H3C Servers Purley Platform BIOS User Guide-1.00.XX-6W102
HomeSupportH3C Servers Purley Platform BIOS User Guide-1.00.XX-6W102
01-Text
01-Text 12.30 MB
1 BIOS overview· 1-1
2 Configuring basic BIOS settings· 2-1
Entering the BIOS setup utility· 2-1
Displaying processor information· 2-3
Displaying memory information· 2-4
Displaying onboard drive information· 2-5
Displaying HDM network information· 2-6
Setting HDM network information· 2-7
Configuring the BIOS passwords· 2-9
Restrictions and guidelines· 2-9
Setting the administrator password· 2-10
Setting the user password· 2-12
Deleting BIOS passwords· 2-14
Setting the system date and time· 2-17
Setting the BIOS boot mode· 2-18
Setting the server boot order 2-18
Configuring RAID·· 2-20
Restoring BIOS default settings· 2-20
3 BIOS menus· 3-1
Main menu· 3-1
Advanced menu· 3-3
Intel(R) Virtual RAID on CPU submenu· 3-5
Driver Health submenu· 3-17
Trusted Computing submenu· 3-17
ACPI Settings submenu· 3-22
Serial Port Console Redirection submenu· 3-22
Slot x:Port x· 3-28
PCI Subsystem Settings submenu· 3-30
Network Stack Configuration submenu· 3-31
CSM Configuration submenu· 3-32
NVMe Configuration submenu· 3-33
USB Configuration submenu· 3-35
Platform Configuration menu· 3-37
PCH Configuration submenu· 3-38
Miscellaneous Configuration submenu· 3-44
Server ME Configuration submenu· 3-46
Runtime Error Logging submenu· 3-47
Socket Configuration menu· 3-56
Processor Configuration submenu· 3-57
Common RefCode Configuration submenu· 3-60
UPI Configuration submenu· 3-62
Memory Configuration submenu· 3-64
IIO Configuration menu· 3-72
Advanced Power Management Configuration submenu· 3-81
Server Management menu· 3-88
Security menu· 3-101
Boot menu· 3-106
Save & Exit menu· 3-116
4 Mapping relations of PCH SATA/sSATA ports and drive backplane ports· 4-1
H3C UniServer R4900 G3 server 4-1
8LFF HDDs· 4-1
8LFF HDDs and 4LFF NVMe SSDs· 4-1
8SFF HDDs· 4-1
8SFF HDDs and 8SFF NVMe SSDs· 4-2
H3C UniServer R4700 G3 server 4-2
4LFF HDDs· 4-2
4LFF HDDs and 2SFF HDDs· 4-2
4SFF NVMe SSDs and 4SFF HDDs· 4-3
8SFF HDDs· 4-3
8SFF HDDs and 2SFF HDDs· 4-3
8SFF NVMe SSDs and 2SFF HDDs· 4-4
H3C UniServer R2900 G3 server 4-4
8LFF HDDs· 4-4
12LFF HDDs· 4-4
12LFF HDDs and 2SFF HDDs· 4-5
8LFF HDDs and 4LFF NVMe SSDs· 4-5
8SFF HDDs· 4-5
8SFF HDDs and 8SFF NVMe SSDs· 4-5
H3C UniServer R2700 G3 server 4-6
4LFF HDDs· 4-6
4LFF HDDs and 2SFF HDDs· 4-6
4SFF NVMe SSDs and 4SFF HDDs· 4-6
8SFF HDDs· 4-6
8SFF HDDs and 2SFF HDDs· 4-7
8SFF NVMe SSDs and 2SFF HDDs· 4-7
5 Acronyms and abbreviations· 5-1
1 BIOS overview
Basic Input and Output System (BIOS) is a non-volatile firmware stored in the system ROM of a server. It is used to perform hardware initialization during server booting and provide runtime services for the operating systems. As shown in Figure 1-1, the BIOS interacts between the server hardware and the operating system (OS).
Figure 1-1 Layered architecture of a server system
This document is applicable to the following products:
·          H3C UniServer R4900 G3.
·          H3C UniServer R4700 G3.
·          H3C UniServer R2900 G3.
·          H3C UniServer R2700 G3.
·      The information in this document is subject to change over time. For the most up-to-date information, contact H3C Support.
·      You can access the H3C website to obtain the most recent version of the BIOS.
This section provides procedures for the following tasks:
·          Entering the BIOS setup utility.
·          Displaying processor information.
·          Displaying memory information.
·          Displaying onboard drive information.
·          Displaying HDM network information.
·          Setting HDM network information.
·          Configuring the BIOS passwords.
·          Setting the system date and time.
·          Setting the BIOS boot mode.
·          Setting the server boot order.
·          Configuring RAID.
·          Restoring BIOS default settings.
1.        Connect a keyboard, mouse, and monitor to the server or enable the remote console from the HDM Web interface.
For information about enabling the remote console, see HDM online help.
2.        Start or restart the server.
3.        Enter the BIOS password if required during boot-up, as shown in Figure 2-1.
By default, no BIOS passwords are set. For information about BIOS password setup, see "Configuring the BIOS passwords."
·      If you enter an incorrect password for three consecutive times, the server will restart automatically.
·      To clear BIOS password settings, power off the server, jump pins 2 and 3 of system maintenance switch 2 on the server's system board, and then power on the server. For more information about the location of the system maintenance switch, see the user guide for the server.
Figure 2-1 Entering the BIOS password
4.        Press Del or Esc when the BIOS startup screen opens, as shown in Figure 2-2.
Figure 2-2 BIOS startup screen
5.        On the BIOS setup utility screen that opens, follow the instructions at the lower-right side of the screen to configure BIOS settings, as shown in Figure 2-3.
Table 2-1 shows detailed information about the operation keys.
Figure 2-3 BIOS setup utility screen
Table 2-1 Operation keys
Key
Select a screen.
Select an item or a submenu.
Enter
Select an item to edit its value or access a submenu.
Change the field value of the selected item.
ESC
Exit the BIOS setup utility or return to the previous screen.
F1
Display the general help window.
F2
Load previous values in BIOS.
F3
Load default values in BIOS.
F4
Save the current configuration and exit BIOS.
<K>
Scroll up the help area at the upper-right side of the screen.
<M>
Scroll down the help area at the upper-right side of the screen.
1.        Enter the BIOS setup utility. For more information, see "Entering the BIOS setup utility."
2.        Select Socket Configuration > Processor Configuration, and press Enter.
The Processor Configuration submenu that opens displays detailed information about processors, as shown in Figure 2-4.
For more information about the Processor Configuration submenu, see "Processor Configuration submenu."
Figure 2-4 Processor Configuration screen
捕获
2.        Select Socket Configuration > Memory Configuration, and press Enter.
The Memory Configuration submenu that opens displays memory capacity and frequency information, as shown in Figure 2-5.
For more information about the Memory Configuration submenu, see "Memory Configuration submenu."
Figure 2-5 Memory Configuration submenu
3.        Select Memory Topology, and press Enter.
The screen that opens displays detailed information about each DIMM.
Both the PCH SATA Configuration and PCH sSATA Configuration submenus display onboard drive information. This example uses the PCH SATA Configuration submenu. For more information about the submenus, see "PCH Configuration submenu."
To display drive information:
2.        Select Platform Configuration > PCH Configuration > PCH SATA Configuration, and press Enter.
The PCH SATA Configuration submenu that opens displays drive information, as shown in Figure 2-6.
Figure 2-6 PCH SATA Configuration submenu
2.        Select Server Management > HDM Network Configuration, and press Enter.
The HDM Network Configuration submenu that opens displays HDM network configuration information, as shown in Figure 2-7.
Figure 2-7 HDM Network Configuration screen
Perform this task to configure the IP address, subnet mask, and router IP address of HDM network ports and the method of obtaining the network information.
The HDM Network Configuration submenu content varies by bond mode setting.
·          EnabledDisplays network information about the HDM bonding network port.
·          Disabled—Displays network information about the HDM shared network port and HDM dedicated network port.
To avoid network storms, make sure the IP address of the HDM shared network port is on a network segment different than the HDM dedicated network port.
The submenu items are the same for all HDM network ports.
This example describes how to set network information for the HDM shared network port and HDM dedicated network port.
To set HDM network information:
The HDM Network Configuration submenu that opens displays HDM network configuration information, as shown in Figure 2-8.
Figure 2-8 HDM Network Configuration submenu
3.        Select Configuration Address Source for the HDM shared network port or the HDM dedicated network port. Then, press Enter.
4.        In the dialog box that opens, select the method for obtaining HDM network information. Options are:
¡  UnspecifiedRetains current configuration.
¡  StaticUses manually specified configuration.
¡  DynamicHdmDhcpUses network information obtained through DHCP.
Figure 2-9 Configuration Address Source dialog box
5.        Press Enter. If you select Static as the method for obtaining HDM network information, edit the following items and press Enter every time you finish editing:
¡  Station IP Address—Enter a static IP address. This item is required.
¡  Subnet Mask—Enter a subnet mask for the static IP address. This item is required.
¡  Router IP Address—Enter a gateway IP address.
¡  Router MAC Address—Enter a gateway MAC address.
6.        Press F4 to save the configuration.
The server will restart automatically.
BIOS passwords include an administrator password and a user password. By default, no passwords are set. The system prompts for a password at user login and grants user or administrator privileges to the login user according to the entered password.
To prevent unauthorized access and changes to the BIOS settings, set different BIOS user and BIOS administrator passwords for the server.
When you change a BIOS password, make sure the new password is different from the most recent three passwords.
The BIOS passwords must meet the following requirements:
·          A case-sensitive string of 8 to 20 characters. Valid characters are letters, digits, spaces, and special characters in Table 2-2.
·          Contain a minimum of two character types from uppercase letters, lowercase letters, and digits.
·          Contain a minimum of one space or special character.
Table 2-2 Special characters
Character name
Symbol
Character name
Symbol
Back quote
Tilde
Exclamation point
At sign
Pound sign
Dollar sign
Percent sign
Caret
Ampersand sign
Asterisk
Left parenthesis
Right parenthesis
Underscore
_
Plus sign
Minus sign
Equal sign
Left bracket
Right bracket
Back slash
Left brace
Right brace
Vertical bar
Semi-colon
Apostrophe
Colon
Quotation marks
Comma
Dot
Forward slash
Left angle bracket
Right angle bracket
Question mark
2.        Select Security > Administrator Password, and press Enter.
Figure 2-10 Setting the administrator password
3.        In the Create New Password dialog box that opens, enter an administrator password, and press Enter.
Figure 2-11 Creating an administrator password
4.        In the Confirm New Password dialog box that opens, enter the password again, and press Enter.
Figure 2-12 Confirming the administrator password
5.        Press F4 to save the configuration.
2.        Select Security > User Password, and press Enter.
Figure 2-13 Setting the user password
3.        In the Create New Password dialog box that opens, enter a user password, and press Enter.
Figure 2-14 Creating a user password
Figure 2-15 Confirming the user password
The procedure for deleting the administrator password and user password is the same. This section uses the administrator password as an example.
To delete the administrator password:
Figure 2-16 Selecting the administrator password
3.        In the Enter Current Password dialog box that opens, enter the current administrator password, and press Enter.
Figure 2-17 Entering the current administrator password
4.        Press Enter when the Create New Password dialog box opens as shown in Figure 2-18.
Figure 2-18 Deleting the administrator password
5.        In the WARNING dialog box that opens, select Yes, and press Enter.
Figure 2-19 Confirming the deletion
2.        Select the Main menu.
Figure 2-20 Main menu
3.        Set the system date:
a.    Select System Date.
The system date is in the format of mm/dd/yyyy.
b.    Press Enter to switch among the month, day, and year fields and use the following methods to modify the value:
-      Press + to increase the value by 1.
-      Press to decrease the value by 1.
-      Press numeric keys to enter a new value.
4.        Set the system time:
a.    Select System Time.
The system time uses the 24-hour time system and is in the format of hh:mm:ss.
b.    Press Enter to switch among the hour, minute, and second fields and use the following methods to modify the value:
About BIOS boot modes
The server supports two BIOS boot modes: legacy mode and UEFI mode.
By default, the boot mode is UEFI. For operating systems that support only the legacy mode, change the boot mode to legacy.
1.        Enter the BIOS setup screen. For more information, see "Entering the BIOS setup utility."
2.        Select Boot > Boot mode select, and press Enter.
3.        In the Boot mode select dialog box that opens, select LEGACY or UEFI, and press Enter.
Figure 2-21 Setting the BIOS boot mode
4.        Press F4 to save the configuration.
If the server has more than one boot devices of the same type, the Fixed Boot Order Priorities list displays only the first boot device. To change the first boot device, select the corresponding priorities submenu below the Fixed Boot Order Priorities list in the Boot screen.
2.        Select the Boot menu.
The Fixed Boot Order Priorities list shows the order in which the server attempts to boot from boot devices. The default boot order is hard disk > network > USB hard disk > USB CD/DVD > USB key > USB floppy > CD/DVD > UEFI AP as shown in Figure 2-22.
Figure 2-22 Boot menu
The UEFI AP is the embedded UEFI Shell. This option is displayed only when the UEFI boot mode is used. By default, UEFI Shell is disabled. To enable UEFI Shell, select UEFI Application Boot Priorities, and then select UEFI: Built-in EFI Shell.
3.        Select the option to be modified from the Fixed Boot Order Priorities area, and press Enter.
4.        In the dialog box that opens, select a new boot device type, and press Enter.
Figure 2-23 Changing a boot option
Configuring RAID
For information about RAID configuration, see the storage controller user guide for the server.
2.        Press F3 in the BIOS, or select Save & Exit > Restore Defaults and press Enter as shown in Figure 2-24.
Figure 2-24 Restoring the default from the Save & Exit menu
3 BIOS menus
Main menu
As shown in Figure 3-1, the Main menu contains information about the BIOS, memory, system language, and system time and date. For more information about the menu items, see Table 3-1.
Figure 3-1 Main menu screen
Table 3-1 Items on the Main menu screen
Item
BIOS Information
BIOS Vendor
Displays the BIOS vendor.
N/A
Core Version
Displays the BIOS core version.
N/A
Compliancy
Displays the standard with which the BIOS is compliant.
N/A
Project Name
Displays the project name.
N/A
Product Name
Displays the server model.
N/A
BIOS Version
Displays the BIOS version.
N/A
System Uuid
Displays the universally unique identifier (UUID) of the system.
N/A
Asset Tag
Displays the asset tag of the server.
N/A
Build Date and Time
Displays the date and time of the BIOS build.
N/A
Access Level
Displays the current user's access level, Administrator or User.
For more information about BIOS access levels, see "Security menu."
N/A
Platform Information
Platform
Displays the platform type.
N/A
Processor
Displays the CPU model.
N/A
PCH
Displays the platform controller hub (PCH) model.
N/A
RC Revision
Displays the RC version.
N/A
Memory Information
Total Memory
Displays the total memory capacity of the system.
N/A
Current Memory Frequency
Displays the current memory frequency.
For information about changing the memory frequency, see "Memory Configuration submenu."
