03-Layer 2 - LAN Switching Configuration Examples
HomeSupportSwitchesS10500X SeriesConfigure & DeployConfiguration ExamplesH3C S10500X Switch Series Configuration Examples-Release7557P01-6W10003-Layer 2 - LAN Switching Configuration Examples
06-H3C_MVRP_Configuration_Examples
06-H3C_MVRP_Configuration_Examples 101.57 KB
H3C MVRP Configuration Examples
H3C_彩色.emf
Introduction
This document provides MVRP configuration examples.
This document assumes that you have basic knowledge of MVRP.
Example: Configuring MVRP
As shown in Figure 1:
·     Device A and Device B are core layer devices. Device C and Device D are aggregation layer devices.
·     Ports on all devices allow packets from VLANs 11 through 30 to pass through.
·     MSTP implements load balancing and link backup for traffic of VLANs 11 through 30 between the core layer devices and the aggregation layer devices.
Configure MVRP on all devices to synchronize and update VLAN information. When the network is stable, set the registration mode to fixed on Ten-GigabitEthernet 1/0/1 of Device B to maintain dynamic VLAN information.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     To assign all devices to the same MST region, configure the same settings for the following parameters on all the devices:
¡     Spanning tree mode. (This example uses the default mode MSTP.)
¡     MST region name. (This example uses the region name test.)
¡     MST region revision level. (This example uses the default setting 0.)
¡     VLAN-to-instance mappings. (This example maps VLANs 11 through 20 to MSTI 1, and maps VLANs 21 through 30 to MSTI 2.)
·     For MSTIs 1 and 2 to use different uplinks for backup, set Device A and Device B as the root bridges of MSTIs 1 and 2, respectively.
·     Make sure each MSTI is mapped to an existing VLAN on each device in the network.
·     MVRP takes effect only on trunk ports. You must set the port link type to trunk for MVRP participants.
Software versions used
This configuration example was created and verified on S10500X-CMW710-R7557.
When you configure MVRP, follow these restrictions and guidelines:
·     MVRP can work with STP, RSTP, or MSTP. Ports blocked by STP, RSTP, or MSTP can receive and send MVRP frames. MVRP cannot work with other link layer topology protocols, including service loopback, PVST, RRPP, and Smart Link.
·     On a Layer 2 aggregate interface, MVRP takes effect on both the aggregate interface and all Selected member ports in the link aggregation group.
·     MVRP configuration made on an aggregation group member port takes effect only after the port is removed from the aggregation group.
Procedures
Configuring Device A
# Create VLANs 11 through 30.
[DeviceA] vlan 11 to 30
# Enter MST region view.
[DeviceA] stp region-configuration
# Set the MST region name to test.
[DeviceA-mst-region] region-name test
# Map VLANs 11 through 20 to MSTI 1.
[DeviceA-mst-region] instance 1 vlan 11 to 20
# Map VLANs 21 through 30 to MSTI 2.
[DeviceA-mst-region] instance 2 vlan 21 to 30
# Activate the MST region configuration.
[DeviceA-mst-region] active region-configuration
[DeviceA-mst-region] quit
# Configure Device A as the root bridge of MSTI 1.
[DeviceA] stp instance 1 root primary
# Enable the spanning tree feature globally.
[DeviceA] stp global enable
# Enable MVRP globally.
[DeviceA] mvrp global enable
# Configure the ports Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/3 as trunk ports, assign the ports to VLANs 11 through 30, and enable MVRP on these ports.
[DeviceA] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/3
[DeviceA-if-range] port link-mode bridge
[DeviceA-if-range] port link-type trunk
[DeviceA-if-range] port trunk permit vlan 11 to 30
[DeviceA-if-range] mvrp enable
[DeviceA-if-range] undo shutdown
[DeviceA-if-range] quit
Configuring Device B
# Create VLANs 11 and 21.
[DeviceB] vlan 11
[DeviceB-vlan11] quit
[DeviceB] vlan 21
[DeviceB-vlan21] quit
[DeviceB] stp region-configuration
[DeviceB-mst-region] region-name test
[DeviceB-mst-region] instance 1 vlan 11 to 20
[DeviceB-mst-region] instance 2 vlan 21 to 30
[DeviceB-mst-region] active region-configuration
[DeviceB-mst-region] quit
# Configure Device B as the root bridge of MSTI 2.
[DeviceB] stp instance 2 root primary
[DeviceB] stp global enable
[DeviceB] mvrp global enable
[DeviceB] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/3
[DeviceB-if-range] port link-mode bridge
[DeviceB-if-range] port link-type trunk
[DeviceB-if-range] port trunk permit vlan 11 to 30
[DeviceB-if-range] mvrp enable
[DeviceB-if-range] undo shutdown
[DeviceB-if-range] quit
Configuring Device C
<DeviceC> system-view
[DeviceC] vlan 11
[DeviceC-vlan11] quit
[DeviceC] vlan 21
[DeviceC-vlan21] quit
[DeviceC-mst-region] region-name test
[DeviceC-mst-region] instance 1 vlan 11 to 20
[DeviceC-mst-region] instance 2 vlan 21 to 30
[DeviceC-mst-region] quit
[DeviceC] stp global enable
[DeviceC] mvrp global enable
# Configure the ports Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 as trunk ports, assign the ports to VLANs 11 through 30, and enable MVRP on these ports.
