- 04-Layer 3 - IP Services Configuration Examples
- 01-H3C_DHCP_Snooping_Configuration_Examples
- 02-H3C_GRE_with_OSPF_Configuration_Examples
- 03-H3C_GRE_Tunnel_Configuration_Examples
- 04-H3C_IPv6_over_IPv4_Manual_Tunneling_with_OSPFv3_Configuration_Examples
- 05-H3C_ISATAP_Tunnel_and_6to4_Tunnel_Configuration_Examples
- 06-H3C_IP_Unnumbered_Configuration_Examples
- 07-H3C_Cross-Subnet_Dynamic_IP_Address_Allocation_Configuration_Examples
06-H3C_IP_Unnumbered_Configuration_Examples | 69.54 KB |
H3C IP Unnumbered Configuration Examples
Copyright © 2018 New H3C Technologies Co., Ltd. All rights reserved. No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of New H3C Technologies Co., Ltd. The information in this document is subject to change without notice. |
Introduction
This document provides IP unnumbered configuration examples.
This feature enables an interface to borrow an IP address from another interface on the device when the borrowing interface does not have any IP addresses. The borrowing interface is called IP unnumbered interface.
This document assumes that you have basic knowledge of H3C IP unnumbered.
When you configure IP unnumbered, follow these restrictions and guidelines:
· Loopback interfaces cannot borrow IP addresses of other interfaces.
· An interface cannot borrow an IP address from an unnumbered interface.
Example: Configuring IP unnumbered
As shown in Figure 1, Group A and Group B are two private IPv4 networks. Device A and Device C will establish a GRE tunnel to interconnect Group 1 and Group 2.
To save IP address space, configure tunnel interface Tunnel 1 to borrow an IP address from the loopback interface loopback 0.
Software versions used
This configuration example was created and verified on S10500X-CMW710-R7557.
Procedures
Configuring Device A
1. Assign IP addresses to the interfaces:
# Assign an IP address to VLAN-interface 12.
[DeviceA] interface vlan-interface 12
[DeviceA-Vlan-interface12] ip address 12.12.12.1 24
[DeviceA-Vlan-interface12] quit
# Assign IP addresses to other interfaces in the same way an IP address is assigned to VLAN-interface 12. (Details not shown.)
2. Configure OSPF:
[DeviceA] ospf 1
# Create Area 0 and specify VLAN-interface 12 whose IP address is on network 12.12.12.0/24 to run OSPF in Area 0.
[DeviceA-ospf-1] area 0
[DeviceA-ospf-1-area-0.0.0.0] network 12.12.12.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] quit
[DeviceA-ospf-1] quit
3. Configure a GRE tunnel:
# Create service loopback group 1 and specify the unicast tunnel service for the group.
[DeviceA] service-loopback group 1 type tunnel
# Assign Ten-GigabitEthernet 3/0/3 to the service loopback group.
[DeviceA] interface ten-gigabitethernet 3/0/3
[DeviceA-Ten-GigabitEthernet3/0/3] port service-loopback group 1
[DeviceA-Ten-GigabitEthernet3/0/3] quit
# Create a tunnel interface Tunnel 1, and specify the tunnel mode as GRE/IPv4.
[DeviceA] interface tunnel 1 mode gre
# Specify 12.12.12.1 as the source address of interface Tunnel 1.
[DeviceA-Tunnel1] source 12.12.12.1
# Specify 23.23.23.3 as the destination address of interface Tunnel 1.
[DeviceA-Tunnel1] destination 23.23.23.3
# Configure interface Tunnel 1 to borrow an IP address from loopback 0.
[DeviceA-Tunnel1] ip address unnumbered interface loopback 0
[DeviceA-Tunnel1] quit
# Configure a static route from Device A through the tunnel interface to Group B.
[DeviceA] ip route-static 10.2.1.0 255.255.255.0 tunnel 1
Configuring Device B
[DeviceB] interface vlan-interface 12
[DeviceB-Vlan-interface12] ip address 12.12.12.2 24
[DeviceB-Vlan-interface12] quit
# Assign an IP address to VLAN-interface 23 in the same way an IP address is assigned to VLAN-interface 12. (Details not shown.)
2. Configure OSPF:
# Enable OSPF process 1.
[DeviceB] ospf 1
# Create Area 0 and specifyVLAN-interface 12 whose IP address is on network 12.12.12.0/24 to run OSPF in Area 0.
[DeviceB-ospf-1] area 0
[DeviceB-ospf-1-area-0.0.0.0] network 12.12.12.0 0.0.0.255
# Create Area 0 and specify VLAN-interface 23 whose IP address is on network 23.23.23.0/24 to run OSPF in Area 0.
[DeviceB-ospf-1-area-0.0.0.0] network 23.23.23.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] quit
[DeviceB-ospf-1] quit
Configuring Device C
#Assign an IP address to VLAN-interface 23.