N/A
Other items
System Language
Displays the language used in the system.
The BIOS supports English and simplified Chinese.
To switch between the languages, press Enter.
English
Modify Asset Tag
Modify the asset tag of the server, as shown in Figure 3-2.
N/A
System Date
Displays the system date. You can change the system date as needed.
The system date is in the format of mm/dd/yyyy. To move between the month, day, and year fields, press Enter. To change the value for the selected field, use the following method:
·         Press + to increase the value by 1.
·         Press - to decrease the value by 1.
·         Press a numeric key to set the final value.
N/A
System Time
Displays the system time. You can change the system time as needed.
The system time is in the format of hh:mm:ss in 24-hour format. To move between the hour, minute, and second fields, press Enter. To change the value for the selected field, use the following method:
N/A
Figure 3-2 shows the Modify Asset Tag submenu, on which you can configure the asset tag of the server as described in Table 3-2.
Figure 3-2 Modify asset tag submenu screen
Table 3-2 Items on the Modify Asset Tag submenu screen
Item
Enter New Asset Tag
Enter a new asset tag.
Confirm Set Asset Tag
Select NO to cancel the tag change.
Select YES to save the tag change.
Advanced menu
The Advanced menu varies by server configuration.
·          If no Ethernet interfaces, storage controllers, or NVMe drives that have an Option ROM are present, the Advanced menu is displayed as shown in Figure 3-3.
·          If Ethernet interfaces, storage controllers, or NVMe drives that have an Option ROM are present, the Advanced menu is displayed as shown in Figure 3-4.
The Advanced menu contains advanced system features and functionalities, which are described in Table 3-3.
Figure 3-3 Advanced menu screen (without Option ROM-capable Ethernet interfaces, storage controllers, or NVMe drives)
Figure 3-4 Advanced menu screen (with Option ROM-capable Ethernet interfaces, storage controllers, or NVMe drives)
Table 3-3 Items on the Advanced menu screen
Item
Submenu for configuring Intel(R) Virtual RAID on CPU (Intel VROC).
Slot x:Port x
Submenu for configuring an Ethernet interface, storage controller, or NVMe drive that has an Option ROM.
Driver Health
Submenu for viewing the health state of drivers or controllers.
This submenu is available only in UEFI boot mode.
Trusted Computing
Submenu for configuring trusted computing.
ACPI Settings
Submenu for configuring advanced configuration and power interface (ACPI) settings.
Submenu for configuring serial console port redirection.
Submenu for configuring the PCI subsystem.
Submenu for configuring network stacks.
CSM Configuration
Submenu for configuring the compatibility support module (CSM).
NVMe Configuration
Submenu for configuring NVMe.
USB Configuration
Submenu for configuring USB.
Intel® Virtual RAID on CPU (Intel VROC) is a RAID solution specifically designed for NVMe-based SSDs.
Prerequisites for using Intel VROC
Before using Intel VROC for RAID volume management on a CPU that has NVMe SSDs attached, use the following procedure to enable Intel Volume Management Device (VMD) for that CPU:
1.        Install an Intel NVMe VROC module. The system supports the following NVMe VROC modules:
¡  Intel® VROC StandardSupports RAID levels 0, 1, and 10.
¡  Intel® VROC PremiumSupports RAID levels 0, 1, 5, and 10.
¡  Intel® VROC Intel® SSD OnlySupports RAID levels 0, 1, 5, and 10 and only Intel NVMe SSDs.
2.        Make sure a 4-port NVMe expander module (Retimer) or 8-port NVMe expander module (Switch) is installed in the PCIe X16 slot for that CPU.
3.        Enable Intel Volume Management Device (VMD) for that CPU:
a.    Select Socket Configuration > IIO Configuration > Intel® VMD technology, and then press Enter.
b.    On the Intel® VMD technology menu, select the CPU for which you want to enable Intel VMD, and then press Enter. This example uses Intel® VMD for Volume Management Device on Processor 1.
c.    On the VMD Config for PStack0 screen shown in Figure 3-5, set the status of Intel® VMD for Volume Management Device for PStack0 to Enabled or Auto.
Figure 3-5 Intel® VMD for Volume Management Device on Processor 1 screen
Using the Intel Virtual RAID on CPU menu to manage volumes or VMD controllers
Figure 3-6 shows the Intel(R) Virtual RAID on CPU menu, on which you can manage RAID volumes and Intel VMD controllers as described in Table 3-4.
Figure 3-6 Intel(R) Virtual RAID on CPU menu screen
Table 3-4 Items on the Intel(R) Virtual RAID on CPU menu screen
Item
Intel VROC Managed Volumes
Displays summary information about managed RAID volumes, including their volume name, RAID level, capacity, and state, for example, Volume0, RAID0 (Stripe), 1415.89GB, Normal.
To view detailed information about a volume or manage its member drives, select that volume. The RAID volume management submenu opens, as shown in Figure 3-7. For more information about the submenu items, see Table 3-5.
Intel VROC Managed Controllers
To view information about Intel VROC managed VMD controllers and use a controller to create and configure a RAID volume, select All Intel VMD Controllers. The Intel VMD controller management submenu opens, as shown in Figure 3-11. For more information about the submenu items, see Table 3-7.
Managing an Intel VROC volume
Figure 3-7 shows the RAID volume management submenu screen, on which you can view information about the selected RAID volume and manage its member drives. For more information about the submenu items, see Table 3-5.
Figure 3-7 RAID volume management submenu screen
Table 3-5 Items on the RAID volume management submenu screen
Item
Volume Actions
Delete
CAUTION CAUTION:
All data in the member drives of the volume are permanently deleted when the volume is deleted. As a best practice to avoid data loss, back up the data before you delete a volume.
To delete the RAID volume, select this item, and then select Yes to confirm the deletion, as shown in Figure 3-8.
RAID Volume Information
Name
Displays the name of the RAID volume.
RAID Level
Displays the RAID level.
Strip Size
Displays the stripe size of the RAID volume.
Size
Displays the capacity of the RAID volume.
Status
Displays the state of the RAID volume.
Bootable
Displays whether the RAID volume is bootable.
Block Size
Displays the block size of the RAID volume, in bytes.
RAID Member Disks
Member drives of the RAID, for example:
·         SAMSUNG MZWLL1T6HEHP-00003 SN:S3HDNX0J600102,1490.42GB Port 1:1,Slot 121,CPU0,VMD0,BDF 02:00.0
·         INTEL SSDPE2ME800G4 SN:PHMD63960129800GGN,745.21GB Port 1:3,Slot 123,CPU0,VMD0,BDF 04:00.0
To manage a member drive or view its detailed information, select that drive. The RAID member drive management submenu opens, as shown in Figure 3-9. For more information about the submenu items, see Table 3-6.
The port ID depends on the installed NVMe SSD expander module and its installation location:
·         If a 4-port NVMe SSD expander module is installed in the riser card on PCIe riser connector 1, the port ID is 1:1 or 1:3 as shown in the example.
·         If an 8-port NVMe SSD expander module is installed, the port ID is 1:0 or 2:0. If the expander module is installed in the riser card on PCIe riser connector 1, the port ID is 1:0. If the expander module is installed in the riser card on PCIe riser connector 2, the port ID is 2:0.
Figure 3-8 RAID volume delete screen
Figure 3-9 RAID member drive management submenu screen
Table 3-6 Items on the RAID member drive management submenu screen
Item
Disk Actions
Reset to non-RAID
CAUTION CAUTION:
This action deletes all data on the drive. As a best practice to avoid data loss, back up the data before you perform this action.
To remove the drive from the RAID array, select this item, and then select Yes to confirm the deletion, as shown in Figure 3-10.
Other information
Controller
Displays the controller information, which is Volume Management Device Controller in this example.
Model Number
Displays the model number of the drive.
Serial Number
Displays the serial number of the drive.
Size
Displays the capacity of the drive.
Status
Displays whether the drive is a RAID member.
Block Size
Displays the block size of the drive, in bytes.
Root Port Number
Displays the root port number of the drive.
Root Port Offset
Displays the root port offset of the drive.
Slot Number
Displays the slot number of the drive.
Socket Number
Displays the slot number of the processor for the drive.
VMD Controller Number
Displays controller number.
PCI Bus:Device.Function
Displays the Bus:Dev:Func of the drive.
Figure 3-10 shows the Reset to non-RAID screen, on which you can remove the selected drive from the RAID array.
Figure 3-10 Reset to non-RAID screen
Managing an Intel VMD controller
Figure 3-11 shows the Intel VMD controller management submenu screen, on which you can perform the following tasks:
·          Create a RAID volume by using non-RAID physical drives. A non-RAID physical drives is a drive that has not been used to build a RAID volume.
·          View information about a non-RAID physical drive or set that drive as a spare or journal disk.
Figure 3-11 Intel VDM controller management submenu screen
Table 3-7 Items on the Intel VMD controller management submenu screen
Item
Create RAID Volume
To create a RAID volume, select this item to access the Create RAID Volume screen shown in Figure 3-12 , and then create the RAID volume as described in Table 3-8.
RAID Volumes
Existing RAID volumes, for example:
Volume0, RAID0 (Stripe), 1.72TB, Normal
Displays summary information about each existing RAID volume, including the volume name, RAID level, capacity, and state.
Non-RAID Physical Disks
Drives that are not in a RAID volume, for example:
INTEL SSDPE2KX010T7 SN:PHLF721100J21P0GGN,931.5GB Port 1:2,Slot 121,CPU0,VMD0,BDF 03:00.0
Displays physical drives that are available for creating a RAID volume.
To view information about a non-RAID physical drive or set that drive as a spare or journal disk, select that drive to access the non-RAID physical drive configuration submenu shown in Figure 3-13 . For more information about the submenu items, see Table 3-9.
·         If a 4-port NVMe SSD expander module is installed in the riser card on PCIe riser connector 1, the port ID is 1:0 or 1:1 as shown in the example.
Figure 3-12 Create RAID Volume submenu screen
Table 3-8 Items on the Create RAID Volume screen
Item
Name
Enter the name of the RAID volume.
Make sure the name does not contain special characters.
N/A
RAID Level
Select a RAID level.
·         RAID0(Stripe).
·         RAID1(Mirror).
·         RAID5(Parity).
·         RAID10(RAID0+1).
RAID0 (Stripe)
Enable RAID spanned over VMD Controllers
To build a RAID volume over physical drives controlled by different VMD controllers, select this item.
N/A
Select Disks
All available drives, for example:
INTEL SSDPE2ME800G4 SN:PHMD63960129800GGN,745.21GB  Port 1:3,CPU0,VMD0
Select drives over which you want to create the RAID volume.
The selected drive is represented by the symbol X.
No drives are selected for RAID creation.
Stripe Size
Set the stripe size of the RAID volume.
N/A
Capacity (MB)
Displays the total capacity of the RAID volume.
N/A
Create Volume
Select Create Volume and press Enter to create the RAID volume.
To verify that the volume is correctly created, examine the RAID Volumes section on the Intel VMD controller management submenu screen, as shown in Figure 3-12.
N/A
Figure 3-13 shows the configuration submenu screen for a non-RAID physical drive. On the screen, you can view information about the drive and set the drive as a spare or journaling disk, as described in Table 3-9.
Figure 3-13 Non-RAID physical drive configuration submenu screen
Table 3-9 Items on the non-RAID drive configuration submenu screen
Item
Disk Actions
Mark as Spare
CAUTION CAUTION:
Setting a drive as a spare disk deletes all data on that drive. As a best practice to avoid data loss, back up the data before you perform this action.
To specify the drive as a spare disk, select this item, and then select Yes to confirm the action, as shown in Figure 3-14.
A spare disk cannot be used to build a RAID volume.
Mark as Journaling Drive
CAUTION CAUTION:
Setting a drive as a journaling drive deletes all data on that drive. As a best practice to avoid data loss, back up the data before you perform this action.
To specify the drive as a journaling drive, select this item, and then select Yes to confirm the action, as shown in Figure 3-15.
A journaling drive cannot be used to build a RAID volume.
Information about the drive
Controller
Model Number
Serial Number
Size
Status
Block Size
Displays the block size of the drive.
Root Port Number
Root Port Offset
Slot Number
Socket Number
Displays controller information.
Figure 3-14 Mark as Spare screen
Figure 3-15 Mark as Journaling Drive screen
Figure 3-16 shows the Driver Health submenu screen, on which you can view the health state of a driver or controller. This section uses a controller of a 4-port mLOM Ethernet adapter as an example. For more information about the menu items, see Table 3-10.
Figure 3-16 Driver Health menu screen
Table 3-10 Items on the Driver Health menu screen
Item
Intel(R) 40GbE 2.5.07
Display the health state of a driver or a controller. The scr
Options:
·         Healthy—Normal.
·         Failed—Abnormal.
If the state is Failed, press Enter and follow the instructions to repair the driver or controller. The repair method varies by driver or controller.
The server might contain a trusted platform module (TPM) or a trusted cryptography module (TCM).
If the server does not contain a TPM or TCM module, the Trusted Computing menu screen is as shown in Figure 3-17. The menu items are described in Table 3-11.
If the server contains a TPM module, the Trusted Computing menu screen is as shown in Figure 3-18. The menu items are described in Table 3-12.
If the server contains a TCM module, the Trusted Computing menu screen is as shown in Figure 3-19. The menu items are described in Table 3-13.
Figure 3-17 Trusted Computing menu screen (no security device installed)
Table 3-11 Items on the Trusted Computing menu screen when no security device is installed
Item
Security Device Support
Select Enabled or Disabled to enable or disable BIOS support for security devices.
Figure 3-18 Trusted Computing menu screen (TPM module installed)
Table 3-12 Items on the Trusted Computing menu screen when a TPM module is installed
Item
Select Enabled or Disabled to enable or disable BIOS support for TPM 2.0.
N/A
Active PCR Banks
Displays the active platform configuration register (PCR) banks.
N/A
Available PCR Banks
Displays the available PCR banks.
N/A
SHA-1 PCR Bank
Select Enabled or Disabled to enable or disable the SHA-1 PCR bank.
Enabled
SHA256 PCR Bank
Select Enabled or Disabled to enable or disable the SHA256 PCR bank.
Enabled
SM3_256PCR Bank
Select Enabled or Disabled to enable or disable the SM3_256PCR bank.
Enabled
TPM State
Select Enabled or Disabled to enable or disable TPM.
Enabled
Pending Operation
Select the TPM operation to be performed during the next boot process.
Options are None and TPM Clear. The TPM Clear operation clears the values of measurements in the TPM.
None
Platform Hierarchy
Select Enabled or Disabled to enable or disable platform hierarchy.
Enabled
Storage Hierarchy
Select Enabled or Disabled to enable or disable storage hierarchy.
Enabled
Endorsement Hierarchy
Select Enabled or Disabled to enable or disable endorsement hierarchy.
Enabled
TPM 2.0 UEFI Spec Version
Select the supported Trusted Computing Group (TCG) specification version.
Options:
·         TCG_1_2—Compatible with Windows 8 and Windows 10.
