04-Layer 3—IP Services Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S12500-X & S12500X-AF Switch Series Configuration Guides-Release 113x-6W10104-Layer 3—IP Services Configuration Guide
00-Preface
00-Preface 83.68 KB
Preface
The H3C S12500-X & S12500X-AF documentation set includes 17 configuration guides. These guides describe the software features for the H3C S12500-X & S12500X-AF Switch Series running Release 1135 and later, and guide you through the software configuration procedures. These guides also provide configuration examples to help you apply software features to different network scenarios.
The Layer 3—IP Services Configuration Guide describes IP services fundamentals and configurations.
This preface includes:
·          Audience
·          Conventions
·          Obtaining documentation
·          Technical support
·          Documentation feedback
Audience
·          Network planners
·          Field technical support and servicing engineers
·          Network administrators working with the S12500-X & S12500X-AF series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Network topology icons
Represents an access point.
Represents a security product, such as a firewall, UTM, multiservice security gateway, or load-balancing device.
Represents a security card, such as a firewall, load-balancing, NetStream, SSL VPN, IPS, or ACG card.
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
Access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents]—Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions]—Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download]—Provides the documentation released with the software version.
Technical support
service@h3c.com
http://www.h3c.com
We appreciate your comments.
