- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-ISSU configuration
- 09-Emergency shell configuration
- 10-Automatic configuration
- 11-Device management configuration
- 12-Tcl configuration
- 13-Python configuration
- 14-License management
14-License management | 114.70 KB |
Licenses for different device types
Restrictions and guidelines: License management
License consistency in an IRF fabric
License management tasks at a glance
Identifying the license storage
Compressing the license storage
Obtaining required information for license register
Restrictions and guidelines for license installation
Restrictions and guidelines for license uninstallation
Uninstalling an activation file
Display and maintenance commands for license management
Managing licenses
About licenses
License-based features, such as ACG, IPS, SSL VPN, and Web caching, require a license to run on your device.
License types
(In standalone mode.) You must purchase a license key for the entire device. To license the device, use the license key and the device's SN and DID to register an activation file and install the activation file on the device.
(In standalone mode.) (For features other than the unified wired and wireless AC feature.) You must purchase a license key for each IRF member device. To license an IRF member device, use the license key and the member's SN and DID to register an activation file and install the activation file on the IRF member device. An IRF member device is licensed even if the device joins another IRF fabric.
License operations
Make sure no one else is performing license management tasks on the device you are working with.
You can manage licenses only on the default MDC. Any license operation performed on the default MDC takes effect on all MDCs. For information about MDCs, see Virtual Technologies Configuration Guide.
Activation file operations
When you manage activation files, follow these restrictions and guidelines:
· Do not open and edit the files to avoid file corruption.
· Do not modify the names of the files to avoid licensing error.
· For licensed features to function correctly, do not delete files that are usable or in use in the flash:/license directory. The license management feature uses this directory for license management.
For licensed features to function correctly in an IRF fabric, make sure all IRF member devices are installed with the same licenses.
To manage licenses, perform the following tasks:
1. Identifying the license storage
2. (Optional.) Compressing the license storage
3. Obtaining required information for license register
6. Managing installed licenses
? Recovering an activation file
To identify the license storage, execute the following command in any view:
display license feature
From the command output, view the Total and Usage fields to examine whether the remaining license storage is sufficient for installing new licenses. If the remaining license storage is not sufficient, compress the license storage.
About license storage compression
Compress the license storage to delete expired and uninstalled license information to ensure sufficient storage space for installing new licenses.
The DID changes each time the license storage is compressed. Licenses generated based on the old DID cannot be installed after the compression.
1. Back up the Uninstall keys of uninstalled licenses.
When you uninstall an unexpired license, an Uninstall key is created. The Uninstall key is required for transferring the license.
2. Make sure all licenses generated based on the old DID have been installed.
3. Enter system view.
4. Compress the license storage.
In standalone mode:
license compress
In IRF mode:
license compress chassis chassis-number
1. (Optional.) Identify features to be licensed by using the display license feature command.
2. Obtain the following information:
? License key, which is obtained by purchasing the license.
? SN and DID information, which can be obtained by using the display license device-id command.
3. Back up the license key, SN, and DID information in case of loss.
Registering a license
If you cannot obtain or re-register the activation file due to problems such as operating system and browser errors, contact H3C Support.
1. Access http://www.h3c.com/en/License/, and select Register the First Time or Register Upgrade Licenses from the navigation tree.
Upgrade licenses are used for add-on nodes, add-on features, or time extensions.
2. Select the product category and use the license key, SN, and DID to register the license.
3. Obtain the activation file or activation key and download it to the PC.
Installing a license
When installing a license, the system automatically searches the storage media for a matching feature package. When a match is found, it stops searching and installs the package.
Installing an activation file
1. Enter system view.
2. Install an activation file.
In standalone mode:
license activation-file install license-file
In IRF mode:
license activation-file install license-file chassis chassis-number
Uninstalling a license
About license uninstallation
Perform this task to uninstall an unexpired formal license when the license remains unused for a while or needs to be transferred to another device.
After uninstallation, Uninstall keys are generated, which will be used for license transfer.
Trial licenses cannot be transferred. Uninstall a trial license does not create any uninstallation information.
Expired licenses cannot be uninstalled.
A license that was uninstalled on a device cannot be re-installed on the device. It can only be transferred to another device.
2. Uninstall an activation file.
In standalone mode:
license activation-file uninstall license-file
In IRF mode:
license activation-file uninstall license-file chassis chassis-number
Only unexpired activation files can be uninstalled.
Transferring a license
About license transfer
You can transfer a license from one device to another if the license has not expired.
1. Log in to the source device, and uninstall the license to obtain the uninstallation information. For more information, see "Uninstalling a license."
2. Obtain the Uninstall key of the license by using the display license command.
3. Access the target device and obtain SN and DID information. For more information, see "Obtaining required information for license register."
4. Register a license for the target device. For more information, see "Registering a license."
During the license register, you must provide SN and DID information of the target device and the Uninstall key of the source device.
5. Install the new license on the target device. For more information, see "Installing a license."
If you mistakenly delete an activation file, use the following procedure to recover the activation file:
1. Use the copy command to copy the backup activation file to directory flash:/license.
2. Use the display license command to verify that the state of the recovered activation file is In use.
3. Restart the device if the license state is In use but the licensed feature cannot function correctly.
Task |
Command |
Display detailed license information. |
In standalone mode: display license [ activation-file ] In IRF mode: display license [ activation-file ] [ chassis chassis-number ] |
Display the SN and DID information. |
In standalone mode: display license device-id In standalone mode: display license device-id chassis chassis-number |
Display brief feature license information. |
display license feature |