·         TCG_2—Specifies the TCG 2 protocol and event format for Windows 10 and higher versions.
TCG_2
Physical Presence Spec Version
Select the Physical Presence Interface (PPI) specification version to be reported to the OS.
Options:
·         1.2.
·         1.3. This option might be not supported by some HCK tests.
1.3
TPM 2.0 InterfaceType
Displays the TPM 2.0 interface type.
N/A
PH Randomization
Select Enabled or Disabled to enable or disable platform hierarchy randomization.
Disabled
Device Select
Select the supported TPM version.
·         TPM1.0—Select this option only if a TPM 1.0 module is installed.
·         TPM2.0—Select this option only if a TPM 2.0 module is installed.
·         Auto—Select this option to have the system automatically select TPM 1.0 or TPM 2.0. The default is TPM 2.0. If TPM 2.0 is not present, TPM 1.0 is selected.
Auto
Figure 3-19 Trusted Computing menu screen (TCM module installed)
Table 3-13 Items on the Trusted Computing menu screen when a TCM module is installed
Item
Configuration
Enabled
TCM State
Select Enabled or Disabled to enable or disable TCM.
Enabled
Pending Operation
Select the TCM operation to be performed during the next boot process.
Options are None and TCM Clear. The TCM Clear operation clears the values of measurements in the TCM.
None
Device Select
Auto
Current Status Information
TCM Enabled Status
Indicates whether TCM is enabled or disabled.
N/A
TCM Active Status
Indicates whether TCM is activated or deactivated.
N/A
TCM Owner Status
Indicates the TCM ownership status. Options are Owned and Unowned.
N/A
The ACPI Settings menu contains the ACPI options for you to configure OS-directed configuration and power management of the server. The menu items are described in Table 3-14.
Figure 3-20 ACPI Settings menu screen
Table 3-14 Items on the ACPI Settings menu screen
Item
Enable ACPI Auto Configuration
Select Enabled or Disabled to enable or disable ACPI auto configuration.
ACPI auto configuration allows the operating system to control and allocate power on the server hardware.
Disabled
Lock Legacy Resources
Select Enabled or Disabled to enable or disable lock of legacy resources.
Disabled
Serial port console redirection enables you to send all text-based output to one of the on-board serial ports by using a physical or virtual serial port.
Figure 3-21 shows the Serial Port Console Redirection menu screen, on which you can configure console redirection settings as described in Table 3-15.
Figure 3-21 Serial Port Console Redirection menu screen
1
Table 3-15 Items on the Serial Port Console Redirection menu screen
Item
COM0
Serial port COM0.
N/A
Console Redirection
Select Enabled or Disabled to enable or disable console redirection on the serial port (COM0).
Enabled
Console Redirection Settings
Open the Console Redirection Settings submenu for COM0, as shown in Figure 3-22.
The Console Redirection Settings submenu is accessible only when Console Redirection is enabled on COM0.
N/A
Serial Port for Out-of-Band Management/Windows Emergency Management Services (EMS)
Serial port for out-of-band management or Windows Emergency Management Services (EMS).
N/A
Console Redirection
Select Enabled or Disabled to enable or disable console redirection on the serial port.
Disabled
Open the Console Redirection Settings submenu for the out-of-band management port, as shown in Figure 3-23.
The Console Redirection Settings submenu is accessible only when Console Redirection is enabled for the out-of-band management port.
N/A
Figure 3-22 shows the Console Redirection Settings menu screen for COM0. The menu items are described in Table 3-16.
Figure 3-22 Console Redirection Settings menu screen (COM0)
Table 3-16 Items on the Console Redirection Settings menu screen (COM0)
Item
Terminal Type
Select the type of terminal used for console redirection.
Options:
·         VT100—Uses a supported VT100 video terminal with the ASCII character set.
·         VT100+—Uses a supported VT100-plus video terminal and its character set. VT100+ supports colors and function keys.
·         VT-UTF8Uses a video terminal with the UTF-8 character set.
·         ANSIUses the ANSI character set, which is an extended ASCII character set.
VT100+
Bits Per Second
Set the baud rate of the serial port in bits per second.
Options:
·         9600.
·         19200.
·         38400.
·         57600.
·         115200.
This baud rate setting must match the setting on the remote terminal.
As a best practice, set a low speed on a long or noisy serial line.
115200
Data Bits
Set the number of bits used to represent one character of data.
Options:
·         7.
·         8.
8
Parity
Set the parity bit to be sent with the data bits for transmission error detection.
Options:
·         NoneNo parity bit is sent.
·         Even—Sets the parity bit so that the number of ones in the data set is an even number.
·         Odd—Sets the parity bit so that the number of ones in the data set is an odd number.
·         Mark—Always sets the parity bit to 1. This setting cannot be used for error detection.
·         Space—Always sets the parity bit to 0. This setting cannot be used for error detection.
None
Stop Bits
Set the number of stop bits used to indicate the end of a serial data packet.
Options:
·         1.
·         2.
Two stop bits might be required for communications with a slow device.
1
Flow Control
Select a flow control method to prevent data loss from buffer overflow.
Options:
·         NoneNo flow control is used.
·         Hardware RTS/CTSFlow control that uses the ready to send/clear to send (RTS/CTS) signal. When you select this option, make sure it is supported on the serial port.
If you enable hardware RTS/CTS on a serial port that does not support hardware flow control (such as a port that uses a USB-to-serial cable), or on a serial port with no cable connected, the following issues might occur:
·         Failure to load the option ROM of embedded and external PCIe devices.
·         Screen blackout.
·         Cursor flickering.
None
VT-UTF8 Combo Key Support
Select Enabled or Disabled to enable or disable VT-UTF8 combination key support for ANSI/VT100 terminals.
Enabled
Recorder Mode
Select Enabled or Disabled to enable or disable the recorder mode, which is used to capture terminal text data.
Disabled
Resolution 100×31
Select Enabled or Disabled to enable or disable enhanced terminal resolution (100 × 31).
N/A
Legacy OS Redirection Resolution
Set the resolution for legacy OS redirection.
Options:
·         80×24.
·         80×25.
80×24
Putty KeyPad
Select a mode to change the action of the function keys and keypad in PuTTY.
Options:
·         VT100.
·         LINUX.
·         XTERMR6.
·         SCO.
·         ESCN.
·         VT400.
VT100
Redirection After BIOS POST
Configure the legacy console redirection setting after BIOS POST.
Options:
·         Always Enable—Legacy console redirection is always enabled for legacy OS.
·         BootLoader—Legacy console redirection is disabled before booting to legacy OS.
Always Enable
Figure 3-23 shows the Console Redirection Settings menu for the out-of-band management port. The menu items are described in Table 3-17.
Figure 3-23 Console Redirection Settings menu screen (out-of-band management serial port)
Table 3-17 Items on the Console Redirection Settings menu screen (out-of-band management port)
Item
Out-of-Band Mgmt Port
Indicates the out-of-band management serial port.
This port allows Microsoft Windows EMS to remotely access the Window OS to collect fault information.
N/A
Terminal Type
Options:
VT100+
Bits Per Second
Set the data transfer rate of the serial port in bits per second.
Options:
·         9600.
·         19200.
·         57600.
·         115200.
This data transfer rate setting must match the setting on the remote terminal.
115200
Flow Control
Select a flow control method to prevent data loss from buffer overflow. Options:
·         Software Xon/Xoff—Flow control that uses the XON (transmit ON) and XOFF (transmit OFF) control characters. When the data transfer rate exceeds 1200 bits per second, the receiver sends an XOFF to have the sender stop transmission. The sender will resume the transmission only when it receives an XON from the receiver.
None
Data Bits
Displays the number of bits used to represent one character of data.
N/A
Parity
Displays the parity bit sent with the data bits for transmission error detection.
N/A
Stop Bits
Displays the number of stop bits used to indicate the end of a character frame.
N/A
Slot x:Port x
Ethernet interfaces, storage controllers, and NVMe drives that have an Option ROM are displayed on the Advanced screen as Slot x:Port x entries. For Ethernet interfaces, Slot x represent the slot number of the Ethernet adapter that contains the interface and Port x represents the port index of the interface on the Ethernet adapter.
The Slot x:Port x submenu screen is generated by the option ROM of a PCIe module and the items on the screen vary by vendor. This section uses the Slot 9-mLOM:Port 1 entry for the embedded mLOM Ethernet adapter as an example. Figure 3-24 shows the Ethernet interface configuration submenu screen of the Slot 9-mLOM:Port 1 entry. The menu items are described in Table 3-18.
Figure 3-24 Slot x:Port x entry submenu screen
Table 3-18 Items on the Ethernet interface configuration menu screen
Item
NIC Configuration
Open the NIC configuration submenu menu, as shown in Figure 3-25.
N/A
Blink LEDs
Set the number of seconds for which the port connection status LED keeps blinking.
Value range: 0 to 15.
0
UEFI Driver
Displays the UEFI driver name.
N/A
Adapter PBA
Displays the network adapter PBA number.
N/A
Device Name
Displays the name of the embedded NIC.
N/A
Chip Type
Displays the chip type of the NIC.
N/A
PCI Device ID
Displays the ID of the PCI device.
N/A
PCI Address
Displays the address of the PCI device.
N/A
Link Status
Displays the link status.
Options:
·         Disconnected.
·         Connected.
N/A
MAC Address
Displays the MAC address of the embedded NIC.
N/A
Virtual MAC Address
Displays the virtual MAC address of the embedded NIC.
N/A
Figure 3-25 shows the NIC configuration screen, on which you can configure the link speed and enable or disable Wake On LAN for the Ethernet interface as described in Table 3-19.
Figure 3-25 NIC Configuration screen
Table 3-19 Items on the NIC Configuration screen
Item
Link Speed
Display the link speed setting.
The setting is fixed at Auto Negotiated, which is not user configurable.
N/A
Wake On LAN
Select Enabled or Disabled to enable or disable waking up the system from a low power mode remotely. If this option is enabled, the server is wakened up when it receives an out-of-band magic packet.
Disabled
Figure 3-26 shows the PCI Subsystem Settings menu screen, on which you can configure PCI subsystem settings as described Table 3-20.
Figure 3-26 PCI Subsystem Settings menu screen
Table 3-20 Items on the PCI Subsystem Settings menu screen
Item
PCI Bus Driver Version
Displays the PCI bus driver version.
N/A
PCI Devices Common Settings
Above 4G Decoding
Select Enabled or Disabled to enable or disable decoding of 64-bit PCI devices in a 4 GB or greater address space.
As a best practice, enable this option if the PCIe device has a 4 GB or higher-capacity VRAM. For example, disabling this option can cause an M60 or K80 GPU to get stuck in the EarlyPOST 100% phase, preventing you from accessing the BIOS setup menu or the OS.
Enabled
SR-IOV Support
Select Enabled or Disabled to enable or disable the support for PCIe single-root I/O virtualization (SR-IOV).
By default, the OS allocates I/O resources if the PCIe card supports SR-IOV. If the PCIe card does not support SR-IOV, SR-IOV is automatically disabled.
Enabled
BME DMA Mitigation
Select Enabled or Disabled to enable or disable DMA attack prevention.
With this feature enabled, the performance of PCIe devices will degrade.
Disabled
The network stack configuration is used only in UEFI mode for the server to set up a pre-boot network connection for OS deployment through Preboot eXecution Environment (PEX) over the network.
Figure 3-27 shows the Network Stack Configuration menu screen, on which you can configure UEFI network stack settings as described in Table 3-21.
Figure 3-27 Network Stack Configuration menu screen
Table 3-21 Items on the Network Stack Configuration menu screen
Item
Network Stack
Select Enabled or Disabled to enable or disable the UEFI network stack.
Enabled
IPv4 PXE Support
Select Enabled or Disabled to enable or disable loading the OS over an IPv4 network.
If Disabled is selected, the IPv4 PEX boot option will not be created.
Enabled
IPv6 PXE Support
Select Enabled or Disabled to enable or disable loading the OS over an IPv6 network.
If Disabled is selected, the IPv6 PEX boot option will not be created.
Enabled
Media detect count
Set the maximum number of media presence detections.
Value range: 1 to 50.
1
PXE Retry Count
Set the maximum number of PXE retries.
Value range: 0 to 50.
A value of 0 indicates that the number of PEX retries is not limited.
1
The configuration support module (CSM) provides UEFI compatibility with OSs that do not support UEFI boot mode.
Figure 3-28 shows the CSM Configuration menu screen, on which you can configure CMS settings as described in Table 3-22.
Figure 3-28 CSM Configuration menu screen
Table 3-22 Items on the CSM Configuration menu screen
Item
CSM Support
Select Enabled or Disabled to enable or disable support for UEFI-incapable operating systems.
In legacy boot mode, the setting is always Enabled and cannot be changed.
Enabled
Option ROM Execution
Option ROM Policy
This item is available only when CSM Support is set to Enabled.
Options:
·         Auto—Automatically load the option ROMs.
·         Custom—Customize the option ROM load methods for NICs, storage devices, video devices, and other PCI devices. The configuration submenus (Network, Storage, Video, and Other PCI Devices) are available only when the Custom option is selected.
Auto
Network
Select the option ROM load method for NICs.
Options:
·         UEFI—Load the option ROM for NICs in UEFI boot mode.
·         Legacy—Load the option ROM for NICs in legacy boot mode.
In UEFI boot mode: UEFI.
In legacy boot mode: Legacy.
Storage
Select the option ROM load method for storage devices.
Options:
·         UEFI—Load the option ROM for storage devices in UEFI boot mode.
·         Legacy—Load the option ROM for storage devices in legacy boot mode.
Video
Select the option ROM load method for video devices.
Options:
·         UEFI—Load the option ROM for video cards in UEFI boot mode.
·         Legacy—Load the option ROM for video cards in legacy boot mode.
Other PCI devices
Select the option ROM load method for other PCI devices such as input devices.
Options:
·         UEFI—Load the option ROM for other PCI devices in UEFI boot mode.
·         Legacy—Load the option ROM for other PCI devices in legacy boot mode.
Figure 3-29 shows the NVMe Configuration menu screen, on which all installed NVMe devices are displayed. You can select an NVMe device to view its information as shown in Figure 3-30.
You cannot turn on state LEDs of NVMe drives by using VMD in the BIOS.
Figure 3-29 NVMe Configuration menu screen
Figure 3-30 NVMe device information screen
Table 3-23 Items on the NVMe device information screen
Item
Slot: Port:
Displays the slot number and port number of the NVMe device.
Bus:Dev:Func
Displays the Bus:Dev:Func of the NVMe device.
Model Number
Displays the model number of the NVMe device.
Total Size
Displays the total size of the NVMe device.
Vendor ID
Displays the vendor ID of the NVMe device.
Device ID
Displays the device ID of the NVMe device.
Namespace
Displays the namespace of the NVMe device.
Figure 3-31 shows the USB Configuration menu screen, on which you can view connected USB devices and configure USB settings as described in Table 3-24.
Figure 3-31 USB Configuration menu screen
Table 3-24 Items on the USB Configuration menu screen
Item
USB Controllers
Displays the detected USB controllers. The system supports eXtensible Host Controller (XHCI) controllers that support USB 3.0.
