[RouterA] display ppp mp
Template: MP-group3/1/1
max-bind: 16, fragment: enabled, min-fragment: 128
Master link: MP-group3/1/1, Active members: 2, Bundle Multilink
Peer's endPoint descriptor: MP-group3/1/1
Sequence format: short (rcv)/long (sent)
Bundle Up Time: 2012/11/04  09:03:16:612
0 lost fragments, 0 reordered, 0 unassigned, 0 interleaved
Sequence: 0 (rcvd)/0 (sent)
Active member channels: 2 members
      Serial3/1/1:0               Up-Time:2012/11/04  09:03:16:613
      Serial3/1/2:0               Up-Time:2012/11/04  09:03:42:945
# Display information about interface MP-group 3/1/1 on Router A.
[RouterA] display interface mp-group 3/1/1
MP-group3/1/1
Current state: UP
Description: MP-group3/1/1 Interface
Bandwidth: 2048kbps
Internet address: 1.1.1.1/24 (primary)
LCP: opened, MP: opened, IPCP: opened
Physical: MP, baudrate: 2048000 bps
Last link flapping: Never
Input: 2 packets, 80 bytes, 0 drops
Output: 2 packets, 24 bytes, 0 drops
# Ping Router B from Router A.
[RouterA] ping 1.1.1.2
Ping 1.1.1.2 (1.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 1.1.1.2: icmp_seq=0 ttl=255 time=4.000 ms
56 bytes from 1.1.1.2: icmp_seq=1 ttl=255 time=1.000 ms
56 bytes from 1.1.1.2: icmp_seq=2 ttl=255 time=0.000 ms
56 bytes from 1.1.1.2: icmp_seq=3 ttl=255 time=7.000 ms
56 bytes from 1.1.1.2: icmp_seq=4 ttl=255 time=1.000 ms
--- Ping statistics for 1.1.1.2 ---
round-trip min/avg/max/std-dev = 0.000/2.600/7.000/2.577 ms
