- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-Login management configuration
- 03-RBAC configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-ISSU configuration
- 09-Device management configuration
- 10-Python configuration
- 11-License management(HP不支持)
- 12-Preprovisioning feature configuration
- 13-Automatic configuration
| 12-Preprovisioning feature configuration | 44.30 KB |
Configuring preprovisioning
Overview
Preprovisioning allows you to preconfigure interfaces on an offline module. In this release, interface cards can be preprovisioned.
With preprovisioning, you can configure a module before installing or attaching the module to the device. The preprovisioned settings are applied when the module comes online.
You can also enable preprovisioning for an online module and configure the module. The settings take effect immediately. After the module goes offline, the existing preprovisioned settings are retained and you can continue to change the existing settings or add new settings. The final settings are applied when the module comes online again.
Enabling preprovisioning
The device automatically creates interfaces when preprovisioning is enabled for a module. The display interface command does not display these interfaces until the module comes online.
After preprovisioning is enabled for a module, you can configure the module and its interfaces. To verify the preprovisioned settings, see "Displaying and maintaining preprovisioned settings." For the preprovisioned settings to survive a reboot, you must use the save command to save the settings to the next-startup configuration file.
When you disable preprovisioning for a slot, the device removes all preprovisioned commands from the slot.
To enable preprovisioning for a slot:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Select the slot to preprovision and enter slot view. |
In standalone mode: ·
In IRF mode: |
N/A |
3. Enable preprovisioning for the slot. |
provision model model |
By default, preprovisioning is disabled. You must make sure the specified model matches the model of the interface card you want to preprovision. If the model information does not match, the interface card cannot come online. |
Task |
Command |
Remarks |
Display the preprovisioned commands that were not applied to preprovisioned modules that came online. |
display provision failed-config |
After preprovisioned modules come online, you can use this command to determine the application result of preprovisioned settings. A preprovisioned command cannot be applied if it conflicts with the running configuration. |
Clear application failure records for preprovisioned commands. |
reset provision failed-config |
N/A |