N/A
USB Devices
Displays the numbers of connected USB devices, including drives, keyboards, mice, and hubs.
The server has one embedded USB hub in addition to the connected USB hubs.
N/A
Legacy USB Support
Select whether to enable the support for legacy USB devices.
Options:
·         Enabled—Legacy USB support is always enabled.
·         Disabled—USB devices are available only for EFI applications.
·         Auto—The system automatically disables legacy USB support if no USB devices are connected.
Enabled
XHCI Hand-off
The xHCI setting that specifies the owner of the control over USB 3.0 ports.
Options:
·         Enabled—Hands off the control over USB 3.0 ports to the OS after the OS loads.
·         Disabled—BIOS controls USB 3.0 ports.
Enabled
USB Mass Storage Driver Support
Select Enabled or Disabled to enable or disable the support for USB mass storage drivers.
Enabled
Mass Storage Devices:
This section displays the installed mass storage devices.
N/A
Dual SD Card RAID LUN
This option is available only if a dual SD card expander module is installed with a minimum of one SD card.
When you manage SD cards, follow these guidelines:
·         The dual SD card expander module is not hot swappable. However, the SD cards are hot swappable.
·         For redundancy and storage use efficiency, install two same-capacity SD cards.
·         If an SD card fails while the server is operating, replace that SD card on line, and then power cycle the server. This replacement procedure ensures that the server can restore the data on the new SD card. Data loss might occur if you replace the failed SD card after powering off the server.
N/A
SanDisk
Indicates that a SanDisk USB flash drive is present.
N/A
ASUS SDR-08B1-U A A301
Indicates that an ASUS SDR-08B1-U A A301 USB drive is present.
N/A
Hp v220w 1100
Indicates that an HP v220w 1100 USB drive is present.
N/A
KingstonDataTraveler 3.0PMAP
Indicates that a KingstonDataTraveler 3.0PMAP USB drive is present.
N/A
AMI Virtual CDROM0 1.00
Indicates that an AMI Virtual CDROM0 1.00 drive is present.
N/A
H3C Virtual CDROM0 1.00
Indicates that an H3C Virtual CDROM0 1.00 drive is present.
A virtual CD-ROM drive provides the same functionality as a physical CD-ROM drive.
By default, virtual CDROM0 is mounted when you open the remote console.
N/A
H3C Virtual Floppy0 1.00
Indicates that an H3C Virtual Floppy0 1.00 drive is detected.
A virtual floppy drive provides the same functionality as a physical floppy drive.
By default, virtual Floppy0 is mounted when you open the remote console.
N/A
H3C Virtual HDisk0 1.00
Indicates that an H3C Virtual HDisk0 1.00 drive is present.
A virtual hard disk drive provides the same functionality as a physical hard disk drive.
By default, Virtual HDisk0 is mounted when you open the remote console.
N/A
H3C Virtual CDROM1 1.00
Indicates that an H3C Virtual CDROM1 1.00 USB driver is present.
By default, Virtual CDROM1 is mounted when you open the remote console.
N/A
H3C Virtual Floppy1 1.00
Indicates that an H3C Virtual Floppy1 1.00 drive is present.
By default, Virtual Floppy1 is mounted when you open the remote console.
N/A
H3C Virtual HDisk1 1.00
Indicates that an H3C Virtual HDisk1 1.00 drive is present.
By default, Virtual HDisk1 is mounted when you open the remote console.
N/A
As shown in Figure 3-32, the Platform Configuration menu contains the submenus described in Table 3-25.
Figure 3-32 Platform Configuration menu screen
Table 3-25 Items on the Platform Configuration menu screen
Item
PCH Configuration
Submenu for configuring the platform controller hub (PCH).
Submenu for configuring miscellaneous settings, including video display device and debug mode settings.
Submenu for configuring the server management engine (ME).
Submenu for configuring runtime error logging.
Figure 3-33 shows the PCH Configuration submenu screen, on which you can configure PCH settings as described in Table 3-26.
Figure 3-33 PCH Configuration submenu screen
Table 3-26 Items on the PCH Configuration submenu screen
Item
PCH Devices
Submenu for configuring PCH devices, as shown in Figure 3-34.
The submenu menu items are described in Table 3-27.
Submenu for configuring PCH SATA settings, as shown in Figure 3-35.
The submenu menu items are described in Table 3-28.
Submenu for configuring PCH sSATA settings, as shown in Figure 3-36.
The submenu menu items are described in Table 3-29.
USB Configuration
Submenu for configuring USB, as shown in Figure 3-37 .
The submenu menu items are described in Table 3-30.
Figure 3-34 PCH Devices submenu screen
Table 3-27 Items on the PCH Devices submenu screen
Item
PCIe PLL SSC
Set the PCIe Phase-Locked Loop (PLL) Spread Spectrum Clocking (SSC) frequency.
Options:
·         Disabled—Disables SSC.
·         Auto—Allows the BIOS to set the PCIe PLL SSC frequency automatically.
·         0.5%—Sets the PCIe PLL SSC frequency to 0.5% of the bus clock frequency.
Auto
Figure 3-35 PCH SATA Configuration submenu screen
Table 3-28 Items on the PCH SATA Configuration submenu screen
Item
SATA Controller
Select Enabled or Disabled to enable or disable the SATA controller.
Enabled
Configure SATA As
Select the operating mode of the SATA controller.
Options:
·         AHCI—Uses the AHCI mode, which allows the drives attached to the SATA ports to be used as SATA disks. This mode supports hot swapping of drives. To use this mode, a SATA driver must be installed.
·         RAID—Uses the RAID mode, which allows creation of a logical drive from multiple independent physical drives.
AHCI
SATA Test Mode
Select Enabled or Disabled to enable or disable SATA test mode.
Disabled
SATA Port N
Displays the name and slot number of the drive connected to logic PCH SATA port N. If no drive is connected, Not Installed is displayed.
For the mapping relations between logic PCH SATA ports and drive backplane ports, see "Mapping relations of PCH SATA/sSATA ports and drive backplane ports."
N/A
Port N
Select Enabled or Disabled to enable or disable the drive connected to SATA port N.
Enabled
Figure 3-36 PCH sSATA Configuration submenu screen
Table 3-29 Items on the PCH sSATA Configuration submenu screen
Item
sSATA Controller
Select Enabled or Disabled to enable or disable the sSATA controller.
Enabled
Configure sSATA As
Select the operating mode of the sSATA controller.
Options:
AHCI
sSATA Test Mode
Select Enabled or Disabled to enable or disable sSATA test mode.
Disabled
sSATA Port N
Displays the name and the slot number of the drive connected to logic PCH sSATA port N. If no drive is connected, Not Installed is displayed.
The number of sSATA ports varies by server model. For example, one sSATA port is available for an H3C UniServer R4900 or R4700 G3 server. Six sSATA ports are available for an H3C UniServer R2900 or R2700 G3 server.
N/A
Port N
Select Enabled or Disabled to enable or disable the drive connected to sSATA port N.
Enabled
Figure 3-37 USB Configuration submenu screen (H3C UniServer R4900 or R2900 G3 server)
Figure 3-38 USB Configuration submenu screen (H3C UniServer R4700 or R2700 G3 server)
Table 3-30 Items on the USB Configuration submenu screen
Parameter
USB Per-Connector Disable
Enable or disable independent control of individual USB connectors on the system board.
Options:
·         Enabled—You can disable the USB connectors on a per-connector basis.
·         Disabled—You cannot disable the USB connectors on a per-connector basis.
If a USB connector is disabled, BIOS or OS does not display the USB device plugged into that connector.
All subsequent menu items for setting USB port capability are available only if you set USB Per-Connector Disable to Enabled.
Disabled
Rear Left USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the USB 2.0 connector at the left of the rear panel.
Enabled
Rear Right USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the USB 2.0 connector at the right of the rear panel.
Enabled
Internal Top USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the internal top USB 2.0 connector.
Enabled
Internal Bottom USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the internal bottom USB 2.0 connector.
Enabled
Front Left Top USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the top USB port 2.0 connector on the front left chassis ear.
Enabled
Front Left Bottom USB Port 2.0 Capability
Select Enabled or Disabled to enable or disable the bottom USB port 2.0 connector on the front left chassis ear.
Enabled
Front Right USB Port 3.0 Capability
This item is available only on a 2U server, for example, an H3C UniServer R4900 or 2900 G3 server.
Select Enabled or Disabled to enable or disable USB port 3.0 connector on the front right chassis ear.
Enabled
SD Card Slot USB Port 3.0 Capability
Select Enabled or Disabled to enable or disable USB 3.0 capability of the SD card slot.
Enabled
Rear Left USB Port 3.0 Capability
Select Enabled or Disabled to enable or disable the USB 3.0 connector at the left of the rear panel.
Enabled
Rear Right USB Port 3.0 Capability
Select Enabled or Disabled to enable or disable the USB 3.0 connector at the right of the rear panel.
Enabled
Internal Top USB Port 3.0 Capability
Select Enabled or Disabled to enable or disable the internal top USB 3.0 connector.
Enabled
Internal Bottom USB Port 3.0 Capability
Select Enabled or Disabled to enable or disable the internal bottom USB 3.0 connector.
Enabled
Figure 3-39 shows the Miscellaneous Configuration submenu screen, on which you can configure features described in Table 3-31.
Figure 3-39 Miscellaneous Configuration submenu screen
Table 3-31 Items on the Miscellaneous Configuration submenu screen
Item
Active Video
Select a monitor to display videos.
Options:
·         Auto—Enables the server to automatically select a monitor to display videos.
·         Onboard Device—Uses the monitor connected to the onboard VGA connector to display videos.
·         PCIe Device—Uses the monitor connected to the GPU module in the PCIe slot to display videos.
In legacy boot mode, the server cannot display the BIOS menus on the monitor connected to the GPU module or VGA connector if the Onboard Device or PCIe Device option is selected, respectively.
Onboard Device
Debug Mode
Select Enabled or Disabled to enable or disable outputting the debug log from a BIOS serial port.
If debug mode is enabled, you can obtain the debug log by connecting to a BIOS serial port.
Disabled
SOL Mode
This item is available only when Debug Mode is set to Enabled.
Select Enabled or Disabled to enable or disable SOL mode.
With SOL mode enabled, you can obtain the debug log by executing the following command if your operating system is Linux:
curl http://HDM_IP/cgi/download_cpsol.cgi | tr -d '\000' > sol.txt
The HDM_IP argument represents the IP address of the HDM shared or dedicated network port and the sol.txt argument represents the name of the downloaded file. You can set the log file name as needed.
Enabled
Figure 3-40 shows the Server ME Configuration submenu screen, on which you can view the server management engine information described in Table 3-32.
Figure 3-40 Server ME Configuration submenu screen
Table 3-32 Items on the Server ME Configuration submenu screen
Item
Operational Firmware Version
Displays the active firmware version.
Backup Firmware Version
Displays the backup firmware version.
Recovery Firmware Version
Displays the recovery firmware version.
ME Firmware Status #1
Displays ME firmware status #1.
ME Firmware Status #2
Displays ME firmware status #2.
Current State
Displays the current ME state.
Error Code
Displays the error code.
Altitude
Displays the altitude at which the server is located, in meters. The default is 8000 meters (or 26246.72 ft).
MCTP Bus Owner
Displays the Management Component Transport Protocol (MCTP) bus owner.
ME Firmware Features
Displays the ME firmware features.
Figure 3-41 shows the Runtime Error Logging submenu screen, on which you can configure the runtime error logging as described in Table 3-33.
Figure 3-41 Runtime Error Logging submenu screen
Table 3-33 Items on the Runtime Error Logging submenu screen
Item
System Errors
This item controls system error logging, which enables the server to correct system errors automatically and report uncorrectable errors to HDM and the operating system.
Select Enabled or Disabled to enable or disable system error logging.
Enabled
S/W Error Injection Support
This item is available only when System Errors is set to Enabled.
Software error injection tests system performance by injecting software errors.
To test system performance, select Enabled.
Disabled
System Memory Poison
Select Enabled or Disabled to enable or disable system memory poison.
To report event logs to HDM when uncorrectable memory errors are injected, you must set both System Memory Poison and Viral Status to Disabled.
Enabled
Viral Status
Select Enabled or Disabled to enable or disable detection of memory-resident viruses.
Enabled
System Cloaking
System cloaking enables the operating system and software to block corrected errors and uncorrected no action required (UCNA) errors.
Select Enabled or Disabled to enable or disable system cloaking.
Enabled
EMCA Settings
Access the submenu for configuring the Enhanced Machine Check Architecture (EMCA), as shown in Figure 3-42.
The submenu items are described in Table 3-34.
N/A
WHEA Settings
Access the submenu for configuring the Windows Hardware Error Architecture (WHEA), as shown in Figure 3-43.
The submenu items are described in Table 3-35.
N/A
Error Injection Settings
Access the submenu for configuring error injection settings, as shown in Figure 3-44.
The submenu items are described in Table 3-36.
N/A
UPI Error Enabling
Access the submenu for configuring UltraPath Interconnect (UPI) error reporting, as shown in Figure 3-45.
The submenu items are described in Table 3-37.
N/A
Memory Error Enabling
Access the submenu for configuring memory error reporting, as shown in Figure 3-46.
The submenu items are described in Table 3-38.
N/A
IIO Error Enabling
Access the submenu for configuring Integrated I/O module (IIO) error reporting, as shown in Figure 3-47.
The submenu items are described in Table 3-39.
N/A
PCIe Error Enabling
Access the submenu for configuring PCIe error reporting, as shown in Figure 3-48.
The submenu items are described in Table 3-40.
N/A
Figure 3-42 EMCA Settings submenu screen
Table 3-34 Items on the EMCA Settings submenu screen
Item
EMCA Logging Support
Select Enabled or Disabled to enable or disable EMCA logging.
EMCA logging provides MAC error reports for the server.
Enabled
LMCE Support
Local machine check exceptions (LMCE) support enables the system to log detected hardware errors in firmware registers.
Select Enabled or Disabled to enable or disable LMCE support.
Enabled
Ignore OS EMCA Opt-in
Select Enabled or Disabled to enable or disable the ignore OS EMCA opt-in feature.
Disabled
EMCA CMCI-SMI Morphing
When EMCA CMCI-SMI morphing is enabled:
·         The SMI is triggered each time a correctable error occurs.
·         If the number of correctable errors on the MCBank exceeds the upper limit, the SMI is triggered but the Corrected Machine Check Interrupt (CMCI) is not.
Options:
·         EMCA gen 1 Lite—Enables EMCA CMCI-SMI morphing in EMCA gen 1 lite mode.
·         EMCA gen 2 CSMI—Enables EMCA CMCI-SMI morphing in EMCA gen 2 CSMI mode.
·         Disabled—Disables EMCA CMCI-SMI morphing.
EMCA gen 2 CSMI
EMCA MCE-SMI Enable
Options:
·         EMCA gen 1 Dual Mode—Enables EMCA MCE-SMI in EMCA gen1 dual mode.