[DeviceC] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/2
[DeviceC-if-range] port link-mode bridge
[DeviceC-if-range] port link-type trunk
[DeviceC-if-range] port trunk permit vlan 11 to 30
[DeviceC-if-range] mvrp enable
[DeviceC-if-range] undo shutdown
[DeviceC-if-range] quit
Configuring Device D
Configure Device D in the same way Device C is configured. (Details not shown.)
Verifying MSTI topologies
# Display brief spanning tree information on Device A.
[DeviceA] display stp brief
 MST ID   Port                                Role  STP State   Protection
 1        Ten-GigabitEthernet1/0/1            DESI  FORWARDING  NONE
 1        Ten-GigabitEthernet1/0/2            DESI  FORWARDING  NONE
 1        Ten-GigabitEthernet1/0/3            DESI  FORWARDING  NONE
 2        Ten-GigabitEthernet1/0/1            ROOT  FORWARDING  NONE
 2        Ten-GigabitEthernet1/0/2            DESI  FORWARDING  NONE
 2        Ten-GigabitEthernet1/0/3            DESI  FORWARDING  NONE
# Display brief spanning tree information on Device B.
[DeviceB] display stp brief
 1        Ten-GigabitEthernet1/0/1            ROOT  FORWARDING  NONE
 2        Ten-GigabitEthernet1/0/1            DESI  FORWARDING  NONE
# Display brief spanning tree information on Device C.
[DeviceC] display stp brief
 1        Ten-GigabitEthernet1/0/1            ALTE  DISCARDING  NONE
 1        Ten-GigabitEthernet1/0/2            ROOT  FORWARDING  NONE
 2        Ten-GigabitEthernet1/0/2            ALTE  DISCARDING  NONE
# Display brief spanning tree information on Device D.
[DeviceD] display stp brief
 1        Ten-GigabitEthernet1/0/2            ALTE  DISCARDING  NONE
 2        Ten-GigabitEthernet1/0/1            ALTE  DISCARDING  NONE
 2        Ten-GigabitEthernet1/0/2            ROOT  FORWARDING  NONE
Based on the output, you can get MSTI topologies, as shown in Figure 2.
Figure 2 MSTI topologies
Verifying local VLAN information on all devices
# Display local VLAN information on Device A.
[DeviceA] display mvrp running-status
 -------[MVRP Global Info] -------
 Global Status     : Enabled
 Compliance-GVRP   : False
 ----[Ten-GigabitEthernet1/0/1] ----
 Registration Type              : Normal
 Registered VLANs :
  1(default), 11, 21
 Declared VLANs :
  1(default), 11-30
 Propagated VLANs :
  1(default), 11, 21
 ----[Ten-GigabitEthernet1/0/2] ----
 Registered VLANs :
  1(default), 11
 Declared VLANs :
  1(default), 11-30
 Propagated VLANs :
  1(default), 11
 ----[Ten-GigabitEthernet1/0/3] ----
 Registered VLANs :
  1(default), 11
 Declared VLANs :
  1(default), 11-30
 Propagated VLANs :
  1(default), 11
The output shows that all ports of Device A have declared VLANs 11 through 30.
# Display local VLAN information on Device B.
[DeviceB] display mvrp running-status
 Registered VLANs :
  1(default), 11-30
 Declared VLANs :
  1(default), 11, 21
 Propagated VLANs :
  1(default), 11-30
 Registered VLANs :
  21
 Declared VLANs :
  1(default), 11-30
 Propagated VLANs :
  21
 Registered VLANs :
  21
 Declared VLANs :
  1(default), 11-30
 Propagated VLANs :
  21
The output shows that:
·     Ten-GigabitEthernet 1/0/1 has registered and propagated VLANs 11 through 30.
·     Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3 have declared VLANs 11 through 30.
# Display local VLAN information on Device C.
[DeviceC] display mvrp running-status
 Registered VLANs :
  1(default), 11-30
 Declared VLANs :
  21
 Propagated VLANs :
  21-30
 Registered VLANs :
  1(default), 11-30
 Declared VLANs :
  1(default), 11
 Propagated VLANs :
  1(default), 11-20
[DeviceC]
·     Ten-GigabitEthernet 1/0/1 has registered VLANs 11 through 30. Because Ten-GigabitEthernet 1/0/1 is a blocked port in MSTI 1, the port propagated only VLANs 21 through 30.
·     Ten-GigabitEthernet 1/0/2 has registered VLANs 11 through 30. Because Ten-GigabitEthernet 1/0/2 is a blocked port in MSTI 2, the port propagated only VLANs 11 through 20.