<DeviceC> system-view
[DeviceC] interface vlan-interface 23
[DeviceC-Vlan-interface10] ip address 23.23.23.3 24
[DeviceC-Vlan-interface10] quit
# Assign IP addresses to other interfaces in the same way an IP address is assigned to VLAN-interface 23. (Details not shown.)
2. Configure OSPF:
[DeviceC] ospf 1
[DeviceC-ospf-1] area 0
[DeviceC-ospf-1-area-0.0.0.0] network 23.23.23.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] quit
[DeviceC-ospf-1] quit
[DeviceC] service-loopback group 1 type tunnel
[DeviceC] interface ten-gigabitethernet 3/0/3
[DeviceC-Ten-GigabitEthernet3/0/3] port service-loopback group 1
[DeviceC-Ten-GigabitEthernet3/0/3] quit
[DeviceC] interface tunnel 1 mode gre
# Specify 23.23.23.3 as the source address of interface Tunnel 1.
[DeviceC-Tunnel1] source 23.23.23.3
# Specify 12.12.12.1 as the destination address of interface Tunnel 1.
[DeviceC-Tunnel1] destination 12.12.12.1
[DeviceC-Tunnel1] ip address unnumbered interface loopback 0
[DeviceC-Tunnel1] quit
# Configure a static route from Device C through the tunnel interface to Group A.
[DeviceC] ip route-static 10.1.1.0 255.255.255.0 tunnel 1
This example uses Device A to verify the configuration.
# Verify that the interface Tunnel 1 has borrowed the IP address 8.8.8.8/32 from loopback 0.
[DeviceA] display interface tunnel 1
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64kbps
Maximum Transmit Unit: 1476
Internet Address is 8.8.8.8/32 Unnumbered
Tunnel source 12.12.12.1, destination 23.23.23.3
Tunnel keepalive disabled
Tunnel TTL 255
Tunnel protocol/transport GRE/IP
GRE key disabled
Checksumming of GRE packets disabled
Input: 11 packets, 924 bytes, 0 drops
Output: 10 packets, 840 bytes, 0 drops
# Verify that VLAN-interface 10 on Device A can ping the IP address of VLAN-interface 10 on Device C.
[DeviceA] ping -a 10.1.1.1 10.2.1.1
Ping 10.2.1.1 (10.2.1.1) from 10.1.1.1: 56 data bytes, press CTRL_C to break
56 bytes from 10.2.1.1: icmp_seq=0 ttl=255 time=32.641 ms
56 bytes from 10.2.1.1: icmp_seq=1 ttl=255 time=4.881 ms
56 bytes from 10.2.1.1: icmp_seq=2 ttl=255 time=4.816 ms
56 bytes from 10.2.1.1: icmp_seq=3 ttl=255 time=26.393 ms
56 bytes from 10.2.1.1: icmp_seq=4 ttl=255 time=43.003 ms
--- Ping statistics for 10.2.1.1 ---
round-trip min/avg/max/std-dev = 4.816/22.347/43.003/15.241 ms
Configuration files
· Device A:
ospf 1
area 0.0.0.0
vlan 10
vlan 12
interface LoopBack0
ip address 8.8.8.8 255.255.255.255
interface Vlan-interface10
interface Vlan-interface12
ip address 12.12.12.1 255.255.255.0
interface Ten-GigabitEthernet3/0/3
port link-mode bridge
interface Tunnel1 mode gre
ip address unnumbered interface LoopBack0
source 12.12.12.1
ip route-static 10.2.1.0 24 Tunnel1
· Device B:
ospf 1
area 0.0.0.0
vlan 12
vlan 23
ip address 12.12.12.2 255.255.255.0
interface Vlan-interface23
ip address 23.23.23.3 255.255.255.0
· Device C:
ospf 1
area 0.0.0.0
vlan 10
vlan 23
interface LoopBack0
ip address 9.9.9.9 255.255.255.255
ip address 10.2.1.1 255.255.255.0
source 23.23.23.3
ip route-static 10.1.1.0 24 Tunnel1
Related documentation
· H3C S10500X Switch Series Layer 3—IP Services Configuration Guide-R7557
· H3C S10500X Switch Series Layer 3—IP Services Command Reference-R7557