·         EMCA gen 2 – MSMI—Enables EMCA MCE-SMI in EMCA gen 2 MSMI mode.
·         Disabled—Disables EMCA MCE-SMI.
EMCA gen 2 – MSMI
Figure 3-43 WHEA Settings submenu screen
Table 3-35 Items on the WHEA Settings submenu screen
Item
WHEA Support
Select Enabled or Disabled to enable or disable WHEA.
WHEA provides hardware error reports for the server.
Enabled
Figure 3-44 Error Injection Settings submenu screen
Table 3-36 Items on the Error Injection Settings submenu screen
Item
Mca Bank Error Injection Support
Select Enabled or Disabled to enable or disable MCA bank error injection.
If MCA bank error injection is enabled, the write function of the register into which errors are injected is enabled.
Disabled
WHEA Error Injection Support
Select Enabled or Disabled to enable or disable WHEA error injection.
Disabled
Figure 3-45 UPI Error Enabling submenu screen
Table 3-37 Items on the UPI Error Enabling submenu screen
Item
SMI UPI Lane Failover
Select Enabled or Disabled to enable or disable triggering an SMI upon a UPI lane failover.
Disabled
Figure 3-46 Memory Error Enabling submenu screen
Table 3-38 Items on the Memory Error Enabling submenu screen
Item
Memory Error
Select Enabled or Disabled to enable or disable memory error reporting.
Enabled
Memory Corrected Error
Select Enabled or Disabled to enable or disable correctable memory error reporting.
Enabled
Spare Interrupt
This item is available only when Memory Corrected Error is set to Enabled.
Select the type of the spare interrupt to generate upon detection of a memory error.
Options:
·         Disabled—Disables spare interrupt generation.
·         SMI—Generates an SMI interrupt.
SMI
Figure 3-47 IIO Error Enabling submenu screen
Table 3-39 Items on the IIO Error Enabling submenu screen
Item
IIO/PCH Global Error Support
Select Enabled or Disabled to enable or disable IIO/PCH global error reporting.
Enabled
IIO PCIe AER Spec Compliant
Select Enabled or Disabled to enable or disable IIO PCIe Advanced Error Reporting (AER) specification compliance checking.
Disabled
Figure 3-48 PCIe Error Enabling submenu screen
Table 3-40 Items on the PCIe Error Enabling submenu screen
Items
Corrected Error
Select Enabled or Disabled to enable or disable PCIe correctable error reporting.
Enabled
Uncorrected Error
Enabled
Fatal Error Enable
Select Enabled or Disabled to enable or disable PCIe fatal error reporting.
Enabled
PCIe Corrected Error Threshold Counter
Select Enabled or Disabled to enable or disable the PCIe correctable error threshold counter.
Disabled
PCIe Corrected Error Threshold Mask
This item is available only when PCIe Corrected Error Threshold Counter is set to Enabled.
Set the PCIe correctable error threshold mask.
0
Set the PCIe correctable error threshold.
1
SERR Propagation
Select Enabled or Disabled to enable or disable SERR propagation.
Enabled
PERR Propagation
Select Enabled or Disabled to enable or disable PERR propagation.
Enabled
Socket Configuration menu
Figure 3-49 shows the Socket Configuration menu screen, on which you can configure CPU, command reference code, UPI, memory, IIO, and advanced power management settings as described in Table 3-41.
Figure 3-49 Socket Configuration menu screen
Table 3-41 Items on the Socket Configuration menu screen
Item
Processor Configuration
Submenu for configuring processors, as shown in Figure 3-50.
The submenu items are described in Table 3-44.
Common RefCode Configuration
Submenu for configuring the common reference code, as shown in Figure 3-53.
The submenu items are described in Table 3-45.
UPI Configuration
Submenu for configuring Intel® UltraPath Interconnect (UPI) parameters, as shown in Figure 3-54.
The submenu items are described in Table 3-46.
Submenu for configuring memory parameters, as shown in Figure 3-57.
The submenu items are described in Table 3-48.
IIO Configuration
Submenu for configuring Integrated I/O module (IIO) parameters, as shown in Figure 3-62.
The submenu items are described in Table 3-53.
Advanced Power Management Configuration
Submenu for configuring advanced power management parameters, as shown in Figure 3-71.
The submenu items are described in Table 3-60.
Processor Configuration submenu
Figure 3-50 shows the Processor Configuration submenu screen, on which you can configure features such as hyper-threading and hardware prefetcher for processors.
The submenu items are described in Table 3-42.
Figure 3-50 Processor Configuration submenu screen
Table 3-42 Items on the Processor Configuration submenu screen
Item
Per-Socket Configuration
Access the submenu for per-socket configuration, as shown in Figure 3-51.
The submenu items are described in Table 3-43.
N/A
Processor BSP Revision
Displays the processor revision.
N/A
Processor Socket
Displays the sequence number of the processor socket.
N/A
Processor ID
Displays the processor ID.
N/A
Processor Frequency
Displays the processor frequency.
N/A
Processor Max Frequency
Displays the maximum frequency allowed for each processor.
N/A
Processor Min Frequency
Displays the minimum frequency allowed for each processor.
N/A
Processor TDP
Displays the thermal design power (TDP) of the processor.
N/A
Microcode Revision
Displays the microcode revision.
N/A
L1 Cache RAM
Displays the capacity of the level-1 processor cache.
N/A
L2 Cache RAM
Displays the capacity of the level-2 processor cache.
N/A
L3 Cache RAM
Displays the capacity of the level-3 processor cache.
N/A
Processor 1 Version
Displays the version of processor 1.
N/A
Processor 2 Version
Displays the version of processor 2.
N/A
Hyper-Threading [ALL]
Select Enabled or Disabled to enable or disable hyper-threading for the processors.
Hyper-threading improves the overall system performance by enabling each physical processor core to function as two logical processor cores.
Enabled
Check CPU BIST Result
Select Enabled or Disabled to enable or disable checking the CPU built-in self-test (BIST) result.
If this feature is enabled, the system checks the CPU BIST result and disables process cores that failed the test.
If this feature is disabled, the CPU BIST result is ignored.
Disabled
Monitor/Mwait
Select Enabled or Disabled to enable or disable MONITOR and MWAIT instructions.
For some OSs, to disable CPU C State Control, you must also disable this feature.
Enabled
Enable Intel(R) TXT
Select Enabled or Disabled to enable or disable Intel Trusted Execution Technology (TXT).
Intel TXT provides comprehensive data security protection in a virtualized computing environment.
CAUTION CAUTION:
Set Debug Interface to Disabled before enabling Intel TXT.
Disabled
VMX
This item is configurable only when Enable Intel(R) TXT is set to Disabled.
Select Enabled or Disabled to enable or disable CPU Virtual Machine Extensions (VMX).
CPU VMX improves server hardware resource usage by enabling the virtualization layer or OS that supports VMX to use Intel hardware virtualization capabilities.
Enabled
Enable SMX
Select Enabled or Disabled to enable or disable Intel Safer Mode Extensions (SMX).
Disabled
Debug Interface
Select Enabled or Disabled to enable or disable debug interface.
If debug interface is enabled, you can debug the system.
Enabled
Hardware Prefetcher
Select Enabled or Disabled to enable or disable hardware prefetcher.
If hardware prefetcher is enabled, the CPU prefetches instructions or data from memory to L2 cache before processing the instructions or data. This feature helps improve system performance by reducing memory access time and eliminating potential bottlenecks.
Enabled
Figure 3-51 Per-Socket Configuration submenu screen
Table 3-43 Items on the Per-Socket Configuration submenu screen
Item
CPU Socket 1 Configuration
Submenu for configuring processor 1, as shown in Figure 3-52.
CPU Socket 2 Configuration
Submenu for configuring processor 2.
This item is available only when processor 2 is present.
You can configure processor 2 in the same way processor 1 is configured.
Figure 3-52 CPU Socket 1 Configuration submenu screen
Table 3-44 Items on the CPU Socket 1 Configuration submenu screen
Item
Cores Enabled
Set the number of enabled cores for the processor.
To enable all cores of the processor, set the value to 0.
Common RefCode Configuration submenu
Figure 3-53 shows the Common RefCode Configuration submenu screen, on which you can configure memory mapped I/O (MMIO) above 4 GB and non-uniform memory access (NUMA) settings as described in Table 3-45.
Figure 3-53 Common RefCode Configuration submenu screen
Table 3-45 Items on the Common RefCode Configuration submenu screen
Item
MMIO High Base
Select the address space for MMIO above 4 GB.
Options:
·         56T.
·         40T.
·         24T.
·         16T.
·         4T.
·         1T.
·         896G.
896G
MMIO High Granularity Size
Select the address allocation size for MMIO above 4 GB.
Options:
·         1G.
·         4G.
·         16G.
·         64G.
·         512G.
·         1024G.
64G
NUMA
Select Enabled or Disabled to enable or disable NUMA.
Non-uniform memory access (NUMA) allows a processor to access its local memory faster than a non-local memory.
Enabled
UPI Configuration submenu
Figure 3-53 shows the UPI Configuration submenu screen, from which you can access the UPI General Configuration submenu to configure UPI parameters such as the UPI link frequency.
Figure 3-54 UPI Configuration submenu screen
Figure 3-55 shows the UPI General Configuration submenu screen, on which you can configure parameters such as the UPI link frequency and UPI failover support as described in Table 3-46.
Figure 3-55 UPI General Configuration submenu screen
Table 3-46 Items on the UPI General Configuration submenu screen
Item
UPI Status
Access the submenu that displays UPI information, as shown in Figure 3-56.
The submenu items are described in Table 3-47.
N/A
Link Frequency Select
Select a link frequency.
Options:
·         9.6 GT/s.
·         10.4 GT/s.
·         Auto.
Auto
UPI Failover Support
Select whether to enable UPI failover.
Options:
·         Enabled.
·         Disabled.
·         Auto.
Auto
SNC
Select whether to enable sub-NUMA clustering (SNC).
Options:
·         Enabled.
·         Disabled.
·         Auto.
Disabled
CRC Mode
Select a UPI CRC mode.
Options:
·         16 Bit CRC.
·         32 Bit Rolling CRC.
·         Auto.
Auto
Figure 3-56 UPI Status submenu screen
Table 3-47 Items on the UPI Status submenu screen
Item
Number of CPU
Displays the number of processors.
Number of IIO
Displays the number of integrated I/O modules.
Current UPI Link Speed
Displays the current speed of the UPI link.
Current UPI Link Frequency
Displays the current frequency of the UPI link.
UPI Global MMIO Low Base/Limit
Displays the UPI global MMIO low base address and limit.
UPI Global MMIO High Base/Limit
Displays the UPI global MMIO high base address and limit.
UPI PCIe Configuration Base/Size
Displays the PCIe configuration base address and size.
Figure 3-57 shows the Memory Configuration submenu screen, on which you can configure memory settings such as the memory speed and memory RAS features as described in Table 3-48.
Figure 3-57 Memory Configuration submenu screen
Table 3-48 Items on the Memory Configuration submenu screen
Item
Total Memory
Displays the total memory capacity.
N/A
N/A
IMC Configuration
Access the submenu for configuring the integrated memory controller (IMC), as shown in Figure 3-58.
The submenu items are described in Table 3-49.
N/A
Enforce POR
Select whether to enforce POR restrictions on DDR4 frequency selection to improve memory reliability.
Options:
·         Auto.
·         Enforce POR.
·         Disabled.
Auto
Memory Frequency
Select a memory frequency.
Options:
·         Auto.
·         1600.
·         1866.
·         2133.
·         2400.
·         2666.
Auto
LRDIMM Module Delay
Configure the load-reduced dual inline memory module (LRDIMM) delay setting.
Options:
·         Disabled—Disables the memory regulator controller (MRC) from using SPD bytes 90 to 95 for module delay on LRDIMM memory.
·         Auto—Enables the system to automatically set the LRDIMM module delay. If the SPD value is 0 or out of range, MRC uses the default setting on the LRDIMM module.
Auto
Rank Margin Tool
Select whether to enable the use of the rank margin tool after DDR4 memory training.
Options:
·         Auto—Use the default setting in the MRC.
·         Disabled—Disables the rank margin tool.
·         Enabled—Uses the rank margin tool after DDR4 memory training.
Auto
Data Scrambling for DDR4
Select whether to enable data scrambling for enhanced detection of DDR4 address line errors.
Options:
·         Auto.
·         Disabled.
·         Enabled.
Auto
WR CRC Feature Control
Select whether to enable the write CRC feature.
Options:
·         Auto—Uses the default setting in the MRC. If write CRC is enabled in the MRC, this item displays Auto.
·         Disabled—Disables write CRC.
·         Enabled—Enables write CRC.
Auto
DIMM Isolation Enable
Select whether to enable DIMM isolation.
Options:
·         Auto—Uses the default setting in the MRC. If DIMM isolation is enabled in the MRC, this item displays Auto.
·         Disabled—Disables DIMM isolation for command/address verification and the CRC write feature.
·         Enabled—Enables DIMM isolation for command/address verification and the CRC write feature.
Auto
Custom Refresh Enable
Select Enabled or Disabled to enable or disable setting a custom memory refresh rate.
N/A
Custom Refresh Rate
This item is available only when Custom Refresh Enable is set to Enabled.
Set the memory refresh rate.
N/A
Refresh Options
Select a memory refresh mode.
Options:
·         Acc Self Refresh—Enables accelerated memory refresh.
·         2x Refresh—Refreshes memory data at twice the normal refresh rate.
N/A
C/A Parity Enable
Select whether to enable command and address (C/A) parity check.
Options:
·         Auto—Uses the default setting in the MRC. If C/A parity check is enabled in the MRC, this item displays Auto.
·         Disabled—Disables parity check on DDR4 commands and addresses.
·         Enabled—Enables parity check on DDR4 commands and addresses.
Auto
Memory Topology
Access the submenu that displays memory information, as shown in Figure 3-59.
The submenu items are described in Table 3-50.
N/A
Memory Map
Access the submenu for configuring memory mapping and interleaving, as shown in Figure 3-60.
You can enable memory interleaving to improve memory read and write performance.
The submenu items are described in Table 3-51.
N/A
Memory RAS Configuration
Access the submenu for configuring memory reliability, availability, and serviceability (RAS) settings, as shown in Figure 3-61.
The submenu items are described in Table 3-52.
N/A
Figure 3-58 IMC Configuration submenu screen
Table 3-49 Items on the IMC Configuration submenu screen
Item
Enable ProcessorNumber IMC
Select Enabled or Disabled to enable or disable the integrated memory controller for a processor.
Enabled
Figure 3-59 Memory Topology submenu screen
Table 3-50 Items on the Memory Topology submenu screen
Item
Processor1 Ch1 DIMM A1: DIMM is Present.DIMM Status:Enabled.DIMM Details: 2666MT/s Micron SRx4 16GB RDIMM
Displays information about the memory module of a processor (for example, DIMM A1 in channel 1 of processor 1), including:
·         Presence of the DIMM.
·         Enabling status of the DIMM.
·         Memory specifications:
¡  Memory frequency.