# Display local VLAN information on Device D.
[DeviceD] display mvrp running-status
 Registered VLANs :
  1(default), 11-30
 Declared VLANs :
  1(default), 11
 Propagated VLANs :
  1(default), 11-20
 Registered VLANs :
  1(default), 11-30
 Declared VLANs :
  21
 Propagated VLANs :
  21-30
[DeviceD]
·     Ten-GigabitEthernet 1/0/1 has registered VLANs 11 through 30. Because Ten-GigabitEthernet 1/0/1 is a blocked port in MSTI 2, the port propagated only VLANs 11 through 20.
·     Ten-GigabitEthernet 1/0/2 has registered VLANs 11 through 30. Because Ten-GigabitEthernet 1/0/2 is a blocked port in MSTI 1, the port propagated only VLANs 21 through 30.
Verifying VLAN information after changing the registration mode
When the network is stable, set the MVRP registration mode to fixed on Ten-GigabitEthernet 1/0/1 of Device B. Then, verify that dynamic VLANs on the port will not be deregistered.
# Set the MVRP registration mode to fixed on Ten-GigabitEthernet 1/0/1 of Device B.
[DeviceB-Ten-GigabitEthernet1/0/1] mvrp registration fixed
# Remove VLAN 30 from Device A.
[DeviceA] undo vlan 30
# Display local VLAN information on Ten-GigabitEthernet 1/0/1 of Device B.
[DeviceB] display mvrp running-status interface ten-gigabitethernet 1/0/1
 Config Status                  : Enabled
 Running Status                 : Enabled
 Join Timer                     : 20 (centiseconds)
 Leave Timer                    : 60 (centiseconds)
 Periodic Timer                 : 100 (centiseconds)
 LeaveAll Timer                 : 1000 (centiseconds)
 Registration Type              : Fixed
 Registered VLANs :
  1(default), 21-30
 Declared VLANs :
  1(default), 21
 Propagated VLANs :
  1(default), 21-30
The output shows that VLAN information on Ten-GigabitEthernet 1/0/1 does not change after you set its MVRP registration mode to fixed.
# Create VLAN 30 on Device A.
[DeviceA] vlan 30
Verifying VLAN information after changing the network topology
Shut down Ten-GigabitEthernet 1/0/2 of Device C to change the network topology, and then verify the VLAN information on this port.
# Display VLAN information on Ten-GigabitEthernet 1/0/2 of Device C.
[DeviceC] display interface ten-gigabitethernet 1/0/2
Current state: UP
Line protocol state: UP
Port link-type: trunk
 VLAN Passing:   1(default vlan), 11-30
 VLAN permitted: 1(default vlan), 11-30
 Trunk port encapsulation: IEEE 802.1q
The output shows that VLAN 1 and VLANs 11 through 30 can pass through Ten-GigabitEthernet 1/0/2.
# Shut down Ten-GigabitEthernet 1/0/2.
[DeviceC] interface ten-gigabitethernet 1/0/2
[DeviceC-Ten-GigabitEthernet1/0/2] shutdown
[DeviceC-Ten-GigabitEthernet1/0/2] quit
 0        Ten-GigabitEthernet1/0/2            ROOT  FORWARDING  NONE
 0        Ten-GigabitEthernet1/0/2            ALTE  DISCARDING  NONE
Based on the output, you can get the topology of MSTI 1, as shown in Figure 3.
Figure 3 Topology of MSTI 1
# Display dynamic VLANs on Device C.
[DeviceC] display vlan dynamic
 Dynamic VLANs: 18
 The dynamic VLANs include:
 12-20, 22-30
 VLAN Passing:   1(default vlan), 11, 21
·     VLANs 1, 11, and 21 can pass through Ten-GigabitEthernet 1/0/2.
·     Ten-GigabitEthernet 1/0/2 failed to learn dynamic VLANs.
Configuration files
·     Device A:
 sysname DeviceA
 mvrp global enable
vlan 1
vlan 11 to 30
 region-name test
 stp instance 0 to 1 root primary
 stp global enable
 port trunk permit vlan 1 11 to 30
 mvrp enable
 mvrp enable
 mvrp enable
·     Device B:
 sysname DeviceB
 mvrp global enable
vlan 1
vlan 11
vlan 21
 region-name test
 stp global enable
 mvrp enable
 mvrp enable
 mvrp enable
·     Device C:
 sysname DeviceC
 mvrp global enable
vlan 1
vlan 11
vlan 21
 region-name test
 stp global enable
 mvrp enable
 mvrp enable
·     Device D:
 sysname DeviceD
 mvrp global enable
vlan 1
vlan 11
vlan 21
 region-name test
 stp global enable
 mvrp enable
 mvrp enable
Related documentation
·     H3C S10500X Switch Series Layer 2—LAN Switching Command Reference-R7557
·     H3C S10500X Switch Series Layer 2—LAN Switching Configuration Guide-R7557
