| 03-Multicast VLAN Commands | 67.47 KB |
display multicast-vlan
display multicast-vlan [ vlan-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vlan-id: Specifies a VLAN by its ID, in the range of 1 to 4094. If this argument is not provided, the information about all multicast VLANs will be displayed.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display multicast-vlan to display information about the specified multicast VLAN.
# Display information about all multicast VLANs.
<Sysname> display multicast-vlan
Total 1 multicast-vlan(s)
Multicast vlan 100
subvlan list:
port list:
WLAN-ESS1
Total 1 multicast-vlan(s) |
Total number of multicast VLANs |
port list |
Port list of the multicast VLAN |
multicast-vlan
multicast-vlan vlan-id
undo multicast-vlan { all | vlan-id }
View
Default level
2: System level
all: Specifies all multicast VLANs.
Use multicast-vlan to configure the specified VLAN as a multicast VLAN and enter multicast VLAN view.
Use undo multicast-vlan to remove the specified multicast VLAN.
The VLAN to be configured is not a multicast VLAN by default.
The specified VLAN to be configured as a multicast VLAN must exist.
The multicast VLAN feature cannot be enabled on a device with IP multicast routing enabled.
For a port-based multicast VLAN, you need to enable IGMP snooping in both the multicast VLAN and all user VLANs.
# Enable IGMP snooping in VLAN 100. Configure it as a multicast VLAN and enter multicast VLAN view.
[Sysname] igmp-snooping
[Sysname-igmp-snooping] quit
[Sysname] vlan 100
[Sysname-vlan100] igmp-snooping enable
[Sysname-vlan100] quit
[Sysname] multicast-vlan 100
[Sysname-mvlan-100]
port (multicast VLAN view)
port interface-list
undo port { all | interface-list }
View
Multicast VLAN view
Default level
2: System level
interface-list: Specifies a port in the form of interface-type interface-number, or a port range in the form of interface-type start-interface-number to interface-type end-interface-number, where the end interface number must be greater than the start interface number.
all: Specifies all ports in the current multicast VLAN.
Use port to assign the specified port or ports to the current multicast VLAN.
Use undo port to delete the specified ports from the current multicast VLAN.
By default, a multicast VLAN has no ports.
A port can belong to only one multicast VLAN.
Only Ethernet ports, WLAN-MESH interfaces, and WLAN-ESS interfaces can be configured as multicast VLAN ports.
# Assign ports WLAN-ESS 2 through WLAN-ESS 3 to multicast VLAN 100.
[Sysname-mvlan-100] port WLAN-ESS 2 to WLAN-ESS 3
port multicast-vlan
port multicast-vlan vlan-id
undo port multicast-vlan
View
Ethernet interface view, WLAN-ESS interface view, Layer 2 aggregate interface view, port group view.
Default level
2: System level
Use port multicast-vlan to assign the current port or ports to the specified multicast VLAN.
Use undo port multicast-vlan to restore the default.
By default, a port does not belong to any multicast VLAN.
NOTE: Support for the command depends on your device model. For the command matrixes, see About the WX Series Access Controllers Command References. |
# Assign WLAN-ESS 1 to multicast VLAN 100.
[Sysname] interface WLAN-ESS 1
[Sysname-WLAN-ESS 1] port multicast-vlan 100