¡  Vendor.
¡  Number of ranks and bit width.
¡  Memory capacity.
¡  Memory type.
Figure 3-60 Memory Map submenu screen
Table 3-51 Items on the Memory Map submenu screen
Item
Volatile Memory Mode
Select the volatile memory mode.
Options:
·         1LM.
·         2LM.
·         Auto.
1LM
1LM Memory Interleave Granularity
Select the granularity for 1LM memory interleaving.
Options:
·         256B Target,256B Channel.
·         64B Target,64B Channel.
·         Auto.
Auto
IMC Interleaving
Select an interleaving mode for integrated memory controllers.
Options:
·         Auto.
·         1-way Interleave.
·         2-way Interleave.
Auto
Channel Interleaving
Select a memory channel interleaving mode.
Options:
·         Auto.
·         1-way Interleave.
·         2-way Interleave.
·         3-way Interleave.
Auto
Rank Interleaving
Select a memory rank interleaving mode.
Rank interleaving enables interleaving of memory ranks on the same channel.
Options:
·         Auto.
·         1-way Interleave.
·         2-way Interleave.
·         4-way Interleave.
·         8-way Interleave.
Auto
Socket Interleave Below 4GB
Select Enabled or Disabled to enable or disable socket interleaving for memory below 4 GB.
This item is automatically disabled and cannot be enabled if the NUMA item is enabled. For more information about the NUMA item, see "Common RefCode Configuration submenu."
Disabled
Figure 3-61 Memory RAS Configuration submenu screen
Table 3-52 Items on the Memory RAS Configuration submenu screen
Item
Mirror Mode
Select a memory mirroring mode to optimize system reliability by using half the system memory capacity for backup.
Options:
·         Disabled.
·         Mirror Mode 1LM.
After you enable memory mirroring, the Total Memory Size item on the Memory Configuration submenu screen displays the total available memory, which is half the installed physical memory. To identify the installed physical memory capacity, access the Smbios Type 17 structure from a shell (for example, the CLI) of the operating system.
If all the DIMM slots are installed with DIMMs and memory mirroring is enabled, the memory capacity displayed on the POST self-test screen and the BIOS setup utility is larger than half the total installed physical memory.
Disabled
Enable Partial Mirror
Select Mirror Mode 1LM to enable partial mirroring by using 1LM memory or select Disabled to disable partial mirroring.
To use partial mirroring, you must select Disabled for Memory Rank Sparing.
Disabled
Memory Rank Sparing
Select Enabled or Disabled to enable or disable memory sparing for memory ranks.
Memory rank sparing uses some ranks in the memory as spare ranks for the non-spare ranks on the same channel.
Memory rank sparing is mutually exclusive with memory mirroring.
When the independent RAS mode is set and memory rank sparing is enabled, both the independent RAS mode and memory rank sparing take effect.
Disabled
Multi Rank Sparing
Select the number of spare ranks per channel. This item is available only when Memory Rank Sparing is set to Enabled.
Options:
·         One Rank—Uses one spare rank on a channel. To use one spare rank, each channel must have a minimum of two ranks.
·         Two Rank—Uses two spare ranks on a channel. To use two spare ranks, each channel must have a minimum of four ranks.
N/A
Correctable Error Threshold
Set the correctable error threshold.
Value range: 0 to 32767.
Value 0 indicates that no correctable error threshold is set.
4096
SDDC Plus One
Select Enabled or Disabled to enable or disable single device data correction (SDDC) plus one-bit error correction.
Disabled
ADDDC Sparing
Select Enabled or Disabled to enable or disable adaptive double device data correction sparing (ADDDC).
This feature requires a B/L forced interleaving interval of 64B.
ADDDC sparing can correct two-bit memory errors.
Disabled
Patrol Scrub
Select Enabled or Disabled to enable or disable patrol scrubbing.
Patrol scrubbing allows a processor to automatically search for and correct correctable memory errors at regular intervals while the system is idle.
Enabled
Patrol Scrub Interval
Set the patrol scrub interval. This item is available only when Patrol Scrub is set to Enabled.
24
Demand Scrub
Select Enabled or Disabled to enable or disable demand scrubbing.
Demand scrubbing attempts to correct data errors when memory is read.
Disabled
IIO Configuration menu
Figure 3-62 shows the IIO Configuration submenu screen, on which you can configure the peripheral component interconnect express (PCIe) slots, including their link speed and maximum payload size, as described in Table 3-53.
Figure 3-62 IIO Configuration submenu screen
Table 3-53 Items on the IIO Configuration submenu screen
Item
Processor n Configuration
Access the IIO configuration submenu for a processor, for example, processor 1 or processor 2.
The port items on the Processor 1 Configuration submenu vary by server model and PCIe module.
Figure 3-63 and Figure 3-64 use the Processor 1 Configuration submenu screen and the Processor 2 Configuration submenu screen for the R4900 G3 server as examples.
The submenu items are described in Table 3-54.
N/A
Intel® VT for Directed I/O (VT-d)
Access the submenu for enabling or disabling Intel virtualization technology for directed I/O (VT-d), as shown in Figure 3-67.
The submenu items are described in Table 3-56.
N/A
Intel® VMD technology
Access the submenu for configuring Intel Volume Management Device (VMD) technology, as shown in Figure 3-68 .
The submenu items are described in Table 3-57.
N/A
PCIe Hot Plug
Select Enabled or Disabled to enable or disable hot swapping of PCIe modules.
Enabled
Figure 3-63 Processor 1 Configuration submenu screen
Figure 3-64 Processor 2 Configuration submenu screen
Table 3-54 Items on the Processor n Configuration submenu screen
Item
PCIe port submenu items, for example:
Processor 1 PcieBr0D00F0 - Port 0/DMI
Processor 1 PcieBr1D00F0 - Port 1A
Processor 2 PcieBr1D02F0 - Port 1C
Submenus for configuring PCIe ports.
Figure 3-65 shows the submenu for configuring Processor 1 PcieBr0D00F0 - Port 0/DMI, which slightly differs from the submenu for other PCIe ports, as shown in Figure 3-66 .
The submenu items are described in Table 3-55.
In this document, the PCIe port identified with "DMI" is referred to as the DMI PCIe port. The PCIe ports that do not have the "DMI" identification are referred to as non-DMI PCIe ports.
Figure 3-65 Submenu screen for Processor 1 PcieBr0D00F0 - Port 0/DMI
Figure 3-66 Submenu screen for non-DMI PCIe ports
Table 3-55 Items on the Processor 1 PcieBr0D00F0 - Port 0/DMI submenu screen
Item
PCI-E Port
This item is available only for non-DMI PCIe ports.
Select whether to enable the PCIe port.
Options:
·         Auto.
·         Enabled.
·         Disabled.
If Disabled is selected, the Hot Plug Capable and Link Speed items will not be available.
Auto
Hot Plug Capable
Select Enabled or Disabled to enable or disable the hot swapping feature on the PCIe port.
N/A
Surprise Hot Plug Capable
Select Enabled or Disabled to enable or disable the surprise hot swapping feature on the PCIe port.
N/A
Link Speed
Select a link speed for the PCIe port.
Options:
·         Auto.
·         Gen 1 (2.5 GT/s).
·         Gen 2 (5.0 GT/s).
·         Gen 3 (8.0 GT/s).
Auto
PCI-E Port Link Status
Displays the PCIe port link status.
N/A
PCI-E Port Link Max
Displays the maximum bandwidth of the PCIe port link.
N/A
PCI-E Port Link Speed
Displays the PCIe port link speed.
N/A
Figure 3-67 Intel® VT for Directed I/O (VT-d) submenu screen
Table 3-56 Items on the Intel® VT for Directed I/O (VT-d) submenu screen
Item
Select Enabled or Disabled to enable or disable Intel virtualization technology for directed I/O (VT-d).
Intel VT-d enhances system security and reliability, and improves the performance of I/O devices in a virtualized environment.
Enabled
Figure 3-68 Intel® VMD technology submenu screen
Table 3-57 Items on the Intel® VMD technology submenu screen
Item
Intel® VMD for Volume Management Device on Processor 1
VMD configuration submenu for the volume management device on Processor 1, as shown in Figure 3-69.
The submenu items are described in Table 3-58.
Intel® VMD for Volume Management Device on Processor 2
VMD configuration submenu for the volume management device on Processor 2, as shown in Figure 3-70.
The submenu items are described in Table 3-59.
Figure 3-69 Intel® VMD for Volume Management Device on Processor 1 submenu screen
Table 3-58 Items on the Intel® VMD for Volume Management Device on Processor 1submenu screen
Item
Intel® VMD for Volume Management Device for PStack0
This item is available only in UEFI boot mode.
Select whether to enable Intel® VMD for the volume management device in PStack0.
Options:
·         Disabled—Disables Intel® VMD for the volume management device for PStack0.
·         Enabled—Enables Intel® VMD for the volume management device for PStack0.
·         Auto—Enables Intel® VMD automatically when an NVMe expander module is detected for the stack during POST.
Auto
Intel® VMD for Volume Management Device for PStack2
Select whether to enable Intel® VMD for the volume management device in PStack2.
Options:
·         Disabled—Disables Intel® VMD for the volume management device for PStack2.
·         Enabled—Enables Intel® VMD for the volume management device for PStack2.
Auto
Figure 3-70 Intel® VMD for Volume Management Device on Processor 2 submenu screen
Table 3-59 Items on the Intel® VMD for Volume Management Device on Processor 2 submenu screen
Item
Options:
Auto
Intel® VMD for Volume Management Device for PStack1
Select whether to enable Intel® VMD for the volume management device in PStack1.
Options:
·         Disabled—Disables Intel® VMD for the volume management device for PStack1.
·         Enabled—Enables Intel® VMD for the volume management device for PStack1.
Auto
Options:
Auto
Advanced Power Management Configuration submenu
Figure 3-71 shows the Advanced Power Management Configuration submenu screen, on which you can configure advanced power management parameters, including P state control and C state control for processors and power management policy.
Figure 3-71 Advanced Power Management Configuration submenu screen
Table 3-60 Items on the Advanced Power Management Configuration submenu screen
Item
CPU P State Control
Submenu for configuring CPU P-state control options, as shown in Figure 3-72.
On the submenu, you can select whether to enable Enhanced Intel SpeedStep Technology (EIST) and turbo mode as described in Table 3-61.
CPU C State Control
Submenu for configuring CPU C-state control options, as shown in Figure 3-73.
On the submenu, you can control the power consumption of CPUs in idle state as described in Table 3-62.
Package C State Control
Submenu for configuring package C state control options, as shown in Figure 3-74.
On the submenu, you can set the C2 to C3 state transition timer as described in Table 3-63.
CPU Thermal Management
Submenu for configuring CPU thermal management options, as shown in Figure 3-75.
The submenu items are described in Table 3-64.
CPU Advanced PM Tuning
Submenu for configuring CPU advanced power management tuning, as shown in Figure 3-77.
The submenu items are described in Table 3-66.
Figure 3-72 CPU P State Control submenu screen
Table 3-61 Items on the CPU P State Control submenu screen
Item
EIST (P-States)
Select Enabled or Disabled to enable or disable Enhanced Intel SpeedStep Technology (EIST).
EIST allows the system to automatically adjust processor voltage and core frequency to reduce power consumption and heat dissipation.
Enabled
Turbo Mode
Select Enabled or Disabled to enable or disable Turbo mode.
Enabled
Figure 3-73 CPU C State Control submenu screen
Table 3-62 Items on the CPU C State Control submenu screen
Item
Autonomous Core C-State
Select Enabled or Disabled to enable or disable the autonomous core C-state.
If this item is enabled, the hardware autonomously chooses to enter a C-state based on power consumption and clock speed.
Disabled
CPU C6 Report
Select whether to enable the BIOS to report the C6 state to the operating system.
Options:
·         Enabled.
·         Disabled.
·         Auto.
Disabled
Enhanced Halt State (C1E)
Select Enabled or Disabled to enable or disable the C1E feature.
C1E feature reduces the power consumption of a CPU by reducing its clock cycle and voltage during a Halt-state.
Disabled
Figure 3-74 Package C State Control submenu screen
Table 3-63 Items on the Package C State Control submenu screen
Item
Package C State
Select the package C state limit.
Options:
·         Auto.
·         C0/C1 state.
·         C2 state.
·         C6 (non Retention) state.
·         C6 (Retention) state.
·         No Limit.
C0/C1 state
C2C3TT
Set the C2 to C3 state transition timer.
Value range: 0 to 255.
If the timer is set to 0, the BIOS sets the timer automatically.
0
Figure 3-75 CPU Thermal Management submenu screen
Table 3-64 Items on the CPU Thermal Management submenu screen
Item
CPU T State Control
CPU T-state control submenu, as shown in Figure 3-76 .
The submenu items are described in Table 3-65.
Figure 3-76 CPU T State Control submenu screen
Table 3-65 Items on the CPU T State Control submenu screen
Item
Software Controlled T-State
Select Enabled or Disabled to enable or disable software controlled T-state.
Disabled
Figure 3-77 CPU Advanced PM Tuning submenu screen
Table 3-66 Items on the CPU Advanced PM Tuning submenu screen
Item
Energy Perf BIAS
Energy and performance bias configuration submenu, on which you can configure the energy and performance policy for the system, as shown in Figure 3-78.
The submenu items are described in Table 3-67.
Figure 3-78 Energy Perf BIAS submenu screen
Table 3-67 Items on the Energy Perf BIAS submenu screen
Item
Energy Performance Tuning
Select the operating system or the BIOS to control energy and performance bias tuning.
Options:
·         OS Controls EPB.
·         BIOS Controls EPB.
BIOS Controls EPB
ENERGY_PERF_BIAS_CFG Mode
This item is available only when Energy Performance Tuning is set to BIOS Controls EPB.
Select an energy and performance bias option. The setting for this option overrides the energy and performance bias configured by the operating system.
Options:
·         PerformanceProvides maximum system performance (maximum cooling) at the expense of energy efficiency.
·         Balanced PerformanceProvides optimum performance with good energy efficiency.
·         Balanced PowerProvides optimum power efficiency with good performance.
·         PowerProvides maximum power efficiency (maximum power saving) at the expense of system performance.
Performance
Server Management menu
Figure 3-79 shows the Server Management menu, on which you can configure server management features such as the FRB-2 timer, OS watchdog timer, system event logging, and HDM.
The menu items are described in Table 3-41.
You can also access the firmware information submenu from the Server Management menu.
Figure 3-79 Server Management menu screen
Table 3-68 Items on the Server Management menu screen
Item
Wait for HDM
Select Enabled or Disabled to enable or disable the wait for HDM feature.
Disabled
FRB-2 Timer
Select Enabled or Disabled to enable or disable the FRB-2 timer.
Enabled
FRB-2 Timer Timeout
Set the timeout time for the FRB-2 timer.
Options:
·         3 Minutes.
·         4 Minutes.
·         5 Minutes.
·         6 Minutes.
·         10 Minutes.
·         15 Minutes.
·         20 Minutes.
15 Minutes
FRB-2 Timer Policy
Select the action to take when the FRB-2 timer expires.
Options:
·         Do NothingNo action is taken.
·         Reset—Reboot the system.
·         Power Down—Removes the main power from the system.
·         Power Cycle—Power cycles the system.
Do Nothing
OS Watchdog Timer
Select Enabled or Disabled to enable or disable the OS watchdog timer.
The OS watchdog timer starts when the operating system begins to run.
Disabled
OS Wtd Timer Timeout
This item is configurable only when OS Watchdog Timer is set to Enabled.
Set the timeout time for the OS watchdog timer.
Options:
·         5 Minutes.
·         10 Minutes.
·         15 Minutes.
·         20 Minutes.
10 Minutes
OS Wtd Timer Policy
Select the action to take when the OS watchdog timer expires.
Options:
·         Do Nothing—No action is taken.
·         Reset—Reboots the system.
Reset
System Event Log
Access the submenu for configuring system event logging, as shown in Figure 3-80.
The submenu items are described in Table 3-69.
N/A
HDM Network Configuration
Access the network configuration submenu for HDM access, as shown in Figure 3-82.
The submenu items are described in Table 3-70.
N/A
HDM User Settings
Access the submenu for managing HDM user accounts, as shown in Figure 3-83.
The submenu items are described in Table 3-71.
N/A
Load HDM Default
Restore the factory default settings for HDM.
CAUTION CAUTION:
The restoration process takes about 30 seconds. Do not configure any HDM settings before the server restarts.
N/A
Firmware Information
Access the submenu that displays the firmware information, as shown in Figure 3-86.
The submenu items are described in Table 3-75.
N/A
HDD Slot Number and Silkscreen Mapping
Access the submenu that displays drive slot numbers and their corresponding silkscreens, as shown in Figure 3-87 and Figure 3-88.
The submenu items are described in Table 3-76.
N/A
AC Restore Settings
Select the power-on policy of the server when the server is connected to the power source.
Options:
·         Always Power On—Enables the server to automatically start up when it is connected to the power source.
·         Always Remain Off—Disables the server from automatically start up when it is connected to the power source.
·         Restore Last Power State—Enables the server to return to the power state on the previous power-off.
You can configure the power-on policy from the BIOS and HDM. The configuration in HDM takes precedence over the configuration in the BIOS.
Figure 3-80 System Event Log submenu screen
Table 3-69 Items on the System Event Log submenu screen
Item
Enabling/Disabling Options
SEL Components
Select Enabled or Disabled to enable or disable system event logging.
Enabled
Erasing Settings
Erase SEL
This item is available only when SEL Components is set to Enabled.
Select a system event log erasure option.
Options:
·         No—Disable automatic system event log erasure.
·         Yes, On next reset—Erases the system event log only at next reboot.
·         Yes, On every reset—Erases the system event log at each reboot.
No
Custom EFI Logging Options
Log EFI Status Codes
Configure EFI status code logging.
Options:
·         Disabled—Disables logging EFI status codes.
·         Both—Logs both EFI error codes and progress codes.
·         Error Code—Logs only EFI error codes.
·         Progress Code—Logs only EFI progress codes.
Error Code
Figure 3-81 HDM Network Configuration submenu
Table 3-70 Items on the HDM Network Configuration submenu screen
Item
Bond Mode Setting
Select Enabled or Disabled to enable or disable HDM network port bonding.
HDM network port bonding aggregates the HDM dedicated network port and the shared network port into a bond port.
The bond port uses the IP address setting of the dedicated network port.
After you enable HDM network port bonding, the HDM Network Configuration submenu displays only the HDM bonding network port information, and the BIOS setup page displays only the IP address of the HDM bond port.
Disabled
Configuration Address Source
Select the IP address obtaining method for the port.
Options:
·         Unspecified—Uses the current IP address obtaining method and settings.
·         Static—Uses the manually configured static IP address.
·         DynamicHdmDhcp—Obtains an IP address from a DHCP server.
Unspecified
Current Configuration Address Source
Displays the current IP address obtaining method.
N/A
Station IP Address
Displays the IP address of the port.
N/A
Subnet Mask
Displays the subnet mask.
N/A
Station MAC address
Displays the MAC address of the port.
N/A
Router IP Address
Displays the gateway IP address.
N/A
Router MAC Address
Displays the gateway MAC address.
N/A
Figure 3-82 HDM User Settings submenu screen
Table 3-71 Items on the HDM User Settings submenu screen
Item
Add User
Submenu for adding an HDM user account, as shown in Figure 3-83.
The submenu items are described in Table 3-72.
Delete User
Submenu for deleting an HDM user account, as shown in Figure 3-84.
The submenu items are described in Table 3-73.
Change User Settings
Submenu for changing the settings of an existing HDM user account, as shown in Figure 3-85 .
The submenu items are described in Table 3-74.
Figure 3-83 Add User submenu screen
Table 3-72 Items on the Add User submenu screen
Item
User Name
Specify the username, a case-sensitive string of 1 to 16 characters. The user name can contain letters, digits, and underscores (_).
N/A
User Password
Specify an HDM user password.
If password complexity check is enabled on the HDM Web interface, the password must meet the following requirements:
·         8 to 20 characters in length.
·         Case sensitive. Valid characters are letters, digits, spaces, and the following special characters: ` ~ ! @ # $ % ^ & * ( ) _ + - = [ ] \ { } | ; ' : " , . / < > ?
·         Must contain characters from at least two of the following categories: uppercase letters, lowercase letters, and digits.
·         Must contain at least one space or special character.
·         Must not be identical to the user name or the reverse of the username.
If password complexity check is disabled on the HDM Web interface, the password must meet the following requirements:
·         2 to 20 characters in length.
By default, password complexity check is enabled on the HDM Web interface. For more information about enabling or disabling password complexity check, see HDM online help.
N/A
User Privilege Limit
Select a user role, which represents a set of network and service access privileges.
Options:
·         None—Does not assign any network access permissions to the HDM user account.
·         User—Assigns the user the read-only permission to HDM.
·         Operator—Assigns the user the read permission to all HDM features and write permission to a limited set of HDM features.
·         AdministratorAssigns the user read and write permissions to all HDM features.
None
Access to HDM
Select whether to enable HDM access for the HDM user account.
Options:
·         Enabled.
·         Disabled.
·         Default—Retains the saved setting.
Figure 3-84 Delete User submenu screen
Table 3-73 Items on the Delete User submenu screen
Item
User Name
Enter the username of the HDM user account to be deleted.
User Password
Enter the password of the HDM user account to be deleted.
Figure 3-85 Change User Settings submenu screen
Table 3-74 Items on the Change User Settings submenu screen
Item
User Name
Enter the username of an existing HDM user account.
N/A
User Password
Enter the password of the HDM user account.
N/A
Access to HDM
This item is available only after you specify the correct user name and password for a user account.
Select whether to enable HDM access for the user account.
Options:
·         Enabled.
·         Disabled.
Change User Password
This item is available only after you specify the correct user name and password for an HDM user account.
Specify a new password.
The password must meet the complexity requirements described in Table 3-72.
N/A
This item is available only after you specify the correct user name and password of an HDM user account.
Assign role-based privileges to the user account.
Options:
·         None—Retains the current privileges of the user account.
·         Administrator—Assigns the user read and write permissions to all HDM features.
None
Figure 3-86 Firmware Information submenu screen
Table 3-75 Items on the Firmware Information submenu screen
Item
BIOS Information
BIOS Vendor
Displays the BIOS vendor.
Compliancy
Displays the standard with which the BIOS is compliant.
Project Name
Displays the project name.
BIOS Version
Displays the BIOS version.
Build Date and Time
Displays the date and time of the BIOS build.
HDM Information
HDM Self Test Status
Displays the HDM self test status.
HDM Device ID
Displays the HDM device ID.
HDM Device Revision
Displays the HDM device revision.
HDM Firmware Revision
Displays the HDM firmware revision.
IPMI Version
Displays the IPMI version.
Figure 3-87  HDD Slot Number and Silkscreen Mapping submenu screen (1)
Figure 3-88 HDD Slot Number and Silkscreen Mapping submenu screen (2)
Table 3-76 Items on the HDD Slot Number and Silkscreen Mapping submenu screen
Item
BIOS(Port)
Displays the drive slot numbers in the BIOS.
Silkscreen
Displays the silkscreens on drives.
Connecting 8SFF
2SFF(Front)+RSTe(SATA)
Indicates the two front-installed SFF drives controlled by the embedded RSTe RAID controller.
SATA indicates drive slot numbers displayed on the PCH SATA Configuration screen.
2SFF(Front)+RSTe(sSATA)
sSATA indicates drive slot numbers displayed on the PCH sSATA Configuration screen.
Connecting 4NVME+4SFF HDD
4NVME+Retimer
Indicates the four NVMe SSDs controlled by the 4-port NVMe expander module (Retimer).
4SFF HDD+RSTe(SATA)
Indicates the four SFF HDDs controlled by the embedded RSTe RAID controller.
4SFF HDD+RAID/HBA
Indicates the four SFF HDDs controlled by the RAID or HBA controller.
Connecting 8LFF HDD+4NVME
4NVME+Retimer
Connecting 12LFF SATA HDD
8LFF+RSTe(SATA)
Indicates the eight LFF HDDs controlled by the embedded RSTe RAID controller.
4LFF+RSTe(sSATA)
Indicates the four LFF drives controlled by the embedded RSTe RAID controller.
Connecting 8NVME
8NVME+Retimer (slot 1/2)
Indicates the four NVMe SSDs controlled by the 4-port NVMe expander module (Retimer) installed in PCIe slot 1 or 2.
For a 1U server, the expander module is installed in PCIe slot 1. For a 2U server, the expander module is installed in PCIe slot 2.
8NVME+Retimer (slot 2/5)
Indicates the four NVMe SSDs controlled by the 4-port NVMe expander module (Retimer) installed in PCIe slot 2 or 5.
For a 1U server, the expander module is installed in PCIe slot 2. For a 2U server, the expander module is installed in PCIe slot 5.
8NVME+Switch
Indicates the eight NVMe SSDs controlled by the 8-port NVMe expander module (Switch).
Security menu
Figure 3-89 shows the Security menu, on which you can configure security features such as setting the BIOS administrator and user passwords.
The menu items are described in Table 3-77.
Figure 3-89 Security menu screen
Table 3-77 Items on the Security menu screen
Item
Password Description
Displays the password description.
N/A
Administrator Password
Set the administrator password.
If you access the BIOS with the administrator password, you have full access to the BIOS.
Empty
User Password
Set the user password.
If you access the BIOS with the user password, you have limited access to the BIOS. Table 3-78 shows the submenus and submenu items that are inaccessible with the user password.
Empty
HDD Security Configuration:
Hard disk drive that supports security configuration, for example, P3:SAMSUNG MZ7LM240HCGR-00005
If the server contains hard disk drives that support security configuration, this item is displayed and the hard disk drives are listed.
Access the submenu for configuring security settings for a hard disk drive, as shown in Figure 3-90.
The submenu items are described in Table 3-79.
N/A
Secure Boot Menu
Access the submenu for configuring secure boot, as shown in Figure 3-91.
The submenu items are described in Table 3-80.
N/A
Table 3-78 BIOS submenus and submenu items inaccessible with the user password
Level-1 menu
Level-2 submenu
Submenu items
Advanced
ACPI Settings
Enable ACPI Auto Configuration
Lock Legacy Resources
PCI Subsystem Settings
Above 4G Decoding
SR-IOV Support
USB Configuration
Legacy USB Support
XHCI Hand-off
USB Mass Storage Device Support
Server Mgmt
Wait for HDM
Entire submenu inaccessible
FRB-2 Timer
FRB-2 Timer Timeout
FRB-2 Timer Policy
OS Watchdog Timer
OS Wtd Timer Policy
System Event Log
HDM User Settings
Security
Secure Boot Menu
System Mode
Secure Boot
Vendor Keys
Attempt Secure Boot
Secure Boot Mode
Key Management
Figure 3-90 HDD Security Configuration submenu screen
4
Table 3-79 Items on the HDD Security Configuration submenu screen
Item
Security Supported
Displays whether the hard disk drive supports security configuration.
Security Enabled
Displays whether an HDD user password has been set.
If an HDD user password has been set, you must provide the password to unlock the hard disk drive before using it.
Security Locked
Displays whether the hard disk drive is locked.
If the hard disk drive is locked, enter the user password to unlock it.
Security Frozen
Displays the security frozen status.
Options:
·         Yes—The hard disk drive can be used but you cannot configure a user password for it. To change the security frozen status to No, you must power cycle the server.
·         No—The hard disk drive is not frozen. You can set the HDD user password.
HDD User Pwd Status
Displays whether an HDD user password is set (Installed) or not (Not Installed.)
Set User Password
Set an HDD user password, a case-sensitive string of 1 to 32 characters which can contain letters, digits, spaces, and the following special characters:
Store the HDD user password in a safe place. You will be asked to enter the password during server startup. The hard disk drive will be locked on three consecutive password attempt failures.
Figure 3-91 Secure Boot Menu submenu screen
Table 3-80 Items on the Secure Boot menu screen
Item
System Mode
Displays the system mode.
N/A
Secure Boot
Displays whether secure boot is active or inactive.
N/A
Vendor Keys
Displays whether the vendor keys have been modified.
N/A
Attempt Secure Boot
Select Enabled or Disabled to enable or disable secure boot.
Secure boot can be enabled only when the following requirements are met:
·         The system is in user mode and the platform key is installed.
·         The CSM Support item on the CSM Configuration menu is set to Disabled.
Disabled
Secure Boot Mode
Select a secure boot mode.
Options:
·         Standard.
·         Customized.
In customized boot mode, you can change the image execution policy and manage secure boot keys.
Customized
Key Management
Access the submenu for key management, as shown in Figure 3-92.
The submenu items are described in Table 3-81.
N/A
Figure 3-92 Key Management submenu screen
Table 3-81 Items on the Key Management submenu screen
Item
Provision Factory Default Keys
Select Enabled or Disabled to enable or disable provisioning the factory default keys when the system is in setup mode.
Disabled
Install Factory Default Keys
Install all factory default keys.
When factory default key installation is complete, this item changes to Reset all Secure Boot Variables.
N/A
Save All Secure Boot Variables
Save all secure boot variables.
N/A
Platform Key(PK)
Access the submenu for managing the platform key. You can select Set New Var to set a new key.
N/A
Key Exchange Keys
Access the submenu for managing key exchange keys.
Options:
·         Set New Var.
·         Append Key.
N/A
Authorized Signatures
Access the submenu for configuring authorized signatures.
Options:
·         Set New Var.
·         Append Key.
N/A
Forbidden Signatures
Access the submenu for managing forbidden signatures.
Options:
·         Set New Var.
·         Append Key.
N/A
Authorized TimeStamps
Access the submenu for managing authorized timestamps.
Options:
·         Set New Var.
·         Append Key.
N/A
OsRecovery Signatures
Access the submenu for configuring operating system recovery signatures.
Options:
·         Set New Var.
·         Append Key.
N/A
Boot menu
Figure 3-93 shows the Boot menu, on which you can configure boot settings such as the boot type and boot sequence.
The menu items are described in Table 3-82.
Figure 3-93 Boot menu screen
Table 3-82 Items on the Boot menu screen
Item
Setup Prompt Timeout
Set the number of seconds to wait for the setup activation key.
Value range: 1 to 65535.
1
Bootup NumLock State
Select On or Off to turn on or turn off the NumLock key on the numeric keypad of the keyboard at system boot.
On
Quiet Boot
Select Enabled or Disabled to enable or disable the quiet boot mode.
Disabled
Boot mode Select
Select a boot mode.
Options:
·         Legacy.
·         UEFI.
UEFI
Fixed Boot Order Priorities
This item allows you to set a prioritized list of bootable devices from which the system can boot.
Select each boot option (Boot Option #N) to specify a bootable device, as shown in Figure 3-94 . The lower the option number, the higher the priority.
In legacy mode, a drive is eligible for selection only if it has the highest boot priority (BBS priority) among all the drives of the same type.
Boot Option #9 is available only in UEFI boot mode.
N/A
UEFI Hard Disk Drive BBS Priorities
Access the submenu for configuring the boot priorities of hard disk drives, as shown in Figure 3-95 .
N/A
This item is available only in legacy boot mode.
Access the submenu for configuring the boot priorities of hard disk drives.
N/A
UEFI CDROM/DVD Drive BBS Priorities
This item is available only in UEFI boot mode and when one or more CD- or DVD-ROM drives are connected.
Access the submenu for configuring the boot priorities of connected CD- or DVD-ROM drives, as shown in Figure 3-96 .
The submenu items are described in Table 3-84.
N/A
This item is available only in legacy boot mode and when one or more CD- or DVD-ROM drives are connected.
Access the submenu for configuring the boot priorities of connected CD- or DVD-ROM drives.
N/A
UEFI USB Hard Disk Drive BBS Priorities
This item is available only in UEFI boot mode and when one or more hard disk drives are connected through USB interfaces.
Access the submenu for configuring the boot priorities of hard disk drives connected through USB interfaces, as shown in Figure 3-97 .
The submenu items are described in Table 3-85.
N/A
This item is available only in legacy boot mode and when one or more hard disk drives are connected through USB interfaces.
Access the submenu for configuring the boot priorities of hard disk drives connected through USB interfaces.
N/A
UEFI USB CDROM/DVD Drive BBS Priorities
This item is available only in UEFI boot mode and when one or more CD- or DVD-ROM drives are connected through USB interfaces.
Access the submenu for configuring the boot priorities of CD- or DVD-ROM drives connected through USB interfaces, as shown in Figure 3-98 .
The submenu items are described in Table 3-86.
N/A
This item is available only in legacy boot mode and when one or more CD- or DVD-ROM drives are connected through USB interfaces.
Access the submenu for configuring the boot priorities of CD- or DVD-ROM drives connected through USB interfaces.
N/A
UEFI USB Key Drive BBS Priorities
This item is available only in UEFI boot mode and when one or more USB key drives are connected.
Access the submenu for configuring the boot priorities of connected USB key drives.
N/A
This item is available only in legacy boot mode and when one or more USB key drives are connected.
N/A
UEFI USB Floppy Drive BBS Priorities
This item is available only in UEFI boot mode and when one or more floppy drives are connected through USB interfaces.
Access the submenu for configuring the boot priorities of the floppy drives connected through USB interfaces.
N/A
This item is available only in legacy boot mode and when one or more floppy drives are connected through USB interfaces.
Access the submenu for configuring the boot priorities of floppy drives connected through USB interfaces.
N/A
UEFI Network Drive BBS Priorities
Access the submenu for configuring the boot priorities of available network drives.
N/A
N/A
UEFI Application Boot Priorities
Access the submenu for configuring UEFI application boot priorities.
N/A
Figure 3-94 Setting the prioritized list of bootable devices
Figure 3-95 UEFI Hard Disk Drive BBS Priorities submenu screen
Table 3-83 Items on the UEFI Hard Disk Drive BBS Priorities submenu screen
Item
Boot Option #1
Select a hard disk drive as the first boot option.
Boot Option #2
Select a hard disk drive as the second boot option.
Figure 3-96 UEFI CDROM/DVD Drive BBS Priorities submenu screen
Table 3-84 Items on the UEFI CDROM/DVD Drive BBS Priorities submenu screen
Item
Boot Option #1
Select a CD- or DVD-ROM drive as the first boot option.
Figure 3-97 UEFI USB Hard Disk Drive BBS Priorities submenu screen
Table 3-85 Items on the UEFI USB Hard Disk Drive BBS Priorities submenu screen
Item
Boot Option #1
Select a hard disk drive connected through a USB interface as the first boot option.
Figure 3-98 UEFI USB CDROM/DVD Drive BBS Priorities submenu screen
Table 3-86 Items on the UEFI USB CDROM/DVD Drive BBS Priorities submenu screen
Item
Boot Option #1
Select a CD- or DVD-ROM drive connected through a USB device as the first boot option.
Boot Option #2
Select a CD- or DVD-ROM drive connected through a USB device as the second boot option.
Figure 3-99 UEFI USB Key Drive BBS Priorities submenu screen
Table 3-87 Items on the UEFI USB Key Drive BBS Priorities submenu screen
Items
Boot Option #1
Select a USB key drive as the first boot option.
Figure 3-100 EFI USB Floppy Drive BBS Priorities submenu screen
Table 3-88 Items on the UEFI USB Floppy Drive BBS Priorities submenu screen
Item
Boot Option #1
Select a floppy drive connected through a USB interface as the first boot option.
Figure 3-101 UEFI Network Drive BBS Priorities submenu screen
Table 3-89 Items on the UEFI Network Drive BBS Priorities submenu screen
Item
Boot Option #1
Select an available network drive as the first boot option.
Boot Option #2
Select an available network drive as the second boot option.
Boot Option #3
Select an available network drive as the third boot option.
Boot Option #4
Select an available network drive as the fourth boot option.
Boot Option #5
Select an available network drive as the fifth boot option.
Boot Option #6
Select an available network drive as the sixth boot option.
Boot Option #7
Select an available network drive as the seventh boot option.
Boot Option #8
Select an available network drive as the eighth boot option.
Figure 3-102 UEFI Application Boot Priorities submenu screen
Table 3-90 Items on the UEFI Application Boot Priorities submenu screen
Item
Boot Option #1
Select a UEFI application as the first boot option.
Save & Exit menu
Figure 3-103 shows the Save & Exit menu, on which you can save the BIOS parameter settings and exit BIOS.
The menu items are described in Table 3-91.
Figure 3-103 Save & Exit menu screen
Table 3-91 Items on the Save & Exit menu screen
Item
Save Options
Save Changes and Exit
Exit with changes saved.
Discard Changes and Exit
Exit without saving changes.
Save Changes and Reset
Restart the server with changes saved.
Discard Changes and Reset
Restart the server without saving changes.
Save Changes
Save changes without exiting the BIOS.
Discard Changes
Discard changes without exiting the BIOS.
Default Options
Restore Defaults
Restore the factory-default settings.
Boot Override
Select a boot device option and press Enter to boot from that device.
This setting is a one-time setting that takes effect only at next boot. Subsequent boots will use the boot order configured on the Boot menu screen.
If you have not saved changes, a Save & Reset dialog box will open after you select a boot option for Boot Override.
·         To save the changes and reboot the server, select Yes.
·         To cancel the reboot, select No.
In legacy boot mode, a drive is eligible to be a boot option for Boot Override only if it has the highest priority (BBS priority) among all drives of the same type.
4 Mapping relations of PCH SATA/sSATA ports and drive backplane ports
This chapter describes the mapping relations of PCH SATA/sSATA ports on the system board and ports on the drive backplane connected by data cables when the embedded RAID controller is used. If only a mezzanine or standard storage controller is used, data cables connect ports on the drive backplane to the storage controller, instead of PCH SATA/sSATA ports on the system board.
H3C UniServer R4900 G3 server
8LFF HDDs
Storage controller
Ports on the drive backplane
Embedded RSTe RAID controller
PCH mini-SAS HD J11 port (logic SATA ports 0 through 7)
Ports 0 through 7
8LFF HDDs and 4LFF NVMe SSDs
Storage controller
Embedded RSTe RAID controller + 4-port NVMe expander module
(4-port NVMe expander module in PCIe slot 2)
8LFF HDDs
(embedded RSTe RAID controller)
Ports 0 through 7
4LFF NVMe SSDs
(4-port NVMe expander module)
N/A
N/A
8SFF HDDs
Storage controller
Ports 0 through 7
8SFF HDDs and 8SFF NVMe SSDs
Storage controller
Embedded RSTe RAID controller + 8-port NVMe expander module
(expander module in PCIe slot 2)
8SFF HDDs
Ports 0 through 7
8SFF NVMe SSDs
(8-port NVMe expander module)
N/A
N/A
Embedded RSTe RAID controller + 4-port NVMe expander modules
(expander modules in PCIe slots 2 and 5)
8SFF HDDs
Ports 0 through 7
8SFF NVMe SSDs
(4-port NVMe expander modules)
N/A
N/A
H3C UniServer R4700 G3 server
4LFF HDDs
Storage controller
PCH mini-SAS HD J11 port (logic SATA ports 0 through 3)
Ports 0 through 3
4LFF HDDs and 2SFF HDDs
Storage controller
4LFF HDDs
Ports 0 through 3
2SFF HDDs
PCH mini-SAS HD J11 port (logic SATA ports 4 and 5)
Ports 4 and 5
4SFF NVMe SSDs and 4SFF HDDs
Storage controller
(expander module in PCIe slot 1)
4SFF HDDs
Ports 4 through 7
4SFF NVMe SSDs
N/A
N/A
8SFF HDDs
Storage controller
Ports 0 through 7
8SFF HDDs and 2SFF HDDs
Storage controller
Embedded RSTe RAID controller + Mezzanine storage controller
2SFF HDDs
PCH mini-SAS HD J11 port (logic SATA ports 0 and 1)
Ports 8 and 9
8SFF HDDs
(Mezzanine storage controller)
N/A
N/A
Embedded RSTe RAID controller + standard storage controller
(standard storage controller in PCIe slot 1)
2SFF HDDs
Ports 8 and 9
8SFF HDDs
(standard storage controller)
N/A
N/A
8SFF NVMe SSDs and 2SFF HDDs
Storage controller
2SFF HDDs
Ports 8 and 9
8SFF NVMe SSDs
N/A
N/A
(expander modules in PCIe slots 1 and 2)
2SFF HDDs
Ports 8 and 9
8SFF NVMe SSDs
N/A
N/A
H3C UniServer R2900 G3 server
8LFF HDDs
Storage controller
Ports 0 through 7
12LFF HDDs
Storage controller
Ports 0 through 7
PCH mini-SAS HD J12 port (logic sSATA ports 2 through 5)
Ports 8 through 11
12LFF HDDs and 2SFF HDDs
Storage controller
Ports 0 through 7
Ports 8 through 11
PCH 7PIN SATA J13 port (logic sSATA ports 0 and 1)
Ports 28 and 29
Storage controller
8LFF HDDs
Ports 0 through 7
4LFF NVMe SSDs
N/A
N/A
8SFF HDDs
Storage controller
Ports 0 through 7
Storage controller
8SFF HDDs
Ports 0 through 7
8SFF NVMe SSDs
N/A
N/A
8SFF HDDs
Ports 0 through 7
8SFF NVMe SSDs
N/A
N/A
H3C UniServer R2700 G3 server
4LFF HDDs
Storage controller
Ports 0 through 3
N/A
N/A
Storage controller
4LFF HDDs
Ports 0 through 3
2SFF HDDs
Ports 4 and 5
Storage controller
4SFF HDDs
Ports 4 through 7
4SFF NVMe SSDs
N/A
N/A
8SFF HDDs
Storage controller
Ports 0 through 7
Storage controller
8SFF HDDs
Ports 0 through 7
2SFF HDDs
PCH mini-SAS HD J12 port (logic sSATA ports 2 and 3)
Ports 8 and 9
2SFF HDDs
Ports 8 and 9
8SFF HDDs
N/A
N/A
2SFF HDDs
Ports 8 and 9
8SFF HDDs
N/A
N/A
Storage controller
2SFF HDDs
Ports 8 and 9
8SFF NVMe SSDs
N/A
N/A
2SFF HDDs
Ports 8 and 9
8SFF NVMe SSDs
N/A
N/A
5 Acronyms and abbreviations
Table 5-1 Acronyms and abbreviations
Term
Definition
A
ACPI
Advanced Configuration and Power Interface
AES
Advanced Encryption Standard
AHCI
Advanced Host Controller Interface
APIC
Advanced Programmable Interrupt Controller
B
BIOS
Basic Input Output System
C
COD
Cluster On Die
CFG
Configure
CSM
Compatibility Support Module
D
DCU
Drive Control Unit
DMA
Direct Memory Access
DRAM
Dynamic Random Access Memory
E
E2E
End To End
ECC
Error Checking and Correcting
EFI
Extensible Firmware Interface
EHCI
Enhanced Host Controller Interface
EIST
EMS
Emergency Management Services
EMCA
Enhanced Machine Check Architecture
G
GPU
Graphics Processing Unit
H
HBA
Host Bus Adapter
HDM
H3C Device Management
I
IDE
Integrated Drive Electronics
IIO
Integrated I/O Module
IMC
Integrated Memory Controller
IRQ
Interrupt Request
M
MAC
Media Access Control
MCTP
Management Component Transport Protocol
ME
Management Engine
MMIO
Memory mapping I/O
MRC
Memory Reference Code
N
NIC
Network Interface Controller
NMI
Non-Maskable Interrupt
NUMA
Non Uniform Memory Access
O
OS
Operating System
P
PCH
Platform Controller Hub
PCI
Peripheral Component Interface
PCIe
Peripheral Component Interconnect Express
PCU
Power Controller Unit
PK
Platform Key
POR
Plan Of Record
POST
Power On Self Test
PXE
Preboot Execute Environment
R
RAID
Redundant Arrays of Independent Disks
RAPL
Running Average Power Limit
RAS
Reliability, Availability, Serviceability
RMT
Rank Margin Tool
ROM
Read-Only Memory
RTS/CTS
Request To Send/Clear To Send
S
SAS
Serial Attached SCSI
SATA
Serial Advanced Technology Attachment
SCSI
Small Computer System Interface
SEL
System Event Log
SMI
System Management Interrupt
SPD
Serial Presence Detect
SR-IOV
Single-Root I/O Virtualization
T
TCG
Trusted Computing Group
TDP
Thermal Design Power
TPM
Trusted Platform Module
TXT
Trusted Execution Technologies
U
UEFI
Unified Extensible Firmware Interface
UID
Unit Identification
UPI
Ultra Path Interconnect
V
VMD
VT-d
Intel Virtualization Technology For Directed I/O
VGA
Video Graphics Array
X
XHCI
eXtensible Host Controller Interface
